TDA4VM: Device boot failure
Part Number: TDA4VM
Hello E2E,
The device we are working with stopped booting correctly when using PSDK 6.2 build. When running PSDK 7.1 it works correctly, but we had to move back to PSDK 6.2 and after formatting the SD Card - with PSDK 6.2's file system, it would not boot correctly.
First we thought it was a file-system related issue, but it would not boot properly after changing SD cards and re-writing the file system as described in the documentation. The same SD card we are working with on the non-booting device works correctly with another working device, so this behavior doesn't seem to be file-system related.
A full boot log with PSDK 6_2 is attached - device hangs.
U-Boot SPL 2019.01-g350f3927b8 (Feb 07 2020 - 14:39:06 +0000)
SYSFW ABI: 2.9 (firmware rev 0x0013 '19.12.1-v2019.12a (Terrific Lla')
Trying to boot from MMC2
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Remoteproc 2 started successfully
** File not found /lib/firmware/j7-mcu-r5f0_0-fw **
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.2(release):ti2019.05-rc1
NOTICE:  BL31: Built : 12:19:54, Jan 27 2020
I/TC:
I/TC: OP-TEE version: ti2019.05-rc1-dev (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 Mon Jan 27 12:29:57 UTC 2020 aarch64
I/TC: Initialized
U-Boot SPL 2019.01-g350f3927b8 (Feb 07 2020 - 14:39:43 +0000)
Detected: J7X-BASE-CPB rev E2
Detected: J7X-INFOTAN-EXP rev E3
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2019.01-g350f3927b8 (Feb 07 2020 - 14:39:43 +0000)
SoC:   J721E PG 1.0
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM1-SOM rev E2
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from MMC... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:
Warning: ethernet@046000000 using MAC address from ROM
eth0: ethernet@046000000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
** Unable to read file boot.scr **
81 bytes read in 1 ms (79.1 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
2459460 bytes read in 54 ms (43.4 MiB/s)
Invalid op: Trying to load/start on already running core 6
Load Remote Processor 2 with data@addr=0x82000000 2459460 bytes: Failed!
4622296 bytes read in 99 ms (44.5 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 4622296 bytes: Success!
** File not found /lib/firmware/j7-main-r5f1_0-fw **
** File not found /lib/firmware/j7-main-r5f1_1-fw **
1447952 bytes read in 30 ms (46 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 1447952 bytes: Success!
Load Remote Processor 7 with data@addr=0x82000000 1447952 bytes: Success!
6954352 bytes read in 60 ms (110.5 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 6954352 bytes: Success!
13338632 bytes read in 281 ms (45.3 MiB/s)
99354 bytes read in 3 ms (31.6 MiB/s)
3779 bytes read in 1 ms (3.6 MiB/s)
   Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 4.19.94-g5a23bc00e0 (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Fri Feb 7 09:45:50 UTC 2020
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3e4 with crng_init=0
[    0.000000] percpu: Embedded 2 pages/cpu s48536 r8192 d74344 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for EL2 vector hardening
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 62339
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),57216k@8m(ospi.rootfs),128k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=ae971293-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes)
[    0.000000] software IO TLB: mapped [mem 0xdbff0000-0xdfff0000] (64MB)
[    0.000000] Memory: 3377664K/3993600K available (8510K kernel code, 738K rwdata, 3136K rodata, 576K init, 641K bss, 91648K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=2.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x00000008c00a0000
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] CPU0: using LPI pending table @0x00000008c00b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008378] Console: colour dummy device 80x25
[    0.012940] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023609] pid_max: default: 32768 minimum: 301
[    0.028354] Security Framework initialized
[    0.032561] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes)
[    0.039418] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes)
[    0.070762] ASID allocator initialised with 32768 entries
[    0.084292] rcu: Hierarchical SRCU implementation.
[    0.097255] Platform MSI: gic-its@1820000 domain created
[    0.102896] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created
[    0.120332] smp: Bringing up secondary CPUs ...
[    0.157246] Detected PIPT I-cache on CPU1
[    0.157269] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.157298] CPU1: using LPI pending table @0x00000008c0310000
[    0.157327] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.157381] smp: Brought up 1 node, 2 CPUs
[    0.185221] SMP: Total of 2 processors activated.
[    0.190032] CPU features: detected: GIC system register CPU interface
[    0.196613] CPU features: detected: 32-bit EL0 Support
[    0.202109] CPU: All CPU(s) started at EL2
[    0.206297] alternatives: patching kernel code
[    0.211412] devtmpfs: initialized
[    0.219929] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.229899] futex hash table entries: 512 (order: -1, 32768 bytes)
[    0.236936] pinctrl core: initialized pinctrl subsystem
[    0.242713] NET: Registered protocol family 16
[    0.247641] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.255207] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.264527] DMA: preallocated 256 KiB pool for atomic allocations
[    0.278476] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.285330] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.292861] cryptd: max_cpu_qlen set to 1000
[    0.297843] vsys_3v3: supplied by evm_12v0
[    0.302114] vsys_5v0: supplied by evm_12v0
[    0.306687] SCSI subsystem initialized
[    0.310775] media: Linux media interface: v0.10
[    0.315411] videodev: Linux video capture interface: v2.00
[    0.321025] pps_core: LinuxPPS API ver. 1 registered
[    0.326094] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.335431] PTP clock support registered
[    0.339441] EDAC MC: Ver: 3.0.0
[    0.343389] Advanced Linux Sound Architecture Driver Initialized.
[    0.350024] clocksource: Switched to clocksource arch_sys_counter
[    0.356336] VFS: Disk quotas dquot_6.6.0
[    0.360381] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.370001] NET: Registered protocol family 2
[    0.374786] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes)
[    0.382843] TCP established hash table entries: 32768 (order: 2, 262144 bytes)
[    0.390327] TCP bind hash table entries: 32768 (order: 3, 524288 bytes)
[    0.397400] TCP: Hash tables configured (established 32768 bind 32768)
[    0.404134] UDP hash table entries: 2048 (order: 0, 65536 bytes)
[    0.410321] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes)
[    0.417008] NET: Registered protocol family 1
[    0.421713] RPC: Registered named UNIX socket transport module.
[    0.427768] RPC: Registered udp transport module.
[    0.432571] RPC: Registered tcp transport module.
[    0.437374] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.444294] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.454011] Initialise system trusted keyrings
[    0.458643] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.466794] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.472976] NFS: Registering the id_resolver key type
[    0.478152] Key type id_resolver registered
[    0.482423] Key type id_legacy registered
[    0.486522] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.493448] 9p: Installing v9fs 9p2000 file system support
[    0.500591] Key type asymmetric registered
[    0.504779] Asymmetric key parser 'x509' registered
[    0.509791] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.517352] io scheduler noop registered
[    0.521358] io scheduler deadline registered
[    0.525767] io scheduler cfq registered (default)
[    0.530575] io scheduler mq-deadline registered
[    0.535202] io scheduler kyber registered
[    0.540238] pinctrl-single 4301c000.pinmux: 94 pins, size 376
[    0.546323] pinctrl-single 11c000.pinmux: 173 pins, size 692
[    0.552485] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[    0.561713] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.568137] ti-pat 31010000.pat: Failed to create 31010000.pat debugfs directory
[    0.575846] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.582258] ti-pat 31011000.pat: Failed to create 31011000.pat debugfs directory
[    0.589906] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.596318] ti-pat 31012000.pat: Failed to create 31012000.pat debugfs directory
[    0.603965] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.610286] ti-pat 31013000.pat: Failed to create 31013000.pat debugfs directory
[    0.617928] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.624250] ti-pat 31014000.pat: Failed to create 31014000.pat debugfs directory
[    0.633208] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.645032] brd: module loaded
[    0.651080] loop: module loaded
[    0.655542] libphy: Fixed MDIO Bus: probed
[    0.659899] tun: Universal TUN/TAP device driver, 1.6
[    0.665332] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    0.673335] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.679401] sky2: driver version 1.30
[    0.683794] VFIO - User Level meta-driver version: 0.3
[    0.689409] i2c /dev entries driver
[    0.693433] sdhci: Secure Digital Host Controller Interface driver
[    0.699749] sdhci: Copyright(c) Pierre Ossman
[    0.704403] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.710664] ledtrig-cpu: registered to indicate activity on CPUs
[    0.717709] optee: probing for conduit method from DT.
[    0.722981] optee: revision 3.7 (5208e5c1)
[    0.723162] optee: initialized driver
[    0.731867] NET: Registered protocol family 17
[    0.736481] 9pnet: Installing 9P2000 support
[    0.740868] Key type dns_resolver registered
[    0.745447] registered taskstats version 1
[    0.749631] Loading compiled-in X.509 certificates
[    0.759333] ti-sci 44083000.dmsc: ABI: 2.9 (firmware rev 0x0013 '19.12.1-v2019.12a (Terrific Lla')
[    0.784817] random: fast init done
[    0.828637] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.834586] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.840544] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.846577] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
[    0.853993] pca953x 3-0020: Linked as a consumer to regulator.0
[    0.882786] GPIO line 509 (VINOUT_MUX_SEL1) hogged as output/high
[    0.889332] GPIO line 508 (VINOUT_MUX_SEL0) hogged as output/low
[    0.895579] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
[    0.902979] pca953x 3-0022: Linked as a consumer to regulator.0
[    0.909854] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low
[    0.916579] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high
[    0.923167] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    0.929343] omap_i2c 2010000.i2c: bus 4 rev0.12 at 100 kHz
[    0.935239] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
[    0.941158] pca953x 6-0020: 6-0020 supply vcc not found, using dummy regulator
[    0.948568] pca953x 6-0020: Linked as a consumer to regulator.0
[    1.962154] pca953x 6-0020: failed reading register
[    1.967167] pca953x 6-0020: Dropping the link to regulator.0
[    1.972963] pca953x: probe of 6-0020 failed with error -16
[    1.978654] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[    1.984558] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[    1.990421] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[    1.996355] pca953x 9-0020: 9-0020 supply vcc not found, using dummy regulator
[    2.003759] pca953x 9-0020: Linked as a consumer to regulator.0
[    2.030446] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[    2.045886] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[    2.054644] cdns-pcie-host d000000.pcie: missing "mem"
[    2.060311] cdns-pcie-host d000000.pcie: Linked as a consumer to phy-5000000.serdes.0
[    3.069691] cdns-pcie-host d000000.pcie: Phy link never came up
[    3.075744] cdns-pcie-host d000000.pcie: host bridge /interconnect@100000/pcie@2900000/pcie@d000000 ranges:
[    3.085714] cdns-pcie-host d000000.pcie:    IO 0x10001000..0x10010fff -> 0x10001000
[    3.093546] cdns-pcie-host d000000.pcie:   MEM 0x4000000000..0x407fffffff -> 0x00000000
[    3.101795] cdns-pcie-host d000000.pcie: PCI host bridge to bus 0000:00
[    3.108557] pci_bus 0000:00: root bus resource [bus 00-0f]
[    3.114163] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[    3.123854] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x407fffffff] (bus address [0x00000000-0x7fffffff])
[    3.134639] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    3.144510] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    3.154406] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[    3.164368] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[    3.174356] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[    3.186201] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.194385] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    3.204344] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    3.214303] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    3.224261] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x6 may corrupt adjacent RW1C bits
[    3.235748] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x1a may corrupt adjacent RW1C bits
[    3.245719] pci 0000:00:00.0: PCI bridge to [bus 01]
[    3.251245] cdns-pcie-host d800000.pcie: missing "mem"
[    3.256912] cdns-pcie-host d800000.pcie: Linked as a consumer to phy-5010000.serdes.1
[    4.266290] cdns-pcie-host d800000.pcie: Phy link never came up
[    4.272346] cdns-pcie-host d800000.pcie: host bridge /interconnect@100000/pcie@2910000/pcie@d800000 ranges:
[    4.282313] cdns-pcie-host d800000.pcie:    IO 0x18001000..0x18010fff -> 0x18001000
[    4.290145] cdns-pcie-host d800000.pcie:   MEM 0x4100000000..0x417fffffff -> 0x00000000
[    4.298387] cdns-pcie-host d800000.pcie: PCI host bridge to bus 0001:00
[    4.305148] pci_bus 0001:00: root bus resource [bus 00-0f]
[    4.310753] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[    4.320621] pci_bus 0001:00: root bus resource [mem 0x4100000000-0x417fffffff] (bus address [0x00000000-0x7fffffff])
[    4.333172] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.342998] pci 0001:00:00.0: PCI bridge to [bus 01]
[    4.348474] cdns-pcie-host e000000.pcie: missing "mem"
[    4.354071] cdns-pcie-host e000000.pcie: Linked as a consumer to phy-5020000.serdes.2
[    5.363448] cdns-pcie-host e000000.pcie: Phy link never came up
[    5.369500] cdns-pcie-host e000000.pcie: host bridge /interconnect@100000/pcie@2920000/pcie@e000000 ranges:
[    5.379468] cdns-pcie-host e000000.pcie:    IO 0x4400001000..0x4400010fff -> 0x00001000
[    5.387654] cdns-pcie-host e000000.pcie:   MEM 0x4400011000..0x4407ffffff -> 0x00011000
[    5.395890] cdns-pcie-host e000000.pcie: PCI host bridge to bus 0002:00
[    5.402651] pci_bus 0002:00: root bus resource [bus 00-0f]
[    5.408257] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[    5.417503] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[    5.430059] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    5.439870] pci 0002:00:00.0: PCI bridge to [bus 01]
[    5.445425] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    5.455302] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    5.462062] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    5.469730] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    5.479871] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    5.486630] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    5.494254] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
[    5.501817] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
[    5.510955] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
[    5.519692] console [ttyS2] enabled
[    5.526728] bootconsole [ns16550a0] disabled
[    5.535635] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 20, base_baud = 3000000) is a 8250
[    5.544441] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 21, base_baud = 3000000) is a 8250
[    5.553171] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    5.561871] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
[    5.571919] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    5.582429] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    5.592585] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    5.602825] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    5.613643] scsi host0: ufshcd
[    5.628717] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[    5.634904] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[    5.641504] Creating 8 MTD partitions on "47040000.spi.0":
[    5.643451] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[    5.646977] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    5.665103] 0x000000080000-0x000000280000 : "ospi.tispl"
[    5.670606] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    5.676208] 0x000000680000-0x0000006a0000 : "ospi.env"
[    5.679574] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[    5.693009] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[    5.704261] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    5.704352] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    5.710222] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    5.723868] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    5.723955] 0x000000800000-0x000003fe0000 : "ospi.rootfs"
[    5.732573] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[    5.737926] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
[    5.878116] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[    5.885776] cadence-qspi 47050000.spi: n25q512a (65536 Kbytes)
[    5.906113] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[    5.913565] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22
[    5.920623] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[    5.932077] UDMA has not been proped
[    5.935650] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[    5.944157] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    5.952689] mmc0: Unknown controller version (4). You may experience problems.
[    5.959951] mmc0: CQHCI version 5.10
[    5.994252] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[    6.008534] vdd_mmc1: supplied by vsys_3v3
[    6.013091] pca953x 4-0021: 4-0021 supply vcc not found, using dummy regulator
[    6.020336] pca953x 4-0021: Linked as a consumer to regulator.0
[    6.052564] GPIO line 457 (HDMI_DDC_OE) hogged as output/high
[    6.059085] pca953x 4-0020: 4-0020 supply vcc not found, using dummy regulator
[    6.066378] pca953x 4-0020: Linked as a consumer to regulator.0
[    6.072394] mmc0: Command Queue Engine enabled
[    6.076833] mmc0: new HS400 MMC card at address 0001
[    6.082245] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[    6.087079] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[    6.093356] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[    6.099384] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (242:0)
[    6.107003] GPIO line 440 (DP0_PWR_SW_EN) hogged as output/high
[    6.114357] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    6.121240] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    6.128108] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    6.135009] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    6.141858] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    6.455688] ti-udma 285c0000.udmap: Channels: 24 (tchan: 48, echan: 0, rchan: 48, rflow: 96)
[    6.465294] ti-udma 31150000.udmap: Channels: 84 (tchan: 140, echan: 160, rchan: 140, rflow: 300)
[    6.476346] tfp410-bridge dvi-bridge: Connector's ddc i2c bus found
[    6.486675] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[    6.492849] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[    6.499450] Creating 8 MTD partitions on "47040000.spi.0":
[    6.504929] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    6.510717] 0x000000080000-0x000000280000 : "ospi.tispl"
[    6.516223] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    6.521831] 0x000000680000-0x0000006a0000 : "ospi.env"
[    6.527161] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    6.533091] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    6.538620] 0x000000800000-0x000003fe0000 : "ospi.rootfs"
[    6.544204] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
[    6.552240] cadence-qspi 47050000.spi: n25q512a (65536 Kbytes)
[    6.560168] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22
[    6.567235] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[    6.584813] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    6.595350] pps pps0: new PPS source ptp1
[    6.599490] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
[    6.608437] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 0.4
[    6.615643] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    6.658030] am65-cpsw-nuss 46000000.ethernet: davinci mdio revision 9.7, bus freq 1000000
[    6.666190] libphy: 46000000.ethernet: probed
[    6.671963] sdhci-am654 4fb0000.sdhci: Linked as a consumer to regulator.4
[    6.678851] sdhci-am654 4fb0000.sdhci: Linked as a consumer to regulator.5
[    6.685741] mmc1: Unknown controller version (4). You may experience problems.
[    6.692998] mmc1: CQHCI version 5.10
[    6.726586] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit
[    6.744650] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    6.751716] hctosys: unable to open rtc device (rtc0)
[    6.778816] ALSA device list:
[    6.781773]   No soundcards found.
[    6.785441] Waiting for root device PARTUUID=ae971293-02...
[    8.165876] mmc1: new ultra high speed DDR50 SDHC card at address 59b4
[    8.173034] mmcblk1: mmc1:59b4       14.5 GiB
[    8.183988]  mmcblk1: p1 p2
[    8.261293] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    8.269401] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    8.279852] devtmpfs: mounted
[    8.282956] Freeing unused kernel memory: 576K
[    8.287407] Run /sbin/init as init process
[    8.439034] systemd[1]: System time before build time, advancing clock.
[    8.490343] NET: Registered protocol family 10
[    8.495229] Segment Routing with IPv6
[    8.516226] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    8.537693] systemd[1]: Detected architecture arm64.
Welcome to Arago 2019.11!
[    8.569925] systemd[1]: Set hostname to <j7-evm>.
[    8.665432] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    8.679871] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    8.697588] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    8.711667] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    8.727274] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    8.741513] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    8.757195] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[    8.861370] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Reached target Remote File Systems.
[    8.882125] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Created slice system-getty.slice.
[    8.902115] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Reached target Swap.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Listening on Process Core Dump Socket.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Paths.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
[  OK  ] Listening on Journal Socket.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
         Starting Create list of required st…ce nodes for the current kernel...
         Mounting Kernel Debug File System...
         Mounting Huge Pages File System...
         Mounting POSIX Message Queue File System...
         Starting Remount Root and Kernel File Systems...
[    9.156017] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
         Mounting Temporary Directory (/tmp)...
[  OK  ] Listening on Journal Socket (/dev/log).
         Starting Journal Service...
[  OK  ] Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on Network Service Netlink Socket.
         Starting Load Kernel Modules...
[    9.251897] cmemk: loading out-of-tree module taints kernel.
[  OK  ] Listening on udev Control Socket.
[    9.258746] CMEMK module: reference Linux version 4.19.94
[    9.268769] no physical memory specified
[    9.272711] cmemk initialized
         Starting udev Coldplug all Devices...
[    9.282287] cryptodev: driver 1.9 loaded.
[  OK  ] Started Journal Service.
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Load Kernel Modules.
         Mounting Kernel Configuration File System...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[    9.521265] systemd-journald[157]: Received request to flush runtime journal from PID 1
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Containers.
         Mounting /var/volatile...
         Mounting /media/ram...
         Starting udev Kernel Device Manager...
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Service...
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Service.
[    9.847774] rti-wdt 2200000.rti: heartbeat 60 sec
         Starting Wait for Network to be Configured...
[    9.871001] rti-wdt 2210000.rti: heartbeat 60 sec
         Starting Network Name Resolution...
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    9.965981] pcm3168a 6-0044: Linked as a consumer to regulator.2
[  OK  ] Listening on D-Bus System Message Bus Socket.
[    9.990751] pcm3168a 6-0044: Linked as a consumer to regulator.3
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[   10.069251] pci-endpoint-test 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[  OK  ] Started Periodic Command Scheduler.
         [   10.091177] pci_generic_config_write32: 29 callbacks suppressed
Starting Login Service...
[   10.091183] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.092036] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[   10.106122] pci-endpoint-test 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
         [   10.141385] pci_bus 0001:00: 1-byte config write to 0001:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
Starting rc.pvr.service...
[  OK  ] Started TEE Supplicant.
[   10.173856] pci-endpoint-test 0002:00:00.0: of_irq_parse_pci: failed with rc=-22
[  OK  ] Started irqbalance daemon.
[   10.193183] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[   10.197200] pci_bus 0002:00: 1-byte config write to 0002:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[  OK  ] Started Daily Cleanup of Temporary Directories.
[   10.228605] remoteproc remoteproc0: 4d80800000.dsp is available
         Starting Print notice about GPLv3 packages...
[   10.257839] ntb_hw_epf 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.265419] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[   10.297622] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.298173] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[   10.312505] ntb_hw_epf 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.322716] remoteproc remoteproc0: powering up 4d80800000.dsp
[   10.327599] pci_bus 0001:00: 1-byte config write to 0001:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.330045] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 1447952
[   10.341081] ntb_hw_epf 0002:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.354212] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[   10.354948] pci_bus 0002:00: 1-byte config write to 0002:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.361523] virtio_rpmsg_bus virtio0: rpmsg host is online
[   10.371330] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[   10.376308] remoteproc remoteproc1: 4d81800000.dsp is available
[   10.389297] remoteproc remoteproc0: registered virtio0 (type 7)
[   10.395297] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[   10.404050] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[   10.419207] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
         Starting RPC Bind Service...
[   10.436752] remoteproc remoteproc2: 64800000.dsp is available
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Job spooling tools.
[   10.487446] remoteproc remoteproc1: powering up 4d81800000.dsp
[  OK  ] Reached target System Time Synchronized.
[   10.498882] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 1447952
[  OK  ] Started Daily rotation of log files.
[   10.516705] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[  OK  ] Reached target Timers.
[  OK  ] Started Network Name Resolution.
[  OK  ] Found devi[   10.530608] virtio_rpmsg_bus virtio1: rpmsg host is online
ce /dev/ttyS2.
[   10.534486] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[   10.547897] remoteproc remoteproc1: registered virtio1 (type 7)
[   10.566613] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
[  OK  ] Started Reboot and dump vmcore via kexec.
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Reached target Network.
         Starting Permit User Sessions...
[   10.592662] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
0;32m  OK  ] Reached target Host and Network Name Lookups.
[   10.604343] remoteproc remoteproc2: powering up 64800000.dsp
[   10.611684] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 6954352
[   10.619556] [drm] No driver support for vblank timestamp query.
[   10.628858] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[   10.638262] pvrsrvkm 4e20000000.gpu: Linked as a consumer to genpd:0:4e20000000.gpu
[   10.648671] pvrsrvkm 4e20000000.gpu: Linked as a consumer to genpd:1:4e20000000.gpu
[   10.662141] PVR_K:  286: Read BVNC 22.104.208.318 from HW device registers
[   10.662601] virtio_rpmsg_bus virtio2: rpmsg host is online
[   10.669061] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[   10.675476] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[   10.685330] PVR_K:  286: RGX Device initialised with BVNC 22.104.208.318
[   10.692975] remoteproc remoteproc2: registered virtio2 (type 7)
[   10.707115] remoteproc remoteproc2: remote processor 64800000.dsp is now up
[   10.719715] [drm] Initialized pvr 1.10.5371573 20170530 for 4e20000000.gpu on minor 1
[   10.727594] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_edid_block [mhdp8546]] *ERROR* get block[0] edid failed: -22
[   10.739536] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_modes [mhdp8546]] *ERROR* Failed to read EDID
[  OK  ] Started Login Service.
[  OK  ] Started RPC Bind Service.
[  OK  ] Started Permit User Sessions.
[   10.775259] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_edid_block [mhdp8546]] *ERROR* get block[0] edid failed: -22
[   10.775266] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_modes [mhdp8546]] *ERROR* Failed to read EDID
[   10.789463] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [mhdp8546]] *ERROR* Failed to read DPCD
[   10.947113] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [mhdp8546]] *ERROR* Failed to read DPCD
[   11.018339] k3_r5_rproc interconnect@100000:interconnect@28380000:r5fss@41000000: creating child devices for R5F cores
[   11.021227] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_edid_block [mhdp8546]] *ERROR* get block[0] edid failed: -22
[   11.021235] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_modes [mhdp8546]] *ERROR* Failed to read EDID
[   11.021967] platform 41000000.r5f: configured R5F for remoteproc mode
[   11.023028] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   11.023166] remoteproc remoteproc3: 41000000.r5f is available
[   11.023239] remoteproc remoteproc3: Direct firmware load for j7-mcu-r5f0_0-fw failed with error -2
[   11.023462] remoteproc remoteproc3: powering up 41000000.r5f
[   11.023473] remoteproc remoteproc3: Direct firmware load for j7-mcu-r5f0_0-fw failed with error -2
[   11.023476] remoteproc remoteproc3: request_firmware failed: -2
[   11.023972] k3_r5_rproc interconnect@100000:r5fss@5c00000: creating child devices for R5F cores
[   11.025694] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[   11.026172] platform 5c00000.r5f: configured R5F for IPC-only mode
[   11.026239] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[   11.026366] remoteproc remoteproc4: 5c00000.r5f is available
[   11.027266] platform 5d00000.r5f: configured R5F for IPC-only mode
[   11.027358] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[   11.027474] remoteproc remoteproc5: 5d00000.r5f is available
[   11.027824] k3_r5_rproc interconnect@100000:r5fss@5e00000: creating child devices for R5F cores
[   11.028836] platform 5e00000.r5f: configured R5F for remoteproc mode
[   11.029414] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[   11.029539] remoteproc remoteproc6: 5e00000.r5f is available
[   11.029624] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[   11.029629] remoteproc remoteproc6: powering up 5e00000.r5f
[   11.029637] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[   11.029640] remoteproc remoteproc6: request_firmware failed: -2
[   11.039725] Console: switching to colour frame buffer device 128x48
[   11.046547] pcm3168a 6-0044: Failed to reset device: -16
[   11.046882] pcm3168a: probe of 6-0044 failed with error -16
[   11.117046] remoteproc remoteproc4: powering up 5c00000.r5f
[   11.128782] tidss 4a00000.dss: fb0: DRM emulated frame buffer device
[   11.139959] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 2459460
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Found device /dev/ttyS1.
[  OK  ] Started rc.pvr.service.
[   11.414679] remoteproc remoteproc5: powering up 5d00000.r5f
[   11.425086] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 4622296
[   11.433175] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[   11.440838] virtio_rpmsg_bus virtio3: rpmsg host is online
[   11.451518] remoteproc remoteproc5: registered virtio3 (type 7)
[   11.458903] TI DP83867 k3-cpsw-mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=k3-cpsw-mdio:00, irq=POLL)
[   11.469804] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
[   11.477923] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   11.488471] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[   11.496633] virtio_rpmsg_bus virtio4: rpmsg host is online
[   11.504672] remoteproc remoteproc4: registered virtio4 (type 7)
Note: the same device boots properly when using PSDK 7.1 - a full boot log is attached:
U-Boot SPL 2020.01-g3c9ebdb87d (Nov 19 2020 - 18:33:21 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla')
NOTICE:  BL31: v2.3():07.01.00.004-1-g52c334fc3-dirty
NOTICE:  BL31: Built : 18:17:14, Nov 19 2020
U-Boot SPL 2020.01-g3c9ebdb87d (Nov 19 2020 - 18:29:59 +0000)
U-Boot 2020.01-g3c9ebdb87d (Nov 19 2020 - 18:29:59 +0000)
SoC:   J721E SR1.0
DRAM:  4 GiB
not found for dev hbmc-mux
Flash: 0 Bytes
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:
Warning: ethernet@46000000 using MAC address from ROM
eth0: ethernet@46000000
483 bytes read in 1 ms (471.7 KiB/s)
Running uenvcmd ...
1 bytes read in 3 ms (0 Bytes/s)
Already setup.
6105496 bytes read in 131 ms (44.4 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 6105496 bytes: Success!
2799616 bytes read in 63 ms (42.4 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 2799616 bytes: Success!
1521744 bytes read in 36 ms (40.3 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 1521744 bytes: Success!
Load Remote Processor 7 with data@addr=0x82000000 1521744 bytes: Success!
9969648 bytes read in 87 ms (109.3 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 9969648 bytes: Success!
16666632 bytes read in 348 ms (45.7 MiB/s)
93829 bytes read in 5 ms (17.9 MiB/s)
6199 bytes read in 3 ms (2 MiB/s)
   Loading Device Tree to 000000008fee6000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Linux version 5.4.74-g9574bba32a (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Thu Nov 19 18:30:39 UTC 2020
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 7 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a5800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5900000, size 7 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a5900000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-dma-memory@ac000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ce000000, size 720 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-core-heap-memory@ce000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@fb000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@fb100000, compatible id shared-dma-pool
[    0.000000] cma: Failed to reserve 512 MiB
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] Built 1 zonelists, mobility grouping off.  Total pages: 35779
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),57216k@8m(ospi.rootfs),128k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=d41ae08b-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x9a800000-0x9e800000] (64MB)
[    0.000000] Memory: 2584000K/2293760K available (9598K kernel code, 788K rwdata, 3840K rodata, 1664K init, 683K bss, 18446744073709261376K reserved, 0K cma-reserved)
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: using LPI property table @0x00000008c00c0000
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000
[    0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x43c with crng_init=0
[    0.008366] Console: colour dummy device 80x25
[    0.012933] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023602] pid_max: default: 32768 minimum: 301
[    0.028354] LSM: Security Framework initializing
[    0.033107] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.040676] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.049945] ASID allocator initialised with 32768 entries
[    0.055539] rcu: Hierarchical SRCU implementation.
[    0.060610] Platform MSI: gic-its@1820000 domain created
[    0.066301] PCI/MSI: /bus@100000/interrupt-controller@1800000/gic-its@1820000 domain created
[    0.075161] smp: Bringing up secondary CPUs ...
[    0.081177] Detected PIPT I-cache on CPU1
[    0.081202] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.081212] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000
[    0.081246] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.081308] smp: Brought up 1 node, 2 CPUs
[    0.110653] SMP: Total of 2 processors activated.
[    0.115458] CPU features: detected: 32-bit EL0 Support
[    0.120711] CPU features: detected: CRC32 instructions
[    0.132576] CPU: All CPU(s) started at EL2
[    0.136772] alternatives: patching kernel code
[    0.141967] devtmpfs: initialized
[    0.150551] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.160523] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[    0.167967] pinctrl core: initialized pinctrl subsystem
[    0.173848] NET: Registered protocol family 16
[    0.178616] DMA: preallocated 256 KiB pool for atomic allocations
[    0.185149] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.200877] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.207736] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.214496] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.222695] cryptd: max_cpu_qlen set to 1000
[    0.229261] vsys_3v3: supplied by evm_12v0
[    0.233548] vsys_5v0: supplied by evm_12v0
[    0.238142] iommu: Default domain type: Translated
[    0.243343] SCSI subsystem initialized
[    0.247475] mc: Linux media interface: v0.10
[    0.251845] videodev: Linux video capture interface: v2.00
[    0.257455] pps_core: LinuxPPS API ver. 1 registered
[    0.262524] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.271860] PTP clock support registered
[    0.275872] EDAC MC: Ver: 3.0.0
[    0.279619] FPGA manager framework
[    0.283140] Advanced Linux Sound Architecture Driver Initialized.
[    0.289747] clocksource: Switched to clocksource arch_sys_counter
[    0.296079] VFS: Disk quotas dquot_6.6.0
[    0.300130] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.309669] Carveout Heap: Exported 512 MiB at 0x00000000ae000000
[    0.315913] thermal_sys: Registered thermal governor 'step_wise'
[    0.315916] thermal_sys: Registered thermal governor 'power_allocator'
[    0.322408] NET: Registered protocol family 2
[    0.333908] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.342675] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.350871] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.358692] TCP: Hash tables configured (established 32768 bind 32768)
[    0.365444] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.372339] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.379739] NET: Registered protocol family 1
[    0.384518] RPC: Registered named UNIX socket transport module.
[    0.390570] RPC: Registered udp transport module.
[    0.395372] RPC: Registered tcp transport module.
[    0.400175] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.406761] PCI: CLS 0 bytes, default 64
[    0.411184] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.421357] Initialise system trusted keyrings
[    0.425994] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.434706] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.440955] NFS: Registering the id_resolver key type
[    0.446133] Key type id_resolver registered
[    0.450404] Key type id_legacy registered
[    0.454500] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.461474] 9p: Installing v9fs 9p2000 file system support
[    0.474663] Key type asymmetric registered
[    0.478848] Asymmetric key parser 'x509' registered
[    0.483851] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.491409] io scheduler mq-deadline registered
[    0.496034] io scheduler kyber registered
[    0.501326] pinctrl-single 4301c000.pinmux: 94 pins, size 376
[    0.507429] pinctrl-single 11c000.pinmux: 173 pins, size 692
[    0.515646] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.521919] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.528265] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.534687] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[    0.542695] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.549109] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[    0.557038] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.563450] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[    0.571370] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.577697] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[    0.585618] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.591939] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[    0.601362] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.613592] brd: module loaded
[    0.620052] loop: module loaded
[    0.623673] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
[    0.631597] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.74-g9574bba32a #1
[    0.638706] Hardware name: Texas Instruments K3 J721E SoC (DT)
[    0.644661] Call trace:
[    0.647159]  dump_backtrace+0x0/0x140
[    0.650894]  show_stack+0x14/0x20
[    0.654276]  dump_stack+0xb4/0x114
[    0.657755]  sysfs_warn_dup+0x5c/0x78
[    0.661489]  sysfs_create_dir_ns+0xd8/0xf0
[    0.665670]  kobject_add_internal+0x94/0x280
[    0.670026]  kobject_add+0x90/0xf8
[    0.673496]  device_add+0xdc/0x600
[    0.676964]  platform_device_add+0xfc/0x228
[    0.681230]  platform_device_register_full+0xc8/0x140
[    0.686389]  dma_buf_phys_init+0x68/0x94
[    0.690390]  do_one_initcall+0x50/0x1a8
[    0.694306]  kernel_init_freeable+0x194/0x23c
[    0.698752]  kernel_init+0x10/0xfc
[    0.702220]  ret_from_fork+0x10/0x1c
[    0.705883] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
[    0.720068] libphy: Fixed MDIO Bus: probed
[    0.724451] tun: Universal TUN/TAP device driver, 1.6
[    0.729894] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    0.737896] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.744001] sky2: driver version 1.30
[    0.748277] VFIO - User Level meta-driver version: 0.3
[    0.753942] i2c /dev entries driver
[    0.758026] sdhci: Secure Digital Host Controller Interface driver
[    0.764340] sdhci: Copyright(c) Pierre Ossman
[    0.769008] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.775295] ledtrig-cpu: registered to indicate activity on CPUs
[    0.782157] optee: probing for conduit method from DT.
[    0.787429] optee: revision 3.8 (199fca17)
[    0.787789] optee: initialized driver
[    0.796637] NET: Registered protocol family 17
[    0.801262] 9pnet: Installing 9P2000 support
[    0.805655] Key type dns_resolver registered
[    0.810177] registered taskstats version 1
[    0.814365] Loading compiled-in X.509 certificates
[    0.823124] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.829449] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.837816] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla')
[    0.980323] random: fast init done
[    1.167732] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    1.178953] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    1.185435] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    1.192044] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    1.198738] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
[    1.206160] pca953x 3-0020: using no AI
[    1.234272] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
[    1.241733] pca953x 3-0022: using AI
[    1.245999] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low
[    1.252592] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high
[    1.259463] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    1.265912] omap_i2c 2020000.i2c: bus 4 rev0.12 at 100 kHz
[    1.272287] pca953x 5-0020: 5-0020 supply vcc not found, using dummy regulator
[    1.279706] pca953x 5-0020: using no AI
[    2.289903] pca953x 5-0020: failed writing register
[    2.294947] pca953x: probe of 5-0020 failed with error -16
[    2.300677] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[    2.307034] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
[    2.313412] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
[    2.320235] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    2.330695] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    2.339925] ti-sci-intr bus@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created
[    2.351057] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    3.393542] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.401243] j721e-pcie 2900000.pcie:    IO 0x10001000..0x10010fff -> 0x10001000
[    3.408729] j721e-pcie 2900000.pcie:   MEM 0x10011000..0x17ffffff -> 0x10011000
[    3.416313] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[    3.422721] pci_bus 0000:00: root bus resource [bus 00-0f]
[    3.428327] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[    3.438017] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[    3.445061] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[    3.451211] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    3.461080] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    3.470968] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
[    3.480927] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    3.490894] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[    3.500856] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[    3.510841] pci 0000:00:00.0: supports D1
[    3.514934] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    3.520806] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[    3.532482] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.540670] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    3.550628] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    3.560587] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    3.572007] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
[    3.578777] pci 0000:00:00.0: PCI bridge to [bus 01]
[    3.584053] pcieport 0000:00:00.0: PME: Signaling with IRQ 37
[    3.590078] pcieport 0000:00:00.0: AER: enabled with IRQ 37
[    4.600273] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    4.607946] j721e-pcie 2910000.pcie:    IO 0x18001000..0x18010fff -> 0x18001000
[    4.615423] j721e-pcie 2910000.pcie:   MEM 0x18011000..0x1fffffff -> 0x18011000
[    4.622962] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[    4.629368] pci_bus 0001:00: root bus resource [bus 00-0f]
[    4.634972] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[    4.644840] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[    4.651877] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
[    4.658083] pci 0001:00:00.0: supports D1
[    4.662177] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[    4.669660] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.679399] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
[    4.686171] pci 0001:00:00.0: PCI bridge to [bus 01]
[    4.691441] pcieport 0001:00:00.0: PME: Signaling with IRQ 40
[    4.697459] pcieport 0001:00:00.0: AER: enabled with IRQ 40
[    5.707249] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    5.714924] j721e-pcie 2920000.pcie:    IO 0x4400001000..0x4400010fff -> 0x00001000
[    5.722756] j721e-pcie 2920000.pcie:   MEM 0x4400011000..0x4407ffffff -> 0x00011000
[    5.730658] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
[    5.737066] pci_bus 0002:00: root bus resource [bus 00-0f]
[    5.742670] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[    5.751917] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[    5.762687] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
[    5.768894] pci 0002:00:00.0: supports D1
[    5.772988] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
[    5.780477] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    5.790124] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
[    5.796891] pci 0002:00:00.0: PCI bridge to [bus 01]
[    5.802143] pcieport 0002:00:00.0: PME: Signaling with IRQ 43
[    5.808166] pcieport 0002:00:00.0: AER: enabled with IRQ 43
[    5.815046] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    5.824921] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    5.831680] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    5.841074] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    5.851230] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    5.857991] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    5.866334] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
[    5.875967] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250
[    5.884710] printk: console [ttyS2] enabled
[    5.893150] printk: bootconsole [ns16550a0] disabled
[    5.903942] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250
[    5.913199] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 24, base_baud = 3000000) is a 8250
[    5.922472] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    5.931591] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq
[    5.940717] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq
[    5.948420] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
[    5.958172] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    5.968684] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    5.978838] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    5.989077] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    6.003033] scsi host0: ufshcd
[    6.024743] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[    6.055879] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[    6.057754] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    6.067543] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[    6.075144] libphy: 46000f00.mdio: probed
[    6.086439] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    6.091469] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    6.099111] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    6.106951] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    6.115667] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[    6.128204] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[    6.147858] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    6.157334] mmc0: CQHCI version 5.10
[    6.198304] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[    6.209902] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    6.242272] vdd_mmc1: supplied by vsys_3v3
[    6.248601] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    6.257079] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    6.265655] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    6.274112] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    6.282632] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    6.296362] ti-udma 285c0000.dma-controller: Channels: 24 (tchan: 12, rchan: 12, gp-rflow: 8)
[    6.310254] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    6.319989] mmc0: Command Queue Engine enabled
[    6.324433] mmc0: new HS200 MMC card at address 0001
[    6.330911] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[    6.335618] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[    6.341709] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[    6.347840] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0)
[    6.377149] cadence-qspi 47040000.spi: PHY calibration failed: -2
[    6.383237] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[    6.388463] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[    6.395061] Creating 8 MTD partitions on "47040000.spi.0":
[    6.400535] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    6.406597] 0x000000080000-0x000000280000 : "ospi.tispl"
[    6.412292] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    6.418096] 0x000000680000-0x0000006a0000 : "ospi.env"
[    6.423671] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    6.429783] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    6.435599] 0x000000800000-0x000003fe0000 : "ospi.rootfs"
[    6.441372] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
[    6.458852] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[    6.505763] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    6.513412] libphy: 46000f00.mdio: probed
[    6.518527] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    6.526790] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    6.545366] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    6.554667] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4
[    6.561967] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    6.569264] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    6.582533] mmc1: CQHCI version 5.10
[    7.647474] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit
[    7.656763] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    7.698482] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    7.705950] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    7.713264] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    7.720611] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    7.733964] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    7.741868] hctosys: unable to open rtc device (rtc0)
[    7.782195] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[    7.789137] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
[    7.800608]  mmcblk1: p1 p2
[    7.890343] ALSA device list:
[    7.893300]   No soundcards found.
[    9.165406] EXT4-fs (mmcblk1p2): recovery complete
[    9.176917] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    9.185039] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    9.199447] devtmpfs: mounted
[    9.202833] Freeing unused kernel memory: 1664K
[    9.207385] Run /sbin/init as init process
[    9.371701] systemd[1]: System time before build time, advancing clock.
[    9.430047] NET: Registered protocol family 10
[    9.434977] Segment Routing with IPv6
[    9.457029] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    9.478841] systemd[1]: Detected architecture arm64.
Welcome to Arago 2020.09!
[    9.533414] systemd[1]: Set hostname to <j7-evm>.
[    9.756057] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[    9.829963] random: systemd: uninitialized urandom read (16 bytes read)
[    9.836692] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    9.849019] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    9.859113] systemd[1]: Created slice system-getty.slice.
[    9.881838] random: systemd: uninitialized urandom read (16 bytes read)
[    9.889126] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    9.905807] random: systemd: uninitialized urandom read (16 bytes read)
[    9.912946] systemd[1]: Created slice User and Session Slice.
[    9.929934] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    9.953857] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    9.977883] systemd[1]: Reached target Paths.
[    9.993803] systemd[1]: Reached target Remote File Systems.
[   10.013790] systemd[1]: Reached target Slices.
[   10.029798] systemd[1]: Reached target Swap.
[   10.050292] systemd[1]: Listening on RPCbind Server Activation Socket.
[   10.069836] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[   10.095215] systemd[1]: Listening on Process Core Dump Socket.
[   10.113958] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   10.146680] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.155081] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.174040] systemd[1]: Listening on Journal Socket.
[   10.190118] systemd[1]: Listening on Network Service Netlink Socket.
[   10.209994] systemd[1]: Listening on udev Control Socket.
[   10.225924] systemd[1]: Listening on udev Kernel Socket.
[   10.246896] systemd[1]: Mounting Huge Pages File System...
[   10.269471] systemd[1]: Mounting POSIX Message Queue File System...
[   10.294502] systemd[1]: Mounting Kernel Debug File System...
[   10.317550] systemd[1]: Mounting Temporary Directory (/tmp)...
[   10.338925] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[   10.367242] systemd[1]: Starting Start psplash boot splash screen...
[   10.397682] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[   10.423552] systemd[1]: Starting RPC Bind...
[   10.445983] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   10.467738] systemd[1]: Starting Journal Service...
[   10.498255] systemd[1]: Starting Load Kernel Modules...
[   10.518278] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.542008] cryptodev: loading out-of-tree module taints kernel.
[   10.556714] systemd[1]: Starting udev Coldplug all Devices...
[   10.559077] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[   10.568099] cryptodev: driver 1.10 loaded.
[   10.588449] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[   10.611113] systemd[1]: Mounted Huge Pages File System.
[   10.634938] systemd[1]: Mounted POSIX Message Queue File System.
[   10.662387] systemd[1]: Started Journal Service.
[  OK  ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[   10.883667] systemd-journald[168]: Received client request to flush runtime journal.
[  OK  ] Reached target System Time Set.
         Starting Docker Socket for the API.
[  OK  ] Listening on Docker Socket for the API.
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started IPv6 Packet Filtering Framework.
[  OK  ] Started IPv4 Packet Filtering Framework.
[  OK  ] Reached target Network (Pre).
[   11.909460] rti-wdt 2200000.watchdog: heartbeat 60 sec
[   11.956876] PVR_K:  238: Read BVNC 22.104.208.318 from HW device registers
[   11.981901] PVR_K:  238: RGX Device initialised with BVNC 22.104.208.318
[   12.002382] [drm] Initialized pvr 1.10.5371573 20170530 for 4e20000000.gpu on minor 0
[   12.097694] rti-wdt 2210000.watchdog: heartbeat 60 sec
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[   12.722479] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[   13.002753] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[   13.017785] random: crng init done
[   13.021187] random: 7 urandom warning(s) missed due to ratelimiting
[   13.106000] remoteproc remoteproc0: 4d80800000.dsp is available
[   13.198620] CAN device driver interface
[   13.258206] remoteproc remoteproc0: powering up 4d80800000.dsp
[   13.258461] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[   13.264355] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 1521744
[   13.298644] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[   13.307124]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
[   13.319614] virtio_rpmsg_bus virtio0: rpmsg host is online
[   13.325184]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[   13.338215] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[   13.338587] m_can_platform 40528000.can: m_can device registered (irq=15, version=32)
[   13.353293] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[   13.389887] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[   13.530345] m_can_platform 40568000.can: m_can device registered (irq=17, version=32)
[   13.573864] remoteproc remoteproc1: 4d81800000.dsp is available
[   13.635302] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[   13.705851] remoteproc remoteproc1: powering up 4d81800000.dsp
[   13.712414] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 1521744
[   13.721789] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[   13.730507] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[   13.737329]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
[   13.750427] virtio_rpmsg_bus virtio1: rpmsg host is online
[   13.758704]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[   13.764806] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
[   13.773268] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[   13.834739] platform 41000000.r5f: configured R5F for IPC-only mode
[   13.849351] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[   13.869823] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   13.885855] remoteproc remoteproc3: 64800000.dsp is available
[   13.924221] remoteproc remoteproc2: 41000000.r5f is available
[   13.958060] remoteproc remoteproc2: powering up 41000000.r5f
[   13.963818] remoteproc remoteproc2: Booting fw image j7-mcu-r5f0_0-fw, size 195880
[   13.979822] platform 41000000.r5f: R5F core initialized in IPC-only mode
[   13.986551]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[   14.002439] virtio_rpmsg_bus virtio2: rpmsg host is online
[   14.013818]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[   14.019980] remoteproc remoteproc2: remote processor 41000000.r5f is now up
[   14.052713] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[   14.062040] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[   14.087107] platform 5c00000.r5f: configured R5F for IPC-only mode
[   14.145917] platform 5c00000.r5f: assigned reserved memory node vision_apps-r5f-dma-memory@a1000000
[   14.266009] remoteproc remoteproc4: 5c00000.r5f is available
[   14.313533] platform 5d00000.r5f: configured R5F for IPC-only mode
[   14.341844] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[   14.357902] remoteproc remoteproc5: 5d00000.r5f is available
[   14.391419] platform 5e00000.r5f: configured R5F for remoteproc mode
[   14.411808] platform 5e00000.r5f: assigned reserved memory node vision_apps-r5f-dma-memory@a5000000
[   14.437868] remoteproc remoteproc6: 5e00000.r5f is available
[   14.457867] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[   14.468867] platform 5f00000.r5f: configured R5F for remoteproc mode
[   14.475548] remoteproc remoteproc6: powering up 5e00000.r5f
[   14.481194] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[   14.497765] remoteproc remoteproc6: request_firmware failed: -2
[   14.584325] platform 5f00000.r5f: assigned reserved memory node vision_apps-r5f-dma-memory@a5800000
[   14.730198] remoteproc remoteproc7: 5f00000.r5f is available
[   14.838202] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[   14.851163] remoteproc remoteproc7: powering up 5f00000.r5f
[   14.859596] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[   14.875179] remoteproc remoteproc7: request_firmware failed: -2
[   14.891391] remoteproc remoteproc3: powering up 64800000.dsp
[   14.897089] remoteproc remoteproc3: Booting fw image j7-c71_0-fw, size 9969648
[   14.909964] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[   14.921202] remoteproc remoteproc5: powering up 5d00000.r5f
[   14.930851] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 2799616
[   14.940031]  remoteproc3#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
[   14.953936] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[   14.961622] virtio_rpmsg_bus virtio3: rpmsg host is online
[   14.969773]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[   14.971111] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[   14.978180]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[   14.994303] virtio_rpmsg_bus virtio4: rpmsg host is online
[   15.001768] remoteproc remoteproc3: remote processor 64800000.dsp is now up
[   15.002444] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[   15.008785]  remoteproc5#vdev0buffer: registered virtio4 (type 7)
[   15.019516] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[   15.029826] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
[   15.068496] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[   15.157887] remoteproc remoteproc4: powering up 5c00000.r5f
[   15.163657] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 6105496
[   15.176648] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[   15.185777]  remoteproc4#vdev0buffer: assigned reserved memory node vision_apps-r5f-dma-memory@a1000000
[   15.201413] virtio_rpmsg_bus virtio5: rpmsg host is online
[   15.210207]  remoteproc4#vdev0buffer: registered virtio5 (type 7)
[   15.212440] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[   15.221777] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
[   15.229831] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[   15.237457] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[   15.249354] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[   15.256907] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[   15.273858] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[   15.289878] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[   15.301837] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[   15.313841] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[   15.325865] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[   15.336793] virtio_rpmsg_bus virtio5: creating channel ti.ethfw.notifyservice addr 0x1e
[   15.348741] virtio_rpmsg_bus virtio5: creating channel rpmsg-kdrv addr 0x1a
[   15.359325] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: Device info: permissions: 07FFFFFF uart_id: 2
[   15.373786] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: FW ver 0.1 (rev 1)  8/Feb/2021 SHA:9701c4bd
[   15.467576] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[   15.691751] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
[   15.831054] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:00000003 rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00
[   15.899562] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   15.931420] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
[   16.043093] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   16.280629] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   16.289670] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav
        gzip
        less
        libasm1
        libbfd
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libidn2-0
        libmpc3
        libmpfr6
        libreadline-dev
        libreadline8
        libunistring2
        m4-dev
        m4
        make
        nettle
        parted
        tar
        which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
[  OK  ] Created slice system-weston.slice.
[  OK  ] Started Weston Wayland Compositor.
[   17.244061] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   17.253196] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   17.266622] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   17.274178] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   17.276587] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   17.293780] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   17.306119] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   17.316736] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   17.326343] remoteproc remoteproc8: b034000.pru is available
[   17.385904] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[   17.387904] pru-rproc b034000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@34000 probed successfully
[   17.502089] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   17.511467] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   17.621193] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   17.631678] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   17.644211] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   17.653213] remoteproc remoteproc9: b004000.rtu is available
[   17.658901] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   17.732524] pru-rproc b004000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@4000 probed successfully
[   17.760359] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   17.769765] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   17.782118] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   17.792709] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   17.796562] pru-rproc b00a000.txpru: IRQ vring not found
[   17.806901] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   17.816686] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   17.876446] pru-rproc b00a000.txpru: IRQ kick not found
[   17.898802] remoteproc remoteproc10: b00a000.txpru is available
[   17.936328] pru-rproc b00a000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@a000 probed successfully
[   17.950990] cdns-usb3 6000000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[   17.988854] remoteproc remoteproc11: b038000.pru is available
[   17.995128] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   18.007399] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   18.033488] pru-rproc b038000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@38000 probed successfully
[   18.074274] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   18.085786] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   18.093811] remoteproc remoteproc12: b006000.rtu is available
[   18.137956] pru-rproc b006000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@6000 probed successfully
[   18.246112] pru-rproc b00c000.txpru: IRQ vring not found
[   18.252020] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   18.265246] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   18.347364] pru-rproc b00c000.txpru: IRQ kick not found
[   18.368032] remoteproc remoteproc13: b00c000.txpru is available
[   18.400735] pru-rproc b00c000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@c000 probed successfully
[   18.471995] remoteproc remoteproc14: b134000.pru is available
[   18.478155] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   18.485646] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   18.525845] pru-rproc b134000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@34000 probed successfully
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org j7-evm ttyS2
Arago 2020.09 j7-evm ttyS2
j7-evm login: [   18.634841] remoteproc remoteproc15: b104000.rtu is available
[   18.641075] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   18.649291] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   18.696770] pru-rproc b104000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@4000 probed successfully
[   18.722853] pru-rproc b10a000.txpru: IRQ vring not found
[   18.729386] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   18.737612] pru-rproc b10a000.txpru: IRQ kick not found
[   18.742862] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   18.750349] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
[   18.758857] cdns-usb3 6400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[   18.761994] remoteproc remoteproc16: b10a000.txpru is available
[   18.766574] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   18.777782] pru-rproc b10a000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@a000 probed successfully
[   18.785565] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   18.798752] remoteproc remoteproc17: b138000.pru is available
[   18.801598] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   18.817407] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   18.827996] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   18.833819] pru-rproc b138000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@38000 probed successfully
[   18.838815] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   18.882976] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   18.895419] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   18.903890] remoteproc remoteproc18: b106000.rtu is available
[   18.913869] pru-rproc b106000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@6000 probed successfully
[   18.914367] usbcore: registered new interface driver usbfs
[   18.930953] pru-rproc b10c000.txpru: IRQ vring not found
[   18.936632] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   18.944131] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   18.954264] usbcore: registered new interface driver hub
[   18.958402] pru-rproc b10c000.txpru: IRQ kick not found
[   18.967540] usbcore: registered new device driver usb
[   18.970446] remoteproc remoteproc19: b10c000.txpru is available
[   18.985851] pru-rproc b10c000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@c000 probed successfully
[   19.006091] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   19.017759] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   19.029336] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   19.173805] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   19.206304] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
[   19.242297] xhci-hcd xhci-hcd.2.auto: irq 596, io mem 0x06010000
[   19.260930] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   19.284885] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   19.301747] usb usb1: Product: xHCI Host Controller
[   19.313745] usb usb1: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
[   19.325746] usb usb1: SerialNumber: xhci-hcd.2.auto
[   19.338053] hub 1-0:1.0: USB hub found
[   19.345777] hub 1-0:1.0: 1 port detected
[   19.350343] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   19.356204] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   19.357782] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[   19.365754] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   19.377760] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[   19.389787] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   19.405793] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[   19.421757] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   19.433745] usb usb2: Product: xHCI Host Controller
[   19.438616] usb usb2: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
[   19.445763] usb usb2: SerialNumber: xhci-hcd.2.auto
[   19.450933] hub 2-0:1.0: USB hub found
[   19.461762] hub 2-0:1.0: 1 port detected
[   19.466283] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   19.473956] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   19.479446] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   19.489922] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3
[   19.497891] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   19.509791] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   19.517058] xhci-hcd xhci-hcd.3.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
[   19.533778] xhci-hcd xhci-hcd.3.auto: irq 599, io mem 0x06410000
[   19.545897] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   19.554262] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   19.565747] usb usb3: Product: xHCI Host Controller
[   19.573749] usb usb3: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
[   19.585746] usb usb3: SerialNumber: xhci-hcd.3.auto
[   19.590922] hub 3-0:1.0: USB hub found
[   19.597766] hub 3-0:1.0: 1 port detected
[   19.602250] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   19.608072] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   19.617748] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   19.629893] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4
[   19.637951] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[   19.649794] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[   19.665792] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[   19.674124] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   19.685746] usb usb4: Product: xHCI Host Controller
[   19.693746] usb usb4: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
[   19.701779] usb usb4: SerialNumber: xhci-hcd.3.auto
[   19.714248] hub 4-0:1.0: USB hub found
[   19.718016] hub 4-0:1.0: 1 port detected
[   19.726083] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   19.737799] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   19.750189] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   19.761775] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   19.933767] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[   20.098017] usb 3-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[   20.109744] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[   20.121744] usb 3-1: SerialNumber: 4608084120CE
[   20.126774] hub 3-1:1.0: USB hub found
[   20.133756] hub 3-1:1.0: 4 ports detected
[   20.144121] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
[   20.157773] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
j7-evm login: root
Last login: Thu Nov 19 18:09:27 UTC 2020
root@j7-evm:~#
Could it be a hardware issue?
Any suggestions or recommendations will be appreciated!
Update (09.03.2021) boot log with prebuilt PSDK 6.2. binaries:
U-Boot SPL 2019.01-g350f3927b8 (Feb 07 2020 - 14:39:06 +0000)
SYSFW ABI: 2.9 (firmware rev 0x0013 '19.12.1-v2019.12a (Terrific Lla')
Trying to boot from MMC2
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Remoteproc 2 started successfully
** File not found /lib/firmware/j7-mcu-r5f0_0-fw **
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.2(release):ti2019.05-rc1
NOTICE:  BL31: Built : 12:19:54, Jan 27 2020
I/TC:
I/TC: OP-TEE version: ti2019.05-rc1-dev (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 Mon Jan 27 12:29:57 UTC 2020 aarch64
I/TC: Initialized
U-Boot SPL 2019.01-g350f3927b8 (Feb 07 2020 - 14:39:43 +0000)
Detected: J7X-BASE-CPB rev E2
Detected: J7X-INFOTAN-EXP rev E3
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2019.01-g350f3927b8 (Feb 07 2020 - 14:39:43 +0000)
SoC:   J721E PG 1.0
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM1-SOM rev E2
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from MMC... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:
Warning: ethernet@046000000 using MAC address from ROM
eth0: ethernet@046000000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
** Unable to read file boot.scr **
81 bytes read in 1 ms (79.1 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
128832 bytes read in 6 ms (20.5 MiB/s)
Invalid op: Trying to load/start on already running core 6
Load Remote Processor 2 with data@addr=0x82000000 128832 bytes: Failed!
3811288 bytes read in 81 ms (44.9 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 3811288 bytes: Success!
** File not found /lib/firmware/j7-main-r5f1_0-fw **
** File not found /lib/firmware/j7-main-r5f1_1-fw **
1448016 bytes read in 31 ms (44.5 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 1448016 bytes: Success!
Load Remote Processor 7 with data@addr=0x82000000 1448016 bytes: Success!
6954352 bytes read in 147 ms (45.1 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 6954352 bytes: Success!
13338632 bytes read in 282 ms (45.1 MiB/s)
99354 bytes read in 3 ms (31.6 MiB/s)
3779 bytes read in 0 ms
   Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 4.19.94-g5a23bc00e0 (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Fri Feb 7 09:45:50 UTC 2020
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3e4 with crng_init=0
[    0.000000] percpu: Embedded 2 pages/cpu s48536 r8192 d74344 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for EL2 vector hardening
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 62339
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),57216k@8m(ospi.rootfs),128k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=c22177f9-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes)
[    0.000000] software IO TLB: mapped [mem 0xdbff0000-0xdfff0000] (64MB)
[    0.000000] Memory: 3377664K/3993600K available (8510K kernel code, 738K rwdata, 3136K rodata, 576K init, 641K bss, 91648K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=2.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x00000008c00a0000
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] CPU0: using LPI pending table @0x00000008c00b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008377] Console: colour dummy device 80x25
[    0.012941] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023609] pid_max: default: 32768 minimum: 301
[    0.028351] Security Framework initialized
[    0.032559] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes)
[    0.039416] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes)
[    0.070760] ASID allocator initialised with 32768 entries
[    0.084289] rcu: Hierarchical SRCU implementation.
[    0.097254] Platform MSI: gic-its@1820000 domain created
[    0.102897] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created
[    0.120334] smp: Bringing up secondary CPUs ...
[    0.157250] Detected PIPT I-cache on CPU1
[    0.157272] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.157303] CPU1: using LPI pending table @0x00000008c0310000
[    0.157331] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.157386] smp: Brought up 1 node, 2 CPUs
[    0.185229] SMP: Total of 2 processors activated.
[    0.190039] CPU features: detected: GIC system register CPU interface
[    0.196620] CPU features: detected: 32-bit EL0 Support
[    0.202121] CPU: All CPU(s) started at EL2
[    0.206309] alternatives: patching kernel code
[    0.211442] devtmpfs: initialized
[    0.220055] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.230026] futex hash table entries: 512 (order: -1, 32768 bytes)
[    0.237025] pinctrl core: initialized pinctrl subsystem
[    0.242793] NET: Registered protocol family 16
[    0.247729] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.255294] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.264537] DMA: preallocated 256 KiB pool for atomic allocations
[    0.278478] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.285334] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.292864] cryptd: max_cpu_qlen set to 1000
[    0.297856] vsys_3v3: supplied by evm_12v0
[    0.302128] vsys_5v0: supplied by evm_12v0
[    0.306705] SCSI subsystem initialized
[    0.310798] media: Linux media interface: v0.10
[    0.315435] videodev: Linux video capture interface: v2.00
[    0.321049] pps_core: LinuxPPS API ver. 1 registered
[    0.326119] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.335455] PTP clock support registered
[    0.339467] EDAC MC: Ver: 3.0.0
[    0.343428] Advanced Linux Sound Architecture Driver Initialized.
[    0.350050] clocksource: Switched to clocksource arch_sys_counter
[    0.356364] VFS: Disk quotas dquot_6.6.0
[    0.360409] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.370031] NET: Registered protocol family 2
[    0.374817] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes)
[    0.382870] TCP established hash table entries: 32768 (order: 2, 262144 bytes)
[    0.390354] TCP bind hash table entries: 32768 (order: 3, 524288 bytes)
[    0.397625] TCP: Hash tables configured (established 32768 bind 32768)
[    0.404363] UDP hash table entries: 2048 (order: 0, 65536 bytes)
[    0.410549] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes)
[    0.417235] NET: Registered protocol family 1
[    0.421948] RPC: Registered named UNIX socket transport module.
[    0.428002] RPC: Registered udp transport module.
[    0.432806] RPC: Registered tcp transport module.
[    0.437608] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.444547] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.454300] Initialise system trusted keyrings
[    0.458915] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.467066] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.473261] NFS: Registering the id_resolver key type
[    0.478433] Key type id_resolver registered
[    0.482706] Key type id_legacy registered
[    0.486804] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.493734] 9p: Installing v9fs 9p2000 file system support
[    0.500875] Key type asymmetric registered
[    0.505067] Asymmetric key parser 'x509' registered
[    0.510078] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.517638] io scheduler noop registered
[    0.521645] io scheduler deadline registered
[    0.526061] io scheduler cfq registered (default)
[    0.530866] io scheduler mq-deadline registered
[    0.535493] io scheduler kyber registered
[    0.540535] pinctrl-single 4301c000.pinmux: 94 pins, size 376
[    0.546615] pinctrl-single 11c000.pinmux: 173 pins, size 692
[    0.552773] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[    0.562005] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.568428] ti-pat 31010000.pat: Failed to create 31010000.pat debugfs directory
[    0.576139] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.582552] ti-pat 31011000.pat: Failed to create 31011000.pat debugfs directory
[    0.590205] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.596618] ti-pat 31012000.pat: Failed to create 31012000.pat debugfs directory
[    0.604262] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.610584] ti-pat 31013000.pat: Failed to create 31013000.pat debugfs directory
[    0.618225] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.624546] ti-pat 31014000.pat: Failed to create 31014000.pat debugfs directory
[    0.633501] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.645202] brd: module loaded
[    0.651249] loop: module loaded
[    0.655693] libphy: Fixed MDIO Bus: probed
[    0.660049] tun: Universal TUN/TAP device driver, 1.6
[    0.665495] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    0.673500] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.679566] sky2: driver version 1.30
[    0.683959] VFIO - User Level meta-driver version: 0.3
[    0.689588] i2c /dev entries driver
[    0.693599] sdhci: Secure Digital Host Controller Interface driver
[    0.699916] sdhci: Copyright(c) Pierre Ossman
[    0.704571] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.710836] ledtrig-cpu: registered to indicate activity on CPUs
[    0.717861] optee: probing for conduit method from DT.
[    0.723131] optee: revision 3.7 (5208e5c1)
[    0.723312] optee: initialized driver
[    0.732018] NET: Registered protocol family 17
[    0.736633] 9pnet: Installing 9P2000 support
[    0.741020] Key type dns_resolver registered
[    0.745612] registered taskstats version 1
[    0.749798] Loading compiled-in X.509 certificates
[    0.759496] ti-sci 44083000.dmsc: ABI: 2.9 (firmware rev 0x0013 '19.12.1-v2019.12a (Terrific Lla')
[    0.784972] random: fast init done
[    0.828782] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.834731] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.840684] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.846707] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
[    0.854120] pca953x 3-0020: Linked as a consumer to regulator.0
[    0.882807] GPIO line 509 (VINOUT_MUX_SEL1) hogged as output/high
[    0.889353] GPIO line 508 (VINOUT_MUX_SEL0) hogged as output/low
[    0.895600] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
[    0.902998] pca953x 3-0022: Linked as a consumer to regulator.0
[    0.909872] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low
[    0.916597] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high
[    0.923182] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    0.929343] omap_i2c 2010000.i2c: bus 4 rev0.12 at 100 kHz
[    0.935237] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
[    0.941151] pca953x 6-0020: 6-0020 supply vcc not found, using dummy regulator
[    0.948560] pca953x 6-0020: Linked as a consumer to regulator.0
[    1.962180] pca953x 6-0020: failed reading register
[    1.967191] pca953x 6-0020: Dropping the link to regulator.0
[    1.972989] pca953x: probe of 6-0020 failed with error -16
[    1.978680] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[    1.984583] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[    1.990455] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[    1.996387] pca953x 9-0020: 9-0020 supply vcc not found, using dummy regulator
[    2.003792] pca953x 9-0020: Linked as a consumer to regulator.0
[    2.030471] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[    2.045902] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[    2.054667] cdns-pcie-host d000000.pcie: missing "mem"
[    2.060334] cdns-pcie-host d000000.pcie: Linked as a consumer to phy-5000000.serdes.0
[    3.069715] cdns-pcie-host d000000.pcie: Phy link never came up
[    3.075768] cdns-pcie-host d000000.pcie: host bridge /interconnect@100000/pcie@2900000/pcie@d000000 ranges:
[    3.085738] cdns-pcie-host d000000.pcie:    IO 0x10001000..0x10010fff -> 0x10001000
[    3.093570] cdns-pcie-host d000000.pcie:   MEM 0x4000000000..0x407fffffff -> 0x00000000
[    3.101820] cdns-pcie-host d000000.pcie: PCI host bridge to bus 0000:00
[    3.108582] pci_bus 0000:00: root bus resource [bus 00-0f]
[    3.114187] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[    3.123878] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x407fffffff] (bus address [0x00000000-0x7fffffff])
[    3.134664] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    3.144534] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    3.154432] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[    3.164393] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[    3.174384] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[    3.186228] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.194411] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    3.204370] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    3.214329] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    3.224287] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x6 may corrupt adjacent RW1C bits
[    3.235788] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x1a may corrupt adjacent RW1C bits
[    3.245759] pci 0000:00:00.0: PCI bridge to [bus 01]
[    3.251281] cdns-pcie-host d800000.pcie: missing "mem"
[    3.256947] cdns-pcie-host d800000.pcie: Linked as a consumer to phy-5010000.serdes.1
[    4.266326] cdns-pcie-host d800000.pcie: Phy link never came up
[    4.272381] cdns-pcie-host d800000.pcie: host bridge /interconnect@100000/pcie@2910000/pcie@d800000 ranges:
[    4.282349] cdns-pcie-host d800000.pcie:    IO 0x18001000..0x18010fff -> 0x18001000
[    4.290180] cdns-pcie-host d800000.pcie:   MEM 0x4100000000..0x417fffffff -> 0x00000000
[    4.298422] cdns-pcie-host d800000.pcie: PCI host bridge to bus 0001:00
[    4.305183] pci_bus 0001:00: root bus resource [bus 00-0f]
[    4.310788] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[    4.320657] pci_bus 0001:00: root bus resource [mem 0x4100000000-0x417fffffff] (bus address [0x00000000-0x7fffffff])
[    4.333209] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.343033] pci 0001:00:00.0: PCI bridge to [bus 01]
[    4.348512] cdns-pcie-host e000000.pcie: missing "mem"
[    4.354109] cdns-pcie-host e000000.pcie: Linked as a consumer to phy-5020000.serdes.2
[    5.363486] cdns-pcie-host e000000.pcie: Phy link never came up
[    5.369538] cdns-pcie-host e000000.pcie: host bridge /interconnect@100000/pcie@2920000/pcie@e000000 ranges:
[    5.379506] cdns-pcie-host e000000.pcie:    IO 0x4400001000..0x4400010fff -> 0x00001000
[    5.387691] cdns-pcie-host e000000.pcie:   MEM 0x4400011000..0x4407ffffff -> 0x00011000
[    5.395926] cdns-pcie-host e000000.pcie: PCI host bridge to bus 0002:00
[    5.402687] pci_bus 0002:00: root bus resource [bus 00-0f]
[    5.408292] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[    5.417538] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[    5.430084] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    5.439893] pci 0002:00:00.0: PCI bridge to [bus 01]
[    5.445444] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    5.455321] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    5.462081] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    5.469747] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    5.479887] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    5.486646] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    5.494272] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
[    5.501834] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
[    5.510976] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
[    5.519713] console [ttyS2] enabled
[    5.526750] bootconsole [ns16550a0] disabled
[    5.535651] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 20, base_baud = 3000000) is a 8250
[    5.544456] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 21, base_baud = 3000000) is a 8250
[    5.553184] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    5.561892] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
[    5.571934] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    5.582445] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    5.592600] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    5.602841] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    5.613663] scsi host0: ufshcd
[    5.628742] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[    5.634932] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[    5.641530] Creating 8 MTD partitions on "47040000.spi.0":
[    5.643436] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[    5.647004] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    5.665135] 0x000000080000-0x000000280000 : "ospi.tispl"
[    5.670639] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    5.676240] 0x000000680000-0x0000006a0000 : "ospi.env"
[    5.679574] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[    5.693175] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    5.699115] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    5.704608] 0x000000800000-0x000003fe0000 : "ospi.rootfs"
[    5.710222] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
[    5.830793] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[    5.842092] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    5.850847] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    5.854158] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[    5.866173] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[    5.874173] cadence-qspi 47050000.spi: n25q512a (65536 Kbytes)
[    5.894168] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[    5.901518] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22
[    5.908583] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[    5.920037] UDMA has not been proped
[    5.923615] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[    5.932189] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    5.940727] mmc0: Unknown controller version (4). You may experience problems.
[    5.947995] mmc0: CQHCI version 5.10
[    5.982317] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[    5.996668] vdd_mmc1: supplied by vsys_3v3
[    6.001219] pca953x 4-0021: 4-0021 supply vcc not found, using dummy regulator
[    6.008463] pca953x 4-0021: Linked as a consumer to regulator.0
[    6.040596] GPIO line 457 (HDMI_DDC_OE) hogged as output/high
[    6.047118] pca953x 4-0020: 4-0020 supply vcc not found, using dummy regulator
[    6.054414] pca953x 4-0020: Linked as a consumer to regulator.0
[    6.060435] mmc0: Command Queue Engine enabled
[    6.064873] mmc0: new HS400 MMC card at address 0001
[    6.070290] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[    6.075112] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[    6.081391] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[    6.087420] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (242:0)
[    6.095038] GPIO line 440 (DP0_PWR_SW_EN) hogged as output/high
[    6.102413] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    6.109292] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    6.116155] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    6.123057] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    6.129909] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    6.455714] ti-udma 285c0000.udmap: Channels: 24 (tchan: 48, echan: 0, rchan: 48, rflow: 96)
[    6.465317] ti-udma 31150000.udmap: Channels: 84 (tchan: 140, echan: 160, rchan: 140, rflow: 300)
[    6.476356] tfp410-bridge dvi-bridge: Connector's ddc i2c bus found
[    6.486683] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[    6.492859] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[    6.499460] Creating 8 MTD partitions on "47040000.spi.0":
[    6.504940] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    6.510728] 0x000000080000-0x000000280000 : "ospi.tispl"
[    6.516233] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    6.521851] 0x000000680000-0x0000006a0000 : "ospi.env"
[    6.527184] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    6.533111] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    6.538637] 0x000000800000-0x000003fe0000 : "ospi.rootfs"
[    6.544224] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
[    6.552261] cadence-qspi 47050000.spi: n25q512a (65536 Kbytes)
[    6.560179] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22
[    6.567249] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[    6.584808] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    6.595337] pps pps0: new PPS source ptp1
[    6.599483] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
[    6.608431] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 0.4
[    6.615635] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    6.658057] am65-cpsw-nuss 46000000.ethernet: davinci mdio revision 9.7, bus freq 1000000
[    6.666219] libphy: 46000000.ethernet: probed
[    6.671999] sdhci-am654 4fb0000.sdhci: Linked as a consumer to regulator.4
[    6.678889] sdhci-am654 4fb0000.sdhci: Linked as a consumer to regulator.5
[    6.685781] mmc1: Unknown controller version (4). You may experience problems.
[    6.693040] mmc1: CQHCI version 5.10
[    6.726613] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit
[    6.744639] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    6.751699] hctosys: unable to open rtc device (rtc0)
[    6.778808] ALSA device list:
[    6.781764]   No soundcards found.
[    6.785427] Waiting for root device PARTUUID=c22177f9-02...
[    8.179163] mmc1: new ultra high speed DDR50 SDHC card at address 59b4
[    8.186349] mmcblk1: mmc1:59b4       14.5 GiB
[    8.197244]  mmcblk1: p1 p2
[    8.273574] EXT4-fs (mmcblk1p2): recovery complete
[    8.278368] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    8.286465] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    8.296832] devtmpfs: mounted
[    8.299937] Freeing unused kernel memory: 576K
[    8.304387] Run /sbin/init as init process
[    8.457575] systemd[1]: System time before build time, advancing clock.
[    8.509149] NET: Registered protocol family 10
[    8.514042] Segment Routing with IPv6
[    8.538905] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    8.560351] systemd[1]: Detected architecture arm64.
Welcome to Arago 2019.11!
[    8.586629] systemd[1]: Set hostname to <j7-evm>.
[    8.684426] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    8.698889] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    8.716566] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    8.730640] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    8.746256] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    8.760495] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    8.776184] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[    8.881372] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Listening on Journal Socket.
[    8.902252] random: systemd: uninitialized urandom read (16 bytes read)
[    8.927327] random: systemd: uninitialized urandom read (16 bytes read)
[    8.946704] cmemk: loading out-of-tree module taints kernel.
[    8.953315] CMEMK module: reference Linux version 4.19.94
[  OK  ] Listening on Process Core Dump Socket.
[    8.959109] no physical memory specified
[    8.968099] cmemk initialized
[  OK  ] Started Forward Password Requests to Wall Di[    8.975835] cryptodev: driver 1.9 loaded.
rectory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Paths.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Reached target Remote File Systems.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[    9.171770] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[  OK  ] Listening on Network Service Netlink Socket.
         Starting Create list of required st…ce nodes for the current kernel...
[  OK  ] Reached target Swap.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Mounted Temporary Directory (/tmp).
         Starting Create Static Device Nodes in /dev...
         Starting Apply Kernel Variables...
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Mounted Kernel Configuration File System.
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
[  OK  ] Reached target Containers.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
[    9.648624] systemd-journald[151]: Received request to flush runtime journal from PID 1
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Load/Save Random Seed.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
[    9.757223] rti-wdt 2200000.rti: heartbeat 60 sec
         Starting Network Service...
[    9.773008] rti-wdt 2210000.rti: heartbeat 60 sec
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Service.
         Starting Wait for Network to be Configured...
         Starting Network Name Resolution...
[    9.898955] pcm3168a 6-0044: Linked as a consumer to regulator.2
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Synchronized.
[    9.924775] pcm3168a 6-0044: Linked as a consumer to regulator.3
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[   10.040359] pci-endpoint-test 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.048572] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[   10.059535] pci_generic_config_write32: 29 callbacks suppressed
[   10.059541] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[  OK  ] Listening on dropbear.socket.
[   10.080925] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Reached target Sockets.
[   10.116962] remoteproc remoteproc0: 4d80800000.dsp is available
[  OK  ] Reached target Basic System.
[   10.136604] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
         Starting RPC Bind Service...
[   10.156430] pci-endpoint-test 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
         Starting Login Service...
[   10.172937] remoteproc remoteproc0: powering up 4d80800000.dsp
[  OK  ] Started irqbalance daemon.
[   10.185773] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 1448016
         Starting rc.pvr.service...
[   10.212035] pci_bus 0001:00: 1-byte config write to 0001:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[  OK  ] Started D-Bus System Message Bus.
[   10.235581] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[  OK  ] Started Job spooling tools.
[   10.255734] virtio_rpmsg_bus virtio0: rpmsg host is online
[   10.265676] remoteproc remoteproc0: registered virtio0 (type 7)
         Starting Print notice about GPLv3 packages...
[   10.278691] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[   10.288532] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[   10.296290] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[  OK  ] Started Periodic Command Scheduler.
[   10.311803] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   10.323690] pci-endpoint-test 0002:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.331150] [drm] No driver support for vblank timestamp query.
[   10.339909] remoteproc remoteproc1: 4d81800000.dsp is available
[  OK  ] Started Daily rotation of log files.
[   10.351568] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[  OK  ] Reached target Timers.
[   10.363481] pci_bus 0002:00: 1-byte config write to 0002:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.376949] [drm] Cannot find any crtc or sizes
[   10.383828] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[   10.393257] [drm] Cannot find any crtc or sizes
[   10.400656] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[   10.407445] [drm] Cannot find any crtc or sizes
[   10.410224] remoteproc remoteproc2: 64800000.dsp is available
[  OK  ] Started TEE Supplicant.
[  OK  ] Started Network Name Resolution.
[  OK  ] Started Reboot and dump vmcore via kexec.
[  OK  ] Found device /dev/ttyS2.
[  OK  ] Started RPC Bind Service.
[   10.473204] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_edid_block [mhdp8546]] *ERROR* get block[0] edid failed: -22
[   10.487221] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_modes [mhdp8546]] *ERROR* Failed to read EDID
[   10.506296] remoteproc remoteproc1: powering up 4d81800000.dsp
[   10.506306] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 1448016
[   10.506423] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[   10.506980] virtio_rpmsg_bus virtio1: rpmsg host is online
[   10.507038] remoteproc remoteproc1: registered virtio1 (type 7)
[   10.507041] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
[   10.510596] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[   10.521623] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [mhdp8546]] *ERROR* Failed to read DPCD
[   10.606032] pvrsrvkm 4e20000000.gpu: Linked as a consumer to genpd:0:4e20000000.gpu
[   10.606564] pvrsrvkm 4e20000000.gpu: Linked as a consumer to genpd:1:4e20000000.gpu
[   10.606597] PVR_K:  295: Read BVNC 22.104.208.318 from HW device registers
[   10.606601] PVR_K:  295: RGX Device initialised with BVNC 22.104.208.318
[   10.633144] [drm] Initialized pvr 1.10.5371573 20170530 for 4e20000000.gpu on minor 1
[   10.639206] cdns-mhdp a000000.dp-bridge: [drm:mhdp_transfer [mhdp8546]] *ERROR* Failed to read DPCD
[   10.671426] Console: switching to colour frame buffer device 128x48
[   10.794737] tidss 4a00000.dss: fb0: DRM emulated frame buffer device
[  OK  ] Reached target Network.
         Starting Permit User Sessions...
[  OK  ] Reached target Host and Network Name Lookups.
[   10.835198] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_edid_block [mhdp8546]] *ERROR* get block[0] edid failed: -22
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Avahi mDNS/DNS-SD Stack...
[   10.854783] ntb_hw_epf 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.870263] cdns-mhdp a000000.dp-bridge: [drm:cdns_mhdp_get_modes [mhdp8546]] *ERROR* Failed to read EDID
[   10.907346] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.922363] ntb_hw_epf 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.930525] pci_bus 0001:00: 1-byte config write to 0001:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.942407] ntb_hw_epf 0002:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.957893] pci_bus 0002:00: 1-byte config write to 0002:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.968214] k3_r5_rproc interconnect@100000:interconnect@28380000:r5fss@41000000: creating child devices for R5F cores
[   10.968946] remoteproc remoteproc2: powering up 64800000.dsp
[   10.980534] platform 41000000.r5f: configured R5F for remoteproc mode
[   10.986923] pcm3168a 6-0044: Failed to reset device: -16
[   10.991596] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   10.996919] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 6954352
[   11.004582] remoteproc remoteproc3: 41000000.r5f is available
[   11.022233] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[   11.033987] pcm3168a: probe of 6-0044 failed with error -16
[   11.037052] remoteproc remoteproc3: Direct firmware load for j7-mcu-r5f0_0-fw failed with error -2
[   11.040844] virtio_rpmsg_bus virtio2: rpmsg host is online
[   11.050167] k3_r5_rproc interconnect@100000:r5fss@5c00000: creating child devices for R5F cores
[   11.057701] remoteproc remoteproc2: registered virtio2 (type 7)
[   11.062772] remoteproc remoteproc3: powering up 41000000.r5f
[   11.073598] remoteproc remoteproc2: remote processor 64800000.dsp is now up
[   11.074528] remoteproc remoteproc3: Direct firmware load for j7-mcu-r5f0_0-fw failed with error -2
[   11.094110] remoteproc remoteproc3: request_firmware failed: -2
[   11.106166] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[   11.132925] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[  OK  ] Started Login Service.
[  OK  ] Started Permit User Sessions.
[  OK  ] Found device /dev/ttyS1.
[  OK  ] Started rc.pvr.service.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
         Starting weston.service...
[  OK  ] Started Serial Getty on ttyS1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[   11.274935] platform 5c00000.r5f: configured R5F for IPC-only mode
[  OK  ] Started weston.service.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
         Starting telnetd.service...
         Starting DEMO...
[  OK  ] Started DEMO.
[  OK  ] Started telnetd.service.
         Starting thttpd.service...
[   11.342436] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[   11.351459] TI DP83867 k3-cpsw-mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=k3-cpsw-mdio:00, irq=POLL)
[   11.376473] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  OK  ] Started thttpd.service.
[   11.420637] remoteproc remoteproc4: 5c00000.r5f is available
[   11.450318] platform 5d00000.r5f: configured R5F for IPC-only mode
[   11.459818] remoteproc remoteproc4: powering up 5c00000.r5f
[   11.465575] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 128832
[   11.477808] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[   11.488416] virtio_rpmsg_bus virtio3: rpmsg host is online
[   11.496566] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[   11.498143] remoteproc remoteproc4: registered virtio3 (type 7)
[   11.507840] remoteproc remoteproc5: 5d00000.r5f is available
[   11.517462] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
[   11.524917] k3_r5_rproc interconnect@100000:r5fss@5e00000: creating child devices for R5F cores
[   11.536185] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[   11.601258] platform 5e00000.r5f: configured R5F for remoteproc mode
[   11.633311] remoteproc remoteproc5: powering up 5d00000.r5f
[   11.639242] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 3811288
[   11.653353] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[   11.659051] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[   11.662540] virtio_rpmsg_bus virtio4: rpmsg host is online
[   11.668328] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
Todor
  • Hi Todor,
    I do not suspect it to be a hardware issue as 7.1 seems to be booting correctly. Could you please
    make the SD card for 6.02 correctly?
    I see that mcu0_0 firmware is not loaded properly.
    Just make sure that you have a clean 6.2 based SD card.
    Keerthy
  • Hi Keerthy,
    That same SD card with PSDK 6.2 boots successfully on another device.
    I followed your suggestion and downloaded the prebuilt binaries from the PSDK 6.2's download page. Then I executed the provided scripts which format the SD card and copy the prebuilt binaries. The device could not boot successfully. I could not post the log in this Reply, so I edited the main post.
    Todor
  • Hi Todor,
    Once you enter u-boot prompt please give the following commands:
    env default -a
    saveenv
    boot
    Let me know if that helps.
    Keerthy
  • Hello Keerthy,
    Your suggestion was able to resolve the issue. Thank you for the help!
    Todor
