Hi... Everyone
Does anyone successfully boot up devkit8000 with 2.6.35 kernel?
Devkit8000 board is a clone Beagleboard..
I downloaded kernel 2.6.35.11 from http://www.kernel.org, cross-complied well, but there are two problem unfourtunatly.
The 1st. kernel can't recognize nand memory, after kernel panic with error message following booting is stoped.
[ 0.923767] omap2-nand: probe of omap2-nand failed with error -16
[ 0.931396] UBI error: ubi_init: UBI error: cannot initialize UBI, error -19
The 2nd is could'nt setup omapfb
[ 1.385162] omapfb omapfb: no driver for display
[ 1.389953] omapfb omapfb: failed to setup omapfb
Could you show me the way to escape from this hell
There are booing message following
Thanks in advance
Starting kernel ...
[ 0.000000] Linux version 2.6.35.11 (human@desktop) (gcc version 4.3.3 (GCC) ) #4 Wed Mar 2 14:41:10 KST 2011
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: OMAP3 Devkit8000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430/3530 ES3.1 (l2cache iva sgx neon isp )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000
[ 0.000000] Reserving 12582912 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyS2,115200n8 ubi.mtd=4 root=ubi0:rootfs rootfstype=ubifs vram=12M omapfb.vrc
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 128MB 128MB = 256MB total
[ 0.000000] Memory: 242736k/242736k available, 19408k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0034000 ( 176 kB)
[ 0.000000] .text : 0xc0034000 - 0xc044b000 (4188 kB)
[ 0.000000] .data : 0xc046a000 - 0xc049eee0 ( 212 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] Verbose stalled-CPUs detection is disabled.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/266/500 MHz
[ 0.000000] omap_hwmod: l3_hwmod: cannot be enabled (3)
[ 0.000000] omap_hwmod: l4_core_hwmod: cannot be enabled (3)
[ 0.000000] omap_hwmod: l4_per_hwmod: cannot be enabled (3)
[ 0.000000] omap_hwmod: l4_wkup_hwmod: cannot be enabled (3)
[ 0.000000] Reprogramming SDRC clock to 266000000 Hz
[ 0.000000] dpll3_m2_clk rate change failed: -22
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 479.96 BogoMIPS (lpj=1871872)
[ 0.000000] pid_max: default: 32768 minimum: 301
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000030] OMAP DMA hardware revision 4.0
[ 0.017669] bio: create slab <bio-0> at 0
[ 0.020385] SCSI subsystem initialized
[ 0.022857] usbcore: registered new interface driver usbfs
[ 0.023132] usbcore: registered new interface driver hub
[ 0.023406] usbcore: registered new device driver usb
[ 0.024291] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 0.028289] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.028320] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.028930] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.031921] regulator: VUSB1V5: 1500 mV normal standby
[ 0.032684] regulator: VUSB1V8: 1800 mV normal standby
[ 0.033355] regulator: VUSB3V1: 3100 mV normal standby
[ 0.035064] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 0.036285] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
[ 0.036956] regulator: VDAC: 1800 mV normal standby
[ 0.037628] regulator: VDVI: 1800 mV normal standby
[ 0.038391] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
[ 0.038635] i2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHz
[ 0.040466] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.041412] NET: Registered protocol family 23
[ 0.041503] Bluetooth: Core ver 2.15
[ 0.041748] NET: Registered protocol family 31
[ 0.041748] Bluetooth: HCI device and connection manager initialized
[ 0.041778] Bluetooth: HCI socket layer initialized
[ 0.041809] Switching to clocksource 32k_counter
[ 0.063659] musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
[ 0.066864] musb_hdrc musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 0.067504] NET: Registered protocol family 2
[ 0.067749] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.068359] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.068603] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.068756] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.068756] TCP reno registered
[ 0.068786] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.068817] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.069061] NET: Registered protocol family 1
[ 0.069458] RPC: Registered udp transport module.
[ 0.069488] RPC: Registered tcp transport module.
[ 0.069488] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.070312] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.072296] VFS: Disk quotas dquot_6.5.2
[ 0.072418] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.074096] JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[ 0.074737] msgmni has been set to 474
[ 0.078399] alg: No test for stdrng (krng)
[ 0.078491] io scheduler noop registered
[ 0.078491] io scheduler deadline registered
[ 0.078674] io scheduler cfq registered (default)
[ 0.079925] OMAP DSS rev 2.0
[ 0.080047] OMAP DISPC rev 3.0
[ 0.080108] OMAP VENC rev 2
[ 0.247161] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.268585] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
[ 0.288757] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
[ 0.308837] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
[ 0.888610] console [ttyS2] enabled
[ 0.904388] brd: module loaded
[ 0.913879] loop: module loaded
[ 0.919555] omap2-nand driver initializing
[ 0.938659] dm9000 Ethernet Driver, V1.31
[ 1.034240] dm9000 dm9000: eth%d: Invalid ethernet MAC address. Please set using ifconfig
[ 1.043212] eth0: dm9000a at d08bc000,d08c0400 IRQ 185 MAC: 00:00:00:00:00:00 (chip)
[ 1.051300] usbmon: debugfs is not available
[ 1.055603] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.062744] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 1.068542] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 1.076202] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 1.096649] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 1.102600] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.109466] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.116760] usb usb1: Product: OMAP-EHCI Host Controller
[ 1.122131] usb usb1: Manufacturer: Linux 2.6.35.11 ehci_hcd
[ 1.127868] usb usb1: SerialNumber: ehci-omap.0
[ 1.133453] hub 1-0:1.0: USB hub found
[ 1.137298] hub 1-0:1.0: 3 ports detected
[ 1.168395] input: TWL4030 Keypad as /devices/platform/i2c_omap.1/i2c-1/1-004a/twl4030_keypad/input/input0
[ 1.179931] ads7846 spi2.0: unable to get regulator: -19
[ 1.186126] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 1.192443] twl_rtc twl_rtc: Power up reset detected.
[ 1.197875] twl_rtc twl_rtc: Enabling TWL-RTC.
[ 1.202880] i2c /dev entries driver
[ 1.207885] sdhci: Secure Digital Host Controller Interface driver
[ 1.214172] sdhci: Copyright(c) Pierre Ossman
[ 1.223632] usbcore: registered new interface driver usbhid
[ 1.229278] usbhid: USB HID core driver
[ 1.311737] No device for DAI omap-mcbsp-dai-0
[ 1.316253] No device for DAI omap-mcbsp-dai-1
[ 1.320739] No device for DAI omap-mcbsp-dai-2
[ 1.325225] No device for DAI omap-mcbsp-dai-3
[ 1.329711] No device for DAI omap-mcbsp-dai-4
[ 1.334197] OMAP3 Beagle/Devkit8000 SoC init
[ 1.340484] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 1.349761] ALSA device list:
[ 1.352752] #0: omap3beagle (twl4030)
[ 1.356964] TCP cubic registered
[ 1.360198] NET: Registered protocol family 17
[ 1.364807] NET: Registered protocol family 15
[ 1.369873] Power Management for TI OMAP3.
[ 1.374359] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[ 1.395233] regulator_init_complete: incomplete constraints, leaving VDVI on
[ 1.402496] regulator_init_complete: incomplete constraints, leaving VDAC on
[ 1.411163] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 1.424987] UBIFS error (pid 1): ubifs_get_sb: cannot open "ubi0:rootfs", error -19
[ 1.432769] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0)
[ 1.439849] Please append a correct "root=" boot option; here are the available partitions:
[ 1.448333] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
