AM437x : Board porting with TI RTOS sdk
Expert 1700 points
using this document :
5277.AM335x_AMIC110_Board_Porting_using_PRSDK.pdf
we are porting our applications that was based on IDKAM437x to a custom board.
with respect to board detect (page 8)
according to the document 2 files needs to be modified. as the custom board does not have the same functionality in the same HW , it needs to be overridden.
1) I could not find the function mentioned in the document "BoradID_detect. maybe the documentation lags behind the code ? I did find at
C:\ti\pdk_am437x_1_0_17\packages\ti\starterware\board\am43xx\board_am43xx.c the function boardId_t BoardGetIdAm43xx(void). can you confirm this is the function I need to change ?
2) the document points out that there are 2 places board id is read and used : board library and bootloader source. while I could find board_am43xx.c , I did not find xxxx_info.c . can you point out the exact names of the relevant files ?
