USB enable
Hi all,
i am trying to bring up USB on my custom board and these are the prints am getting,
and_davinci nand_davinci.0: hardware revision: 2.3
dm_spi.0: davinci SPI Controller driver at 0xc801e000 (irq = 42) use_dma=0
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
musb_hdrc: version 6.0, pio, host, debug=0
MUX: initialized GPIO33
musb_hdrc: USB Host mode controller at c8074000 using PIO, IRQ 12
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.18_pro500-davinci_evm-arm_v5t_le musb-hcd
usb usb1: SerialNumber: musb_hdrc
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
NIK:in hub_port_status:ret=4
mice: PS/2 mouse device common for all mice
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
RAMDISK: Compressed image found at block 0
Time: timer0_1 clocksource has been installed.
Clock event device timer0_0 configured with caps set: 08
Switched to high resolution mode on CPU 0
usb 1-1: new high speed USB device using musb_hdrc and address 2
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
NIK:in hub_port_status:ret=-32
hub 1-1:1.0: hub_port_status failed (err = -32)
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
VFS: Mounted root (ext2 filesystem).
Freeing init memory: 176K
can anybody tell what needs to be done to correct the error and why error 32 is coming....
thanks
  • Looks lik some issue with hub interfacing. Whats your usb layout? IS there any hub chip connected? I would recommend you to get your schematics reviewed by local TI representative. Also can you move to latest kernel as v2.6.18 is quite old.
    ajay
