Part Number: TDA4VM
We designed a product with tda4 chip, and we encountered the following problems when configuring bt1120 interface.
1.I want to configure vout0 (dpi0) and Vout1 (dpi1) to bt1120 mode,I don't know where to configure it.(Only the configuration files for DSI and EDP interfaces in PSDKRA(app_dss_defaults.c)).I found the driver of DSS (I don't know, right? )In the directory:pdk_jacinto_07_00_00\packages\ti\drv\dss\src\drv. There are only DP and DSI drivers, not have BT mode drivers.Does BT mode need drivers similar to DP and DSI? If necessary, do you have driver source code?
2. Now the driver of DSS is controlled by r5f(TI-RTOS), but, I have two video data streams on A72(Linux). How can I use the display screen (bt1120) to display these two video data streams at the same time?
Looking forward to your reply, thanks a lot!
