Part Number: TDA4VM
Is there support for the MMU/MPU on ARM R5F core on TDA4 under TI-RTOS/SysBios?
Does TI-RTOS provides means for memory protection?
Milena
Hi Milena,
There is support for MPU for the R5F core in SYSBIOS.
Take the example of udma_memcpy_testapp for instance:
Source code: <SDK_PATH>/pdk_jacinto_xx_xx_xx_xx/packages/ti/drv/udma/examples/udma_memcpy_test/*
SYSBIOS config file: <SDK_PATH>/pdk_jacinto_xx_xx_xx_xx/packages/ti/build/j721e/sysbios_r5.cfg
MPU config file: <SDK_PATH>/pdk_jacinto_xx_xx_xx_xx/packages/ti/build/j721e/r5_mpu.xs
The MPU config file gets consumed as a part of the SYSBIOS config file and that is what programs the MPU as a part of the SYSBIOS startup code.
Karan
Hi Karan,
Thanks for fast reply.
Where can I find more documentation about MPU and its usage?
Milena
Hi Milena,
Milena Milosevic said:Where can I find more documentation about MPU and its usage?
That would be the R5F TRM Chapter MPU on ARM's website - https://developer.arm.com/documentation/ddi0460/c/Memory-Protection-Unit
Karan
