could you tell me following background knowledge? Could you please explain?
(1)
What's "scratchpad use"? (cf. 5.1.3.1.10 Scrachpad Registers in TRM)
(I don't know what scratchpad use is in the first place.)
(2)
As for Boot mode configuration by SPI,
what is the difference between "SPI without PLL Boot Device Configuration" and "SPI with PLL Boot Device Configuration"?
(cf. Figure 4-7 and Figure 4-8 in TRM)
Although I am supposed to use SPI Flash memory boot, I don't know how BOOTMODE Pin should be set
becasue I don't know the difference between "SPI without PLL Boot Device Configuration" and "SPI with PLL Boot Device Configuration."
(3)
As for Device Memory Map for DDR_0_DATA in TRM,
what is IO coherency? (Could you please explain the difference between "2G area(00 8000 0000--00 FFFF FFFF)" and "8G area(08 0000 0000--09 FFFF FFFF)"?)
Regards.
