Scrub that. Solved the problem with this post (of yesterday!):
http://e2e.ti.com/support/dsp/integra_dsparm/f/625/p/96453/336394.aspx
I have a new and related problem; after I type
make CROSS_COMPILE=arm-none-linux-gnueabi- ARCH=arm ti8168_evm_config_nand
I then run this to compile the second stage of uboot (as per the PDF):
make CROSS_COMPILE=arm-none-linux-gnueabi- ARCH=arm u-boot.ti
however after a while the build fails with this error message:
common/libcommon.a(env_nand.o): In function `nand_block_isbad':
/home/user/ezsdk/ti-ezsdk_c6a816x-evm_5_00_00_56/psp/u-boot-2010.06-psp04.00.00.07/include/nand.h:51: multiple definition of `env_ptr'
common/libcommon.a(env_nowhere.o):/home/user/ezsdk/ti-ezsdk_c6a816x-evm_5_00_00_56/psp/u-boot-2010.06-psp04.00.00.07/common/env_nowhere.c:41: first defined here
make: *** [u-boot] Error 1
I am following the instructions exactly yet the build fails. Please could you suggest a fix?
Ralph
