We have received several J721e based custom boards from the factory. I was able to flash the firmware in several boards over USB using "dfu-util" and the board is booting up fine from eMMC.
We have one single board where I can flash "tiboot3.bin" & "sysfw.itb" but after this I don't see any output from "sudo dfu-util -l". That means I can't flash the rest of the bootloader. Here is the log -
slaldas@daimler:~$ sudo dfu-util -R -a bootloader -D /home/slaldas/nova_slot5/build/arago-tmp-external-arm-glibc/deploy/images/nova-slot5/tiboot3.bin dfu-util 0.9 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2016 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to sourceforge.net/.../ dfu-util: Invalid DFU suffix signature dfu-util: A valid DFU suffix will be required in a future dfu-util release!!! Opening DFU capable USB device... ID 0451:6163 Run-time device DFU version 0110 Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing DFU mode device DFU version 0110 Device returned transfer size 512 Copying data from PC to DFU device Download [=========================] 100% 229546 bytes Download done. state(6) = dfuMANIFEST-SYNC, status(0) = No error condition is present state(2) = dfuIDLE, status(0) = No error condition is present Done! dfu-util: can't detach Resetting USB to switch back to runtime mode slaldas@daimler:~$ slaldas@daimler:~$ sudo dfu-util -l dfu-util 0.9 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2016 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to sourceforge.net/.../ Found DFU: [0451:6163] ver=0224, devnum=68, cfg=1, intf=0, path="1-3.2", alt=0, name="sysfw.itb", serial="UNKNOWN" slaldas@daimler:~$ slaldas@daimler:~$ sudo dfu-util -R -a sysfw.itb -D /home/slaldas/nova_slot5/build/arago-tmp-external-arm-glibc/deploy/images/nova-slot5/sysfw.itb dfu-util 0.9 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2016 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to sourceforge.net/.../ dfu-util: Invalid DFU suffix signature dfu-util: A valid DFU suffix will be required in a future dfu-util release!!! Opening DFU capable USB device... ID 0451:6163 Run-time device DFU version 0110 Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing DFU mode device DFU version 0110 Device returned transfer size 4096 Copying data from PC to DFU device Download [=========================] 100% 268410 bytes Download done. state(7) = dfuMANIFEST, status(0) = No error condition is present state(2) = dfuIDLE, status(0) = No error condition is present Done! Resetting USB to switch back to runtime mode slaldas@daimler:~$ slaldas@daimler:~$ sudo dfu-util -l dfu-util 0.9 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2016 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to sourceforge.net/.../
Could you please let me know how to debug this issue?
Satish
