AM4378: NAND Write protect issue
Part Number: AM4378
Good day TI Team,
On the custom board based on TI AM437x GP evm, we use the same NAND as MT29F4G08ABADAWP used on the GP .
From the u-boot, I couldn't able to write to the NAND. I can able to erase on the first time but cannot write. I have also changed the ecc from OMAP_ECC_BCH16_CODE_HW to OMAP_ECC_BCH8_CODE_HW as I was getting ecc errors.
Here is the log:
<debug_uart>
Passed early_system_init()
Under enable_board_pin_mux.... 1
Passed board_early_init_f()
Passed sdram_init()
U-Boot SPL 2019.01-g333c3e72d3 (Nov 24 2020 - 05:57:47 +0000)
Trying to boot from MMC1
SPL: Please implement spl_start_uboot() for your board
SPL: Direct Linux boot not active!
U-Boot 2019.01-g333c3e72d3 (Nov 24 2020 - 05:57:47 +0000)
CPU  : AM437X-GP rev 1.2
Model: TI AM437x GP EVM
DRAM:  1 GiB
PMIC:  TPS65218
NAND:  Found nand..
nand: selected OMAP_ECC_BCH8_CODE_HW
device found, Manufacturer ID: 0x2c, Chip ID: 0xdc
Micron MT29F4G08ABADAH4
512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
512 MiB Luma
MMC:   OMAP SD/MMC: 0
Loading Environment from FAT... OK
Net:   No ethernet found.
Hit any key to stop autoboot:  0
=> nand erase 0 0x20000
NAND erase: device 0 offset 0x0, size 0x20000
nand_erase_nand: start = 0x000000000000, len = 131072
Under nand_check_wp.. Status register: 0xe0
Erasing at 0x0 -- 100% complete.
OK
=> mw.b 0x82000000 0xff 0x1000
=> mw.b 0x82000000 0xfe 1
=> nand write.raw 0x82000000 0x0 0x1
NAND write: Under nand_check_wp.. Status register: 0x60
raw_access: error at offset 0, ret -5
 2112 bytes written: ERROR
nand_erase_nand: device is write protected!
nand0: MTD Erase failure: -5
OK
I have enable the debug in files: driver/mtd/nand/raw/nand_base.c and driver/mtd/nand/raw/omap_elm.c
Also added debug in nand_check_wp function under driver/mtd/nand/raw/nand_base.c
static int nand_check_wp(struct mtd_info *mtd)
	struct nand_chip *chip = mtd_to_nand(mtd);
	/* Broken xD cards report WP despite being writable */
	if (chip->options & NAND_BROKEN_XD)
		return 0;
	/* Check the WP bit */
	chip->cmdfunc(mtd, NAND_CMD_STATUS, -1, -1);
	printf("Under nand_check_wp.. Status register: 0x%x\n", chip->read_byte(mtd));
	return (chip->read_byte(mtd) & NAND_STATUS_WP) ? 0 : 1;
Please find the hardware schematics snip:
If I remove or populate the R410 (DNF) with zero ohm resistor, the issue remains the same.
I have tried to follow links to get some hint but invain:
e2e.ti.com/.../1964691
e2e.ti.com/.../571584
Any pointers are welcome. Please share if you need more info.
Ankur
  • Somehow the schematic is not pasted properly.
  • Hi Ankur,
    I've tried the same sequence of u-boot cmds on AM437x GP EVM, and not able to reproduce the issue in your test.
    I'm attaching the log file for your reference.
    Have you tried running the cmds like below?
    => mmc rescan
    => nand erase.chip
    => load mmc 0 ${loadaddr} MLO
    => nand write ${loadaddr} NAND.SPL ${filesize}
    -Hong
    OK
    => md.b 0x82000000 0x100
    82000000: fe ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    82000010: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    82000020: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    82000030: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    82000040: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    82000050: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    82000060: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    82000070: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    82000080: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    82000090: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    820000a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    820000b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    820000c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    820000d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    820000e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    820000f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
    NAND write:  4320 bytes written: OK
    => nand dump 0
    Page 00000000 dump:
    OOB:
    	ff 6d fd f7 e5 43 f7 e0
    	d5 1f fb fb ed 5d db f5
    	a7 cf 67 fd 7b 77 d7 f5
    	6f 57 e7 fd df 67 f7 fe
    	7f ed 1f 4d 47 e6 f7 ff
    	75 fc ff fb ff fc ff ff
    	bb 75 6f df ab 79 ff 77
    	9f dd ff df f9 f7 ff db
    	59 ff 4f fb 6e af e7 ff
    	9b 6d df f4 78 de f5 6f
    	e7 f7 ff 7a b5 7d fe bf
    	bd ff ff b7 9d ff fd bf
    	ff f7 ff ff ff d9 77 ff
    	ff 51 ff cb ff ef 65 ff
    	bd ff f2 5d 57 fe 7f ff
    	ff f7 7e dd 9d 5f de d7
    	7f d7 f7 7d f6 ff 9d b7
    	7f 5f fd ce 5e f5 9d 3d
    	bd f5 ff d6 df 57 0f 5f
    	ff d5 7e 5d 9c 77 73 7b
    	ff 8f af bb ff 7f ff 7e
    	5f df ff 77 d7 f3 3f ff
    	ff 1f 3f fb bf ff fe b7
    	ff de ff b9 fb df 74 bd
    	fc db f9 fc ff 5d fe 55
    	ff db fd d5 3c 55 ff d7
    	fd 17 fd ff fc 1f fd ca
    	ff 87 f5 e2 ed 9f f7 f7
