We are using an internal algorithm in DSP (it takes about 60% without any DSP extrinsic operation), but we are analysing to run the same algorithm into EVE or IPU. It seems it is taking a lot of CPU, I would like to confirm with you it is a normal CPU load. is it expected behaviour?
Do you have a compatibility (indicative) table between cores CPU load?
Do you know the EVE and IPU consumption estimation (all operations are integer byte operations) from DSP consumption?
Do you know if there are internal EVE (VCOP) operation list (like DSP extrinsic operations)? and for IPU?
