CPU Instruction Set Test Code for AM3703?
Other Parts Discussed in Thread: AM3703, TMS320C6472
I am wondering if there is assembly code available for doing a CPU Instruction Test on an AM3703 CPU (similar to OMAP35x).
It seems like this type of Power On Self Test code is available for some of your other products:
Is there any OMAP35x / AM37x CPU Instruction Set Assembly code similar to the list on page 2 of this document? http://focus.ti.com/general/docs/lit/getliterature.tsp?literatureNumber=spraas5a&fileType=pdf
The test contains the following modules:
• Module 1. Chk6xTest ()
Verifies the CPU instruction set. This module uses the following assembly files to perform the CPU
test:
– alu_64x.asm: arithmetic operations
– alu40.asm: 40-bit arithmetic
– basic_64x.asm: basic operations
– bit.asm: bit management
– circular_64x.asm: circular addressing instructions
– cond.asm: branch and conditional instructions
– mult_64x: multiplier operations
– sat_64x: saturation instructions
– spbuffer_b/le0/1.asm: software pipelined loop buffer
If this exists somewhere, I'd appreciate being pointed in the right direction as I've been unable to find it. Thanks! - Elijah
  • Elijah,
    I have never seen something like this internally. But as the AM35xx is based on standard ARMv7 (Cortex-A8) architecture you can use such code you can find in industry. There are a lot of other devices based on Cortex-A8.
    Not sure what you want to achieve with that? I would assume this to be a very rare case that only single instructions are failing on a device. I hereby assume that there are no issues with our core implementation...
    Regards.
  • >  Not sure what you want to achieve with that? I would assume this to be a very rare case that only single instructions are failing on a device. I hereby assume that there are no issues with our core implementation...
    Frank,
    Thank you for your reply. We don't know of any hardware issues, we simply want a way to perform a CPU self-test. Thank you for the information.
    Elijah
