Part Number: AM5729
Other Parts Discussed in Thread: TMDSIDK572
I have received TMDSIDK572 eval board and checking for GPMC SDK example code check with Synchronous Multiplexed mode and probed GPMC_CLK signal at Expansion connector. But I didn’t received cock signal. Kindly help me to debug the code.
1) Gpmc configuration – SYNC mode, SINGLE ACCESS type, Address(0:15) and data(15:0) multiplexed mode.
Here I attached my gpmc file (gpmc.txt) and MMU config (.cfg) text file. please refer this. I am reading and writing continuously through gpmc. But not getting GPMC clock.
2) SDK – “ ti-processor-sdk-rtos-am57xx-evm-06.03.00.106-Windows-x86-Install”
3) OS – “TI-RTOS”.
* Copyright (C) 2013-2019 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* \file main.c
* \brief GPMC test application optimized for FPGA read and write using CPU and DMA.
Use the macros to select between synchronous/non-synchronous,
burst/non-burst, and CPU/DMA modes. The application will perform
reads and writes and output the benchmarks to UART terminal. The
test will pass/fail depending on whether the benchmark numbers fall
within the predefined bounds.
The timing values configured in GPMC_init() can be tuned to further
optimize your application.
One of the following configurations can be tested at a time by defining/undefining the macros below.
1. Synchronous Burst DMA Mode
2. Synchronous Non-burst DMA Mode
3. Asynchronous Burst DMA Mode
4. Asynchronous Non-burst DMA Mode
5. Synchronous Burst CPU Mode
6. Synchronous Non-burst CPU Mode
7. Asynchronous Burst CPU Mode
8. Asynchronous Non-burst CPU Mode
/* Include Files */
#include <ti/csl/example/utils/uart_console/inc/uartConfig.h>
#include <ti/csl/csl_gpmc.h>
#include <ti/csl/soc.h>
#include <ti/csl/hw_types.h>
#include <ti/csl/csl_edma.h>
#include <ti/csl/example/edma/edma_test/sample.h>
#include <ti/drv/uart/UART.h>
#include <ti/drv/uart/UART_stdio.h>
#include <ti/csl/soc/am572x/src/cslr_control_core_pad_io.h>
/* Macros */
#define BURST_MODE
#define SYNC_MODE
#define DMA_ENABLE
/* Global Variables */
signed char __attribute__((section(".my_sect_ddr"))) _srcBuff1[MAX_BUFFER_SIZE];
signed char __attribute__((section(".my_sect_ddr"))) _dstBuff1[MAX_BUFFER_SIZE];
uint32_t edma_ch_num = 1;
uint32_t edma_tcc_num = 1;
uint32_t edma_evtq_num = 0;
uint32_t region = EDMA3_CC_REGION;
signed char *srcBuff1;
signed char *dstBuff1;
extern uint32_t base_address;
/*To use UARTConfigPuts function for prints*/
uint32_t uartBaseAddr = SOC_UART3_BASE;
/* To use for benchmarking */
#define TIMER14_TCLR (*((volatile uint32_t *)0x4882A038))
#define TIMER14_TLDR (*((volatile uint32_t *)0x4882A040))
#define TIMER14_TCRR (*((volatile uint32_t *)0x4882A03C))
#define TIMER14_TMAR (*((volatile uint32_t *)0x4882A04C))
#define TIMER14_TSICR (*((volatile uint32_t *)0x4882A054))
/* Function Definitions */
void GPMC_init(void);
void padConfig_prcmEnable(void);
int gpmc_init(void);
int gpmc_init(void)
uint32_t i, t_start, t_stop, t_overhead;
uint32_t t_delta_cpu_writes, t_delta_cpu_reads;
uint32_t var0 = 0xFFFFFFFF;
volatile uint32_t * GPMC0 = (volatile uint32_t*) 0x08000000;
volatile uint32_t * GPMC1 = (volatile uint32_t*) 0x08000004;
volatile uint32_t * GPMC2 = (volatile uint32_t*) 0x08000008;
volatile uint32_t * GPMC3 = (volatile uint32_t*) 0x0800000C;
volatile uint32_t * GPMC4 = (volatile uint32_t*) 0x08000010;
volatile uint32_t * GPMC5 = (volatile uint32_t*) 0x08000014;
volatile uint32_t * GPMC6 = (volatile uint32_t*) 0x08000018;
volatile uint32_t * GPMC7 = (volatile uint32_t*) 0x0800001C;
UART_printf("Data received is gpmc 1\n");
/*MMC1 PAD Configuration*/
padConfig_prcmEnable();
/* Configure GPMC registers with timing values optimized for an FPGA */
GPMC_init();
while (1)
/* Initialize timer14 for benchmarking */
TIMER14_TCLR = 0;
TIMER14_TLDR = 0;
TIMER14_TCRR = 0;
TIMER14_TMAR = 0;
TIMER14_TSICR = 0;
TIMER14_TCLR = 0x1;
/* Calculate timer overhead */
t_start = TIMER14_TCRR;
t_stop = TIMER14_TCRR;
t_overhead = t_stop - t_start;
for(i=0;i<4;i++)
*GPMC0 = 0xFFFFFFFF;
*GPMC1 = 0x00000000;
*GPMC2 = 0xAAAAAAAA;
*GPMC3 = 0x55555555;
*GPMC4 = 0xFFFFFFFF;
*GPMC5 = 0x00000000;
*GPMC6 = 0xFFFFFFFF;
*GPMC7 = 0xAAAAAAAA;
t_delta_cpu_writes = t_stop - t_start - t_overhead;
for(i=0;i<4;i++)
var0 = *GPMC0;
var0 = *GPMC1;
var0 = *GPMC2;
var0 = *GPMC3;
var0 = *GPMC4;
var0 = *GPMC5;
var0 = *GPMC6;
var0 = *GPMC7;
t_delta_cpu_reads = t_stop - t_start - t_overhead;
UART_printf("Data received is gpmc print end\n");
return 0;
/* Configures GPMC registers with timing values optimized for an OCTAL UART */
uint32_t baseAddr = CSL_MPU_GPMC_CONF_REGS_REGS;
uint32_t config;
/* Enable the chip select 3 OCTAL UART */
GPMCCSConfig(baseAddr, GPMC_CHIP_SELECT_0, GPMC_CS_ENABLE);
/* Select the chip-select base address, chip addr needs to be given */
GPMCBaseAddrSet(baseAddr, GPMC_CHIP_SELECT_0, 0x00000008);
/* Select the chip-select mask address */
GPMCMaskAddrSet(baseAddr, GPMC_CHIP_SELECT_0, GPMC_CS_SIZE_64MB);
/* Set the device size attached */
GPMCDevSizeSelect(baseAddr, GPMC_CHIP_SELECT_0, GPMC_DEVICESIZE_8BITS);
/* Set the read mode operation and write mode operation */
/*SYNC_MODE*/
GPMCReadTypeSelect(baseAddr,GPMC_CHIP_SELECT_0, GPMC_READTYPE_SYNC);
GPMCWriteTypeSelect(baseAddr,GPMC_CHIP_SELECT_0, GPMC_WRITETYPE_SYNC);
/* Select single access reads and writes*/
/* NON_BURST_MODE */ //need to check burst
GPMCAccessTypeSelect(baseAddr, GPMC_CHIP_SELECT_0, GPMC_MODE_READ, GPMC_ACCESSTYPE_SINGLE);
GPMCAccessTypeSelect(baseAddr, GPMC_CHIP_SELECT_0, GPMC_MODE_WRITE, GPMC_ACCESSTYPE_SINGLE);
/* Set the signals timing latencies scalar factor */
GPMCTimeParaGranularitySelect(baseAddr, GPMC_CHIP_SELECT_0,
GPMC_TIMEPARAGRANULARITY_X1);
/* Set the address and data multiplexed protocol */
GPMCAddrDataMuxProtocolSelect(baseAddr, GPMC_CHIP_SELECT_0,
GPMC_MUXADDDATA_ADMUX);
/* Set the timing parameters for the chip select signal */
//CSWROFFTIME, CSRDOFFTIME, CSEXTRADELAY, CSONTIME
config = GPMC_CS_TIMING_CONFIG(10, 7, GPMC_CS_EXTRA_NODELAY, 0);
GPMCCSTimingConfig(baseAddr, GPMC_CHIP_SELECT_0, config);
/* Set the timing parameters for the ADV# signal */
/* ADVAADMUXWROFFTIME, ADVAADMUXRDOFFTIME, ADVWROFFTIME, ADVRDOFFTIME, ADVEXTRADELAY, ADVAADMUXONTIME, ADVONTIME */
config = GPMC_ADV_TIMING_CONFIG(0, 0, 4, 4, GPMC_ADV_EXTRA_NODELAY, 0, 0);
GPMCADVTimingConfig(baseAddr, GPMC_CHIP_SELECT_0, config);
/* Set the timing parameters for the WE# and OE# signals */
/* WEOFFTIME, WEEXTRADELAY, WEONTIME, OEAADMUX_OFFTIME, OEOFFTIME, OEEXTRADELAY, OEAADMUX_ONTIME, OEONTIME */
config = GPMC_WE_OE_TIMING_CONFIG(7, 0, 4, 0, 7, GPMC_OE_EXTRA_NODELAY, 0,
4);
GPMCWEAndOETimingConfig(baseAddr, GPMC_CHIP_SELECT_0, config);
/* Set the RdAccessTime and CycleTime timing parameters */
/* RDCYCLETIME, WRCYCLETIME, RDACCESSTIME, PAGEBURSTACCESSTIME */
config = GPMC_RDACCESS_CYCLETIME_TIMING_CONFIG(9, 9, 6, 3);
GPMCRdAccessAndCycleTimeTimingConfig(baseAddr, GPMC_CHIP_SELECT_0, config);
/* Configure the Cycle2Cycle and BusTurnAround timing parameters */
/* CYCLE2CYCLEDELAY, CYCLE2CYCLEDELAYSAMECSCFG, CYCLE2CYCLEDELAYDIFFCSCFG, BUSTATIME */
config = GPMC_CYCLE2CYCLE_BUSTURNAROUND_TIMING_CONFIG(
2, GPMC_CYCLE2CYCLESAMECSEN_C2CDELAY,
GPMC_CYCLE2CYCLEDIFFCSEN_NOC2CDELAY, 0);
GPMCycle2CycleAndTurnArndTimeTimingConfig(baseAddr, GPMC_CHIP_SELECT_0,
config);
/* Configure the WrAccessTime, Cycle2Cycle andBusTurnAround timing parameters.*/
/* WRACCESSTIME, WRDATAONADMUXBUS */
GPMCWrAccessAndWrDataOnADMUXBusTimingConfig(baseAddr, GPMC_CHIP_SELECT_0, 6,
4);
/* Set the FCLK divide down value */
GPMCFclkDividerSelect(baseAddr, GPMC_CHIP_SELECT_0, GPMC_FCLK_DIV_BY_3);
/* Set the attached device page (burst) length */
GPMCDevPageLenSet(baseAddr, GPMC_CHIP_SELECT_0,
GPMC_DEV_PAGELENGTH_SIXTEEN);
UART_printf("Data received is gpmc 3\n");
/*Pad configurations */
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_UART3_RXD,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_UART3_TXD,
0x00000000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_UART2_CTSN,
0x00060002);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_UART2_RTSN,
0x00060001);
/*Pad configurations*/
/*GPMC Data lines AD15-AD0*/
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD15,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD14,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD13,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD12,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD11,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD10,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD9,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD8,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD7,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD6,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD5,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD4,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD3,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD2,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD1,
0x00050000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD0,
0x00050000);
/*GPMC Add lines A15-A1*/
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A15,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A14,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A13,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A12,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A11,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A10,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A9,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A8,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A7,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A6,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A5,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A4,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A3,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A2,
0x00040000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A1,
0x00040000);
/*GPMC chip select*/
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_CS0,
0x00060000);
/*GPMC control lines*/
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_ADVN_ALE,
0x00060000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_OEN_REN,
0x00070000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_WEN,
0x00070000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_BEN0,
0x00070000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_WAIT0,
0x000F0000);
HW_WR_REG32(
CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_CLK,
0x00060000);
UART_printf("Data received is gpmc 2\n");
/***************************** End Of File ***********************************/
* \file uart_arm.cfg
* \brief Sysbios config file for UART example project on AM572X IDK EVM.
* Copyright (C) 2015 Texas Instruments Incorporated - http://www.ti.com/
* are met:
* distribution.
/* ================ General configuration ================ */
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var Diags = xdc.useModule('xdc.runtime.Diags');
var Error = xdc.useModule('xdc.runtime.Error');
var Log = xdc.useModule('xdc.runtime.Log');
var LoggerBuf = xdc.useModule('xdc.runtime.LoggerBuf');
var Main = xdc.useModule('xdc.runtime.Main');
var Memory = xdc.useModule('xdc.runtime.Memory')
var SysMin = xdc.useModule('xdc.runtime.SysMin');
var System = xdc.useModule('xdc.runtime.System');
var Text = xdc.useModule('xdc.runtime.Text');
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Swi = xdc.useModule('ti.sysbios.knl.Swi');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
var IntXbar = xdc.useModule('ti.sysbios.family.shared.vayu.IntXbar');
var Program = xdc.useModule("xdc.cfg.Program");
* Program.argSize sets the size of the .args section.
* The examples don't use command line args so argSize is set to 0.
/* Program.argSize = 0x0; */
Program.heap = 0x10000;
/* System stack size (used by ISRs and Swis) */
Program.stack = 0x20000;
* Uncomment this line to globally disable Asserts.
* All modules inherit the default from the 'Defaults' module. You
* can override these defaults on a per-module basis using Module.common$.
* Disabling Asserts will save code space and improve runtime performance.
Defaults.common$.diags_ASSERT = Diags.ALWAYS_OFF;
* Uncomment this line to keep module names from being loaded on the target.
* The module name strings are placed in the .const section. Setting this
* parameter to false will save space in the .const section. Error and
* Assert messages will contain an "unknown module" prefix instead
* of the actual module name.
/*Defaults.common$.namedModule = false;*/
* Create and install logger for the whole system
var loggerBufParams = new LoggerBuf.Params();
loggerBufParams.numEntries = 16;
var logger0 = LoggerBuf.create(loggerBufParams);
Defaults.common$.logger = logger0;
Main.common$.diags_INFO = Diags.ALWAYS_ON;
/* ================ BIOS configuration ================ */
var BIOS = xdc.useModule('ti.sysbios.BIOS');
* Build a custom SYS/BIOS library from sources.
BIOS.libType = BIOS.LibType_Custom;
BIOS.heapSize = 0x10000;
/* ================ Driver configuration ================ */
/* Load the OSAL package */
var osType = "tirtos";
var Osal = xdc.loadPackage('ti.osal');
Osal.Settings.osType = osType;
/*use CSL package*/
var socType = "am572x";
var Csl = xdc.loadPackage('ti.csl');
Csl.Settings.deviceType = socType;
/* Load the uart package */
var Uart = xdc.loadPackage('ti.drv.uart');
Uart.Settings.socType = socType;
/* Load the I2C package */
var I2c = xdc.loadPackage('ti.drv.i2c');
I2c.Settings.socType = socType;
/* Load the SPI package */
var Spi = xdc.loadPackage('ti.drv.spi');
/* Load the Board package and set the board name */
var Board = xdc.loadPackage('ti.board');
Board.Settings.boardName = "idkAM572x";
/* ================ Cache and MMU configuration ================ */
var Cache1 = xdc.useModule('ti.sysbios.family.arm.a15.Cache');
var Mmu = xdc.useModule('ti.sysbios.family.arm.a15.Mmu');
/* Enable the cache */
Cache1.enableCache = true;
/* Enable the MMU (Required for L1 data caching) */
Mmu.enableMMU = true;
var attrs = new Mmu.DescriptorAttrs();
Mmu.initDescAttrsMeta(attrs);
attrs.type = Mmu.DescriptorType_BLOCK;
attrs.noExecute = true;
attrs.accPerm = 0; // R/W at PL1
attrs.attrIndx = 4; // Use MAIR0 Byte2
Mmu.setMAIRMeta(4, 0x04);
Mmu.setSecondLevelDescMeta(0x43200000, 0x43200000, attrs);
/* Set IO Delay configuration areas as non-cache */
attrs.attrIndx = 1;
Mmu.setSecondLevelDescMeta(0x4844a000, 0x4844a000, attrs);
Mmu.setSecondLevelDescMeta(0x4ae07d00, 0x4ae07d00, attrs);
/* Adding for GPMC setting */
var peripheralAttrs = new Mmu.DescriptorAttrs();
Mmu.initDescAttrsMeta(peripheralAttrs);
peripheralAttrs.type = Mmu.DescriptorType_BLOCK;
peripheralAttrs.shareable = 2;
peripheralAttrs.noExecute = true;
peripheralAttrs.accPerm = 0;
peripheralAttrs.attrIndx = 1; // level1 is 1GB area
/* Define the base address of the 1 Meg page the peripheral resieds in. */
var gpmcConfigBaseAddr = 0x50000000;
/* Configure the corresponding MMU page descriptor accordingly */
Mmu.setSecondLevelDescMeta(gpmcConfigBaseAddr,
gpmcConfigBaseAddr,
peripheralAttrs);
var gpmcAttrs = new Mmu.DescriptorAttrs();
Mmu.initDescAttrsMeta(gpmcAttrs);
gpmcAttrs.type = Mmu.DescriptorType_BLOCK;
gpmcAttrs.shareable = 2;
gpmcAttrs.noExecute = true;
gpmcAttrs.accPerm = 0;
gpmcAttrs.attrIndx = 1; // level2: 2MB area (level1 is 1GB area)
var gpmcBaseAddr = 0x08000000;
Mmu.setSecondLevelDescMeta(gpmcBaseAddr,
gpmcBaseAddr,
gpmcAttrs);
/* ================ Memory sections configuration ================ */
Program.sectMap["BOARD_IO_DELAY_DATA"] = "OCMC_RAM1";
Program.sectMap["BOARD_IO_DELAY_CODE"] = "OCMC_RAM1";
