TILD build error
Facing below issue while build  TIDL as i made changes to the Post_Pro and Pre_Proc.
Please let me know if i am missing some thing.
@laptopU:~/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11$ make TARGET_PLATFORM=PC
======== MAKING IMPORT TOOL PROTOS LIB =================
make -C ./ti_dl/utils/tidlModelImport -f makefile_lib
make[1]: Entering directory '/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/utils/tidlModelImport'
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/device_attributes.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/types.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/node_def.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/op_def.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/cost_graph.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/allocation_description.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/attr_value.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/kernel_def.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/graph.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/function.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/log_memory.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/tensor_shape.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/versions.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/tensor_slice.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/tensor_description.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/variable.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/step_stats.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/summary.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/resource_handle.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/tensor.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../onnxImport/onnx_cc/onnx/onnx-operators-ml.proto3.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../onnxImport/onnx_cc/onnx/onnx-ml.proto3.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/faster_rcnn.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/matcher.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/graph_rewriter.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/faster_rcnn_box_coder.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/losses.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/ssd_anchor_generator.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/anchor_generator.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/square_box_coder.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/argmax_matcher.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/bipartite_matcher.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/box_coder.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/grid_anchor_generator.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/image_resizer.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/model.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/input_reader.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/box_predictor.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/post_processing.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/multiscale_anchor_generator.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/train.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/preprocessor.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/mean_stddev_box_coder.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/ssd.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/region_similarity_calculator.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/optimizer.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/string_int_label_map.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/pipeline.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/keypoint_box_coder.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/hyperparams.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/models_research_cc/object_detection/protos/eval.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../caffeImport/caffe.pb.obj
r - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/utils/tidlModelImport/../tidlMetaArch/tidl_meta_arch.pb.obj
make[1]: Leaving directory '/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/utils/tidlModelImport'
======== MAKING IMPORT LIBS =================
make -C ./ti_dl/utils/tidlModelImport -f makefile_shared
compiling ../../custom/tidl_custom_import.c
compiling tidl_import_core.cpp
compiling tidl_import_common.cpp
compiling tidl_import_common_model_check.cpp
compiling tidl_onnxImport.cpp
compiling tidl_tfImport.cpp
compiling tidl_caffeImport_v2.cpp
compiling tidl_caffeImport_param.cpp
compiling tidl_tfMetaArchImport.cpp
compiling tidl_tfLiteImport.cpp
compiling tidl_metaArchImport.cpp
======== MAKING IMPORT TOOL =================
make -C ./ti_dl/utils/tidlModelImport -f makefile_bin
compiling ../../../common/configparser.c
compiling tidl_import_main.cpp
compiling tidl_import_config.cpp
======== MAKING CUSTOM LIB here =================
make -C ./ti_dl/custom -f makefile
make[1]: Entering directory '/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/custom'
compiling tidl_custom.c
compiling tidl_custom_maxpooling.c
compiling tidsp/tidl_custom_maxpool_ixX_oxX.c
compiling tidsp/tidl_custom_maxpool_ixX_oxX_c7x.c
compiling tidsp/tidl_custom_maxpool_ixX_oxX_cn.c
/usr/bin/ar: creating ../lib/PC/dsp/algo/release/libtidl_custom.a
a - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/custom/tidl_custom.obj
a - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/custom/tidl_custom_maxpooling.obj
a - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/custom/./tidsp/tidl_custom_maxpool_ixX_oxX.obj
a - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/custom/./tidsp/tidl_custom_maxpool_ixX_oxX_c7x.obj
a - /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/out/PC/dsp/algo/release/ti_dl/custom/./tidsp/tidl_custom_maxpool_ixX_oxX_cn.obj
make[1]: Leaving directory '/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/custom'
======== MAKING TIDL ALGO =================
======== PRINITING =================
make -C ./ti_dl/algo -f makefile
make[1]: Entering directory '/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/algo'
======== tidl ALGO SANDEEP =================
======== PRINITING all SANDEEP =============
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/pdk_jacinto_07_01_00_45/packages
make[1]: Leaving directory '/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/algo'
======== MAKING TIDL TEST =================
make -C ./ti_dl/test -f makefile final_install
make[1]: Entering directory '/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test'
SHELL=/bin/sh
TARGET_MAKEFILES=src/dsp_sdk/concerto.mak src/pc_linux/concerto.mak src/pc_windows/concerto.mak
Keep only PC platform in TARGET_COMBOS
undefined TIARMCGT_ROOT=
undefined GCC_SYSBIOS_ARM_ROOT=
undefined CGT6X_ROOT=
file CGT7X_ROOT="/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/ti-cgt-c7000_1.4.0.LTS"
undefined GCC_WINDOWS_ROOT=
file GCC_LINUX_ROOT=/usr
undefined GCC_QNX_ROOT=
TARGET_COMBO=PC:LINUX:x86_64:1:release:GCC_LINUX
HOST_ROOT=/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test
HOST_COMPILER=GCC_LINUX
HOST_PLATFORM=PC
HOST_OS=LINUX
HOST_CPU=x86_64
HOST_ARCH=64
HOST_FAMILY=x86_64
HOST_NUM_CORES=8
TARGET_OS=LINUX
TARGET_CPU=x86_64
TARGET_ARCH=64
TARGET_FAMILY=x86_64
TARGET_NUM_CORES=1
TARGET_PLATFORM=PC
TARGET_BUILD=release
TARGET_OUT=/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/out/PC/x86_64/LINUX/release
TARGET_DOC=/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/out/PC/x86_64/LINUX/release/docs
BUILD_DEFS =
PC_LINUX_x86_64_1_release_GCC_LINUX_DEFS = LINUX PC x86_64="x86_64" TARGET_NUM_CORES=1 TARGET_ARCH=64 ARCH_64 TARGET_BUILD=1
PC_LINUX_x86_64_1_release_GCC_LINUX_LDIRS =
SCM_ROOT=
SCM_VERSION=
[GCC] Compiling C99 main.c
cc1plus: warning: command line option ‘-std=c99’ is valid for C/ObjC but not for C++
[GCC] Compiling C99 tidl_tb.c
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb.c: In function ‘void splitCommandLineToArgv(int8_t*, int32_t*, int8_t***)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb.c:119:38: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
   while(res = strtok((char *)str, " "))
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb.c: In function ‘int32_t tidlMultiInstanceTest(int8_t**, int32_t, void*, int32_t, char**, int32_t)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb.c:502:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
           for (i0 = 0; i0 < params->totNumClasses; i0++)
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb.c:504:29: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
             for (i1 = 0; i1 < params->totNumClasses; i1++)
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb.c:528:24: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
           for(j = 0; j < gIOParams.numInputBuf; j++)
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb.c:533:24: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
           for(j = 0; j < gIOParams.numOutputBuf; j++)
[GCC] Compiling C99 tidl_rt.c
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_rt.c: In function ‘int32_t TIDLRT_create(sTIDLRT_Params_t*, void**)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_rt.c:685:35: warning: converting to non-pointer type ‘int32_t {aka int}’ from NULL [-Wconversion-null]
     createPrms->net->dataFlowInfo = NULL;
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_rt.c: In function ‘int32_t TIDLRT_invoke(void*, sTIDLRT_Tensor_t**, sTIDLRT_Tensor_t**)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_rt.c:803:18: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
     for(i = 0; i < inBufs.numBufs; i++)
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_rt.c:807:18: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
     for(i = 0; i < outBufs.numBufs; i++)
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_rt.c: In function ‘void tidl_copyRTTensorToInBufs(sTIDL_Network_t*, sTIDL_IOBufDesc_t*, sTIDLRT_Tensor_t**, IVISION_BufDesc*)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_rt.c:487:27: warning: ‘data’ may be used uninitialized in this function [-Wmaybe-uninitialized]
             data = ((data - zp)/inScale) * scale;
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_rt.c: In function ‘void tidl_copyOutBufsToRTTensor(sTIDL_IOBufDesc_t*, sTIDLRT_Tensor_t**, IVISION_BufDesc*, float*)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_rt.c:583:27: warning: ‘data’ may be used uninitialized in this function [-Wmaybe-uninitialized]
             data = (((data/scales[i]) * outScale) + zp);
[GCC] Compiling C99 tidl_tb_utils.c
In file included from /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c:88:0:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/pdk_jacinto_07_01_00_45/packages/ti/drv/udma/udma.h: In function ‘void* Udma_defaultPhyToVirtFxn(uint64_t, uint32_t, void*)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/pdk_jacinto_07_01_00_45/packages/ti/drv/udma/udma.h:402:22: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
     return ((void *) temp);
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c: In function ‘int32_t tidl_NetOutputPostproc(tidl_net_config*, sTIDL_IOBufDesc_t*, sTIDLRT_Tensor_t**, int32_t)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c:1227:12: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       if(i == params->postProcDataId)
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c: In function ‘int tidl_tb_printf(int, const char*, ...)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c:1373:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
   if(traceLevel <= gParams.debugTraceLevel)
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c: In function ‘int32_t getNumberOfLinesIntheFile(char*)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c:319:45: warning: ignoring return value of ‘char* fgets(char*, int, FILE*)’, declared with attribute warn_unused_result [-Wunused-result]
     fgets(line, TIDL_CFG_MAX_LINE_SIZE, fp1);
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c: In function ‘int32_t getConfigFileNamesList(char*, int32_t*, int8_t**)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c:382:45: warning: ignoring return value of ‘char* fgets(char*, int, FILE*)’, declared with attribute warn_unused_result [-Wunused-result]
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c: In function ‘int32_t tidl_tb_ReadBinFromFile(const char*, void*, int32_t)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c:935:31: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result [-Wunused-result]
     FREAD(addr, size, 1, fptr);
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c: In function ‘int32_t tidl_CompareNetOutputMem(tidl_net_config*, sTIDL_IOBufDesc_t*, sTIDLRT_Tensor_t**)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_tb_utils.c:1177:48: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result [-Wunused-result]
     FREAD(readPtr, 1, readSize, refCompareFile);
[GCC] Compiling C99 tidl_config.c
[GCC] Compiling C99 tidl_image_postproc.c
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c: In function ‘int32_t writeOutImage(uint8_t*, uint8_t*, uint8_t*, uint8_t*, int32_t, int32_t)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c:179:11: warning: unused variable ‘i’ [-Wunused-variable]
   int32_t i, j;
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c:179:14: warning: unused variable ‘j’ [-Wunused-variable]
   int32_t i, j;
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c: In function ‘void APP_drawBoldBoxRGB(uint8_t*, uint8_t*, uint8_t*, uint32_t, int16_t, int16_t, int16_t, int16_t, int16_t, int16_t, uint32_t)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c:528:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
   for (i = 0; i < lineThickNess; i++)
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c: In function ‘int32_t tidl_tb_postProc(int32_t, int32_t, int32_t, int32_t, void*, int32_t)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c:1032:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         if ((segValue < gParams.totNumClasses) && (gtData[i] < gParams.totNumClasses))
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c:1045:29: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       for (label = 0; label < gParams.totNumClasses; label++)
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c:1049:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         for (j = 0; j < gParams.totNumClasses; j++)
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c:1054:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c: In function ‘float TIDL_findMax(void*, int32_t, int32_t)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c:574:5: warning: ‘data’ may be used uninitialized in this function [-Wmaybe-uninitialized]
     if(data > max)
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_postproc.c:1032:23: warning: ‘segValue’ may be used uninitialized in this function [-Wmaybe-uninitialized]
[GCC] Compiling C99 tidl_image_preproc.c
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_preproc.c: In function ‘int32_t readResizeCrop(uint8_t*, uint8_t*, int32_t, int32_t, int32_t, int32_t, int32_t, int32_t, int32_t)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_preproc.c:160:11: warning: unused variable ‘imreadChannels’ [-Wunused-variable]
   int32_t imreadChannels = image.channels();
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_preproc.c: In function ‘int32_t readImage(uint8_t*, void*, int32_t, int16_t, int16_t, int16_t, int16_t, int16_t, int32_t, int32_t, int32_t, int32_t, int32_t)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_preproc.c:248:94: warning: ' ' flag used with ‘%p’ gnu_printf format [-Wformat=]
      offset, roi, n, width, height, pitch, chOffset, frameCount, inBufIdx, type, inResizeMode);
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_preproc.c:248:94: warning: format ‘%p’ expects argument of type ‘void*’, but argument 6 has type ‘int’ [-Wformat=]
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_preproc.c:279:15: warning: unused variable ‘freadStatus’ [-Wunused-variable]
       int32_t freadStatus = fread(meanImgae, 1, (width*height*n*sizeof(float)), fptr);
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_preproc.c:311:136: warning: ‘meanImgae’ may be used uninitialized in this function [-Wmaybe-uninitialized]
          in = data[i2*n*width*height + i0*width*height + i1*width + i3] - meanImgae[i2*n*width*height + i0*width*height + i1*width + i3];
[GCC] Compiling C99 tidl_image_read_write.c
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_read_write.c: In function ‘uint8_t* tidl_loadBMP(const char*, int32_t*, int32_t*)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_read_write.c:120:66: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result [-Wunused-result]
       FREAD(bmHeader, sizeof(uint8_t), sizeof(tidl_bmpHeader), f);
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../tidl_image_read_write.c:125:52: warning: ignoring return value of ‘size_t fread(void*, size_t, size_t, FILE*)’, declared with attribute warn_unused_result [-Wunused-result]
       FREAD(pixels, sizeof(unsigned char), size, f);
[GCC] Compiling C99 ti_draw_utils.c
[GCC] Compiling C99 ti_mem_manager.c
[GCC] Compiling C99 configparser.c
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../../../../common/configparser.c: In function ‘bool convertDirectInt(char*, int*, char**)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../../../../common/configparser.c:144:18: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
   if(n == 1 && c == strlen(arg))
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../../../../common/configparser.c: In function ‘bool convertDirectFloat(char*, float*, char**)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../../../../common/configparser.c:157:18: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../../../../common/configparser.c: In function ‘int readparamfile(char*, sTokenMapping*)’:
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../../../../common/configparser.c:636:11: warning: unused variable ‘freadStatus’ [-Wunused-variable]
   int32_t freadStatus =  FREAD (fileBuffer, 1, fileSize, fConfigFile);
Required system library libtidl_custom.a
Required system library libtidl_algo.a
Required system library libtidl_obj_algo.a
Required system library libtidl_priv_algo.a
Required system library libmmalib_cn_x86_64.a
Required system library libmmalib_x86_64.a
Required system library libcommon_x86_64.a
Required system library libC7100-host-emulation.a
Required system library libopencv_imgproc.a
Required system library libopencv_imgcodecs.a
Required system library libopencv_core.a
Required system library liblibtiff.a
Required system library liblibwebp.a
Required system library liblibpng.a
Required system library liblibjpeg.a
Required system library libIlmImf.a
Required system library libzlib.a
Required system library liblibjasper.a
Required system library libdl.so
Linking /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/out/PC/x86_64/LINUX/release/PC_dsp_test_dl_algo.out
/usr/bin/ld: cannot find -ltidl_algo
collect2: error: ld returned 1 exit status
/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/vision_apps/concerto/finale.mak:208: recipe for target '/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/out/PC/x86_64/LINUX/release/PC_dsp_test_dl_algo.out' failed
make[1]: [/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/out/PC/x86_64/LINUX/release/PC_dsp_test_dl_algo.out] Error 1 (ignored)
Copying built libraries: /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/out/PC/x86_64/LINUX/release to /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/lib/PC/x86_64/LINUX/release
Copying built libraries: /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/out/PC/x86_64/LINUX/release/PC_dsp_test_dl_algo.out to /home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/src/pc_linux/../..
cp: cannot stat '/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test/out/PC/x86_64/LINUX/release/PC_dsp_test_dl_algo.out': No such file or directory
makefile:58: recipe for target 'final_install' failed
make[1]: [final_install] Error 1 (ignored)
make[1]: Leaving directory '/home/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/tidl_j7_01_03_00_11/ti_dl/test'
