Part Number: AM5728
The customer is using AM5728 @1176MHz on OPP_OD. They want a little more higher performance, but they don't want much higher heat up by 1500MHz.
Therefore, they’re considering to clock up just a little to 1200MHz on OPP_HIGH.
Is it possible ? I think it’s possible, but I’m not sure if 1200MHz frequency can be created by the combination of some PLL dividers and multipliers. If so, around 1200MHz would be OK.
If it’s possible to clock up, could you tell them which registers they should set ?
Thanks and regards,
Hideaki
