Part Number: TDA2EG-17
Hi,Ti expert
I used the PROCESSOR_SDK_VISION_03_08_00_00 package on my own board. When I applied the early boot patch "earlyboot-lateattach-patches" in the package,
I found the following two problems:
1. After entering the linux system, I used dmesg to view the kernel output information and found that when the omap_remoteproc.ko module was loaded, the kernel had a warning message output;
2. When using the following command to test the read and write speed of emmc, it will exit halfway and the system will freeze
$ time dd if=/dev/zero of=test.emmc bs=1M count=1024
[15:52:26][2021-03-01_15:52:26] [15:52:28]cd /opt/vision_sdk/ [15:52:30]root@dra7xx-evm:/opt/vision_sdk# ./lh_avm_board_conf.sh [15:52:30]----------------------------------- [15:52:30] start set Peripherals [15:52:30]----------------------------------- [15:52:30]set serdes max96708 [15:52:30]get max96708 reg 0x07 val: [15:52:30]0x02 [15:52:30]0x02 [15:52:30]0x02 [15:52:30]0x02 [15:52:30]set max96708 reg 0x07 val for 0x86 [15:52:30]get max96708 reg 0x07 val: [15:52:30]0x86 [15:52:30]0x86 [15:52:30]0x86 [15:52:30]0x86 [15:52:30]set lvds 921 [15:52:30]set display chip 921 register [15:52:33]root@dra7xx-evm:/opt/vision_sdk# ./apps.out [15:52:33] ASSERT (osa_mem.c|OSA_memInit|601) [15:52:35]^C [15:52:37]root@dra7xx-evm:/opt/vision_sdk# ./vision_sdk_load.sh [15:52:37]insmod: ERROR: could not load module ./bin/cmemk.ko: No such file or directory [15:52:37]Error: I2C Read failed [15:52:37]Error: I2C Read failed [15:52:37]Error: I2C Read failed [15:52:37]Error: I2C Read failed [15:52:37]./disableDssInterruptsOnA15.sh: line 11: @0x4A002AEC:: command not found [15:52:37]./disableDssInterruptsOnA15.sh: line 12: @0x4A002AEC:: command not found [15:52:37]./disableDssInterruptsOnA15.sh: line 13: @0x4A002AEC:: command not found [15:52:37]./disableDssInterruptsOnA15.sh: line 14: @0x4A002AEC:: command not found [15:52:37]./disableDssInterruptsOnA15.sh: line 15: @0x4A002AEC:: command not found [15:52:37]./disableDssInterruptsOnA15.sh: line 16: @0x4A002AEC:: command not found [15:52:37]./disableDssInterruptsOnA15.sh: line 17: @0x4A002AEC:: command not found [15:52:37]./disableDssInterruptsOnA15.sh: line 18: @0x4A002AEC:: command not found [15:52:37]./disableDssInterruptsOnA15.sh: line 19: @0x4A002AEC:: command not found [15:52:37]updated 0x4A002AEC value is 002F0000 [15:52:39]root@dra7xx-evm:/opt/vision_sdk# ./apps.out [15:52:39] [HOST] OSA: MEM: 0: Mapped 0xa0100000 to 0xb6928000 of size 0x00100000 [15:52:39] [HOST] OSA: MEM: 1: Mapped 0x84203000 to 0xa6f28000 of size 0x0fa00000 [15:52:39] [HOST] OSA: MEM: 2: Mapped 0xa0200000 to 0xa6e68000 of size 0x00040000 [15:52:39] [HOST] OSA: MEM: 3: Mapped 0xa02c0000 to 0xa6ea8000 of size 0x00080000 [15:52:39] [HOST] OSA: MEM: 4: Mapped 0x00000000 to 0x00000000 of size 0x00000000 [15:52:39] [HOST] OSA: HOST Remote Log Shared Memory @ 0xa024f140 [15:52:39] [HOST] OSA: DSP1 Remote Log Shared Memory @ 0xa02769e0 [15:52:39] [HOST] OSA: IPU2 Remote Log Shared Memory @ 0xa0363da0 [15:52:39] [HOST] [HOST ] 60.341060 s: SYSTEM: System A15 Init in progress [system_common.c]!!! [15:52:39] [HOST] [HOST ] 60.341212 s: SYSTEM: IPC: Init in progress in hlos!!! [15:52:39] [HOST] [HOST ] 60.341212 s: SYSTEM: IPC: Notify init in progress !!! [15:52:39] [HOST] [HOST ] 60.341304 s: SYSTEM: IPC: [IPU2] socket bind success !!! (dst vproc = 1, endpt = 81) [15:52:39] [HOST] [HOST ] 60.341334 s: SYSTEM: IPC: [IPU2] socket info (family = 45, dst proc id = -1, endpt = 81) !!! [15:52:39] [HOST] [HOST ] 60.341365 s: SYSTEM: IPC: [IPU2] socket connect success !!! (dst vproc = 1, endpt = 80) [15:52:39] [HOST] [HOST ] 60.341365 s: SYSTEM: IPC: [IPU2] socket info (family = 45, dst proc id = -1, endpt = 1024) !!! [15:52:39] [HOST] [HOST ] 60.341395 s: SYSTEM: IPC: [DSP1] socket bind success !!! (dst vproc = 2, endpt = 81) [15:52:39] [HOST] [HOST ] 60.341395 s: SYSTEM: IPC: [DSP1] socket info (family = 45, dst proc id = -1, endpt = 81) !!! [15:52:39] [HOST] [HOST ] 60.341426 s: SYSTEM: IPC: [DSP1] socket connect success !!! (dst vproc = 2, endpt = 80) [15:52:39] [HOST] [HOST ] 60.341456 s: SYSTEM: IPC: [DSP1] socket info (family = 45, dst proc id = -1, endpt = 1024) !!! [15:52:39] [HOST] [HOST ] 60.341609 s: SYSTEM: IPC: Notify init DONE !!! [15:52:39] [HOST] [HOST ] 60.341639 s: SYSTEM: MSGQ: MsgQ init in progress !!! [15:52:39] [HOST] [HOST ] 60.341761 s: [system_ipc_msgq.c|System_ipcMsgQTskMain:136] [15:52:39] [HOST] [HOST ] 60.341792 s: SYSTEM: MSGQ: MsgQ init DONE !!! [15:52:39] [HOST] [HOST ] 60.341792 s: SYSTEM: IPC: Init DONE !!! [15:52:39] [HOST] [HOST ] 60.341792 s: SYSTEM: Initializing A15 Links!!! [15:52:39] [HOST] [HOST ] 60.341792 s: [system_common.c|System_initLinks:454] hlos_system [15:52:39] [HOST] [HOST ] 60.341944 s: IPC_OUT_0 : Init done - linkid-0x2000000 [15:52:39] [HOST] [HOST ] 60.342097 s: IPC_OUT_1 : Init done - linkid-0x2000001 [15:52:39] [HOST] [HOST ] 60.342249 s: IPC_OUT_2 : Init done - linkid-0x2000002 [15:52:39] [HOST] [HOST ] 60.342371 s: IPC_OUT_3 : Init done - linkid-0x2000003 [15:52:39] [HOST] [HOST ] 60.342524 s: IPC_OUT_4 : Init done - linkid-0x2000004 [15:52:39] [HOST] [HOST ] 60.342676 s: IPC_IN_0 : Init done - linkid-0x200000a [15:52:39] [HOST] [HOST ] 60.342859 s: IPC_IN_1 : Init done - linkid-0x200000b [15:52:39] [HOST] [HOST ] 60.342981 s: IPC_IN_2 : Init done - linkid-0x200000c [15:52:39] [HOST] [HOST ] 60.343134 s: IPC_IN_3 : Init done - linkid-0x200000d [15:52:39] [HOST] [HOST ] 60.343317 s: IPC_IN_4 : Init done - linkid-0x200000e [15:52:39] [HOST] [HOST ] 60.343469 s: IPC_IN_5 : Init done - linkid-0x200000f [15:52:39] [HOST] [HOST ] 60.343591 s: IPC_IN_6 : Init done - linkid-0x2000010 [15:52:39] [HOST] [HOST ] 60.343744 s: NULL_0 : Init done - linkid-0x2000014 [15:52:39] [HOST] [HOST ] 60.343866 s: NULL_1 : Init done - linkid-0x2000015 [15:52:39] [HOST] [HOST ] 60.344079 s: NULL_SRC_0 : Init done - linkid-0x2000039 [15:52:39] [HOST] [HOST ] 60.344262 s: DISP_DIST_SRC_0 : Init done - linkid-0x2000066 [15:52:39] [HOST] [HOST ] 60.344384 s: DISP_DIST_SRC_1 : Init done - linkid-0x2000067 [15:52:39] [HOST] [HOST ] 60.344537 s: DISP_DIST_SRC_2 : Init done - linkid-0x2000068 [15:52:39] [HOST] [HOST ] 60.344659 s: DISP_DIST_SRC_3 : Init done - linkid-0x2000069 [15:52:39] [HOST] [HOST ] 60.344659 s: [system_common.c|System_initLinks:469] hlos_system [15:52:39] [HOST] [HOST ] 60.344842 s: ALGORITHM_0 : Init done - linkid-0x2000031 [15:52:39] [HOST] [HOST ] 60.344994 s: ALGORITHM_1 : Init done - linkid-0x2000032 [15:52:39] [HOST] [HOST ] 60.345147 s: ALGORITHM_2 : Init done - linkid-0x2000033 [15:52:39] [HOST] [HOST ] 60.345299 s: ALGORITHM_3 : Init done - linkid-0x2000034 [15:52:39] [HOST] [HOST ] 60.345452 s: ALGORITHM_4 : Init done - linkid-0x2000035 [15:52:39] [HOST] [HOST ] 60.345604 s: ALGORITHM_5 : Init done - linkid-0x2000036 [15:52:39] [HOST] [HOST ] 60.345757 s: ALGORITHM_6 : Init done - linkid-0x2000037 [15:52:39] [HOST] [HOST ] 60.345909 s: ALGORITHM_7 : Init done - linkid-0x2000038 [15:52:39] [HOST] [HOST ] 60.346123 s: DUP0 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.346367 s: DUP1 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.346580 s: DUP2 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.346824 s: DUP3 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.347007 s: DUP4 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.347190 s: SYNC_0 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.347343 s: SYNC_1 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.347526 s: SYNC_2 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.347770 s: SYNC_3 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.347922 s: MERGE_0 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.348105 s: MERGE_1 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.348258 s: MERGE_2 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.348441 s: MERGE_3 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.348593 s: MERGE_4 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.348746 s: SELECT_0 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.348929 s: SELECT_1 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.349081 s: GATE_0 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.349203 s: GATE_1 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.349325 s: GATE_2 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.349447 s: GATE_3 : Init done - linkid-0x0 [15:52:39] [HOST] [HOST ] 60.349600 s: SGXFRMCPY_0 : Init done - linkid-0x200004a [15:52:39] [HOST] [HOST ] 60.349630 s: SYSTEM: Initializing A15 Links ... DONE !!! [15:52:39] [HOST] [HOST ] 60.349630 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:39] [HOST] [HOST ] 60.350027 s: OSA: Adjusting global time, timeH by 0 units!!! [15:52:39] [HOST] [HOST ] 60.350027 s: SYSTEM: System A15 Init Done !!! [15:52:39] [HOST] [HOST ] 60.350179 s: NETWORK_CTRL: Starting Server (port=5000) !!! [15:52:39] [HOST] [HOST ] 60.350240 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!! [15:52:39] [HOST] [HOST ] 60.350820 s: [chains_main.c|265] [15:52:39] [HOST] [HOST ] 60.350820 s: [chains_main.c|272] [15:52:39] [HOST] [HOST ] 60.350850 s: [chains_common.c|ChainsCommon_appCtrlCommonInit:290] [15:52:39] [HOST] [HOST ] 60.350850 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:39] [HOST] [HOST ] 60.352162 s: [chains_common.c|ChainsCommon_appCtrlCommonInit:299] [15:52:39] [HOST] [HOST ] 60.352162 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:39] [HOST] [HOST ] 60.353718 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:39] [HOST] [HOST ] 60.354206 s: [chains_main.c|290] [15:52:39] [HOST] [HOST ] 60.354236 s: chains.h Chains_Ctrl_Init ----------------->1 [15:52:39] [HOST] [DSP1 ] 0.777343 s: ***** DSP1 Firmware build time 15:40:53 Feb 27 2021 [15:52:39] [HOST] [DSP1 ] 0.777404 s: [src/main_common_c6xdsp1.c|189] run here --->1 [15:52:39] [HOST] [DSP1 ] 0.777435 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 600000000 Hz> [15:52:39] [HOST] [DSP1 ] 0.777496 s: [system_common.c:759] System_start [15:52:39] [HOST] [DSP1 ] 0.777618 s: [system_common.c:777] System_start [15:52:39] [HOST] [DSP1 ] 0.777679 s: SYSTEM: System Common Init in progress !!! [15:52:39] [HOST] [DSP1 ] 0.777770 s: SYSTEM: IPC init in progress in rtos!!! [15:52:39] [HOST] [DSP1 ] 0.777801 s: SYSTEM: Attaching to [IPU2] ... [15:52:39] [HOST] [DSP1 ] 0.800829 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [15:52:40] [HOST] [DSP1 ] 0.800890 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [15:52:40] [HOST] [DSP1 ] 0.800921 s: SYSTEM: Notify init done !!! [15:52:40] [HOST] [DSP1 ] 0.801043 s: [system_ipc_msgq.c|System_ipcMsgQTaskMain:306] [15:52:40] [HOST] [DSP1 ] 0.801073 s: SYSTEM: MsgQ init done !!! [15:52:40] [HOST] [DSP1 ] 0.801165 s: RpmsgInit in progress... [15:52:40] [HOST] [DSP1 ] 0.801195 s: SYSTEM: IPC init DONE !!! [15:52:40] [HOST] [DSP1 ] 0.801836 s: SYSTEM: System Common Init Done !!! [15:52:40] [HOST] [DSP1 ] 0.801866 s: SYSTEM: System DSP Init in progress [system_c6xdsp.c]!!! [15:52:40] [HOST] [DSP1 ] 0.802049 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [15:52:40] [HOST] [DSP1 ] 0.802110 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [15:52:40] [HOST] [DSP1 ] 0.802141 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 522072 B (509 KB) [15:52:40] [HOST] [DSP1 ] 0.802171 s: SYSTEM: Initializing Links !!! [15:52:40] [HOST] [DSP1 ] 0.802202 s: [system_initDeinitLinks.c|System_initLinks:186] [15:52:40] [HOST] [DSP1 ] 0.809857 s: SYSTEM: Initializing Links ..i DONE !!! [15:52:40] [HOST] [DSP1 ] 0.809888 s: [system_initDeinitLinks.c|System_initLinks:301] [15:52:40] [HOST] [DSP1 ] 0.809918 s: SYSTEM: System DSP Init Done !!! [15:52:40] [HOST] [DSP1 ] 1.118678 s: [system_common.c:613] System_main --->1 [15:52:40] [HOST] [DSP1 ] 1.118709 s: [system_common.c:637] System_main --->4 [15:52:40] [HOST] [DSP1 ] 1.118739 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!! [15:52:40] [HOST] [DSP1 ] 1.118770 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!! [15:52:40] [HOST] [DSP1 ] 9.220917 s: Connection established with HLOS, calling rpmsgInit [15:52:40] [HOST] [IPU2 ] 0.755078 s: [src/main_common_ipu2.c|562] ---->4 [15:52:40] [HOST] [IPU2 ] 0.784084 s: ***** IPU2 Firmware build time 11:51:53 Mar 1 2021 [15:52:40] [HOST] [IPU2 ] 0.784206 s: [src/main_common_ipu2.c|569] ---->5 [15:52:40] [HOST] [IPU2 ] 0.784328 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz> [15:52:40] [HOST] [IPU2 ] 0.784450 s: [src/main_common_ipu2.c|main_common:612] [15:52:40] [HOST] [IPU2 ] 0.786128 s: [src/main_common_ipu2.c|625] ---->5-1 [15:52:40] [HOST] [IPU2 ] 0.786555 s: [system_common.c:759] System_start [15:52:40] [HOST] [IPU2 ] 0.788202 s: [system_common.c:777] System_start [15:52:40] [HOST] [IPU2 ] 0.789025 s: [src/main_common_ipu2.c|lh_cam_gpi_pwm:388] [15:52:40] [HOST] [IPU2 ] 0.789147 s: SYSTEM: System Common Init in progress !!! [15:52:40] [HOST] [IPU2 ] 0.798237 s: SYSTEM: IPC init in progress in rtos!!! [15:52:40] [HOST] [IPU2 ] 0.798328 s: SYSTEM: Attaching to [DSP1] ... [15:52:40] [HOST] [IPU2 ] 0.800829 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [15:52:40] [HOST] [IPU2 ] 0.800921 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [15:52:40] [HOST] [IPU2 ] 0.801073 s: SYSTEM: Notify init done !!! [15:52:40] [HOST] [IPU2 ] 0.802751 s: [system_ipc_msgq.c|System_ipcMsgQTaskMain:306] [15:52:40] [HOST] [IPU2 ] 0.802903 s: SYSTEM: MsgQ init done !!! [15:52:40] [HOST] [IPU2 ] 0.803818 s: RpmsgInit in progress... [15:52:40] [HOST] [IPU2 ] 0.803910 s: SYSTEM: IPC init DONE !!! [15:52:40] [HOST] [IPU2 ] 0.809034 s: SYSTEM: System Common Init Done !!! [15:52:40] [HOST] [IPU2 ] 0.809156 s: SYSTEM: System Init in progress [system_ipu1_0.c:158]!!! [15:52:40] [HOST] [IPU2 ] 0.809217 s: SYSTEM: BSP Common Init in progress !!! [15:52:40] [HOST] [IPU2 ] 0.809308 s: SYSTEM: BSP Common Init Done !!! [15:52:40] [HOST] [IPU2 ] 0.809369 s: SYSTEM: BSP Platform Init in progress !!! [15:52:40] [HOST] [IPU2 ] 0.809491 s: yancc in Bsp_platformInit--->1 [15:52:40] [HOST] [IPU2 ] 0.809552 s: yancc in Bsp_platformTda2xxInit--->6 [15:52:40] [HOST] [IPU2 ] 0.809644 s: yancc in Bsp_platformInit--->2 [15:52:40] [HOST] [IPU2 ] 0.809705 s: [system_bsp_init.c|System_bspInit:180] [15:52:40] [HOST] [IPU2 ] 0.809796 s: SYSTEM: BSP Platform Init Done !!! [15:52:40] [HOST] [IPU2 ] 0.809857 s: SYSTEM: FVID2 Init in progress !!! [15:52:40] [HOST] [IPU2 ] 0.809979 s: SYSTEM: FVID2 Init Done !!! [15:52:40] [HOST] [IPU2 ] 0.810040 s: SYSTEM: VPS Init in progress !!! [15:52:40] [HOST] [IPU2 ] 0.810101 s: [system_bsp_init.c|System_bspInit:298] [15:52:40] [HOST] [IPU2 ] 0.810162 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000] [15:52:40] [HOST] [IPU2 ] 0.810315 s: src/vpsdrv_init.c @ Line 227: [15:52:40] [HOST] [IPU2 ] 0.810406 s: vps_init in vpsdrv_init.c [15:52:40] [HOST] [IPU2 ] 0.812999 s: *** VPDMA Firmware Loading... *** [15:52:40] [HOST] [IPU2 ] 0.813121 s: VPDMA Firmware Address = 0xa03597c0 [15:52:40] [HOST] [IPU2 ] 0.813212 s: VPDMA Load Address = 0x4897d004 [15:52:40] [HOST] [IPU2 ] 0.813304 s: VPDMA Firmware Version = 0x4d0001b8 [15:52:40] [HOST] [IPU2 ] 0.813487 s: VPDMA List Busy Status = 0x00000000 [15:52:40] [HOST] [IPU2 ] 0.813578 s: *** VPDMA Firmware Load Success *** [15:52:40] [HOST] [IPU2 ] 0.813883 s: *** VPDMA Firmware Loading... *** [15:52:40] [HOST] [IPU2 ] 0.813975 s: VPDMA Firmware Address = 0xa03597c0 [15:52:40] [HOST] [IPU2 ] 0.814036 s: VPDMA Load Address = 0x489dd004 [15:52:40] [HOST] [IPU2 ] 0.814127 s: VPDMA Firmware Version = 0x4d0001b8 [15:52:40] [HOST] [IPU2 ] 0.814219 s: VPDMA List Busy Status = 0x00000000 [15:52:40] [HOST] [IPU2 ] 0.814280 s: *** VPDMA Firmware Load Success *** [15:52:40] [HOST] [IPU2 ] 0.849142 s: captdrv/src/vpsdrv_captureApi.c @ Line 147: [15:52:40] [HOST] [IPU2 ] 0.849264 s: numInst:8, retVal:0 in VpsDrv_captInit [15:52:40] [HOST] [IPU2 ] 0.851033 s: SYSTEM: VPS Init Done !!! [15:52:40] [HOST] [IPU2 ] 0.851125 s: [system_bsp_init.c|System_bspInit:330] [15:52:40] [HOST] [IPU2 ] 0.851979 s: UTILS: DMA: HWI Create for INT25 !!! [15:52:40] [HOST] [IPU2 ] 0.852223 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [15:52:40] [HOST] [IPU2 ] 0.852315 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 259800 B (253 KB) [15:52:40] [HOST] [IPU2 ] 0.852528 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [15:52:40] [HOST] [IPU2 ] 0.852681 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 262144000 B (250 MB), Free size = 262144000 B (250 MB) [15:52:40] [HOST] [IPU2 ] 0.852864 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1047040 B (0 MB), Free size = 1037824 B (0 MB) [15:52:40] [HOST] [IPU2 ] 0.853016 s: SYSTEM: Initializing Links !!! [15:52:40] [HOST] [IPU2 ] 0.853077 s: [system_initDeinitLinks.c|System_initLinks:186] [15:52:40] [HOST] [IPU2 ] 0.968187 s: [system_initDeinitLinks.c|System_initLinks:246] [15:52:40] [HOST] [IPU2 ] 0.968279 s: [system_initDeinitLinks.c|System_initLinks:250] [15:52:40] [HOST] [IPU2 ] 1.063899 s: [system_initDeinitLinks.c|System_initLinks:276] [15:52:40] [HOST] [IPU2 ] 1.064021 s: [captureLink_tsk.c|CaptureLink_init:409] [15:52:40] [HOST] [IPU2 ] 1.115872 s: SYSTEM: Initializing Links ... DONE !!! [15:52:40] [HOST] [IPU2 ] 1.115994 s: [system_initDeinitLinks.c|System_initLinks:301] [15:52:40] [HOST] [IPU2 ] 1.116055 s: SYSTEM: System Init in progress [system_ipu1_0.c:185]!!! [15:52:40] [HOST] [IPU2 ] 1.116147 s: SYSTEM: System Init in progress [system_ipu1_0.c:197]!! [15:52:40] [HOST] [IPU2 ] 1.118678 s: [system_common.c:613] System_main --->1 [15:52:40] [HOST] [IPU2 ] 1.118770 s: /home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/common/chains_main_linux.c|Chains_main:597 [15:52:40] [HOST] [IPU2 ] 1.118892 s: CHAINS: Application Started !!! [15:52:40] [HOST] [IPU2 ] 1.118953 s: /home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/common/chains_main_linux.c|Chains_main:601 [15:52:40] [HOST] [IPU2 ] 1.119166 s: [/home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/common/chains_main_linux.c|AppCtrl_init:549] [15:52:40] [HOST] [IPU2 ] 1.121484 s: [/home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_tsk.c|GrpxSrcLink_init:1093] [15:52:40] [HOST] [IPU2 ] 1.129842 s: /home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/common/chains_main_linux.c|Chains_main:608 [15:52:40] [HOST] [IPU2 ] 1.130025 s: [/home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/board/board_tda2xx_ti_evm.c|Board_init:167] yancc [15:52:40] [HOST] [IPU2 ] 1.130147 s: BOARD: Board Init in progress !!! [15:52:40] [HOST] [IPU2 ] 1.130238 s: src/bsp_board.c @ Line 183: [15:52:40] [HOST] [IPU2 ] 1.130299 s: yancc in Bsp_boardInit--->1 [15:52:40] [HOST] [IPU2 ] 1.130757 s: yancc in Bsp_boardTda2exInit--->1 [15:52:40] [HOST] [IPU2 ] 1.130848 s: yancc in Bsp_boardTda2exInit--->2 [15:52:40] [HOST] [IPU2 ] 1.130909 s: BOARD: Board Init Done !!! [15:52:40] [HOST] [IPU2 ] 1.131611 s: src/bsp_device.c @ Line 105: [15:52:40] [HOST] [IPU2 ] 1.131702 s: Bsp_deviceInit --->1 [15:52:40] [HOST] [IPU2 ] 1.131763 s: src/bsp_device.c @ Line 128: [15:52:40] [HOST] [IPU2 ] 1.131855 s: Bsp_deviceInit --->2 isI2cInitReq:1 [15:52:40] [HOST] [IPU2 ] 1.132465 s: ov1063x/src/bspdrv_ov1063xApi.c @ Line 166: [15:52:40] [HOST] [IPU2 ] 1.132556 s: 66666666666666--->1 [15:52:40] [HOST] [IPU2 ] 1.132892 s: ov1063x/src/bspdrv_ov1063xApi.c @ Line 207: [15:52:40] [HOST] [IPU2 ] 1.132983 s: 66666666666666--->2 [15:52:40] [HOST] [IPU2 ] 1.134356 s: ds90uh925/src/bspdrv_ds90uh925Api.c @ Line 141: [15:52:40] [HOST] [IPU2 ] 1.134478 s: 77777777777777--->1 [15:52:40] [HOST] [IPU2 ] 1.134813 s: ds90uh925/src/bspdrv_ds90uh925Api.c @ Line 155: [15:52:40] [HOST] [IPU2 ] 1.134905 s: 77777777777777--->2 [15:52:40] [HOST] [IPU2 ] 1.135027 s: ds90uh926/src/bspdrv_ds90uh926Api.c @ Line 141: [15:52:40] [HOST] [IPU2 ] 1.135088 s: 888888888888888--->1 [15:52:40] [HOST] [IPU2 ] 1.135423 s: ds90uh926/src/bspdrv_ds90uh926Api.c @ Line 155: [15:52:40] [HOST] [IPU2 ] 1.135515 s: 888888888888888--->2 [15:52:40] [HOST] [IPU2 ] 1.137619 s: /home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/board/board_tda2xx_ti_evm.c @ Linen124: [15:52:40] [HOST] [IPU2 ] 1.137772 s: Board_isMultiDesConnected yancc--------->1 [15:52:40] [HOST] [IPU2 ] 1.137863 s: yancc in Bsp_boardGetIdTda2ex--->1 [15:52:40] [HOST] [IPU2 ] 1.137955 s: /home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/board/board_tda2xx_ti_evm.c @ Line 132: [15:52:40] [HOST] [IPU2 ] 1.138077 s: Board_isMultiDesConnected yancc--------->2 [15:52:40] [HOST] [IPU2 ] 1.138138 s: [/home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/board/board_tda2xx_ti_evm.c|Board_init:284] yancc [15:52:40] [HOST] [IPU2 ] 1.138290 s: come in yancc-2 [15:52:40] [HOST] [IPU2 ] 1.138656 s: Initializing Multi-Deserializer Setup ...!! [15:52:40] [HOST] [IPU2 ] 1.138778 s: exit from here yancc-2 [15:52:40] [HOST] [IPU2 ] 1.138839 s: MultiDes Board Init Done [15:52:40] [HOST] [IPU2 ] 1.138900 s: src/bsp_boardTda2ex.c @ Line 356: [15:52:40] [HOST] [IPU2 ] 1.138992 s: yancc in Bsp_boardTda2exLateInit--->1 [15:52:40] [HOST] [IPU2 ] 1.139053 s: [15:52:40] [HOST] [IPU2 ] 1.139083 s: [/home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/board/board_tda2xx_ti_evm.c|Board_init:334] yancc end [15:52:40] [HOST] [IPU2 ] 1.139205 s: /home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/common/chains_main_linux.c|Chains_main:637 [15:52:40] [HOST] [IPU2 ] 9.383608 s: Connection established with HLOS, calling rpmsgInit [15:52:40] [HOST] [IPU2 ] 60.350972 s: [/home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/common/chains_main_linux.c|AppCtrl_cmdHandler:371] cmd:0x1004 [15:52:40] [HOST] [IPU2 ] 60.352284 s: [/home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/common/chains_main_linux.c|AppCtrl_cmdHandler:371] cmd:0x1006 [15:52:40] [HOST] [IPU2 ] 60.353870 s: [/home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/apps/src/rtos/common/chains_main_linux.c|AppCtrl_cmdHandler:371] cmd:0x1014 [15:52:41] [chains_lvdsVipMultiCam_SgxDisplay_priv.c|chains_lvdsVipMultiCam_SgxDisplay_Create:148] [15:52:41] [/home/yue/chips/ti/vsdk_03_08/psdk_v_03a08_local/vision_sdk/links_fw/include/link_api/captureLink.h|CaptureLink_CreateParams_Init:748] [15:52:41] [/home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/links_fw/include/link_api/displayLink.h|DisplayLink_CreateParams_Init:460] [15:52:41] [/home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/links_fw/include/link_api/grpxSrcLink.h|GrpxSrcLink_CreateParams_Init:624] [15:52:41] [/home/yue/chips/ti/vsdk_03_08/psdk_v_03_08_local/vision_sdk/links_fw/include/link_api/displayLink.h|DisplayLink_CreateParams_Init:460] [15:52:41] [HOST] [HOST ] 60.854328 s: chains_main.c main ----------------->1 [15:52:41] [HOST] [HOST ] 60.854328 s: xchains_lvdsVipMultiCam_SgxDisplay.c|chains_lvdsVipMultiCam_SgxDisplay:370] [15:52:41] [HOST] [HOST ] 62.028396 s: [chains_lvdsVipMultiCam_SgxDisplay.c|chains_lvdsVipMultiCam_SgxDisplay_SetAppPrms:229] captureSrc:0 [15:52:41] [HOST] [HOST ] 62.028396 s: [chains_common.c|ChainsCommon_MultiCam_SetCapturePrms:645] [15:52:41] [HOST] [HOST ] 62.028396 s: [chains_common.c|ChainsCommon_MultiCam_SetCapturePrms:671] [15:52:41] [HOST] [HOST ] 62.028426 s: [chains_common.c|ChainsCommon_GetDisplayWidthHeight:1130] displayType:6 [15:52:41] [HOST] [HOST ] 62.028426 s: [chains_common.c|ChainsCommon_SetGrpxSrcPrms:1980] [15:52:41] [HOST] [HOST ] 62.028426 s: [chains_common.c|ChainsCommon_SetDisplayPrms:1494] [15:52:41] [HOST] [HOST ] 62.028426 s: [chains_common.c|ChainsCommon_StartDisplayCtrl:1868] [15:52:41] [HOST] [HOST ] 62.028457 s: [chains_common.c|ChainsCommon_SetDctrlConfig:1531] displayType:6 [15:52:41] [HOST] [HOST ] 62.028457 s: [chains_common.c|ChainsCommon_SetDctrlConfig:1743] displayType:6, displayWidth:1280, displayHeight:720 [15:52:41] [HOST] [HOST ] 62.028457 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.028823 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [chains_lvdsVipMultiCam_SgxDisplay_priv.c|chains_lvdsVipMultiCam_SgxDisplay_Create:154] [15:52:41] [chains_lvdsVipMultiCam_SgxDisplay_priv.c|chains_lvdsVipMultiCam_SgxDisplay_ConnectLinks:141] [15:52:41] [HOST] [HOST ] 62.074025 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.074330 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.074544 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.074788 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.075032 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.075306 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [IPU2 ] 62.075428 s: [captureLink_tsk.c|CaptureLink_tskMain:294] [15:52:41] [HOST] [IPU2 ] 62.075550 s: CAPTURE: Create in progress !!! [15:52:41] [HOST] [IPU2 ] 62.075611 s: [captureLink_drv.c|CaptureLink_drvCreate:638] pPrm->numVipInst:4 [15:52:41] [HOST] [IPU2 ] 62.075947 s: captdrv/src/vpsdrv_captureApi.c @ Line 227: [15:52:41] [HOST] [IPU2 ] 62.076069 s: drvId:0x200, instId:0xff, in VpsDrv_captCreate [15:52:41] [HOST] [IPU2 ] 62.076160 s: [captureLink_drv.c|CaptureLink_drvCreateInst:191] [15:52:41] [HOST] [IPU2 ] 62.076313 s: CAPTURE: VIP1 Slice1 PortA capture mode is [ 8-bit] !!! [15:52:41] [HOST] [IPU2 ] 62.076404 s: captdrv/src/vpsdrv_captureApi.c @ Line 227: [15:52:41] [HOST] [IPU2 ] 62.076526 s: drvId:0x200, instId:0x2, in VpsDrv_captCreate [15:52:41] [HOST] [IPU2 ] 62.197553 s: [captureLink_drv.c|CaptureLink_drvCreateInst:191] [15:52:41] [HOST] [IPU2 ] 62.197736 s: CAPTURE: VIP1 Slice0 PortA capture mode is [ 8-bit] !!! [15:52:41] [HOST] [IPU2 ] 62.197858 s: captdrv/src/vpsdrv_captureApi.c @ Line 227: [15:52:41] [HOST] [IPU2 ] 62.197950 s: drvId:0x200, instId:0x0, in VpsDrv_captCreate [15:52:41] [HOST] [IPU2 ] 62.319008 s: [captureLink_drv.c|CaptureLink_drvCreateInst:191] [15:52:41] [HOST] [IPU2 ] 62.319221 s: CAPTURE: VIP1 Slice1 PortB capture mode is [ 8-bit] !!! [15:52:41] [HOST] [IPU2 ] 62.319343 s: captdrv/src/vpsdrv_captureApi.c @ Line 227: [15:52:41] [HOST] [IPU2 ] 62.319465 s: drvId:0x200, instId:0x3, in VpsDrv_captCreate [15:52:41] [HOST] [IPU2 ] 62.440492 s: [captureLink_drv.c|CaptureLink_drvCreateInst:191] [15:52:41] [HOST] [IPU2 ] 62.440675 s: CAPTURE: VIP1 Slice0 PortB capture mode is [ 8-bit] !!! [15:52:41] [HOST] [IPU2 ] 62.440797 s: captdrv/src/vpsdrv_captureApi.c @ Line 227: [15:52:41] [HOST] [IPU2 ] 62.440889 s: drvId:0x200, instId:0x1, in VpsDrv_captCreate [15:52:41] [HOST] [HOST ] 62.562465 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.563197 s: [system_linkApi.c|System_linkControl:144] procId:2 [15:52:41] [HOST] [HOST ] 62.563258 s: IPC_IN_0 : Create in progress !!! [15:52:41] [HOST] [HOST ] 62.563868 s: IPC_IN_0 : Create Done !!! [15:52:41] [HOST] [HOST ] 62.563929 s: [system_linkApi.c|System_linkControl:159] [15:52:41] [HOST] [HOST ] 62.563929 s: [system_linkApi.c|System_linkControl:144] procId:2 [15:52:41] [HOST] [HOST ] 62.564204 s: [system_linkApi.c|System_linkControl:159] [15:52:41] [HOST] [HOST ] 62.564234 s: [system_linkApi.c|System_linkControl:144] procId:2 [15:52:41] [HOST] [HOST ] 62.564265 s: SGXFRMCPY: Create in progress for resolution: 1280x720 !!! [15:52:41] [HOST] [HOST ] 62.564356 s: SYSTEM_PVRSCOPE: FIFO /opt/vision_sdk/gpufifo opened successfully [15:52:41] [HOST] [IPU2 ] 62.562160 s: CAPTURE: Create Done !!! [15:52:41] [HOST] [IPU2 ] 62.562618 s: IPC_OUT_0 : Create in progress !!! [15:52:41] [HOST] [IPU2 ] 62.562923 s: IPC_OUT_0 : Create Done !!! [15:52:41] [HOST] [HOST ] 62.634478 s: EGL: version 1.4 [15:52:41] [HOST] [HOST ] 62.648234 s: EGL: GL Version = (null) [15:52:41] [HOST] [HOST ] 62.648234 s: EGL: GL Vendor = (null) [15:52:41] [HOST] [HOST ] 62.648234 s: EGL: GL Renderer = (null) [15:52:41] [HOST] [HOST ] 62.648264 s: EGL: GL Extensions = (null) [15:52:41] [HOST] [HOST ] 62.648295 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.649484 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.650521 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.651528 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.701732 s: SGXFRMCPY: Create Done for resolution: 1280x720 !!! [15:52:41] [HOST] [HOST ] 62.701823 s: [system_linkApi.c|System_linkControl:159] [15:52:41] [HOST] [HOST ] 62.701823 s: [system_linkApi.c|System_linkControl:144] procId:2 [15:52:41] [HOST] [HOST ] 62.701854 s: IPC_OUT_0 : Create in progress !!! [15:52:41] [HOST] [HOST ] 62.701884 s: IPC_OUT_0 : Create Done !!! [15:52:41] [HOST] [HOST ] 62.701915 s: [system_linkApi.c|System_linkControl:159] [15:52:41] [HOST] [HOST ] 62.701915 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.703531 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [HOST ] 62.704813 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:41] [HOST] [IPU2 ] 62.702098 s: IPC_IN_0 : Create in progress !!! [15:52:41] [HOST] [IPU2 ] 62.703257 s: IPC_IN_0 : Create Done !!! [15:52:41] [HOST] [IPU2 ] 62.703653 s: DISPLAY: Create in progress !!! [15:52:41] [HOST] [IPU2 ] 62.703776 s: [displayLink_drv.c|DisplayLink_drvCreate:516] [15:52:41] [HOST] [IPU2 ] 62.703867 s: [displayLink_drv.c|DisplayLink_drvSwitchCh:196] activeChId:0 [15:52:41] [HOST] [IPU2 ] 62.703959 s: [displayLink_drv.c|DisplayLink_drvDisplayCreate:348] displayId:0 [15:52:41] [HOST] [IPU2 ] 62.704325 s: [displayLink_drv.c|DisplayLink_drvCreate:523] [15:52:41] [HOST] [IPU2 ] 62.704569 s: DISPLAY: Create Done !!! [15:52:41] [HOST] [IPU2 ] 62.704965 s: GRPXSRC: Create in progress !!! [15:52:42] [HOST] [HOST ] 63.340480 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:42] [HOST] [HOST ] 63.341792 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:42] [HOST] [IPU2 ] 63.340175 s: GRPXSRC: Create Done !!! [15:52:42] [HOST] [IPU2 ] 63.340663 s: DISPLAY: Create in progress !!! [15:52:42] [HOST] [IPU2 ] 63.340785 s: [displayLink_drv.c|DisplayLink_drvCreate:516] [15:52:42] [HOST] [IPU2 ] 63.340877 s: [displayLink_drv.c|DisplayLink_drvSwitchCh:196] activeChId:0 [15:52:42] [HOST] [IPU2 ] 63.340968 s: [displayLink_drv.c|DisplayLink_drvDisplayCreate:348] displayId:3 [15:52:42] [HOST] [IPU2 ] 63.341334 s: [displayLink_drv.c|DisplayLink_drvCreate:523] [15:52:42] [HOST] [IPU2 ] 63.341578 s: DISPLAY: Create Done !!! [15:52:42] [HOST] [IPU2 ] 63.342219 s: *** UTILS: CPU KHz = 20000 Khz *** [15:52:42] [HOST] [HOST ] 63.442383 s: [system_linkApi.c|System_linkControl:144] procId:3 [15:52:42] [HOST] [DSP1 ] 63.442444 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [15:52:42] [HOST] [DSP1 ] 63.442505 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [15:52:42] [HOST] [DSP1 ] 63.442536 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 521592 B (509 KB) [15:52:42] [HOST] [HOST ] 63.442749 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:42] [HOST] [HOST ] 63.443847 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:42] [HOST] [HOST ] 63.444274 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:42] [HOST] [HOST ] 63.452235 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:42] [HOST] [IPU2 ] 63.442902 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [15:52:42] [HOST] [IPU2 ] 63.443024 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 253744 B (247 KB) [15:52:42] [HOST] [IPU2 ] 63.443207 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [15:52:42] [HOST] [IPU2 ] 63.443359 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 262144000 B (250 MB), Free size = 212377600 B (202 MB) [15:52:42] [HOST] [IPU2 ] 63.443542 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1047040 B (0 MB), Free size = 1037824 B (0 MB) [15:52:42] [HOST] [IPU2 ] 63.444000 s: DISPLAY: Start in progress !!! [15:52:42] [HOST] [IPU2 ] 63.444091 s: DISPLAY: Start Done !!! [15:52:42] [HOST] [IPU2 ] 63.452510 s: DISPLAY: Start in progress !!! [15:52:42] [HOST] [IPU2 ] 63.452601 s: DISPLAY: Start Done !!! [15:52:42] [HOST] [HOST ] 63.453089 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:42] [HOST] [HOST ] 63.453333 s: [system_linkApi.c|System_linkControl:144] procId:2 [15:52:42] [HOST] [HOST ] 63.453394 s: [system_linkApi.c|System_linkControl:159] [15:52:42] [HOST] [HOST ] 63.453394 s: [system_linkApi.c|System_linkControl:144] procId:2 [15:52:42] [HOST] [HOST ] 63.453425 s: SGXFRMCPY: Start in progress !!! [15:52:42] [HOST] [HOST ] 63.453455 s: SGXFRMCPY: Start Done !!! [15:52:42] [HOST] [HOST ] 63.453455 s: [system_linkApi.c|System_linkControl:159] [15:52:42] [HOST] [HOST ] 63.453455 s: [system_linkApi.c|System_linkControl:144] procId:2 [15:52:42] [HOST] [HOST ] 63.453516 s: [system_linkApi.c|System_linkControl:159] [15:52:42] [HOST] [HOST ] 63.453547 s: [system_linkApi.c|System_linkControl:144] procId:2 [15:52:42] [HOST] [HOST ] 63.453577 s: [system_linkApi.c|System_linkControl:159] [15:52:42] [HOST] [HOST ] 63.453608 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:42] [HOST] [HOST ] 63.453821 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:42] [HOST] [HOST ] 63.462636 s: [system_linkApi.c|System_linkControl:144] procId:3 [15:52:42] [HOST] [HOST ] 63.462788 s: [system_linkApi.c|System_linkControl:144] procId:9 [15:52:42] [HOST] [IPU2 ] 63.453943 s: CAPTURE: Start in progress !!! [15:52:42] [HOST] [IPU2 ] 63.462392 s: CAPTURE: Start Done !!! [15:52:44] [15:52:46] [15:52:47]^C [15:52:49]root@dra7xx-evm:/opt/vision_sdk# dmesg -c [15:52:49][ 54.669923] DMA: Module install successful, device major num = 241 [15:52:49][ 54.669931] DRV: Module install successful [15:52:49][ 56.697175] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable) [15:52:49][ 56.697191] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable) [15:52:49][ 65.745381] virtio_rpmsg_bus virtio1: msg received with no recipient
The problem log is attached
