TDA4VM: the distribution method
Part Number: TDA4VM
Hi
Related to http://e2e.ti.com/support/processors/f/791/t/970739.
Will the distribution method be changed in the future?
For example, do you have a plan to support it in a coherent CSL in the future? In that case, please let me know the schedule for it.
I ask it because, if you change distribution method to something different from the current method in the future then it will cause conflict with current our implementation.
Thanks and Best regards,
HaTa.
  • Hi HaTa,
    Can you please explain your question a little more in detail?
    What do you mean by coherent CSL and where is this terminology coming from?
    Karthik
  • Hi Karthk
    What I'd like to know is if you have a plan to change the SW structure in the future.
    We believe that the CSL should be gathered in the appropriate place such like "pdk_jacinto_07_01_00_45\packages\ti\csl".
    However, for example, the actual codes for CSL_c7xSetTBR0() is located at the folder for TIDL (psdk_rtos_auto_j7_07_00_00_11/tidl_j7_01_02_00_09/common/c7x_mmu/) and not for CSL.
    We describe this situation as CSL is not coherent.
    HaTa.
  • Hi HaTa,
    Ok, I understand your question better now, thank you for the explanation.
    From what I know, no change is planned in the near future. However, you bring an interesting point that may need an investigation to make this "coherent".
    After the investigation if anything changes I will respond on this thread.
    Karthik
  • Hi Karthik,
    Ok, I understand.
    I appreciate if you keep in your mind for about this thread, and let me know it your strategy is changed.
  • Hi HaTa,
    We investigated a bit further and the reasons seem to be coming from some legacy convention, we are considering to remove the CSL from the TIDL folder. But first the investigation must be completed on the impact. So this will be done very soon, you can track TIDL-1271 on the internal JIRA.
    Karthik
