Can EMIFA be used for the LCD controller frame buffer access? I would like to reduce the burden on the bus caused by the frame buffer transfers. Assuming the DDR2/mDDR interface is used for all run-time memory will using EMIFA for the frame buffer transfers reduce the burden on the CPU/BUS? Again assume there is no other memory on the EMIFA.
Chris
