AM3352: USB flash drive doesn't get detected
Part Number: AM3352
We have this one board which doesn't detect any USB device (flash drive or micro USB cable). We are using kernel version 4.9.31 (Arago Krogoth).
Below are the logs when a USB flash device is connected to the board using an OTG cable. Any idea what could be wrong?
[ 386.489585] usb 1-1: new full-speed USB device number 2 using musb-hdrc
[ 386.629721] usb 1-1: device descriptor read/64, error -71
[ 386.889731] usb 1-1: device descriptor read/64, error -71
[ 387.149738] usb 1-1: new full-speed USB device number 3 using musb-hdrc
[ 387.289726] usb 1-1: device descriptor read/64, error -71
[ 387.549789] usb 1-1: device descriptor read/64, error -71
[ 387.809734] usb 1-1: new full-speed USB device number 4 using musb-hdrc
[ 388.249723] usb 1-1: device not accepting address 4, error -71
[ 388.389744] usb 1-1: new full-speed USB device number 5 using musb-hdrc
[ 388.829709] usb 1-1: device not accepting address 5, error -71
[ 388.829916] usb usb1-port1: unable to enumerate USB device
Fariya
  • Hi Fariya,
    Does the USB port can detect any other USB device?
    Do you use the USB0 or USB1 port?
    Please run the following script on your board after the failure and provide the output.
    #!/bin/bash
    # Util to check USB subsystem for Linux kernel 3.12+ on TI Sitara devices
    # Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/
    #  Redistribution and use in source and binary forms, with or without
    #  modification, are permitted provided that the following conditions
    #  are met:
    #    Redistributions of source code must retain the above copyright
    #    notice, this list of conditions and the following disclaimer.
    #    Redistributions in binary form must reproduce the above copyright
    #    notice, this list of conditions and the following disclaimer in the
    #    documentation and/or other materials provided with the
    #    distribution.
    #    Neither the name of Texas Instruments Incorporated nor the names of
    #    its contributors may be used to endorse or promote products derived
    #    from this software without specific prior written permission.
    #  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    #  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    #  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    #  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    #  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    #  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    #  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    #  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    #  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    #  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    #  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    VERSION=0.3.0
    DTPATH=/proc/device-tree
    DEVPATH=/sys/devices/platform
    KMODPATH="/lib/modules/`uname -r`"
    ### ENV
    # $V: debug flag
    # $PLATFORM: force g_plaform if not found in device tree
    ### functions ###
    # $1 commands to be checked
    check_command() {
        local _lst="$*"
        local _cmd
        for _cmd in $_lst; do
            which $_cmd > /dev/null || {
                echo "Error: $_cmd command not found"
                exit 1
        done
    # check if the kernel is supported
    # this tool only runs on v4.0+ kernel
    # return 0 - if kernel version >= 4.0
    #        1 - if kernel version < 4.0
    has_supported_kernel() {
    	local _ver
    	local _t
        check_command uname
        uname -a
    	_ver=`uname -r`
        _t=${_ver%%.*}
        # 3.x.x or older, unsupported
        [ $_t -ge 4 ] || return 1
        return 0
    # define variables for musb entries in sysfs and device tree
    # output variables: USB_DT_PARENT, USB0DT, USB1DT
    #                   USB_DEV_PARENT, USB0DEV, USB1DEV
    query_musb_entries() {
        local _lst
        local _t
        local _intr
        check_command find
        # find usb entry names in device-tree
        _t=$(find ${DTPATH}/ -maxdepth 2 -name '*47400000*')
        [ -n "$_t" ] && USB_DT_PARENT=$_t || {
            echo "usb parent DT node not found in device-tree"
            exit 1
        _lst=$(find ${USB_DT_PARENT}/ -maxdepth 1 -name 'usb@*')
        [ -n "$_lst" ] || {
            echo "usb0 and usb1 DT node not found in device-tree"
            exit 1
        # find USB child DT node based on its interrupt number
        for _t in $_lst; do
            [[ -f "${_t}/interrupts" ]] || continue
            _intr=$(hexdump ${_t}/interrupts | head -1 | cut -d' ' -f3)
            case $_intr in
                "1200") USB0DT=$_t;;
                "1300") USB1DT=$_t;;
                *)  echo "unkown usb interrupt number $_intr"
                    exit 1
            esac
        done
        # find device names in sysfs
        _t=$(find ${DEVPATH}/ -maxdepth 2 -name '*47400000*')
        [ -n "$_t" ] && USB_DEV_PARENT=$_t || {
            echo "usb device not found in sysfs"
            exit 1
        _t=$(find ${USB_DEV_PARENT}/47401400.usb/ -maxdepth 1 -name 'musb-hdrc.*')
        [ -n "$_t" ] && USB0DEV=$_t || echo "usb0 device not found in sysfs"
        _t=$(find ${USB_DEV_PARENT}/47401c00.usb/ -maxdepth 1 -name 'musb-hdrc.*')
        [ -n "$_t" ] && USB1DEV=$_t || echo "usb1 device not found in sysfs"
    # check if the platform is supported
    # return 0 - if platform is supported
    #        1 - if platform is not supported
    check_platform () {
    	local _hw
        check_command grep
        _hw=`cat ${DTPATH}/compatible | tr '\0' ' '`
        DBG_PRINT "DT compatible: $_hw"
        if [[ "$_hw" == *"ti,am33xx"* ]]; then
            g_platform="am335x"
        elif [[ "$_hw" == *"ti,am43"* ]]; then
            g_platform="am437x"
        else
            # read from ENV
            g_platform=$PLATFORM
        fi
        DBG_PRINT "g_platform: $g_platform"
        case $g_platform in
            "am335x")
                query_musb_entries
                return 0;;
            "am437x")
                USB0DT="$(find $DTPATH -name 'usb@48390000')"
                USB1DT="$(find $DTPATH -name 'usb@483d0000')"
                return 0;;
                echo "Unsupported \"$g_platform\""
                return 1;;
        esac
    # get kernel config options from /proc/config.gz
    # params $@ - the list of config options to query, without 'CONFIG_'
    # return - the config options settings in /proc/config.gz
    get_kernel_configs() {
        local _opts="$@"
        local _lst=""
        local _t
        check_command zcat grep
        for _t in $_opts; do
            [ -z "$_lst" ] &&
                _lst="^CONFIG_${_t}\>" ||
                _lst="${_lst}\|^CONFIG_${_t}\>"
        done
        [ -z "$_lst" ] || zcat /proc/config.gz | grep "$_lst"
    # check a kernel CONFIG option
    # params $1 - the config option list returned from get_kernel_config()
    #             if "", directly check $2 from /proc/config.gz
    #        $2 - the config option to check
    #        $3 = '-q', quiet output
    # return 0 - undefined
    #        1 - defined as 'm', kernel module
    #        2 - defined as 'y', kernel builtin
    check_kernel_config() {
        local _cfg
        local _t
        [ -n "$2" ] || return 0
        if [ -z "$1" ]; then
            check_command zcat
            _cfg=`zcat /proc/config.gz | grep "^$2\>"`
        else
            for _t in $1; do
                [[ "$_t" != "${2}="? ]] || { _cfg=$_t; break; }
            done
        fi
        case ${_cfg#*=} in
            "y") return 2;;
            "m") return 1;;
              *) [ "$3" = "-q" ] ||
                  echo "Error: $2 is undefined in kernel config"
              return 0;;
        esac
    # check a kernel module
    # $1 - module name, relative path from drivers/, without .ko surfix
    # return 0 - found
    #        1 - error
    check_module() {
        local _modname
        local _moddep
        [ -n "$1" ] || return 1
        _modname="${KMODPATH}/kernel/drivers/${1}.ko"
        _moddep="${KMODPATH}/modules.dep"
        DBG_PRINT "${1}.ko checking..."
        [ -f $_modname ] || {
            echo "Error: $_modname not found."
            echo "       Please ensure 'make module_install' is done properly."
            return 1
        DBG_PRINT "${1}.ko found"
        [ -f $_moddep ] || $g_printed_once || {
            echo "Error: $_moddep not found."
            g_printed_once=true
        DBG_PRINT "${1}.ko moddep checked"
        check_command lsmod basename tr
        lsmod | grep `basename $1 | tr '-' '_'` > /dev/null || {
            DBG_PRINT ">>>> ${1}.ko not found in lsmod:"
            if grep "${1}.ko:" $_moddep > /dev/null; then
                echo "Error: $_moddep seems to be valid,"
                echo "       but `basename $1`.ko is not loaded."
                echo "       Please provide /proc/config.gz and ${KMODPATH}/*"
                echo "       for further investigation."
            else
                echo "Error: `basename $1`: $_moddep is invalid."
                echo "       Please run command 'depmod' on the target to re-generate it,"
                echo "       then reboot the target. If the issue still exists, please"
                echo "       ensure 'make module_install' is done properly."
            fi
            return 1
        DBG_PRINT "${1}.ko done"
        return 0
    # check kernel config, and modules (if CONFIG_*=M) for musb
    check_musb_drivers() {
        local _lst=("USB_MUSB_HDRC" "USB_MUSB_DUAL_ROLE" "USB_OTG" "USB_MUSB_DSPS" \
                    "AM335X_PHY_USB" "MUSB_PIO_ONLY" "TI_CPPI41")
        local _opts
        _opts=$(get_kernel_configs ${_lst[*]})
        check_kernel_config "$_opts" CONFIG_USB_MUSB_HDRC
        [ $? != 1 ] || check_module 'usb/musb/musb_hdrc'
        check_kernel_config "$_opts" CONFIG_USB_MUSB_DUAL_ROLE -q
        [ $? != 0 ] || echo "Warning: CONFIG_USB_MUSB_DUAL_ROLE undefined."
        check_kernel_config "$_opts" CONFIG_USB_OTG -q
        [ $? == 0 ] || echo "Warning: CONFIG_USB_OTG defined."
        check_kernel_config "$_opts" CONFIG_USB_MUSB_DSPS
        [ $? != 1 ] || {
            check_module 'usb/musb/musb_dsps'
        check_kernel_config "$_opts" CONFIG_AM335X_PHY_USB
        [ $? != 1 ] || {
            check_module 'usb/phy/phy-am335x'
            check_module 'usb/phy/phy-am335x-control'
        check_kernel_config "$_opts" CONFIG_MUSB_PIO_ONLY -q
        [ $? != 0 ] || {
           if check_kernel_config "$_opts" CONFIG_TI_CPPI41 -q; then
               echo "Error: MUSB CPPI DMA mode is enabled, but CPPI moudle is not enabled in DMA Engine."
               echo "       Please enable CONFIG_TI_CPPI41 under DMA Engine Support in kernel config."
           fi
    # check kernel config, and modules (if CONFIG_*=M) for dwc3
    check_dwc3_drivers() {
        local _lst=("USB_DWC3" "USB_DWC3_DUAL_ROLE" "USB_OTG" "USB_DWC3_OMAP" \
                    "USB_XHCI_HCD" "OMAP_CONTROL_PHY" "OMAP_USB2")
        local _opts
        check_kernel_config "$_opts" CONFIG_USB_DWC3
        [ $? != 1 ] || check_module 'usb/dwc3/dwc3'
        check_kernel_config "$_opts" CONFIG_USB_DWC3_DUAL_ROLE -q
        [ $? != 0 ] || echo "Warning: CONFIG_USB_DWC3_DUAL_ROLE undefined."
        check_kernel_config "$_opts" CONFIG_USB_DWC3_OMAP
        [ $? != 1 ] || check_module 'usb/dwc3/dwc3-omap'
        check_kernel_config "$_opts" CONFIG_USB_XHCI_HCD
        [ $? != 1 ] || {
            check_module 'usb/host/xhci-plat-hcd'
            check_module 'usb/host/xhci-hcd'
        check_kernel_config "$_opts" CONFIG_OMAP_CONTROL_PHY
        [ $? != 1 ] || check_module 'phy/phy-omap-control'
        check_kernel_config "$_opts" CONFIG_OMAP_USB2
        [ $? != 1 ] || check_module 'phy/phy-omap-usb2'
    check_musb_dt() {
        local _dt_dir
        local _ent
        local _sts
        local _t
        case $USB_DT_PARENT in
            *"usb@"*)
                _ent=("control@44e10620" "usb-phy@47401300" "usb-phy@47401b00" \
                      "usb@47401000" "usb@47401800" "dma-controller@47402000")
            *"target-module@"*)
                _ent=("usb-phy@1300" "usb-phy@1b00" "usb@1400" "usb@1800" \
                      "dma-controller@2000")
                echo "Warning: unknown USB DT ($USB_DT_PARENT)"
                return
        esac
        echo "Device Tree USB node status:"
        for _t in '.' ${_ent[*]}; do
            [ -d "${USB_DT_PARENT}/${_t}/" ] || {
                echo -e "\tWarning: USB DT node $_t not found"
                continue
            [ -f "${USB_DT_PARENT}/${_t}/status" ] &&
                _sts=$(tr -d '\0' <${USB_DT_PARENT}/${_t}/status) ||
                _sts="(enabled)"
            echo -e "\t$_t: $_sts"
        done
    dump_sysfs_debugfs() {
        local _debugfs
        local _l
        local _f
        _debugfs=`sed -ne 's/^debugfs \(.*\) debugfs.*/\1/p' /proc/mounts`
        [ -n "$_debugfs" ] || return
        case $g_platform in
            am335x)
                _debugfs=$(find $_debugfs -name 'musb-hdrc.*')
                _debugfs=${_debugfs%/*}
                for _f in $USB0DEV $USB1DEV; do
                    _l=$(basename $_f)
                    echo "$_l: mode $(cat ${_f}/mode), $(cat ${_f}/vbus)"
                    grep -i 'power\|devctl\|testmode' ${_debugfs}/${_l}/regdump
                done
        esac
    check_gadget_kernel_config() {
        local _lst=("USB_ZERO" "USB_AUDIO" "USB_ETH" "USB_G_NCM" "USB_MASS_STORAGE" \
                    "USB_G_SERIAL" "USB_G_PRINTER")
        local _opts
        check_kernel_config "$_opts" CONFIG_USB_ZERO -q ||
            echo "Gadget Kernel Config: g_zero is enabled"
        check_kernel_config "$_opts" CONFIG_USB_AUDIO -q ||
            echo "Gadget Kernel Config: g_audio is enabled"
        check_kernel_config "$_opts" CONFIG_USB_ETH -q ||
            echo "Gadget Kernel Config: g_ether is enabled"
        check_kernel_config "$_opts" CONFIG_USB_G_NCM -q ||
            echo "Gadget Kernel Config: g_ncm is enabled"
        check_kernel_config "$_opts" CONFIG_USB_MASS_STORAGE -q ||
            echo "Gadget Kernel Config: g_mass_storage is enabled"
        check_kernel_config "$_opts" CONFIG_USB_G_SERIAL -q ||
            echo "Gadget Kernel Config: g_serial is enabled"
        check_kernel_config "$_opts" CONFIG_USB_G_PRINTER -q ||
            echo "Gadget Kernel Config: g_printer is enabled"
    ### debug ###
    g_log_file=/tmp/chkusb.log
    DBG_ENABLE() { g_dbg_enabled=true; }
    DBG_DISABLE() { g_dbg_enabled=false; }
    DBG_LOG_RESET() { ! $g_dbg_enabled || echo > $g_log_file; }
    DBG_PRINT() { ! $g_dbg_enabled || echo "$(date +%H:%M:%S) [$(basename $0)]: $*"; }
    DBG_LOG() { DBG_PRINT $* >> $g_log_file; }
    DBG_LOG_MARK() { DBG_PRINT "----------------" >> $g_log_file; }
    ### main ####
    g_printed_once=false
    echo "chkusb.sh Version $VERSION"
    [ "$V" = "1" ] && DBG_ENABLE && DBG_LOG_RESET || DBG_DISABLE
    has_supported_kernel ||
        { echo "Unsupported kernel version: `uname -r`"; exit 1; }
    check_platform || exit 2
    DBG_PRINT device: $g_platform
    [ -d ${DTPATH} ] || { echo "Error: ${DTPATH} not found"; exit 3; }
    check_command lsusb
    if lsusb > /dev/null 2>&1; then
        echo "USB is initialized"
    else
        echo "USB initialization failed"
    fi
    # check kernel configs
    if [ -f /proc/config.gz ]; then
        case $g_platform in
            am335x) check_musb_drivers;;
            am437x) check_dwc3_drivers;;
        esac
    else
        echo "Error: /proc/config.gz not found"
    fi
    dump_sysfs_debugfs
    # check dr_mode & gadget drivers
    check_command basename
    for _usb_dir in "${USB0DT}" "${USB1DT}"; do
        [ -n "$_usb_dir" ] || continue
        [ -f "$_usb_dir/status" ] &&
            _status=`tr -d '\0' <$_usb_dir/status` ||
            _status='(enabled)'
        _dr_mode=`tr -d '\0'  <$_usb_dir/dr_mode`
        echo `basename $_usb_dir`: $_dr_mode, $_status
        [ "$_status" = "disabled" -o "$_dr_mode" = "host" ] || gadget_mode=true
    done
    case $g_platform in
        am335x) check_musb_dt;;
    esac
    DBG_PRINT $gadget_mode
    $gadget_mode || exit 0
    echo
    check_kernel_config "" CONFIG_USB_LIBCOMPOSITE
    case $? in
        0) echo "Error: no any gadget driver enabled"
           exit 6;;
        1) is_gadget_builtin=false;;
        2) echo "The gadget driver is built-in"
           is_gadget_builtin=true;;
    esac
    [[ ! -f /proc/config.gz ]] || check_gadget_kernel_config
    g_driver=`grep '^DRIVER=' /sys/class/udc/*/uevent 2>/dev/null`
    echo "gadget driver loaded: ${g_driver:-(none)}"
    [[ $is_gadget_builtin == false ]] || exit 0
    echo
    if [ -d "$KMODPATH" ]; then
        echo "The list of USB gadget drivers installed:"
        ls -1Rp ${KMODPATH}/kernel/drivers/usb/gadget/{function,legacy}/
    else
        echo "Error: $KMODPATH not found"
        echo "       Please ensure 'make modules_install' is done properly."
        exit 7
    fi
    # vim: ft=sh:ts=4:sw=4:et
  • Hi Bin,
    Below is the output:
    chkusb.sh Version 0.3.0
    Linux beaglebone 4.9.31-gf9f6f0db2d #25 PREEMPT Tue Oct 29 01:06:33 EDT 2019 armv7l armv7l armv7l GNU/Linux
    find: '/sys/devices/platform/ocp/47400000.usb/47401c00.usb/': No such file or directory
    USB is initialized
    musb-hdrc.0: mode b_idle, Vbus off, timeout 1100 msec
    /sys/kernel/debug/musb-hdrc.0/regdump:Power : e0
    /sys/kernel/debug/musb-hdrc.0/regdump:Testmode : 00
    /sys/kernel/debug/musb-hdrc.0/regdump:DevCtl : 80
    usb@47401000: otg, okay
    .: okay
    control@44e10620: okay
    usb-phy@47401300: okay
    Warning: USB DT node usb-phy@47401b00 not found
    usb@47401000: okay
    Warning: USB DT node usb@47401800 not found
    dma-controller@47402000: okay
    gadget driver loaded: DRIVER=configfs-gadget
    /lib/modules/4.9.31-gf9f6f0db2d/kernel/drivers/usb/gadget/function/:
    u_ether.ko
    u_serial.ko
    usb_f_acm.ko
    usb_f_ecm.ko
    usb_f_ecm_subset.ko
    usb_f_fs.ko
    usb_f_hid.ko
    usb_f_mass_storage.ko
    usb_f_midi.ko
    usb_f_ncm.ko
    usb_f_obex.ko
    usb_f_printer.ko
    usb_f_rndis.ko
    usb_f_serial.ko
    usb_f_ss_lb.ko
    usb_f_uac2.ko
    usb_f_uvc.ko
    /lib/modules/4.9.31-gf9f6f0db2d/kernel/drivers/usb/gadget/legacy/:
    g_acm_ms.ko
    g_audio.ko
    g_cdc.ko
    g_dbgp.ko
    g_ether.ko
    g_ffs.ko
    g_hid.ko
    g_mass_storage.ko
    g_midi.ko
    g_multi.ko
    g_ncm.ko
    g_printer.ko
    g_serial.ko
    g_webcam.ko
    g_zero.ko
    gadgetfs.ko
    The USB port doesn't detect any USB device.
    Fariya
  • Hi Fariya,
    Please probe if the USB0_ID pin is grounded (<100ohm) properly when a USB device is attached.
  • And ensure USB VBUS is close to 5V.
  • Hi Bin,
    USB0_ID is properly grounded at ~1ohm and VBUS is at 5V.
    Fariya
  • Hi Fariya,
    Just for testing, can you please modify the dts to add dr_mode = "host" in the USB0 node, to see if the USB port can enumerate devices?
    This setting configure the USB port to host-only mode.
  • Hi Bin Liu,
    Setting dr_mode to host doesn't help, none of the USB devices get detected even after this.
    Fariya
  • Hi Fariya,
    And you still see the "-71" error message as in your first post above?
    What other USB devices have you tested with? Are they all high-speed device? The log in your first post showing detected full-speed. Can you please check your board layout to ensure USB DP and DM lines are not swapped between AM335x and the USB receptacle?
  • Hi Bin Liu,
    We have majorly tried connecting a USB cable and a Samsung 32 gb, USB 3.0 with micro usb port onto our board. Both the USB cable and the USB flash drive didn't get detected. There are 1 -2 boards on which the devices are not getting detected and this is not the issue with all boards and so we want to understand what could be wrong on these 1 -2 boards.
    Fariya
  • Hi Fariya,
    The working and non-working boards are all from the same manufacturing batch? This sounds like an assembly issue.
