My customer had the following question on the 8167:
Because T.I. tends to redefine the RSVD pins on their DSPs, should I add zero ohm resistors on these pins to allow for changes to the RSVD pin definitions? Currently I have the RSVD pins tied directly to supply voltages or no-connects. Adding these resistors will be a routing challenge. Can you find out if these pins are likely to ever change?
If not I would prefer to leave them as they are currently connected.
Tom
