Hi Sir :
I had an error executing the "/opt/vision_apps" sample demo with the tiny rootfs.
Error : VX_ZONE_ERROR:[ownContextCreateCmdObj:160] context object descriptor [0] allocation failed
=== tisdk-tiny-image-j7-evm.tar.xz ===
PROCESSOR-SDK-LINUX 07_01_00_10 - TI.com => ti-processor-sdk-linux-j7-evm-07_01_00_10-Linux-x86-Install.bin => <install dir>\filesystem => tisdk-tiny-image-j7-evm.tar.xz
=== ti-processor-sdk-rtos-j721e-evm-07_01_00_11-prebuilt.tar.gz ===
PROCESSOR-SDK-RTOS-J721E 07_01_00_11 - TI.com => ti-processor-sdk-rtos-j721e-evm-07_01_00_11-prebuilt.tar.gz => Unzip the file => mk-linux-card.sh => install_to_sd_card.sh (modify : rootfs_file=$PWD/tisdk-tiny-image-j7-evm.tar.xz) => install_data_set_to_sd_card.sh
=== Log ===
U-Boot SPL 2020.01-g3c9ebdb87d (Nov 19 2020 - 18:33:21 +0000) SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla') Trying to boot from MMC2 Loading Environment from MMC... *** Warning - No MMC card found, using default environment Starting ATF on ARM64 core... NOTICE: BL31: v2.3():07.01.00.004-1-g52c334fc3-dirty NOTICE: BL31: Built : 18:17:14, Nov 19 2020 U-Boot SPL 2020.01-g3c9ebdb87d (Nov 19 2020 - 18:29:59 +0000) SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla') Detected: J7X-BASE-CPB rev E3 Detected: J7X-VSC8514-ETH rev E2 Trying to boot from MMC2 U-Boot 2020.01-g3c9ebdb87d (Nov 19 2020 - 18:29:59 +0000) SoC: J721E SR1.0 Model: Texas Instruments K3 J721E SoC Board: J721EX-PM2-SOM rev E7 DRAM: 4 GiB not found for dev hbmc-mux Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from MMC... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Detected: J7X-BASE-CPB rev E3 Detected: J7X-VSC8514-ETH rev E2 Net: Warning: ethernet@46000000 using MAC address from ROM eth0: ethernet@46000000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 483 bytes read in 1 ms (471.7 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 1 ms (1000 Bytes/s) Already setup. 5212504 bytes read in 112 ms (44.4 MiB/s) Load Remote Processor 2 with data@addr=0x82000000 5212504 bytes: Success! 1964032 bytes read in 44 ms (42.6 MiB/s) Load Remote Processor 3 with data@addr=0x82000000 1964032 bytes: Success! 1579152 bytes read in 35 ms (43 MiB/s) Load Remote Processor 6 with data@addr=0x82000000 1579152 bytes: Success! 1579152 bytes read in 37 ms (40.7 MiB/s) Load Remote Processor 7 with data@addr=0x82000000 1579152 bytes: Success! 9969648 bytes read in 211 ms (45.1 MiB/s) Load Remote Processor 8 with data@addr=0x82000000 9969648 bytes: Success! 16666632 bytes read in 349 ms (45.5 MiB/s) 93829 bytes read in 4 ms (22.4 MiB/s) 6199 bytes read in 2 ms (3 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008fee6000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.4.74-g9574bba32a (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Thu Nov 19 18:30:39 UTC 2020 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 7 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a5800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5900000, size 7 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a5900000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-dma-memory@ac000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ce000000, size 720 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-core-heap-memory@ce000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@fb000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@fb100000, compatible id shared-dma-pool [ 0.000000] cma: Failed to reserve 512 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 35779 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),57216k@8m(ospi.rootfs),128k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=d46439ae-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x9a800000-0x9e800000] (64MB) [ 0.000000] Memory: 2584000K/2293760K available (9598K kernel code, 788K rwdata, 3840K rodata, 1664K init, 683K bss, 18446744073709261376K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: no VLPI support, no direct LPI support [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008c00c0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000 [ 0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x43c with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008385] Console: colour dummy device 80x25 [ 0.012951] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023620] pid_max: default: 32768 minimum: 301 [ 0.028370] LSM: Security Framework initializing [ 0.033123] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.040696] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.049948] ASID allocator initialised with 32768 entries [ 0.055541] rcu: Hierarchical SRCU implementation. [ 0.060609] Platform MSI: gic-its@1820000 domain created [ 0.066295] PCI/MSI: /bus@100000/interrupt-controller@1800000/gic-its@1820000 domain created [ 0.075163] smp: Bringing up secondary CPUs ... [ 0.081251] Detected PIPT I-cache on CPU1 [ 0.081274] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.081285] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000 [ 0.081318] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.081381] smp: Brought up 1 node, 2 CPUs [ 0.110727] SMP: Total of 2 processors activated. [ 0.115531] CPU features: detected: 32-bit EL0 Support [ 0.120785] CPU features: detected: CRC32 instructions [ 0.132656] CPU: All CPU(s) started at EL2 [ 0.136850] alternatives: patching kernel code [ 0.142055] devtmpfs: initialized [ 0.150598] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.160568] futex hash table entries: 512 (order: -1, 32768 bytes, linear) [ 0.168013] pinctrl core: initialized pinctrl subsystem [ 0.173874] NET: Registered protocol family 16 [ 0.178645] DMA: preallocated 256 KiB pool for atomic allocations [ 0.185165] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.201183] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages [ 0.208041] HugeTLB registered 512 MiB page size, pre-allocated 0 pages [ 0.214801] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.223003] cryptd: max_cpu_qlen set to 1000 [ 0.229574] vsys_3v3: supplied by evm_12v0 [ 0.233879] vsys_5v0: supplied by evm_12v0 [ 0.238529] iommu: Default domain type: Translated [ 0.243716] SCSI subsystem initialized [ 0.247844] mc: Linux media interface: v0.10 [ 0.252216] videodev: Linux video capture interface: v2.00 [ 0.257827] pps_core: LinuxPPS API ver. 1 registered [ 0.262897] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.272233] PTP clock support registered [ 0.276245] EDAC MC: Ver: 3.0.0 [ 0.280039] FPGA manager framework [ 0.283553] Advanced Linux Sound Architecture Driver Initialized. [ 0.290208] clocksource: Switched to clocksource arch_sys_counter [ 0.296534] VFS: Disk quotas dquot_6.6.0 [ 0.300604] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes) [ 0.310251] Carveout Heap: Exported 512 MiB at 0x00000000ae000000 [ 0.316486] thermal_sys: Registered thermal governor 'step_wise' [ 0.316488] thermal_sys: Registered thermal governor 'power_allocator' [ 0.322933] NET: Registered protocol family 2 [ 0.334345] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear) [ 0.343103] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear) [ 0.351299] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear) [ 0.359117] TCP: Hash tables configured (established 32768 bind 32768) [ 0.365872] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.372764] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.380175] NET: Registered protocol family 1 [ 0.384924] RPC: Registered named UNIX socket transport module. [ 0.390976] RPC: Registered udp transport module. [ 0.395779] RPC: Registered tcp transport module. [ 0.400581] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.407167] PCI: CLS 0 bytes, default 64 [ 0.411562] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 0.421720] Initialise system trusted keyrings [ 0.426357] workingset: timestamp_bits=46 max_order=16 bucket_order=0 [ 0.435109] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.441397] NFS: Registering the id_resolver key type [ 0.446575] Key type id_resolver registered [ 0.450845] Key type id_legacy registered [ 0.454942] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.461914] 9p: Installing v9fs 9p2000 file system support [ 0.474675] Key type asymmetric registered [ 0.478860] Asymmetric key parser 'x509' registered [ 0.483863] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.491422] io scheduler mq-deadline registered [ 0.496047] io scheduler kyber registered [ 0.501373] pinctrl-single 4301c000.pinmux: 94 pins, size 376 [ 0.507458] pinctrl-single 11c000.pinmux: 173 pins, size 692 [ 0.515783] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.522051] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.528396] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.534823] debugfs: Directory '31010000.pat' with parent 'regmap' already present! [ 0.542816] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.549229] debugfs: Directory '31011000.pat' with parent 'regmap' already present! [ 0.557171] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.563582] debugfs: Directory '31012000.pat' with parent 'regmap' already present! [ 0.571508] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.577835] debugfs: Directory '31013000.pat' with parent 'regmap' already present! [ 0.585759] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.592081] debugfs: Directory '31014000.pat' with parent 'regmap' already present! [ 0.601521] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.613842] brd: module loaded [ 0.620254] loop: module loaded [ 0.623866] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys' [ 0.631791] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.74-g9574bba32a #1 [ 0.638900] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 0.644854] Call trace: [ 0.647353] dump_backtrace+0x0/0x140 [ 0.651087] show_stack+0x14/0x20 [ 0.654469] dump_stack+0xb4/0x114 [ 0.657950] sysfs_warn_dup+0x5c/0x78 [ 0.661684] sysfs_create_dir_ns+0xd8/0xf0 [ 0.665867] kobject_add_internal+0x94/0x280 [ 0.670223] kobject_add+0x90/0xf8 [ 0.673693] device_add+0xdc/0x600 [ 0.677161] platform_device_add+0xfc/0x228 [ 0.681427] platform_device_register_full+0xc8/0x140 [ 0.686585] dma_buf_phys_init+0x68/0x94 [ 0.690587] do_one_initcall+0x50/0x1a8 [ 0.694503] kernel_init_freeable+0x194/0x23c [ 0.698950] kernel_init+0x10/0xfc [ 0.702418] ret_from_fork+0x10/0x1c [ 0.706082] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory. [ 0.720312] libphy: Fixed MDIO Bus: probed [ 0.724693] tun: Universal TUN/TAP device driver, 1.6 [ 0.730141] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k [ 0.738145] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.744209] sky2: driver version 1.30 [ 0.748484] VFIO - User Level meta-driver version: 0.3 [ 0.754124] i2c /dev entries driver [ 0.758197] sdhci: Secure Digital Host Controller Interface driver [ 0.764510] sdhci: Copyright(c) Pierre Ossman [ 0.769164] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.775409] ledtrig-cpu: registered to indicate activity on CPUs [ 0.782267] optee: probing for conduit method from DT. [ 0.787528] optee: revision 3.8 (199fca17) [ 0.787868] optee: initialized driver [ 0.796742] NET: Registered protocol family 17 [ 0.801375] 9pnet: Installing 9P2000 support [ 0.805776] Key type dns_resolver registered [ 0.810307] registered taskstats version 1 [ 0.814494] Loading compiled-in X.509 certificates [ 0.823239] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.829563] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.837945] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla') [ 0.980923] random: fast init done [ 1.168721] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.179944] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz [ 1.186407] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [ 1.193064] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz [ 1.199771] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator [ 1.207193] pca953x 3-0020: using no AI [ 1.234739] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator [ 1.242145] pca953x 3-0022: using AI [ 1.246410] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low [ 1.253005] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high [ 1.259842] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 1.266200] omap_i2c 2020000.i2c: bus 4 rev0.12 at 100 kHz [ 1.272613] pca953x 5-0020: 5-0020 supply vcc not found, using dummy regulator [ 1.280031] pca953x 5-0020: using no AI [ 1.306593] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz [ 1.313024] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz [ 1.319320] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz [ 1.326038] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 1.336514] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 1.345821] ti-sci-intr bus@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created [ 1.356957] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 2.394265] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 2.401944] j721e-pcie 2900000.pcie: IO 0x10001000..0x10010fff -> 0x10001000 [ 2.409423] j721e-pcie 2900000.pcie: MEM 0x10011000..0x17ffffff -> 0x10011000 [ 2.416980] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00 [ 2.423388] pci_bus 0000:00: root bus resource [bus 00-0f] [ 2.428992] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff]) [ 2.438682] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff] [ 2.445723] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400 [ 2.451873] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.461741] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.471629] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits [ 2.481588] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.491556] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits [ 2.501519] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits [ 2.511504] pci 0000:00:00.0: supports D1 [ 2.515597] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.521469] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits [ 2.533379] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.541567] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.551526] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.561484] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.573167] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01 [ 2.579938] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.585242] pcieport 0000:00:00.0: PME: Signaling with IRQ 37 [ 2.591259] pcieport 0000:00:00.0: AER: enabled with IRQ 37 [ 3.594219] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 3.601886] j721e-pcie 2910000.pcie: IO 0x18001000..0x18010fff -> 0x18001000 [ 3.609363] j721e-pcie 2910000.pcie: MEM 0x18011000..0x1fffffff -> 0x18011000 [ 3.616902] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00 [ 3.623308] pci_bus 0001:00: root bus resource [bus 00-0f] [ 3.628913] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff]) [ 3.638780] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff] [ 3.645817] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400 [ 3.652025] pci 0001:00:00.0: supports D1 [ 3.656118] pci 0001:00:00.0: PME# supported from D0 D1 D3hot [ 3.663851] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.673759] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01 [ 3.680529] pci 0001:00:00.0: PCI bridge to [bus 01] [ 3.685823] pcieport 0001:00:00.0: PME: Signaling with IRQ 40 [ 3.691840] pcieport 0001:00:00.0: AER: enabled with IRQ 40 [ 4.694223] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges: [ 4.701893] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x00001000 [ 4.709726] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x00011000 [ 4.717624] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00 [ 4.724030] pci_bus 0002:00: root bus resource [bus 00-0f] [ 4.729635] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff]) [ 4.738881] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff]) [ 4.749649] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400 [ 4.755857] pci 0002:00:00.0: supports D1 [ 4.759951] pci 0002:00:00.0: PME# supported from D0 D1 D3hot [ 4.767661] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.777563] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01 [ 4.784333] pci 0002:00:00.0: PCI bridge to [bus 01] [ 4.789592] pcieport 0002:00:00.0: PME: Signaling with IRQ 43 [ 4.795606] pcieport 0002:00:00.0: AER: enabled with IRQ 43 [ 4.802501] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 4.812376] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 4.819135] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 4.828511] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 4.838666] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 4.845424] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 4.853860] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250 [ 4.863488] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250 [ 4.872227] printk: console [ttyS2] enabled [ 4.872227] printk: console [ttyS2] enabled [ 4.880665] printk: bootconsole [ns16550a0] disabled [ 4.880665] printk: bootconsole [ns16550a0] disabled [ 4.891436] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250 [ 4.900781] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 24, base_baud = 3000000) is a 8250 [ 4.909979] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 4.919110] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq [ 4.928264] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq [ 4.935994] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs [ 4.945744] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 4.956261] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 4.966414] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 4.976652] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 4.991267] scsi host0: ufshcd [ 5.013071] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0 [ 5.044275] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2 [ 5.046214] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 5.063543] libphy: 46000f00.mdio: probed [ 5.067545] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0 [ 5.068702] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 5.086929] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 5.099731] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 5.099818] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517 [ 5.116269] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 5.120615] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 5.133280] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found [ 5.134368] mmc0: CQHCI version 5.10 [ 5.184781] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit [ 5.196541] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.228709] vdd_mmc1: supplied by vsys_3v3 [ 5.235032] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 5.243597] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 5.252128] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 5.260697] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 5.269183] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 5.283118] ti-udma 285c0000.dma-controller: Channels: 24 (tchan: 12, rchan: 12, gp-rflow: 8) [ 5.297021] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16) [ 5.307324] mmc0: Command Queue Engine enabled [ 5.311767] mmc0: new HS200 MMC card at address 0001 [ 5.317763] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 5.322503] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB [ 5.328685] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB [ 5.334730] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0) [ 5.343544] mmcblk0: p1 p2 [ 5.365603] cadence-qspi 47040000.spi: PHY calibration failed: -2 [ 5.371693] spi-nor spi0.0: mt35xu512aba (65536 Kbytes) [ 5.376917] 8 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 5.383516] Creating 8 MTD partitions on "47040000.spi.0": [ 5.388990] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 5.395076] 0x000000080000-0x000000280000 : "ospi.tispl" [ 5.400798] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 5.406604] 0x000000680000-0x0000006a0000 : "ospi.env" [ 5.412175] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup" [ 5.418305] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 5.424119] 0x000000800000-0x000003fe0000 : "ospi.rootfs" [ 5.429899] 0x000003fe0000-0x000004000000 : "ospi.phypattern" [ 5.447318] spi-nor spi1.0: mt25qu512a (65536 Kbytes) [ 5.494226] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 5.501876] libphy: 46000f00.mdio: probed [ 5.506994] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 5.515257] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 5.533796] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 5.543098] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4 [ 5.550397] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 5.557796] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 5.571096] mmc1: CQHCI version 5.10 [ 6.634919] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit [ 6.644196] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 6.685782] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 6.693192] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 6.700514] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 6.707828] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 6.716050] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 6.722932] hctosys: unable to open rtc device (rtc0) [ 6.868606] ALSA device list: [ 6.871571] No soundcards found. [ 6.875309] Waiting for root device PARTUUID=d46439ae-02... [ 7.015787] mmc1: new ultra high speed DDR50 SDHC card at address 01e1 [ 7.022762] mmcblk1: mmc1:01e1 UC0D5 29.8 GiB [ 7.030877] mmcblk1: p1 p2 [ 7.206986] EXT4-fs (mmcblk1p2): recovery complete [ 7.216041] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 7.224163] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 7.232570] devtmpfs: mounted [ 7.235968] Freeing unused kernel memory: 1664K [ 7.240522] Run /sbin/init as init process INIT: version 2.96 booting [ 7.489056] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) hwclock: Cannot access the Hardware Clock via any known method. hwclock: Use the --verbose option to see the details of our search for an access method. Thu Nov 19 19:21:46 UTC 2020 hwclock: Cannot access the Hardware Clock via any known method. hwclock: Use the --verbose option to see the details of our search for an access method. [ 7.731130] random: dd: uninitialized urandom read (512 bytes read) INIT: Entering runlevel: 5 Configuring network interfaces... [ 7.825875] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL) [ 7.838342] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down udhcpc: started, v1.31.1 udhcpc: sending discover udhcpc: sending discover udhcpc: sending discover udhcpc: no lease, forking to background done. Starting dockerd: [ 20.582224] random: crng init done hwclock: Cannot access the Hardware Clock via any known method. hwclock: Use the --verbose option to see the details of our search for an access method. Starting syslogd/klogd: done _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org j7-evm ttyS2 Arago 2020.09 j7-evm ttyS2 j7-evm login: root root@j7-evm:~# cd /opt/vision_apps/ root@j7-evm:/opt/vision_apps# ./vision_apps_init.sh root@j7-evm:/opt/vision_apps# [MCU2_0] 4.195456 s: CIO: Init ... Done !!! [MCU2_0] 4.195529 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz> [MCU2_0] 4.195568 s: APP: Init ... !!! [MCU2_0] 4.195587 s: SCICLIENT: Init ... !!! [MCU2_0] 4.196792 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [MCU2_0] 4.196836 s: SCICLIENT: DMSC FW revision 0x14 [MCU2_0] 4.196863 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 4.196887 s: SCICLIENT: Init ... Done !!! [MCU2_0] 4.196907 s: UDMA: Init ... !!! [MCU2_0] 4.206568 s: UDMA: Init ... Done !!! [MCU2_0] 4.206619 s: MEM: Init ... !!! [MCU2_0] 4.206654 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d2400000 of size 8388608 bytes !!! [MCU2_0] 4.206706 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 131072 bytes !!! [MCU2_0] 4.206750 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ ce000000 of size 65536 bytes !!! [MCU2_0] 4.206793 s: MEM: Init ... Done !!! [MCU2_0] 4.206811 s: FVID2: Init ... !!! [MCU2_0] 4.206863 s: FVID2: Init ... Done !!! [MCU2_0] 4.206887 s: VHWA: VPAC Init ... !!! [MCU2_0] 4.206905 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2 [MCU2_0] 4.207640 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 4.207674 s: VHWA: LDC Init ... !!! [MCU2_0] 4.220515 s: VHWA: LDC Init ... Done !!! [MCU2_0] 4.220584 s: VHWA: MSC Init ... !!! [MCU2_0] 4.259377 s: VHWA: MSC Init ... Done !!! [MCU2_0] 4.259425 s: VHWA: NF Init ... !!! [MCU2_0] 4.266189 s: VHWA: NF Init ... Done !!! [MCU2_0] 4.266234 s: VHWA: VISS Init ... !!! [MCU2_0] 4.294614 s: VHWA: VISS Init ... Done !!! [MCU2_0] 4.294663 s: VHWA: VPAC Init ... Done !!! [MCU2_0] 4.294691 s: IPC: Init ... !!! [MCU2_0] 4.294720 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 4.294755 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 4.311178 s: CIO: Init ... Done !!! [MCU2_1] 4.311252 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz> [MCU2_1] 4.311295 s: APP: Init ... !!! [MCU2_1] 4.311317 s: SCICLIENT: Init ... !!! [MCU2_1] 4.312451 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [MCU2_1] 4.312492 s: SCICLIENT: DMSC FW revision 0x14 [MCU2_1] 4.312516 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 4.312543 s: SCICLIENT: Init ... Done !!! [MCU2_1] 4.312567 s: UDMA: Init ... !!! [MCU2_1] 4.324055 s: UDMA: Init ... Done !!! [MCU2_1] 4.324108 s: MEM: Init ... !!! [MCU2_1] 4.324146 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d2c00000 of size 16777216 bytes !!! [MCU2_1] 4.324203 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3620000 of size 131072 bytes !!! [MCU2_1] 4.324279 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ ce010000 of size 67043328 bytes !!! [MCU2_1] 4.324335 s: MEM: Init ... Done !!! [MCU2_1] 4.324357 s: FVID2: Init ... !!! [MCU2_1] 4.324413 s: FVID2: Init ... Done !!! [MCU2_1] 4.324441 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 4.324465 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 4.325271 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 4.325305 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 4.326009 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 4.326038 s: VHWA: DOF Init ... !!! [MCU2_1] 4.351541 s: VHWA: DOF Init ... Done !!! [MCU2_1] 4.351596 s: VHWA: SDE Init ... !!! [MCU2_1] 4.361593 s: VHWA: SDE Init ... Done !!! [MCU2_1] 4.361644 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 4.361674 s: VHWA: Codec: Init ... !!! [MCU2_1] 4.361696 s: VHWA: VDEC Init ... !!! [MCU2_1] 4.376094 s: VHWA: VDEC Init ... Done !!! [MCU2_1] 4.376149 s: VHWA: VENC Init ... !!! [MCU2_1] 4.376998 s: MM_ENC_Init: No OCM RAM pool available, fallback to DDR mode for above mp params [MCU2_1] 4.455215 s: VHWA: VENC Init ... Done !!! [MCU2_1] 4.455304 s: VHWA: Init ... Done !!! [MCU2_1] 4.455335 s: IPC: Init ... !!! [MCU2_1] 4.455368 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 4.455403 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_1 ] 4.397825 s: CIO: Init ... Done !!! [C6x_1 ] 4.397860 s: ### CPU Frequency <ORG = 1350000000 Hz>, <NEW = 1350000000 Hz> [C6x_1 ] 4.397873 s: APP: Init ... !!! [C6x_1 ] 4.397881 s: SCICLIENT: Init ... !!! [C6x_1 ] 4.398984 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [C6x_1 ] 4.398996 s: SCICLIENT: DMSC FW revision 0x14 [C6x_1 ] 4.399006 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 4.399015 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 4.399023 s: UDMA: Init ... !!! [C6x_1 ] 4.413192 s: UDMA: Init ... Done !!! [C6x_1 ] 4.413214 s: MEM: Init ... !!! [C6x_1 ] 4.413227 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d4000000 of size 16777216 bytes !!! [C6x_1 ] 4.413244 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_1 ] 4.413260 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ d5000000 of size 50331648 bytes !!! [C6x_1 ] 4.413275 s: MEM: Init ... Done !!! [C6x_1 ] 4.413283 s: IPC: Init ... !!! [C6x_1 ] 4.413296 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 4.413310 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_2 ] 4.453754 s: CIO: Init ... Done !!! [C6x_2 ] 4.453790 s: ### CPU Frequency <ORG = 1350000000 Hz>, <NEW = 1350000000 Hz> [C6x_2 ] 4.453804 s: APP: Init ... !!! [C6x_2 ] 4.453812 s: SCICLIENT: Init ... !!! [C6x_2 ] 4.454987 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [C6x_2 ] 4.454999 s: SCICLIENT: DMSC FW revision 0x14 [C6x_2 ] 4.455009 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 4.455019 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 4.455029 s: UDMA: Init ... !!! [C6x_2 ] 4.469431 s: UDMA: Init ... Done !!! [C6x_2 ] 4.469453 s: MEM: Init ... !!! [C6x_2 ] 4.469467 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d8000000 of size 16777216 bytes !!! [C6x_2 ] 4.469484 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_2 ] 4.469500 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ d9000000 of size 50331648 bytes !!! [C6x_2 ] 4.469516 s: MEM: Init ... Done !!! [C6x_2 ] 4.469524 s: IPC: Init ... !!! [C6x_2 ] 4.469539 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 4.469553 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 4.690164 s: CIO: Init ... Done !!! [C7x_1 ] 4.690187 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz> [C7x_1 ] 4.690202 s: APP: Init ... !!! [C7x_1 ] 4.690210 s: SCICLIENT: Init ... !!! [C7x_1 ] 4.691373 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [C7x_1 ] 4.691387 s: SCICLIENT: DMSC FW revision 0x14 [C7x_1 ] 4.691397 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 4.691408 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 4.691417 s: UDMA: Init ... !!! [C7x_1 ] 4.700648 s: UDMA: Init ... Done !!! [C7x_1 ] 4.700660 s: MEM: Init ... !!! [C7x_1 ] 4.700670 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ dc000000 of size 268435456 bytes !!! [C7x_1 ] 4.700691 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!! [C7x_1 ] 4.700708 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 491520 bytes !!! [C7x_1 ] 4.700725 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!! [C7x_1 ] 4.700742 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ ec000000 of size 234881024 bytes !!! [C7x_1 ] 4.700760 s: MEM: Init ... Done !!! [C7x_1 ] 4.700768 s: IPC: Init ... !!! [C7x_1 ] 4.700778 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 4.700792 s: IPC: Waiting for HLOS to be ready ... !!! root@j7-evm:/opt/vision_apps# ls app_avp.cfg app_srv_avp_cfg run_app_tidl_avp.sh vx_app_c7x_kernel.out vx_app_srv_fileio.out app_avp2.cfg app_stereo.cfg run_app_tidl_avp2.sh vx_app_conformance.out vx_app_stereo_depth.out app_avp3.cfg app_tidl_cam.cfg run_app_tidl_avp3.sh vx_app_dense_optical_flow.out vx_app_surround_radar_ogmap.out app_avp4.cfg app_vl.cfg run_app_tidl_avp4.sh vx_app_dense_optical_flow2.out vx_app_test_framework.out app_c7x.cfg libtivision_apps.so.7.1.0 run_app_tidl_cam.sh vx_app_dof_sfm_fisheye.out vx_app_tidl.out app_dof.cfg limits.conf run_app_tidl_od.sh vx_app_encode.out vx_app_tidl_avp.out app_encode.cfg ptk_app_cfg run_app_tidl_seg.sh vx_app_lidar_ogmap.out vx_app_tidl_avp2.out app_multi_cam.cfg run_app_c7x.sh run_app_tidl_seg_16bit.sh vx_app_linux_arm_ipc.out vx_app_tidl_avp3.out app_oc.cfg run_app_dof.sh run_app_tidl_vl.sh vx_app_linux_arm_mem.out vx_app_tidl_avp4.out app_oc_16bit.cfg run_app_encode.sh run_ptk_demo.sh vx_app_linux_arm_remote_log.out vx_app_tidl_cam.out app_od.cfg run_app_multi_cam.sh test_data vx_app_load_test.out vx_app_tidl_od.out app_pcie_video_sink.cfg run_app_single_cam.sh test_data_ptk vx_app_multi_cam.out vx_app_tidl_seg.out app_pcie_video_source.cfg run_app_srv.sh uEnv.txt vx_app_sde.out vx_app_tidl_vl.out app_seg.cfg run_app_srv_avp.sh vision_apps_init.sh vx_app_sde_obstacle_detection.out vx_app_tutorial.out app_seg_16bit.cfg run_app_stereo.sh vx_app_arm_fd_exchange_consumer.out vx_app_single_cam.out vx_app_valet_parking.out app_single_cam.cfg run_app_tidl.sh vx_app_arm_fd_exchange_producer.out vx_app_srv_calibration.out app_srv.cfg run_app_tidl_16bit.sh vx_app_arm_opengl_mosaic.out vx_app_srv_camera.out root@j7-evm:/opt/vision_apps# ./run_app_tidl.sh APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=4) !!! MEM: Init ... Done !!! IPC: Init ... !!! rpmsg_chrdev driver is not enabled/installed IPC: Init ... Done !!! APP: ERROR: IPC init failed !!! REMOTE_SERVICE: Init ... !!! rpmsg_char_open cannot be invoked without initialization rpmsg_char_open cannot be invoked without initialization rpmsg_char_open cannot be invoked without initialization rpmsg_char_open cannot be invoked without initialization rpmsg_char_open cannot be invoked without initialization REMOTE_SERVICE: Init ... Done !!! APP: Init ... Done !!! 50.836385 s: VX_ZONE_INIT:Enabled 50.836396 s: VX_ZONE_ERROR:Enabled 50.836400 s: VX_ZONE_WARNING:Enabled 50.840184 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!! 50.840416 s: VX_ZONE_INIT:[tivxHostInit:48] Initialization Done for HOST !!! 50.841337 s: VX_ZONE_ERROR:[ownContextCreateCmdObj:160] context object descriptor [0] allocation failed 50.841351 s: VX_ZONE_ERROR:[vxCreateContext:907] context objection creation failed 50.844036 s: VX_ZONE_ERROR:[vxGetStatus:700] Reference is NULL 50.844945 s: VX_ZONE_ERROR:[vxGetStatus:700] Reference is NULL 50.844952 s: VX_ZONE_ERROR:[vxGetStatus:700] Reference is NULL 50.844957 s: VX_ZONE_ERROR:[vxGetStatus:700] Reference is NULL 50.844962 s: VX_ZONE_ERROR:[vxGetStatus:700] Reference is NULL 50.846821 s: VX_ZONE_ERROR:[tivxAddKernelTIDL:234] Unable to allocate user kernel ID 50.880193 s: VX_ZONE_ERROR:[vxSetReferenceName:646] Invalid reference 50.880227 s: VX_ZONE_ERROR:[vxMapUserDataObject:473] Invalid user data object reference Segmentation fault root@j7-evm:/opt/vision_apps#
U-Boot SPL 2020.01-g3c9ebdb87d (Nov 19 2020 - 18:29:59 +0000) SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla') Detected: J7X-BASE-CPB rev E3 Detected: J7X-VSC8514-ETH rev E2 Trying to boot from MMC2 U-Boot 2020.01-g3c9ebdb87d (Nov 19 2020 - 18:29:59 +0000) SoC: J721E SR1.0 Model: Texas Instruments K3 J721E SoC Board: J721EX-PM2-SOM rev E7 DRAM: 4 GiB not found for dev hbmc-mux Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from MMC... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Detected: J7X-BASE-CPB rev E3 Detected: J7X-VSC8514-ETH rev E2 Net: Warning: ethernet@46000000 using MAC address from ROM eth0: ethernet@46000000 Hit any key to stop autoboot: 2 U-Boot SPL 2020.01-g3c9ebdb87d (Nov 19 2020 - 18:33:21 +0000) SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla') Trying to boot from MMC2 Loading Environment from MMC... *** Warning - No MMC card found, using default environment Starting ATF on ARM64 core... NOTICE: BL31: v2.3():07.01.00.004-1-g52c334fc3-dirty NOTICE: BL31: Built : 18:17:14, Nov 19 2020 U-Boot SPL 2020.01-g3c9ebdb87d (Nov 19 2020 - 18:29:59 +0000) SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla') Detected: J7X-BASE-CPB rev E3 Detected: J7X-VSC8514-ETH rev E2 Trying to boot from MMC2 U-Boot 2020.01-g3c9ebdb87d (Nov 19 2020 - 18:29:59 +0000) SoC: J721E SR1.0 Model: Texas Instruments K3 J721E SoC Board: J721EX-PM2-SOM rev E7 DRAM: 4 GiB not found for dev hbmc-mux Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from MMC... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Detected: J7X-BASE-CPB rev E3 Detected: J7X-VSC8514-ETH rev E2 Net: Warning: ethernet@46000000 using MAC address from ROM eth0: ethernet@46000000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 483 bytes read in 1 ms (471.7 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 1 ms (1000 Bytes/s) Already setup. 5212504 bytes read in 112 ms (44.4 MiB/s) Load Remote Processor 2 with data@addr=0x82000000 5212504 bytes: Success! 1964032 bytes read in 44 ms (42.6 MiB/s) Load Remote Processor 3 with data@addr=0x82000000 1964032 bytes: Success! 1579152 bytes read in 35 ms (43 MiB/s) Load Remote Processor 6 with data@addr=0x82000000 1579152 bytes: Success! 1579152 bytes read in 37 ms (40.7 MiB/s) Load Remote Processor 7 with data@addr=0x82000000 1579152 bytes: Success! 9969648 bytes read in 212 ms (44.8 MiB/s) Load Remote Processor 8 with data@addr=0x82000000 9969648 bytes: Success! 16666632 bytes read in 350 ms (45.4 MiB/s) 93829 bytes read in 4 ms (22.4 MiB/s) 6199 bytes read in 2 ms (3 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008fee6000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.4.74-g9574bba32a (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Thu Nov 19 18:30:39 UTC 2020 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 7 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a5800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5900000, size 7 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a5900000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-dma-memory@ac000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ce000000, size 720 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-core-heap-memory@ce000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@fb000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@fb100000, compatible id shared-dma-pool [ 0.000000] cma: Failed to reserve 512 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 35779 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),57216k@8m(ospi.rootfs),128k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=d46439ae-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x9a800000-0x9e800000] (64MB) [ 0.000000] Memory: 2584000K/2293760K available (9598K kernel code, 788K rwdata, 3840K rodata, 1664K init, 683K bss, 18446744073709261376K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: no VLPI support, no direct LPI support [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008c00c0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000 [ 0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x43c with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008390] Console: colour dummy device 80x25 [ 0.012957] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023626] pid_max: default: 32768 minimum: 301 [ 0.028379] LSM: Security Framework initializing [ 0.033132] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.040703] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.049990] ASID allocator initialised with 32768 entries [ 0.055583] rcu: Hierarchical SRCU implementation. [ 0.060643] Platform MSI: gic-its@1820000 domain created [ 0.066328] PCI/MSI: /bus@100000/interrupt-controller@1800000/gic-its@1820000 domain created [ 0.075187] smp: Bringing up secondary CPUs ... [ 0.081273] Detected PIPT I-cache on CPU1 [ 0.081299] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.081310] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000 [ 0.081341] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.081401] smp: Brought up 1 node, 2 CPUs [ 0.110748] SMP: Total of 2 processors activated. [ 0.115552] CPU features: detected: 32-bit EL0 Support [ 0.120806] CPU features: detected: CRC32 instructions [ 0.132680] CPU: All CPU(s) started at EL2 [ 0.136875] alternatives: patching kernel code [ 0.142095] devtmpfs: initialized [ 0.150660] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.160628] futex hash table entries: 512 (order: -1, 32768 bytes, linear) [ 0.168059] pinctrl core: initialized pinctrl subsystem [ 0.173936] NET: Registered protocol family 16 [ 0.178723] DMA: preallocated 256 KiB pool for atomic allocations [ 0.185252] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.201301] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages [ 0.208158] HugeTLB registered 512 MiB page size, pre-allocated 0 pages [ 0.214920] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.223111] cryptd: max_cpu_qlen set to 1000 [ 0.229694] vsys_3v3: supplied by evm_12v0 [ 0.233996] vsys_5v0: supplied by evm_12v0 [ 0.238632] iommu: Default domain type: Translated [ 0.243807] SCSI subsystem initialized [ 0.247946] mc: Linux media interface: v0.10 [ 0.252316] videodev: Linux video capture interface: v2.00 [ 0.257928] pps_core: LinuxPPS API ver. 1 registered [ 0.262997] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.272333] PTP clock support registered [ 0.276345] EDAC MC: Ver: 3.0.0 [ 0.280104] FPGA manager framework [ 0.283625] Advanced Linux Sound Architecture Driver Initialized. [ 0.290233] clocksource: Switched to clocksource arch_sys_counter [ 0.296565] VFS: Disk quotas dquot_6.6.0 [ 0.300617] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes) [ 0.310275] Carveout Heap: Exported 512 MiB at 0x00000000ae000000 [ 0.316509] thermal_sys: Registered thermal governor 'step_wise' [ 0.316510] thermal_sys: Registered thermal governor 'power_allocator' [ 0.322978] NET: Registered protocol family 2 [ 0.334476] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear) [ 0.343245] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear) [ 0.351438] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear) [ 0.359247] TCP: Hash tables configured (established 32768 bind 32768) [ 0.366004] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.372896] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.380308] NET: Registered protocol family 1 [ 0.385089] RPC: Registered named UNIX socket transport module. [ 0.391140] RPC: Registered udp transport module. [ 0.395943] RPC: Registered tcp transport module. [ 0.400746] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.407331] PCI: CLS 0 bytes, default 64 [ 0.411761] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 0.421923] Initialise system trusted keyrings [ 0.426565] workingset: timestamp_bits=46 max_order=16 bucket_order=0 [ 0.435278] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.441541] NFS: Registering the id_resolver key type [ 0.446718] Key type id_resolver registered [ 0.450988] Key type id_legacy registered [ 0.455085] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.462060] 9p: Installing v9fs 9p2000 file system support [ 0.474389] Key type asymmetric registered [ 0.478575] Asymmetric key parser 'x509' registered [ 0.483583] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.491142] io scheduler mq-deadline registered [ 0.495767] io scheduler kyber registered [ 0.501082] pinctrl-single 4301c000.pinmux: 94 pins, size 376 [ 0.507186] pinctrl-single 11c000.pinmux: 173 pins, size 692 [ 0.515439] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.521706] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.528051] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.534475] debugfs: Directory '31010000.pat' with parent 'regmap' already present! [ 0.542484] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.548897] debugfs: Directory '31011000.pat' with parent 'regmap' already present! [ 0.556832] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.563242] debugfs: Directory '31012000.pat' with parent 'regmap' already present! [ 0.571163] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.577490] debugfs: Directory '31013000.pat' with parent 'regmap' already present! [ 0.585409] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.591731] debugfs: Directory '31014000.pat' with parent 'regmap' already present! [ 0.601164] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.613548] brd: module loaded [ 0.620027] loop: module loaded [ 0.623653] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys' [ 0.631579] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.74-g9574bba32a #1 [ 0.638688] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 0.644643] Call trace: [ 0.647140] dump_backtrace+0x0/0x140 [ 0.650875] show_stack+0x14/0x20 [ 0.654257] dump_stack+0xb4/0x114 [ 0.657736] sysfs_warn_dup+0x5c/0x78 [ 0.661470] sysfs_create_dir_ns+0xd8/0xf0 [ 0.665651] kobject_add_internal+0x94/0x280 [ 0.670007] kobject_add+0x90/0xf8 [ 0.673477] device_add+0xdc/0x600 [ 0.676944] platform_device_add+0xfc/0x228 [ 0.681211] platform_device_register_full+0xc8/0x140 [ 0.686370] dma_buf_phys_init+0x68/0x94 [ 0.690372] do_one_initcall+0x50/0x1a8 [ 0.694290] kernel_init_freeable+0x194/0x23c [ 0.698736] kernel_init+0x10/0xfc [ 0.702204] ret_from_fork+0x10/0x1c [ 0.705869] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory. [ 0.720061] libphy: Fixed MDIO Bus: probed [ 0.724446] tun: Universal TUN/TAP device driver, 1.6 [ 0.729891] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k [ 0.737896] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.743997] sky2: driver version 1.30 [ 0.748283] VFIO - User Level meta-driver version: 0.3 [ 0.753939] i2c /dev entries driver [ 0.758015] sdhci: Secure Digital Host Controller Interface driver [ 0.764329] sdhci: Copyright(c) Pierre Ossman [ 0.768989] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.775243] ledtrig-cpu: registered to indicate activity on CPUs [ 0.782033] optee: probing for conduit method from DT. [ 0.787302] optee: revision 3.8 (199fca17) [ 0.787656] optee: initialized driver [ 0.796502] NET: Registered protocol family 17 [ 0.801132] 9pnet: Installing 9P2000 support [ 0.805530] Key type dns_resolver registered [ 0.810057] registered taskstats version 1 [ 0.814243] Loading compiled-in X.509 certificates [ 0.823120] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.829444] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.837814] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla') [ 0.980875] random: fast init done [ 1.168524] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.179658] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz [ 1.186190] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [ 1.192852] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz [ 1.199465] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator [ 1.206890] pca953x 3-0020: using no AI [ 1.234757] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator [ 1.242162] pca953x 3-0022: using AI [ 1.246428] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low [ 1.253023] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high [ 1.259863] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 1.266293] omap_i2c 2020000.i2c: bus 4 rev0.12 at 100 kHz [ 1.272671] pca953x 5-0020: 5-0020 supply vcc not found, using dummy regulator [ 1.280086] pca953x 5-0020: using no AI [ 1.306628] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz [ 1.313043] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz [ 1.319346] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz [ 1.326124] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 1.336515] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 1.345823] ti-sci-intr bus@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created [ 1.356961] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 2.397110] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 2.404820] j721e-pcie 2900000.pcie: IO 0x10001000..0x10010fff -> 0x10001000 [ 2.412309] j721e-pcie 2900000.pcie: MEM 0x10011000..0x17ffffff -> 0x10011000 [ 2.419872] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00 [ 2.426280] pci_bus 0000:00: root bus resource [bus 00-0f] [ 2.431885] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff]) [ 2.441574] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff] [ 2.448617] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400 [ 2.454767] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.464637] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.474525] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits [ 2.484483] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.494451] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits [ 2.504413] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits [ 2.514398] pci 0000:00:00.0: supports D1 [ 2.518491] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.524363] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits [ 2.536260] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.544451] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.554410] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.564368] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.575977] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01 [ 2.582747] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.588026] pcieport 0000:00:00.0: PME: Signaling with IRQ 37 [ 2.594067] pcieport 0000:00:00.0: AER: enabled with IRQ 37 [ 3.604176] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 3.611858] j721e-pcie 2910000.pcie: IO 0x18001000..0x18010fff -> 0x18001000 [ 3.619336] j721e-pcie 2910000.pcie: MEM 0x18011000..0x1fffffff -> 0x18011000 [ 3.626876] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00 [ 3.633282] pci_bus 0001:00: root bus resource [bus 00-0f] [ 3.638886] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff]) [ 3.648754] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff] [ 3.655792] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400 [ 3.661999] pci 0001:00:00.0: supports D1 [ 3.666093] pci 0001:00:00.0: PME# supported from D0 D1 D3hot [ 3.673821] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.683733] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01 [ 3.690502] pci 0001:00:00.0: PCI bridge to [bus 01] [ 3.695763] pcieport 0001:00:00.0: PME: Signaling with IRQ 40 [ 3.701775] pcieport 0001:00:00.0: AER: enabled with IRQ 40 [ 4.711565] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges: [ 4.719249] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x00001000 [ 4.727081] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x00011000 [ 4.734981] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00 [ 4.741387] pci_bus 0002:00: root bus resource [bus 00-0f] [ 4.746992] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff]) [ 4.756238] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff]) [ 4.767007] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400 [ 4.773214] pci 0002:00:00.0: supports D1 [ 4.777307] pci 0002:00:00.0: PME# supported from D0 D1 D3hot [ 4.785012] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.794917] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01 [ 4.801685] pci 0002:00:00.0: PCI bridge to [bus 01] [ 4.806941] pcieport 0002:00:00.0: PME: Signaling with IRQ 43 [ 4.812956] pcieport 0002:00:00.0: AER: enabled with IRQ 43 [ 4.819969] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 4.829847] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 4.836606] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 4.846076] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 4.856234] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 4.862993] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 4.871416] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250 [ 4.881135] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250 [ 4.889878] printk: console [ttyS2] enabled [ 4.889878] printk: console [ttyS2] enabled [ 4.898317] printk: bootconsole [ns16550a0] disabled [ 4.898317] printk: bootconsole [ns16550a0] disabled [ 4.909187] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250 [ 4.918461] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 24, base_baud = 3000000) is a 8250 [ 4.927731] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 4.936830] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq [ 4.945958] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq [ 4.953657] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs [ 4.963444] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 4.973955] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 4.984107] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 4.994347] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 5.008294] scsi host0: ufshcd [ 5.030054] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0 [ 5.061224] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2 [ 5.066239] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 5.080493] libphy: 46000f00.mdio: probed [ 5.084494] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0 [ 5.085643] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 5.103875] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 5.116688] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 5.116744] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517 [ 5.133190] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 5.137580] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 5.150218] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found [ 5.151277] mmc0: CQHCI version 5.10 [ 5.200809] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit [ 5.212485] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.244744] vdd_mmc1: supplied by vsys_3v3 [ 5.251051] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 5.259531] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 5.268057] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 5.276491] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 5.284990] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 5.298865] ti-udma 285c0000.dma-controller: Channels: 24 (tchan: 12, rchan: 12, gp-rflow: 8) [ 5.312783] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16) [ 5.323349] mmc0: Command Queue Engine enabled [ 5.327792] mmc0: new HS200 MMC card at address 0001 [ 5.333490] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 5.338215] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB [ 5.344381] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB [ 5.350422] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0) [ 5.359205] mmcblk0: p1 p2 [ 5.381579] cadence-qspi 47040000.spi: PHY calibration failed: -2 [ 5.387668] spi-nor spi0.0: mt35xu512aba (65536 Kbytes) [ 5.392892] 8 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 5.399490] Creating 8 MTD partitions on "47040000.spi.0": [ 5.404963] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 5.411041] 0x000000080000-0x000000280000 : "ospi.tispl" [ 5.416858] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 5.422664] 0x000000680000-0x0000006a0000 : "ospi.env" [ 5.428237] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup" [ 5.434414] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 5.440178] 0x000000800000-0x000003fe0000 : "ospi.rootfs" [ 5.445945] 0x000003fe0000-0x000004000000 : "ospi.phypattern" [ 5.463434] spi-nor spi1.0: mt25qu512a (65536 Kbytes) [ 5.510252] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 5.517900] libphy: 46000f00.mdio: probed [ 5.523014] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 5.531278] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 5.549836] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 5.559150] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4 [ 5.566450] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 5.573769] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 5.587146] mmc1: CQHCI version 5.10 [ 6.655360] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit [ 6.664740] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 6.706271] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 6.713668] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 6.720992] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 6.728305] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 6.736558] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 6.743442] hctosys: unable to open rtc device (rtc0) [ 6.888960] ALSA device list: [ 6.891926] No soundcards found. [ 6.895628] Waiting for root device PARTUUID=d46439ae-02... [ 7.044442] mmc1: new ultra high speed DDR50 SDHC card at address 01e1 [ 7.051388] mmcblk1: mmc1:01e1 UC0D5 29.8 GiB [ 7.059504] mmcblk1: p1 p2 [ 7.290305] EXT4-fs (mmcblk1p2): recovery complete [ 7.299424] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 7.307537] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 7.316228] devtmpfs: mounted [ 7.319603] Freeing unused kernel memory: 1664K [ 7.324158] Run /sbin/init as init process INIT: version 2.96 booting [ 7.589008] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) hwclock: Cannot access the Hardware Clock via any known method. hwclock: Use the --verbose option to see the details of our search for an access method. Thu Nov 19 19:21:46 UTC 2020 hwclock: Cannot access the Hardware Clock via any known method. hwclock: Use the --verbose option to see the details of our search for an access method. [ 7.842923] random: dd: uninitialized urandom read (512 bytes read) INIT: Entering runlevel: 5 Configuring network interfaces... [ 7.939315] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL) [ 7.951718] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down udhcpc: started, v1.31.1 udhcpc: sending discover udhcpc: sending discover udhcpc: sending discover udhcpc: no lease, forking to background done. Starting dockerd: [ 20.694251] random: crng init done hwclock: Cannot access the Hardware Clock via any known method. hwclock: Use the --verbose option to see the details of our search for an access method. Starting syslogd/klogd: done _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org j7-evm ttyS2 Arago 2020.09 j7-evm ttyS2 j7-evm login: root root@j7-evm:~# ls root@j7-evm:~# df Filesystem 1K-blocks Used Available Use% Mounted on /dev/root 30513004 12500548 16439440 43% / devtmpfs 1291968 0 1291968 0% /dev tmpfs 1292800 448 1292352 0% /run tmpfs 51200 384 50816 1% /var/volatile root@j7-evm:~# cd /opt/vision_apps/ root@j7-evm:/opt/vision_apps# ls app_avp.cfg app_srv_avp_cfg run_app_tidl_avp.sh vx_app_c7x_kernel.out vx_app_srv_fileio.out app_avp2.cfg app_stereo.cfg run_app_tidl_avp2.sh vx_app_conformance.out vx_app_stereo_depth.out app_avp3.cfg app_tidl_cam.cfg run_app_tidl_avp3.sh vx_app_dense_optical_flow.out vx_app_surround_radar_ogmap.out app_avp4.cfg app_vl.cfg run_app_tidl_avp4.sh vx_app_dense_optical_flow2.out vx_app_test_framework.out app_c7x.cfg libtivision_apps.so.7.1.0 run_app_tidl_cam.sh vx_app_dof_sfm_fisheye.out vx_app_tidl.out app_dof.cfg limits.conf run_app_tidl_od.sh vx_app_encode.out vx_app_tidl_avp.out app_encode.cfg ptk_app_cfg run_app_tidl_seg.sh vx_app_lidar_ogmap.out vx_app_tidl_avp2.out app_multi_cam.cfg run_app_c7x.sh run_app_tidl_seg_16bit.sh vx_app_linux_arm_ipc.out vx_app_tidl_avp3.out app_oc.cfg run_app_dof.sh run_app_tidl_vl.sh vx_app_linux_arm_mem.out vx_app_tidl_avp4.out app_oc_16bit.cfg run_app_encode.sh run_ptk_demo.sh vx_app_linux_arm_remote_log.out vx_app_tidl_cam.out app_od.cfg run_app_multi_cam.sh test_data vx_app_load_test.out vx_app_tidl_od.out app_pcie_video_sink.cfg run_app_single_cam.sh test_data_ptk vx_app_multi_cam.out vx_app_tidl_seg.out app_pcie_video_source.cfg run_app_srv.sh uEnv.txt vx_app_sde.out vx_app_tidl_vl.out app_seg.cfg run_app_srv_avp.sh vision_apps_init.sh vx_app_sde_obstacle_detection.out vx_app_tutorial.out app_seg_16bit.cfg run_app_stereo.sh vx_app_arm_fd_exchange_consumer.out vx_app_single_cam.out vx_app_valet_parking.out app_single_cam.cfg run_app_tidl.sh vx_app_arm_fd_exchange_producer.out vx_app_srv_calibration.out app_srv.cfg run_app_tidl_16bit.sh vx_app_arm_opengl_mosaic.out vx_app_srv_camera.out root@j7-evm:/opt/vision_apps# ./vision_apps_init.sh root@j7-evm:/opt/vision_apps# [MCU2_0] 4.201151 s: CIO: Init ... Done !!! [MCU2_0] 4.201223 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz> [MCU2_0] 4.201264 s: APP: Init ... !!! [MCU2_0] 4.201283 s: SCICLIENT: Init ... !!! [MCU2_0] 4.202412 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [MCU2_0] 4.202458 s: SCICLIENT: DMSC FW revision 0x14 [MCU2_0] 4.202483 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 4.202507 s: SCICLIENT: Init ... Done !!! [MCU2_0] 4.202528 s: UDMA: Init ... !!! [MCU2_0] 4.212128 s: UDMA: Init ... Done !!! [MCU2_0] 4.212178 s: MEM: Init ... !!! [MCU2_0] 4.212212 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d2400000 of size 8388608 bytes !!! [MCU2_0] 4.212292 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 131072 bytes !!! [MCU2_0] 4.212340 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ ce000000 of size 65536 bytes !!! [MCU2_0] 4.212384 s: MEM: Init ... Done !!! [MCU2_0] 4.212402 s: FVID2: Init ... !!! [MCU2_0] 4.212455 s: FVID2: Init ... Done !!! [MCU2_0] 4.212482 s: VHWA: VPAC Init ... !!! [MCU2_0] 4.212500 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2 [MCU2_0] 4.213296 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 4.213333 s: VHWA: LDC Init ... !!! [MCU2_0] 4.226147 s: VHWA: LDC Init ... Done !!! [MCU2_0] 4.226193 s: VHWA: MSC Init ... !!! [MCU2_0] 4.264752 s: VHWA: MSC Init ... Done !!! [MCU2_0] 4.264801 s: VHWA: NF Init ... !!! [MCU2_0] 4.271340 s: VHWA: NF Init ... Done !!! [MCU2_0] 4.271387 s: VHWA: VISS Init ... !!! [MCU2_0] 4.299654 s: VHWA: VISS Init ... Done !!! [MCU2_0] 4.299702 s: VHWA: VPAC Init ... Done !!! [MCU2_0] 4.299725 s: IPC: Init ... !!! [MCU2_0] 4.299753 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 4.299791 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 4.316500 s: CIO: Init ... Done !!! [MCU2_1] 4.316576 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz> [MCU2_1] 4.316620 s: APP: Init ... !!! [MCU2_1] 4.316642 s: SCICLIENT: Init ... !!! [MCU2_1] 4.317779 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [MCU2_1] 4.317826 s: SCICLIENT: DMSC FW revision 0x14 [MCU2_1] 4.317853 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 4.317879 s: SCICLIENT: Init ... Done !!! [MCU2_1] 4.317902 s: UDMA: Init ... !!! [MCU2_1] 4.329335 s: UDMA: Init ... Done !!! [MCU2_1] 4.329389 s: MEM: Init ... !!! [MCU2_1] 4.329424 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d2c00000 of size 16777216 bytes !!! [MCU2_1] 4.329480 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3620000 of size 131072 bytes !!! [MCU2_1] 4.329533 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ ce010000 of size 67043328 bytes !!! [MCU2_1] 4.329605 s: MEM: Init ... Done !!! [MCU2_1] 4.329635 s: FVID2: Init ... !!! [MCU2_1] 4.329696 s: FVID2: Init ... Done !!! [MCU2_1] 4.329725 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 4.329749 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 4.330536 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 4.330565 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 4.331284 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 4.331314 s: VHWA: DOF Init ... !!! [MCU2_1] 4.356809 s: VHWA: DOF Init ... Done !!! [MCU2_1] 4.356864 s: VHWA: SDE Init ... !!! [MCU2_1] 4.366859 s: VHWA: SDE Init ... Done !!! [MCU2_1] 4.366910 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 4.366939 s: VHWA: Codec: Init ... !!! [MCU2_1] 4.366959 s: VHWA: VDEC Init ... !!! [MCU2_1] 4.382362 s: VHWA: VDEC Init ... Done !!! [MCU2_1] 4.382412 s: VHWA: VENC Init ... !!! [MCU2_1] 4.383180 s: MM_ENC_Init: No OCM RAM pool available, fallback to DDR mode for above mp params [MCU2_1] 4.461534 s: VHWA: VENC Init ... Done !!! [MCU2_1] 4.461621 s: VHWA: Init ... Done !!! [MCU2_1] 4.461653 s: IPC: Init ... !!! [MCU2_1] 4.461688 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 4.461727 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_1 ] 4.404731 s: CIO: Init ... Done !!! [C6x_1 ] 4.404765 s: ### CPU Frequency <ORG = 1350000000 Hz>, <NEW = 1350000000 Hz> [C6x_1 ] 4.404779 s: APP: Init ... !!! [C6x_1 ] 4.404786 s: SCICLIENT: Init ... !!! [C6x_1 ] 4.405896 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [C6x_1 ] 4.405907 s: SCICLIENT: DMSC FW revision 0x14 [C6x_1 ] 4.405916 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 4.405926 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 4.405935 s: UDMA: Init ... !!! [C6x_1 ] 4.420137 s: UDMA: Init ... Done !!! [C6x_1 ] 4.420159 s: MEM: Init ... !!! [C6x_1 ] 4.420173 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d4000000 of size 16777216 bytes !!! [C6x_1 ] 4.420190 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_1 ] 4.420205 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ d5000000 of size 50331648 bytes !!! [C6x_1 ] 4.420220 s: MEM: Init ... Done !!! [C6x_1 ] 4.420229 s: IPC: Init ... !!! [C6x_1 ] 4.420242 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 4.420256 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_2 ] 4.460861 s: CIO: Init ... Done !!! [C6x_2 ] 4.460898 s: ### CPU Frequency <ORG = 1350000000 Hz>, <NEW = 1350000000 Hz> [C6x_2 ] 4.460912 s: APP: Init ... !!! [C6x_2 ] 4.460921 s: SCICLIENT: Init ... !!! [C6x_2 ] 4.462062 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [C6x_2 ] 4.462074 s: SCICLIENT: DMSC FW revision 0x14 [C6x_2 ] 4.462083 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 4.462093 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 4.462103 s: UDMA: Init ... !!! [C6x_2 ] 4.476536 s: UDMA: Init ... Done !!! [C6x_2 ] 4.476558 s: MEM: Init ... !!! [C6x_2 ] 4.476572 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d8000000 of size 16777216 bytes !!! [C6x_2 ] 4.476589 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_2 ] 4.476604 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ d9000000 of size 50331648 bytes !!! [C6x_2 ] 4.476620 s: MEM: Init ... Done !!! [C6x_2 ] 4.476629 s: IPC: Init ... !!! [C6x_2 ] 4.476644 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 4.476658 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 4.697668 s: CIO: Init ... Done !!! [C7x_1 ] 4.697692 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz> [C7x_1 ] 4.697707 s: APP: Init ... !!! [C7x_1 ] 4.697715 s: SCICLIENT: Init ... !!! [C7x_1 ] 4.698876 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla] [C7x_1 ] 4.698892 s: SCICLIENT: DMSC FW revision 0x14 [C7x_1 ] 4.698902 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 4.698912 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 4.698921 s: UDMA: Init ... !!! [C7x_1 ] 4.708233 s: UDMA: Init ... Done !!! [C7x_1 ] 4.708245 s: MEM: Init ... !!! [C7x_1 ] 4.708255 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ dc000000 of size 268435456 bytes !!! [C7x_1 ] 4.708276 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!! [C7x_1 ] 4.708293 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 491520 bytes !!! [C7x_1 ] 4.708311 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!! [C7x_1 ] 4.708327 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ ec000000 of size 234881024 bytes !!! [C7x_1 ] 4.708346 s: MEM: Init ... Done !!! [C7x_1 ] 4.708353 s: IPC: Init ... !!! [C7x_1 ] 4.708364 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 4.708378 s: IPC: Waiting for HLOS to be ready ... !!! root@j7-evm:/opt/vision_apps# ./run_app_tidl_avp3.sh APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=4) !!! MEM: Init ... Done !!! IPC: Init ... !!! rpmsg_chrdev driver is not enabled/installed IPC: Init ... Done !!! APP: ERROR: IPC init failed !!! REMOTE_SERVICE: Init ... !!! rpmsg_char_open cannot be invoked without initialization rpmsg_char_open cannot be invoked without initialization rpmsg_char_open cannot be invoked without initialization rpmsg_char_open cannot be invoked without initialization rpmsg_char_open cannot be invoked without initialization REMOTE_SERVICE: Init ... Done !!! APP: Init ... Done !!! 71.815809 s: VX_ZONE_INIT:Enabled 71.815820 s: VX_ZONE_ERROR:Enabled 71.815824 s: VX_ZONE_WARNING:Enabled 71.816499 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!! 71.816726 s: VX_ZONE_INIT:[tivxHostInit:48] Initialization Done for HOST !!! 71.817577 s: VX_ZONE_ERROR:[ownContextCreateCmdObj:160] context object descriptor [0] allocation failed 71.817592 s: VX_ZONE_ERROR:[vxCreateContext:907] context objection creation failed 71.817599 s: VX_ZONE_ERROR:[vxGetStatus:700] Reference is NULL 71.817607 s: VX_ZONE_ERROR:[vxGetStatus:700] Reference is NULL GRPX: ERROR: Unable to create vx_graph for graphics !!! 71.817622 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817627 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817632 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817638 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817642 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817647 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817651 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817656 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817661 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817666 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817670 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817675 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817680 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817685 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817690 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817695 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817699 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817703 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817708 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817713 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817717 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817722 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817726 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817731 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817735 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817740 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817744 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817749 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817754 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817758 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817763 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817767 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817773 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817777 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817782 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817786 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817791 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817795 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817800 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817805 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817809 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817814 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.817819 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 71.819505 s: VX_ZONE_ERROR:[vxReleaseContext:1067] context is invalid 71.819513 s: VX_ZONE_INIT:[tivxHostDeInit:56] De-Initialization Done for HOST !!! 71.823820 s: VX_ZONE_INIT:[tivxDeInit:111] De-Initialization Done !!! APP: Deinit ... !!! REMOTE_SERVICE: Deinit ... !!! REMOTE_SERVICE: Deinit ... Done !!! IPC: Deinit ... !!! Segmentation fault root@j7-evm:/opt/vision_apps#
