TDA4VM: Reduced PCIe initialization time.
Part Number: TDA4VM
HI Sir :
I compared the system boot time with PCIe RC enable and disable.
The PCIe will take 3.639,765 seconds.
Is there any way to reduce the PCIe initialization time?
TDA4 EVM Device Tree for Disable PCIe RC
k3-j721e-common-proc-board.dts
&pcie0_rc {
	status = "disabled";
&pcie1_rc {
&pcie2_rc {
&pcie0_ep {
&pcie1_ep {
&pcie2_ep {
&pcie3_rc {
&pcie3_ep {
TDA4 EVM Log for Disable PCIe RC
[2021-01-08@15:0:49.306]U-Boot SPL 2020.01-g2b4a28f (Jan 08 2021 - 14:34:42 +0800)
[2021-01-08@15:0:49.306]SYSFW ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[2021-01-08@15:0:49.478]Trying to boot from MMC2
[2021-01-08@15:0:49.634]Loading Environment from MMC... *** Warning - No MMC card found, using default environment
[2021-01-08@15:0:50.144]Remoteproc 2 started successfully
[2021-01-08@15:0:50.400]Starting ATF on ARM64 core...
[2021-01-08@15:0:50.400]NOTICE:  BL31: v2.3():07.00.00.005-dirty
[2021-01-08@15:0:50.400]NOTICE:  BL31: Built : 14:33:55, Jun 17 2020
[2021-01-08@15:0:50.512]
[2021-01-08@15:0:50.515]U-Boot SPL 2020.01-g2b4a28f (Jan 08 2021 - 14:34:48 +0800)
[2021-01-08@15:0:50.516]SYSFW ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[2021-01-08@15:0:50.544]Detected: J7X-BASE-CPB rev E3
[2021-01-08@15:0:50.560]Detected: J7X-VSC8514-ETH rev E2
[2021-01-08@15:0:50.560]Diagnostic Key Check
[2021-01-08@15:0:50.672]Trying to boot from MMC2
[2021-01-08@15:0:51.184]
[2021-01-08@15:0:51.187]
[2021-01-08@15:0:51.187]U-Boot 2020.01-g2b4a28f (Jan 08 2021 - 14:34:48 +0800)
[2021-01-08@15:0:51.187]SoC:   J721E SR1.0
[2021-01-08@15:0:51.187]Model: Texas Instruments K3 J721E SoC
[2021-01-08@15:0:51.204]Board: J721EX-PM2-SOM rev E7
[2021-01-08@15:0:51.204]DRAM:  4 GiB
[2021-01-08@15:0:51.220]Flash: 0 Bytes
[2021-01-08@15:0:51.232]MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
[2021-01-08@15:0:51.392]Loading Environment from MMC... OK
[2021-01-08@15:0:51.392]In:    serial@2800000
[2021-01-08@15:0:51.408]Out:   serial@2800000
[2021-01-08@15:0:51.409]Err:   serial@2800000
[2021-01-08@15:0:51.472]Detected: J7X-BASE-CPB rev E3
[2021-01-08@15:0:51.488]Detected: J7X-VSC8514-ETH rev E2
[2021-01-08@15:0:51.488]Net:   eth0: ethernet@046000000
[2021-01-08@15:0:53.496]Hit any key to stop autoboot:  0
[2021-01-08@15:0:53.808]switch to partitions #0, OK
[2021-01-08@15:0:53.808]mmc1 is current device
[2021-01-08@15:0:54.074]SD/MMC found on device 1
[2021-01-08@15:0:54.074]58 bytes read in 1 ms (56.6 KiB/s)
[2021-01-08@15:0:54.074]Loaded env from uEnv.txt
[2021-01-08@15:0:54.090]Importing environment from mmc1 ...
[2021-01-08@15:0:54.105]95476 bytes read in 10 ms (9.1 MiB/s)
[2021-01-08@15:0:54.121]Load Remote Processor 3 with data@addr=0x80080000 95476 bytes: Success!
[2021-01-08@15:0:54.136]95476 bytes read in 8 ms (11.4 MiB/s)
[2021-01-08@15:0:54.136]Load Remote Processor 4 with data@addr=0x80080000 95476 bytes: Success!
[2021-01-08@15:0:54.152]95476 bytes read in 9 ms (10.1 MiB/s)
[2021-01-08@15:0:54.152]Load Remote Processor 5 with data@addr=0x80080000 95476 bytes: Success!
[2021-01-08@15:0:54.183]192416 bytes read in 11 ms (16.7 MiB/s)
[2021-01-08@15:0:54.183]Load Remote Processor 6 with data@addr=0x80080000 192416 bytes: Success!
[2021-01-08@15:0:54.199]192416 bytes read in 11 ms (16.7 MiB/s)
[2021-01-08@15:0:54.199]Load Remote Processor 7 with data@addr=0x80080000 192416 bytes: Success!
[2021-01-08@15:0:54.448]10489904 bytes read in 223 ms (44.9 MiB/s)
[2021-01-08@15:0:54.448]Load Remote Processor 8 with data@addr=0x80080000 10489904 bytes: Success!
[2021-01-08@15:0:54.792]16654344 bytes read in 346 ms (45.9 MiB/s)
[2021-01-08@15:0:54.807]90724 bytes read in 5 ms (17.3 MiB/s)
[2021-01-08@15:0:54.807]## Flattened Device Tree blob at 82000000
[2021-01-08@15:0:54.807]   Booting using the fdt blob at 0x82000000
[2021-01-08@15:0:54.838]   Loading Device Tree to 00000000fdd9f000, end 00000000fdeb8fff ... OK
[2021-01-08@15:0:54.838]Starting kernel ...
[2021-01-08@15:0:54.979][    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[2021-01-08@15:0:54.994][    0.000000] Linux version 5.4.40+ (pierrehsieh@dell-r540) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Thu Jan 7 17:45:38 CST 2021
[2021-01-08@15:0:54.994][    0.000000] Machine model: Texas Instruments K3 J721E SoC
[2021-01-08@15:0:55.010][    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[2021-01-08@15:0:55.010][    0.000000] printk: bootconsole [ns16550a0] enabled
[2021-01-08@15:0:55.026][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[2021-01-08@15:0:55.026][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[2021-01-08@15:0:55.057][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[2021-01-08@15:0:55.057][    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[2021-01-08@15:0:55.072][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[2021-01-08@15:0:55.072][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[2021-01-08@15:0:55.088][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 31 MiB
[2021-01-08@15:0:55.104][    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[2021-01-08@15:0:55.104][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[2021-01-08@15:0:55.119][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[2021-01-08@15:0:55.119][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[2021-01-08@15:0:55.135][    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[2021-01-08@15:0:55.135][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[2021-01-08@15:0:55.150][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[2021-01-08@15:0:55.150][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[2021-01-08@15:0:55.166][    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[2021-01-08@15:0:55.166][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[2021-01-08@15:0:55.182][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[2021-01-08@15:0:55.197][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[2021-01-08@15:0:55.197][    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[2021-01-08@15:0:55.213][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[2021-01-08@15:0:55.213][    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[2021-01-08@15:0:55.228][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[2021-01-08@15:0:55.228][    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[2021-01-08@15:0:55.244][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[2021-01-08@15:0:55.244][    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[2021-01-08@15:0:55.260][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[2021-01-08@15:0:55.260][    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[2021-01-08@15:0:55.275][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[2021-01-08@15:0:55.291][    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[2021-01-08@15:0:55.291][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[2021-01-08@15:0:55.306][    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[2021-01-08@15:0:55.306][    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 32 MiB
[2021-01-08@15:0:55.322][    0.000000] OF: reserved mem: initialized node vision_apps-dma-memory@ac000000, compatible id shared-dma-pool
[2021-01-08@15:0:55.322][    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[2021-01-08@15:0:55.338][    0.000000] Reserved memory: created DMA memory pool at 0x00000000ce000000, size 720 MiB
[2021-01-08@15:0:55.353][    0.000000] OF: reserved mem: initialized node vision_apps-core-heap-memory@ce000000, compatible id shared-dma-pool
[2021-01-08@15:0:55.353][    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 1 MiB
[2021-01-08@15:0:55.369][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@fb000000, compatible id shared-dma-pool
[2021-01-08@15:0:55.369][    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100000, size 15 MiB
[2021-01-08@15:0:55.384][    0.000000] OF: reserved mem: initialized node r5f-memory@fb100000, compatible id shared-dma-pool
[2021-01-08@15:0:55.384][    0.000000] cma: Failed to reserve 512 MiB
[2021-01-08@15:0:55.400][    0.000000] psci: probing for conduit method from DT.
[2021-01-08@15:0:55.400][    0.000000] psci: PSCIv1.1 detected in firmware.
[2021-01-08@15:0:55.416][    0.000000] psci: Using standard PSCI v0.2 function IDs
[2021-01-08@15:0:55.416][    0.000000] psci: Trusted OS migration not required
[2021-01-08@15:0:55.416][    0.000000] psci: SMC Calling Convention v1.0
[2021-01-08@15:0:55.431][    0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072
[2021-01-08@15:0:55.431][    0.000000] Detected PIPT I-cache on CPU0
[2021-01-08@15:0:55.431][    0.000000] CPU features: detected: GIC system register CPU interface
[2021-01-08@15:0:55.447][    0.000000] CPU features: detected: EL2 vector hardening
[2021-01-08@15:0:55.447][    0.000000] Built 1 zonelists, mobility grouping off.  Total pages: 35779
[2021-01-08@15:0:55.478][    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=f89fc473-02 rw rootfstype=ext4 rootwait
[2021-01-08@15:0:55.494][    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[2021-01-08@15:0:55.494][    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[2021-01-08@15:0:55.509][    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[2021-01-08@15:0:55.525][    0.000000] software IO TLB: mapped [mem 0x9a800000-0x9e800000] (64MB)
[2021-01-08@15:0:55.540][    0.000000] Memory: 2584000K/2293760K available (9534K kernel code, 776K rwdata, 3840K rodata, 1728K init, 695K bss, 18446744073709261376K reserved, 0K cma-reserved)
[2021-01-08@15:0:55.540][    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2021-01-08@15:0:55.556][    0.000000] rcu: Preemptible hierarchical RCU implementation.
[2021-01-08@15:0:55.556][    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[2021-01-08@15:0:55.556][    0.000000] 	Tasks RCU enabled.
[2021-01-08@15:0:55.572][    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[2021-01-08@15:0:55.572][    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[2021-01-08@15:0:55.587][    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[2021-01-08@15:0:55.587][    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[2021-01-08@15:0:55.587][    0.000000] GICv3: 960 SPIs implemented
[2021-01-08@15:0:55.587][    0.000000] GICv3: 0 Extended SPIs implemented
[2021-01-08@15:0:55.603][    0.000000] GICv3: Distributor has no Range Selector support
[2021-01-08@15:0:55.603][    0.000000] GICv3: 16 PPIs implemented
[2021-01-08@15:0:55.603][    0.000000] GICv3: no VLPI support, no direct LPI support
[2021-01-08@15:0:55.618][    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[2021-01-08@15:0:55.618][    0.000000] ITS [mem 0x01820000-0x0182ffff]
[2021-01-08@15:0:55.650][    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[2021-01-08@15:0:55.650][    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
[2021-01-08@15:0:55.665][    0.000000] ITS: using cache flushing for cmd queue
[2021-01-08@15:0:55.665][    0.000000] GICv3: using LPI property table @0x00000008c00c0000
[2021-01-08@15:0:55.665][    0.000000] GIC: using cache flushing for LPI property table
[2021-01-08@15:0:55.681][    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000
[2021-01-08@15:0:55.681][    0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x438 with crng_init=0
[2021-01-08@15:0:55.696][    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[2021-01-08@15:0:55.712][    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[2021-01-08@15:0:55.712][    0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[2021-01-08@15:0:55.712][    0.008349] Console: colour dummy device 80x25
[2021-01-08@15:0:55.728][    0.012904] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[2021-01-08@15:0:55.728][    0.023573] pid_max: default: 32768 minimum: 301
[2021-01-08@15:0:55.743][    0.028320] LSM: Security Framework initializing
[2021-01-08@15:0:55.743][    0.033063] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[2021-01-08@15:0:55.759][    0.040631] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[2021-01-08@15:0:55.774][    0.072674] ASID allocator initialised with 32768 entries
[2021-01-08@15:0:55.790][    0.086201] rcu: Hierarchical SRCU implementation.
[2021-01-08@15:0:55.806][    0.099147] Platform MSI: gic-its@1820000 domain created
[2021-01-08@15:0:55.821][    0.104675] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created
[2021-01-08@15:0:55.821][    0.122110] smp: Bringing up secondary CPUs ...
[2021-01-08@15:0:55.868][    0.159063] Detected PIPT I-cache on CPU1
[2021-01-08@15:0:55.868][    0.159080] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[2021-01-08@15:0:55.884][    0.159090] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000
[2021-01-08@15:0:55.884][    0.159108] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[2021-01-08@15:0:55.884][    0.159147] smp: Brought up 1 node, 2 CPUs
[2021-01-08@15:0:55.899][    0.188491] SMP: Total of 2 processors activated.
[2021-01-08@15:0:55.899][    0.193295] CPU features: detected: 32-bit EL0 Support
[2021-01-08@15:0:55.899][    0.198548] CPU features: detected: CRC32 instructions
[2021-01-08@15:0:55.915][    0.209833] CPU: All CPU(s) started at EL2
[2021-01-08@15:0:55.915][    0.214028] alternatives: patching kernel code
[2021-01-08@15:0:55.915][    0.218976] devtmpfs: initialized
[2021-01-08@15:0:55.930][    0.226382] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[2021-01-08@15:0:55.946][    0.236350] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[2021-01-08@15:0:55.946][    0.243478] pinctrl core: initialized pinctrl subsystem
[2021-01-08@15:0:55.946][    0.249153] NET: Registered protocol family 16
[2021-01-08@15:0:55.971][    0.253871] DMA: preallocated 256 KiB pool for atomic allocations
[2021-01-08@15:0:55.971][    0.260360] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[2021-01-08@15:0:55.989][    0.275802] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[2021-01-08@15:0:56.006][    0.282654] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[2021-01-08@15:0:56.006][    0.289413] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[2021-01-08@15:0:56.006][    0.298066] cryptd: max_cpu_qlen set to 1000
[2021-01-08@15:0:56.024][    0.305171] vsys_3v3: supplied by evm_12v0
[2021-01-08@15:0:56.024][    0.309453] vsys_5v0: supplied by evm_12v0
[2021-01-08@15:0:56.024][    0.314047] iommu: Default domain type: Translated
[2021-01-08@15:0:56.041][    0.319167] SCSI subsystem initialized
[2021-01-08@15:0:56.041][    0.323264] mc: Linux media interface: v0.10
[2021-01-08@15:0:56.042][    0.327633] videodev: Linux video capture interface: v2.00
[2021-01-08@15:0:56.059][    0.333248] pps_core: LinuxPPS API ver. 1 registered
[2021-01-08@15:0:56.059][    0.338317] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[2021-01-08@15:0:56.076][    0.347654] PTP clock support registered
[2021-01-08@15:0:56.076][    0.351664] EDAC MC: Ver: 3.0.0
[2021-01-08@15:0:56.076][    0.355317] FPGA manager framework
[2021-01-08@15:0:56.077][    0.358823] Advanced Linux Sound Architecture Driver Initialized.
[2021-01-08@15:0:56.093][    0.365348] clocksource: Switched to clocksource arch_sys_counter
[2021-01-08@15:0:56.094][    0.371645] VFS: Disk quotas dquot_6.6.0
[2021-01-08@15:0:56.094][    0.375696] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[2021-01-08@15:0:56.111][    0.385008] Carveout Heap: Exported 512 MiB at 0x00000000ae000000
[2021-01-08@15:0:56.111][    0.391237] thermal_sys: Registered thermal governor 'step_wise'
[2021-01-08@15:0:56.128][    0.391238] thermal_sys: Registered thermal governor 'power_allocator'
[2021-01-08@15:0:56.128][    0.397543] NET: Registered protocol family 2
[2021-01-08@15:0:56.145][    0.408880] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[2021-01-08@15:0:56.145][    0.417638] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[2021-01-08@15:0:56.145][    0.425832] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[2021-01-08@15:0:56.145][    0.433540] TCP: Hash tables configured (established 32768 bind 32768)
[2021-01-08@15:0:56.145][    0.440275] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[2021-01-08@15:0:56.162][    0.447162] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[2021-01-08@15:0:56.162][    0.454543] NET: Registered protocol family 1
[2021-01-08@15:0:56.180][    0.459254] RPC: Registered named UNIX socket transport module.
[2021-01-08@15:0:56.180][    0.465308] RPC: Registered udp transport module.
[2021-01-08@15:0:56.180][    0.470113] RPC: Registered tcp transport module.
[2021-01-08@15:0:56.197][    0.474917] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2021-01-08@15:0:56.197][    0.481500] PCI: CLS 0 bytes, default 64
[2021-01-08@15:0:56.197][    0.485756] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[2021-01-08@15:0:56.215][    0.497305] Initialise system trusted keyrings
[2021-01-08@15:0:56.215][    0.501930] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[2021-01-08@15:0:56.232][    0.510387] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2021-01-08@15:0:56.232][    0.516578] NFS: Registering the id_resolver key type
[2021-01-08@15:0:56.232][    0.521799] Key type id_resolver registered
[2021-01-08@15:0:56.250][    0.526070] Key type id_legacy registered
[2021-01-08@15:0:56.250][    0.530167] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[2021-01-08@15:0:56.250][    0.537096] 9p: Installing v9fs 9p2000 file system support
[2021-01-08@15:0:56.266][    0.549492] Key type asymmetric registered
[2021-01-08@15:0:56.267][    0.553679] Asymmetric key parser 'x509' registered
[2021-01-08@15:0:56.277][    0.558681] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[2021-01-08@15:0:56.277][    0.566242] io scheduler mq-deadline registered
[2021-01-08@15:0:56.277][    0.570868] io scheduler kyber registered
[2021-01-08@15:0:56.294][    0.575965] pinctrl-single 4301c000.pinmux: 94 pins, size 376
[2021-01-08@15:0:56.294][    0.582040] pinctrl-single 11c000.pinmux: 173 pins, size 692
[2021-01-08@15:0:56.311][    0.588171] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[2021-01-08@15:0:56.311][    0.596916] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[2021-01-08@15:0:56.329][    0.603180] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[2021-01-08@15:0:56.329][    0.609501] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[2021-01-08@15:0:56.346][    0.615914] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[2021-01-08@15:0:56.346][    0.623866] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[2021-01-08@15:0:56.346][    0.630280] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[2021-01-08@15:0:56.363][    0.638239] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[2021-01-08@15:0:56.363][    0.644653] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[2021-01-08@15:0:56.380][    0.652584] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[2021-01-08@15:0:56.381][    0.658905] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[2021-01-08@15:0:56.397][    0.666824] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[2021-01-08@15:0:56.397][    0.673145] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[2021-01-08@15:0:56.414][    0.682444] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[2021-01-08@15:0:56.414][    0.694019] brd: module loaded
[2021-01-08@15:0:56.430][    0.700046] loop: module loaded
[2021-01-08@15:0:56.433][    0.704536] libphy: Fixed MDIO Bus: probed
[2021-01-08@15:0:56.433][    0.708906] tun: Universal TUN/TAP device driver, 1.6
[2021-01-08@15:0:56.450][    0.714311] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[2021-01-08@15:0:56.451][    0.722318] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[2021-01-08@15:0:56.451][    0.728384] sky2: driver version 1.30
[2021-01-08@15:0:56.451][    0.732587] VFIO - User Level meta-driver version: 0.3
[2021-01-08@15:0:56.451][    0.738167] i2c /dev entries driver
[2021-01-08@15:0:56.451][    0.742214] sdhci: Secure Digital Host Controller Interface driver
[2021-01-08@15:0:56.467][    0.748527] sdhci: Copyright(c) Pierre Ossman
[2021-01-08@15:0:56.467][    0.753159] sdhci-pltfm: SDHCI platform and OF driver helper
[2021-01-08@15:0:56.467][    0.759402] ledtrig-cpu: registered to indicate activity on CPUs
[2021-01-08@15:0:56.484][    0.766119] optee: probing for conduit method from DT.
[2021-01-08@15:0:56.484][    0.771378] optee: revision 3.8 (199fca17)
[2021-01-08@15:0:56.484][    0.771658] optee: initialized driver
[2021-01-08@15:0:56.501][    0.780329] NET: Registered protocol family 17
[2021-01-08@15:0:56.501][    0.784930] 9pnet: Installing 9P2000 support
[2021-01-08@15:0:56.502][    0.789315] Key type dns_resolver registered
[2021-01-08@15:0:56.502][    0.793795] registered taskstats version 1
[2021-01-08@15:0:56.519][    0.797982] Loading compiled-in X.509 certificates
[2021-01-08@15:0:56.519][    0.806482] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[2021-01-08@15:0:56.537][    0.812796] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[2021-01-08@15:0:56.537][    0.820419] ti-sci 44083000.dmsc: ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[2021-01-08@15:0:56.563][    0.845219] random: fast init done
[2021-01-08@15:0:56.593][    0.875891] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[2021-01-08@15:0:56.593][    0.883176] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[2021-01-08@15:0:56.593][    0.889160] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[2021-01-08@15:0:56.608][    0.895132] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[2021-01-08@15:0:56.608][    0.901165] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
[2021-01-08@15:0:56.641][    0.929857] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
[2021-01-08@15:0:56.656][    0.937883] GPIO line 478 (MCAN0_EN) hogged as output/high
[2021-01-08@15:0:56.656][    0.943678] GPIO line 479 (MCAN0_STBN) hogged as output/high
[2021-01-08@15:0:56.657][    0.949911] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low
[2021-01-08@15:0:56.673][    0.956503] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high
[2021-01-08@15:0:56.673][    0.963201] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[2021-01-08@15:0:56.673][    0.969197] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[2021-01-08@15:0:56.690][    0.975075] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
[2021-01-08@15:0:56.690][    0.981001] pca953x 6-0020: 6-0020 supply vcc not found, using dummy regulator
[2021-01-08@15:0:56.720][    1.009721] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[2021-01-08@15:0:56.721][    1.015663] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[2021-01-08@15:0:56.737][    1.021541] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[2021-01-08@15:0:56.737][    1.027466] pca953x 9-0020: 9-0020 supply vcc not found, using dummy regulator
[2021-01-08@15:0:56.769][    1.057652] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[2021-01-08@15:0:56.784][    1.063868] ti-sci-intr interconnect@100000:interconnect@28380000:interrupt-controller2: Interrupt Router 137 domain created
[2021-01-08@15:0:56.785][    1.075434] ti-sci-intr interconnect@100000:interrupt-controller0: Interrupt Router 131 domain created
[2021-01-08@15:0:56.801][    1.085041] ti-sci-intr interconnect@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created
[2021-01-08@15:0:56.819][    1.096044] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[2021-01-08@15:0:56.836][    1.112693] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[2021-01-08@15:0:56.836][    1.120700] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[2021-01-08@15:0:56.854][    1.130574] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[2021-01-08@15:0:56.854][    1.137332] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[2021-01-08@15:0:56.871][    1.146191] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[2021-01-08@15:0:56.871][    1.156334] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[2021-01-08@15:0:56.888][    1.163095] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[2021-01-08@15:0:56.889][    1.170756] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
[2021-01-08@15:0:56.906][    1.178263] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
[2021-01-08@15:0:56.906][    1.187403] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
[2021-01-08@15:0:56.924][    1.196139] printk: console [ttyS2] enabled
[2021-01-08@15:0:56.924][    1.204576] printk: bootconsole [ns16550a0] disabled
[2021-01-08@15:0:56.925][    1.204576] printk: bootconsole [ns16550a0] disabled
[2021-01-08@15:0:56.925][    1.214903] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 20, base_baud = 3000000) is a 8250
[2021-01-08@15:0:56.942][    1.223731] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 21, base_baud = 3000000) is a 8250
[2021-01-08@15:0:56.942][    1.232470] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
[2021-01-08@15:0:56.959][    1.242018] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq
[2021-01-08@15:0:56.960][    1.250799] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq
[2021-01-08@15:0:56.976][    1.258237] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
[2021-01-08@15:0:56.993][    1.267851] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[2021-01-08@15:0:56.993][    1.278365] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[2021-01-08@15:0:57.010][    1.288517] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[2021-01-08@15:0:57.027][    1.298756] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[2021-01-08@15:0:57.027][    1.309500] scsi host0: ufshcd
[2021-01-08@15:0:57.027][    1.316215] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[2021-01-08@15:0:57.043][    1.322396] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[2021-01-08@15:0:57.043][    1.328994] Creating 7 MTD partitions on "47040000.spi.0":
[2021-01-08@15:0:57.061][    1.334471] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[2021-01-08@15:0:57.061][    1.334474] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[2021-01-08@15:0:57.078][    1.352707] 0x000000080000-0x000000280000 : "ospi.tispl"
[2021-01-08@15:0:57.078][    1.358375] 0x000000280000-0x000000680000 : "ospi.u-boot"
[2021-01-08@15:0:57.078][    1.364152] 0x000000680000-0x0000006a0000 : "ospi.env"
[2021-01-08@15:0:57.096][    1.369646] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[2021-01-08@15:0:57.096][    1.375748] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[2021-01-08@15:0:57.096][    1.381433] 0x000000800000-0x000004000000 : "ospi.rootfs"
[2021-01-08@15:0:57.122][    1.396910] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[2021-01-08@15:0:57.261][    1.546368] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[2021-01-08@15:0:57.277][    1.557610] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[2021-01-08@15:0:57.277][    1.566394] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[2021-01-08@15:0:57.294][    1.575058] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[2021-01-08@15:0:57.356][    1.637554] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[2021-01-08@15:0:57.357][    1.645149] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[2021-01-08@15:0:57.404][    1.685538] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[2021-01-08@15:0:57.437][    1.729351] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[2021-01-08@15:0:57.452][    1.736994] libphy: 46000f00.mdio: probed
[2021-01-08@15:0:57.453][    1.742021] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[2021-01-08@15:0:57.470][    1.750284] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[2021-01-08@15:0:57.470][    1.761704] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[2021-01-08@15:0:57.487][    1.770224] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[2021-01-08@15:0:57.487][    1.778733] mmc0: CQHCI version 5.10
[2021-01-08@15:0:57.533][    1.817089] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[2021-01-08@15:0:57.533][    1.825685] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[2021-01-08@15:0:57.549][    1.832276] davinci_gpio 42110000.gpio: IRQ index 4 not found
[2021-01-08@15:0:57.549][    1.838030] davinci_gpio 42110000.gpio: IRQ not populated, err = -6
[2021-01-08@15:0:57.566][    1.847574] vdd_mmc1: supplied by vsys_3v3
[2021-01-08@15:0:57.566][    1.852118] pca953x 4-0020: 4-0020 supply vcc not found, using dummy regulator
[2021-01-08@15:0:57.597][    1.881892] GPIO line 284 (DP0_PWR_SW_EN) hogged as output/high
[2021-01-08@15:0:57.597][    1.888423] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@15:0:57.613][    1.895258] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@15:0:57.613][    1.902113] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@15:0:57.630][    1.908947] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@15:0:57.630][    1.915750] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@15:0:57.644][    1.925256] ti-udma 285c0000.dma-controller: Channels: 24 (tchan: 12, rchan: 12, gp-rflow: 8)
[2021-01-08@15:0:57.645][    1.935597] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[2021-01-08@15:0:57.662][    1.948078] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[2021-01-08@15:0:57.662][    1.954260] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[2021-01-08@15:0:57.678][    1.960888] Creating 7 MTD partitions on "47040000.spi.0":
[2021-01-08@15:0:57.678][    1.966377] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[2021-01-08@15:0:57.679][    1.972355] 0x000000080000-0x000000280000 : "ospi.tispl"
[2021-01-08@15:0:57.696][    1.978064] 0x000000280000-0x000000680000 : "ospi.u-boot"
[2021-01-08@15:0:57.696][    1.983879] 0x000000680000-0x0000006a0000 : "ospi.env"
[2021-01-08@15:0:57.714][    1.989481] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[2021-01-08@15:0:57.717][    1.995647] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[2021-01-08@15:0:57.717][    2.001363] 0x000000800000-0x000004000000 : "ospi.rootfs"
[2021-01-08@15:0:57.734][    2.009507] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[2021-01-08@15:0:57.734][    2.015643] mmc0: Command Queue Engine enabled
[2021-01-08@15:0:57.734][    2.020080] mmc0: new HS400 MMC card at address 0001
[2021-01-08@15:0:57.751][    2.025718] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[2021-01-08@15:0:57.751][    2.030383] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[2021-01-08@15:0:57.751][    2.036443] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[2021-01-08@15:0:57.768][    2.042420] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0)
[2021-01-08@15:0:57.769][    2.050885]  mmcblk0: p1 p2
[2021-01-08@15:0:57.805][    2.089361] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[2021-01-08@15:0:57.805][    2.097008] libphy: 46000f00.mdio: probed
[2021-01-08@15:0:57.820][    2.102053] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[2021-01-08@15:0:57.820][    2.110318] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[2021-01-08@15:0:57.838][    2.122518] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[2021-01-08@15:0:57.838][    2.129611] pps pps0: new PPS source ptp1
[2021-01-08@15:0:57.855][    2.133728] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
[2021-01-08@15:0:57.855][    2.142679] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4
[2021-01-08@15:0:57.873][    2.149971] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[2021-01-08@15:0:57.873][    2.156848] mmc1: CQHCI version 5.10
[2021-01-08@15:0:57.900][    2.191238] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit
[2021-01-08@15:0:57.917][    2.199369] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[2021-01-08@15:0:57.918][    2.211269] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[2021-01-08@15:0:57.922][    2.218625] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[2021-01-08@15:0:57.922][    2.225958] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[2021-01-08@15:0:57.937][    2.233272] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[2021-01-08@15:0:57.937][    2.241183] hctosys: unable to open rtc device (rtc0)
[2021-01-08@15:0:57.953][    2.261158] ALSA device list:
[2021-01-08@15:0:57.968][    2.264122]   No soundcards found.
[2021-01-08@15:0:57.968][    2.267723] Waiting for root device PARTUUID=f89fc473-02...
[2021-01-08@15:0:59.390][    3.698261] mmc1: new ultra high speed DDR50 SDXC card at address 5048
[2021-01-08@15:0:59.421][    3.705083] mmcblk1: mmc1:5048 SD128 119 GiB
[2021-01-08@15:0:59.421][    3.712632]  mmcblk1: p1 p2
[2021-01-08@15:0:59.452][    3.738988] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[2021-01-08@15:0:59.452][    3.747087] VFS: Mounted root (ext4 filesystem) on device 179:98.
[2021-01-08@15:0:59.468][    3.758032] devtmpfs: mounted
[2021-01-08@15:0:59.468][    3.761577] Freeing unused kernel memory: 1728K
[2021-01-08@15:0:59.468][    3.766112] Run /sbin/init as init process
[2021-01-08@15:0:59.671][    3.964608] systemd[1]: System time before build time, advancing clock.
[2021-01-08@15:0:59.733][    4.031346] NET: Registered protocol family 10
[2021-01-08@15:0:59.733][    4.036140] Segment Routing with IPv6
[2021-01-08@15:0:59.764][    4.056622] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[2021-01-08@15:0:59.780][    4.072119] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[2021-01-08@15:0:59.811][    4.091948] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[2021-01-08@15:0:59.811][    4.113636] systemd[1]: Detected architecture arm64.
[2021-01-08@15:0:59.842]
[2021-01-08@15:0:59.842]Welcome to Arago 2020.05!
[2021-01-08@15:0:59.858][    4.158656] systemd[1]: Set hostname to <j7-evm>.
[2021-01-08@15:1:0.076][    4.350272] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[2021-01-08@15:1:0.124][    4.417813] random: systemd: uninitialized urandom read (16 bytes read)
[2021-01-08@15:1:0.140][    4.424505] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[2021-01-08@15:1:0.159][    4.436830] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[2021-01-08@15:1:0.159][    4.446539] systemd[1]: Created slice system-getty.slice.
[2021-01-08@15:1:0.159][  OK  ] Created slice system-getty.slice.
[2021-01-08@15:1:0.176][    4.465436] random: systemd: uninitialized urandom read (16 bytes read)
[2021-01-08@15:1:0.195][    4.472551] systemd[1]: Created slice system-serial\x2dgetty.slice.
[2021-01-08@15:1:0.195][  OK  ] Created slice system-serial\x2dgetty.slice.
[2021-01-08@15:1:0.213][    4.489393] random: systemd: uninitialized urandom read (16 bytes read)
[2021-01-08@15:1:0.214][    4.496440] systemd[1]: Created slice User and Session Slice.
[2021-01-08@15:1:0.233][  OK  ] Created slice User and Session Slice.
[2021-01-08@15:1:0.233][    4.513477] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[2021-01-08@15:1:0.250][  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[2021-01-08@15:1:0.269][    4.537446] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[2021-01-08@15:1:0.269][  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[2021-01-08@15:1:0.269][    4.561435] systemd[1]: Reached target Paths.
[2021-01-08@15:1:0.269][  OK  ] Reached target Paths.
[2021-01-08@15:1:0.286][    4.577400] systemd[1]: Reached target Remote File Systems.
[2021-01-08@15:1:0.304][  OK  ] Reached target Remote File Systems.
[2021-01-08@15:1:0.304][    4.593392] systemd[1]: Reached target Slices.
[2021-01-08@15:1:0.304][  OK  ] Reached target Slices.
[2021-01-08@15:1:0.322][    4.609396] systemd[1]: Reached target Swap.
[2021-01-08@15:1:0.322][  OK  ] Reached target Swap.
[2021-01-08@15:1:0.331][    4.627191] systemd[1]: Listening on RPCbind Server Activation Socket.
[2021-01-08@15:1:0.348][  OK  ] Listening on RPCbind Server Activation Socket.
[2021-01-08@15:1:0.349][    4.645416] systemd[1]: Reached target RPC Port Mapper.
[2021-01-08@15:1:0.366][  OK  ] Reached target RPC Port Mapper.
[2021-01-08@15:1:0.384][    4.664133] systemd[1]: Listening on Process Core Dump Socket.
[2021-01-08@15:1:0.384][  OK  ] Listening on Process Core Dump Socket.
[2021-01-08@15:1:0.402][    4.681484] systemd[1]: Listening on initctl Compatibility Named Pipe.
[2021-01-08@15:1:0.402][  OK  ] Listening on initctl Compatibility Named Pipe.
[2021-01-08@15:1:0.428][    4.712003] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[2021-01-08@15:1:0.429][    4.720256] systemd[1]: Listening on Journal Socket (/dev/log).
[2021-01-08@15:1:0.443][  OK  ] Listening on Journal Socket (/dev/log).
[2021-01-08@15:1:0.444][    4.737574] systemd[1]: Listening on Journal Socket.
[2021-01-08@15:1:0.461][  OK  ] Listening on Journal Socket.
[2021-01-08@15:1:0.461][    4.753596] systemd[1]: Listening on Network Service Netlink Socket.
[2021-01-08@15:1:0.478][  OK  ] Listening on Network Service Netlink Socket.
[2021-01-08@15:1:0.479][    4.773524] systemd[1]: Listening on udev Control Socket.
[2021-01-08@15:1:0.497][  OK  ] Listening on udev Control Socket.
[2021-01-08@15:1:0.497][    4.789485] systemd[1]: Listening on udev Kernel Socket.
[2021-01-08@15:1:0.507][  OK  ] Listening on udev Kernel Socket.
[2021-01-08@15:1:0.523][    4.812005] systemd[1]: Mounting Huge Pages File System...
[2021-01-08@15:1:0.524]         Mounting Huge Pages File System...
[2021-01-08@15:1:0.539][    4.835306] systemd[1]: Mounting POSIX Message Queue File System...
[2021-01-08@15:1:0.557]         Mounting POSIX Message Queue File System...
[2021-01-08@15:1:0.575][    4.859949] systemd[1]: Mounting Kernel Debug File System...
[2021-01-08@15:1:0.575]         Mounting Kernel Debug File System...
[2021-01-08@15:1:0.587][    4.881072] systemd[1]: Mounting Temporary Directory (/tmp)...
[2021-01-08@15:1:0.604]         Mounting Temporary Directory (/tmp)...
[2021-01-08@15:1:0.619][    4.903790] systemd[1]: Starting Create list of static device nodes for the current kernel...
[2021-01-08@15:1:0.620]         Starting Create list of st…odes for the current kernel...
[2021-01-08@15:1:0.637][    4.931487] systemd[1]: Starting Start psplash boot splash screen...
[2021-01-08@15:1:0.655]         Starting Start psplash boot splash screen...
[2021-01-08@15:1:0.673][    4.956915] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[2021-01-08@15:1:0.673][  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[2021-01-08@15:1:0.683][    4.978829] systemd[1]: Starting RPC Bind...
[2021-01-08@15:1:0.701]         Starting RPC Bind...
[2021-01-08@15:1:0.701][    4.993593] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[2021-01-08@15:1:0.719][    5.011967] systemd[1]: Starting Journal Service...
[2021-01-08@15:1:0.736]         Starting Journal Service...
[2021-01-08@15:1:0.754][    5.025581] systemd-journald[229]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[2021-01-08@15:1:0.772][    5.053129] systemd[1]: Starting Load Kernel Modules...
[2021-01-08@15:1:0.789][    5.054042] systemd-journald[229]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[2021-01-08@15:1:0.789]         Starting Load Kernel Modules...
[2021-01-08@15:1:0.807][    5.087800] systemd[1]: Starting Remount Root and Kernel File Systems...
[2021-01-08@15:1:0.824]         Starting Remount Root and Kernel File Systems...
[2021-01-08@15:1:0.824][    5.103557] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[2021-01-08@15:1:0.842][    5.115602] systemd[1]: Starting udev Coldplug all Devices...
[2021-01-08@15:1:0.842]         Starting udev Coldplug all Devices...
[2021-01-08@15:1:0.852][    5.135668] systemd[1]: Started RPC Bind.
[2021-01-08@15:1:0.852][  OK  ] Started RPC Bind.
[2021-01-08@15:1:0.863][    5.150317] systemd[1]: Started Journal Service.
[2021-01-08@15:1:0.863][  OK  ] Started Journal Service.
[2021-01-08@15:1:0.875][  OK  ] Mounted Huge Pages File System.
[2021-01-08@15:1:0.907][  OK  ] Mounted POSIX Message Queue File System.
[2021-01-08@15:1:0.921][  OK  ] Mounted Kernel Debug File System.
[2021-01-08@15:1:0.937][  OK  ] Mounted Temporary Directory (/tmp).
[2021-01-08@15:1:0.953][  OK  ] Started Create list of sta… nodes for the current kernel.
[2021-01-08@15:1:0.968][FAILED] Failed to start Start psplash boot splash screen.
[2021-01-08@15:1:0.984]See 'systemctl status psplash-start.service' for details.
[2021-01-08@15:1:0.999][DEPEND] Dependency failed for Star…progress communication helper.
[2021-01-08@15:1:1.015][  OK  ] Started Load Kernel Modules.
[2021-01-08@15:1:1.031][  OK  ] Started Remount Root and Kernel File Systems.
[2021-01-08@15:1:1.046]         Mounting Kernel Configuration File System...
[2021-01-08@15:1:1.062]         Starting Flush Journal to Persistent Storage...
[2021-01-08@15:1:1.077][    5.367964] systemd-journald[229]: Received client request to flush runtime journal.
[2021-01-08@15:1:1.077]         Starting Apply Kernel Variables...
[2021-01-08@15:1:1.093]         Starting Create Static Device Nodes in /dev...
[2021-01-08@15:1:1.109][  OK  ] Mounted Kernel Configuration File System.
[2021-01-08@15:1:1.124][  OK  ] Started Flush Journal to Persistent Storage.
[2021-01-08@15:1:1.140][  OK  ] Started Apply Kernel Variables.
[2021-01-08@15:1:1.155][  OK  ] Started Create Static Device Nodes in /dev.
[2021-01-08@15:1:1.171][  OK  ] Reached target Local File Systems (Pre).
[2021-01-08@15:1:1.187]         Mounting /media/ram...
[2021-01-08@15:1:1.202]         Mounting /var/volatile...
[2021-01-08@15:1:1.202]         Starting udev Kernel Device Manager...
[2021-01-08@15:1:1.218][  OK  ] Mounted /media/ram.
[2021-01-08@15:1:1.233][  OK  ] Mounted /var/volatile.
[2021-01-08@15:1:1.249]         Starting Load/Save Random Seed...
[2021-01-08@15:1:1.265][  OK  ] Reached target Local File Systems.
[2021-01-08@15:1:1.280]         Starting Create Volatile Files and Directories...
[2021-01-08@15:1:1.296][  OK  ] Started udev Coldplug all Devices.
[2021-01-08@15:1:1.311][  OK  ] Started udev Kernel Device Manager.
[2021-01-08@15:1:1.327][  OK  ] Started Create Volatile Files and Directories.
[2021-01-08@15:1:1.358]         Starting Network Time Synchronization...
[2021-01-08@15:1:1.374]         Starting Update UTMP about System Boot/Shutdown...
[2021-01-08@15:1:1.389][  OK  ] Started Update UTMP about System Boot/Shutdown.
[2021-01-08@15:1:1.436][  OK  ] Started Network Time Synchronization.
[2021-01-08@15:1:1.452][  OK  ] Reached target System Initialization.
[2021-01-08@15:1:1.467][  OK  ] Started Daily Cleanup of Temporary Directories.
[2021-01-08@15:1:1.483][  OK  ] Reached target System Time Set.
[2021-01-08@15:1:1.499][  OK  ] Reached target System Time Synchronized.
[2021-01-08@15:1:1.514][  OK  ] Started Daily rotation of log files.
[2021-01-08@15:1:1.514][  OK  ] Reached target Timers.
[2021-01-08@15:1:1.530][  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[2021-01-08@15:1:1.561][  OK  ] Listening on D-Bus System Message Bus Socket.
[2021-01-08@15:1:1.577]         Starting Docker Socket for the API.
[2021-01-08@15:1:1.592][  OK  ] Listening on dropbear.socket.
[2021-01-08@15:1:1.592]         Starting Reboot and dump vmcore via kexec...
[2021-01-08@15:1:1.608][  OK  ] Listening on Docker Socket for the API.
[2021-01-08@15:1:1.623][  OK  ] Reached target Sockets.
[2021-01-08@15:1:1.639][  OK  ] Reached target Basic System.
[2021-01-08@15:1:1.655][  OK  ] Started Job spooling tools.
[2021-01-08@15:1:1.655][  OK  ] Started Periodic Command Scheduler.
[2021-01-08@15:1:1.686][  OK  ] Started D-Bus System Message Bus.
[2021-01-08@15:1:1.701]         Starting Print notice about GPLv3 packages...
[2021-01-08@15:1:1.717]         Starting IPv6 Packet Filtering Framework...
[2021-01-08@15:1:1.717][    6.013143] rti-wdt 2200000.rti: heartbeat 60 sec
[2021-01-08@15:1:1.733]         Starting IPv4 Packet Filtering Framework...
[2021-01-08@15:1:1.733][  OK  ] Started irqbalance daemon.
[2021-01-08@15:1:1.733]         Starting rc.pvr.service...
[2021-01-08@15:1:1.748]         Starting Login Service...
[2021-01-08@15:1:1.779][  OK  ] Started TEE Supplicant.
[2021-01-08@15:1:1.779][  OK  ] Started Reboot and dump vmcore via kexec.
[2021-01-08@15:1:1.795][  OK  ] Started IPv6 Packet Filtering Framework.
[2021-01-08@15:1:1.795][  OK  ] Started IPv4 Packet Filtering Framework.
[2021-01-08@15:1:1.795][  OK  ] Reached target Network (Pre).
[2021-01-08@15:1:1.811]         Starting Network Service...
[2021-01-08@15:1:1.920][  OK  ] Started Network Service.
[2021-01-08@15:1:1.920]         Starting Wait for Network to be Configured...
[2021-01-08@15:1:1.935]         Starting Network Name Resolution...
[2021-01-08@15:1:1.951][  OK  ] Started Login Service.
[2021-01-08@15:1:2.028][    6.313604] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[2021-01-08@15:1:2.076][  OK  ] Started Network Name Resolution.
[2021-01-08@15:1:2.076][  OK  ] Reached target Network.
[2021-01-08@15:1:2.076][  OK  ] Reached target Host and Network Name Lookups.
[2021-01-08@15:1:2.094]         Starting Avahi mDNS/DNS-SD Stack...
[2021-01-08@15:1:2.094][  OK[    6.381306] rti-wdt 2210000.rti: heartbeat 60 sec
[2021-01-08@15:1:2.094]  ] Started NFS status monitor for NFSv2/3 locking..
[2021-01-08@15:1:2.113]         Starting Permit User Sessions...
[2021-01-08@15:1:2.113][  OK  ] Started Permit User Sessions.
[2021-01-08@15:1:2.113][  OK  ] Started Getty on tty1.
[2021-01-08@15:1:2.131][  OK  ] Started Serial Getty on ttyS2.
[2021-01-08@15:1:2.131][  OK  ] Started Serial Getty on ttyS3.
[2021-01-08@15:1:2.131][  OK  ] Reached target Login Prompts.
[2021-01-08@15:1:2.149]         Starting Synchronize System and HW clocks...
[2021-01-08@15:1:2.149][  OK  ] Started Avahi mDNS/DNS-SD Stack.
[2021-01-08@15:1:2.168][FAILED] Failed to start Synchronize System and HW clocks.
[2021-01-08@15:1:2.168]See 'systemctl status sync-clocks.service' for details.
[2021-01-08@15:1:2.284][    6.573759] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[2021-01-08@15:1:2.396][    6.682366] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[2021-01-08@15:1:2.396][    6.689636] [drm] No driver support for vblank timestamp query.
[2021-01-08@15:1:2.413][    6.701338] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[2021-01-08@15:1:2.432][    6.709681] remoteproc remoteproc0: 4d80800000.dsp is available
[2021-01-08@15:1:2.432][    6.713774] [drm] Cannot find any crtc or sizes
[2021-01-08@15:1:2.540][    6.829436] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[2021-01-08@15:1:2.556][    6.845497] remoteproc remoteproc0: powering up 4d80800000.dsp
[2021-01-08@15:1:2.556][    6.851358] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 192416
[2021-01-08@15:1:2.572][    6.861481] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[2021-01-08@15:1:2.590][    6.873372]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
[2021-01-08@15:1:2.590][    6.882136] virtio_rpmsg_bus virtio0: rpmsg host is online
[2021-01-08@15:1:2.608][    6.890227]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[2021-01-08@15:1:2.608][    6.896337] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[2021-01-08@15:1:2.627][    6.909378] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@15:1:2.956][    7.241380] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[2021-01-08@15:1:3.068][    7.350034] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[2021-01-08@15:1:3.132][    7.425971] remoteproc remoteproc1: 4d81800000.dsp is available
[2021-01-08@15:1:3.228][    7.517371] random: crng init done
[2021-01-08@15:1:3.228][    7.520766] random: 7 urandom warning(s) missed due to ratelimiting
[2021-01-08@15:1:3.292][  OK  ] Started Load/Save Random Seed.
[2021-01-08@15:1:3.308][    7.597434] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[2021-01-08@15:1:3.324][    7.613866] remoteproc remoteproc1: powering up 4d81800000.dsp
[2021-01-08@15:1:3.343][    7.619777] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 192416
[2021-01-08@15:1:3.343][    7.632017] platform 41000000.r5f: configured R5F for IPC-only mode
[2021-01-08@15:1:3.361][    7.632136] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[2021-01-08@15:1:3.379][    7.651191]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
[2021-01-08@15:1:3.379][    7.665839] virtio_rpmsg_bus virtio1: rpmsg host is online
[2021-01-08@15:1:3.397][    7.674216]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[2021-01-08@15:1:3.415][    7.685368] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
[2021-01-08@15:1:3.415][    7.695209] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@15:1:3.484][    7.778464] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[2021-01-08@15:1:3.516][    7.806393] remoteproc remoteproc2: 41000000.r5f is available
[2021-01-08@15:1:3.564][  OK  ] Started rc.pvr.service.
[2021-01-08@15:1:3.580]         Starting weston.service...
[2021-01-08@15:1:3.628][    7.918741] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[2021-01-08@15:1:3.645][    7.929491] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[2021-01-08@15:1:3.663][    7.948962] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[2021-01-08@15:1:3.724][    8.012626] remoteproc remoteproc2: powering up 41000000.r5f
[2021-01-08@15:1:3.724][    8.018294] remoteproc remoteproc2: Booting fw image j7-mcu-r5f0_0-fw, size 95552
[2021-01-08@15:1:3.740][    8.030362] platform 41000000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@15:1:3.758][    8.037082]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[2021-01-08@15:1:3.776][    8.049490] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[2021-01-08@15:1:3.776][    8.061650] virtio_rpmsg_bus virtio2: rpmsg host is online
[2021-01-08@15:1:3.776][    8.067229]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[2021-01-08@15:1:3.793][    8.074788] remoteproc remoteproc2: remote processor 41000000.r5f is now up
[2021-01-08@15:1:3.852][    8.144738] remoteproc remoteproc3: 64800000.dsp is available
[2021-01-08@15:1:3.937][    8.231202] platform 5c00000.r5f: configured R5F for IPC-only mode
[2021-01-08@15:1:4.124][    8.413437] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
[2021-01-08@15:1:4.218][    8.505854] remoteproc remoteproc3: powering up 64800000.dsp
[2021-01-08@15:1:4.218][    8.511529] remoteproc remoteproc3: Booting fw image j7-c71_0-fw, size 10489904
[2021-01-08@15:1:4.234][    8.523193] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[2021-01-08@15:1:4.249][    8.534005]  remoteproc3#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
[2021-01-08@15:1:4.249][    8.547619] virtio_rpmsg_bus virtio3: rpmsg host is online
[2021-01-08@15:1:4.265][    8.550143] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@15:1:4.265][    8.557411]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[2021-01-08@15:1:4.280][    8.571214] remoteproc remoteproc3: remote processor 64800000.dsp is now up
[2021-01-08@15:1:4.327][    8.621682] remoteproc remoteproc4: 5c00000.r5f is available
[2021-01-08@15:1:4.390][    8.689848] platform 5d00000.r5f: configured R5F for IPC-only mode
[2021-01-08@15:1:4.421][    8.715821] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[2021-01-08@15:1:4.436][    8.730324] remoteproc remoteproc4: powering up 5c00000.r5f
[2021-01-08@15:1:4.436][    8.735930] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 1669948
[2021-01-08@15:1:4.452][    8.748953] platform 5c00000.r5f: Allocated carveout doesn't fit device address request
[2021-01-08@15:1:4.468][    8.761661] platform 5c00000.r5f: Allocated carveout doesn't fit device address request
[2021-01-08@15:1:4.483][    8.773747] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@15:1:4.483][    8.784479]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a1000000
[2021-01-08@15:1:4.499][    8.797497] virtio_rpmsg_bus virtio4: rpmsg host is online
[2021-01-08@15:1:4.499][    8.803035]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[2021-01-08@15:1:4.514][    8.815789] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
[2021-01-08@15:1:4.530][    8.826093] remoteproc remoteproc5: 5d00000.r5f is available
[2021-01-08@15:1:4.577][    8.873713] remoteproc remoteproc5: powering up 5d00000.r5f
[2021-01-08@15:1:4.577][    8.880949] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 95476
[2021-01-08@15:1:4.592][    8.893121] platform 5e00000.r5f: configured R5F for IPC-only mode
[2021-01-08@15:1:4.592][    8.899499] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@15:1:4.608][    8.906196]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[2021-01-08@15:1:4.608][    8.916009] virtio_rpmsg_bus virtio5: rpmsg host is online
[2021-01-08@15:1:4.624][    8.925837]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
[2021-01-08@15:1:4.639][    8.935392] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
[2021-01-08@15:1:4.655][    8.947732] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@15:1:4.670][    8.974496] j721e-audio sound@0: pcm3168a-dac <-> 2ba0000.mcasp mapping ok
[2021-01-08@15:1:4.811][    9.093429] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[2021-01-08@15:1:4.842][    9.126641] j721e-audio sound@0: pcm3168a-adc <-> 2ba0000.mcasp mapping ok
[2021-01-08@15:1:4.967][    9.261166] remoteproc remoteproc6: 5e00000.r5f is available
[2021-01-08@15:1:5.138][    9.438516] remoteproc remoteproc6: powering up 5e00000.r5f
[2021-01-08@15:1:5.154][    9.444093] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 95476
[2021-01-08@15:1:5.154][    9.457475] platform 5e00000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@15:1:5.170][    9.464405] platform 5f00000.r5f: configured R5F for IPC-only mode
[2021-01-08@15:1:5.170][    9.470606]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
[2021-01-08@15:1:5.185][    9.481887] virtio_rpmsg_bus virtio6: rpmsg host is online
[2021-01-08@15:1:5.201][    9.493382]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
[2021-01-08@15:1:5.201][    9.499487] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
[2021-01-08@15:1:5.216][    9.510762] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@15:1:5.232][    9.527038] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
[2021-01-08@15:1:5.232]***************************************************************
[2021-01-08@15:1:5.248]NOTICE: This file system contains the following GPLv3 packages:
[2021-01-08@15:1:5.248]	bash-dev
[2021-01-08@15:1:5.248]	bc
[2021-01-08@15:1:5.248]	binutils
[2021-01-08@15:1:5.248]	cifs-utils
[2021-01-08@15:1:5.248]	cpio
[2021-01-08@15:1:5.248]	dosfstools
[2021-01-08@15:1:5.248]	elfutils
[2021-01-08@15:1:5.248]	gawk
[2021-01-08@15:1:5.248]	gdb
[2021-01-08@15:1:5.248]	gdbserver
[2021-01-08@15:1:5.248]	glmark2
[2021-01-08@15:1:5.263]	gstreamer1.0-libav
[2021-01-08@15:1:5.279]	gzip
[2021-01-08@15:1:5.279]	less
[2021-01-08@15:1:5.279]	libasm1
[2021-01-08@15:1:5.279]	libbfd
[2021-01-08@15:1:5.279]	libdw1
[2021-01-08@15:1:5.279]	libelf1
[2021-01-08@15:1:5.279]	libgdbm-compat4
[2021-01-08@15:1:5.279]	libgdbm-dev
[2021-01-08@15:1:5.279]	libgdbm6
[2021-01-08@15:1:5.279]	libgmp10
[2021-01-08@15:1:5.279]	libidn2-0
[2021-01-08@15:1:5.279]	libreadline-dev
[2021-01-08@15:1:5.279]	libreadline8
[2021-01-08@15:1:5.279]	libunistring2
[2021-01-08@15:1:5.279]	m4-dev
[2021-01-08@15:1:5.294]	nettle
[2021-01-08@15:1:5.294]	parted
[2021-01-08@15:1:5.294]	tar
[2021-01-08@15:1:5.294]	which
[2021-01-08@15:1:5.294]If you do not wish to distribute GPLv3 components please remove
[2021-01-08@15:1:5.294]the above packages prior to distribution.  This can be done using
[2021-01-08@15:1:5.310]the opkg remove command.  i.e.:
[2021-01-08@15:1:5.310]    opkg remove <package>
[2021-01-08@15:1:5.310]Where <package> is the name printed in the list above
[2021-01-08@15:1:5.310]NOTE: If the package is a dependency of another package you
[2021-01-08@15:1:5.326]      will be notified of the dependent packages.  You should
[2021-01-08@15:1:5.326]      use the --force-removal-of-dependent-packages option to
[2021-01-08@15:1:5.326]      also remove the dependent packages as well
[2021-01-08@15:1:5.341]***************************************************************
[2021-01-08@15:1:5.341][  OK  ] Created slice system-systemd\x2dfsck.slice.
[2021-01-08@15:1:5.357][  OK  ] Started Print notice about GPLv3 packages.
[2021-01-08@15:1:5.482][    9.779768] remoteproc remoteproc7: 5f00000.r5f is available
[2021-01-08@15:1:5.622][    9.913940] remoteproc remoteproc7: powering up 5f00000.r5f
[2021-01-08@15:1:5.622][    9.921971] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 95476
[2021-01-08@15:1:5.638][    9.936354] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@15:1:5.653][    9.945368]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
[2021-01-08@15:1:5.669][    9.958263] virtio_rpmsg_bus virtio7: rpmsg host is online
[2021-01-08@15:1:5.669][    9.969396]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
[2021-01-08@15:1:5.684][    9.975502] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
[2021-01-08@15:1:5.700][    9.989969] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@15:1:5.872][   10.167688] remoteproc remoteproc8: b034000.pru is available
[2021-01-08@15:1:5.903][   10.203398] pru-rproc b034000.pru: PRU rproc node /interconnect@100000/icssg@b000000/pru@34000 probed successfully
[2021-01-08@15:1:5.982][  OK  ] Found device /dev/mmcblk0p2.
[2021-01-08@15:1:5.997][  OK  ] Created slice system-weston.slice   10.301128] remoteproc remoteproc9: b004000.rtu is available
[2021-01-08@15:1:5.997]m.
[2021-01-08@15:1:6.044]         Starting File System Check on /dev/mmcblk0p2...
[2021-01-08@15:1:6.044][  OK  ] Started Weston Wayland Compositor.
[2021-01-08@15:1:6.122][  OK  ] Created slice User Slice of UID 0.
[2021-01-08@15:1:6.122]         Starting User Runtime Directory /run/user/0...
[2021-01-08@15:1:6.138][  OK  ] Started User Runtime Directory /run/user/0.
[2021-01-08@15:1:6.153]         Starting User Manager for UID 0   10.437788] omap_rng 4e10000.trng: Random Number Generator ver. 241b34c
[2021-01-08@15:1:6.153]0m...
[2021-01-08@15:1:6.169][  OK  ] Started File System Check on /dev/mmcblk0p2.
[2021-01-08@15:1:6.185][   10.477415] pru-rproc b004000.rtu: PRU rproc node /interconnect@100000/icssg@b000000/rtu@4000 probed successfully
[2021-01-08@15:1:6.200]         Mounting /run/media/mmcblk0p2...
[2021-01-08@15:1:6.231][   10.526131] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[2021-01-08@15:1:6.247][  OK  ] Mounted /run/media/mmcblk0p2.
[2021-01-08@15:1:6.341][   10.644088] pru-rproc b00a000.txpru: IRQ vring not found
[2021-01-08@15:1:6.387][  OK  ] Found device /dev/mmcblk0p1.
[2021-01-08@15:1:6.403][  OK  ] Found device /dev/mmcblk1p1.
[2021-01-08@15:1:6.419][  OK  ] Started User Manager for UID 0.
[2021-01-08@15:1:6.434][  OK  ] Started Session c1 of user root.[   10.737537] pru-rproc b00a000.txpru: IRQ kick not found
[2021-01-08@15:1:6.465]         Starting File System Check on /dev/mmcblk0p1...
[2021-01-08@15:1:6.481]         Starting File System Check on /dev/mmcblk1p1...
[2021-01-08@15:1:6.528][  OK  ] Started File System Check on /dev/mmcblk0p1.
[2021-01-08@15:1:6.543]         Mounting /run/media/mmcblk0p1   10.839259] cdns-usb3 6000000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[2021-01-08@15:1:6.543]m...
[2021-01-08@15:1:6.543][   10.850033] remoteproc remoteproc10: b00a000.txpru is available
[2021-01-08@15:1:6.559][   10.861846] pru-rproc b00a000.txpru: PRU rproc node /interconnect@100000/icssg@b000000/txpru@a000 probed successfully
[2021-01-08@15:1:6.575][  OK  ] Mounted /run/media/mmcblk0p1.
[2021-01-08@15:1:6.637][   10.934170] remoteproc remoteproc11: b038000.pru is available
[2021-01-08@15:1:6.653][   10.951727] cdns-usb3 6400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[2021-01-08@15:1:6.684][   10.967443] pru-rproc b038000.pru: PRU rproc node /interconnect@100000/icssg@b000000/pru@38000 probed successfully
[2021-01-08@15:1:6.715][  OK  ] Started weston.service.
[2021-01-08@15:1:6.731]         Starting Save/Restore Sound Card State...
[2021-01-08@15:1:6.731]         Starting DEMO...
[2021-01-08@15:1:6.746]         Starting telnetd.service...
[2021-01-08@15:1:6.762][  OK  ] Started DEMO.
[2021-01-08@15:1:6.777][   11.075870] remoteproc remoteproc12: b006000.rtu is available
[2021-01-08@15:1:6.793][  OK  ] Started File System Check on /dev/mmcblk1p1.
[2021-01-08@15:1:6.809][  OK  ] Started telnetd.service.
[2021-01-08@15:1:6.824][  OK  ] Started Save/Restore Sound Card State.
[2021-01-08@15:1:6.840][  OK  ] Reached target Sound Card.
[2021-01-08@15:1:6.855]         Mounting /run/media/mmcblk1p1...
[2021-01-08@15:1:6.871][   11.161441] pru-rproc b006000.rtu: PRU rproc node /interconnect@100000/icssg@b000000/rtu@6000 probed successfully
[2021-01-08@15:1:6.887][   11.184332] usbcore: registered new interface driver usbfs
[2021-01-08@15:1:6.902][   11.197438] usbcore: registered new interface driver hub
[2021-01-08@15:1:6.918][  OK  ] Mounted /run/media/mmcblk1p1.
[2021-01-08@15:1:6.918][   11.218117] usbcore: registered new device driver usb
[2021-01-08@15:1:6.933][   11.227564] pru-rproc b00c000.txpru: IRQ vring not found
[2021-01-08@15:1:6.949][   11.243678] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[2021-01-08@15:1:6.965][   11.256080] pru-rproc b00c000.txpru: IRQ kick not found
[2021-01-08@15:1:6.965][   11.264766] remoteproc remoteproc13: b00c000.txpru is available
[2021-01-08@15:1:6.980][   11.274827] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[2021-01-08@15:1:6.996][   11.288503] pru-rproc b00c000.txpru: PRU rproc node /interconnect@100000/icssg@b000000/txpru@c000 probed successfully
[2021-01-08@15:1:7.011][   11.306521] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
[2021-01-08@15:1:7.027][   11.326186] remoteproc remoteproc14: b134000.pru is available
[2021-01-08@15:1:7.043][   11.335908] xhci-hcd xhci-hcd.2.auto: irq 507, io mem 0x06410000
[2021-01-08@15:1:7.058][   11.345240] pru-rproc b134000.pru: PRU rproc node /interconnect@100000/icssg@b100000/pru@34000 probed successfully
[2021-01-08@15:1:7.074][   11.365554] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[2021-01-08@15:1:7.089][   11.381787] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2021-01-08@15:1:7.089][   11.394158] remoteproc remoteproc15: b104000.rtu is available
[2021-01-08@15:1:7.121][   11.407681] pru-rproc b104000.rtu: PRU rproc node /interconnect@100000/icssg@b100000/rtu@4000 probed successfully
[2021-01-08@15:1:7.121][   11.423715] usb usb1: Product: xHCI Host Controller
[2021-01-08@15:1:7.136][   11.433534] usb usb1: Manufacturer: Linux 5.4.40+ xhci-hcd
[2021-01-08@15:1:7.152][   11.446051] pru-rproc b10a000.txpru: IRQ vring not found
[2021-01-08@15:1:7.167][   11.451371] usb usb1: SerialNumber: xhci-hcd.2.auto
[2021-01-08@15:1:7.167][   11.461443] pru-rproc b10a000.txpru: IRQ kick not found
[2021-01-08@15:1:7.183][   11.467106] hub 1-0:1.0: USB hub found
[2021-01-08@15:1:7.183][   11.470862] hub 1-0:1.0: 1 port detected
[2021-01-08@15:1:7.199][   11.481459] remoteproc remoteproc16: b10a000.txpru is available
[2021-01-08@15:1:7.199][   11.488373] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[2021-01-08@15:1:7.214][   11.497380] pru-rproc b10a000.txpru: PRU rproc node /interconnect@100000/icssg@b100000/txpru@a000 probed successfully
[2021-01-08@15:1:7.230][   11.513356] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[2021-01-08@15:1:7.230][   11.525354] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[2021-01-08@15:1:7.245][   11.525816] remoteproc remoteproc17: b138000.pru is available
[2021-01-08@15:1:7.245][   11.537545] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[2021-01-08@15:1:7.261][   11.553376] pru-rproc b138000.pru: PRU rproc node /interconnect@100000/icssg@b100000/pru@38000 probed successfully
[2021-01-08@15:1:7.277][   11.553395] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[2021-01-08@15:1:7.277][   11.573775] remoteproc remoteproc18: b106000.rtu is available
[2021-01-08@15:1:7.308][   11.589389] pru-rproc b106000.rtu: PRU rproc node /interconnect@100000/icssg@b100000/rtu@6000 probed successfully
[2021-01-08@15:1:7.308][   11.589519] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2021-01-08@15:1:7.323][   11.609721] pru-rproc b10c000.txpru: IRQ vring not found
[2021-01-08@15:1:7.323][   11.621352] pru-rproc b10c000.txpru: IRQ kick not found
[2021-01-08@15:1:7.339][   11.621521] usb usb2: Product: xHCI Host Controller
[2021-01-08@15:1:7.339][   11.633394] remoteproc remoteproc19: b10c000.txpru is available
[2021-01-08@15:1:7.355][   11.641423] usb usb2: Manufacturer: Linux 5.4.40+ xhci-hcd
[2021-01-08@15:1:7.355][   11.645381] pru-rproc b10c000.txpru: PRU rproc node /interconnect@100000/icssg@b100000/txpru@c000 probed successfully
[2021-01-08@15:1:7.355][   11.653347] usb usb2: SerialNumber: xhci-hcd.2.auto
[2021-01-08@15:1:7.370][   11.669702] hub 2-0:1.0: USB hub found
[2021-01-08@15:1:7.370][   11.673467] hub 2-0:1.0: 1 port detected
[2021-01-08@15:1:7.542][   11.837701] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[2021-01-08@15:1:7.698][   12.001624] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[2021-01-08@15:1:7.713][   12.013349] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[2021-01-08@15:1:7.713][   12.020474] usb 1-1: SerialNumber: 5C0100797885
[2021-01-08@15:1:7.729][   12.033732] hub 1-1:1.0: USB hub found
[2021-01-08@15:1:7.729][   12.037492] hub 1-1:1.0: 4 ports detected
[2021-01-08@15:1:8.143]
[2021-01-08@15:1:8.146] _____                    _____           _         _
[2021-01-08@15:1:8.163]|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
[2021-01-08@15:1:8.163]|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
[2021-01-08@15:1:8.164]|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
[2021-01-08@15:1:8.180]              |___|                    |___|
[2021-01-08@15:1:8.181]
[2021-01-08@15:1:8.181]Arago Project http://arago-project.org j7-evm ttyS2
[2021-01-08@15:1:8.181]Arago 2020.05 j7-evm ttyS2
[2021-01-08@15:3:2.765]j7-evm login: [  127.067780] Initializing XFRM netlink socket
[2021-01-08@15:3:5.058][  129.347927] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[2021-01-08@15:3:5.074][  129.361756] Bridge firewalling registered
[2021-01-08@15:31:55.028]
[2021-01-08@15:31:55.028]U-Boot SPL 2020.01-g2b4a28f (Jan 08 2021 - 14:34:42 +0800)
[2021-01-08@15:31:55.028]SYSFW ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[2021-01-08@15:31:55.199]Trying to boot from MMC2
[2021-01-08@15:31:55.355]Loading Environment from MMC... *** Warning - No MMC card found, using default environment
[2021-01-08@15:31:55.886]Remoteproc 2 started successfully
[2021-01-08@15:31:56.166]Starting ATF on ARM64 core...
[2021-01-08@15:31:56.166]NOTICE:  BL31: v2.3():07.00.00.005-dirty
[2021-01-08@15:31:56.166]NOTICE:  BL31: Built : 14:33:55, Jun 17 2020
[2021-01-08@15:31:56.260]
[2021-01-08@15:31:56.276]U-Boot SPL 2020.01-g2b4a28f (Jan 08 2021 - 14:34:48 +0800)
[2021-01-08@15:31:56.276]SYSFW ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[2021-01-08@15:31:56.307]Detected: J7X-BASE-CPB rev E3
[2021-01-08@15:31:56.322]Detected: J7X-VSC8514-ETH rev E2
[2021-01-08@15:31:56.322]Diagnostic Key Check
[2021-01-08@15:31:56.416]Trying to boot from MMC2
[2021-01-08@15:31:57.118]
[2021-01-08@15:31:57.118]U-Boot 2020.01-g2b4a28f (Jan 08 2021 - 14:34:48 +0800)
[2021-01-08@15:31:57.118]SoC:   J721E SR1.0
[2021-01-08@15:31:57.118]Model: Texas Instruments K3 J721E SoC
[2021-01-08@15:31:57.134]Board: J721EX-PM2-SOM rev E7
[2021-01-08@15:31:57.134]DRAM:  4 GiB
[2021-01-08@15:31:57.149]Flash: 0 Bytes
[2021-01-08@15:31:57.165]MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
[2021-01-08@15:31:57.321]Loading Environment from MMC... OK
[2021-01-08@15:31:57.321]In:    serial@2800000
[2021-01-08@15:31:57.336]Out:   serial@2800000
[2021-01-08@15:31:57.336]Err:   serial@2800000
[2021-01-08@15:31:57.399]Detected: J7X-BASE-CPB rev E3
[2021-01-08@15:31:57.414]Detected: J7X-VSC8514-ETH rev E2
[2021-01-08@15:31:57.414]Net:   eth0: ethernet@046000000
[2021-01-08@15:31:59.427]Hit any key to stop autoboot:  0
[2021-01-08@15:31:59.895]switch to partitions #0, OK
[2021-01-08@15:31:59.910]mmc1 is current device
[2021-01-08@15:32:0.332]SD/MMC found on device 1
[2021-01-08@15:32:0.347]58 bytes read in 1 ms (56.6 KiB/s)
[2021-01-08@15:32:0.347]Loaded env from uEnv.txt
[2021-01-08@15:32:0.347]Importing environment from mmc1 ...
[2021-01-08@15:32:0.378]95476 bytes read in 10 ms (9.1 MiB/s)
[2021-01-08@15:32:0.378]Load Remote Processor 3 with data@addr=0x80080000 95476 bytes: Success!
[2021-01-08@15:32:0.394]95476 bytes read in 8 ms (11.4 MiB/s)
[2021-01-08@15:32:0.394]Load Remote Processor 4 with data@addr=0x80080000 95476 bytes: Success!
[2021-01-08@15:32:0.410]95476 bytes read in 10 ms (9.1 MiB/s)
[2021-01-08@15:32:0.425]Load Remote Processor 5 with data@addr=0x80080000 95476 bytes: Success!
[2021-01-08@15:32:0.441]192416 bytes read in 11 ms (16.7 MiB/s)
[2021-01-08@15:32:0.441]Load Remote Processor 6 with data@addr=0x80080000 192416 bytes: Success!
[2021-01-08@15:32:0.472]192416 bytes read in 12 ms (15.3 MiB/s)
[2021-01-08@15:32:0.472]Load Remote Processor 7 with data@addr=0x80080000 192416 bytes: Success!
[2021-01-08@15:32:0.690]10489904 bytes read in 224 ms (44.7 MiB/s)
[2021-01-08@15:32:0.706]Load Remote Processor 8 with data@addr=0x80080000 10489904 bytes: Success!
[2021-01-08@15:32:1.065]16654344 bytes read in 346 ms (45.9 MiB/s)
[2021-01-08@15:32:1.080]90412 bytes read in 5 ms (17.2 MiB/s)
[2021-01-08@15:32:1.080]## Flattened Device Tree blob at 82000000
[2021-01-08@15:32:1.080]   Booting using the fdt blob at 0x82000000
[2021-01-08@15:32:1.096]   Loading Device Tree to 00000000fdd9f000, end 00000000fdeb8fff ... OK
[2021-01-08@15:32:1.112]
[2021-01-08@15:32:1.112]Starting kernel ...
[2021-01-08@15:32:1.252][    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[2021-01-08@15:32:1.268][    0.000000] Linux version 5.4.40+ (pierrehsieh@dell-r540) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Thu Jan 7 17:45:38 CST 2021
[2021-01-08@15:32:1.283][    0.000000] Machine model: Texas Instruments K3 J721E SoC
[2021-01-08@15:32:1.283][    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[2021-01-08@15:32:1.283][    0.000000] printk: bootconsole [ns16550a0] enabled
[2021-01-08@15:32:1.299][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[2021-01-08@15:32:1.299][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[2021-01-08@15:32:1.314][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[2021-01-08@15:32:1.314][    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[2021-01-08@15:32:1.330][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[2021-01-08@15:32:1.361][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[2021-01-08@15:32:1.361][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 31 MiB
[2021-01-08@15:32:1.377][    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[2021-01-08@15:32:1.377][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[2021-01-08@15:32:1.392][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[2021-01-08@15:32:1.392][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[2021-01-08@15:32:1.408][    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[2021-01-08@15:32:1.408][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[2021-01-08@15:32:1.424][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[2021-01-08@15:32:1.424][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[2021-01-08@15:32:1.439][    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[2021-01-08@15:32:1.455][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[2021-01-08@15:32:1.455][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[2021-01-08@15:32:1.470][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[2021-01-08@15:32:1.470][    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[2021-01-08@15:32:1.486][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[2021-01-08@15:32:1.486][    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[2021-01-08@15:32:1.502][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[2021-01-08@15:32:1.502][    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[2021-01-08@15:32:1.517][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[2021-01-08@15:32:1.517][    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[2021-01-08@15:32:1.533][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[2021-01-08@15:32:1.548][    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[2021-01-08@15:32:1.548][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[2021-01-08@15:32:1.564][    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[2021-01-08@15:32:1.580][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[2021-01-08@15:32:1.580][    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[2021-01-08@15:32:1.580][    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 32 MiB
[2021-01-08@15:32:1.595][    0.000000] OF: reserved mem: initialized node vision_apps-dma-memory@ac000000, compatible id shared-dma-pool
[2021-01-08@15:32:1.595][    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[2021-01-08@15:32:1.611][    0.000000] Reserved memory: created DMA memory pool at 0x00000000ce000000, size 720 MiB
[2021-01-08@15:32:1.626][    0.000000] OF: reserved mem: initialized node vision_apps-core-heap-memory@ce000000, compatible id shared-dma-pool
[2021-01-08@15:32:1.626][    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 1 MiB
[2021-01-08@15:32:1.642][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@fb000000, compatible id shared-dma-pool
[2021-01-08@15:32:1.642][    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100000, size 15 MiB
[2021-01-08@15:32:1.658][    0.000000] OF: reserved mem: initialized node r5f-memory@fb100000, compatible id shared-dma-pool
[2021-01-08@15:32:1.658][    0.000000] cma: Failed to reserve 512 MiB
[2021-01-08@15:32:1.673][    0.000000] psci: probing for conduit method from DT.
[2021-01-08@15:32:1.673][    0.000000] psci: PSCIv1.1 detected in firmware.
[2021-01-08@15:32:1.689][    0.000000] psci: Using standard PSCI v0.2 function IDs
[2021-01-08@15:32:1.689][    0.000000] psci: Trusted OS migration not required
[2021-01-08@15:32:1.689][    0.000000] psci: SMC Calling Convention v1.0
[2021-01-08@15:32:1.704][    0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072
[2021-01-08@15:32:1.704][    0.000000] Detected PIPT I-cache on CPU0
[2021-01-08@15:32:1.704][    0.000000] CPU features: detected: GIC system register CPU interface
[2021-01-08@15:32:1.720][    0.000000] CPU features: detected: EL2 vector hardening
[2021-01-08@15:32:1.720][    0.000000] Built 1 zonelists, mobility grouping off.  Total pages: 35779
[2021-01-08@15:32:1.751][    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=f89fc473-02 rw rootfstype=ext4 rootwait
[2021-01-08@15:32:1.767][    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[2021-01-08@15:32:1.782][    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[2021-01-08@15:32:1.782][    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[2021-01-08@15:32:1.798][    0.000000] software IO TLB: mapped [mem 0x9a800000-0x9e800000] (64MB)
[2021-01-08@15:32:1.814][    0.000000] Memory: 2584000K/2293760K available (9534K kernel code, 776K rwdata, 3840K rodata, 1728K init, 695K bss, 18446744073709261376K reserved, 0K cma-reserved)
[2021-01-08@15:32:1.814][    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2021-01-08@15:32:1.829][    0.000000] rcu: Preemptible hierarchical RCU implementation.
[2021-01-08@15:32:1.829][    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[2021-01-08@15:32:1.829][    0.000000] 	Tasks RCU enabled.
[2021-01-08@15:32:1.845][    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[2021-01-08@15:32:1.845][    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[2021-01-08@15:32:1.860][    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[2021-01-08@15:32:1.860][    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[2021-01-08@15:32:1.860][    0.000000] GICv3: 960 SPIs implemented
[2021-01-08@15:32:1.892][    0.000000] GICv3: 0 Extended SPIs implemented
[2021-01-08@15:32:1.892][    0.000000] GICv3: Distributor has no Range Selector support
[2021-01-08@15:32:1.892][    0.000000] GICv3: 16 PPIs implemented
[2021-01-08@15:32:1.892][    0.000000] GICv3: no VLPI support, no direct LPI support
[2021-01-08@15:32:1.907][    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[2021-01-08@15:32:1.907][    0.000000] ITS [mem 0x01820000-0x0182ffff]
[2021-01-08@15:32:1.923][    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[2021-01-08@15:32:1.923][    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
[2021-01-08@15:32:1.938][    0.000000] ITS: using cache flushing for cmd queue
[2021-01-08@15:32:1.938][    0.000000] GICv3: using LPI property table @0x00000008c00c0000
[2021-01-08@15:32:1.938][    0.000000] GIC: using cache flushing for LPI property table
[2021-01-08@15:32:1.954][    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000
[2021-01-08@15:32:1.970][    0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x438 with crng_init=0
[2021-01-08@15:32:1.970][    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[2021-01-08@15:32:1.985][    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[2021-01-08@15:32:1.985][    0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[2021-01-08@15:32:1.985][    0.008349] Console: colour dummy device 80x25
[2021-01-08@15:32:2.001][    0.012904] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[2021-01-08@15:32:2.001][    0.023574] pid_max: default: 32768 minimum: 301
[2021-01-08@15:32:2.016][    0.028321] LSM: Security Framework initializing
[2021-01-08@15:32:2.016][    0.033064] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[2021-01-08@15:32:2.016][    0.040633] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[2021-01-08@15:32:2.048][    0.072678] ASID allocator initialised with 32768 entries
[2021-01-08@15:32:2.048][    0.086204] rcu: Hierarchical SRCU implementation.
[2021-01-08@15:32:2.079][    0.099151] Platform MSI: gic-its@1820000 domain created
[2021-01-08@15:32:2.094][    0.104677] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created
[2021-01-08@15:32:2.110][    0.122113] smp: Bringing up secondary CPUs ...
[2021-01-08@15:32:2.141][    0.159064] Detected PIPT I-cache on CPU1
[2021-01-08@15:32:2.141][    0.159080] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[2021-01-08@15:32:2.157][    0.159089] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000
[2021-01-08@15:32:2.157][    0.159108] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[2021-01-08@15:32:2.157][    0.159147] smp: Brought up 1 node, 2 CPUs
[2021-01-08@15:32:2.172][    0.188491] SMP: Total of 2 processors activated.
[2021-01-08@15:32:2.172][    0.193295] CPU features: detected: 32-bit EL0 Support
[2021-01-08@15:32:2.172][    0.198548] CPU features: detected: CRC32 instructions
[2021-01-08@15:32:2.188][    0.209845] CPU: All CPU(s) started at EL2
[2021-01-08@15:32:2.188][    0.214038] alternatives: patching kernel code
[2021-01-08@15:32:2.204][    0.218981] devtmpfs: initialized
[2021-01-08@15:32:2.204][    0.226492] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[2021-01-08@15:32:2.219][    0.236458] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[2021-01-08@15:32:2.219][    0.243585] pinctrl core: initialized pinctrl subsystem
[2021-01-08@15:32:2.219][    0.249261] NET: Registered protocol family 16
[2021-01-08@15:32:2.250][    0.253974] DMA: preallocated 256 KiB pool for atomic allocations
[2021-01-08@15:32:2.250][    0.260461] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[2021-01-08@15:32:2.250][    0.275901] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[2021-01-08@15:32:2.266][    0.282753] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[2021-01-08@15:32:2.266][    0.289513] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[2021-01-08@15:32:2.297][    0.298165] cryptd: max_cpu_qlen set to 1000
[2021-01-08@15:32:2.297][    0.305282] vsys_3v3: supplied by evm_12v0
[2021-01-08@15:32:2.297][    0.309565] vsys_5v0: supplied by evm_12v0
[2021-01-08@15:32:2.297][    0.314167] iommu: Default domain type: Translated
[2021-01-08@15:32:2.297][    0.319282] SCSI subsystem initialized
[2021-01-08@15:32:2.297][    0.323372] mc: Linux media interface: v0.10
[2021-01-08@15:32:2.297][    0.327762] videodev: Linux video capture interface: v2.00
[2021-01-08@15:32:2.313][    0.333373] pps_core: LinuxPPS API ver. 1 registered
[2021-01-08@15:32:2.313][    0.338443] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[2021-01-08@15:32:2.328][    0.347785] PTP clock support registered
[2021-01-08@15:32:2.328][    0.351796] EDAC MC: Ver: 3.0.0
[2021-01-08@15:32:2.328][    0.355494] FPGA manager framework
[2021-01-08@15:32:2.328][    0.359002] Advanced Linux Sound Architecture Driver Initialized.
[2021-01-08@15:32:2.360][    0.365552] clocksource: Switched to clocksource arch_sys_counter
[2021-01-08@15:32:2.360][    0.371851] VFS: Disk quotas dquot_6.6.0
[2021-01-08@15:32:2.375][    0.375893] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[2021-01-08@15:32:2.375][    0.385329] Carveout Heap: Exported 512 MiB at 0x00000000ae000000
[2021-01-08@15:32:2.375][    0.391559] thermal_sys: Registered thermal governor 'step_wise'
[2021-01-08@15:32:2.391][    0.391560] thermal_sys: Registered thermal governor 'power_allocator'
[2021-01-08@15:32:2.391][    0.397863] NET: Registered protocol family 2
[2021-01-08@15:32:2.406][    0.409167] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[2021-01-08@15:32:2.406][    0.417925] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[2021-01-08@15:32:2.406][    0.426118] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[2021-01-08@15:32:2.406][    0.433813] TCP: Hash tables configured (established 32768 bind 32768)
[2021-01-08@15:32:2.422][    0.440542] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[2021-01-08@15:32:2.422][    0.447430] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[2021-01-08@15:32:2.422][    0.454808] NET: Registered protocol family 1
[2021-01-08@15:32:2.438][    0.459500] RPC: Registered named UNIX socket transport module.
[2021-01-08@15:32:2.438][    0.465551] RPC: Registered udp transport module.
[2021-01-08@15:32:2.438][    0.470354] RPC: Registered tcp transport module.
[2021-01-08@15:32:2.453][    0.475157] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2021-01-08@15:32:2.453][    0.481740] PCI: CLS 0 bytes, default 64
[2021-01-08@15:32:2.453][    0.485988] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[2021-01-08@15:32:2.484][    0.497441] Initialise system trusted keyrings
[2021-01-08@15:32:2.484][    0.502040] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[2021-01-08@15:32:2.484][    0.510505] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2021-01-08@15:32:2.484][    0.516742] NFS: Registering the id_resolver key type
[2021-01-08@15:32:2.500][    0.521911] Key type id_resolver registered
[2021-01-08@15:32:2.500][    0.526181] Key type id_legacy registered
[2021-01-08@15:32:2.500][    0.530277] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[2021-01-08@15:32:2.516][    0.537200] 9p: Installing v9fs 9p2000 file system support
[2021-01-08@15:32:2.516][    0.549694] Key type asymmetric registered
[2021-01-08@15:32:2.547][    0.553879] Asymmetric key parser 'x509' registered
[2021-01-08@15:32:2.547][    0.558883] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[2021-01-08@15:32:2.547][    0.566444] io scheduler mq-deadline registered
[2021-01-08@15:32:2.562][    0.571069] io scheduler kyber registered
[2021-01-08@15:32:2.562][    0.576188] pinctrl-single 4301c000.pinmux: 94 pins, size 376
[2021-01-08@15:32:2.562][    0.582245] pinctrl-single 11c000.pinmux: 173 pins, size 692
[2021-01-08@15:32:2.578][    0.588372] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[2021-01-08@15:32:2.578][    0.597189] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[2021-01-08@15:32:2.594][    0.603451] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[2021-01-08@15:32:2.594][    0.609773] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[2021-01-08@15:32:2.609][    0.616183] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[2021-01-08@15:32:2.609][    0.624139] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[2021-01-08@15:32:2.625][    0.630550] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[2021-01-08@15:32:2.625][    0.638477] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[2021-01-08@15:32:2.625][    0.644886] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[2021-01-08@15:32:2.640][    0.652808] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[2021-01-08@15:32:2.640][    0.659131] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[2021-01-08@15:32:2.656][    0.667055] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[2021-01-08@15:32:2.656][    0.673377] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[2021-01-08@15:32:2.672][    0.682713] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[2021-01-08@15:32:2.672][    0.694407] brd: module loaded
[2021-01-08@15:32:2.687][    0.700385] loop: module loaded
[2021-01-08@15:32:2.687][    0.704935] libphy: Fixed MDIO Bus: probed
[2021-01-08@15:32:2.687][    0.709303] tun: Universal TUN/TAP device driver, 1.6
[2021-01-08@15:32:2.703][    0.714705] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[2021-01-08@15:32:2.703][    0.722712] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[2021-01-08@15:32:2.703][    0.728776] sky2: driver version 1.30
[2021-01-08@15:32:2.718][    0.732996] VFIO - User Level meta-driver version: 0.3
[2021-01-08@15:32:2.718][    0.738580] i2c /dev entries driver
[2021-01-08@15:32:2.718][    0.742628] sdhci: Secure Digital Host Controller Interface driver
[2021-01-08@15:32:2.734][    0.748943] sdhci: Copyright(c) Pierre Ossman
[2021-01-08@15:32:2.734][    0.753585] sdhci-pltfm: SDHCI platform and OF driver helper
[2021-01-08@15:32:2.750][    0.759808] ledtrig-cpu: registered to indicate activity on CPUs
[2021-01-08@15:32:2.750][    0.766529] optee: probing for conduit method from DT.
[2021-01-08@15:32:2.750][    0.771793] optee: revision 3.8 (199fca17)
[2021-01-08@15:32:2.750][    0.772081] optee: initialized driver
[2021-01-08@15:32:2.765][    0.780670] NET: Registered protocol family 17
[2021-01-08@15:32:2.765][    0.785272] 9pnet: Installing 9P2000 support
[2021-01-08@15:32:2.765][    0.789653] Key type dns_resolver registered
[2021-01-08@15:32:2.781][    0.794134] registered taskstats version 1
[2021-01-08@15:32:2.781][    0.798322] Loading compiled-in X.509 certificates
[2021-01-08@15:32:2.781][    0.806888] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[2021-01-08@15:32:2.796][    0.813203] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[2021-01-08@15:32:2.812][    0.820828] ti-sci 44083000.dmsc: ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[2021-01-08@15:32:2.828][    0.845631] random: fast init done
[2021-01-08@15:32:2.859][    0.876305] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[2021-01-08@15:32:2.859][    0.883604] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[2021-01-08@15:32:2.874][    0.889610] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[2021-01-08@15:32:2.874][    0.895586] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[2021-01-08@15:32:2.874][    0.901629] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
[2021-01-08@15:32:2.906][    0.930066] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
[2021-01-08@15:32:2.921][    0.938089] GPIO line 478 (MCAN0_EN) hogged as output/high
[2021-01-08@15:32:2.921][    0.943884] GPIO line 479 (MCAN0_STBN) hogged as output/high
[2021-01-08@15:32:2.921][    0.950118] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low
[2021-01-08@15:32:2.937][    0.956711] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high
[2021-01-08@15:32:2.937][    0.963410] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[2021-01-08@15:32:2.952][    0.969395] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[2021-01-08@15:32:2.952][    0.975276] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
[2021-01-08@15:32:2.952][    0.981197] pca953x 6-0020: 6-0020 supply vcc not found, using dummy regulator
[2021-01-08@15:32:2.984][    1.009899] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[2021-01-08@15:32:2.984][    1.015771] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[2021-01-08@15:32:2.999][    1.021642] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[2021-01-08@15:32:2.999][    1.027592] pca953x 9-0020: 9-0020 supply vcc not found, using dummy regulator
[2021-01-08@15:32:3.030][    1.057855] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[2021-01-08@15:32:3.046][    1.064058] ti-sci-intr interconnect@100000:interconnect@28380000:interrupt-controller2: Interrupt Router 137 domain created
[2021-01-08@15:32:3.046][    1.075626] ti-sci-intr interconnect@100000:interrupt-controller0: Interrupt Router 131 domain created
[2021-01-08@15:32:3.062][    1.085233] ti-sci-intr interconnect@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created
[2021-01-08@15:32:3.077][    1.096235] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[2021-01-08@15:32:3.093][    1.112984] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[2021-01-08@15:32:3.093][    1.120957] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[2021-01-08@15:32:3.108][    1.130830] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[2021-01-08@15:32:3.108][    1.137589] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[2021-01-08@15:32:3.124][    1.146451] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[2021-01-08@15:32:3.124][    1.156595] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[2021-01-08@15:32:3.140][    1.163355] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[2021-01-08@15:32:3.140][    1.171017] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
[2021-01-08@15:32:3.155][    1.178541] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
[2021-01-08@15:32:3.155][    1.187685] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
[2021-01-08@15:32:3.171][    1.196421] printk: console [ttyS2] enabled
[2021-01-08@15:32:3.171][    1.204858] printk: bootconsole [ns16550a0] disabled
[2021-01-08@15:32:3.186][    1.204858] printk: bootconsole [ns16550a0] disabled
[2021-01-08@15:32:3.186][    1.215193] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 20, base_baud = 3000000) is a 8250
[2021-01-08@15:32:3.202][    1.224014] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 21, base_baud = 3000000) is a 8250
[2021-01-08@15:32:3.202][    1.232754] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
[2021-01-08@15:32:3.218][    1.242293] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq
[2021-01-08@15:32:3.218][    1.251060] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq
[2021-01-08@15:32:3.233][    1.258490] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
[2021-01-08@15:32:3.249][    1.268128] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[2021-01-08@15:32:3.249][    1.278643] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[2021-01-08@15:32:3.264][    1.288795] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[2021-01-08@15:32:3.280][    1.299033] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[2021-01-08@15:32:3.280][    1.309775] scsi host0: ufshcd
[2021-01-08@15:32:3.280][    1.316479] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[2021-01-08@15:32:3.296][    1.322659] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[2021-01-08@15:32:3.296][    1.329257] Creating 7 MTD partitions on "47040000.spi.0":
[2021-01-08@15:32:3.311][    1.334735] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[2021-01-08@15:32:3.311][    1.334738] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[2021-01-08@15:32:3.327][    1.353013] 0x000000080000-0x000000280000 : "ospi.tispl"
[2021-01-08@15:32:3.327][    1.358674] 0x000000280000-0x000000680000 : "ospi.u-boot"
[2021-01-08@15:32:3.327][    1.364471] 0x000000680000-0x0000006a0000 : "ospi.env"
[2021-01-08@15:32:3.342][    1.369986] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[2021-01-08@15:32:3.358][    1.376105] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[2021-01-08@15:32:3.358][    1.381782] 0x000000800000-0x000004000000 : "ospi.rootfs"
[2021-01-08@15:32:3.374][    1.397222] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[2021-01-08@15:32:3.389][    1.408886] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[2021-01-08@15:32:3.405][    1.420129] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[2021-01-08@15:32:3.420][    1.428859] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[2021-01-08@15:32:3.420][    1.437525] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[2021-01-08@15:32:3.608][    1.633762] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[2021-01-08@15:32:3.623][    1.641366] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[2021-01-08@15:32:3.654][    1.681741] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[2021-01-08@15:32:3.701][    1.725553] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[2021-01-08@15:32:3.701][    1.733197] libphy: 46000f00.mdio: probed
[2021-01-08@15:32:3.717][    1.738217] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[2021-01-08@15:32:3.732][    1.746479] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[2021-01-08@15:32:3.732][    1.757898] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[2021-01-08@15:32:3.748][    1.766428] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[2021-01-08@15:32:3.748][    1.774939] mmc0: CQHCI version 5.10
[2021-01-08@15:32:3.795][    1.813303] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[2021-01-08@15:32:3.795][    1.821899] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[2021-01-08@15:32:3.795][    1.828509] davinci_gpio 42110000.gpio: IRQ index 4 not found
[2021-01-08@15:32:3.810][    1.834259] davinci_gpio 42110000.gpio: IRQ not populated, err = -6
[2021-01-08@15:32:3.810][    1.843786] vdd_mmc1: supplied by vsys_3v3
[2021-01-08@15:32:3.826][    1.848326] pca953x 4-0020: 4-0020 supply vcc not found, using dummy regulator
[2021-01-08@15:32:3.857][    1.878091] GPIO line 284 (DP0_PWR_SW_EN) hogged as output/high
[2021-01-08@15:32:3.857][    1.884634] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@15:32:3.857][    1.891466] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@15:32:3.873][    1.898319] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@15:32:3.873][    1.905155] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@15:32:3.888][    1.911957] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@15:32:3.888][    1.921459] ti-udma 285c0000.dma-controller: Channels: 24 (tchan: 12, rchan: 12, gp-rflow: 8)
[2021-01-08@15:32:3.904][    1.931825] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[2021-01-08@15:32:3.920][    1.944298] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[2021-01-08@15:32:3.920][    1.950480] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[2021-01-08@15:32:3.920][    1.957108] Creating 7 MTD partitions on "47040000.spi.0":
[2021-01-08@15:32:3.935][    1.962598] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[2021-01-08@15:32:3.935][    1.968559] 0x000000080000-0x000000280000 : "ospi.tispl"
[2021-01-08@15:32:3.935][    1.974268] 0x000000280000-0x000000680000 : "ospi.u-boot"
[2021-01-08@15:32:3.951][    1.980089] 0x000000680000-0x0000006a0000 : "ospi.env"
[2021-01-08@15:32:3.951][    1.985698] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[2021-01-08@15:32:3.966][    1.991846] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[2021-01-08@15:32:3.966][    1.997601] 0x000000800000-0x000004000000 : "ospi.rootfs"
[2021-01-08@15:32:3.966][    2.005713] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[2021-01-08@15:32:3.998][    2.011846] mmc0: Command Queue Engine enabled
[2021-01-08@15:32:3.998][    2.016284] mmc0: new HS400 MMC card at address 0001
[2021-01-08@15:32:3.998][    2.021927] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[2021-01-08@15:32:4.013][    2.026605] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[2021-01-08@15:32:4.013][    2.032657] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[2021-01-08@15:32:4.029][    2.038649] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0)
[2021-01-08@15:32:4.029][    2.051332]  mmcblk0: p1 p2
[2021-01-08@15:32:4.076][    2.085565] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[2021-01-08@15:32:4.076][    2.093212] libphy: 46000f00.mdio: probed
[2021-01-08@15:32:4.076][    2.098251] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[2021-01-08@15:32:4.091][    2.106516] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[2021-01-08@15:32:4.107][    2.118709] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[2021-01-08@15:32:4.107][    2.125804] pps pps0: new PPS source ptp1
[2021-01-08@15:32:4.107][    2.129920] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
[2021-01-08@15:32:4.122][    2.138873] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4
[2021-01-08@15:32:4.122][    2.146165] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[2021-01-08@15:32:4.138][    2.153067] mmc1: CQHCI version 5.10
[2021-01-08@15:32:4.169][    2.187468] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit
[2021-01-08@15:32:4.169][    2.195596] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[2021-01-08@15:32:4.185][    2.207477] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[2021-01-08@15:32:4.200][    2.214831] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[2021-01-08@15:32:4.200][    2.222201] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[2021-01-08@15:32:4.216][    2.229516] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[2021-01-08@15:32:4.216][    2.237417] hctosys: unable to open rtc device (rtc0)
[2021-01-08@15:32:4.232][    2.257373] ALSA device list:
[2021-01-08@15:32:4.232][    2.260334]   No soundcards found.
[2021-01-08@15:32:4.247][    2.263954] Waiting for root device PARTUUID=f89fc473-02...
[2021-01-08@15:32:5.838][    3.864598] mmc1: new ultra high speed DDR50 SDXC card at address 5048
[2021-01-08@15:32:5.838][    3.871430] mmcblk1: mmc1:5048 SD128 119 GiB
[2021-01-08@15:32:5.854][    3.879095]  mmcblk1: p1 p2
[2021-01-08@15:32:5.885][    3.911520] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[2021-01-08@15:32:5.885][    3.919620] VFS: Mounted root (ext4 filesystem) on device 179:98.
[2021-01-08@15:32:5.901][    3.930713] devtmpfs: mounted
[2021-01-08@15:32:5.901][    3.934245] Freeing unused kernel memory: 1728K
[2021-01-08@15:32:5.901][    3.938790] Run /sbin/init as init process
[2021-01-08@15:32:6.119][    4.143718] systemd[1]: System time before build time, advancing clock.
[2021-01-08@15:32:6.197][    4.212019] NET: Registered protocol family 10
[2021-01-08@15:32:6.197][    4.216817] Segment Routing with IPv6
[2021-01-08@15:32:6.228][    4.237787] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[2021-01-08@15:32:6.244][    4.253249] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[2021-01-08@15:32:6.260][    4.273215] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[2021-01-08@15:32:6.275][    4.294898] systemd[1]: Detected architecture arm64.
[2021-01-08@15:32:6.291]
[2021-01-08@15:32:6.291]Welcome to Arago 2020.05!
[2021-01-08@15:32:6.306][    4.334889] systemd[1]: Set hostname to <j7-evm>.
[2021-01-08@15:32:6.525][    4.537896] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[2021-01-08@15:32:6.572][    4.607044] random: systemd: uninitialized urandom read (16 bytes read)
[2021-01-08@15:32:6.587][    4.613729] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[2021-01-08@15:32:6.603][    4.626052] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[2021-01-08@15:32:6.603][    4.635817] systemd[1]: Created slice system-getty.slice.
[2021-01-08@15:32:6.603][  OK  ] Created slice system-getty.slice.
[2021-01-08@15:32:6.618][    4.653647] random: systemd: uninitialized urandom read (16 bytes read)
[2021-01-08@15:32:6.634][    4.660761] systemd[1]: Created slice system-serial\x2dgetty.slice.
[2021-01-08@15:32:6.634][  OK  ] Created slice system-serial\x2dgetty.slice.
[2021-01-08@15:32:6.650][    4.677592] random: systemd: uninitialized urandom read (16 bytes read)
[2021-01-08@15:32:6.650][    4.684640] systemd[1]: Created slice User and Session Slice.
[2021-01-08@15:32:6.665][  OK  ] Created slice User and Session Slice.
[2021-01-08@15:32:6.681][    4.701678] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[2021-01-08@15:32:6.681][  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[2021-01-08@15:32:6.712][    4.725646] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[2021-01-08@15:32:6.712][  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[2021-01-08@15:32:6.728][    4.749637] systemd[1]: Reached target Paths.
[2021-01-08@15:32:6.728][  OK  ] Reached target Paths.
[2021-01-08@15:32:6.743][    4.765602] systemd[1]: Reached target Remote File Systems.
[2021-01-08@15:32:6.759][  OK  ] Reached target Remote File Systems.
[2021-01-08@15:32:6.759][    4.785594] systemd[1]: Reached target Slices.
[2021-01-08@15:32:6.774][  OK  ] Reached target Slices.
[2021-01-08@15:32:6.774][    4.801597] systemd[1]: Reached target Swap.
[2021-01-08@15:32:6.790][  OK  ] Reached target Swap.
[2021-01-08@15:32:6.806][    4.819458] systemd[1]: Listening on RPCbind Server Activation Socket.
[2021-01-08@15:32:6.806][  OK  ] Listening on RPCbind Server Activation Socket.
[2021-01-08@15:32:6.821][    4.837618] systemd[1]: Reached target RPC Port Mapper.
[2021-01-08@15:32:6.821][  OK  ] Reached target RPC Port Mapper.
[2021-01-08@15:32:6.837][    4.856374] systemd[1]: Listening on Process Core Dump Socket.
[2021-01-08@15:32:6.837][  OK  ] Listening on Process Core Dump Socket.
[2021-01-08@15:32:6.852][    4.873689] systemd[1]: Listening on initctl Compatibility Named Pipe.
[2021-01-08@15:32:6.852][  OK  ] Listening on initctl Compatibility Named Pipe.
[2021-01-08@15:32:6.884][    4.904538] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[2021-01-08@15:32:6.884][    4.912790] systemd[1]: Listening on Journal Socket (/dev/log).
[2021-01-08@15:32:6.899][  OK  ] Listening on Journal Socket (/dev/log).
[2021-01-08@15:32:6.899][    4.929773] systemd[1]: Listening on Journal Socket.
[2021-01-08@15:32:6.915][  OK  ] Listening on Journal Socket.
[2021-01-08@15:32:6.930][    4.945797] systemd[1]: Listening on Network Service Netlink Socket.
[2021-01-08@15:32:6.930][  OK  ] Listening on Network Service Netlink Socket.
[2021-01-08@15:32:6.946][    4.969723] systemd[1]: Listening on udev Control Socket.
[2021-01-08@15:32:6.946][  OK  ] Listening on udev Control Socket.
[2021-01-08@15:32:6.962][    4.985683] systemd[1]: Listening on udev Kernel Socket.
[2021-01-08@15:32:6.962][  OK  ] Listening on udev Kernel Socket.
[2021-01-08@15:32:6.977][    5.004049] systemd[1]: Mounting Huge Pages File System...
[2021-01-08@15:32:6.977]         Mounting Huge Pages File System...
[2021-01-08@15:32:6.993][    5.023993] systemd[1]: Mounting POSIX Message Queue File System...
[2021-01-08@15:32:7.008]         Mounting POSIX Message Queue File System...
[2021-01-08@15:32:7.024][    5.044239] systemd[1]: Mounting Kernel Debug File System...
[2021-01-08@15:32:7.024]         Mounting Kernel Debug File System...
[2021-01-08@15:32:7.040][    5.065644] systemd[1]: Mounting Temporary Directory (/tmp)...
[2021-01-08@15:32:7.040]         Mounting Temporary Directory (/tmp)...
[2021-01-08@15:32:7.071][    5.087928] systemd[1]: Starting Create list of static device nodes for the current kernel...
[2021-01-08@15:32:7.071]         Starting Create list of st…odes for the current kernel...
[2021-01-08@15:32:7.086][    5.115515] systemd[1]: Starting Start psplash boot splash screen...
[2021-01-08@15:32:7.102]         Starting Start psplash boot splash screen...
[2021-01-08@15:32:7.118][    5.138332] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[2021-01-08@15:32:7.118][  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[2021-01-08@15:32:7.133][    5.163737] systemd[1]: Starting RPC Bind...
[2021-01-08@15:32:7.133]         Starting RPC Bind...
[2021-01-08@15:32:7.149][    5.177709] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[2021-01-08@15:32:7.164][    5.189198] systemd[1]: Starting Journal Service...
[2021-01-08@15:32:7.164]         Starting Journal Service...
[2021-01-08@15:32:7.180][    5.205477] systemd-journald[227]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[2021-01-08@15:32:7.211][    5.227256] systemd-journald[227]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[2021-01-08@15:32:7.211][    5.247261] systemd[1]: Starting Load Kernel Modules...
[2021-01-08@15:32:7.227]         Starting Load Kernel Modules...
[2021-01-08@15:32:7.242][    5.271645] systemd[1]: Starting Remount Root and Kernel File Systems...
[2021-01-08@15:32:7.258]         Starting Remount Root and Kernel File Systems...
[2021-01-08@15:32:7.258][    5.290556] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[2021-01-08@15:32:7.274][    5.299727] systemd[1]: Starting udev Coldplug all Devices...
[2021-01-08@15:32:7.274]         Starting udev Coldplug all Devices...
[2021-01-08@15:32:7.305][    5.323738] systemd[1]: Started RPC Bind.
[2021-01-08@15:32:7.305][  OK  ] Started RPC Bind.
[2021-01-08@15:32:7.305][    5.341829] systemd[1]: Started Journal Service.
[2021-01-08@15:32:7.336][  OK  ] Started Journal Service.
[2021-01-08@15:32:7.336][  OK  ] Mounted Huge Pages File System.
[2021-01-08@15:32:7.367][  OK  ] Mounted POSIX Message Queue File System.
[2021-01-08@15:32:7.383][  OK  ] Mounted Kernel Debug File System.
[2021-01-08@15:32:7.398][  OK  ] Mounted Temporary Directory (/tmp).
[2021-01-08@15:32:7.414][  OK  ] Started Create list of sta… nodes for the current kernel.
[2021-01-08@15:32:7.430][FAILED] Failed to start Start psplash boot splash screen.
[2021-01-08@15:32:7.445]See 'systemctl status psplash-start.service' for details.
[2021-01-08@15:32:7.461][DEPEND] Dependency failed for Star…progress communication helper.
[2021-01-08@15:32:7.476][  OK  ] Started Load Kernel Modules.
[2021-01-08@15:32:7.492][  OK  ] Started Remount Root and Kernel File Systems.
[2021-01-08@15:32:7.508]         Mounting Kernel Configuration File System...
[2021-01-08@15:32:7.523]         Starting Flush Journal to Persistent Storage...
[2021-01-08@15:32:7.539][    5.552489] systemd-journald[227]: Received client request to flush runtime journal.
[2021-01-08@15:32:7.539]         Starting Apply Kernel Variables...
[2021-01-08@15:32:7.554]         Starting Create Static Device Nodes in /dev...
[2021-01-08@15:32:7.570][  OK  ] Mounted Kernel Configuration File System.
[2021-01-08@15:32:7.586][  OK  ] Started Flush Journal to Persistent Storage.
[2021-01-08@15:32:7.617][  OK  ] Started Apply Kernel Variables.
[2021-01-08@15:32:7.617][  OK  ] Started Create Static Device Nodes in /dev.
[2021-01-08@15:32:7.632][  OK  ] Reached target Local File Systems (Pre).
[2021-01-08@15:32:7.648]         Mounting /media/ram...
[2021-01-08@15:32:7.664]         Mounting /var/volatile...
[2021-01-08@15:32:7.664]         Starting udev Kernel Device Manager...
[2021-01-08@15:32:7.679][  OK  ] Mounted /media/ram.
[2021-01-08@15:32:7.695][  OK  ] Mounted /var/volatile.
[2021-01-08@15:32:7.710]         Starting Load/Save Random Seed...
[2021-01-08@15:32:7.726][  OK  ] Reached target Local File Systems.
[2021-01-08@15:32:7.742]         Starting Create Volatile Files and Directories...
[2021-01-08@15:32:7.757][  OK  ] Started udev Coldplug all Devices.
[2021-01-08@15:32:7.773][  OK  ] Started Create Volatile Files and Directories.
[2021-01-08@15:32:7.788][  OK  ] Started udev Kernel Device Manager.
[2021-01-08@15:32:7.804]         Starting Network Time Synchronization...
[2021-01-08@15:32:7.804]         Starting Update UTMP about System Boot/Shutdown...
[2021-01-08@15:32:7.835][  OK  ] Started Update UTMP about System Boot/Shutdown.
[2021-01-08@15:32:7.882][  OK  ] Started Network Time Synchronization.
[2021-01-08@15:32:7.898][  OK  ] Reached target System Initialization.
[2021-01-08@15:32:7.913][  OK  ] Started Daily Cleanup of Temporary Directories.
[2021-01-08@15:32:7.929][  OK  ] Reached target System Time Set.
[2021-01-08@15:32:7.944][  OK  ] Reached target System Time Synchronized.
[2021-01-08@15:32:7.960][  OK  ] Started Daily rotation of log files.
[2021-01-08@15:32:7.991][  OK  ] Reached target Timers.
[2021-01-08@15:32:8.007][  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[2021-01-08@15:32:8.022][  OK  ] Listening on D-Bus System Message Bus Socket.
[2021-01-08@15:32:8.038]         Starting Docker Socket for the API.
[2021-01-08@15:32:8.054][  OK  ] Listening on dropbear.socket.
[2021-01-08@15:32:8.069]         Starting Reboot and dump vmcore via kexec...
[2021-01-08@15:32:8.085][  OK  ] Listening on Docker Socket for the API.
[2021-01-08@15:32:8.100][  OK  ] Reached target Sockets.
[2021-01-08@15:32:8.100][  OK  ] Reached target Basic System.
[2021-01-08@15:32:8.116][  OK  ] Started Job spooling tools.
[2021-01-08@15:32:8.132][  OK  ] Started Periodic Command Scheduler.
[2021-01-08@15:32:8.147][  OK  ] Started D-Bus System Message Bus.
[2021-01-08@15:32:8.163]         Starting Print notice about GPLv3 packages...
[2021-01-08@15:32:8.178]         Starting IPv6 Packet Filtering Framework...
[2021-01-08@15:32:8.194]         Starting IPv4 Packet Filtering Framework...
[2021-01-08@15:32:8.194][  OK  ] Started irqbalance daemon.
[2021-01-08@15:32:8.194]         Starting rc.pvr.service...
[2021-01-08@15:32:8.210]         Starting Login Service...
[2021-01-08@15:32:8.210][  OK  ] Started TEE Supplicant.
[2021-01-08@15:32:8.225][  OK  ] Started Reboot and dump vmcore via kexec.
[2021-01-08@15:32:8.225][  OK  ] Started IPv6 Packet Filtering Framework.
[2021-01-08@15:32:8.241][  OK  ] Started IPv4 Packet Filtering Framework.
[2021-01-08@15:32:8.241][  OK  ] Reached target Network (Pre).
[2021-01-08@15:32:8.241]         Starting Network Service...
[2021-01-08@15:32:8.303][    6.333481] rti-wdt 2200000.rti: heartbeat 60 sec
[2021-01-08@15:32:8.334][  OK  ] Started Network Service.
[2021-01-08@15:32:8.334]         Starting Wait for Network to be Configured...
[2021-01-08@15:32:8.334]         Starting Network Name Resolution...
[2021-01-08@15:32:8.366][    6.397177] rti-wdt 2210000.rti: heartbeat 60 sec
[2021-01-08@15:32:8.444][  OK  ] Started Login Service.
[2021-01-08@15:32:8.475][  OK  ] Started Network Name Resolution.
[2021-01-08@15:32:8.490][  OK  ] Reached target Network.
[2021-01-08@15:32:8.490][  OK  ] Reached target Host and Network Name Lookups.
[2021-01-08@15:32:8.490]         Starting Avahi mDNS/DNS-SD Stack...
[2021-01-08@15:32:8.522][  OK  ] Started NFS status monitor for NFSv2/3 locking..
[2021-01-08@15:32:8.522]         Starting Permit User Sessions...
[2021-01-08@15:32:8.522][  OK  ] Started Permit User Sessions.
[2021-01-08@15:32:8.537][  OK  ] Started Getty on tty1.
[2021-01-08@15:32:8.537][  OK  ] Started Serial Getty on ttyS2.
[2021-01-08@15:32:8.537][  OK  ] Started Serial Getty on ttyS3.
[2021-01-08@15:32:8.553][  OK  ] Reached target Login Prompts.
[2021-01-08@15:32:8.553]         Starting Synchronize System and HW clocks...
[2021-01-08@15:32:8.568][FAILED] Failed to start Synchronize System and HW clocks.
[2021-01-08@15:32:8.568]See 'systemctl status sync-clocks.service' for details.
[2021-01-08@15:32:8.568][  OK  ] Started Avahi mDNS/DNS-SD Stack.
[2021-01-08@15:32:8.631][    6.641921] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[2021-01-08@15:32:8.678][    6.698203] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[2021-01-08@15:32:8.756][    6.779343] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[2021-01-08@15:32:8.771][    6.787622] [drm] No driver support for vblank timestamp query.
[2021-01-08@15:32:8.787][    6.812118] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[2021-01-08@15:32:8.802][    6.821543] [drm] Cannot find any crtc or sizes
[2021-01-08@15:32:8.927][    6.959877] remoteproc remoteproc0: 4d80800000.dsp is available
[2021-01-08@15:32:8.958][    6.984829] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[2021-01-08@15:32:8.974][    7.002229] remoteproc remoteproc0: powering up 4d80800000.dsp
[2021-01-08@15:32:8.974][    7.008075] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 192416
[2021-01-08@15:32:8.990][    7.019791] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[2021-01-08@15:32:9.005][    7.026599]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
[2021-01-08@15:32:9.021][    7.044840] virtio_rpmsg_bus virtio0: rpmsg host is online
[2021-01-08@15:32:9.021][    7.049067] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@15:32:9.036][    7.050400]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[2021-01-08@15:32:9.052][    7.073927] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[2021-01-08@15:32:9.317][    7.342471] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[2021-01-08@15:32:9.489][    7.501378] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[2021-01-08@15:32:9.582][    7.605253] remoteproc remoteproc1: 4d81800000.dsp is available
[2021-01-08@15:32:9.614][    7.641222] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[2021-01-08@15:32:9.629][    7.649813] platform 41000000.r5f: configured R5F for IPC-only mode
[2021-01-08@15:32:9.629][    7.656770] remoteproc remoteproc1: powering up 4d81800000.dsp
[2021-01-08@15:32:9.629][    7.662625] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 192416
[2021-01-08@15:32:9.645][    7.673770] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[2021-01-08@15:32:9.660][    7.680647]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
[2021-01-08@15:32:9.676][    7.698054] virtio_rpmsg_bus virtio1: rpmsg host is online
[2021-01-08@15:32:9.676][    7.701501] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[2021-01-08@15:32:9.676][    7.703594]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[2021-01-08@15:32:9.707][    7.711664] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@15:32:9.707][    7.727745] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
[2021-01-08@15:32:9.738][    7.773573] random: crng init done
[2021-01-08@15:32:9.738][    7.776974] random: 7 urandom warning(s) missed due to ratelimiting
[2021-01-08@15:32:9.848][    7.858850] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[2021-01-08@15:32:9.863][    7.879623] remoteproc remoteproc2: 41000000.r5f is available
[2021-01-08@15:32:9.879][  OK  ] Started Load/Save Random Seed.
[2021-01-08@15:32:9.910][    7.927598] remoteproc remoteproc3: 64800000.dsp is available
[2021-01-08@15:32:9.926][    7.945581] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[2021-01-08@15:32:9.941][    7.961083] remoteproc remoteproc2: powering up 41000000.r5f
[2021-01-08@15:32:9.941][    7.966770] remoteproc remoteproc2: Booting fw image j7-mcu-r5f0_0-fw, size 95552
[2021-01-08@15:32:9.957][    7.980115] platform 41000000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@15:32:9.972][    7.989575]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[2021-01-08@15:32:9.988][    8.002578] virtio_rpmsg_bus virtio2: rpmsg host is online
[2021-01-08@15:32:9.988][    8.012926]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[2021-01-08@15:32:10.004][    8.021575] remoteproc remoteproc2: remote processor 41000000.r5f is now up
[2021-01-08@15:32:10.004][    8.028362] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[2021-01-08@15:32:10.035][    8.051266] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[2021-01-08@15:32:10.191][  OK  ] Started rc.pvr.service.
[2021-01-08@15:32:10.191]         Starting weston.service...
[2021-01-08@15:32:10.269][    8.290699] platform 5c00000.r5f: configured R5F for IPC-only mode
[2021-01-08@15:32:10.378][    8.409080] remoteproc remoteproc3: powering up 64800000.dsp
[2021-01-08@15:32:10.378][    8.414853] remoteproc remoteproc3: Booting fw image j7-c71_0-fw, size 10489904
[2021-01-08@15:32:10.394][    8.429627] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[2021-01-08@15:32:10.425][    8.436252]  remoteproc3#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
[2021-01-08@15:32:10.425][    8.448825] virtio_rpmsg_bus virtio3: rpmsg host is online
[2021-01-08@15:32:10.440][    8.457764]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[2021-01-08@15:32:10.456][    8.469575] remoteproc remoteproc3: remote processor 64800000.dsp is now up
[2021-01-08@15:32:10.487][    8.504275] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
[2021-01-08@15:32:10.581][    8.600447] remoteproc remoteproc4: 5c00000.r5f is available
[2021-01-08@15:32:10.628][    8.643647] platform 5d00000.r5f: configured R5F for IPC-only mode
[2021-01-08@15:32:10.643][    8.668175] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[2021-01-08@15:32:10.659][    8.679034] remoteproc remoteproc4: powering up 5c00000.r5f
[2021-01-08@15:32:10.659][    8.684677] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 1669948
[2021-01-08@15:32:10.674][    8.697474] platform 5c00000.r5f: Allocated carveout doesn't fit device address request
[2021-01-08@15:32:10.690][    8.711114] platform 5c00000.r5f: Allocated carveout doesn't fit device address request
[2021-01-08@15:32:10.706][    8.725131] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@15:32:10.721][    8.736628]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a1000000
[2021-01-08@15:32:10.721][    8.751508] virtio_rpmsg_bus virtio4: rpmsg host is online
[2021-01-08@15:32:10.737][    8.759980]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[2021-01-08@15:32:10.752][    8.769963] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
[2021-01-08@15:32:10.830][    8.860073] remoteproc remoteproc5: 5d00000.r5f is available
[2021-01-08@15:32:10.877][    8.906434] remoteproc remoteproc5: powering up 5d00000.r5f
[2021-01-08@15:32:10.893][    8.912054] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 95476
[2021-01-08@15:32:10.893][    8.924731] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@15:32:10.908][    8.935139]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[2021-01-08@15:32:10.908][    8.936132] platform 5e00000.r5f: configured R5F for IPC-only mode
[2021-01-08@15:32:10.924][    8.948188] virtio_rpmsg_bus virtio5: rpmsg host is online
[2021-01-08@15:32:10.924][    8.959621]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
[2021-01-08@15:32:10.940][    8.962167] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[2021-01-08@15:32:10.940][    8.965757] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
[2021-01-08@15:32:10.955][    8.978528] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@15:32:11.049][    9.076644] remoteproc remoteproc6: 5e00000.r5f is available
[2021-01-08@15:32:11.158][    9.171989] platform 5f00000.r5f: configured R5F for IPC-only mode
[2021-01-08@15:32:11.158][    9.180888] remoteproc remoteproc6: powering up 5e00000.r5f
[2021-01-08@15:32:11.174][    9.186487] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 95476
[2021-01-08@15:32:11.174][    9.199286] platform 5e00000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@15:32:11.189][    9.210516]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
[2021-01-08@15:32:11.205][    9.222074] virtio_rpmsg_bus virtio6: rpmsg host is online
[2021-01-08@15:32:11.205][    9.230302]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
[2021-01-08@15:32:11.220][    9.239650] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
[2021-01-08@15:32:11.236][    9.253599] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@15:32:11.361]***************************************************************
[2021-01-08@15:32:11.361]NOTICE: This file system contains the following GPLv3 packages:
[2021-01-08@15:32:11.361]	bash-dev
[2021-01-08@15:32:11.376]	bc
[2021-01-08@15:32:11.376]	binutils
[2021-01-08@15:32:11.376]	cifs-utils
[2021-01-08@15:32:11.376]	cpio
[2021-01-08@15:32:11.376]	dosfst[    9.400487] j721e-audio sound@0: pcm3168a-dac <-> 2ba0000.mcasp mapping ok
[2021-01-08@15:32:11.376]ools
[2021-01-08@15:32:11.376]	elfutils
[2021-01-08@15:32:11.376]	gawk
[2021-01-08@15:32:11.376]	gdb
[2021-01-08@15:32:11.376]	gdbserver
[2021-01-08@15:32:11.376]	glmark2
[2021-01-08@15:32:11.392]	gstreamer1.0-libav
[2021-01-08@15:32:11.392]	gzip
[2021-01-08@15:32:11.392]	less
[2021-01-08@15:32:11.392]	libasm1
[2021-01-08@15:32:11.392]	libbfd
[2021-01-08@15:32:11.392]	libdw1
[2021-01-08@15:32:11.392]	libelf1
[2021-01-08@15:32:11.392]	libgdbm-compat4
[2021-01-08@15:32:11.392]	libgdbm-dev
[2021-01-08@15:32:11.392]	libgdbm6
[2021-01-08@15:32:11.392]	libgmp10
[2021-01-08@15:32:11.392]	libidn2-0
[2021-01-08@15:32:11.392]	libreadline-dev
[2021-01-08@15:32:11.392]	libreadline8
[2021-01-08@15:32:11.392]	libunistring2
[2021-01-08@15:32:11.408]	m4-dev
[2021-01-08@15:32:11.408]	nettle
[2021-01-08@15:32:11.408]	parted
[2021-01-08@15:32:11.408]	tar
[2021-01-08@15:32:11.408]	which
[2021-01-08@15:32:11.408]If you do not wish to distribute[    9.436289] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
[2021-01-08@15:32:11.423] GPLv3 components please remove
[2021-01-08@15:32:11.423]the above packages prior to distribution.  This can be done using
[2021-01-08@15:32:11.423]the opkg remove command.  i.e.:
[2021-01-08@15:32:11.423]    opkg remove <package>
[2021-01-08@15:32:11.439]Where <package> is the name printed in the list above
[2021-01-08@15:32:11.439]NOTE: If the package is a dependency of another package you
[2021-01-08@15:32:11.439]      will be notified of the dependent packages.  You should
[2021-01-08@15:32:11.454]      use the --force-removal-of-dependent-packages option to
[2021-01-08@15:32:11.454]      also remove the dependent packages as well
[2021-01-08@15:32:11.454]***************************************************************
[2021-01-08@15:32:11.470]***************************************************************
[2021-01-08@15:32:11.486][  OK  ] Started Print notice about GPLv3 packages.
[2021-01-08@15:32:11.548][    9.580626] j721e-audio sound@0: pcm3168a-adc <-> 2ba0000.mcasp mapping ok
[2021-01-08@15:32:11.595][    9.624243] remoteproc remoteproc7: 5f00000.r5f is available
[2021-01-08@15:32:11.642][  OK  ] Created slice system-systemd\x2dfsck.slice.
[2021-01-08@15:32:11.688][    9.725694] remoteproc remoteproc7: powering up 5f00000.r5f
[2021-01-08@15:32:11.704][    9.731282] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 95476
[2021-01-08@15:32:11.704][    9.744474] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@15:32:11.735][    9.755162]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
[2021-01-08@15:32:11.751][    9.769216] virtio_rpmsg_bus virtio7: rpmsg host is online
[2021-01-08@15:32:11.751][    9.776511]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
[2021-01-08@15:32:11.766][    9.787072] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
[2021-01-08@15:32:11.782][    9.798738] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@15:32:12.281][  OK  ] Found device /dev/mmcblk0p2.
[2021-01-08@15:32:12.312]         Starting File System Check on /dev/mmcblk0p2...
[2021-01-08@15:32:12.422][  OK  ] Created slice system-weston.slice.
[2021-01-08@15:32:12.422][  OK  ] Started Weston Wayland Compositor.
[2021-01-08@15:32:12.437][  OK  ] Started File System Check on /dev/mmcblk0p2.
[2021-01-08@15:32:12.437][   10.462529] remoteproc remoteproc8: b034000.pru is available
[2021-01-08@15:32:12.453]         Mounting /run/media/mmcblk0p2...
[2021-01-08@15:32:12.468][  OK  ] Created slice User Slice of UID 0.
[2021-01-08@15:32:12.484][   10.498420] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[2021-01-08@15:32:12.500]         Starting User Runtime Directory /run/user/0...
[2021-01-08@15:32:12.515][  OK  ] Mounted /run/media/mmcblk0p2.
[2021-01-08@15:32:12.531][   10.550052] pru-rproc b034000.pru: PRU rproc node /interconnect@100000/icssg@b000000/pru@34000 probed successfully
[2021-01-08@15:32:12.547][  OK  ] Started User Runtime Directory /run/user/0.
[2021-01-08@15:32:12.547]         Starting User Manager for UID 0...
[2021-01-08@15:32:12.688][   10.706716] remoteproc remoteproc9: b004000.rtu is available
[2021-01-08@15:32:12.688][   10.715744] omap_rng 4e10000.trng: Random Number Generator ver. 241b34c
[2021-01-08@15:32:12.719][   10.737910] pru-rproc b004000.rtu: PRU rproc node /interconnect@100000/icssg@b000000/rtu@4000 probed successfully
[2021-01-08@15:32:12.719][  OK  ] Found device /dev/mmcblk0p1.
[2021-01-08@15:32:12.735]         Starting File System Check on /dev/mmcblk0p1...
[2021-01-08@15:32:12.797][  OK  ] Started File System Check on /dev/mmcblk0p1.
[2021-01-08@15:32:12.813]         Mounting /run/media/mmcblk0p1...
[2021-01-08@15:32:12.828][  OK  ] Found device /dev/mmcblk1p1.
[2021-01-08@15:32:12.844][   10.864744] pru-rproc b00a000.txpru: IRQ vring not found
[2021-01-08@15:32:12.859][  OK  ] Started User Manager for UID 0.
[2021-01-08@15:32:12.875][  OK  ] Mounted /run/media/mmcblk0p1.
[2021-01-08@15:32:12.891][  OK  ] Started Session c1 of user root.
[2021-01-08@15:32:12.906]         Starting File System Check on /dev/mmcblk1p1...
[2021-01-08@15:32:12.953][   10.983205] pru-rproc b00a000.txpru: IRQ kick not found
[2021-01-08@15:32:13.015][   11.037023] remoteproc remoteproc10: b00a000.txpru is available
[2021-01-08@15:32:13.078]         Starting Save/Restore Sound Card State...
[2021-01-08@15:32:13.125][   11.134626] pru-rproc b00a000.txpru: PRU rproc node /interconnect@100000/icssg@b000000/txpru@a000 probed successfully
[2021-01-08@15:32:13.125][  OK  ] Started File System Check on /dev/mmcblk1p1.
[2021-01-08@15:32:13.140][   11.154820] cdns-usb3 6000000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[2021-01-08@15:32:13.140][   11.155443] remoteproc remoteproc11: b038000.pru is available
[2021-01-08@15:32:13.156]         Mounting /run/media/mmcblk1p1...
[2021-01-08@15:32:13.171][  OK  ] Started Save/Restore Sound Card State.
[2021-01-08@15:32:13.187][   11.210011] pru-rproc b038000.pru: PRU rproc node /interconnect@100000/icssg@b000000/pru@38000 probed successfully
[2021-01-08@15:32:13.203][  OK  ] Reached target Sound Card.
[2021-01-08@15:32:13.218][   11.239125] remoteproc remoteproc12: b006000.rtu is available
[2021-01-08@15:32:13.234][   11.250896] pru-rproc b006000.rtu: PRU rproc node /interconnect@100000/icssg@b000000/rtu@6000 probed successfully
[2021-01-08@15:32:13.234][   11.262663] cdns-usb3 6400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[2021-01-08@15:32:13.249][   11.272168] pru-rproc b00c000.txpru: IRQ vring not found
[2021-01-08@15:32:13.281][  OK  ] Mounted /run/media/mmcblk1p1.
[2021-01-08@15:32:13.312][   11.332859] pru-rproc b00c000.txpru: IRQ kick not found
[2021-01-08@15:32:13.312][   11.342946] remoteproc remoteproc13: b00c000.txpru is available
[2021-01-08@15:32:13.343][   11.371187] usbcore: registered new interface driver usbfs
[2021-01-08@15:32:13.359][   11.377632] pru-rproc b00c000.txpru: PRU rproc node /interconnect@100000/icssg@b000000/txpru@c000 probed successfully
[2021-01-08@15:32:13.359][   11.381775] usbcore: registered new interface driver hub
[2021-01-08@15:32:13.374][   11.404556] usbcore: registered new device driver usb
[2021-01-08@15:32:13.390][   11.414392] remoteproc remoteproc14: b134000.pru is available
[2021-01-08@15:32:13.405][   11.427498] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[2021-01-08@15:32:13.421][   11.437803] pru-rproc b134000.pru: PRU rproc node /interconnect@100000/icssg@b100000/pru@34000 probed successfully
[2021-01-08@15:32:13.421][   11.449594] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[2021-01-08@15:32:13.421][   11.454331] remoteproc remoteproc15: b104000.rtu is available
[2021-01-08@15:32:13.437][   11.464382] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
[2021-01-08@15:32:13.468][   11.469587] pru-rproc b104000.rtu: PRU rproc node /interconnect@100000/icssg@b100000/rtu@4000 probed successfully
[2021-01-08@15:32:13.468][   11.487879] xhci-hcd xhci-hcd.2.auto: irq 507, io mem 0x06410000
[2021-01-08@15:32:13.483][   11.503125] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[2021-01-08@15:32:13.483][  OK  ] Started weston.service.
[2021-01-08@15:32:13.483][   11.518533] pru-rproc b10a000.txpru: IRQ vring not found
[2021-01-08@15:32:13.499]         Starting DEMO...[   11.530025] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2021-01-08@15:32:13.515]         Starting telnetd.service...
[2021-01-08@15:32:13.561][   11.589199] usb usb1: Product: xHCI Host Controller
[2021-01-08@15:32:13.561][   11.593877] pru-rproc b10a000.txpru: IRQ kick not found
[2021-01-08@15:32:13.577][   11.602154] remoteproc remoteproc16: b10a000.txpru is available
[2021-01-08@15:32:13.577][   11.608450] usb usb1: Manufacturer: Linux 5.4.40+ xhci-hcd
[2021-01-08@15:32:13.608][   11.628661] pru-rproc b10a000.txpru: PRU rproc node /interconnect@100000/icssg@b100000/txpru@a000 probed successfully
[2021-01-08@15:32:13.608][   11.640846] usb usb1: SerialNumber: xhci-hcd.2.auto
[2021-01-08@15:32:13.624][   11.650452] remoteproc remoteproc17: b138000.pru is available
[2021-01-08@15:32:13.624][   11.657682] hub 1-0:1.0: USB hub found
[2021-01-08@15:32:13.655][   11.662225] pru-rproc b138000.pru: PRU rproc node /interconnect@100000/icssg@b100000/pru@38000 probed successfully
[2021-01-08@15:32:13.655][   11.668773] hub 1-0:1.0: 1 port detected
[2021-01-08@15:32:13.655][   11.680169] remoteproc remoteproc18: b106000.rtu is available
[2021-01-08@15:32:13.671][   11.689597] pru-rproc b106000.rtu: PRU rproc node /interconnect@100000/icssg@b100000/rtu@6000 probed successfully
[2021-01-08@15:32:13.686][   11.689886] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[2021-01-08@15:32:13.702][   11.714532] pru-rproc b10c000.txpru: IRQ vring not found
[2021-01-08@15:32:13.702][   11.725749] pru-rproc b10c000.txpru: IRQ kick not found
[2021-01-08@15:32:13.717][   11.727090] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[2021-01-08@15:32:13.717][   11.737682] remoteproc remoteproc19: b10c000.txpru is available
[2021-01-08@15:32:13.733][   11.749609] pru-rproc b10c000.txpru: PRU rproc node /interconnect@100000/icssg@b100000/txpru@c000 probed successfully
[2021-01-08@15:32:13.733][   11.755084] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[2021-01-08@15:32:13.764][   11.790883] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[2021-01-08@15:32:13.905][   11.930104] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[2021-01-08@15:32:13.920][   11.950478] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2021-01-08@15:32:13.951][   11.970324] usb usb2: Product: xHCI Host Controller
[2021-01-08@15:32:13.951][   11.982827] usb usb2: Manufacturer: Linux 5.4.40+ xhci-hcd
[2021-01-08@15:32:13.967][   11.989581] usb usb2: SerialNumber: xhci-hcd.2.auto
[2021-01-08@15:32:13.967][   11.998158] hub 2-0:1.0: USB hub found
[2021-01-08@15:32:13.983][   12.005575] hub 2-0:1.0: 1 port detected
[2021-01-08@15:32:14.014][   12.033573] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[2021-01-08@15:32:14.154][   12.189838] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[2021-01-08@15:32:14.170][   12.200430] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[2021-01-08@15:32:14.185][   12.211795] usb 1-1: SerialNumber: 5C0100797885
[2021-01-08@15:32:14.185][   12.219578] hub 1-1:1.0: USB hub found
[2021-01-08@15:32:14.185][   12.225522] hub 1-1:1.0: 4 ports detected
[2021-01-08@15:32:14.544]
[2021-01-08@15:32:14.544] _____                    _____           _         _
[2021-01-08@15:32:14.560]|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
[2021-01-08@15:32:14.560]|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
[2021-01-08@15:32:14.560]|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
[2021-01-08@15:32:14.575]              |___|                    |___|
[2021-01-08@15:32:14.575]Arago Project http://arago-project.org j7-evm ttyS2
[2021-01-08@15:32:14.575]Arago 2020.05 j7-evm ttyS2
TDA4 EVM Log
[2021-01-08@14:53:6.992]U-Boot SPL 2020.01-g2b4a28f (Jan 08 2021 - 14:34:42 +0800)
[2021-01-08@14:53:6.992]SYSFW ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[2021-01-08@14:53:7.163]Trying to boot from MMC2
[2021-01-08@14:53:7.319]Loading Environment from MMC... *** Warning - No MMC card found, using default environment
[2021-01-08@14:53:7.803]Remoteproc 2 started successfully
[2021-01-08@14:53:8.053]Starting ATF on ARM64 core...
[2021-01-08@14:53:8.053]NOTICE:  BL31: v2.3():07.00.00.005-dirty
[2021-01-08@14:53:8.053]NOTICE:  BL31: Built : 14:33:55, Jun 17 2020
[2021-01-08@14:53:8.162]
[2021-01-08@14:53:8.162]U-Boot SPL 2020.01-g2b4a28f (Jan 08 2021 - 14:34:48 +0800)
[2021-01-08@14:53:8.162]SYSFW ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[2021-01-08@14:53:8.193]Detected: J7X-BASE-CPB rev E3
[2021-01-08@14:53:8.209]Detected: J7X-VSC8514-ETH rev E2
[2021-01-08@14:53:8.209]Diagnostic Key Check
[2021-01-08@14:53:8.318]Trying to boot from MMC2
[2021-01-08@14:53:8.833]
[2021-01-08@14:53:8.848]U-Boot 2020.01-g2b4a28f (Jan 08 2021 - 14:34:48 +0800)
[2021-01-08@14:53:8.848]SoC:   J721E SR1.0
[2021-01-08@14:53:8.848]Model: Texas Instruments K3 J721E SoC
[2021-01-08@14:53:8.848]Board: J721EX-PM2-SOM rev E7
[2021-01-08@14:53:8.848]DRAM:  4 GiB
[2021-01-08@14:53:8.879]Flash: 0 Bytes
[2021-01-08@14:53:8.879]MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
[2021-01-08@14:53:9.051]Loading Environment from MMC... OK
[2021-01-08@14:53:9.051]In:    serial@2800000
[2021-01-08@14:53:9.051]Out:   serial@2800000
[2021-01-08@14:53:9.051]Err:   serial@2800000
[2021-01-08@14:53:9.113]Detected: J7X-BASE-CPB rev E3
[2021-01-08@14:53:9.145]Detected: J7X-VSC8514-ETH rev E2
[2021-01-08@14:53:9.160]Net:   eth0: ethernet@046000000
[2021-01-08@14:53:11.157]Hit any key to stop autoboot:  0
[2021-01-08@14:53:11.469]switch to partitions #0, OK
[2021-01-08@14:53:11.469]mmc1 is current device
[2021-01-08@14:53:11.750]SD/MMC found on device 1
[2021-01-08@14:53:11.750]58 bytes read in 2 ms (28.3 KiB/s)
[2021-01-08@14:53:11.750]Loaded env from uEnv.txt
[2021-01-08@14:53:11.765]Importing environment from mmc1 ...
[2021-01-08@14:53:11.781]95476 bytes read in 9 ms (10.1 MiB/s)
[2021-01-08@14:53:11.797]Load Remote Processor 3 with data@addr=0x80080000 95476 bytes: Success!
[2021-01-08@14:53:11.812]95476 bytes read in 7 ms (13 MiB/s)
[2021-01-08@14:53:11.812]Load Remote Processor 4 with data@addr=0x80080000 95476 bytes: Success!
[2021-01-08@14:53:11.828]95476 bytes read in 9 ms (10.1 MiB/s)
[2021-01-08@14:53:11.828]Load Remote Processor 5 with data@addr=0x80080000 95476 bytes: Success!
[2021-01-08@14:53:11.843]192416 bytes read in 10 ms (18.3 MiB/s)
[2021-01-08@14:53:11.859]Load Remote Processor 6 with data@addr=0x80080000 192416 bytes: Success!
[2021-01-08@14:53:11.875]192416 bytes read in 11 ms (16.7 MiB/s)
[2021-01-08@14:53:11.875]Load Remote Processor 7 with data@addr=0x80080000 192416 bytes: Success!
[2021-01-08@14:53:12.109]10489904 bytes read in 222 ms (45.1 MiB/s)
[2021-01-08@14:53:12.109]Load Remote Processor 8 with data@addr=0x80080000 10489904 bytes: Success!
[2021-01-08@14:53:12.467]16654344 bytes read in 347 ms (45.8 MiB/s)
[2021-01-08@14:53:12.483]90652 bytes read in 5 ms (17.3 MiB/s)
[2021-01-08@14:53:12.483]## Flattened Device Tree blob at 82000000
[2021-01-08@14:53:12.483]   Booting using the fdt blob at 0x82000000
[2021-01-08@14:53:12.499]   Loading Device Tree to 00000000fdd9f000, end 00000000fdeb8fff ... OK
[2021-01-08@14:53:12.514]
[2021-01-08@14:53:12.514]Starting kernel ...
[2021-01-08@14:53:12.655][    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[2021-01-08@14:53:12.670][    0.000000] Linux version 5.4.40+ (pierrehsieh@dell-r540) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Thu Jan 7 17:45:38 CST 2021
[2021-01-08@14:53:12.686][    0.000000] Machine model: Texas Instruments K3 J721E SoC
[2021-01-08@14:53:12.686][    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[2021-01-08@14:53:12.686][    0.000000] printk: bootconsole [ns16550a0] enabled
[2021-01-08@14:53:12.701][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[2021-01-08@14:53:12.701][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[2021-01-08@14:53:12.717][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[2021-01-08@14:53:12.717][    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[2021-01-08@14:53:12.733][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[2021-01-08@14:53:12.748][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[2021-01-08@14:53:12.748][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 31 MiB
[2021-01-08@14:53:12.764][    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[2021-01-08@14:53:12.764][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[2021-01-08@14:53:12.779][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[2021-01-08@14:53:12.779][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[2021-01-08@14:53:12.795][    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[2021-01-08@14:53:12.795][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[2021-01-08@14:53:12.811][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[2021-01-08@14:53:12.811][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[2021-01-08@14:53:12.826][    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[2021-01-08@14:53:12.826][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[2021-01-08@14:53:12.842][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[2021-01-08@14:53:12.857][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[2021-01-08@14:53:12.857][    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[2021-01-08@14:53:12.873][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[2021-01-08@14:53:12.873][    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[2021-01-08@14:53:12.889][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[2021-01-08@14:53:12.889][    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[2021-01-08@14:53:12.920][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[2021-01-08@14:53:12.920][    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[2021-01-08@14:53:12.935][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[2021-01-08@14:53:12.951][    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[2021-01-08@14:53:12.951][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[2021-01-08@14:53:12.967][    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[2021-01-08@14:53:12.967][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[2021-01-08@14:53:12.982][    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[2021-01-08@14:53:12.982][    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 32 MiB
[2021-01-08@14:53:12.998][    0.000000] OF: reserved mem: initialized node vision_apps-dma-memory@ac000000, compatible id shared-dma-pool
[2021-01-08@14:53:12.998][    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[2021-01-08@14:53:13.013][    0.000000] Reserved memory: created DMA memory pool at 0x00000000ce000000, size 720 MiB
[2021-01-08@14:53:13.029][    0.000000] OF: reserved mem: initialized node vision_apps-core-heap-memory@ce000000, compatible id shared-dma-pool
[2021-01-08@14:53:13.029][    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 1 MiB
[2021-01-08@14:53:13.045][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@fb000000, compatible id shared-dma-pool
[2021-01-08@14:53:13.045][    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100000, size 15 MiB
[2021-01-08@14:53:13.060][    0.000000] OF: reserved mem: initialized node r5f-memory@fb100000, compatible id shared-dma-pool
[2021-01-08@14:53:13.060][    0.000000] cma: Failed to reserve 512 MiB
[2021-01-08@14:53:13.076][    0.000000] psci: probing for conduit method from DT.
[2021-01-08@14:53:13.091][    0.000000] psci: PSCIv1.1 detected in firmware.
[2021-01-08@14:53:13.091][    0.000000] psci: Using standard PSCI v0.2 function IDs
[2021-01-08@14:53:13.091][    0.000000] psci: Trusted OS migration not required
[2021-01-08@14:53:13.107][    0.000000] psci: SMC Calling Convention v1.0
[2021-01-08@14:53:13.107][    0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072
[2021-01-08@14:53:13.107][    0.000000] Detected PIPT I-cache on CPU0
[2021-01-08@14:53:13.123][    0.000000] CPU features: detected: GIC system register CPU interface
[2021-01-08@14:53:13.123][    0.000000] CPU features: detected: EL2 vector hardening
[2021-01-08@14:53:13.123][    0.000000] Built 1 zonelists, mobility grouping off.  Total pages: 35779
[2021-01-08@14:53:13.169][    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=f89fc473-02 rw rootfstype=ext4 rootwait
[2021-01-08@14:53:13.169][    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[2021-01-08@14:53:13.185][    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[2021-01-08@14:53:13.185][    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[2021-01-08@14:53:13.201][    0.000000] software IO TLB: mapped [mem 0x9a800000-0x9e800000] (64MB)
[2021-01-08@14:53:13.216][    0.000000] Memory: 2584000K/2293760K available (9534K kernel code, 776K rwdata, 3840K rodata, 1728K init, 695K bss, 18446744073709261376K reserved, 0K cma-reserved)
[2021-01-08@14:53:13.232][    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2021-01-08@14:53:13.232][    0.000000] rcu: Preemptible hierarchical RCU implementation.
[2021-01-08@14:53:13.232][    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[2021-01-08@14:53:13.247][    0.000000] 	Tasks RCU enabled.
[2021-01-08@14:53:13.247][    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[2021-01-08@14:53:13.263][    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[2021-01-08@14:53:13.263][    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[2021-01-08@14:53:13.263][    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[2021-01-08@14:53:13.279][    0.000000] GICv3: 960 SPIs implemented
[2021-01-08@14:53:13.279][    0.000000] GICv3: 0 Extended SPIs implemented
[2021-01-08@14:53:13.279][    0.000000] GICv3: Distributor has no Range Selector support
[2021-01-08@14:53:13.279][    0.000000] GICv3: 16 PPIs implemented
[2021-01-08@14:53:13.294][    0.000000] GICv3: no VLPI support, no direct LPI support
[2021-01-08@14:53:13.294][    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[2021-01-08@14:53:13.294][    0.000000] ITS [mem 0x01820000-0x0182ffff]
[2021-01-08@14:53:13.310][    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[2021-01-08@14:53:13.325][    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
[2021-01-08@14:53:13.325][    0.000000] ITS: using cache flushing for cmd queue
[2021-01-08@14:53:13.325][    0.000000] GICv3: using LPI property table @0x00000008c00c0000
[2021-01-08@14:53:13.341][    0.000000] GIC: using cache flushing for LPI property table
[2021-01-08@14:53:13.341][    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000
[2021-01-08@14:53:13.357][    0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x438 with crng_init=0
[2021-01-08@14:53:13.357][    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[2021-01-08@14:53:13.372][    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[2021-01-08@14:53:13.372][    0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[2021-01-08@14:53:13.388][    0.008328] Console: colour dummy device 80x25
[2021-01-08@14:53:13.388][    0.012883] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[2021-01-08@14:53:13.403][    0.023552] pid_max: default: 32768 minimum: 301
[2021-01-08@14:53:13.403][    0.028299] LSM: Security Framework initializing
[2021-01-08@14:53:13.403][    0.033042] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[2021-01-08@14:53:13.419][    0.040611] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[2021-01-08@14:53:13.450][    0.072653] ASID allocator initialised with 32768 entries
[2021-01-08@14:53:13.466][    0.086180] rcu: Hierarchical SRCU implementation.
[2021-01-08@14:53:13.466][    0.099123] Platform MSI: gic-its@1820000 domain created
[2021-01-08@14:53:13.481][    0.104648] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created
[2021-01-08@14:53:13.497][    0.122084] smp: Bringing up secondary CPUs ...
[2021-01-08@14:53:13.528][    0.159037] Detected PIPT I-cache on CPU1
[2021-01-08@14:53:13.559][    0.159054] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[2021-01-08@14:53:13.559][    0.159064] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000
[2021-01-08@14:53:13.559][    0.159083] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[2021-01-08@14:53:13.575][    0.159120] smp: Brought up 1 node, 2 CPUs
[2021-01-08@14:53:13.575][    0.188463] SMP: Total of 2 processors activated.
[2021-01-08@14:53:13.575][    0.193267] CPU features: detected: 32-bit EL0 Support
[2021-01-08@14:53:13.591][    0.198520] CPU features: detected: CRC32 instructions
[2021-01-08@14:53:13.591][    0.209885] CPU: All CPU(s) started at EL2
[2021-01-08@14:53:13.606][    0.214078] alternatives: patching kernel code
[2021-01-08@14:53:13.606][    0.219021] devtmpfs: initialized
[2021-01-08@14:53:13.622][    0.226428] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[2021-01-08@14:53:13.622][    0.236395] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[2021-01-08@14:53:13.622][    0.243521] pinctrl core: initialized pinctrl subsystem
[2021-01-08@14:53:13.637][    0.249192] NET: Registered protocol family 16
[2021-01-08@14:53:13.637][    0.253910] DMA: preallocated 256 KiB pool for atomic allocations
[2021-01-08@14:53:13.653][    0.260397] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[2021-01-08@14:53:13.669][    0.275702] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[2021-01-08@14:53:13.669][    0.282553] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[2021-01-08@14:53:13.669][    0.289313] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[2021-01-08@14:53:13.684][    0.297963] cryptd: max_cpu_qlen set to 1000
[2021-01-08@14:53:13.684][    0.305085] vsys_3v3: supplied by evm_12v0
[2021-01-08@14:53:13.684][    0.309368] vsys_5v0: supplied by evm_12v0
[2021-01-08@14:53:13.700][    0.313969] iommu: Default domain type: Translated
[2021-01-08@14:53:13.700][    0.319087] SCSI subsystem initialized
[2021-01-08@14:53:13.700][    0.323180] mc: Linux media interface: v0.10
[2021-01-08@14:53:13.715][    0.327567] videodev: Linux video capture interface: v2.00
[2021-01-08@14:53:13.715][    0.333183] pps_core: LinuxPPS API ver. 1 registered
[2021-01-08@14:53:13.731][    0.338253] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[2021-01-08@14:53:13.731][    0.347590] PTP clock support registered
[2021-01-08@14:53:13.731][    0.351600] EDAC MC: Ver: 3.0.0
[2021-01-08@14:53:13.731][    0.355264] FPGA manager framework
[2021-01-08@14:53:13.747][    0.358766] Advanced Linux Sound Architecture Driver Initialized.
[2021-01-08@14:53:13.747][    0.365271] clocksource: Switched to clocksource arch_sys_counter
[2021-01-08@14:53:13.747][    0.371575] VFS: Disk quotas dquot_6.6.0
[2021-01-08@14:53:13.762][    0.375623] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[2021-01-08@14:53:13.762][    0.385000] Carveout Heap: Exported 512 MiB at 0x00000000ae000000
[2021-01-08@14:53:13.778][    0.391230] thermal_sys: Registered thermal governor 'step_wise'
[2021-01-08@14:53:13.778][    0.391231] thermal_sys: Registered thermal governor 'power_allocator'
[2021-01-08@14:53:13.778][    0.397534] NET: Registered protocol family 2
[2021-01-08@14:53:13.793][    0.408867] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[2021-01-08@14:53:13.793][    0.417626] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[2021-01-08@14:53:13.809][    0.425820] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[2021-01-08@14:53:13.809][    0.433508] TCP: Hash tables configured (established 32768 bind 32768)
[2021-01-08@14:53:13.825][    0.440244] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[2021-01-08@14:53:13.825][    0.447132] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[2021-01-08@14:53:13.840][    0.454514] NET: Registered protocol family 1
[2021-01-08@14:53:13.840][    0.459209] RPC: Registered named UNIX socket transport module.
[2021-01-08@14:53:13.840][    0.465269] RPC: Registered udp transport module.
[2021-01-08@14:53:13.856][    0.470073] RPC: Registered tcp transport module.
[2021-01-08@14:53:13.856][    0.474874] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2021-01-08@14:53:13.856][    0.481456] PCI: CLS 0 bytes, default 64
[2021-01-08@14:53:13.871][    0.485704] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[2021-01-08@14:53:13.871][    0.497136] Initialise system trusted keyrings
[2021-01-08@14:53:13.887][    0.501742] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[2021-01-08@14:53:13.887][    0.510202] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2021-01-08@14:53:13.887][    0.516433] NFS: Registering the id_resolver key type
[2021-01-08@14:53:13.903][    0.521607] Key type id_resolver registered
[2021-01-08@14:53:13.903][    0.525877] Key type id_legacy registered
[2021-01-08@14:53:13.903][    0.529973] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[2021-01-08@14:53:13.918][    0.536898] 9p: Installing v9fs 9p2000 file system support
[2021-01-08@14:53:13.934][    0.549660] Key type asymmetric registered
[2021-01-08@14:53:13.934][    0.553846] Asymmetric key parser 'x509' registered
[2021-01-08@14:53:13.934][    0.558849] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[2021-01-08@14:53:13.949][    0.566410] io scheduler mq-deadline registered
[2021-01-08@14:53:13.949][    0.571036] io scheduler kyber registered
[2021-01-08@14:53:13.949][    0.576160] pinctrl-single 4301c000.pinmux: 94 pins, size 376
[2021-01-08@14:53:13.965][    0.582221] pinctrl-single 11c000.pinmux: 173 pins, size 692
[2021-01-08@14:53:13.965][    0.588349] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[2021-01-08@14:53:13.981][    0.597229] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[2021-01-08@14:53:13.981][    0.603492] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[2021-01-08@14:53:13.981][    0.609814] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[2021-01-08@14:53:13.996][    0.616225] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[2021-01-08@14:53:13.996][    0.624174] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[2021-01-08@14:53:14.012][    0.630585] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[2021-01-08@14:53:14.012][    0.638530] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[2021-01-08@14:53:14.027][    0.644944] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[2021-01-08@14:53:14.027][    0.652871] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[2021-01-08@14:53:14.043][    0.659194] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[2021-01-08@14:53:14.043][    0.667114] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[2021-01-08@14:53:14.043][    0.673435] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[2021-01-08@14:53:14.059][    0.682734] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[2021-01-08@14:53:14.059][    0.694414] brd: module loaded
[2021-01-08@14:53:14.074][    0.700395] loop: module loaded
[2021-01-08@14:53:14.074][    0.704925] libphy: Fixed MDIO Bus: probed
[2021-01-08@14:53:14.090][    0.709280] tun: Universal TUN/TAP device driver, 1.6
[2021-01-08@14:53:14.090][    0.714675] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[2021-01-08@14:53:14.090][    0.722682] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[2021-01-08@14:53:14.105][    0.728748] sky2: driver version 1.30
[2021-01-08@14:53:14.105][    0.732955] VFIO - User Level meta-driver version: 0.3
[2021-01-08@14:53:14.105][    0.738541] i2c /dev entries driver
[2021-01-08@14:53:14.121][    0.742618] sdhci: Secure Digital Host Controller Interface driver
[2021-01-08@14:53:14.121][    0.748934] sdhci: Copyright(c) Pierre Ossman
[2021-01-08@14:53:14.121][    0.753577] sdhci-pltfm: SDHCI platform and OF driver helper
[2021-01-08@14:53:14.137][    0.759812] ledtrig-cpu: registered to indicate activity on CPUs
[2021-01-08@14:53:14.137][    0.766544] optee: probing for conduit method from DT.
[2021-01-08@14:53:14.137][    0.771807] optee: revision 3.8 (199fca17)
[2021-01-08@14:53:14.152][    0.772120] optee: initialized driver
[2021-01-08@14:53:14.168][    0.780737] NET: Registered protocol family 17
[2021-01-08@14:53:14.168][    0.785342] 9pnet: Installing 9P2000 support
[2021-01-08@14:53:14.183][    0.789724] Key type dns_resolver registered
[2021-01-08@14:53:14.183][    0.794210] registered taskstats version 1
[2021-01-08@14:53:14.183][    0.798396] Loading compiled-in X.509 certificates
[2021-01-08@14:53:14.199][    0.807169] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[2021-01-08@14:53:14.199][    0.813483] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[2021-01-08@14:53:14.215][    0.821090] ti-sci 44083000.dmsc: ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[2021-01-08@14:53:14.230][    0.845808] random: fast init done
[2021-01-08@14:53:14.261][    0.876918] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[2021-01-08@14:53:14.277][    0.884201] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[2021-01-08@14:53:14.277][    0.890181] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[2021-01-08@14:53:14.277][    0.896153] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[2021-01-08@14:53:14.293][    0.902180] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
[2021-01-08@14:53:14.324][    0.933782] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
[2021-01-08@14:53:14.324][    0.941804] GPIO line 478 (MCAN0_EN) hogged as output/high
[2021-01-08@14:53:14.324][    0.947599] GPIO line 479 (MCAN0_STBN) hogged as output/high
[2021-01-08@14:53:14.339][    0.953832] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low
[2021-01-08@14:53:14.339][    0.960425] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high
[2021-01-08@14:53:14.355][    0.967120] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[2021-01-08@14:53:14.355][    0.973103] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[2021-01-08@14:53:14.355][    0.978979] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
[2021-01-08@14:53:14.371][    0.984928] pca953x 6-0020: 6-0020 supply vcc not found, using dummy regulator
[2021-01-08@14:53:14.402][    1.013664] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[2021-01-08@14:53:14.402][    1.019552] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[2021-01-08@14:53:14.402][    1.025423] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[2021-01-08@14:53:14.417][    1.031369] pca953x 9-0020: 9-0020 supply vcc not found, using dummy regulator
[2021-01-08@14:53:14.449][    1.061575] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[2021-01-08@14:53:14.449][    1.067784] ti-sci-intr interconnect@100000:interconnect@28380000:interrupt-controller2: Interrupt Router 137 domain created
[2021-01-08@14:53:14.464][    1.079345] ti-sci-intr interconnect@100000:interrupt-controller0: Interrupt Router 131 domain created
[2021-01-08@14:53:14.480][    1.088950] ti-sci-intr interconnect@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created
[2021-01-08@14:53:14.480][    1.099950] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[2021-01-08@14:53:14.495][    1.116556] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[2021-01-08@14:53:15.509][    2.125053] j721e-pcie 2900000.pcie: host bridge /interconnect@100000/pcie@2900000 ranges:
[2021-01-08@14:53:15.525][    2.133523] j721e-pcie 2900000.pcie:    IO 0x10001000..0x10010fff -> 0x10001000
[2021-01-08@14:53:15.525][    2.141000] j721e-pcie 2900000.pcie:   MEM 0x10011000..0x17ffffff -> 0x10011000
[2021-01-08@14:53:15.541][    2.148534] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[2021-01-08@14:53:15.541][    2.154939] pci_bus 0000:00: root bus resource [bus 00-0f]
[2021-01-08@14:53:15.556][    2.160544] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[2021-01-08@14:53:15.556][    2.170234] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[2021-01-08@14:53:15.556][    2.177275] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[2021-01-08@14:53:15.572][    2.183427] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[2021-01-08@14:53:15.587][    2.193297] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[2021-01-08@14:53:15.587][    2.203182] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
[2021-01-08@14:53:15.603][    2.213140] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[2021-01-08@14:53:15.603][    2.223105] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[2021-01-08@14:53:15.619][    2.233065] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[2021-01-08@14:53:15.619][    2.243064] pci 0000:00:00.0: supports D1
[2021-01-08@14:53:15.634][    2.247157] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[2021-01-08@14:53:15.634][    2.253029] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[2021-01-08@14:53:15.650][    2.262994] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x208 may corrupt adjacent RW1C bits
[2021-01-08@14:53:15.650][    2.273046] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[2021-01-08@14:53:15.665][    2.280072] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[2021-01-08@14:53:15.681][    2.290039] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits
[2021-01-08@14:53:15.681][    2.300086] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits
[2021-01-08@14:53:15.697][    2.311570] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[2021-01-08@14:53:15.697][    2.321059] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
[2021-01-08@14:53:15.712][    2.327829] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
[2021-01-08@14:53:15.712][    2.335301] pci 0000:00:00.0: PCI bridge to [bus 01]
[2021-01-08@14:53:15.728][    2.340530] pcieport 0000:00:00.0: PME: Signaling with IRQ 40
[2021-01-08@14:53:15.728][    2.346569] pcieport 0000:00:00.0: AER: enabled with IRQ 40
[2021-01-08@14:53:16.742][    3.354365] j721e-pcie 2910000.pcie: host bridge /interconnect@100000/pcie@2910000 ranges:
[2021-01-08@14:53:16.757][    3.362840] j721e-pcie 2910000.pcie:    IO 0x18001000..0x18010fff -> 0x18001000
[2021-01-08@14:53:16.757][    3.370315] j721e-pcie 2910000.pcie:   MEM 0x18011000..0x1fffffff -> 0x18011000
[2021-01-08@14:53:16.757][    3.377840] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[2021-01-08@14:53:16.773][    3.384246] pci_bus 0001:00: root bus resource [bus 00-0f]
[2021-01-08@14:53:16.773][    3.389851] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[2021-01-08@14:53:16.789][    3.399718] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[2021-01-08@14:53:16.789][    3.406753] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
[2021-01-08@14:53:16.789][    3.412952] pci 0001:00:00.0: supports D1
[2021-01-08@14:53:16.804][    3.417046] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[2021-01-08@14:53:16.804][    3.424290] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[2021-01-08@14:53:16.820][    3.433774] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
[2021-01-08@14:53:16.820][    3.440537] pci 0001:00:00.0: PCI bridge to [bus 01]
[2021-01-08@14:53:16.835][    3.445750] pcieport 0001:00:00.0: PME: Signaling with IRQ 43
[2021-01-08@14:53:16.835][    3.451731] pcieport 0001:00:00.0: AER: enabled with IRQ 43
[2021-01-08@14:53:17.835][    4.459565] j721e-pcie 2920000.pcie: host bridge /interconnect@100000/pcie@2920000 ranges:
[2021-01-08@14:53:17.850][    4.468040] j721e-pcie 2920000.pcie:    IO 0x4400001000..0x4400010fff -> 0x00001000
[2021-01-08@14:53:17.850][    4.475871] j721e-pcie 2920000.pcie:   MEM 0x4400011000..0x4407ffffff -> 0x00011000
[2021-01-08@14:53:17.866][    4.483753] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
[2021-01-08@14:53:17.866][    4.490158] pci_bus 0002:00: root bus resource [bus 00-0f]
[2021-01-08@14:53:17.866][    4.495763] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[2021-01-08@14:53:17.882][    4.505009] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[2021-01-08@14:53:17.897][    4.515775] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
[2021-01-08@14:53:17.897][    4.521974] pci 0002:00:00.0: supports D1
[2021-01-08@14:53:17.897][    4.526068] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
[2021-01-08@14:53:17.913][    4.533295] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[2021-01-08@14:53:17.913][    4.542768] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
[2021-01-08@14:53:17.928][    4.549533] pci 0002:00:00.0: PCI bridge to [bus 01]
[2021-01-08@14:53:17.928][    4.554734] pcieport 0002:00:00.0: PME: Signaling with IRQ 46
[2021-01-08@14:53:17.928][    4.560713] pcieport 0002:00:00.0: AER: enabled with IRQ 46
[2021-01-08@14:53:17.960][    4.567035] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[2021-01-08@14:53:17.960][    4.576909] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[2021-01-08@14:53:17.975][    4.583667] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[2021-01-08@14:53:17.991][    4.592485] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[2021-01-08@14:53:17.991][    4.602628] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[2021-01-08@14:53:17.991][    4.609386] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[2021-01-08@14:53:18.006][    4.617041] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
[2021-01-08@14:53:18.006][    4.624551] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
[2021-01-08@14:53:18.022][    4.633696] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
[2021-01-08@14:53:18.022][    4.642430] printk: console [ttyS2] enabled
[2021-01-08@14:53:18.022][    4.650866] printk: bootconsole [ns16550a0] disabled
[2021-01-08@14:53:18.038][    4.650866] printk: bootconsole [ns16550a0] disabled
[2021-01-08@14:53:18.038][    4.661194] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 20, base_baud = 3000000) is a 8250
[2021-01-08@14:53:18.053][    4.670012] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 21, base_baud = 3000000) is a 8250
[2021-01-08@14:53:18.053][    4.678748] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
[2021-01-08@14:53:18.069][    4.688122] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq
[2021-01-08@14:53:18.069][    4.696853] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq
[2021-01-08@14:53:18.084][    4.704274] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
[2021-01-08@14:53:18.100][    4.713865] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[2021-01-08@14:53:18.100][    4.724373] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[2021-01-08@14:53:18.116][    4.734526] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[2021-01-08@14:53:18.131][    4.744765] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[2021-01-08@14:53:18.131][    4.755501] scsi host0: ufshcd
[2021-01-08@14:53:18.131][    4.762229] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[2021-01-08@14:53:18.162][    4.768402] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[2021-01-08@14:53:18.162][    4.775001] Creating 7 MTD partitions on "47040000.spi.0":
[2021-01-08@14:53:18.162][    4.780480] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[2021-01-08@14:53:18.162][    4.780482] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[2021-01-08@14:53:18.194][    4.793225] 0x000000080000-0x000000280000 : "ospi.tispl"
[2021-01-08@14:53:18.194][    4.803971] 0x000000280000-0x000000680000 : "ospi.u-boot"
[2021-01-08@14:53:18.194][    4.809729] 0x000000680000-0x0000006a0000 : "ospi.env"
[2021-01-08@14:53:18.194][    4.815251] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[2021-01-08@14:53:18.194][    4.821401] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[2021-01-08@14:53:18.194][    4.827074] 0x000000800000-0x000004000000 : "ospi.rootfs"
[2021-01-08@14:53:18.225][    4.844479] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[2021-01-08@14:53:18.240][    4.856142] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[2021-01-08@14:53:18.240][    4.867412] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[2021-01-08@14:53:18.256][    4.876155] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[2021-01-08@14:53:18.256][    4.884887] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[2021-01-08@14:53:18.459][    5.081483] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[2021-01-08@14:53:18.474][    5.089085] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[2021-01-08@14:53:18.506][    5.129464] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[2021-01-08@14:53:18.552][    5.173279] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[2021-01-08@14:53:18.552][    5.180920] libphy: 46000f00.mdio: probed
[2021-01-08@14:53:18.568][    5.185934] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[2021-01-08@14:53:18.584][    5.194196] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[2021-01-08@14:53:18.584][    5.205618] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[2021-01-08@14:53:18.599][    5.214145] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[2021-01-08@14:53:18.599][    5.222642] mmc0: CQHCI version 5.10
[2021-01-08@14:53:18.646][    5.260984] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[2021-01-08@14:53:18.646][    5.269574] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[2021-01-08@14:53:18.662][    5.276162] davinci_gpio 42110000.gpio: IRQ index 4 not found
[2021-01-08@14:53:18.662][    5.281909] davinci_gpio 42110000.gpio: IRQ not populated, err = -6
[2021-01-08@14:53:18.662][    5.291482] vdd_mmc1: supplied by vsys_3v3
[2021-01-08@14:53:18.677][    5.296057] pca953x 4-0020: 4-0020 supply vcc not found, using dummy regulator
[2021-01-08@14:53:18.708][    5.325812] GPIO line 284 (DP0_PWR_SW_EN) hogged as output/high
[2021-01-08@14:53:18.708][    5.332334] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@14:53:18.724][    5.339165] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@14:53:18.724][    5.346034] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@14:53:18.724][    5.352877] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@14:53:18.740][    5.359678] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[2021-01-08@14:53:18.755][    5.369182] ti-udma 285c0000.dma-controller: Channels: 24 (tchan: 12, rchan: 12, gp-rflow: 8)
[2021-01-08@14:53:18.755][    5.379514] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[2021-01-08@14:53:18.771][    5.391992] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[2021-01-08@14:53:18.771][    5.398174] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[2021-01-08@14:53:18.786][    5.404804] Creating 7 MTD partitions on "47040000.spi.0":
[2021-01-08@14:53:18.786][    5.410290] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[2021-01-08@14:53:18.786][    5.416266] 0x000000080000-0x000000280000 : "ospi.tispl"
[2021-01-08@14:53:18.802][    5.421983] 0x000000280000-0x000000680000 : "ospi.u-boot"
[2021-01-08@14:53:18.802][    5.427820] 0x000000680000-0x0000006a0000 : "ospi.env"
[2021-01-08@14:53:18.802][    5.433422] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[2021-01-08@14:53:18.818][    5.439586] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[2021-01-08@14:53:18.818][    5.445310] 0x000000800000-0x000004000000 : "ospi.rootfs"
[2021-01-08@14:53:18.833][    5.453364] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[2021-01-08@14:53:18.833][    5.459490] mmc0: Command Queue Engine enabled
[2021-01-08@14:53:18.833][    5.463928] mmc0: new HS400 MMC card at address 0001
[2021-01-08@14:53:18.849][    5.469481] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[2021-01-08@14:53:18.849][    5.474142] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[2021-01-08@14:53:18.849][    5.480198] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[2021-01-08@14:53:18.880][    5.486177] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0)
[2021-01-08@14:53:18.880][    5.494717]  mmcblk0: p1 p2
[2021-01-08@14:53:18.927][    5.533279] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[2021-01-08@14:53:18.927][    5.540923] libphy: 46000f00.mdio: probed
[2021-01-08@14:53:18.942][    5.545955] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[2021-01-08@14:53:18.942][    5.554221] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[2021-01-08@14:53:18.958][    5.566420] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[2021-01-08@14:53:18.958][    5.573516] pps pps0: new PPS source ptp1
[2021-01-08@14:53:18.974][    5.577625] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
[2021-01-08@14:53:18.974][    5.586576] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4
[2021-01-08@14:53:18.974][    5.593869] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[2021-01-08@14:53:18.989][    5.600787] mmc1: CQHCI version 5.10
[2021-01-08@14:53:19.020][    5.635191] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit
[2021-01-08@14:53:19.020][    5.643320] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[2021-01-08@14:53:19.036][    5.655181] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[2021-01-08@14:53:19.052][    5.662539] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[2021-01-08@14:53:19.052][    5.669877] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[2021-01-08@14:53:19.067][    5.677192] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[2021-01-08@14:53:19.067][    5.685140] hctosys: unable to open rtc device (rtc0)
[2021-01-08@14:53:19.083][    5.705271] ALSA device list:
[2021-01-08@14:53:19.083][    5.708226]   No soundcards found.
[2021-01-08@14:53:19.098][    5.711831] Waiting for root device PARTUUID=f89fc473-02...
[2021-01-08@14:53:20.534][    7.155142] mmc1: new ultra high speed DDR50 SDXC card at address 5048
[2021-01-08@14:53:20.534][    7.161977] mmcblk1: mmc1:5048 SD128 119 GiB
[2021-01-08@14:53:20.549][    7.169483]  mmcblk1: p1 p2
[2021-01-08@14:53:20.565][    7.186647] EXT4-fs (mmcblk1p2): recovery complete
[2021-01-08@14:53:20.580][    7.191436] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[2021-01-08@14:53:20.580][    7.199528] VFS: Mounted root (ext4 filesystem) on device 179:98.
[2021-01-08@14:53:20.580][    7.210315] devtmpfs: mounted
[2021-01-08@14:53:20.596][    7.213842] Freeing unused kernel memory: 1728K
[2021-01-08@14:53:20.596][    7.218378] Run /sbin/init as init process
[2021-01-08@14:53:20.783][    7.413629] systemd[1]: System time before build time, advancing clock.
[2021-01-08@14:53:20.861][    7.475984] NET: Registered protocol family 10
[2021-01-08@14:53:20.861][    7.480774] Segment Routing with IPv6
[2021-01-08@14:53:20.892][    7.500896] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[2021-01-08@14:53:20.908][    7.516394] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[2021-01-08@14:53:20.939][    7.535997] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[2021-01-08@14:53:20.939][    7.557692] systemd[1]: Detected architecture arm64.
[2021-01-08@14:53:20.970]
[2021-01-08@14:53:20.970]Welcome to Arago 2020.05!
[2021-01-08@14:53:20.986][    7.602544] systemd[1]: Set hostname to <j7-evm>.
[2021-01-08@14:53:21.002][    7.615957] random: systemd: uninitialized urandom read (16 bytes read)
[2021-01-08@14:53:21.002][    7.622570] systemd[1]: Initializing machine ID from random generator.
[2021-01-08@14:53:21.220][    7.820224] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[2021-01-08@14:53:21.267][    7.887139] random: systemd: uninitialized urandom read (16 bytes read)
[2021-01-08@14:53:21.282][    7.893846] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[2021-01-08@14:53:21.282][    7.906187] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[2021-01-08@14:53:21.298][    7.915939] systemd[1]: Created slice system-getty.slice.
[2021-01-08@14:53:21.298][  OK  ] Created slice system-getty.slice.
[2021-01-08@14:53:21.314][    7.933331] random: systemd: uninitialized urandom read (16 bytes read)
[2021-01-08@14:53:21.314][    7.940442] systemd[1]: Created slice system-serial\x2dgetty.slice.
[2021-01-08@14:53:21.329][  OK  ] Created slice system-serial\x2dgetty.slice.
[2021-01-08@14:53:21.345][    7.961762] systemd[1]: Created slice User and Session Slice.
[2021-01-08@14:53:21.345][  OK  ] Created slice User and Session Slice.
[2021-01-08@14:53:21.360][    7.977409] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[2021-01-08@14:53:21.360][  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[2021-01-08@14:53:21.376][    8.001368] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[2021-01-08@14:53:21.392][  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[2021-01-08@14:53:21.392][    8.025356] systemd[1]: Reached target Paths.
[2021-01-08@14:53:21.407][  OK  ] Reached target Paths.
[2021-01-08@14:53:21.407][    8.041321] systemd[1]: Reached target Remote File Systems.
[2021-01-08@14:53:21.423][  OK  ] Reached target Remote File Systems.
[2021-01-08@14:53:21.423][    8.057315] systemd[1]: Reached target Slices.
[2021-01-08@14:53:21.454][  OK  ] Reached target Slices.
[2021-01-08@14:53:21.454][    8.073316] systemd[1]: Reached target Swap.
[2021-01-08@14:53:21.454][  OK  ] Reached target Swap.
[2021-01-08@14:53:21.485][    8.091046] systemd[1]: Listening on RPCbind Server Activation Socket.
[2021-01-08@14:53:21.485][  OK  ] Listening on RPCbind Server Activation Socket.
[2021-01-08@14:53:21.501][    8.109338] systemd[1]: Reached target RPC Port Mapper.
[2021-01-08@14:53:21.501][  OK  ] Reached target RPC Port Mapper.
[2021-01-08@14:53:21.516][    8.128024] systemd[1]: Listening on Process Core Dump Socket.
[2021-01-08@14:53:21.516][  OK  ] Listening on Process Core Dump Socket.
[2021-01-08@14:53:21.532][    8.145405] systemd[1]: Listening on initctl Compatibility Named Pipe.
[2021-01-08@14:53:21.532][  OK  ] Listening on initctl Compatibility Named Pipe.
[2021-01-08@14:53:21.563][    8.179872] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[2021-01-08@14:53:21.579][    8.188125] systemd[1]: Listening on Journal Socket (/dev/log).
[2021-01-08@14:53:21.579][  OK  ] Listening on Journal Socket (/dev/log).
[2021-01-08@14:53:21.594][    8.205506] systemd[1]: Listening on Journal Socket.
[2021-01-08@14:53:21.594][  OK  ] Listening on Journal Socket.
[2021-01-08@14:53:21.610][    8.221531] systemd[1]: Listening on Network Service Netlink Socket.
[2021-01-08@14:53:21.610][  OK  ] Listening on Network Service Netlink Socket.
[2021-01-08@14:53:21.626][    8.241447] systemd[1]: Listening on udev Control Socket.
[2021-01-08@14:53:21.626][  OK  ] Listening on udev Control Socket.
[2021-01-08@14:53:21.641][    8.257405] systemd[1]: Listening on udev Kernel Socket.
[2021-01-08@14:53:21.641][  OK  ] Listening on udev Kernel Socket.
[2021-01-08@14:53:21.657][    8.275736] systemd[1]: Mounting Huge Pages File System...
[2021-01-08@14:53:21.657]         Mounting Huge Pages File System...
[2021-01-08@14:53:21.688][    8.299714] systemd[1]: Mounting POSIX Message Queue File System...
[2021-01-08@14:53:21.688]         Mounting POSIX Message Queue File System...
[2021-01-08@14:53:21.704][    8.323610] systemd[1]: Mounting Kernel Debug File System...
[2021-01-08@14:53:21.704]         Mounting Kernel Debug File System...
[2021-01-08@14:53:21.735][    8.348850] systemd[1]: Mounting Temporary Directory (/tmp)...
[2021-01-08@14:53:21.735]         Mounting Temporary Directory (/tmp)...
[2021-01-08@14:53:21.750][    8.374482] systemd[1]: Starting Create list of static device nodes for the current kernel...
[2021-01-08@14:53:21.766]         Starting Create list of st…odes for the current kernel...
[2021-01-08@14:53:21.782][    8.403402] systemd[1]: Starting Start psplash boot splash screen...
[2021-01-08@14:53:21.797]         Starting Start psplash boot splash screen...
[2021-01-08@14:53:21.813][    8.429129] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[2021-01-08@14:53:21.813][  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[2021-01-08@14:53:21.828][    8.451441] systemd[1]: Starting RPC Bind...
[2021-01-08@14:53:21.828]         Starting RPC Bind...
[2021-01-08@14:53:21.844][    8.469433] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[2021-01-08@14:53:21.860][    8.484572] systemd[1]: Starting Journal Service...
[2021-01-08@14:53:21.891]         [    8.494806] systemd-journald[231]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[2021-01-08@14:53:21.891]Starting Journal Service...
[2021-01-08@14:53:21.906][    8.521848] systemd-journald[231]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[2021-01-08@14:53:21.922][    8.528560] systemd[1]: Starting Load Kernel Modules...
[2021-01-08@14:53:21.922]         Starting Load Kernel Modules...
[2021-01-08@14:53:21.938][    8.563598] systemd[1]: Starting Remount Root and Kernel File Systems...
[2021-01-08@14:53:21.953]         Starting Remount Root and Kernel File Systems EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[2021-01-08@14:53:21.953][0m...
[2021-01-08@14:53:21.969][    8.595411] systemd[1]: Starting udev Coldplug all Devices...
[2021-01-08@14:53:21.984]         Starting udev Coldplug all Devices...
[2021-01-08@14:53:22.016][    8.623599] systemd[1]: Started RPC Bind.
[2021-01-08@14:53:22.016][  OK  ] Started RPC Bind.
[2021-01-08@14:53:22.016][    8.645542] systemd[1]: Started Journal Service.
[2021-01-08@14:53:22.031][  OK  ] Started Journal Service.
[2021-01-08@14:53:22.047][  OK  ] Mounted Huge Pages File System.
[2021-01-08@14:53:22.047][  OK  ] Mounted POSIX Message Queue File System.
[2021-01-08@14:53:22.078][  OK  ] Mounted Kernel Debug File System.
[2021-01-08@14:53:22.094][  OK  ] Mounted Temporary Directory (/tmp).
[2021-01-08@14:53:22.109][  OK  ] Started Create list of sta… nodes for the current kernel.
[2021-01-08@14:53:22.125][FAILED] Failed to start Start psplash boot splash screen.
[2021-01-08@14:53:22.140]See 'systemctl status psplash-start.service' for details.
[2021-01-08@14:53:22.156][DEPEND] Dependency failed for Star…progress communication helper.
[2021-01-08@14:53:22.172][  OK  ] Started Load Kernel Modules.
[2021-01-08@14:53:22.187][  OK  ] Started Remount Root and Kernel File Systems.
[2021-01-08@14:53:22.203]         Mounting Kernel Configuration File System...
[2021-01-08@14:53:22.218]         Starting Flush Journal to Persistent Storage...
[2021-01-08@14:53:22.234][    8.840866] systemd-journald[231]: Received client request to flush runtime journal.
[2021-01-08@14:53:22.234]         Starting Apply Kernel Variables...
[2021-01-08@14:53:22.250]         Starting Create System Users...
[2021-01-08@14:53:22.265][  OK  ] Mounted Kernel Configuration File System.
[2021-01-08@14:53:22.281][  OK  ] Started Flush Journal to Persistent Storage.
[2021-01-08@14:53:22.296][  OK  ] Started Apply Kernel Variables.
[2021-01-08@14:53:22.312][  OK  ] Started Create System Users.
[2021-01-08@14:53:22.328]         Starting Create Static Device Nodes in /dev...
[2021-01-08@14:53:22.343][  OK  ] Started Create Static Device Nodes in /dev.
[2021-01-08@14:53:22.359][  OK  ] Reached target Local File Systems (Pre).
[2021-01-08@14:53:22.374]         Mounting /media/ram...
[2021-01-08@14:53:22.390]         Mounting /var/volatile...
[2021-01-08@14:53:22.406]         Starting udev Kernel Device Manager...
[2021-01-08@14:53:22.421][  OK  ] Started udev Coldplug all Devices.
[2021-01-08@14:53:22.437][  OK  ] Mounted /media/ram.
[2021-01-08@14:53:22.437][  OK  ] Mounted /var/volatile.
[2021-01-08@14:53:22.452]         Starting Load/Save Random Seed...
[2021-01-08@14:53:22.468][  OK  ] Reached target Local File Systems.
[2021-01-08@14:53:22.484]         Starting Rebuild Dynamic Linker Cache...
[2021-01-08@14:53:22.499]         Starting Create Volatile Files and Directories...
[2021-01-08@14:53:22.515][  OK  ] Started udev Kernel Device Manager.
[2021-01-08@14:53:22.530][  OK  ] Started Create Volatile Files and Directories.
[2021-01-08@14:53:22.546]         Starting Run pending postinsts...
[2021-01-08@14:53:22.562]         Starting Rebuild Journal Catalog...
[2021-01-08@14:53:22.577]         Starting Network Time Synchronization...
[2021-01-08@14:53:22.593]         Starting Update UTMP about System Boot/Shutdown...
[2021-01-08@14:53:22.608][  OK  ] Started Update UTMP about System Boot/Shutdown.
[2021-01-08@14:53:22.640][  OK  ] Started Rebuild Journal Catalog.
[2021-01-08@14:53:22.686][  OK  ] Started Network Time Synchronization.
[2021-01-08@14:53:22.702][  OK  ] Reached target System Time Set.
[2021-01-08@14:53:22.733][  OK  ] Reached target System Time Synchronized.
[2021-01-08@14:53:22.983][    9.603464] rti-wdt 2200000.rti: heartbeat 60 sec
[2021-01-08@14:53:23.217][    9.844046] rti-wdt 2210000.rti: heartbeat 60 sec
[2021-01-08@14:53:23.295][  OK  ] Started Run pending postinsts.
[2021-01-08@14:53:23.420][   10.028872] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[2021-01-08@14:53:23.466][   10.085989] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[2021-01-08@14:53:23.529][   10.148574] remoteproc remoteproc0: 4d80800000.dsp is available
[2021-01-08@14:53:23.591][   10.209167] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[2021-01-08@14:53:23.607][   10.216226] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[2021-01-08@14:53:23.607][   10.225035] [drm] No driver support for vblank timestamp query.
[2021-01-08@14:53:23.622][   10.232051] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[2021-01-08@14:53:23.622][   10.245299] [drm] Cannot find any crtc or sizes
[2021-01-08@14:53:23.638][   10.249968] remoteproc remoteproc0: powering up 4d80800000.dsp
[2021-01-08@14:53:23.638][   10.255893] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 192416
[2021-01-08@14:53:23.654][   10.268039] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[2021-01-08@14:53:23.669][   10.280694]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
[2021-01-08@14:53:23.669][   10.295477] virtio_rpmsg_bus virtio0: rpmsg host is online
[2021-01-08@14:53:23.685][   10.305137]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[2021-01-08@14:53:23.700][   10.315172] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[2021-01-08@14:53:23.700][   10.326994] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@14:53:23.716][   10.334769] [drm] Cannot find any crtc or sizes
[2021-01-08@14:53:23.841][   10.457843] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[2021-01-08@14:53:24.075][   10.681525] remoteproc remoteproc1: 4d81800000.dsp is available
[2021-01-08@14:53:24.215][   10.828554] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[2021-01-08@14:53:24.262][   10.874294] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[2021-01-08@14:53:24.262][   10.888097] remoteproc remoteproc1: powering up 4d81800000.dsp
[2021-01-08@14:53:24.278][   10.893966] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 192416
[2021-01-08@14:53:24.293][   10.905421] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[2021-01-08@14:53:24.293][   10.916216]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
[2021-01-08@14:53:24.309][   10.929672] virtio_rpmsg_bus virtio1: rpmsg host is online
[2021-01-08@14:53:24.324][   10.937761]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[2021-01-08@14:53:24.324][   10.947398] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
[2021-01-08@14:53:24.340][   10.957499] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@14:53:24.340][   10.965072] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[2021-01-08@14:53:24.402][   11.020671] platform 41000000.r5f: configured R5F for IPC-only mode
[2021-01-08@14:53:24.402][   11.026469] remoteproc remoteproc3: 64800000.dsp is available
[2021-01-08@14:53:24.668][   11.275891] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[2021-01-08@14:53:24.699][   11.313305] random: crng init done
[2021-01-08@14:53:24.699][   11.316700] random: 7 urandom warning(s) missed due to ratelimiting
[2021-01-08@14:53:24.761][   11.373928] remoteproc remoteproc2: 41000000.r5f is available
[2021-01-08@14:53:24.777][   11.389486] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[2021-01-08@14:53:24.792][   11.414697] platform 5c00000.r5f: configured R5F for IPC-only mode
[2021-01-08@14:53:24.808][   11.425341] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
[2021-01-08@14:53:24.855][   11.478424] remoteproc remoteproc3: powering up 64800000.dsp
[2021-01-08@14:53:24.870][   11.484250] remoteproc remoteproc2: powering up 41000000.r5f
[2021-01-08@14:53:24.870][   11.489968] remoteproc remoteproc3: Booting fw image j7-c71_0-fw, size 10489904
[2021-01-08@14:53:24.886][   11.497540] remoteproc remoteproc2: Booting fw image j7-mcu-r5f0_0-fw, size 95552
[2021-01-08@14:53:24.886][   11.509403] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[2021-01-08@14:53:24.902][   11.516275] platform 41000000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@14:53:24.902][  OK  ] Started Load/Save Random Seed.
[2021-01-08@14:53:24.917][   11.525604]  remoteproc3#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
[2021-01-08@14:53:24.917][   11.539521]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[2021-01-08@14:53:24.933][   11.551709] virtio_rpmsg_bus virtio2: rpmsg host is online
[2021-01-08@14:53:24.948][   11.561743] virtio_rpmsg_bus virtio3: rpmsg host is online
[2021-01-08@14:53:24.948][   11.567308]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[2021-01-08@14:53:24.964][   11.577319]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[2021-01-08@14:53:24.964][   11.583415] remoteproc remoteproc2: remote processor 41000000.r5f is now up
[2021-01-08@14:53:24.964][   11.590378] remoteproc remoteproc3: remote processor 64800000.dsp is now up
[2021-01-08@14:53:25.011][  OK  ] Started Rebuild Dynamic Linker Cache.
[2021-01-08@14:53:25.026]         Starting Update is Completed...
[2021-01-08@14:53:25.026][  OK  ] Started Update is Completed.
[2021-01-08@14:53:25.042][   11.657043] remoteproc remoteproc4: 5c00000.r5f is available
[2021-01-08@14:53:25.042][  OK  ] Reached target System Initialization.
[2021-01-08@14:53:25.058][  OK  ] Started Daily rotation of log files.
[2021-01-08@14:53:25.073][  OK  ] Started Daily Cleanup of Temporary Directories.
[2021-01-08@14:53:25.089][  OK  ] Reached target Timers.
[2021-01-08@14:53:25.104][  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[2021-01-08@14:53:25.120][  OK  ] Listening on D-Bus System Message Bus Socket.
[2021-01-08@14:53:25.136]         Starting Docker Socket for the API.
[2021-01-08@14:53:25.151][  OK  ] Listening on dropbear.socket.
[2021-01-08@14:53:25.151]         Starting Reboot and dump vmcore via kexec...
[2021-01-08@14:53:25.167][   11.792029] platform 5d00000.r5f: configured R5F for IPC-only mode
[2021-01-08@14:53:25.167][  OK  ] Listening on Docker Socket for the API.
[2021-01-08@14:53:25.198][  OK  ] Reached target Sockets.
[2021-01-08@14:53:25.198][   11.828782] remoteproc remoteproc4: powering up 5c00000.r5f
[2021-01-08@14:53:25.229][   11.834514] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 1669948
[2021-01-08@14:53:25.229][  OK  ] Reached target Basic System.
[2021-01-08@14:53:25.245][   11.847159] platform 5c00000.r5f: Allocated carveout doesn't fit device address request
[2021-01-08@14:53:25.245][  OK  ] Started Job spooling tools.
[2021-01-08@14:53:25.260][   11.861457] platform 5c00000.r5f: Allocated carveout doesn't fit device address request
[2021-01-08@14:53:25.276][  OK  ] Started Periodic Command Scheduler   11.881358] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@14:53:25.276]0m.
[2021-01-08@14:53:25.276][   11.888379] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[2021-01-08@14:53:25.292][   11.888843]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a1000000
[2021-01-08@14:53:25.307][  OK  ] Started D-Bus System Message Bus[   11.913752] virtio_rpmsg_bus virtio4: rpmsg host is online
[2021-01-08@14:53:25.307].
[2021-01-08@14:53:25.307][   11.919291]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[2021-01-08@14:53:25.323]         [   11.934685] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
[2021-01-08@14:53:25.323]Starting Print notice about GPLv3 packages...
[2021-01-08@14:53:25.338]         Starting IPv6 Packet Filtering Framework...
[2021-01-08@14:53:25.354]         Starting IPv4 Packet Filtering Framework...
[2021-01-08@14:53:25.354][  OK  ] Started irqbalance daemon.
[2021-01-08@14:53:25.354]         Starting rc.pvr.service...
[2021-01-08@14:53:25.354]         Starting Login Service...
[2021-01-08@14:53:25.370][  OK  ] Started TEE Supplicant.
[2021-01-08@14:53:25.370][  OK  ] Started Reboot and dump vmcore via kexec.
[2021-01-08@14:53:25.385][  OK  ] Started IPv6 Packet Filtering Framework.
[2021-01-08@14:53:25.385][  OK  ] Started IPv4 Packet Filtering Framework.
[2021-01-08@14:53:25.416][  OK  ] Reached target Network (Pre).
[2021-01-08@14:53:25.416]         Starting Network Service...
[2021-01-08@14:53:25.526][  OK  ] Started Network Service.
[2021-01-08@14:53:25.526]         Starting Wait for Network to be Configured...
[2021-01-08@14:53:25.526]         Starting Network Name Resolution...
[2021-01-08@14:53:25.572][   12.186138] remoteproc remoteproc5: 5d00000.r5f is available
[2021-01-08@14:53:25.572][   12.187484] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[2021-01-08@14:53:25.604][   12.229690] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[2021-01-08@14:53:25.635][  OK  ] Started Login Service.
[2021-01-08@14:53:25.713][  OK  ] Started Network Name Resolution.[   12.338155] remoteproc remoteproc5: powering up 5d00000.r5f
[2021-01-08@14:53:25.728][  OK  ] Reached target Network.
[2021-01-08@14:53:25.728][   12.350926] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 95476
[2021-01-08@14:53:25.744][  OK  ] Reached target Host and Network Name Lookups.
[2021-01-08@14:53:25.744]         Starting Avahi mDNS/DNS-SD Sta[   12.366793] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@14:53:25.744]ck...
[2021-01-08@14:53:25.760][   12.383788]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[2021-01-08@14:53:25.791][   12.394980] virtio_rpmsg_bus virtio5: rpmsg host is online
[2021-01-08@14:53:25.791][   12.402774]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
[2021-01-08@14:53:25.806][   12.408916] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
[2021-01-08@14:53:25.806][   12.423476] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@14:53:25.822][  OK  ] [   12.451346] platform 5e00000.r5f: configured R5F for IPC-only mode
[2021-01-08@14:53:25.853]Started NFS status monitor for NFSv2/3 locking..
[2021-01-08@14:53:25.853]         Starting Permit User Sessions...
[2021-01-08@14:53:25.884][  OK  ] Started Permit User Sessions.
[2021-01-08@14:53:25.884][  OK  ] Started Getty on tty1.
[2021-01-08@14:53:25.884][  OK  ] Started Serial Getty on ttyS2.
[2021-01-08@14:53:25.900][  OK  ] Started Serial Getty on ttyS3.
[2021-01-08@14:53:25.900][  OK  ] Reached target Login Prompts.
[2021-01-08@14:53:25.916]         Starting Synchronize System and HW clocks...
[2021-01-08@14:53:25.916][  OK  ] Started Avahi mDNS/DNS-SD Stack.
[2021-01-08@14:53:25.916][FAILED] Failed to start Synchronize System and HW clocks.
[2021-01-08@14:53:25.931]See 'systemctl status sync-clocks.service' for details.
[2021-01-08@14:53:26.103][   12.715816] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[2021-01-08@14:53:26.118][   12.732819] j721e-audio sound@0: pcm3168a-dac <-> 2ba0000.mcasp mapping ok
[2021-01-08@14:53:26.181][   12.801831] remoteproc remoteproc6: 5e00000.r5f is available
[2021-01-08@14:53:26.212][   12.835701] remoteproc remoteproc6: powering up 5e00000.r5f
[2021-01-08@14:53:26.228][   12.841351] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 95476
[2021-01-08@14:53:26.228][   12.855710] platform 5e00000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@14:53:26.243][   12.866517]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
[2021-01-08@14:53:26.259][   12.879608] virtio_rpmsg_bus virtio6: rpmsg host is online
[2021-01-08@14:53:26.259][   12.886622] platform 5f00000.r5f: configured R5F for IPC-only mode
[2021-01-08@14:53:26.274][   12.886748] j721e-audio sound@0: pcm3168a-adc <-> 2ba0000.mcasp mapping ok
[2021-01-08@14:53:26.274][   12.899837]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
[2021-01-08@14:53:26.290][   12.906055] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
[2021-01-08@14:53:26.290][   12.913600] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@14:53:26.321][   12.940100] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
[2021-01-08@14:53:26.508][   13.116943] remoteproc remoteproc7: 5f00000.r5f is available
[2021-01-08@14:53:26.586][  OK  ] Created slice system-systemd\x2dfsck.slice.
[2021-01-08@14:53:26.633][   13.241924] remoteproc remoteproc7: powering up 5f00000.r5f
[2021-01-08@14:53:26.633][   13.247556] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 95476
[2021-01-08@14:53:26.649][   13.259777] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[2021-01-08@14:53:26.649][   13.266424]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
[2021-01-08@14:53:26.664][   13.285199] virtio_rpmsg_bus virtio7: rpmsg host is online
[2021-01-08@14:53:26.680][   13.295094]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
[2021-01-08@14:53:26.696][   13.305475] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
[2021-01-08@14:53:26.696][   13.314799] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
[2021-01-08@14:53:27.179][  OK  ] Created slice system-weston.slice.
[2021-01-08@14:53:27.179][  OK  ] Started Weston Wayland Compositor.
[2021-01-08@14:53:27.242][   13.859178] remoteproc remoteproc8: b034000.pru is available
[2021-01-08@14:53:27.288][  OK  ] Created slice User Slice of UID 0.
[2021-01-08@14:53:27.288]         Starting User Runtime Directory /run/user/0...
[2021-01-08@14:53:27.304][  OK  ] Started User Runtime Directory /run/user/0.
[2021-01-08@14:53:27.304]         Starting User Manager for UID 0...
[2021-01-08@14:53:27.320][  OK  ] Started rc.pvr.service.
[2021-01-08@14:53:27.320]         Starting weston.service...
[2021-01-08@14:53:27.351][   13.965894] pru-rproc b034000.pru: PRU rproc node /interconnect@100000/icssg@b000000/pru@34000 probed successfully
[2021-01-08@14:53:27.538][   14.164248] remoteproc remoteproc9: b004000.rtu is available
[2021-01-08@14:53:27.616][   14.229423] pru-rproc b004000.rtu: PRU rproc node /interconnect@100000/icssg@b000000/rtu@4000 probed successfully
[2021-01-08@14:53:27.632][  OK  ] Started User Manager for UID 0.
[2021-01-08@14:53:27.632][  OK  ] Started Session c1 of user root.
[2021-01-08@14:53:27.647][  OK  ] Found device /dev/mmcblk0p2.
[2021-01-08@14:53:27.663]         Starting File System Check on /dev/mmcblk0p2...
[2021-01-08@14:53:27.663][   14.291371] pru-rproc b00a000.txpru: IRQ vring not found
[2021-01-08@14:53:27.725][   14.345301] pru-rproc b00a000.txpru: IRQ kick not found
[2021-01-08@14:53:27.741][  OK  ] Found device /dev/mmcblk0p1.
[2021-01-08@14:53:27.756][   14.360651] remoteproc remoteproc10: b00a000.txpru is available
[2021-01-08@14:53:27.756]         Starting File System Check on /dev/mmcblk0p1...
[2021-01-08@14:53:27.803][   14.411692] pru-rproc b00a000.txpru: PRU rproc node /interconnect@100000/icssg@b000000/txpru@a000 probed successfully
[2021-01-08@14:53:27.803][   14.415236] omap_rng 4e10000.trng: Random Number Generator ver. 241b34c
[2021-01-08@14:53:27.819][   14.429775] remoteproc remoteproc11: b038000.pru is available
[2021-01-08@14:53:27.834][   14.439375] pru-rproc b038000.pru: PRU rproc node /interconnect@100000/icssg@b000000/pru@38000 probed successfully
[2021-01-08@14:53:27.850][   14.457658] remoteproc remoteproc12: b006000.rtu is available
[2021-01-08@14:53:27.866][   14.469350] pru-rproc b006000.rtu: PRU rproc node /interconnect@100000/icssg@b000000/rtu@6000 probed successfully
[2021-01-08@14:53:27.881][   14.487543] cdns-usb3 6000000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[2021-01-08@14:53:27.897][  OK  ] Started File System Check on /dev/mmcblk0p1.
[2021-01-08@14:53:27.912]         Mounting /run/media/mmcblk0p1...
[2021-01-08@14:53:27.912][   14.530316] pru-rproc b00c000.txpru: IRQ vring not found
[2021-01-08@14:53:27.928][  OK  ] Started File System Check on /dev/mmcblk0p2.
[2021-01-08@14:53:27.928]         Mounting /run/media/mmcblk0p2...
[2021-01-08@14:53:27.928][  OK  ] Mounted /run/media/mmcblk0p1.
[2021-01-08@14:53:27.959][   14.572319] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[2021-01-08@14:53:27.975][  OK  ] Mounted /run/media/mmcblk0p2.
[2021-01-08@14:53:27.975][   14.593930] cdns-usb3 6400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[2021-01-08@14:53:28.006][   14.630724] pru-rproc b00c000.txpru: IRQ kick not found
[2021-01-08@14:53:28.100][   14.715196] remoteproc remoteproc13: b00c000.txpru is available
[2021-01-08@14:53:28.131]         Starting Save/Restore Sound Card State...
[2021-01-08@14:53:28.146][   14.767706] pru-rproc b00c000.txpru: PRU rproc node /interconnect@100000/icssg@b000000/txpru@c000 probed successfully
[2021-01-08@14:53:28.178][  OK  ] Found device /dev/mmcblk1p1.
[2021-01-08@14:53:28.178]         Starting File System Check on /dev/mmcblk1p1...
[2021-01-08@14:53:28.193][  OK  ] Started Save/Restore Sound Card State.
[2021-01-08@14:53:28.193][  OK  ] Reached target Sound Card.
[2021-01-08@14:53:28.271][   14.892363] usbcore: registered new interface driver usbfs
[2021-01-08@14:53:28.271][   14.904006] remoteproc remoteproc14: b134000.pru is available
[2021-01-08@14:53:28.349][   14.953487] usbcore: registered new interface driver hub
[2021-01-08@14:53:28.349][   14.957813] pru-rproc b134000.pru: PRU rproc node /interconnect@100000/icssg@b100000/pru@34000 probed successfully
[2021-01-08@14:53:28.365][   14.975623] usbcore: registered new device driver usb
[2021-01-08@14:53:28.365][  OK  ] Started File System Check on /dev/mmcblk1p1.
[2021-01-08@14:53:28.380]         Mounting /run/media/mmcblk1p1...
[2021-01-08@14:53:28.380][   14.997987] remoteproc remoteproc15: b104000.rtu is available
[2021-01-08@14:53:28.412][   15.019606] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[2021-01-08@14:53:28.427][   15.036388] pru-rproc b104000.rtu: PRU rproc node /interconnect@100000/icssg@b100000/rtu@4000 probed successfully
[2021-01-08@14:53:28.427][  OK  ] Mounted /run/media/mmcblk1p1.
[2021-01-08@14:53:28.474][   15.086414] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[2021-01-08@14:53:28.490][   15.100756] pru-rproc b10a000.txpru: IRQ vring not found
[2021-01-08@14:53:28.505][   15.110420] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
[2021-01-08@14:53:28.505]***************************************************************
[2021-01-08@14:53:28.521]NOTICE: This file system contains the following GPLv3 packages[   15.134691] pru-rproc b10a000.txpru: IRQ kick not found
[2021-01-08@14:53:28.521]:
[2021-01-08@14:53:28.521]	bash-dev
[2021-01-08@14:53:28.521]	bc
[2021-01-08@14:53:28.521]	binutils
[2021-01-08@14:53:28.521]	cifs-utils
[2021-01-08@14:53:28.521]	cpio
[2021-01-08@14:53:28.536]	dosfst[   15.145116] remoteproc remoteproc16: b10a000.txpru is available
[2021-01-08@14:53:28.536]ools
[2021-01-08@14:53:28.536]	elfutils
[2021-01-08@14:53:28.536]	gawk
[2021-01-08@14:53:28.536]	gdb
[2021-01-08@14:53:28.536]	gdbserver
[2021-01-08@14:53:28.536]	glmark2
[2021-01-08@14:53:28.536]	gstreamer1.0-libav
[2021-01-08@14:53:28.536]	gzip
[2021-01-08@14:53:28.536]	less
[2021-01-08@14:53:28.536]	libasm1
[2021-01-08@14:53:28.536]	libbfd
[2021-01-08@14:53:28.536]	libdw1
[2021-01-08@14:53:28.536]	libelf1
[2021-01-08@14:53:28.552]	li[   15.159461] pru-rproc b10a000.txpru: PRU rproc node /interconnect@100000/icssg@b100000/txpru@a000 probed successfully
[2021-01-08@14:53:28.552]bgdbm-compat4
[2021-01-08@14:53:28.552]	libgdbm-dev
[2021-01-08@14:53:28.552]	libgdbm6
[2021-01-08@14:53:28.552]	libgmp10
[2021-01-08@14:53:28.552]	libidn2-0
[2021-01-08@14:53:28.568]	[   15.160791] xhci-hcd xhci-hcd.2.auto: irq 516, io mem 0x06410000
[2021-01-08@14:53:28.568]libreadline-dev
[2021-01-08@14:53:28.568]	libreadline8
[2021-01-08@14:53:28.568]	libunistring2
[2021-01-08@14:53:28.568]	m4-dev
[2021-01-08@14:53:28.568]	nettle
[2021-01-08@14:53:28.568]	parted
[2021-01-08@14:53:28.568]	tar
[2021-01-08@14:53:28.568]	which
[2021-01-08@14:53:28.583]If you do not wish to distribute[   15.195222] remoteproc remoteproc17: b138000.pru is available
[2021-01-08@14:53:28.583] GPLv3 components please remove
[2021-01-08@14:53:28.599]the above packages prior to dis[   15.205408] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[2021-01-08@14:53:28.599]tribution.  This can be done using
[2021-01-08@14:53:28.599]the opkg remove command.  i.e.:
[2021-01-08@14:53:28.599]    opkg remove <package>
[2021-01-08@14:53:28.614]Where <package> is the name prin[   15.225278] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2021-01-08@14:53:28.614]ted in the list above
[2021-01-08@14:53:28.630]NOTE: If the package is a dependency of[   15.237321] pru-rproc b138000.pru: PRU rproc node /interconnect@100000/icssg@b100000/pru@38000 probed successfully
[2021-01-08@14:53:28.630][   15.241273] usb usb1: Product: xHCI Host Controller
[2021-01-08@14:53:28.630] another package you
[2021-01-08@14:53:28.630]      will be notified of the dependent packages.  You should
[2021-01-08@14:53:28.646]      use the --force-removal-of-dependent-[   15.260690] usb usb1: Manufacturer: Linux 5.4.40+ xhci-hcd
[2021-01-08@14:53:28.646]packages option to
[2021-01-08@14:53:28.661]      also remove the dependent packages as [   15.268338] remoteproc remoteproc18: b106000.rtu is available
[2021-01-08@14:53:28.661]well
[2021-01-08@14:53:28.661]**********************************************************[   15.282993] usb usb1: SerialNumber: xhci-hcd.2.auto
[2021-01-08@14:53:28.677]***************************************************************
[2021-01-08@14:53:28.692][   15.300660] pru-rproc b106000.rtu: PRU rproc node /interconnect@100000/icssg@b100000/rtu@6000 probed successfully
[2021-01-08@14:53:28.692][   15.311077] hub 1-0:1.0: USB hub found
[2021-01-08@14:53:28.692][  OK  ] Started Print notice about GPLv3 packages.
[2021-01-08@14:53:28.708][   15.317938] hub 1-0:1.0: 1 port detected
[2021-01-08@14:53:28.708][   15.323239] pru-rproc b10c000.txpru: IRQ vring not found
[2021-01-08@14:53:28.724][   15.341284] pru-rproc b10c000.txpru: IRQ kick not found
[2021-01-08@14:53:28.724][   15.342159] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[2021-01-08@14:53:28.739][   15.352981] remoteproc remoteproc19: b10c000.txpru is available
[2021-01-08@14:53:28.739][   15.359055] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[2021-01-08@14:53:28.755][   15.365328] pru-rproc b10c000.txpru: PRU rproc node /interconnect@100000/icssg@b100000/txpru@c000 probed successfully
[2021-01-08@14:53:28.755][   15.373281] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[2021-01-08@14:53:28.770][   15.395057] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[2021-01-08@14:53:28.848][   15.466333] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[2021-01-08@14:53:28.926][   15.548514] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2021-01-08@14:53:28.942][   15.563103] usb usb2: Product: xHCI Host Controller
[2021-01-08@14:53:28.942][   15.569385] usb usb2: Manufacturer: Linux 5.4.40+ xhci-hcd
[2021-01-08@14:53:28.958][   15.581280] usb usb2: SerialNumber: xhci-hcd.2.auto
[2021-01-08@14:53:28.958][   15.589404] hub 2-0:1.0: USB hub found
[2021-01-08@14:53:28.989][   15.597284] hub 2-0:1.0: 1 port detected
[2021-01-08@14:53:29.067][   15.673306] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[2021-01-08@14:53:29.207][   15.829556] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[2021-01-08@14:53:29.223][   15.841277] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[2021-01-08@14:53:29.238][   15.853276] usb 1-1: SerialNumber: 5C0100797885
[2021-01-08@14:53:29.238][   15.858262] hub 1-1:1.0: USB hub found
[2021-01-08@14:53:29.238][   15.865287] hub 1-1:1.0: 4 ports detected
[2021-01-08@14:53:30.408][  OK  ] Started weston.service.
[2021-01-08@14:53:30.424]         Starting DEMO...
[2021-01-08@14:53:30.440]         Starting telnetd.service...
[2021-01-08@14:53:30.440][  OK  ] Started DEMO.
[2021-01-08@14:53:30.455][  OK  ] Started telnetd.service.
[2021-01-08@14:53:31.890]
[2021-01-08@14:53:31.890] _____                    _____           _         _
[2021-01-08@14:53:31.906]|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
[2021-01-08@14:53:31.906]|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
[2021-01-08@14:53:31.906]|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
[2021-01-08@14:53:31.922]              |___|                    |___|
[2021-01-08@14:53:31.922]Arago Project http://arago-project.org j7-evm ttyS2
[2021-01-08@14:53:31.922]Arago 2020.05 j7-evm ttyS2
  • Hi Sir :
    I need to shorten the Linux boot time.
    Part I: PCIe initialization time.
    Part 2 :Remote Proce initialization time.
    Is there any way to shorten the Linux boot time?
  • Pierre,
    Thanks for sharing the benchmark. I am not sure if the PCIe probing will take that long, though i never benchmarked as you did, or there are other items got triggered by pcie driver such as logging. could you help to confirm:
    • when you have PCIe enabled, did you have any end-points connected to any slots? I did not see anything up in the log.
    • can you confirm if PCIe is needed in your initial boot, or it can be brought up after boot?
    regards
    Jian
