TDA4VM: Failed to start Boot NFS running Vision app using PSDKRA network
Part Number: TDA4VM
Other Parts Discussed in Thread: PCM3168A
Running Vision app after starting with NFS occurred the following error:
APP_LOG: ERROR: Unable to map memory @ 0xac000000 of size 262144 bytes !!!
Help solve it, thanks
  • log:
    1473264.64
    1473264.65U-Boot SPL 2020.01-dirty (Jan 18 2021 - 17:28:10 +0800)
    1473264.65SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla')
    1473264.67Reading on-board EEPROM at 0x50 failed 1
    1473264.73Trying to boot from MMC1
    1473264.89Loading Environment from MMC... *** Warning - bad CRC, using default environment
    1473264.89
    1473265.20init_env from device 17 not supported!
    1473265.20Starting ATF on ARM64 core...
    1473265.20
    1473265.23NOTICE: BL31: v2.3():07.01.00.004-1-g52c334fc3-dirty
    1473265.23NOTICE: BL31: Built : 18:17:14, Nov 19 2020
    1473265.56
    1473265.56U-Boot SPL 2020.01-dirty (Jan 18 2021 - 17:26:35 +0800)
    1473265.57SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla')
    1473265.64Reading on-board EEPROM at 0x50 failed 1
    1473265.65Trying to boot from MMC1
    1473266.42
    1473266.42
    1473266.42
    1473266.42U-Boot 2020.01-dirty (Feb 08 2021 - 10:33:08 +0800)
    1473266.42
    1473266.42SoC: J721E SR1.0
    1473266.42Model: Texas Instruments K3 J721E SoC
    1473266.53Reading on-board EEPROM at 0x50 failed 1
    1473266.53Board: J721EX-PM1-SOM rev E2
    1473266.53DRAM: 4 GiB
    1473266.57not found for dev hbmc-mux
    1473266.57Flash: 0 Bytes
    1473266.59MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
    1473266.60
    1473266.75Loading Environment from MMC... OK
    1473266.75In: serial@2800000
    1473266.75Out: serial@2800000
    1473266.75Err: serial@2800000
    1473266.78
    1473266.81Reading on-board EEPROM at 0x50 failed 1
    1473266.81Net: Port 1 speed froced to 100Mbit
    1473266.82
    1473266.82Warning: ethernet@46000000 using MAC address from ROM
    1473266.82eth0: ethernet@46000000
    1473266.82Hit any key to stop autoboot: 2 0
    1473266.82=>
    1473266.82=>
    1473266.82=>
    1473266.98
    1473266.98=>
    1473266.98=>
    1473267.15
    1473267.15=>
    1473267.15=>
    1473269.78set ipaddr 192.168.168.186
    1473269.79=> set ipaddr 192.168.168.186
    1473269.79=>
    1473285.59setenv autoload no
    1473285.60=> setenv autoload no
    1473285.60=>
    1473295.03setenv serverip 192.168.168.183
    1473295.04=> setenv serverip 192.168.168.183
    1473295.04=>
    1473304.00setenv gatewayip 192.168.168.183
    1473304.01=> setenv gatewayip 192.168.168.183
    1473304.01=>
    1473312.64setenv netmask 255.255.255.0
    1473312.65=> setenv netmask 255.255.255.0
    1473312.65=>
    1473324.93setenv overlay_files k3-j721e-vision-apps.dtbo
    1473324.95=> setenv overlay_files k3-j721e-vision-apps.dtbo
    1473324.95=>
    1473359.89setenv bootargs root=/dev/nfs rw nfsroot=192.168.168.183:/home/book/work/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/targetfs,nolock,vers=4,tcp ip=dhcp::${netmask} rootdelay=5 nfsrootdebug
    1473359.92=> setenv bootargs root=/dev/nfs rw nfsroot=192.168.168.183:/home/book/work/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/targetfs,nolock,vers=4,tcp ip=dhcp::${netmask} rootdelay=5 nfsrootdebug
    1473359.92=>
    1473383.90tftp 0x82000000 ./boot_02/Image;tftp 0x88000000 ./boot_02/k3-j721e-common-proc-board.dtb;tftp 0x89000000 ./boot_02/k3-j721e-vision-apps.dtbo;booti 0x82000000 - 0x88000000
    1473383.93=> tftp 0x82000000 ./boot_02/Image;tftp 0x88000000 ./boot_02/k3-j721e-common-proc-board.dtb;tftp 0x89000000 ./boot_02/k3-j721e-vision-apps.dtbo;booti 0x82000000 - 0x88000000
    1473383.95link up on port 1, speed 100, full duplex
    1473383.96Using ethernet@46000000 device
    1473383.96TFTP from server 192.168.168.183; our IP address is 192.168.168.186
    1473383.96Filename './boot_02/Image'.
    1473383.98Load address: 0x82000000
    1473384.34Loading: *#################################################################
    1473384.73 #################################################################
    1473385.10 #################################################################
    1473385.51 #################################################################
    1473385.90 #################################################################
    1473386.29 #################################################################
    1473386.70 #################################################################
    1473387.09 #################################################################
    1473387.50 #################################################################
    1473387.87 #################################################################
    1473388.25 #################################################################
    1473388.64 #################################################################
    1473389.06 #################################################################
    1473389.43 #################################################################
    1473389.82 #################################################################
    1473390.25 #################################################################
    1473390.62 #################################################################
    1473390.82 ###############################
    1473390.82 2.3 MiB/s
    1473390.84done
    1473390.84Bytes transferred = 16666632 (fe5008 hex)
    1473390.84link up on port 1, speed 100, full duplex
    1473390.85Using ethernet@46000000 device
    1473390.85TFTP from server 192.168.168.183; our IP address is 192.168.168.186
    1473390.87Filename './boot_02/k3-j721e-common-proc-board.dtb'.
    1473390.87Load address: 0x88000000
    1473390.90Loading: *#######
    1473390.90 3.1 MiB/s
    1473390.90done
    1473390.90Bytes transferred = 93829 (16e85 hex)
    1473390.92link up on port 1, speed 100, full duplex
    1473390.93Using ethernet@46000000 device
    1473390.93TFTP from server 192.168.168.183; our IP address is 192.168.168.186
    1473390.93Filename './boot_02/k3-j721e-vision-apps.dtbo'.
    1473390.93Load address: 0x89000000
    1473390.93Loading: *#
    1473390.93 2 MiB/s
    1473390.93done
    1473390.93Bytes transferred = 6199 (1837 hex)
    1473390.98## Flattened Device Tree blob at 88000000
    1473391.00 Booting using the fdt blob at 0x88000000
    1473391.00 Loading Device Tree to 000000008ffe6000, end 000000008ffffe84 ... OK
    1473391.01
    1473391.01Starting kernel ...
    1473391.03
    1473392.64[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    1473392.65[ 0.000000] Linux version 5.4.74-g9574bba32a (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Thu Nov 19 18:30:39 UTC 2020
    1473392.67[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
    1473392.67[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    1473392.67[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    1473392.68[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    1473392.68[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    1473392.70[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    1473392.71[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    1473392.71[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    1473392.71[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    1473392.75[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    1473392.75[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    1473392.75[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    1473392.76[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    1473392.76[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    1473392.78[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    1473392.78[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    1473392.79[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    1473392.79[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    1473392.81[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    1473392.81[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    1473392.82[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    1473392.82[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    1473392.84[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    1473392.85[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    1473392.85[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    1473392.87[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    1473392.87[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
    1473392.89[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    1473392.90[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
    1473392.90[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    1473392.90[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
    1473392.92[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    1473392.93[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
    1473392.93[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    1473392.95[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    1473392.95[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    1473392.96[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    1473392.96[ 0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    1473392.96[ 0.000000] psci: probing for conduit method from DT.
    1473392.98[ 0.000000] psci: PSCIv1.1 detected in firmware.
    1473392.98[ 0.000000] psci: Using standard PSCI v0.2 function IDs
    1473392.98[ 0.000000] psci: Trusted OS migration not required
    1473393.00[ 0.000000] psci: SMC Calling Convention v1.0
    1473393.00[ 0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072
    1473393.00[ 0.000000] Detected PIPT I-cache on CPU0
    1473393.01[ 0.000000] CPU features: detected: GIC system register CPU interface
    1473393.01[ 0.000000] CPU features: detected: EL2 vector hardening
    1473393.01[ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 48144
    1473393.04[ 0.000000] Kernel command line: root=/dev/nfs rw nfsroot=192.168.168.183:/home/book/work/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/targetfs,nolock,vers=4,tcp ip=dhcp::255.255.255.0 rootdelay=5 nfsrootdebug
    1473393.04[ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    1473393.06[ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    1473393.06[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    1473393.06[ 0.000000] software IO TLB: mapped [mem 0xbbff0000-0xbfff0000] (64MB)
    1473393.07[ 0.000000] Memory: 3374528K/3084288K available (9598K kernel code, 788K rwdata, 3840K rodata, 1664K init, 683K bss, 18446744073708737088K reserved, 524288K cma-reserved)
    1473393.09[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    1473393.09[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
    1473393.09[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    1473393.10[ 0.000000] Tasks RCU enabled.
    1473393.12[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    1473393.12[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    1473393.12[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    1473393.12[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    1473393.14[ 0.000000] GICv3: 960 SPIs implemented
    1473393.14[ 0.000000] GICv3: 0 Extended SPIs implemented
    1473393.14[ 0.000000] GICv3: Distributor has no Range Selector support
    1473393.15[ 0.000000] GICv3: 16 PPIs implemented
    1473393.15[ 0.000000] GICv3: no VLPI support, no direct LPI support
    1473393.15[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    1473393.17[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
    1473393.17[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    1473393.18[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
    1473393.18[ 0.000000] ITS: using cache flushing for cmd queue
    1473393.18[ 0.000000] GICv3: using LPI property table @0x00000008c00c0000
    1473393.20[ 0.000000] GIC: using cache flushing for LPI property table
    1473393.20[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000
    1473393.21[ 0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x43c with crng_init=0
    1473393.21[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    1473393.23[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    1473393.23[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    1473393.25[ 0.000159] Console: colour dummy device 80x25
    1473393.25[ 0.000419] printk: console [tty0] enabled
    1473393.25[ 0.000450] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    1473393.26[ 0.000459] pid_max: default: 32768 minimum: 301
    1473393.26[ 0.000500] LSM: Security Framework initializing
    1473393.28[ 0.000537] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    1473393.28[ 0.000552] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    1473393.28[ 0.001657] ASID allocator initialised with 32768 entries
    1473393.29[ 0.001722] rcu: Hierarchical SRCU implementation.
    1473393.29[ 0.001870] Platform MSI: gic-its@1820000 domain created
    1473393.29[ 0.002068] PCI/MSI: /bus@100000/interrupt-controller@1800000/gic-its@1820000 domain created
    1473393.31[ 0.002256] smp: Bringing up secondary CPUs ...
    1473393.31[ 0.003386] Detected PIPT I-cache on CPU1
    1473393.32[ 0.003412] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    1473393.32[ 0.003423] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000
    1473393.32[ 0.003449] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    1473393.34[ 0.003500] smp: Brought up 1 node, 2 CPUs
    1473393.34[ 0.003520] SMP: Total of 2 processors activated.
    1473393.34[ 0.003525] CPU features: detected: 32-bit EL0 Support
    1473393.35[ 0.003530] CPU features: detected: CRC32 instructions
    1473393.35[ 0.010093] CPU: All CPU(s) started at EL2
    1473393.35[ 0.010113] alternatives: patching kernel code
    1473393.35[ 0.010641] devtmpfs: initialized
    1473393.37[ 0.015540] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    1473393.37[ 0.015566] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    1473393.39[ 0.016396] pinctrl core: initialized pinctrl subsystem
    1473393.39[ 0.016857] NET: Registered protocol family 16
    1473393.40[ 0.019428] DMA: preallocated 256 KiB pool for atomic allocations
    1473393.40[ 0.019729] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    1473393.40[ 0.028931] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    1473393.42[ 0.028949] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    1473393.42[ 0.028955] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    1473393.42[ 0.029972] cryptd: max_cpu_qlen set to 1000
    1473393.43[ 0.031880] vsys_3v3: supplied by evm_12v0
    1473393.43[ 0.031988] vsys_5v0: supplied by evm_12v0
    1473393.43[ 0.032380] iommu: Default domain type: Translated
    1473393.43[ 0.032541] SCSI subsystem initialized
    1473393.45[ 0.032843] mc: Linux media interface: v0.10
    1473393.45[ 0.032858] videodev: Linux video capture interface: v2.00
    1473393.45[ 0.032869] pps_core: LinuxPPS API ver. 1 registered
    1473393.46[ 0.032874] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    1473393.46[ 0.032883] PTP clock support registered
    1473393.46[ 0.032894] EDAC MC: Ver: 3.0.0
    1473393.48[ 0.033405] FPGA manager framework
    1473393.48[ 0.033441] Advanced Linux Sound Architecture Driver Initialized.
    1473393.48[ 0.033846] clocksource: Switched to clocksource arch_sys_counter
    1473393.50[ 0.033944] VFS: Disk quotas dquot_6.6.0
    1473393.50[ 0.033982] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    1473393.50[ 0.036157] thermal_sys: Registered thermal governor 'step_wise'
    1473393.51[ 0.036159] thermal_sys: Registered thermal governor 'power_allocator'
    1473393.53[ 0.036470] NET: Registered protocol family 2
    1473393.53[ 0.036829] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    1473393.53[ 0.036879] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    1473393.54[ 0.036987] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    1473393.54[ 0.037502] TCP: Hash tables configured (established 32768 bind 32768)
    1473393.54[ 0.037565] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    1473393.56[ 0.037610] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    1473393.56[ 0.037713] NET: Registered protocol family 1
    1473393.57[ 0.038057] RPC: Registered named UNIX socket transport module.
    1473393.57[ 0.038067] RPC: Registered udp transport module.
    1473393.57[ 0.038071] RPC: Registered tcp transport module.
    1473393.59[ 0.038075] RPC: Registered tcp NFSv4.1 backchannel transport module.
    1473393.59[ 0.038085] PCI: CLS 0 bytes, default 64
    1473393.59[ 0.038425] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    1473393.60[ 0.040347] Initialise system trusted keyrings
    1473393.60[ 0.040430] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    1473393.60[ 0.042531] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    1473393.62[ 0.042781] NFS: Registering the id_resolver key type
    1473393.62[ 0.042795] Key type id_resolver registered
    1473393.62[ 0.042799] Key type id_legacy registered
    1473393.64[ 0.042806] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    1473393.64[ 0.042989] 9p: Installing v9fs 9p2000 file system support
    1473393.64[ 0.050088] Key type asymmetric registered
    1473393.65[ 0.050097] Asymmetric key parser 'x509' registered
    1473393.65[ 0.050124] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    1473393.65[ 0.050131] io scheduler mq-deadline registered
    1473393.67[ 0.050136] io scheduler kyber registered
    1473393.67[ 0.051323] pinctrl-single 4301c000.pinmux: 94 pins, size 376
    1473393.67[ 0.051539] pinctrl-single 11c000.pinmux: 173 pins, size 692
    1473393.68[ 0.054021] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    1473393.68[ 0.054063] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    1473393.70[ 0.054178] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    1473393.70[ 0.054190] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    1473393.70[ 0.054350] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    1473393.71[ 0.054361] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    1473393.71[ 0.054455] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    1473393.73[ 0.054466] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    1473393.73[ 0.054556] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    1473393.75[ 0.054567] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    1473393.75[ 0.054666] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    1473393.76[ 0.054678] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    1473393.76[ 0.056158] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    1473393.78[ 0.061708] brd: module loaded
    1473393.78[ 0.064853] loop: module loaded
    1473393.78[ 0.066453] libphy: Fixed MDIO Bus: probed
    1473393.78[ 0.066669] tun: Universal TUN/TAP device driver, 1.6
    1473393.79[ 0.066956] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
    1473393.79[ 0.066962] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    1473393.79[ 0.066984] sky2: driver version 1.30
    1473393.79[ 0.067490] VFIO - User Level meta-driver version: 0.3
    1473393.81[ 0.067856] i2c /dev entries driver
    1473393.81[ 0.068408] sdhci: Secure Digital Host Controller Interface driver
    1473393.81[ 0.068413] sdhci: Copyright(c) Pierre Ossman
    1473393.82[ 0.068619] sdhci-pltfm: SDHCI platform and OF driver helper
    1473393.82[ 0.069100] ledtrig-cpu: registered to indicate activity on CPUs
    1473393.84[ 0.069730] optee: probing for conduit method from DT.
    1473393.84[ 0.069749] optee: revision 3.8 (199fca17)
    1473393.84[ 0.070087] optee: initialized driver
    1473393.84[ 0.070950] NET: Registered protocol family 17
    1473393.84[ 0.071028] 9pnet: Installing 9P2000 support
    1473393.85[ 0.071055] Key type dns_resolver registered
    1473393.85[ 0.071202] registered taskstats version 1
    1473393.85[ 0.071207] Loading compiled-in X.509 certificates
    1473393.87[ 0.075178] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    1473393.87[ 0.075282] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    1473393.89[ 0.077249] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla')
    1473393.89[ 0.177859] random: fast init done
    1473393.89[ 0.344822] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    1473393.89[ 0.348745] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    1473393.90[ 0.349521] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    1473393.90[ 0.350291] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    1473393.92[ 0.351015] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
    1473393.92[ 0.351052] pca953x 3-0020: using no AI
    1473393.92[ 0.373887] pca953x 3-0020: failed writing register
    1473393.93[ 0.373949] pca953x: probe of 3-0020 failed with error -121
    1473393.93[ 0.374052] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
    1473393.93[ 0.374127] pca953x 3-0022: using AI
    1473393.95[ 0.374181] pca953x 3-0022: failed writing register
    1473393.95[ 0.374205] pca953x: probe of 3-0022 failed with error -121
    1473393.95[ 0.374244] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    1473393.96[ 0.375032] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    1473393.96[ 0.375609] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
    1473393.96[ 0.376234] pca953x 6-0020: 6-0020 supply vcc not found, using dummy regulator
    1473393.98[ 0.376264] pca953x 6-0020: using no AI
    1473393.98[ 0.397886] pca953x 6-0020: failed writing register
    1473393.98[ 0.397935] pca953x: probe of 6-0020 failed with error -121
    1473394.00[ 0.398037] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    1473394.00[ 0.398634] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    1473394.00[ 0.399266] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    1473394.01[ 0.400021] pca953x 9-0020: 9-0020 supply vcc not found, using dummy regulator
    1473394.01[ 0.400054] pca953x 9-0020: using no AI
    1473394.03[ 1.405849] omap_i2c 2060000.i2c: timeout waiting for bus ready
    1473394.03[ 1.405860] pca953x 9-0020: failed writing register
    1473394.03[ 1.405915] pca953x: probe of 9-0020 failed with error -16
    1473394.04[ 1.405969] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    1473394.04[ 1.407006] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    1473394.06[ 1.408834] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    1473394.06[ 1.409246] ti-sci-intr bus@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created
    1473394.07[ 1.410090] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    1473394.07[ 1.438364] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
    1473394.09[ 1.444145] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    1473394.09[ 1.444157] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    1473394.10[ 1.444162] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    1473394.12[ 1.446640] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    1473394.12[ 1.446654] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    1473394.12[ 1.446659] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    1473394.14[ 1.447412] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
    1473394.15[ 1.448117] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 23, base_baud = 3000000) is a 8250
    1473394.15[ 2.968469] printk: console [ttyS2] enabled
    1473394.15[ 2.973680] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 24, base_baud = 3000000) is a 8250
    1473394.17[ 2.982899] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 25, base_baud = 3000000) is a 8250
    1473394.17[ 2.992028] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
    1473394.18[ 3.000890] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq
    1473394.20[ 3.009591] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq
    1473394.20[ 3.017143] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
    1473394.21[ 3.031670] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    1473394.23[ 3.042211] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    1473394.25[ 3.052367] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    1473394.25[ 3.062609] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    1473394.26[ 3.075754] scsi host0: ufshcd
    1473394.31[ 3.129854] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    1473394.32[ 3.137505] libphy: 46000f00.mdio: probed
    1473394.34[ 3.142695] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver Micrel KSZ9031 Gigabit PHY
    1473394.34[ 3.152356] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    1473394.35[ 3.165163] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
    1473394.35[ 3.176379] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    1473394.37[ 3.185552] mmc0: CQHCI version 5.10
    1473394.42[ 3.228422] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
    1473394.42[ 3.239122] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    1473394.45[ 3.265546] pca953x 4-0020: 4-0020 supply vcc not found, using dummy regulator
    1473394.46[ 3.272811] pca953x 4-0020: using no AI
    1473394.48[ 3.297888] pca953x 4-0020: failed writing register
    1473394.48[ 3.302815] pca953x: probe of 4-0020 failed with error -121
    1473394.50[ 3.310001] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    1473394.50[ 3.318021] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    1473394.51[ 3.326023] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    1473394.51[ 3.334030] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    1473394.53[ 3.342037] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    1473394.53[ 3.352448] mmc0: Command Queue Engine enabled
    1473394.54[ 3.356908] mmc0: new HS200 MMC card at address 0001
    1473394.54[ 3.362257] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
    1473394.54[ 3.367221] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
    1473394.56[ 3.373464] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
    1473394.56[ 3.379694] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (240:0)
    1473394.57[ 3.388991] mmcblk0: p1
    1473394.57[ 3.394737] ti-udma 285c0000.dma-controller: Channels: 24 (tchan: 12, rchan: 12, gp-rflow: 8)
    1473394.59[ 3.407582] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
    1473394.62[ 3.430460] spi-nor spi0.0: unrecognized JEDEC id bytes: ff e0 00 00 00 00
    1473394.62[ 3.437348] spi-nor: probe of spi0.0 failed with error -2
    1473394.64[ 3.450835] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
    1473394.65[ 3.457704] spi-nor: probe of spi1.0 failed with error -2
    1473394.67[ 3.494325] cdns-ufshcd 4e84000.ufs: link startup failed 1
    1473394.68[ 3.499806] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    1473394.68[ 3.501848] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    1473394.70[ 3.504845] cdns-ufshcd 4e84000.ufs: lrb in use=0x0, outstanding reqs=0x0 tasks=0x0
    1473394.70[ 3.512483] libphy: 46000f00.mdio: probed
    1473394.71[ 3.520120] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    1473394.71[ 3.525184] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver Micrel KSZ9031 Gigabit PHY
    1473394.71[ 3.530545] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    1473394.73[ 3.530547] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    1473394.73[ 3.530556] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    1473394.75[ 3.540201] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    1473394.75[ 3.547053] cdns-ufshcd 4e84000.ufs: Clk gate=1
    1473394.76[ 3.557935] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    1473394.76[ 3.559986] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    1473394.78[ 3.574895] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4
    1473394.78[ 3.577254] cdns-ufshcd 4e84000.ufs: Host capabilities=0x1587031f, caps=0x0
    1473394.79[ 3.583684] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    1473394.81[ 3.591141] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    1473394.81[ 3.591144] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    1473394.81[ 3.599509] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    1473394.82[ 3.605401] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    1473394.82[ 3.616345] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    1473394.84[ 3.617291] host_regs: 00000010: 00000000 00000000 00000000 00000000
    1473394.84[ 3.656779] host_regs: 00000020: 00000000 00000470 00000000 00000000
    1473394.84[ 3.663126] host_regs: 00000030: 00000008 00000001 00000000 00000000
    1473394.85[ 3.669470] host_regs: 00000040: 00000000 00000000 00000000 00000000
    1473394.87[ 3.675822] host_regs: 00000050: 00000000 00000000 00000000 00000000
    1473394.87[ 3.676593] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    1473394.87[ 3.682171] host_regs: 00000060: 00000000 00000000 00000000 00000000
    1473394.87[ 3.682173] host_regs: 00000070: 00000000 00000000 00000000 00000000
    1473394.89[ 3.682175] host_regs: 00000080: 00000000 00000000 00000000 00000000
    1473394.90[ 3.682179] host_regs: 00000090: 00000000 00000000 00000000 00000000
    1473394.90[ 3.689568] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    1473394.90[ 3.695816] cdns-ufshcd 4e84000.ufs: hba->ufs_version = 0x210, hba->capabilities = 0x1587031f
    1473394.92[ 3.695819] cdns-ufshcd 4e84000.ufs: hba->outstanding_reqs = 0x0, hba->outstanding_tasks = 0x0
    1473394.92[ 3.702178] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    1473394.93[ 3.708496] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt = 0
    1473394.93[ 3.714852] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    1473394.95[ 3.722125] cdns-ufshcd 4e84000.ufs: No record of pa_err errors
    1473394.95[ 3.722128] cdns-ufshcd 4e84000.ufs: No record of dl_err errors
    1473394.96[ 3.731481] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    1473394.96[ 3.739232] cdns-ufshcd 4e84000.ufs: No record of nl_err errors
    1473394.96[ 3.739235] cdns-ufshcd 4e84000.ufs: No record of tl_err errors
    1473394.98[ 3.739237] cdns-ufshcd 4e84000.ufs: No record of dme_err errors
    1473394.98[ 3.739240] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err errors
    1473394.98[ 3.746932] hctosys: unable to open rtc device (rtc0)
    1473395.00[ 3.754875] cdns-ufshcd 4e84000.ufs: No record of fatal_err errors
    1473395.00[ 3.754877] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 3492485 us
    1473395.01[ 3.754879] cdns-ufshcd 4e84000.ufs: No record of resume_fail errors
    1473395.01[ 3.754881] cdns-ufshcd 4e84000.ufs: No record of suspend_fail errors
    1473395.03[ 3.754884] cdns-ufshcd 4e84000.ufs: No record of dev_reset errors
    1473395.03[ 3.842529] cdns-ufshcd 4e84000.ufs: No record of host_reset errors
    1473395.03[ 3.848800] cdns-ufshcd 4e84000.ufs: No record of task_abort errors
    1473395.04[ 3.855056] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    1473395.04[ 3.861309] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    1473395.04[ 3.867389] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    1473395.10[ 3.919753] Micrel KSZ9031 Gigabit PHY 46000f00.mdio:00: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    1473395.14[ 3.937159] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    1473398.20[ 7.006885] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
    1473399.20[ 7.037846] Sending DHCP requests ., OK
    1473399.21[ 8.025681] IP-Config: Got DHCP answer from 192.168.168.254, my address is 192.168.168.232
    1473399.21[ 8.033933] IP-Config: Complete:
    1473399.23[ 8.037149] device=eth0, hwaddr=e4:15:f6:53:b0:b3, ipaddr=192.168.168.232, mask=255.255.255.0, gw=192.168.168.254
    1473399.23[ 8.047826] host=192.168.168.232, domain=, nis-domain=(none)
    1473399.23[ 8.053905] bootserver=192.168.168.254, rootserver=192.168.168.183, rootpath=
    1473399.25[ 8.053906] nameserver0=192.168.168.254, nameserver1=202.96.128.166
    1473399.37[ 8.183570] ALSA device list:
    1473399.37[ 8.186534] No soundcards found.
    1473399.37[ 8.190105] Waiting 5 sec before mounting root device...
    1473404.46[ 13.290599] VFS: Mounted root (nfs4 filesystem) on device 0:21.
    1473404.48[ 13.299274] devtmpfs: mounted
    1473404.50[ 13.302588] Freeing unused kernel memory: 1664K
    1473404.51[ 13.333856] Run /sbin/init as init process
    1473405.10[ 13.915663] systemd[1]: System time before build time, advancing clock.
    1473405.26[ 14.073943] NET: Registered protocol family 10
    1473405.26[ 14.079422] Segment Routing with IPv6
    1473405.32[ 14.121682] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    1473405.34[ 14.143445] systemd[1]: Detected architecture arm64.
    1473405.35
    1473405.35Welcome to [1mArago 2020.09[0m!
    1473405.35
    1473405.37[ 14.191268] systemd[1]: Set hostname to <j7-evm>.
    1473405.71[ 14.532787] random: crng init done
    1473405.93[ 14.732824] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    1473406.04[ 14.853333] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    1473406.04[ 14.865694] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    1473406.06[ 14.875726] systemd[1]: Created slice system-getty.slice.
    1473406.06[[0;32m OK [0m] Created slice [0;1;39msystem-getty.slice[0m.
    1473406.07[ 14.898595] systemd[1]: Created slice system-serial\x2dgetty.slice.
    1473406.09[[0;32m OK [0m] Created slice [0;1;39msystem-serial\x2dgetty.slice[0m.
    1473406.10[ 14.918442] systemd[1]: Created slice User and Session Slice.
    1473406.10[[0;32m OK [0m] Created slice [0;1;39mUser and Session Slice[0m.
    1473406.12[ 14.942079] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    1473406.14[[0;32m OK [0m] Started [0;1;39mDispatch Password …ts to Console Directory Watch[0m.
    1473406.15[ 14.965973] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    1473406.15[[0;32m OK [0m] Started [0;1;39mForward Password R…uests to Wall Directory Watch[0m.
    1473406.17[ 14.989944] systemd[1]: Reached target Paths.
    1473406.18[[0;32m OK [0m] Reached target [0;1;39mPaths[0m.
    1473406.18[ 15.005890] systemd[1]: Reached target Remote File Systems.
    1473406.20[[0;32m OK [0m] Reached target [0;1;39mRemote File Systems[0m.
    1473406.21[ 15.025883] systemd[1]: Reached target Slices.
    1473406.21[[0;32m OK [0m] Reached target [0;1;39mSlices[0m.
    1473406.21[ 15.041887] systemd[1]: Reached target Swap.
    1473406.23[[0;32m OK [0m] Reached target [0;1;39mSwap[0m.
    1473406.25[ 15.059978] systemd[1]: Listening on RPCbind Server Activation Socket.
    1473406.25[[0;32m OK [0m] Listening on [0;1;39mRPCbind Server Activation Socket[0m.
    1473406.28[ 15.081911] systemd[1]: Reached target RPC Port Mapper.
    1473406.28[[0;32m OK [0m] Reached target [0;1;39mRPC Port Mapper[0m.
    1473406.29[ 15.105787] systemd[1]: Listening on Process Core Dump Socket.
    1473406.31[[0;32m OK [0m] Listening on [0;1;39mProcess Core Dump Socket[0m.
    1473406.31[ 15.126032] systemd[1]: Listening on initctl Compatibility Named Pipe.
    1473406.31[[0;32m OK [0m] Listening on [0;1;39minitctl Compatibility Named Pipe[0m.
    1473406.37[ 15.185417] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    1473406.39[ 15.194761] systemd[1]: Listening on Journal Socket (/dev/log).
    1473406.40[[0;32m OK [0m] Listening on [0;1;39mJournal Socket (/dev/log)[0m.
    1473406.40[ 15.218172] systemd[1]: Listening on Journal Socket.
    1473406.42[[0;32m OK [0m] Listening on [0;1;39mJournal Socket[0m.
    1473406.43[ 15.235170] systemd[1]: Listening on Network Service Netlink Socket.
    1473406.43[[0;32m OK [0m] Listening on [0;1;39mNetwork Service Netlink Socket[0m.
    1473406.45[ 15.261033] systemd[1]: Listening on udev Control Socket.
    1473406.46[[0;32m OK [0m] Listening on [0;1;39mudev Control Socket[0m.
    1473406.46[ 15.282054] systemd[1]: Listening on udev Kernel Socket.
    1473406.48[[0;32m OK [0m] Listening on [0;1;39mudev Kernel Socket[0m.
    1473406.48[ 15.304834] systemd[1]: Mounting Huge Pages File System...
    1473406.50 Mounting [0;1;39mHuge Pages File System[0m...
    1473406.51[ 15.324557] systemd[1]: Mounting POSIX Message Queue File System...
    1473406.51 Mounting [0;1;39mPOSIX Message Queue File System[0m...
    1473406.53[ 15.344754] systemd[1]: Mounting Kernel Debug File System...
    1473406.54 Mounting [0;1;39mKernel Debug File System[0m...
    1473406.56[ 15.365944] systemd[1]: Mounting Temporary Directory (/tmp)...
    1473406.57 Mounting [0;1;39mTemporary Directory (/tmp)[0m...
    1473406.59[ 15.389790] systemd[1]: Starting Create list of static device nodes for the current kernel...
    1473406.59 Starting [0;1;39mCreate list of st…odes for the current kernel[0m...
    1473406.62[ 15.417248] systemd[1]: Starting Start psplash boot splash screen...
    1473406.62 Starting [0;1;39mStart psplash boot splash screen[0m...
    1473406.65[ 15.458706] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
    1473406.65[[0;32m OK [0m] Started [0;1;39mHardware RNG Entropy Gatherer Daemon[0m.
    1473406.68[ 15.487532] systemd[1]: Starting RPC Bind...
    1473406.68 Starting [0;1;39mRPC Bind[0m...
    1473406.70[ 15.506360] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    1473406.71[ 15.519187] systemd[1]: Starting Journal Service...
    1473406.73 Starting [0;1;39mJournal Service[0m...
    1473406.76[ 15.576446] systemd[1]: Starting Load Kernel Modules...
    1473406.78 Starting [0;1;39mLoad Kernel Modules[0m...
    1473406.78[ 15.600735] systemd[1]: Starting Remount Root and Kernel File Systems...
    1473406.81 Starting [0;1;39mRemount Root and Kernel File Systems[0m...
    1473406.81[ 15.624454] systemd[1]: Starting udev Coldplug all Devices...
    1473406.81 Starting [0;1;39mudev Coldplug all Devices[0m...
    1473406.84[ 15.644148] systemd[1]: Mounted Huge Pages File System.
    1473406.84[[0;32m OK [0m] Mounted [0;1;39mHuge Pages File System[0m.
    1473406.84[ 15.658419] systemd[1]: Mounted POSIX Message Queue File System.
    1473406.85[[0;32m OK [0m] Mounted [0;1;39mPOSIX Message Queue File System[0m.
    1473406.87[ 15.682381] systemd[1]: Mounted Kernel Debug File System.
    1473406.87[[0;32m OK [0m] Mounted [0;1;39mKernel Debug File System[0m.
    1473406.90[ 15.706399] systemd[1]: Started RPC Bind.
    1473406.90[[0;32m OK [0m] Started [0;1;39mRPC Bind[0m.
    1473406.90[ 15.718273] cryptodev: loading out-of-tree module taints kernel.
    1473406.92[ 15.724634] systemd[1]: Started Journal Service.
    1473406.92[[0;32m OK [0m] Started [0;1;39mJournal Service[0m.
    1473406.93[ 15.737366] cryptodev: driver 1.10 loaded.
    1473406.95[[0;32m OK [0m] Mounted [0;1;39mTemporary Directory (/tmp)[0m.
    1473406.95[[0;32m OK [0m] Started [0;1;39mCreate list of sta… nodes for the current kernel[0m.
    1473406.96[[0;1;31mFAILED[0m] Failed to start [0;1;39mStart psplash boot splash screen[0m.
    1473407.00See 'systemctl status psplash-start.service' for details.
    1473407.01[[0;1;38;5;185mDEPEND[0m] Dependency failed for [0;1;39mStar…progress communication helper[0m.
    1473407.01[[0;32m OK [0m] Started [0;1;39mLoad Kernel Modules[0m.
    1473407.04[[0;32m OK [0m] Started [0;1;39mRemount Root and Kernel File Systems[0m.
    1473407.07 Mounting [0;1;39mKernel Configuration File System[0m...
    1473407.07 Starting [0;1;39mFlush Journal to Persistent Storage[0m...
    1473407.07 Starting [0;1;39mApply Kernel Variables[0m...
    1473407.10[ 15.907978] systemd-journald[171]: Received client request to flush runtime journal.
    1473407.10 Starting [0;1;39mCreate Static Device Nodes in /dev[0m...
    1473407.10[[0;32m OK [0m] Mounted [0;1;39mKernel Configuration File System[0m.
    1473407.14[[0;32m OK [0m] Started [0;1;39mFlush Journal to Persistent Storage[0m.
    1473407.17[[0;32m OK [0m] Started [0;1;39mApply Kernel Variables[0m.
    1473407.20[[0;32m OK [0m] Started [0;1;39mCreate Static Device Nodes in /dev[0m.
    1473407.21[[0;32m OK [0m] Reached target [0;1;39mLocal File Systems (Pre)[0m.
    1473407.23 Mounting [0;1;39m/media/ram[0m...
    1473407.25 Mounting [0;1;39m/var/volatile[0m...
    1473407.28 Starting [0;1;39mudev Kernel Device Manager[0m...
    1473407.28[[0;32m OK [0m] Mounted [0;1;39m/media/ram[0m.
    1473407.28[[0;32m OK [0m] Mounted [0;1;39m/var/volatile[0m.
    1473407.31[[0;32m OK [0m] Started [0;1;39mudev Coldplug all Devices[0m.
    1473407.34 Starting [0;1;39mLoad/Save Random Seed[0m...
    1473407.37[[0;32m OK [0m] Reached target [0;1;39mLocal File Systems[0m.
    1473407.40 Starting [0;1;39mCreate Volatile Files and Directories[0m...
    1473407.42[[0;32m OK [0m] Started [0;1;39mLoad/Save Random Seed[0m.
    1473407.57[[0;32m OK [0m] Started [0;1;39mudev Kernel Device Manager[0m.
    1473407.62[[0;32m OK [0m] Started [0;1;39mCreate Volatile Files and Directories[0m.
    1473407.65[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Time Synchronization[0m.
    1473407.68See 'systemctl status systemd-timesyncd.service' for details.
    1473407.68[[0;32m OK [0m] Reached target [0;1;39mSystem Time Set[0m.
    1473407.71[[0;32m OK [0m] Reached target [0;1;39mSystem Time Synchronized[0m.
    1473407.71 Starting [0;1;39mUpdate UTMP about System Boot/Shutdown[0m...
    1473407.75[[0;32m OK [0m] Stopped [0;1;39mNetwork Time Synchronization[0m.
    1473407.76[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Time Synchronization[0m.
    1473407.79See 'systemctl status systemd-timesyncd.service' for details.
    1473407.79[[0;32m OK [0m] Stopped [0;1;39mNetwork Time Synchronization[0m.
    1473407.82[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Time Synchronization[0m.
    1473407.87See 'systemctl status systemd-timesyncd.service' for details.
    1473407.87[[0;32m OK [0m] Started [0;1;39mUpdate UTMP about System Boot/Shutdown[0m.
    1473407.90[[0;32m OK [0m] Stopped [0;1;39mNetwork Time Synchronization[0m.
    1473407.92[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Time Synch[ 16.720217] rti-wdt 2200000.watchdog: heartbeat 60 sec
    1473407.92ronization[0m.
    1473407.92See 'systemctl status systemd-timesyncd.service' for details.
    1473407.95[[0;32m OK [0m] Reached target [0;1;39mSystem Initialization[0m.
    1473407.98[[0;32m OK [0m] Started [0;1;39mDaily rotation of log files[0m.
    1473408.00[[0;32m OK [0m] Started [0;1;39mDaily Cleanup of Temporary Directories[0m.
    1473408.00[[0;32m OK [0m] Reached target [0;1;39mTimers[0m.
    1473408.03[[0;32m OK [0m] Listening on [0;1;39mAvahi mDNS/DNS-SD Stack Activation Socket[0m.
    1473408.04[[0;32m OK [0m] Listening on [0;1;39mD-Bus System Message Bus Socket[0m.
    1473408.07 Starting [0;1;39mDocker Socket for the API[0m.
    1473408.10[ 16.914566] rti-wdt 2210000.watchdog: heartbeat 60 sec
    1473408.15[[0;32m OK [0m] Listening on [0;1;39mdropbear.socket[0m.
    1473408.17 Starting [0;1;39mReboot and dump vmcore via kexec[0m...
    1473408.17[[0;32m OK [0m] Listening on [0;1;39mDocker Socket for the API[0m.
    1473408.20[[0;32m OK [0m] Reached target [0;1;39mSockets[0m.
    1473408.21[[0;32m OK [0m] Reached target [0;1;39mBasic System[0m.
    1473408.21[[0;32m OK [0m] Started [0;1;39mJob spooling tools[0m.
    1473408.26[[0;32m OK [0m] Started [0;1;39mPeriodic Command Scheduler[0m.
    1473408.29[[0;32m OK [0m] Started [0;1;39mD-Bus System Message Bus[0m.
    1473408.31 Starting [0;1;39mPrint notice about GPLv3 packages[0m...
    1473408.34 Starting [0;1;39mIPv6 Packet Filtering Framework[0m...
    1473408.35 Starting [0;1;39mIPv4 Packet Filtering Framework[0m...
    1473408.35[[0;32m OK [0m] Started [0;1;39mirqbalance daemon[0m[ 17.139690] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    1473408.35.
    1473408.35 Starting [0;1;39mrc.pvr.service[0m...
    1473408.35[[0;1;31mFAILED[0m] Failed to start [0;1;39mLogin Service[0m.
    1473408.35See 'systemctl status systemd-logind.service' for details.
    1473408.35[[0;32m OK [0m] Stopped [0;1;39mNetwork Time Synchronization[0m.
    1473408.39[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Tim[ 17.178942] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    1473408.40e Synchronization[0m.
    1473408.40See 'systemctl status systemd-timesyncd.service' for details.
    1473408.40[[0;32m OK [0m] Stopped [0;1;39mLogin Service[0m.
    1473408.40[[0;1;31mFAILED[0m] Failed to start [0;1;39mLogin Service[0m.
    1473408.40See 'systemctl status systemd-logind.service' for details.
    1473408.40[[0;32m OK [0m] Stopped [0;1;39mNetwork Time[ 17.211109] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
    1473408.40 Synchronization[0m.
    1473408.43[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Time Synchronization[0m.
    1473408.45See 'systemctl status systemd-timesyncd.service' for details.
    1473408.45[[0;32m OK [0m] Stopped [0;1;39mLogin Service[0m.
    1473408.45[[0;1;31mFAILED[0m] Failed to start [0;1;39mLogin Service[0m.
    1473408.45See 'systemctl status systemd-logind.service' for details.
    1473408.45[[0;32m OK [0m] Stopped [0;[ 17.249650] remoteproc remoteproc0: 4d80800000.dsp is available
    1473408.451;39mLogin Service[0m.
    1473408.48[[0;32m OK [0m] Stopped [0;1;39mLogin Service[0m.
    1473408.50[[0;1;31mFAILED[0m] Failed to start [0;1;39mLogin Service[0m.
    1473408.50See 'systemctl status systemd-logind.service' for details.
    1473408.50[[0;32m OK [0m] Stopped [0;1;39mLogin Service[0m.
    1473408.50[[0;1;31mFAILED[0m] Failed to start [0;1;39mLogin Se[ 17.298508] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    1473408.50rvice[0m.
    1473408.54[ 17.319350] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    1473408.54[ 17.334411] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
    1473408.54[ 17.349674] remoteproc remoteproc1: 4d81800000.dsp is available
    1473408.57[ 17.368835] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    1473408.59[ 17.397244] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    1473408.62[ 17.420606] remoteproc remoteproc2: 64800000.dsp is available
    1473408.95[ 17.770482] PVR_K: 198: Read BVNC 22.104.208.318 from HW device registers
    1473408.98[ 17.782955] PVR_K: 198: RGX Device initialised with BVNC 22.104.208.318
    1473409.01[ 17.801585] [drm] Initialized pvr 1.10.5371573 20170530 for 4e20000000.gpu on minor 0
    1473409.07[ 17.892867] remoteproc remoteproc0: powering up 4d80800000.dsp
    1473409.10[ 17.898800] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 1579152
    1473409.10[ 17.913445] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200000
    1473409.10[ 17.926957] remoteproc remoteproc1: powering up 4d81800000.dsp
    1473409.14[ 17.933126] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 1579152
    1473409.15[ 17.941424] remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
    1473409.15[ 17.962170] virtio_rpmsg_bus virtio0: rpmsg host is online
    1473409.17[ 17.969266] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200000
    1473409.18[ 17.979990] remoteproc0#vdev0buffer: registered virtio0 (type 7)
    1473409.18[ 17.986136] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
    1473409.20[ 17.999436] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    1473409.21[ 18.007745] remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
    1473409.21[ 18.028443] virtio_rpmsg_bus virtio1: rpmsg host is online
    1473409.25[ 18.037991] remoteproc1#vdev0buffer: registered virtio1 (type 7)
    1473409.25[ 18.044104] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
    1473409.28[ 18.066989] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    1473409.31[ 18.113080] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    1473409.31[ 18.121037] [drm] No driver support for vblank timestamp query.
    1473409.34[ 18.138986] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
    1473409.34[ 18.148009] [drm] Cannot find any crtc or sizes
    1473409.60[ 18.414550] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    1473409.64[ 18.453085] platform 41000000.r5f: configured R5F for IPC-only mode
    1473409.67[ 18.476003] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    1473409.71[ 18.531617] remoteproc remoteproc3: 41000000.r5f is available
    1473409.78[ 18.593063] platform 5c00000.r5f: configured R5F for remoteproc mode
    1473409.81[ 18.620591] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    1473409.84[ 18.639077] remoteproc remoteproc4: 5c00000.r5f is available
    1473409.84[ 18.655417] platform 5d00000.r5f: configured R5F for remoteproc mode
    1473409.87[ 18.682267] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    1473409.89[ 18.700096] remoteproc remoteproc3: Direct firmware load for j7-mcu-r5f0_0-fw failed with error -2
    1473409.90[ 18.711829] remoteproc remoteproc3: powering up 41000000.r5f
    1473409.90[ 18.720382] remoteproc remoteproc3: Direct firmware load for j7-mcu-r5f0_0-fw failed with error -2
    1473409.92[ 18.720947] remoteproc remoteproc5: 5d00000.r5f is available
    1473409.93[ 18.732782] remoteproc remoteproc3: request_firmware failed: -2
    1473409.96[ 18.784794] platform 5e00000.r5f: configured R5F for remoteproc mode
    1473410.00[ 18.802175] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    1473410.00[ 18.821363] remoteproc remoteproc6: 5e00000.r5f is available
    1473410.03[ 18.837166] platform 5f00000.r5f: configured R5F for remoteproc mode
    1473410.06[ 18.862142] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    1473410.06[ 18.874266] remoteproc remoteproc7: 5f00000.r5f is available
    1473410.20[ 19.014850] remoteproc remoteproc2: powering up 64800000.dsp
    1473410.21[ 19.014863] remoteproc remoteproc5: Direct firmware load for j7-main-r5f0_1-fw failed with error -2
    1473410.21[ 19.020527] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 9969648
    1473410.21[ 19.027215] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8200000
    1473410.23[ 19.034770] remoteproc remoteproc5: powering up 5d00000.r5f
    1473410.25[ 19.051439] remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
    1473410.25[ 19.055892] remoteproc remoteproc5: Direct firmware load for j7-main-r5f0_1-fw failed with error -2
    1473410.25[ 19.063654] virtio_rpmsg_bus virtio2: rpmsg host is online
    1473410.28[ 19.073053] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
    1473410.28[ 19.079664] remoteproc2#vdev0buffer: registered virtio2 (type 7)
    1473410.28[ 19.086885] remoteproc remoteproc5: request_firmware failed: -2
    1473410.28[ 19.089541] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
    1473410.29[ 19.095436] remoteproc remoteproc6: powering up 5e00000.r5f
    1473410.29[ 19.109857] remoteproc remoteproc2: remote processor 64800000.dsp is now up
    1473410.31[ 19.116913] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
    1473410.31[ 19.117059] remoteproc remoteproc7: powering up 5f00000.r5f
    1473410.32[ 19.134582] remoteproc remoteproc6: request_firmware failed: -2
    1473410.32[ 19.137963] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
    1473410.34[ 19.149401] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    1473410.34[ 19.153854] remoteproc remoteproc7: request_firmware failed: -2
    1473410.37[ 19.176334] CAN device driver interface
    1473410.57[ 19.383790] m_can_platform 40528000.can: m_can device registered (irq=15, version=32)
    1473410.60[ 19.426436] m_can_platform 40568000.can: m_can device registered (irq=17, version=32)
    1473410.68[ 19.504670] remoteproc remoteproc4: powering up 5c00000.r5f
    1473410.70[ 19.510467] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 5212504
    1473410.71[ 19.527428] platform 5c00000.r5f: Allocated carveout doesn't fit device address request
    1473410.71[ 19.539019] platform 5c00000.r5f: Allocated carveout doesn't fit device address request
    1473410.73[ 19.551973] remoteproc remoteproc4: bad phdr da 0xa1100000 mem 0x8c
    1473410.75[ 19.563182] remoteproc remoteproc4: Failed to load program segments: -22
    1473411.03[[0;32m OK [0m] Started [0;1;39mReboot and dump vmcore via kexec[0m.
    1473411.04[[0;32m OK [0m] Started [0;1;39mIPv6 Packet Filtering Framework[0m.
    1473411.04[[0;32m OK [0m] Started [0;1;39mIPv4 Packet Filtering Framework[0m.
    1473411.04[[0;32m OK [0m] Reached target [0;1;39mNetwork (Pre)[0m.
    1473411.06 Starting [0;1;39mNetwork Service[0m...
    1473411.32[[0;32m OK [0m] Started [0;1;39mNetwork Service[0m.
    1473411.34 Starting [0;1;39mWait for Network to be Configured[0m...
    1473411.35[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Name Resolution[0m.
    1473411.37See 'systemctl status systemd-resolved.service' for details.
    1473411.37[[0;32m OK [0m] Reached target [0;1;39mNetwork[0m.
    1473411.37[[0;32m OK [0m] Reached target [0;1;39mHost and Network Name Lookups[0m.
    1473411.39 Starting [0;1;39mAvahi mDNS/DNS-SD Stack[0m...
    1473411.42[[0;32m OK [0m] Started [0;1;39mNFS status monitor for NFSv2/3 locking.[0m.
    1473411.42 Starting [0;1;39mSimple Network Ma…ent Protocol (SNMP) Daemon.[0m...
    1473411.43 Starting [0;1;39mPermit User Sessions[0m...
    1473411.43[[0;32m OK [0m] Stopped [0;1;39mNetwork Name Resolution[0m.
    1473411.46[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Name Resolution[0m.
    1473411.46See 'systemctl status systemd-resolved.service' for details.
    1473411.48[[0;32m OK [0m] Stopped [0;1;39mNetwork Name Resolution[0m.
    1473411.50[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Name Resolution[0m.
    1473411.50See 'systemctl status systemd-resolved.service' for details.
    1473411.50[[0;32m OK [0m] Stopped [0;1;39mNetwork Name Resolution[0m.
    1473411.51See 'systemctl status systemd-resolved.service' for details.
    1473411.53[[0;32m OK [0m] Stopped [0;1;39mNetwork Name Resolution[0m.
    1473411.53[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Name Resolution[0m.
    1473411.53See 'systemctl status systemd-resolved.service' for details.
    1473411.56[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Name Resolution[0m.
    1473411.57See 'systemctl status systemd-resolved.service' for details.
    1473411.59[[0;32m OK [0m] Started [0;1;39mPermit User Sessions[0m.
    1473411.60[[0;32m OK [0m] Started [0;1;39mGetty on tty1[0m.
    1473411.62[[0;32m OK [0m] Started [0;1;39mSerial Getty on ttyS2[0m.
    1473411.64[[0;32m OK [0m] Started [0;1;39mSerial Getty on ttyS3[0m.
    1473411.64[[0;32m OK [0m] Reached target [0;1;39mLogin Prompts[0m.
    1473411.64 Starting [0;1;39mSynchronize System and HW clocks[0m...
    1473411.70[[0;1;31mFAILED[0m] Failed to start [0;1;39mSynchronize System and HW clocks[0m.
    1473411.73See 'systemctl status sync-clocks.service' for details.
    1473411.73[[0;32m OK [0m] Started [0;1;39mAvahi mDNS/DNS-SD Stack[0m.
    1473412.12[ 20.942521] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473412.15[ 20.967164] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.59[ 22.404513] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.62[ 22.413981] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.65[ 22.436195] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.67[[0;32m OK [0m] Created slice [0;1;39msystem-weston.slice[0[ 22.445762] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.67m.
    1473413.68[ 22.463154] remoteproc remoteproc8: b034000.pru is available
    1473413.68[ 22.486561] pru-rproc b034000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@34000 probed successfully
    1473413.71[ 22.513489] remoteproc remoteproc9: b004000.rtu is available
    1473413.71[ 22.526845] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.71[ 22.536404] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.75[ 22.538022] pru-rproc b004000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@4000 probed successfully
    1473413.75[ 22.564117] pru-rproc b00a000.txpru: IRQ vring not found
    1473413.78[[0;32m OK [0m] Started [0;1;39mWeston Wayland Compositor[0m.
    1473413.78[[0;32m OK [0m] Started [0;1;39mrc.pvr.service[0m.
    1473413.78[ 22.578241] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.78 Starting [0;1;39mweston.service[0m...
    1473413.79[ 22.589055] pru-rproc b00a000.txpru: IRQ kick not found
    1473413.79[ 22.593849] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.81[ 22.607291] remoteproc remoteproc10: b00a000.txpru is available
    1473413.82[ 22.630079] pru-rproc b00a000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@a000 probed successfully
    1473413.84[ 22.651552] remoteproc remoteproc11: b038000.pru is available
    1473413.85[ 22.665139] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.87[ 22.674670] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.89[ 22.688199] pru-rproc b038000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@38000 probed successfully
    1473413.92[ 22.715835] remoteproc remoteproc12: b006000.rtu is available
    1473413.92[ 22.728460] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.95[ 22.737875] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.95[ 22.745031] pru-rproc b006000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@6000 probed successfully
    1473413.95[ 22.763184] pru-rproc b00c000.txpru: IRQ vring not found
    1473413.98[ 22.772895] pru-rproc b00c000.txpru: IRQ kick not found
    1473413.98[ 22.781404] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.98[ 22.790869] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.98[ 22.799072] remoteproc remoteproc13: b00c000.txpru is available
    1473414.01[ 22.810240] pru-rproc b00c000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@c000 probed successfully
    1473414.01[ 22.828522] remoteproc remoteproc14: b134000.pru is available
    1473414.04[ 22.841672] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.04[ 22.850891] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.07[ 22.865319] pru-rproc b134000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@34000 probed successfully
    1473414.10[ 22.903381] remoteproc remoteproc15: b104000.rtu is available
    1473414.10[ 22.917765] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.12[ 22.926668] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.14[ 22.936571] pru-rproc b104000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@4000 probed successfully
    1473414.15[ 22.962095] pru-rproc b10a000.txpru: IRQ vring not found
    1473414.17[ 22.973905] pru-rproc b10a000.txpru: IRQ kick not found
    1473414.17[ 22.975059] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.18[ 22.980673] remoteproc remoteproc16: b10a000.txpru is available
    1473414.18[ 22.989758] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.18[ 23.001117] pru-rproc b10a000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@a000 probed successfully
    1473414.21[ 23.019028] remoteproc remoteproc17: b138000.pru is available
    1473414.21[ 23.031328] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.23[ 23.039277] pru-rproc b138000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@38000 probed successfully
    1473414.25[ 23.048881] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.25[ 23.055148] remoteproc remoteproc18: b106000.rtu is available
    1473414.25[ 23.066421] pru-rproc b106000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@6000 probed successfully
    1473414.26[ 23.078000] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.28[ 23.084189] pru-rproc b10c000.txpru: IRQ vring not found
    1473414.28[ 23.089862] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.28[ 23.097608] pru-rproc b10c000.txpru: IRQ kick not found
    1473414.31[ 23.110825] remoteproc remoteproc19: b10c000.txpru is available
    1473414.31[ 23.111045] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.31[ 23.122891] pru-rproc b10c000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@c000 probed successfully
    1473414.32[ 23.129850] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.34[ 23.155647] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.35[ 23.167056] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.42[[0;32m OK [0m] Started [0;1;39mweston.service[0m.
    1473414.42 Starting [0;1;39mDEMO[0m...
    1473414.43 Starting [0;1;39mtelnetd.service[0m...
    1473414.48[ 23.295003] cdns-usb3 6000000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
    1473414.51[[0;32m OK [0m] Started [0;1;39mDEMO[0m.
    1473414.54[[0;32m OK [0m] Started [0;1;39mtelnetd.service[0m.
    1473414.59[[0;32m OK [0m] Started [0;1;39mSimple Network Man…ement Protocol (SNMP) Daemon.[0m.
    1473414.81[ 23.621881] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.82[ 23.630883] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.90[ 23.719869] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    1473414.93[ 23.746345] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.93[ 23.756213] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473415.17[ 23.978748] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473415.17[ 23.988370] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473415.28[ 24.094889] cdns-usb3 6400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
    1473415.29[ 24.102940] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473415.29[ 24.110460] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473415.32[ 24.139115] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473415.34[ 24.149968] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473415.54[ 24.364431] usbcore: registered new interface driver usbfs
    1473415.56[ 24.382387] usbcore: registered new interface driver hub
    1473415.57[ 24.398714] usbcore: registered new device driver usb
    1473415.67[[0;32m OK [0m] Started [0;1;39mWait for Network to be Configured[0m.
    1473415.68[[0;32m OK [0m] Reached target [0;1;39mNetwork is Online[0m.
    1473415.68 Starting [0;1;39mLSB: start and stop d[ 24.500443] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    1473415.68ocker[0m...
    1473415.70 Starting [0;1;39mDocker Application Container Engine[0m...
    1473415.70 Starting [0;1;39mLSB: network benchmark[0m...
    1473415.71[[0;32m OK [0m] Started [0;1;39mstrongSwan IPsec I…IKEv2[ 24.523925] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    1473415.71 daemon using ipsec.conf[0m.
    1473415.75[ 24.545497] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
    1473415.75[ 24.565632] xhci-hcd xhci-hcd.2.auto: irq 597, io mem 0x06010000
    1473415.78[ 24.580884] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    1473415.78[ 24.596438] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    1473415.81[ 24.609117] usb usb1: Product: xHCI Host Controller
    1473415.81[ 24.617877] usb usb1: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
    1473415.81[ 24.630017] usb usb1: SerialNumber: xhci-hcd.2.auto
    1473415.85[ 24.641301] hub 1-0:1.0: USB hub found
    1473415.85[ 24.647895] hub 1-0:1.0: 1 port detected
    1473415.85[ 24.656298] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    1473415.85[ 24.662717] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473415.87[ 24.673081] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473415.87[ 24.683428] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    1473415.89[ 24.694900] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_edid_block [cdns_mhdp]] *ERROR* get block[0] edid failed: -22
    1473415.89[ 24.706033] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_modes [cdns_mhdp]] *ERROR* Failed to read EDID
    1473415.90[ 24.717686] Console: switching to colour frame buffer device 128x48
    1473415.90[ 24.723982] tidss 4a00000.dss: fb0: tidssdrmfb frame buffer device
    1473415.92[ 24.741253] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    1473415.95[ 24.762206] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    1473415.96[ 24.788434] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
    1473416.00[ 24.804580] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    1473416.00[ 24.814045] usb usb2: Product: xHCI Host Controller
    1473416.01[ 24.829138] usb usb2: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
    1473416.03[ 24.849222] usb usb2: SerialNumber: xhci-hcd.2.auto
    1473416.04[ 24.864080] hub 2-0:1.0: USB hub found
    1473416.06[ 24.874048] hub 2-0:1.0: 1 port detected
    1473416.07[ 24.885116] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473416.09[ 24.894579] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
    1473416.09[ 24.900298] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473416.09[ 24.901907] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3
    1473416.10[ 24.916471] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473416.12[ 24.922031] xhci-hcd xhci-hcd.3.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
    1473416.12[ 24.925888] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473416.12[ 24.940913] xhci-hcd xhci-hcd.3.auto: irq 600, io mem 0x06410000
    1473416.15[ 24.951046] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    1473416.15[ 24.966006] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    1473416.15[ 24.977983] usb usb3: Product: xHCI Host Controller
    1473416.17[ 24.983495] usb usb3: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
    1473416.18[[0;32m OK [0m[ 24.999739] usb usb3: SerialNumber: xhci-hcd.3.auto
    1473416.18] Started [0;1;39mLSB: network benchmark[0m.
    1473416.18[ 25.010609] hub 3-0:1.0: USB hub found
    1473416.21[ 25.018966] hub 3-0:1.0: 1 port detected
    1473416.21[ 25.028362] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
    1473416.23[ 25.041702] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473416.25[ 25.050970] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4
    1473416.25[ 25.058910] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473416.25[ 25.067181] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
    1473416.28[ 25.075598] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    1473416.28[ 25.088717] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
    1473416.28[ 25.101886] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    1473416.29[ 25.113560] usb usb4: Product: xHCI Host Controller
    1473416.31[ 25.121884] usb usb4: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
    1473416.31[ 25.132261] usb usb4: SerialNumber: xhci-hcd.3.auto
    1473416.32[ 25.140638] hub 4-0:1.0: USB hub found
    1473416.34[ 25.148386] hub 4-0:1.0: 1 port detected
    1473416.34[ 25.162504] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473416.35[ 25.171889] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473416.46[[0;32m OK [0m] Started [0;1;39mLSB: start and stop docker[0m.
    1473416.46 Starting [0;1;39mthermal-zone-init.service[0m...
    1473417.79
    1473417.81 _____ _____ _ _
    1473417.81| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
    1473417.81| | _| .'| . | . | | __| _| . | | | -_| _| _|
    1473417.81|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
    1473417.82 |___| |___|
    1473417.82
    1473417.82Arago Project http://arago-project.org j7-evm ttyS2
    1473417.82
    1473417.84Arago 2020.09 j7-evm ttyS2
    1473417.84
    1473420.39j7-evm login: [ 29.206400] Initializing XFRM netlink socket
    1473423.37root
    1473423.39[ 32.199946] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_edid_block [cdns_mhdp]] *ERROR* get block[0] edid failed: -22
    1473423.40[ 32.210958] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_modes [cdns_mhdp]] *ERROR* Failed to read EDID
    1473423.40root
    1473423.92[ 32.736948] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473423.93[ 32.747945] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473423.95[ 32.762907] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473423.96[ 32.773923] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473423.96[ 32.787466] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473423.98[ 32.797890] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.00[ 32.811541] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.01[ 32.823324] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.03[ 32.836930] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.03[ 32.847719] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.04[ 32.860916] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.06[ 32.871737] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.06
    1473424.07[ 32.884909] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.07
    1473424.07
    1473424.09[ 32.895286] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.09[ 32.910917] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.10[ 32.922643] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.12[ 32.935909] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.14[ 32.947721] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.15[ 32.962945] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.15[ 32.973903] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.17[ 32.987080] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.18[ 32.997894] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.20[ 33.010706] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.21[ 33.021692] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.21[ 33.035954] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.23[ 33.047648] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.25[ 33.060842] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.26[ 33.071639] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.28[ 33.085068] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.28[ 33.096165] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.29[ 33.110998] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.31[ 33.121941] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.32[ 33.135012] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.34[ 33.147416] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.34[ 33.160750] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.35[ 33.171753] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.37[ 33.186920] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.40[ 33.198473] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.40[ 33.211817] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.40[ 33.223622] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.42[ 33.236942] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.43[ 33.248387] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.45[ 33.263920] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.46[ 33.275497] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.48[ 33.288638] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.48[ 33.300212] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.50[ 33.314456] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.51[ 33.325276] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.53[ 33.338630] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.53[ 33.349507] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.54[ 33.362907] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.56[ 33.374909] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.57[ 33.387738] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.59[ 33.398721] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.60[ 33.411816] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.60[ 33.421879] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.62[ 33.434923] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.64[ 33.445767] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.64[ 33.459630] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.65[ 33.469922] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.67[ 33.484525] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.68[ 33.496347] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.70[ 33.510901] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.71[ 33.521891] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.71[ 33.531039] cdns-mhdp a000000.dp-bridge: Failed to read receiver capabilities
    1473424.73[ 33.538330] cdns-mhdp a000000.dp-bridge: cdns_mhdp_sst_enable: Not enough BW for 1024x768 (0 lanes at 0 Mbps)
    1473425.53
    1473425.547[r[999;999H[6n8root@j7-evm:~#
    1473425.56root@j7-evm:~#
    1473425.87
    1473425.89root@j7-evm:~#
    1473425.90root@j7-evm:~#
    1473426.00
    1473426.01root@j7-evm:~#
    1473426.03root@j7-evm:~#
    1473426.21root@j7-evm:~# [ 35.031947] overlayfs: filesystem on '/var/lib/docker/check-overlayfs-support576318472/upper' not supported as upperdir
    1473426.28[ 35.090893] overlayfs: filesystem on '/var/lib/docker/check-overlayfs-support062080455/upper' not supported as upperdir
    1473426.53[ 35.333184] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    1473426.53[ 35.354488] Bridge firewalling registered
    1473427.62cd /
    1473427.64cd /
    1473427.65root@j7-evm:/#
    1473428.18ls
    1473428.20root@j7-evm:/# ls
    1473428.28bin dev home init linuxrc mnt proc sbin tmp var
    1473428.28boot etc include lib media opt run sys usr
    1473428.29root@j7-evm:/#
    1473430.57root@j7-evm:/# ***************************************************************
    1473430.57***************************************************************
    1473430.59NOTICE: This file system contains the following GPLv3 packages:
    1473430.59 autoconf
    1473430.59 bash-dev
    1473430.59 bash
    1473430.60 bc
    1473430.60 binutils
    1473430.60 cifs-utils
    1473430.60 coreutils-stdbuf
    1473430.60 cpio
    1473430.60 cpp-symlinks
    1473430.60 cpp
    1473430.60 dosfstools
    1473430.60 elfutils
    1473430.60 g++-symlinks
    1473430.60 g++
    1473430.60 gawk
    1473430.60 gcc-symlinks
    1473430.60 gcc
    1473430.60 gdb
    1473430.60 gdbserver
    1473430.60 gettext
    1473430.60 glmark2
    1473430.60 gstreamer1.0-libav
    1473430.60 gzip
    1473430.60 less
    1473430.60 libasm1
    1473430.60 libbfd
    1473430.60 libdw1
    1473430.62 libelf1
    1473430.62 libgdbm-compat4
    1473430.62 libgdbm-dev
    1473430.62 libgdbm6
    1473430.62 libgettextlib
    1473430.62 libgettextsrc
    1473430.62 libgmp10
    1473430.62 libidn2-0
    1473430.62 libmpc3
    1473430.62 libmpfr6
    1473430.62 libreadline-dev
    1473430.62 libreadline8
    1473430.62 libunistring2
    1473430.62 m4-dev
    1473430.62 m4
    1473430.62 make
    1473430.62 nettle
    1473430.62 parted
    1473430.64 tar
    1473430.64 which
    1473430.64
    1473430.64If you do not wish to distribute GPLv3 components please remove
    1473430.64the above packages prior to distribution. This can be done using
    1473430.64the opkg remove command. i.e.:
    1473430.65 opkg remove <package>
    1473430.65Where <package> is the name printed in the list above
    1473430.65
    1473430.67NOTE: If the package is a dependency of another package you
    1473430.67 will be notified of the dependent packages. You should
    1473430.67 use the --force-removal-of-dependent-packages option to
    1473430.67 also remove the dependent packages as well
    1473430.67***************************************************************
    1473430.68***************************************************************
    1473431.07[ 39.901874] tlv71033: disabling
    1473431.95cd opt
    1473431.96cd opt
    1473432.00root@j7-evm:/opt#
    1473432.39
    1473432.40root@j7-evm:/opt#
    1473432.42root@j7-evm:/opt#
    1473432.54
    1473432.56root@j7-evm:/opt#
    1473432.59root@j7-evm:/opt#
    1473432.76
    1473432.79root@j7-evm:/opt#
    1473432.81root@j7-evm:/opt#
    1473433.37ls
    1473433.39root@j7-evm:/opt# ls
    1473433.42containerd img-powervr-sdk ltp tidl_test vision_apps
    1473433.43root@j7-evm:/opt#
    1473436.81cd vision*
    1473436.84root@j7-evm:/opt# cd vision*
    1473436.85root@j7-evm:/opt/vision_apps#
    1473437.50ls
    1473437.53root@j7-evm:/opt/vision_apps# ls
    1473437.54app_avp.cfg run_app_tidl_seg_16bit.sh
    1473437.57app_avp2.cfg run_app_tidl_vl.sh
    1473437.57app_avp3.cfg run_ptk_demo.sh
    1473437.57app_avp4.cfg uEnv.txt
    1473437.57app_c7x.cfg vision_apps_init.sh
    1473437.57app_dof.cfg vx_app_arm_fd_exchange_consumer.out
    1473437.57app_encode.cfg vx_app_arm_fd_exchange_producer.out
    1473437.57app_multi_cam.cfg vx_app_arm_opengl_mosaic.out
    1473437.57app_oc.cfg vx_app_c7x_kernel.out
    1473437.57app_oc_16bit.cfg vx_app_conformance.out
    1473437.59app_od.cfg vx_app_dense_optical_flow.out
    1473437.60app_pcie_video_sink.cfg vx_app_dense_optical_flow2.out
    1473437.60app_pcie_video_source.cfg vx_app_dof_sfm_fisheye.out
    1473437.60app_seg.cfg vx_app_encode.out
    1473437.60app_seg_16bit.cfg vx_app_lidar_ogmap.out
    1473437.60app_single_cam.cfg vx_app_linux_arm_ipc.out
    1473437.60app_srv.cfg vx_app_linux_arm_mem.out
    1473437.60app_srv_avp_cfg vx_app_linux_arm_remote_log.out
    1473437.62app_stereo.cfg vx_app_load_test.out
    1473437.62app_tidl_cam.cfg vx_app_multi_cam.out
    1473437.64app_vl.cfg vx_app_sde.out
    1473437.64libtivision_apps.so.7.1.0 vx_app_sde_obstacle_detection.out
    1473437.64limits.conf vx_app_single_cam.out
    1473437.64ptk_app_cfg vx_app_srv_calibration.out
    1473437.64run_app_c7x.sh vx_app_srv_camera.out
    1473437.64run_app_dof.sh vx_app_srv_fileio.out
    1473437.65run_app_encode.sh vx_app_stereo_depth.out
    1473437.65run_app_multi_cam.sh vx_app_surround_radar_ogmap.out
    1473437.65run_app_single_cam.sh vx_app_test_framework.out
    1473437.65run_app_srv.sh vx_app_tidl.out
    1473437.67run_app_srv_avp.sh vx_app_tidl_avp.out
    1473437.67run_app_stereo.sh vx_app_tidl_avp2.out
    1473437.68run_app_tidl.sh vx_app_tidl_avp3.out
    1473437.68run_app_tidl_16bit.sh vx_app_tidl_avp4.out
    1473437.68run_app_tidl_avp.sh vx_app_tidl_cam.out
    1473437.68run_app_tidl_avp2.sh vx_app_tidl_od.out
    1473437.68run_app_tidl_avp3.sh vx_app_tidl_seg.out
    1473437.68run_app_tidl_avp4.sh vx_app_tidl_vl.out
    1473437.68run_app_tidl_cam.sh vx_app_tutorial.out
    1473437.70run_app_tidl_od.sh vx_app_valet_parking.out
    1473437.70run_app_tidl_seg.sh
    1473437.71root@j7-evm:/opt/vision_apps#
    1473451.65./vision_apps*
    1473451.67root@j7-evm:/opt/vision_apps# ./vision_apps*
    1473451.70root@j7-evm:/opt/vision_apps#
    1473451.71root@j7-evm:/opt/vision_apps# APP_LOG: ERROR: Unable to map memory @ 0xac000000 of size 262144 bytes !!!
    1473454.68
    1473454.71
    1473454.75root@j7-evm:/opt/vision_apps#
  • 1473264.64
    1473264.65U-Boot SPL 2020.01-dirty (Jan 18 2021 - 17:28:10 +0800)
    1473264.65SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla')
    1473264.67Reading on-board EEPROM at 0x50 failed 1
    1473264.73Trying to boot from MMC1
    1473264.89Loading Environment from MMC... *** Warning - bad CRC, using default environment
    1473264.89
    1473265.20init_env from device 17 not supported!
    1473265.20Starting ATF on ARM64 core...
    1473265.20
    1473265.23NOTICE: BL31: v2.3():07.01.00.004-1-g52c334fc3-dirty
    1473265.23NOTICE: BL31: Built : 18:17:14, Nov 19 2020
    1473265.56
    1473265.56U-Boot SPL 2020.01-dirty (Jan 18 2021 - 17:26:35 +0800)
    1473265.57SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla')
    1473265.64Reading on-board EEPROM at 0x50 failed 1
    1473265.65Trying to boot from MMC1
    1473266.42
    1473266.42
    1473266.42
    1473266.42U-Boot 2020.01-dirty (Feb 08 2021 - 10:33:08 +0800)
    1473266.42
    1473266.42SoC: J721E SR1.0
    1473266.42Model: Texas Instruments K3 J721E SoC
    1473266.53Reading on-board EEPROM at 0x50 failed 1
    1473266.53Board: J721EX-PM1-SOM rev E2
    1473266.53DRAM: 4 GiB
    1473266.57not found for dev hbmc-mux
    1473266.57Flash: 0 Bytes
    1473266.59MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
    1473266.60
    1473266.75Loading Environment from MMC... OK
    1473266.75In: serial@2800000
    1473266.75Out: serial@2800000
    1473266.75Err: serial@2800000
    1473266.78
    1473266.81Reading on-board EEPROM at 0x50 failed 1
    1473266.81Net: Port 1 speed froced to 100Mbit
    1473266.82
    1473266.82Warning: ethernet@46000000 using MAC address from ROM
    1473266.82eth0: ethernet@46000000
    1473266.82Hit any key to stop autoboot: 2 0
    1473266.82=>
    1473266.82=>
    1473266.82=>
    1473266.98
    1473266.98=>
    1473266.98=>
    1473267.15
    1473267.15=>
    1473267.15=>
    1473269.78set ipaddr 192.168.168.186
    1473269.79=> set ipaddr 192.168.168.186
    1473269.79=>
    1473285.59setenv autoload no
    1473285.60=> setenv autoload no
    1473285.60=>
    1473295.03setenv serverip 192.168.168.183
    1473295.04=> setenv serverip 192.168.168.183
    1473295.04=>
    1473304.00setenv gatewayip 192.168.168.183
    1473304.01=> setenv gatewayip 192.168.168.183
    1473304.01=>
    1473312.64setenv netmask 255.255.255.0
    1473312.65=> setenv netmask 255.255.255.0
    1473312.65=>
    1473324.93setenv overlay_files k3-j721e-vision-apps.dtbo
    1473324.95=> setenv overlay_files k3-j721e-vision-apps.dtbo
    1473324.95=>
    1473359.89setenv bootargs root=/dev/nfs rw nfsroot=192.168.168.183:/home/book/work/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/targetfs,nolock,vers=4,tcp ip=dhcp::${netmask} rootdelay=5 nfsrootdebug
    1473359.92=> setenv bootargs root=/dev/nfs rw nfsroot=192.168.168.183:/home/book/work/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/targetfs,nolock,vers=4,tcp ip=dhcp::${netmask} rootdelay=5 nfsrootdebug
    1473359.92=>
    1473383.90tftp 0x82000000 ./boot_02/Image;tftp 0x88000000 ./boot_02/k3-j721e-common-proc-board.dtb;tftp 0x89000000 ./boot_02/k3-j721e-vision-apps.dtbo;booti 0x82000000 - 0x88000000
    1473383.93=> tftp 0x82000000 ./boot_02/Image;tftp 0x88000000 ./boot_02/k3-j721e-common-proc-board.dtb;tftp 0x89000000 ./boot_02/k3-j721e-vision-apps.dtbo;booti 0x82000000 - 0x88000000
    1473383.95link up on port 1, speed 100, full duplex
    1473383.96Using ethernet@46000000 device
    1473383.96TFTP from server 192.168.168.183; our IP address is 192.168.168.186
    1473383.96Filename './boot_02/Image'.
    1473383.98Load address: 0x82000000
    1473384.34Loading: *#################################################################
    1473384.73 #################################################################
    1473385.10 #################################################################
    1473385.51 #################################################################
    1473385.90 #################################################################
    1473386.29 #################################################################
    1473386.70 #################################################################
    1473387.09 #################################################################
    1473387.50 #################################################################
    1473387.87 #################################################################
    1473388.25 #################################################################
    1473388.64 #################################################################
    1473389.06 #################################################################
    1473389.43 #################################################################
    1473389.82 #################################################################
    1473390.25 #################################################################
    1473390.62 #################################################################
    1473390.82 ###############################
    1473390.82 2.3 MiB/s
    1473390.84done
    1473390.84Bytes transferred = 16666632 (fe5008 hex)
    1473390.84link up on port 1, speed 100, full duplex
    1473390.85Using ethernet@46000000 device
    1473390.85TFTP from server 192.168.168.183; our IP address is 192.168.168.186
    1473390.87Filename './boot_02/k3-j721e-common-proc-board.dtb'.
    1473390.87Load address: 0x88000000
    1473390.90Loading: *#######
    1473390.90 3.1 MiB/s
    1473390.90done
    1473390.90Bytes transferred = 93829 (16e85 hex)
    1473390.92link up on port 1, speed 100, full duplex
    1473390.93Using ethernet@46000000 device
    1473390.93TFTP from server 192.168.168.183; our IP address is 192.168.168.186
    1473390.93Filename './boot_02/k3-j721e-vision-apps.dtbo'.
    1473390.93Load address: 0x89000000
    1473390.93Loading: *#
    1473390.93 2 MiB/s
    1473390.93done
    1473390.93Bytes transferred = 6199 (1837 hex)
    1473390.98## Flattened Device Tree blob at 88000000
    1473391.00 Booting using the fdt blob at 0x88000000
    1473391.00 Loading Device Tree to 000000008ffe6000, end 000000008ffffe84 ... OK
    1473391.01
    1473391.01Starting kernel ...
    1473391.03
    1473392.64[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    1473392.65[ 0.000000] Linux version 5.4.74-g9574bba32a (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Thu Nov 19 18:30:39 UTC 2020
    1473392.67[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
    1473392.67[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    1473392.67[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    1473392.68[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    1473392.68[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    1473392.70[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    1473392.71[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    1473392.71[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    1473392.71[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    1473392.75[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    1473392.75[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    1473392.75[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    1473392.76[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    1473392.76[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    1473392.78[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    1473392.78[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    1473392.79[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    1473392.79[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    1473392.81[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    1473392.81[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    1473392.82[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    1473392.82[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    1473392.84[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    1473392.85[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    1473392.85[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    1473392.87[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    1473392.87[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
    1473392.89[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    1473392.90[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
    1473392.90[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    1473392.90[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
    1473392.92[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    1473392.93[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
    1473392.93[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    1473392.95[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    1473392.95[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    1473392.96[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    1473392.96[ 0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
    1473392.96[ 0.000000] psci: probing for conduit method from DT.
    1473392.98[ 0.000000] psci: PSCIv1.1 detected in firmware.
    1473392.98[ 0.000000] psci: Using standard PSCI v0.2 function IDs
    1473392.98[ 0.000000] psci: Trusted OS migration not required
    1473393.00[ 0.000000] psci: SMC Calling Convention v1.0
    1473393.00[ 0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072
    1473393.00[ 0.000000] Detected PIPT I-cache on CPU0
    1473393.01[ 0.000000] CPU features: detected: GIC system register CPU interface
    1473393.01[ 0.000000] CPU features: detected: EL2 vector hardening
    1473393.01[ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 48144
    1473393.04[ 0.000000] Kernel command line: root=/dev/nfs rw nfsroot=192.168.168.183:/home/book/work/ti-processor-sdk-rtos-j721e-evm-07_01_00_11/targetfs,nolock,vers=4,tcp ip=dhcp::255.255.255.0 rootdelay=5 nfsrootdebug
    1473393.04[ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    1473393.06[ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    1473393.06[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    1473393.06[ 0.000000] software IO TLB: mapped [mem 0xbbff0000-0xbfff0000] (64MB)
    1473393.07[ 0.000000] Memory: 3374528K/3084288K available (9598K kernel code, 788K rwdata, 3840K rodata, 1664K init, 683K bss, 18446744073708737088K reserved, 524288K cma-reserved)
    1473393.09[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    1473393.09[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
    1473393.09[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    1473393.10[ 0.000000] Tasks RCU enabled.
    1473393.12[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    1473393.12[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    1473393.12[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    1473393.12[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    1473393.14[ 0.000000] GICv3: 960 SPIs implemented
    1473393.14[ 0.000000] GICv3: 0 Extended SPIs implemented
    1473393.14[ 0.000000] GICv3: Distributor has no Range Selector support
    1473393.15[ 0.000000] GICv3: 16 PPIs implemented
    1473393.15[ 0.000000] GICv3: no VLPI support, no direct LPI support
    1473393.15[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    1473393.17[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
    1473393.17[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    1473393.18[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
    1473393.18[ 0.000000] ITS: using cache flushing for cmd queue
    1473393.18[ 0.000000] GICv3: using LPI property table @0x00000008c00c0000
    1473393.20[ 0.000000] GIC: using cache flushing for LPI property table
    1473393.20[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000
    1473393.21[ 0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x43c with crng_init=0
    1473393.21[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    1473393.23[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    1473393.23[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    1473393.25[ 0.000159] Console: colour dummy device 80x25
    1473393.25[ 0.000419] printk: console [tty0] enabled
    1473393.25[ 0.000450] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    1473393.26[ 0.000459] pid_max: default: 32768 minimum: 301
    1473393.26[ 0.000500] LSM: Security Framework initializing
    1473393.28[ 0.000537] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    1473393.28[ 0.000552] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    1473393.28[ 0.001657] ASID allocator initialised with 32768 entries
    1473393.29[ 0.001722] rcu: Hierarchical SRCU implementation.
    1473393.29[ 0.001870] Platform MSI: gic-its@1820000 domain created
    1473393.29[ 0.002068] PCI/MSI: /bus@100000/interrupt-controller@1800000/gic-its@1820000 domain created
    1473393.31[ 0.002256] smp: Bringing up secondary CPUs ...
    1473393.31[ 0.003386] Detected PIPT I-cache on CPU1
    1473393.32[ 0.003412] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    1473393.32[ 0.003423] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000
    1473393.32[ 0.003449] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    1473393.34[ 0.003500] smp: Brought up 1 node, 2 CPUs
    1473393.34[ 0.003520] SMP: Total of 2 processors activated.
    1473393.34[ 0.003525] CPU features: detected: 32-bit EL0 Support
    1473393.35[ 0.003530] CPU features: detected: CRC32 instructions
    1473393.35[ 0.010093] CPU: All CPU(s) started at EL2
    1473393.35[ 0.010113] alternatives: patching kernel code
    1473393.35[ 0.010641] devtmpfs: initialized
    1473393.37[ 0.015540] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    1473393.37[ 0.015566] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    1473393.39[ 0.016396] pinctrl core: initialized pinctrl subsystem
    1473393.39[ 0.016857] NET: Registered protocol family 16
    1473393.40[ 0.019428] DMA: preallocated 256 KiB pool for atomic allocations
    1473393.40[ 0.019729] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    1473393.40[ 0.028931] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    1473393.42[ 0.028949] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    1473393.42[ 0.028955] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    1473393.42[ 0.029972] cryptd: max_cpu_qlen set to 1000
    1473393.43[ 0.031880] vsys_3v3: supplied by evm_12v0
    1473393.43[ 0.031988] vsys_5v0: supplied by evm_12v0
    1473393.43[ 0.032380] iommu: Default domain type: Translated
    1473393.43[ 0.032541] SCSI subsystem initialized
    1473393.45[ 0.032843] mc: Linux media interface: v0.10
    1473393.45[ 0.032858] videodev: Linux video capture interface: v2.00
    1473393.45[ 0.032869] pps_core: LinuxPPS API ver. 1 registered
    1473393.46[ 0.032874] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    1473393.46[ 0.032883] PTP clock support registered
    1473393.46[ 0.032894] EDAC MC: Ver: 3.0.0
    1473393.48[ 0.033405] FPGA manager framework
    1473393.48[ 0.033441] Advanced Linux Sound Architecture Driver Initialized.
    1473393.48[ 0.033846] clocksource: Switched to clocksource arch_sys_counter
    1473393.50[ 0.033944] VFS: Disk quotas dquot_6.6.0
    1473393.50[ 0.033982] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    1473393.50[ 0.036157] thermal_sys: Registered thermal governor 'step_wise'
    1473393.51[ 0.036159] thermal_sys: Registered thermal governor 'power_allocator'
    1473393.53[ 0.036470] NET: Registered protocol family 2
    1473393.53[ 0.036829] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    1473393.53[ 0.036879] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    1473393.54[ 0.036987] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    1473393.54[ 0.037502] TCP: Hash tables configured (established 32768 bind 32768)
    1473393.54[ 0.037565] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    1473393.56[ 0.037610] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    1473393.56[ 0.037713] NET: Registered protocol family 1
    1473393.57[ 0.038057] RPC: Registered named UNIX socket transport module.
    1473393.57[ 0.038067] RPC: Registered udp transport module.
    1473393.57[ 0.038071] RPC: Registered tcp transport module.
    1473393.59[ 0.038075] RPC: Registered tcp NFSv4.1 backchannel transport module.
    1473393.59[ 0.038085] PCI: CLS 0 bytes, default 64
    1473393.59[ 0.038425] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    1473393.60[ 0.040347] Initialise system trusted keyrings
    1473393.60[ 0.040430] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    1473393.60[ 0.042531] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    1473393.62[ 0.042781] NFS: Registering the id_resolver key type
    1473393.62[ 0.042795] Key type id_resolver registered
    1473393.62[ 0.042799] Key type id_legacy registered
    1473393.64[ 0.042806] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    1473393.64[ 0.042989] 9p: Installing v9fs 9p2000 file system support
    1473393.64[ 0.050088] Key type asymmetric registered
    1473393.65[ 0.050097] Asymmetric key parser 'x509' registered
    1473393.65[ 0.050124] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    1473393.65[ 0.050131] io scheduler mq-deadline registered
    1473393.67[ 0.050136] io scheduler kyber registered
    1473393.67[ 0.051323] pinctrl-single 4301c000.pinmux: 94 pins, size 376
    1473393.67[ 0.051539] pinctrl-single 11c000.pinmux: 173 pins, size 692
    1473393.68[ 0.054021] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    1473393.68[ 0.054063] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    1473393.70[ 0.054178] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    1473393.70[ 0.054190] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    1473393.70[ 0.054350] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    1473393.71[ 0.054361] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    1473393.71[ 0.054455] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    1473393.73[ 0.054466] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    1473393.73[ 0.054556] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    1473393.75[ 0.054567] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    1473393.75[ 0.054666] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    1473393.76[ 0.054678] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    1473393.76[ 0.056158] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    1473393.78[ 0.061708] brd: module loaded
    1473393.78[ 0.064853] loop: module loaded
    1473393.78[ 0.066453] libphy: Fixed MDIO Bus: probed
    1473393.78[ 0.066669] tun: Universal TUN/TAP device driver, 1.6
    1473393.79[ 0.066956] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
    1473393.79[ 0.066962] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    1473393.79[ 0.066984] sky2: driver version 1.30
    1473393.79[ 0.067490] VFIO - User Level meta-driver version: 0.3
    1473393.81[ 0.067856] i2c /dev entries driver
    1473393.81[ 0.068408] sdhci: Secure Digital Host Controller Interface driver
    1473393.81[ 0.068413] sdhci: Copyright(c) Pierre Ossman
    1473393.82[ 0.068619] sdhci-pltfm: SDHCI platform and OF driver helper
    1473393.82[ 0.069100] ledtrig-cpu: registered to indicate activity on CPUs
    1473393.84[ 0.069730] optee: probing for conduit method from DT.
    1473393.84[ 0.069749] optee: revision 3.8 (199fca17)
    1473393.84[ 0.070087] optee: initialized driver
    1473393.84[ 0.070950] NET: Registered protocol family 17
    1473393.84[ 0.071028] 9pnet: Installing 9P2000 support
    1473393.85[ 0.071055] Key type dns_resolver registered
    1473393.85[ 0.071202] registered taskstats version 1
    1473393.85[ 0.071207] Loading compiled-in X.509 certificates
    1473393.87[ 0.075178] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    1473393.87[ 0.075282] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    1473393.89[ 0.077249] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla')
    1473393.89[ 0.177859] random: fast init done
    1473393.89[ 0.344822] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    1473393.89[ 0.348745] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    1473393.90[ 0.349521] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    1473393.90[ 0.350291] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    1473393.92[ 0.351015] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
    1473393.92[ 0.351052] pca953x 3-0020: using no AI
    1473393.92[ 0.373887] pca953x 3-0020: failed writing register
    1473393.93[ 0.373949] pca953x: probe of 3-0020 failed with error -121
    1473393.93[ 0.374052] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
    1473393.93[ 0.374127] pca953x 3-0022: using AI
    1473393.95[ 0.374181] pca953x 3-0022: failed writing register
    1473393.95[ 0.374205] pca953x: probe of 3-0022 failed with error -121
    1473393.95[ 0.374244] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    1473393.96[ 0.375032] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
    1473393.96[ 0.375609] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
    1473393.96[ 0.376234] pca953x 6-0020: 6-0020 supply vcc not found, using dummy regulator
    1473393.98[ 0.376264] pca953x 6-0020: using no AI
    1473393.98[ 0.397886] pca953x 6-0020: failed writing register
    1473393.98[ 0.397935] pca953x: probe of 6-0020 failed with error -121
    1473394.00[ 0.398037] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
    1473394.00[ 0.398634] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
    1473394.00[ 0.399266] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
    1473394.01[ 0.400021] pca953x 9-0020: 9-0020 supply vcc not found, using dummy regulator
    1473394.01[ 0.400054] pca953x 9-0020: using no AI
    1473394.03[ 1.405849] omap_i2c 2060000.i2c: timeout waiting for bus ready
    1473394.03[ 1.405860] pca953x 9-0020: failed writing register
    1473394.03[ 1.405915] pca953x: probe of 9-0020 failed with error -16
    1473394.04[ 1.405969] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
    1473394.04[ 1.407006] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    1473394.06[ 1.408834] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    1473394.06[ 1.409246] ti-sci-intr bus@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created
    1473394.07[ 1.410090] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    1473394.07[ 1.438364] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
    1473394.09[ 1.444145] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    1473394.09[ 1.444157] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    1473394.10[ 1.444162] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    1473394.12[ 1.446640] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    1473394.12[ 1.446654] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    1473394.12[ 1.446659] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    1473394.14[ 1.447412] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
    1473394.15[ 1.448117] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 23, base_baud = 3000000) is a 8250
    1473394.15[ 2.968469] printk: console [ttyS2] enabled
    1473394.15[ 2.973680] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 24, base_baud = 3000000) is a 8250
    1473394.17[ 2.982899] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 25, base_baud = 3000000) is a 8250
    1473394.17[ 2.992028] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
    1473394.18[ 3.000890] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq
    1473394.20[ 3.009591] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq
    1473394.20[ 3.017143] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
    1473394.21[ 3.031670] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    1473394.23[ 3.042211] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    1473394.25[ 3.052367] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    1473394.25[ 3.062609] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    1473394.26[ 3.075754] scsi host0: ufshcd
    1473394.31[ 3.129854] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    1473394.32[ 3.137505] libphy: 46000f00.mdio: probed
    1473394.34[ 3.142695] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver Micrel KSZ9031 Gigabit PHY
    1473394.34[ 3.152356] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    1473394.35[ 3.165163] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
    1473394.35[ 3.176379] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    1473394.37[ 3.185552] mmc0: CQHCI version 5.10
    1473394.42[ 3.228422] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
    1473394.42[ 3.239122] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    1473394.45[ 3.265546] pca953x 4-0020: 4-0020 supply vcc not found, using dummy regulator
    1473394.46[ 3.272811] pca953x 4-0020: using no AI
    1473394.48[ 3.297888] pca953x 4-0020: failed writing register
    1473394.48[ 3.302815] pca953x: probe of 4-0020 failed with error -121
    1473394.50[ 3.310001] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    1473394.50[ 3.318021] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    1473394.51[ 3.326023] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    1473394.51[ 3.334030] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    1473394.53[ 3.342037] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    1473394.53[ 3.352448] mmc0: Command Queue Engine enabled
    1473394.54[ 3.356908] mmc0: new HS200 MMC card at address 0001
    1473394.54[ 3.362257] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
    1473394.54[ 3.367221] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
    1473394.56[ 3.373464] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
    1473394.56[ 3.379694] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (240:0)
    1473394.57[ 3.388991] mmcblk0: p1
    1473394.57[ 3.394737] ti-udma 285c0000.dma-controller: Channels: 24 (tchan: 12, rchan: 12, gp-rflow: 8)
    1473394.59[ 3.407582] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
    1473394.62[ 3.430460] spi-nor spi0.0: unrecognized JEDEC id bytes: ff e0 00 00 00 00
    1473394.62[ 3.437348] spi-nor: probe of spi0.0 failed with error -2
    1473394.64[ 3.450835] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
    1473394.65[ 3.457704] spi-nor: probe of spi1.0 failed with error -2
    1473394.67[ 3.494325] cdns-ufshcd 4e84000.ufs: link startup failed 1
    1473394.68[ 3.499806] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    1473394.68[ 3.501848] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    1473394.70[ 3.504845] cdns-ufshcd 4e84000.ufs: lrb in use=0x0, outstanding reqs=0x0 tasks=0x0
    1473394.70[ 3.512483] libphy: 46000f00.mdio: probed
    1473394.71[ 3.520120] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    1473394.71[ 3.525184] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver Micrel KSZ9031 Gigabit PHY
    1473394.71[ 3.530545] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    1473394.73[ 3.530547] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    1473394.73[ 3.530556] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    1473394.75[ 3.540201] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    1473394.75[ 3.547053] cdns-ufshcd 4e84000.ufs: Clk gate=1
    1473394.76[ 3.557935] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    1473394.76[ 3.559986] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    1473394.78[ 3.574895] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4
    1473394.78[ 3.577254] cdns-ufshcd 4e84000.ufs: Host capabilities=0x1587031f, caps=0x0
    1473394.79[ 3.583684] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    1473394.81[ 3.591141] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    1473394.81[ 3.591144] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    1473394.81[ 3.599509] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    1473394.82[ 3.605401] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    1473394.82[ 3.616345] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    1473394.84[ 3.617291] host_regs: 00000010: 00000000 00000000 00000000 00000000
    1473394.84[ 3.656779] host_regs: 00000020: 00000000 00000470 00000000 00000000
    1473394.84[ 3.663126] host_regs: 00000030: 00000008 00000001 00000000 00000000
    1473394.85[ 3.669470] host_regs: 00000040: 00000000 00000000 00000000 00000000
    1473394.87[ 3.675822] host_regs: 00000050: 00000000 00000000 00000000 00000000
    1473394.87[ 3.676593] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    1473394.87[ 3.682171] host_regs: 00000060: 00000000 00000000 00000000 00000000
    1473394.87[ 3.682173] host_regs: 00000070: 00000000 00000000 00000000 00000000
    1473394.89[ 3.682175] host_regs: 00000080: 00000000 00000000 00000000 00000000
    1473394.90[ 3.682179] host_regs: 00000090: 00000000 00000000 00000000 00000000
    1473394.90[ 3.689568] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    1473394.90[ 3.695816] cdns-ufshcd 4e84000.ufs: hba->ufs_version = 0x210, hba->capabilities = 0x1587031f
    1473394.92[ 3.695819] cdns-ufshcd 4e84000.ufs: hba->outstanding_reqs = 0x0, hba->outstanding_tasks = 0x0
    1473394.92[ 3.702178] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    1473394.93[ 3.708496] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt = 0
    1473394.93[ 3.714852] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    1473394.95[ 3.722125] cdns-ufshcd 4e84000.ufs: No record of pa_err errors
    1473394.95[ 3.722128] cdns-ufshcd 4e84000.ufs: No record of dl_err errors
    1473394.96[ 3.731481] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    1473394.96[ 3.739232] cdns-ufshcd 4e84000.ufs: No record of nl_err errors
    1473394.96[ 3.739235] cdns-ufshcd 4e84000.ufs: No record of tl_err errors
    1473394.98[ 3.739237] cdns-ufshcd 4e84000.ufs: No record of dme_err errors
    1473394.98[ 3.739240] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err errors
    1473394.98[ 3.746932] hctosys: unable to open rtc device (rtc0)
    1473395.00[ 3.754875] cdns-ufshcd 4e84000.ufs: No record of fatal_err errors
    1473395.00[ 3.754877] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 3492485 us
    1473395.01[ 3.754879] cdns-ufshcd 4e84000.ufs: No record of resume_fail errors
    1473395.01[ 3.754881] cdns-ufshcd 4e84000.ufs: No record of suspend_fail errors
    1473395.03[ 3.754884] cdns-ufshcd 4e84000.ufs: No record of dev_reset errors
    1473395.03[ 3.842529] cdns-ufshcd 4e84000.ufs: No record of host_reset errors
    1473395.03[ 3.848800] cdns-ufshcd 4e84000.ufs: No record of task_abort errors
    1473395.04[ 3.855056] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    1473395.04[ 3.861309] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    1473395.04[ 3.867389] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    1473395.10[ 3.919753] Micrel KSZ9031 Gigabit PHY 46000f00.mdio:00: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    1473395.14[ 3.937159] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    1473398.20[ 7.006885] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
    1473399.20[ 7.037846] Sending DHCP requests ., OK
    1473399.21[ 8.025681] IP-Config: Got DHCP answer from 192.168.168.254, my address is 192.168.168.232
    1473399.21[ 8.033933] IP-Config: Complete:
    1473399.23[ 8.037149] device=eth0, hwaddr=e4:15:f6:53:b0:b3, ipaddr=192.168.168.232, mask=255.255.255.0, gw=192.168.168.254
    1473399.23[ 8.047826] host=192.168.168.232, domain=, nis-domain=(none)
    1473399.23[ 8.053905] bootserver=192.168.168.254, rootserver=192.168.168.183, rootpath=
    1473399.25[ 8.053906] nameserver0=192.168.168.254, nameserver1=202.96.128.166
    1473399.37[ 8.183570] ALSA device list:
    1473399.37[ 8.186534] No soundcards found.
    1473399.37[ 8.190105] Waiting 5 sec before mounting root device...
    1473404.46[ 13.290599] VFS: Mounted root (nfs4 filesystem) on device 0:21.
    1473404.48[ 13.299274] devtmpfs: mounted
    1473404.50[ 13.302588] Freeing unused kernel memory: 1664K
    1473404.51[ 13.333856] Run /sbin/init as init process
    1473405.10[ 13.915663] systemd[1]: System time before build time, advancing clock.
    1473405.26[ 14.073943] NET: Registered protocol family 10
    1473405.26[ 14.079422] Segment Routing with IPv6
    1473405.32[ 14.121682] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    1473405.34[ 14.143445] systemd[1]: Detected architecture arm64.
    1473405.35
    1473405.35Welcome to [1mArago 2020.09[0m!
    1473405.35
    1473405.37[ 14.191268] systemd[1]: Set hostname to <j7-evm>.
    1473405.71[ 14.532787] random: crng init done
    1473405.93[ 14.732824] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    1473406.04[ 14.853333] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    1473406.04[ 14.865694] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    1473406.06[ 14.875726] systemd[1]: Created slice system-getty.slice.
    1473406.06[[0;32m OK [0m] Created slice [0;1;39msystem-getty.slice[0m.
    1473406.07[ 14.898595] systemd[1]: Created slice system-serial\x2dgetty.slice.
    1473406.09[[0;32m OK [0m] Created slice [0;1;39msystem-serial\x2dgetty.slice[0m.
    1473406.10[ 14.918442] systemd[1]: Created slice User and Session Slice.
    1473406.10[[0;32m OK [0m] Created slice [0;1;39mUser and Session Slice[0m.
    1473406.12[ 14.942079] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    1473406.14[[0;32m OK [0m] Started [0;1;39mDispatch Password …ts to Console Directory Watch[0m.
    1473406.15[ 14.965973] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    1473406.15[[0;32m OK [0m] Started [0;1;39mForward Password R…uests to Wall Directory Watch[0m.
    1473406.17[ 14.989944] systemd[1]: Reached target Paths.
    1473406.18[[0;32m OK [0m] Reached target [0;1;39mPaths[0m.
    1473406.18[ 15.005890] systemd[1]: Reached target Remote File Systems.
    1473406.20[[0;32m OK [0m] Reached target [0;1;39mRemote File Systems[0m.
    1473406.21[ 15.025883] systemd[1]: Reached target Slices.
    1473406.21[[0;32m OK [0m] Reached target [0;1;39mSlices[0m.
    1473406.21[ 15.041887] systemd[1]: Reached target Swap.
    1473406.23[[0;32m OK [0m] Reached target [0;1;39mSwap[0m.
    1473406.25[ 15.059978] systemd[1]: Listening on RPCbind Server Activation Socket.
    1473406.25[[0;32m OK [0m] Listening on [0;1;39mRPCbind Server Activation Socket[0m.
    1473406.28[ 15.081911] systemd[1]: Reached target RPC Port Mapper.
    1473406.28[[0;32m OK [0m] Reached target [0;1;39mRPC Port Mapper[0m.
    1473406.29[ 15.105787] systemd[1]: Listening on Process Core Dump Socket.
    1473406.31[[0;32m OK [0m] Listening on [0;1;39mProcess Core Dump Socket[0m.
    1473406.31[ 15.126032] systemd[1]: Listening on initctl Compatibility Named Pipe.
    1473406.31[[0;32m OK [0m] Listening on [0;1;39minitctl Compatibility Named Pipe[0m.
    1473406.37[ 15.185417] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    1473406.39[ 15.194761] systemd[1]: Listening on Journal Socket (/dev/log).
    1473406.40[[0;32m OK [0m] Listening on [0;1;39mJournal Socket (/dev/log)[0m.
    1473406.40[ 15.218172] systemd[1]: Listening on Journal Socket.
    1473406.42[[0;32m OK [0m] Listening on [0;1;39mJournal Socket[0m.
    1473406.43[ 15.235170] systemd[1]: Listening on Network Service Netlink Socket.
    1473406.43[[0;32m OK [0m] Listening on [0;1;39mNetwork Service Netlink Socket[0m.
    1473406.45[ 15.261033] systemd[1]: Listening on udev Control Socket.
    1473406.46[[0;32m OK [0m] Listening on [0;1;39mudev Control Socket[0m.
    1473406.46[ 15.282054] systemd[1]: Listening on udev Kernel Socket.
    1473406.48[[0;32m OK [0m] Listening on [0;1;39mudev Kernel Socket[0m.
    1473406.48[ 15.304834] systemd[1]: Mounting Huge Pages File System...
    1473406.50 Mounting [0;1;39mHuge Pages File System[0m...
    1473406.51[ 15.324557] systemd[1]: Mounting POSIX Message Queue File System...
    1473406.51 Mounting [0;1;39mPOSIX Message Queue File System[0m...
    1473406.53[ 15.344754] systemd[1]: Mounting Kernel Debug File System...
    1473406.54 Mounting [0;1;39mKernel Debug File System[0m...
    1473406.56[ 15.365944] systemd[1]: Mounting Temporary Directory (/tmp)...
    1473406.57 Mounting [0;1;39mTemporary Directory (/tmp)[0m...
    1473406.59[ 15.389790] systemd[1]: Starting Create list of static device nodes for the current kernel...
    1473406.59 Starting [0;1;39mCreate list of st…odes for the current kernel[0m...
    1473406.62[ 15.417248] systemd[1]: Starting Start psplash boot splash screen...
    1473406.62 Starting [0;1;39mStart psplash boot splash screen[0m...
    1473406.65[ 15.458706] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
    1473406.65[[0;32m OK [0m] Started [0;1;39mHardware RNG Entropy Gatherer Daemon[0m.
    1473406.68[ 15.487532] systemd[1]: Starting RPC Bind...
    1473406.68 Starting [0;1;39mRPC Bind[0m...
    1473406.70[ 15.506360] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    1473406.71[ 15.519187] systemd[1]: Starting Journal Service...
    1473406.73 Starting [0;1;39mJournal Service[0m...
    1473406.76[ 15.576446] systemd[1]: Starting Load Kernel Modules...
    1473406.78 Starting [0;1;39mLoad Kernel Modules[0m...
    1473406.78[ 15.600735] systemd[1]: Starting Remount Root and Kernel File Systems...
    1473406.81 Starting [0;1;39mRemount Root and Kernel File Systems[0m...
    1473406.81[ 15.624454] systemd[1]: Starting udev Coldplug all Devices...
    1473406.81 Starting [0;1;39mudev Coldplug all Devices[0m...
    1473406.84[ 15.644148] systemd[1]: Mounted Huge Pages File System.
    1473406.84[[0;32m OK [0m] Mounted [0;1;39mHuge Pages File System[0m.
    1473406.84[ 15.658419] systemd[1]: Mounted POSIX Message Queue File System.
    1473406.85[[0;32m OK [0m] Mounted [0;1;39mPOSIX Message Queue File System[0m.
    1473406.87[ 15.682381] systemd[1]: Mounted Kernel Debug File System.
    1473406.87[[0;32m OK [0m] Mounted [0;1;39mKernel Debug File System[0m.
    1473406.90[ 15.706399] systemd[1]: Started RPC Bind.
    1473406.90[[0;32m OK [0m] Started [0;1;39mRPC Bind[0m.
    1473406.90[ 15.718273] cryptodev: loading out-of-tree module taints kernel.
    1473406.92[ 15.724634] systemd[1]: Started Journal Service.
    1473406.92[[0;32m OK [0m] Started [0;1;39mJournal Service[0m.
    1473406.93[ 15.737366] cryptodev: driver 1.10 loaded.
    1473406.95[[0;32m OK [0m] Mounted [0;1;39mTemporary Directory (/tmp)[0m.
    1473406.95[[0;32m OK [0m] Started [0;1;39mCreate list of sta… nodes for the current kernel[0m.
    1473406.96[[0;1;31mFAILED[0m] Failed to start [0;1;39mStart psplash boot splash screen[0m.
    1473407.00See 'systemctl status psplash-start.service' for details.
    1473407.01[[0;1;38;5;185mDEPEND[0m] Dependency failed for [0;1;39mStar…progress communication helper[0m.
    1473407.01[[0;32m OK [0m] Started [0;1;39mLoad Kernel Modules[0m.
    1473407.04[[0;32m OK [0m] Started [0;1;39mRemount Root and Kernel File Systems[0m.
    1473407.07 Mounting [0;1;39mKernel Configuration File System[0m...
    1473407.07 Starting [0;1;39mFlush Journal to Persistent Storage[0m...
    1473407.07 Starting [0;1;39mApply Kernel Variables[0m...
    1473407.10[ 15.907978] systemd-journald[171]: Received client request to flush runtime journal.
    1473407.10 Starting [0;1;39mCreate Static Device Nodes in /dev[0m...
    1473407.10[[0;32m OK [0m] Mounted [0;1;39mKernel Configuration File System[0m.
    1473407.14[[0;32m OK [0m] Started [0;1;39mFlush Journal to Persistent Storage[0m.
    1473407.17[[0;32m OK [0m] Started [0;1;39mApply Kernel Variables[0m.
    1473407.20[[0;32m OK [0m] Started [0;1;39mCreate Static Device Nodes in /dev[0m.
    1473407.21[[0;32m OK [0m] Reached target [0;1;39mLocal File Systems (Pre)[0m.
    1473407.23 Mounting [0;1;39m/media/ram[0m...
    1473407.25 Mounting [0;1;39m/var/volatile[0m...
    1473407.28 Starting [0;1;39mudev Kernel Device Manager[0m...
    1473407.28[[0;32m OK [0m] Mounted [0;1;39m/media/ram[0m.
    1473407.28[[0;32m OK [0m] Mounted [0;1;39m/var/volatile[0m.
    1473407.31[[0;32m OK [0m] Started [0;1;39mudev Coldplug all Devices[0m.
    1473407.34 Starting [0;1;39mLoad/Save Random Seed[0m...
    1473407.37[[0;32m OK [0m] Reached target [0;1;39mLocal File Systems[0m.
    1473407.40 Starting [0;1;39mCreate Volatile Files and Directories[0m...
    1473407.42[[0;32m OK [0m] Started [0;1;39mLoad/Save Random Seed[0m.
    1473407.57[[0;32m OK [0m] Started [0;1;39mudev Kernel Device Manager[0m.
    1473407.62[[0;32m OK [0m] Started [0;1;39mCreate Volatile Files and Directories[0m.
    1473407.65[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Time Synchronization[0m.
    1473407.68See 'systemctl status systemd-timesyncd.service' for details.
    1473407.68[[0;32m OK [0m] Reached target [0;1;39mSystem Time Set[0m.
    1473407.71[[0;32m OK [0m] Reached target [0;1;39mSystem Time Synchronized[0m.
    1473407.71 Starting [0;1;39mUpdate UTMP about System Boot/Shutdown[0m...
    1473407.75[[0;32m OK [0m] Stopped [0;1;39mNetwork Time Synchronization[0m.
    1473407.76[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Time Synchronization[0m.
    1473407.79See 'systemctl status systemd-timesyncd.service' for details.
    1473407.79[[0;32m OK [0m] Stopped [0;1;39mNetwork Time Synchronization[0m.
    1473407.82[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Time Synchronization[0m.
    1473407.87See 'systemctl status systemd-timesyncd.service' for details.
    1473407.87[[0;32m OK [0m] Started [0;1;39mUpdate UTMP about System Boot/Shutdown[0m.
    1473407.90[[0;32m OK [0m] Stopped [0;1;39mNetwork Time Synchronization[0m.
    1473407.92[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Time Synch[ 16.720217] rti-wdt 2200000.watchdog: heartbeat 60 sec
    1473407.92ronization[0m.
    1473407.92See 'systemctl status systemd-timesyncd.service' for details.
    1473407.95[[0;32m OK [0m] Reached target [0;1;39mSystem Initialization[0m.
    1473407.98[[0;32m OK [0m] Started [0;1;39mDaily rotation of log files[0m.
    1473408.00[[0;32m OK [0m] Started [0;1;39mDaily Cleanup of Temporary Directories[0m.
    1473408.00[[0;32m OK [0m] Reached target [0;1;39mTimers[0m.
    1473408.03[[0;32m OK [0m] Listening on [0;1;39mAvahi mDNS/DNS-SD Stack Activation Socket[0m.
    1473408.04[[0;32m OK [0m] Listening on [0;1;39mD-Bus System Message Bus Socket[0m.
    1473408.07 Starting [0;1;39mDocker Socket for the API[0m.
    1473408.10[ 16.914566] rti-wdt 2210000.watchdog: heartbeat 60 sec
    1473408.15[[0;32m OK [0m] Listening on [0;1;39mdropbear.socket[0m.
    1473408.17 Starting [0;1;39mReboot and dump vmcore via kexec[0m...
    1473408.17[[0;32m OK [0m] Listening on [0;1;39mDocker Socket for the API[0m.
    1473408.20[[0;32m OK [0m] Reached target [0;1;39mSockets[0m.
    1473408.21[[0;32m OK [0m] Reached target [0;1;39mBasic System[0m.
    1473408.21[[0;32m OK [0m] Started [0;1;39mJob spooling tools[0m.
    1473408.26[[0;32m OK [0m] Started [0;1;39mPeriodic Command Scheduler[0m.
    1473408.29[[0;32m OK [0m] Started [0;1;39mD-Bus System Message Bus[0m.
    1473408.31 Starting [0;1;39mPrint notice about GPLv3 packages[0m...
    1473408.34 Starting [0;1;39mIPv6 Packet Filtering Framework[0m...
    1473408.35 Starting [0;1;39mIPv4 Packet Filtering Framework[0m...
    1473408.35[[0;32m OK [0m] Started [0;1;39mirqbalance daemon[0m[ 17.139690] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    1473408.35.
    1473408.35 Starting [0;1;39mrc.pvr.service[0m...
    1473408.35[[0;1;31mFAILED[0m] Failed to start [0;1;39mLogin Service[0m.
    1473408.35See 'systemctl status systemd-logind.service' for details.
    1473408.35[[0;32m OK [0m] Stopped [0;1;39mNetwork Time Synchronization[0m.
    1473408.39[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Tim[ 17.178942] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
    1473408.40e Synchronization[0m.
    1473408.40See 'systemctl status systemd-timesyncd.service' for details.
    1473408.40[[0;32m OK [0m] Stopped [0;1;39mLogin Service[0m.
    1473408.40[[0;1;31mFAILED[0m] Failed to start [0;1;39mLogin Service[0m.
    1473408.40See 'systemctl status systemd-logind.service' for details.
    1473408.40[[0;32m OK [0m] Stopped [0;1;39mNetwork Time[ 17.211109] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
    1473408.40 Synchronization[0m.
    1473408.43[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Time Synchronization[0m.
    1473408.45See 'systemctl status systemd-timesyncd.service' for details.
    1473408.45[[0;32m OK [0m] Stopped [0;1;39mLogin Service[0m.
    1473408.45[[0;1;31mFAILED[0m] Failed to start [0;1;39mLogin Service[0m.
    1473408.45See 'systemctl status systemd-logind.service' for details.
    1473408.45[[0;32m OK [0m] Stopped [0;[ 17.249650] remoteproc remoteproc0: 4d80800000.dsp is available
    1473408.451;39mLogin Service[0m.
    1473408.48[[0;32m OK [0m] Stopped [0;1;39mLogin Service[0m.
    1473408.50[[0;1;31mFAILED[0m] Failed to start [0;1;39mLogin Service[0m.
    1473408.50See 'systemctl status systemd-logind.service' for details.
    1473408.50[[0;32m OK [0m] Stopped [0;1;39mLogin Service[0m.
    1473408.50[[0;1;31mFAILED[0m] Failed to start [0;1;39mLogin Se[ 17.298508] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    1473408.50rvice[0m.
    1473408.54[ 17.319350] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
    1473408.54[ 17.334411] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
    1473408.54[ 17.349674] remoteproc remoteproc1: 4d81800000.dsp is available
    1473408.57[ 17.368835] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    1473408.59[ 17.397244] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    1473408.62[ 17.420606] remoteproc remoteproc2: 64800000.dsp is available
    1473408.95[ 17.770482] PVR_K: 198: Read BVNC 22.104.208.318 from HW device registers
    1473408.98[ 17.782955] PVR_K: 198: RGX Device initialised with BVNC 22.104.208.318
    1473409.01[ 17.801585] [drm] Initialized pvr 1.10.5371573 20170530 for 4e20000000.gpu on minor 0
    1473409.07[ 17.892867] remoteproc remoteproc0: powering up 4d80800000.dsp
    1473409.10[ 17.898800] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 1579152
    1473409.10[ 17.913445] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200000
    1473409.10[ 17.926957] remoteproc remoteproc1: powering up 4d81800000.dsp
    1473409.14[ 17.933126] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 1579152
    1473409.15[ 17.941424] remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
    1473409.15[ 17.962170] virtio_rpmsg_bus virtio0: rpmsg host is online
    1473409.17[ 17.969266] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200000
    1473409.18[ 17.979990] remoteproc0#vdev0buffer: registered virtio0 (type 7)
    1473409.18[ 17.986136] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
    1473409.20[ 17.999436] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    1473409.21[ 18.007745] remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
    1473409.21[ 18.028443] virtio_rpmsg_bus virtio1: rpmsg host is online
    1473409.25[ 18.037991] remoteproc1#vdev0buffer: registered virtio1 (type 7)
    1473409.25[ 18.044104] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
    1473409.28[ 18.066989] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    1473409.31[ 18.113080] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    1473409.31[ 18.121037] [drm] No driver support for vblank timestamp query.
    1473409.34[ 18.138986] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
    1473409.34[ 18.148009] [drm] Cannot find any crtc or sizes
    1473409.60[ 18.414550] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    1473409.64[ 18.453085] platform 41000000.r5f: configured R5F for IPC-only mode
    1473409.67[ 18.476003] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    1473409.71[ 18.531617] remoteproc remoteproc3: 41000000.r5f is available
    1473409.78[ 18.593063] platform 5c00000.r5f: configured R5F for remoteproc mode
    1473409.81[ 18.620591] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    1473409.84[ 18.639077] remoteproc remoteproc4: 5c00000.r5f is available
    1473409.84[ 18.655417] platform 5d00000.r5f: configured R5F for remoteproc mode
    1473409.87[ 18.682267] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    1473409.89[ 18.700096] remoteproc remoteproc3: Direct firmware load for j7-mcu-r5f0_0-fw failed with error -2
    1473409.90[ 18.711829] remoteproc remoteproc3: powering up 41000000.r5f
    1473409.90[ 18.720382] remoteproc remoteproc3: Direct firmware load for j7-mcu-r5f0_0-fw failed with error -2
    1473409.92[ 18.720947] remoteproc remoteproc5: 5d00000.r5f is available
    1473409.93[ 18.732782] remoteproc remoteproc3: request_firmware failed: -2
    1473409.96[ 18.784794] platform 5e00000.r5f: configured R5F for remoteproc mode
    1473410.00[ 18.802175] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    1473410.00[ 18.821363] remoteproc remoteproc6: 5e00000.r5f is available
    1473410.03[ 18.837166] platform 5f00000.r5f: configured R5F for remoteproc mode
    1473410.06[ 18.862142] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    1473410.06[ 18.874266] remoteproc remoteproc7: 5f00000.r5f is available
    1473410.20[ 19.014850] remoteproc remoteproc2: powering up 64800000.dsp
    1473410.21[ 19.014863] remoteproc remoteproc5: Direct firmware load for j7-main-r5f0_1-fw failed with error -2
    1473410.21[ 19.020527] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 9969648
    1473410.21[ 19.027215] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8200000
    1473410.23[ 19.034770] remoteproc remoteproc5: powering up 5d00000.r5f
    1473410.25[ 19.051439] remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
    1473410.25[ 19.055892] remoteproc remoteproc5: Direct firmware load for j7-main-r5f0_1-fw failed with error -2
    1473410.25[ 19.063654] virtio_rpmsg_bus virtio2: rpmsg host is online
    1473410.28[ 19.073053] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
    1473410.28[ 19.079664] remoteproc2#vdev0buffer: registered virtio2 (type 7)
    1473410.28[ 19.086885] remoteproc remoteproc5: request_firmware failed: -2
    1473410.28[ 19.089541] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
    1473410.29[ 19.095436] remoteproc remoteproc6: powering up 5e00000.r5f
    1473410.29[ 19.109857] remoteproc remoteproc2: remote processor 64800000.dsp is now up
    1473410.31[ 19.116913] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
    1473410.31[ 19.117059] remoteproc remoteproc7: powering up 5f00000.r5f
    1473410.32[ 19.134582] remoteproc remoteproc6: request_firmware failed: -2
    1473410.32[ 19.137963] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
    1473410.34[ 19.149401] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    1473410.34[ 19.153854] remoteproc remoteproc7: request_firmware failed: -2
    1473410.37[ 19.176334] CAN device driver interface
    1473410.57[ 19.383790] m_can_platform 40528000.can: m_can device registered (irq=15, version=32)
    1473410.60[ 19.426436] m_can_platform 40568000.can: m_can device registered (irq=17, version=32)
    1473410.68[ 19.504670] remoteproc remoteproc4: powering up 5c00000.r5f
    1473410.70[ 19.510467] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 5212504
    1473410.71[ 19.527428] platform 5c00000.r5f: Allocated carveout doesn't fit device address request
    1473410.71[ 19.539019] platform 5c00000.r5f: Allocated carveout doesn't fit device address request
    1473410.73[ 19.551973] remoteproc remoteproc4: bad phdr da 0xa1100000 mem 0x8c
    1473410.75[ 19.563182] remoteproc remoteproc4: Failed to load program segments: -22
    1473411.03[[0;32m OK [0m] Started [0;1;39mReboot and dump vmcore via kexec[0m.
    1473411.04[[0;32m OK [0m] Started [0;1;39mIPv6 Packet Filtering Framework[0m.
    1473411.04[[0;32m OK [0m] Started [0;1;39mIPv4 Packet Filtering Framework[0m.
    1473411.04[[0;32m OK [0m] Reached target [0;1;39mNetwork (Pre)[0m.
    1473411.06 Starting [0;1;39mNetwork Service[0m...
    1473411.32[[0;32m OK [0m] Started [0;1;39mNetwork Service[0m.
    1473411.34 Starting [0;1;39mWait for Network to be Configured[0m...
    1473411.35[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Name Resolution[0m.
    1473411.37See 'systemctl status systemd-resolved.service' for details.
    1473411.37[[0;32m OK [0m] Reached target [0;1;39mNetwork[0m.
    1473411.37[[0;32m OK [0m] Reached target [0;1;39mHost and Network Name Lookups[0m.
    1473411.39 Starting [0;1;39mAvahi mDNS/DNS-SD Stack[0m...
    1473411.42[[0;32m OK [0m] Started [0;1;39mNFS status monitor for NFSv2/3 locking.[0m.
    1473411.42 Starting [0;1;39mSimple Network Ma…ent Protocol (SNMP) Daemon.[0m...
    1473411.43 Starting [0;1;39mPermit User Sessions[0m...
    1473411.43[[0;32m OK [0m] Stopped [0;1;39mNetwork Name Resolution[0m.
    1473411.46[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Name Resolution[0m.
    1473411.46See 'systemctl status systemd-resolved.service' for details.
    1473411.48[[0;32m OK [0m] Stopped [0;1;39mNetwork Name Resolution[0m.
    1473411.50[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Name Resolution[0m.
    1473411.50See 'systemctl status systemd-resolved.service' for details.
    1473411.50[[0;32m OK [0m] Stopped [0;1;39mNetwork Name Resolution[0m.
    1473411.51See 'systemctl status systemd-resolved.service' for details.
    1473411.53[[0;32m OK [0m] Stopped [0;1;39mNetwork Name Resolution[0m.
    1473411.53[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Name Resolution[0m.
    1473411.53See 'systemctl status systemd-resolved.service' for details.
    1473411.56[[0;1;31mFAILED[0m] Failed to start [0;1;39mNetwork Name Resolution[0m.
    1473411.57See 'systemctl status systemd-resolved.service' for details.
    1473411.59[[0;32m OK [0m] Started [0;1;39mPermit User Sessions[0m.
    1473411.60[[0;32m OK [0m] Started [0;1;39mGetty on tty1[0m.
    1473411.62[[0;32m OK [0m] Started [0;1;39mSerial Getty on ttyS2[0m.
    1473411.64[[0;32m OK [0m] Started [0;1;39mSerial Getty on ttyS3[0m.
    1473411.64[[0;32m OK [0m] Reached target [0;1;39mLogin Prompts[0m.
    1473411.64 Starting [0;1;39mSynchronize System and HW clocks[0m...
    1473411.70[[0;1;31mFAILED[0m] Failed to start [0;1;39mSynchronize System and HW clocks[0m.
    1473411.73See 'systemctl status sync-clocks.service' for details.
    1473411.73[[0;32m OK [0m] Started [0;1;39mAvahi mDNS/DNS-SD Stack[0m.
    1473412.12[ 20.942521] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473412.15[ 20.967164] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.59[ 22.404513] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.62[ 22.413981] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.65[ 22.436195] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.67[[0;32m OK [0m] Created slice [0;1;39msystem-weston.slice[0[ 22.445762] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.67m.
    1473413.68[ 22.463154] remoteproc remoteproc8: b034000.pru is available
    1473413.68[ 22.486561] pru-rproc b034000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@34000 probed successfully
    1473413.71[ 22.513489] remoteproc remoteproc9: b004000.rtu is available
    1473413.71[ 22.526845] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.71[ 22.536404] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.75[ 22.538022] pru-rproc b004000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@4000 probed successfully
    1473413.75[ 22.564117] pru-rproc b00a000.txpru: IRQ vring not found
    1473413.78[[0;32m OK [0m] Started [0;1;39mWeston Wayland Compositor[0m.
    1473413.78[[0;32m OK [0m] Started [0;1;39mrc.pvr.service[0m.
    1473413.78[ 22.578241] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.78 Starting [0;1;39mweston.service[0m...
    1473413.79[ 22.589055] pru-rproc b00a000.txpru: IRQ kick not found
    1473413.79[ 22.593849] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.81[ 22.607291] remoteproc remoteproc10: b00a000.txpru is available
    1473413.82[ 22.630079] pru-rproc b00a000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@a000 probed successfully
    1473413.84[ 22.651552] remoteproc remoteproc11: b038000.pru is available
    1473413.85[ 22.665139] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.87[ 22.674670] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.89[ 22.688199] pru-rproc b038000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@38000 probed successfully
    1473413.92[ 22.715835] remoteproc remoteproc12: b006000.rtu is available
    1473413.92[ 22.728460] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.95[ 22.737875] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.95[ 22.745031] pru-rproc b006000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@6000 probed successfully
    1473413.95[ 22.763184] pru-rproc b00c000.txpru: IRQ vring not found
    1473413.98[ 22.772895] pru-rproc b00c000.txpru: IRQ kick not found
    1473413.98[ 22.781404] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473413.98[ 22.790869] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473413.98[ 22.799072] remoteproc remoteproc13: b00c000.txpru is available
    1473414.01[ 22.810240] pru-rproc b00c000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@c000 probed successfully
    1473414.01[ 22.828522] remoteproc remoteproc14: b134000.pru is available
    1473414.04[ 22.841672] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.04[ 22.850891] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.07[ 22.865319] pru-rproc b134000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@34000 probed successfully
    1473414.10[ 22.903381] remoteproc remoteproc15: b104000.rtu is available
    1473414.10[ 22.917765] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.12[ 22.926668] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.14[ 22.936571] pru-rproc b104000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@4000 probed successfully
    1473414.15[ 22.962095] pru-rproc b10a000.txpru: IRQ vring not found
    1473414.17[ 22.973905] pru-rproc b10a000.txpru: IRQ kick not found
    1473414.17[ 22.975059] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.18[ 22.980673] remoteproc remoteproc16: b10a000.txpru is available
    1473414.18[ 22.989758] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.18[ 23.001117] pru-rproc b10a000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@a000 probed successfully
    1473414.21[ 23.019028] remoteproc remoteproc17: b138000.pru is available
    1473414.21[ 23.031328] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.23[ 23.039277] pru-rproc b138000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@38000 probed successfully
    1473414.25[ 23.048881] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.25[ 23.055148] remoteproc remoteproc18: b106000.rtu is available
    1473414.25[ 23.066421] pru-rproc b106000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@6000 probed successfully
    1473414.26[ 23.078000] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.28[ 23.084189] pru-rproc b10c000.txpru: IRQ vring not found
    1473414.28[ 23.089862] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.28[ 23.097608] pru-rproc b10c000.txpru: IRQ kick not found
    1473414.31[ 23.110825] remoteproc remoteproc19: b10c000.txpru is available
    1473414.31[ 23.111045] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.31[ 23.122891] pru-rproc b10c000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@c000 probed successfully
    1473414.32[ 23.129850] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.34[ 23.155647] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.35[ 23.167056] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.42[[0;32m OK [0m] Started [0;1;39mweston.service[0m.
    1473414.42 Starting [0;1;39mDEMO[0m...
    1473414.43 Starting [0;1;39mtelnetd.service[0m...
    1473414.48[ 23.295003] cdns-usb3 6000000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
    1473414.51[[0;32m OK [0m] Started [0;1;39mDEMO[0m.
    1473414.54[[0;32m OK [0m] Started [0;1;39mtelnetd.service[0m.
    1473414.59[[0;32m OK [0m] Started [0;1;39mSimple Network Man…ement Protocol (SNMP) Daemon.[0m.
    1473414.81[ 23.621881] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.82[ 23.630883] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473414.90[ 23.719869] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    1473414.93[ 23.746345] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473414.93[ 23.756213] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473415.17[ 23.978748] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473415.17[ 23.988370] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473415.28[ 24.094889] cdns-usb3 6400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
    1473415.29[ 24.102940] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473415.29[ 24.110460] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473415.32[ 24.139115] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473415.34[ 24.149968] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473415.54[ 24.364431] usbcore: registered new interface driver usbfs
    1473415.56[ 24.382387] usbcore: registered new interface driver hub
    1473415.57[ 24.398714] usbcore: registered new device driver usb
    1473415.67[[0;32m OK [0m] Started [0;1;39mWait for Network to be Configured[0m.
    1473415.68[[0;32m OK [0m] Reached target [0;1;39mNetwork is Online[0m.
    1473415.68 Starting [0;1;39mLSB: start and stop d[ 24.500443] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    1473415.68ocker[0m...
    1473415.70 Starting [0;1;39mDocker Application Container Engine[0m...
    1473415.70 Starting [0;1;39mLSB: network benchmark[0m...
    1473415.71[[0;32m OK [0m] Started [0;1;39mstrongSwan IPsec I…IKEv2[ 24.523925] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    1473415.71 daemon using ipsec.conf[0m.
    1473415.75[ 24.545497] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
    1473415.75[ 24.565632] xhci-hcd xhci-hcd.2.auto: irq 597, io mem 0x06010000
    1473415.78[ 24.580884] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    1473415.78[ 24.596438] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    1473415.81[ 24.609117] usb usb1: Product: xHCI Host Controller
    1473415.81[ 24.617877] usb usb1: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
    1473415.81[ 24.630017] usb usb1: SerialNumber: xhci-hcd.2.auto
    1473415.85[ 24.641301] hub 1-0:1.0: USB hub found
    1473415.85[ 24.647895] hub 1-0:1.0: 1 port detected
    1473415.85[ 24.656298] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    1473415.85[ 24.662717] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473415.87[ 24.673081] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473415.87[ 24.683428] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    1473415.89[ 24.694900] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_edid_block [cdns_mhdp]] *ERROR* get block[0] edid failed: -22
    1473415.89[ 24.706033] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_modes [cdns_mhdp]] *ERROR* Failed to read EDID
    1473415.90[ 24.717686] Console: switching to colour frame buffer device 128x48
    1473415.90[ 24.723982] tidss 4a00000.dss: fb0: tidssdrmfb frame buffer device
    1473415.92[ 24.741253] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    1473415.95[ 24.762206] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    1473415.96[ 24.788434] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
    1473416.00[ 24.804580] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    1473416.00[ 24.814045] usb usb2: Product: xHCI Host Controller
    1473416.01[ 24.829138] usb usb2: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
    1473416.03[ 24.849222] usb usb2: SerialNumber: xhci-hcd.2.auto
    1473416.04[ 24.864080] hub 2-0:1.0: USB hub found
    1473416.06[ 24.874048] hub 2-0:1.0: 1 port detected
    1473416.07[ 24.885116] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473416.09[ 24.894579] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
    1473416.09[ 24.900298] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473416.09[ 24.901907] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3
    1473416.10[ 24.916471] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473416.12[ 24.922031] xhci-hcd xhci-hcd.3.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
    1473416.12[ 24.925888] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473416.12[ 24.940913] xhci-hcd xhci-hcd.3.auto: irq 600, io mem 0x06410000
    1473416.15[ 24.951046] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    1473416.15[ 24.966006] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    1473416.15[ 24.977983] usb usb3: Product: xHCI Host Controller
    1473416.17[ 24.983495] usb usb3: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
    1473416.18[[0;32m OK [0m[ 24.999739] usb usb3: SerialNumber: xhci-hcd.3.auto
    1473416.18] Started [0;1;39mLSB: network benchmark[0m.
    1473416.18[ 25.010609] hub 3-0:1.0: USB hub found
    1473416.21[ 25.018966] hub 3-0:1.0: 1 port detected
    1473416.21[ 25.028362] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
    1473416.23[ 25.041702] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473416.25[ 25.050970] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4
    1473416.25[ 25.058910] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473416.25[ 25.067181] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
    1473416.28[ 25.075598] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    1473416.28[ 25.088717] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
    1473416.28[ 25.101886] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    1473416.29[ 25.113560] usb usb4: Product: xHCI Host Controller
    1473416.31[ 25.121884] usb usb4: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
    1473416.31[ 25.132261] usb usb4: SerialNumber: xhci-hcd.3.auto
    1473416.32[ 25.140638] hub 4-0:1.0: USB hub found
    1473416.34[ 25.148386] hub 4-0:1.0: 1 port detected
    1473416.34[ 25.162504] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    1473416.35[ 25.171889] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    1473416.46[[0;32m OK [0m] Started [0;1;39mLSB: start and stop docker[0m.
    1473416.46 Starting [0;1;39mthermal-zone-init.service[0m...
    1473417.79
    1473417.81 _____ _____ _ _
    1473417.81| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
    1473417.81| | _| .'| . | . | | __| _| . | | | -_| _| _|
    1473417.81|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
    1473417.82 |___| |___|
    1473417.82
    1473417.82Arago Project http://arago-project.org j7-evm ttyS2
    1473417.82
    1473417.84Arago 2020.09 j7-evm ttyS2
    1473417.84
    1473420.39j7-evm login: [ 29.206400] Initializing XFRM netlink socket
    1473423.37root
    1473423.39[ 32.199946] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_edid_block [cdns_mhdp]] *ERROR* get block[0] edid failed: -22
    1473423.40[ 32.210958] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_modes [cdns_mhdp]] *ERROR* Failed to read EDID
    1473423.40root
    1473423.92[ 32.736948] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473423.93[ 32.747945] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473423.95[ 32.762907] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473423.96[ 32.773923] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473423.96[ 32.787466] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473423.98[ 32.797890] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.00[ 32.811541] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.01[ 32.823324] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.03[ 32.836930] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.03[ 32.847719] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.04[ 32.860916] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.06[ 32.871737] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.06
    1473424.07[ 32.884909] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.07
    1473424.07
    1473424.09[ 32.895286] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.09[ 32.910917] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.10[ 32.922643] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.12[ 32.935909] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.14[ 32.947721] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.15[ 32.962945] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.15[ 32.973903] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.17[ 32.987080] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.18[ 32.997894] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.20[ 33.010706] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.21[ 33.021692] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.21[ 33.035954] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.23[ 33.047648] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.25[ 33.060842] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.26[ 33.071639] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.28[ 33.085068] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.28[ 33.096165] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.29[ 33.110998] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.31[ 33.121941] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.32[ 33.135012] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.34[ 33.147416] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.34[ 33.160750] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.35[ 33.171753] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.37[ 33.186920] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.40[ 33.198473] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.40[ 33.211817] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.40[ 33.223622] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.42[ 33.236942] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.43[ 33.248387] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.45[ 33.263920] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.46[ 33.275497] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.48[ 33.288638] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.48[ 33.300212] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.50[ 33.314456] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.51[ 33.325276] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.53[ 33.338630] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.53[ 33.349507] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.54[ 33.362907] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.56[ 33.374909] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.57[ 33.387738] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.59[ 33.398721] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.60[ 33.411816] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.60[ 33.421879] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.62[ 33.434923] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.64[ 33.445767] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.64[ 33.459630] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.65[ 33.469922] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.67[ 33.484525] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.68[ 33.496347] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.70[ 33.510901] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.71[ 33.521891] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [cdns_mhdp]] *ERROR* Failed to read DPCD
    1473424.71[ 33.531039] cdns-mhdp a000000.dp-bridge: Failed to read receiver capabilities
    1473424.73[ 33.538330] cdns-mhdp a000000.dp-bridge: cdns_mhdp_sst_enable: Not enough BW for 1024x768 (0 lanes at 0 Mbps)
    1473425.53
    1473425.547[r[999;999H[6n8root@j7-evm:~#
    1473425.56root@j7-evm:~#
    1473425.87
    1473425.89root@j7-evm:~#
    1473425.90root@j7-evm:~#
    1473426.00
    1473426.01root@j7-evm:~#
    1473426.03root@j7-evm:~#
    1473426.21root@j7-evm:~# [ 35.031947] overlayfs: filesystem on '/var/lib/docker/check-overlayfs-support576318472/upper' not supported as upperdir
    1473426.28[ 35.090893] overlayfs: filesystem on '/var/lib/docker/check-overlayfs-support062080455/upper' not supported as upperdir
    1473426.53[ 35.333184] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    1473426.53[ 35.354488] Bridge firewalling registered
    1473427.62cd /
    1473427.64cd /
    1473427.65root@j7-evm:/#
    1473428.18ls
    1473428.20root@j7-evm:/# ls
    1473428.28bin dev home init linuxrc mnt proc sbin tmp var
    1473428.28boot etc include lib media opt run sys usr
    1473428.29root@j7-evm:/#
    1473430.57root@j7-evm:/# ***************************************************************
    1473430.57***************************************************************
    1473430.59NOTICE: This file system contains the following GPLv3 packages:
    1473430.59 autoconf
    1473430.59 bash-dev
    1473430.59 bash
    1473430.60 bc
    1473430.60 binutils
    1473430.60 cifs-utils
    1473430.60 coreutils-stdbuf
    1473430.60 cpio
    1473430.60 cpp-symlinks
    1473430.60 cpp
    1473430.60 dosfstools
    1473430.60 elfutils
    1473430.60 g++-symlinks
    1473430.60 g++
    1473430.60 gawk
    1473430.60 gcc-symlinks
    1473430.60 gcc
    1473430.60 gdb
    1473430.60 gdbserver
    1473430.60 gettext
    1473430.60 glmark2
    1473430.60 gstreamer1.0-libav
    1473430.60 gzip
    1473430.60 less
    1473430.60 libasm1
    1473430.60 libbfd
    1473430.60 libdw1
    1473430.62 libelf1
    1473430.62 libgdbm-compat4
    1473430.62 libgdbm-dev
    1473430.62 libgdbm6
    1473430.62 libgettextlib
    1473430.62 libgettextsrc
    1473430.62 libgmp10
    1473430.62 libidn2-0
    1473430.62 libmpc3
    1473430.62 libmpfr6
    1473430.62 libreadline-dev
    1473430.62 libreadline8
    1473430.62 libunistring2
    1473430.62 m4-dev
    1473430.62 m4
    1473430.62 make
    1473430.62 nettle
    1473430.62 parted
    1473430.64 tar
    1473430.64 which
    1473430.64
    1473430.64If you do not wish to distribute GPLv3 components please remove
    1473430.64the above packages prior to distribution. This can be done using
    1473430.64the opkg remove command. i.e.:
    1473430.65 opkg remove <package>
    1473430.65Where <package> is the name printed in the list above
    1473430.65
    1473430.67NOTE: If the package is a dependency of another package you
    1473430.67 will be notified of the dependent packages. You should
    1473430.67 use the --force-removal-of-dependent-packages option to
    1473430.67 also remove the dependent packages as well
    1473430.67***************************************************************
    1473430.68***************************************************************
    1473431.07[ 39.901874] tlv71033: disabling
    1473431.95cd opt
    1473431.96cd opt
    1473432.00root@j7-evm:/opt#
    1473432.39
    1473432.40root@j7-evm:/opt#
    1473432.42root@j7-evm:/opt#
    1473432.54
    1473432.56root@j7-evm:/opt#
    1473432.59root@j7-evm:/opt#
    1473432.76
    1473432.79root@j7-evm:/opt#
    1473432.81root@j7-evm:/opt#
    1473433.37ls
    1473433.39root@j7-evm:/opt# ls
    1473433.42containerd img-powervr-sdk ltp tidl_test vision_apps
    1473433.43root@j7-evm:/opt#
    1473436.81cd vision*
    1473436.84root@j7-evm:/opt# cd vision*
    1473436.85root@j7-evm:/opt/vision_apps#
    1473437.50ls
    1473437.53root@j7-evm:/opt/vision_apps# ls
    1473437.54app_avp.cfg run_app_tidl_seg_16bit.sh
    1473437.57app_avp2.cfg run_app_tidl_vl.sh
    1473437.57app_avp3.cfg run_ptk_demo.sh
    1473437.57app_avp4.cfg uEnv.txt
    1473437.57app_c7x.cfg vision_apps_init.sh
    1473437.57app_dof.cfg vx_app_arm_fd_exchange_consumer.out
    1473437.57app_encode.cfg vx_app_arm_fd_exchange_producer.out
    1473437.57app_multi_cam.cfg vx_app_arm_opengl_mosaic.out
    1473437.57app_oc.cfg vx_app_c7x_kernel.out
    1473437.57app_oc_16bit.cfg vx_app_conformance.out
    1473437.59app_od.cfg vx_app_dense_optical_flow.out
    1473437.60app_pcie_video_sink.cfg vx_app_dense_optical_flow2.out
    1473437.60app_pcie_video_source.cfg vx_app_dof_sfm_fisheye.out
    1473437.60app_seg.cfg vx_app_encode.out
    1473437.60app_seg_16bit.cfg vx_app_lidar_ogmap.out
    1473437.60app_single_cam.cfg vx_app_linux_arm_ipc.out
    1473437.60app_srv.cfg vx_app_linux_arm_mem.out
    1473437.60app_srv_avp_cfg vx_app_linux_arm_remote_log.out
    1473437.62app_stereo.cfg vx_app_load_test.out
    1473437.62app_tidl_cam.cfg vx_app_multi_cam.out
    1473437.64app_vl.cfg vx_app_sde.out
    1473437.64libtivision_apps.so.7.1.0 vx_app_sde_obstacle_detection.out
    1473437.64limits.conf vx_app_single_cam.out
    1473437.64ptk_app_cfg vx_app_srv_calibration.out
    1473437.64run_app_c7x.sh vx_app_srv_camera.out
    1473437.64run_app_dof.sh vx_app_srv_fileio.out
    1473437.65run_app_encode.sh vx_app_stereo_depth.out
    1473437.65run_app_multi_cam.sh vx_app_surround_radar_ogmap.out
    1473437.65run_app_single_cam.sh vx_app_test_framework.out
    1473437.65run_app_srv.sh vx_app_tidl.out
    1473437.67run_app_srv_avp.sh vx_app_tidl_avp.out
    1473437.67run_app_stereo.sh vx_app_tidl_avp2.out
    1473437.68run_app_tidl.sh vx_app_tidl_avp3.out
    1473437.68run_app_tidl_16bit.sh vx_app_tidl_avp4.out
    1473437.68run_app_tidl_avp.sh vx_app_tidl_cam.out
    1473437.68run_app_tidl_avp2.sh vx_app_tidl_od.out
    1473437.68run_app_tidl_avp3.sh vx_app_tidl_seg.out
    1473437.68run_app_tidl_avp4.sh vx_app_tidl_vl.out
    1473437.68run_app_tidl_cam.sh vx_app_tutorial.out
    1473437.70run_app_tidl_od.sh vx_app_valet_parking.out
    1473437.70run_app_tidl_seg.sh
    1473437.71root@j7-evm:/opt/vision_apps#
    1473451.65./vision_apps*
    1473451.67root@j7-evm:/opt/vision_apps# ./vision_apps*
    1473451.70root@j7-evm:/opt/vision_apps#
    1473451.71root@j7-evm:/opt/vision_apps# APP_LOG: ERROR: Unable to map memory @ 0xac000000 of size 262144 bytes !!!
    1473454.68
    1473454.71
    1473454.75root@j7-evm:/opt/vision_apps#
  • Apologize for a late reply.
    From your linux boot log you dont seem to have loaded vision_apps.dtbo. Please ensure you have loaded this overlay before booting Linux and starting any demo.
    name_overlays=k3-j721e-vision-apps.dtbo
