TDA2PXEVM: TDA2PXEVM
Part Number: TDA2PXEVM
Hi All,
In one of the linker command file related to the BAM app .vcop_parameter_block section is mapped to EXTDMEM as shown below
 .vcop_parameter_block > EXTDMEM PAGE 1
Since VCOP cannot access memory other than WMEM, IBUFH and IBUFL, how this .vcop_parameter_block is being loaded into VCOP memory during runtime ??
Please let me know.
Likhith
[attached linker command file and generated map file ]
test_eveFeatureMatching.eve.out.map.zip
  • Hi Likhith,
        I am not sure which linker you are referring here, but as far as BAM is concerned, it doesnt use .vcop_parameter_block  section. BAM allocates the parameter block memory by its internal memory management module.
    Anshu
  • Hi Anshu,
    Thanks for Reply.
    If .vcop_parameter_block is not used, does the BAM stores parameters any of the memory other than WMEM, IBUFH and IBUFL ??
    And if it is stored in any other memory how is the data being sent to VCOP memory at runtime ??
    Please let me know.
    -Regards
    Likhith
  • Hi Likhith,
         During process call BAM calls the kernel_init function with the memory allocated for parameter blocks in WBUF. And hence the parameters are directly updated in the WBUF memory and no external memory is required.
    Anshu
