TDA4VM: D3 Camera wont start with single or multi cam app
Part Number: TDA4VM
I have one system that works fine with the D3 IMX390 module (both RCM and CM). J721EXCP01EVM, J721EXSOMG01EVM and EVM577PFUSION-V1-0 are the three pieces I have. If I move that SD card to a new system it boots fine, I can get to the terminal and launch the apps but the cameras never fully come up. Below is the output from a successful start on my one working system. The other boards they make it through init but not much further and just hang forever. Same exact camera and cable etc. Anybody have any ideas?
root@j7-evm:~# cd /opt/vision_apps/
root@j7-evm:/opt/vision_apps# ./run_app_single_cam.sh
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
APP: Init ... Done !!!
69.015352 s: VX_ZONE_INIT:Enabled
69.015414 s: VX_ZONE_ERROR:Enabled
69.015420 s: VX_ZONE_WARNING:Enabled
69.016043 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
69.016286 s: VX_ZONE_INIT:[tivxHostInit:48] Initialization Done for HOST !!!
sensor_selection = [0]
ldc_enable = [0]
num_frames_to_run = [1000000000]
is_interactive = [1]
IttCtrl_registerHandler: command echo registered at location 0
IttCtrl_registerHandler: command iss_read_2a_params registered at location 1
IttCtrl_registerHandler: command iss_write_2a_params registered at location 2
IttCtrl_registerHandler: command iss_raw_save registered at location 3
IttCtrl_registerHandler: command iss_yuv_save registered at location 4
IttCtrl_registerHandler: command iss_read_sensor_reg registered at location 5
IttCtrl_registerHandler: command iss_write_sensor_reg registered at location 6
IttCtrl_registerHandler: command dev_ctrl registered at location 7
IttCtrl_registerHandler: command iss_send_dcc_file registered at location 8
NETWORK: Opened at IP Addr = 10.1.1.120, socket port=5000!!!
69.018608 s: ISS: Enumerating sensors ... !!!
69.019079 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
69.019115 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
69.019134 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
69.019150 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
69.019163 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
69.019178 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
6 sensor(s) found
Supported sensor list:
a : IMX390-UB953_D3
b : AR0233-UB953_MARS
c : AR0820-UB953_LI
d : UB9xxx_RAW12_TESTPATTERN
e : UB96x_UYVY_TESTPATTERN
f : GW_AR0233_UYVY
Select a sensor
a
LDC Selection Yes(1)/No(0)
0
Sensor selected : IMX390-UB953_D3
Querying IMX390-UB953_D3
72.965605 s: ISS: Querying sensor [IMX390-UB953_D3] ... !!!
72.965917 s: ISS: Querying sensor [IMX390-UB953_D3] ... Done !!!
72.965929 s: ISS: Initializing sensor [IMX390-UB953_D3], doing IM_SENSOR_CMD_PWRON ... !!!
73.166521 s: ISS: Initializing sensor [IMX390-UB953_D3], doing IM_SENSOR_CMD_CONFIG ... !!!
75.954356 s: ISS: Initializing sensor [IMX390-UB953_D3] ... Done !!!
Test data path is NULL. Defaulting to current folder
reading test RAW image .//img_test.raw
read_test_image_raw : Unable to open file .//img_test.raw
Unsuccessful start ends here and just hangs
Scaler is enabled
Demo : Single Camera w/ 2A
p: Print performance statistics
s: Save Sensor RAW, VISS Output and H3A output images to File System
e: Export performance statistics
u: Update DCC from File System
x: Exit
Enter Choice:
Unsupported command
x: Exit
Enter Choice: 76.028284 s: ISS: Starting sensor [IMX390-UB953_D3] ... !!!
76.582362 s: ISS: Starting sensor [IMX390-UB953_D3] ... !!!
  • Doing a little more digging on this. My working system is an alpha board, the non-working ones are beta. I cant tell if i need to manually make changes for this? Found some reference to uEnv.txt but not sure if that is deprecated, dont seem to have the alpha/beta files referenced. Found mention of uBoot applying the correct dtb automatically as well. Not sure what is relevant for 7.0.2?
    Prior to running the app, did you run "source ./vision_apps_init.sh" as outlined in the documentation below?
    https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/latest/exports/docs/vision_apps/docs/user_guide/RUN_INSTRUCTIONS.html#run_step_run_on_evm_linux
    Lucas
  • I did run ./vision_apps_init.sh but not sourcing it originally, although not on all boots since i was trying anything possible to get this to run. Tried sourcing it now and doesn't change anything. I also tried to reset the env as stated in the link you sent but that didn't help either. Below is the output from boot all the way through to camera config. Just hangs at the end.
    U-Boot SPL 2020.01-g3c9ebdb87d (Jan 25 2021 - 04:06:36 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla')
    Trying to boot from MMC2
    Loading Environment from MMC... *** Warning - No MMC card found, using default environment
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.3():07.01.00.006-dirty
    NOTICE:  BL31: Built : 03:49:38, Jan 25 2021
    U-Boot SPL 2020.01-g3c9ebdb87d (Jan 25 2021 - 04:02:01 +0000)
    Detected: J7X-BASE-CPB rev E3
    Detected: J7X-VSC8514-ETH rev E2
    U-Boot 2020.01-g3c9ebdb87d (Jan 25 2021 - 04:02:01 +0000)
    SoC:   J721E SR2.0
    Model: Texas Instruments K3 J721E SoC
    Board: J721EX-PM2-SOM rev E8
    DRAM:  4 GiB
    not found for dev hbmc-mux
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    Loading Environment from MMC... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:
    Warning: ethernet@46000000 using MAC address from ROM
    eth0: ethernet@46000000
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    483 bytes read in 2 ms (235.4 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    Running uenvcmd ...
    1 bytes read in 2 ms (0 Bytes/s)
    Already setup.
    5216600 bytes read in 112 ms (44.4 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 5216600 bytes: Success!
    1964032 bytes read in 45 ms (41.6 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 1964032 bytes: Success!
    1579152 bytes read in 35 ms (43 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 1579152 bytes: Success!
    1579152 bytes read in 36 ms (41.8 MiB/s)
    Load Remote Processor 7 with data@addr=0x82000000 1579152 bytes: Success!
    9969648 bytes read in 88 ms (108 MiB/s)
    Load Remote Processor 8 with data@addr=0x82000000 9969648 bytes: Success!
    16666632 bytes read in 347 ms (45.8 MiB/s)
    93829 bytes read in 5 ms (17.9 MiB/s)
    6199 bytes read in 3 ms (2 MiB/s)
       Loading Device Tree to 000000008fee6000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.4.74-g9574bba32a (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Mon Jan 25 04:03:30 UTC 2021
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 7 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a5100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@a5800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5900000, size 7 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a5900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-dma-memory@ac000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ce000000, size 720 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-core-heap-memory@ce000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-dma-memory@fb000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@fb100000, compatible id shared-dma-pool
    [    0.000000] cma: Failed to reserve 512 MiB
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.0
    [    0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] Built 1 zonelists, mobility grouping off.  Total pages: 35779
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),57216k@8m(ospi.rootfs),128k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=4d26e277-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x9a800000-0x9e800000] (64MB)
    [    0.000000] Memory: 2584000K/2293760K available (9598K kernel code, 788K rwdata, 3840K rodata, 1664K init, 683K bss, 18446744073709261376K reserved, 0K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: no VLPI support, no direct LPI support
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008c00c0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000
    [    0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x43c with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008371] Console: colour dummy device 80x25
    [    0.012937] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023606] pid_max: default: 32768 minimum: 301
    [    0.028360] LSM: Security Framework initializing
    [    0.033115] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.040686] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [    0.049983] ASID allocator initialised with 32768 entries
    [    0.055579] rcu: Hierarchical SRCU implementation.
    [    0.060649] Platform MSI: gic-its@1820000 domain created
    [    0.066327] PCI/MSI: /bus@100000/interrupt-controller@1800000/gic-its@1820000 domain created
    [    0.075189] smp: Bringing up secondary CPUs ...
    [    0.081288] Detected PIPT I-cache on CPU1
    [    0.081312] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.081323] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000
    [    0.081358] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.081421] smp: Brought up 1 node, 2 CPUs
    [    0.110768] SMP: Total of 2 processors activated.
    [    0.115572] CPU features: detected: 32-bit EL0 Support
    [    0.120825] CPU features: detected: CRC32 instructions
    [    0.132753] CPU: All CPU(s) started at EL2
    [    0.136950] alternatives: patching kernel code
    [    0.142159] devtmpfs: initialized
    [    0.150678] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.160648] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [    0.168098] pinctrl core: initialized pinctrl subsystem
    [    0.173982] NET: Registered protocol family 16
    [    0.178753] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.185281] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.201407] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.208266] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.215027] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.223215] cryptd: max_cpu_qlen set to 1000
    [    0.229796] vsys_3v3: supplied by evm_12v0
    [    0.234128] vsys_5v0: supplied by evm_12v0
    [    0.238742] iommu: Default domain type: Translated
    [    0.243931] SCSI subsystem initialized
    [    0.248064] mc: Linux media interface: v0.10
    [    0.252434] videodev: Linux video capture interface: v2.00
    [    0.258045] pps_core: LinuxPPS API ver. 1 registered
    [    0.263114] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.272450] PTP clock support registered
    [    0.276462] EDAC MC: Ver: 3.0.0
    [    0.280240] FPGA manager framework
    [    0.283751] Advanced Linux Sound Architecture Driver Initialized.
    [    0.290440] clocksource: Switched to clocksource arch_sys_counter
    [    0.296772] VFS: Disk quotas dquot_6.6.0
    [    0.300827] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [    0.310501] Carveout Heap: Exported 512 MiB at 0x00000000ae000000
    [    0.316733] thermal_sys: Registered thermal governor 'step_wise'
    [    0.316735] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.323206] NET: Registered protocol family 2
    [    0.334628] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [    0.343393] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [    0.351589] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [    0.359393] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.366144] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.373035] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [    0.380448] NET: Registered protocol family 1
    [    0.385225] RPC: Registered named UNIX socket transport module.
    [    0.391280] RPC: Registered udp transport module.
    [    0.396084] RPC: Registered tcp transport module.
    [    0.400886] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.407471] PCI: CLS 0 bytes, default 64
    [    0.411871] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    0.422073] Initialise system trusted keyrings
    [    0.426715] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [    0.435495] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.441739] NFS: Registering the id_resolver key type
    [    0.446913] Key type id_resolver registered
    [    0.451184] Key type id_legacy registered
    [    0.455279] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.462253] 9p: Installing v9fs 9p2000 file system support
    [    0.475077] Key type asymmetric registered
    [    0.479263] Asymmetric key parser 'x509' registered
    [    0.484268] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.491826] io scheduler mq-deadline registered
    [    0.496452] io scheduler kyber registered
    [    0.501748] pinctrl-single 4301c000.pinmux: 94 pins, size 376
    [    0.507854] pinctrl-single 11c000.pinmux: 173 pins, size 692
    [    0.516184] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.522492] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.528846] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.535259] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    [    0.543260] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.549679] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    [    0.557613] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.564025] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    [    0.571954] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.578283] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    [    0.586207] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.592533] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    [    0.601933] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.614103] brd: module loaded
    [    0.620572] loop: module loaded
    [    0.624199] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
    [    0.632125] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.74-g9574bba32a #1
    [    0.639235] Hardware name: Texas Instruments K3 J721E SoC (DT)
    [    0.645190] Call trace:
    [    0.647688]  dump_backtrace+0x0/0x140
    [    0.651423]  show_stack+0x14/0x20
    [    0.654805]  dump_stack+0xb4/0x114
    [    0.658286]  sysfs_warn_dup+0x5c/0x78
    [    0.662020]  sysfs_create_dir_ns+0xd8/0xf0
    [    0.666203]  kobject_add_internal+0x94/0x280
    [    0.670559]  kobject_add+0x90/0xf8
    [    0.674029]  device_add+0xdc/0x600
    [    0.677497]  platform_device_add+0xfc/0x228
    [    0.681764]  platform_device_register_full+0xc8/0x140
    [    0.686923]  dma_buf_phys_init+0x68/0x94
    [    0.690925]  do_one_initcall+0x50/0x1a8
    [    0.694842]  kernel_init_freeable+0x194/0x23c
    [    0.699288]  kernel_init+0x10/0xfc
    [    0.702756]  ret_from_fork+0x10/0x1c
    [    0.706417] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
    [    0.720584] libphy: Fixed MDIO Bus: probed
    [    0.725005] tun: Universal TUN/TAP device driver, 1.6
    [    0.730465] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
    [    0.738467] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.744534] sky2: driver version 1.30
    [    0.748835] VFIO - User Level meta-driver version: 0.3
    [    0.754485] i2c /dev entries driver
    [    0.758563] sdhci: Secure Digital Host Controller Interface driver
    [    0.764877] sdhci: Copyright(c) Pierre Ossman
    [    0.769552] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.775808] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.782630] optee: probing for conduit method from DT.
    [    0.787892] optee: revision 3.8 (199fca17)
    [    0.788269] optee: initialized driver
    [    0.797110] NET: Registered protocol family 17
    [    0.801735] 9pnet: Installing 9P2000 support
    [    0.806135] Key type dns_resolver registered
    [    0.810696] registered taskstats version 1
    [    0.814886] Loading compiled-in X.509 certificates
    [    0.823615] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.829944] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.838281] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla')
    [    0.981072] random: fast init done
    [    1.168160] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    1.179383] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    1.185805] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.192454] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    1.199114] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
    [    1.206542] pca953x 3-0020: using no AI
    [    1.234981] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
    [    1.242383] pca953x 3-0022: using AI
    [    1.246667] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low
    [    1.253268] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high
    [    1.260111] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.266515] omap_i2c 2020000.i2c: bus 4 rev0.12 at 100 kHz
    [    1.272888] pca953x 5-0020: 5-0020 supply vcc not found, using dummy regulator
    [    1.280303] pca953x 5-0020: using no AI
    [    2.290598] pca953x 5-0020: failed writing register
    [    2.295641] pca953x: probe of 5-0020 failed with error -16
    [    2.301365] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
    [    2.307720] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
    [    2.314156] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
    [    2.320972] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    2.331366] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    2.340593] ti-sci-intr bus@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created
    [    2.351741] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    3.394295] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    3.402003] j721e-pcie 2900000.pcie:    IO 0x10001000..0x10010fff -> 0x10001000
    [    3.409492] j721e-pcie 2900000.pcie:   MEM 0x10011000..0x17ffffff -> 0x10011000
    [    3.417049] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [    3.423456] pci_bus 0000:00: root bus resource [bus 00-0f]
    [    3.429060] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    3.438751] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    3.445792] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    3.451943] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    3.461812] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    3.471699] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
    [    3.481657] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    3.491623] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
    [    3.501585] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
    [    3.511569] pci 0000:00:00.0: supports D1
    [    3.515662] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    3.521534] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
    [    3.533192] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.541381] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    3.551339] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    3.561297] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
    [    3.572768] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
    [    3.579539] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    3.584811] pcieport 0000:00:00.0: PME: Signaling with IRQ 37
    [    3.590843] pcieport 0000:00:00.0: AER: enabled with IRQ 37
    [    4.601058] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    4.608736] j721e-pcie 2910000.pcie:    IO 0x18001000..0x18010fff -> 0x18001000
    [    4.616213] j721e-pcie 2910000.pcie:   MEM 0x18011000..0x1fffffff -> 0x18011000
    [    4.623751] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [    4.630158] pci_bus 0001:00: root bus resource [bus 00-0f]
    [    4.635762] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    4.645629] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    4.652666] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    4.658873] pci 0001:00:00.0: supports D1
    [    4.662967] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    4.670446] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    4.680140] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
    [    4.686908] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    4.692164] pcieport 0001:00:00.0: PME: Signaling with IRQ 40
    [    4.698173] pcieport 0001:00:00.0: AER: enabled with IRQ 40
    [    5.707973] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    5.715653] j721e-pcie 2920000.pcie:    IO 0x4400001000..0x4400010fff -> 0x00001000
    [    5.723484] j721e-pcie 2920000.pcie:   MEM 0x4400011000..0x4407ffffff -> 0x00011000
    [    5.731377] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
    [    5.737783] pci_bus 0002:00: root bus resource [bus 00-0f]
    [    5.743388] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
    [    5.752634] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
    [    5.763402] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
    [    5.769608] pci 0002:00:00.0: supports D1
    [    5.773702] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
    [    5.781168] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    5.790814] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
    [    5.797580] pci 0002:00:00.0: PCI bridge to [bus 01]
    [    5.802829] pcieport 0002:00:00.0: PME: Signaling with IRQ 43
    [    5.808846] pcieport 0002:00:00.0: AER: enabled with IRQ 43
    [    5.815764] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    5.825641] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    5.832399] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    5.841778] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    5.851931] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    5.858690] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    5.867128] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
    [    5.876778] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250
    [    5.885520] printk: console [ttyS2] enabled
    [    5.893958] printk: bootconsole [ns16550a0] disabled
    [    5.904746] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250
    [    5.914141] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 24, base_baud = 3000000) is a 8250
    [    5.923357] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    5.932467] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq
    [    5.941601] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq
    [    5.949310] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
    [    5.959089] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    5.969601] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    5.979755] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    5.989993] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    6.004019] scsi host0: ufshcd
    [    6.026011] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
    [    6.057187] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
    [    6.058444] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    6.076456] libphy: 46000f00.mdio: probed
    [    6.080458] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
    [    6.081616] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    6.099840] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    6.112645] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    6.112716] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
    [    6.129206] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    6.133548] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    6.146196] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [    6.147255] mmc0: CQHCI version 5.10
    [    6.197015] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
    [    6.208680] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    6.240852] vdd_mmc1: supplied by vsys_3v3
    [    6.247185] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    6.255681] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    6.264215] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    6.272679] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    6.281178] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    6.295017] ti-udma 285c0000.dma-controller: Channels: 24 (tchan: 12, rchan: 12, gp-rflow: 8)
    [    6.308876] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
    [    6.319573] mmc0: Command Queue Engine enabled
    [    6.324021] mmc0: new HS200 MMC card at address 0001
    [    6.329590] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    6.334316] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    6.340486] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    6.346533] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0)
    [    6.375535] cadence-qspi 47040000.spi: PHY calibration failed: -2
    [    6.381624] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
    [    6.386848] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    6.393446] Creating 8 MTD partitions on "47040000.spi.0":
    [    6.398921] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    6.404889] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    6.410696] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    6.416493] 0x000000680000-0x0000006a0000 : "ospi.env"
    [    6.422065] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
    [    6.428233] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    6.433914] 0x000000800000-0x000003fe0000 : "ospi.rootfs"
    [    6.439794] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
    [    6.457259] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
    [    6.502456] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    6.510105] libphy: 46000f00.mdio: probed
    [    6.515234] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    6.523500] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    6.542093] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    6.551392] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4
    [    6.558691] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    6.565955] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    6.579306] mmc1: CQHCI version 5.10
    [    7.644219] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit
    [    7.653490] davinci-mcasp 2ba0000.mcasp: IRQ common not found
    [    7.695047] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    7.702471] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    7.709786] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    7.717093] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    7.725439] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    7.732308] hctosys: unable to open rtc device (rtc0)
    [    7.745556] mmc1: new ultra high speed DDR50 SDXC card at address 0001
    [    7.752517] mmcblk1: mmc1:0001 GC2QT 59.6 GiB
    [    7.759693]  mmcblk1: p1 p2
    [    7.889981] ALSA device list:
    [    7.892945]   No soundcards found.
    [    8.081474] EXT4-fs (mmcblk1p2): recovery complete
    [    8.099684] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    8.107808] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    8.118161] devtmpfs: mounted
    [    8.121564] Freeing unused kernel memory: 1664K
    [    8.126116] Run /sbin/init as init process
    [    8.301845] systemd[1]: System time before build time, advancing clock.
    [    8.356256] NET: Registered protocol family 10
    [    8.361239] Segment Routing with IPv6
    [    8.382337] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    8.404219] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2020.09!
    [    8.449709] systemd[1]: Set hostname to <j7-evm>.
    [    8.664323] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    [    8.731506] random: systemd: uninitialized urandom read (16 bytes read)
    [    8.738241] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    8.750567] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    8.760680] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    8.782537] random: systemd: uninitialized urandom read (16 bytes read)
    [    8.789840] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    8.806509] random: systemd: uninitialized urandom read (16 bytes read)
    [    8.813658] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    8.830619] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    8.854561] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    8.878550] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    8.894498] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    8.910488] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    8.926491] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    8.947634] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    8.966537] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    8.984963] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    9.002656] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    9.035780] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    9.044176] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    9.062747] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    9.078810] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    9.098696] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    9.118615] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    9.143189] systemd[1]: Mounting Huge Pages File System...
    [    9.163208] systemd[1]: Mounting POSIX Message Queue File System...
    [    9.190992] systemd[1]: Mounting Kernel Debug File System...
    [    9.212411] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    9.236209] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    9.266545] systemd[1]: Starting Start psplash boot splash screen...
    [    9.298300] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [    9.323009] systemd[1]: Starting RPC Bind...
    [    9.338707] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    9.362182] systemd[1]: Starting Journal Service...
    [    9.390222] systemd[1]: Starting Load Kernel Modules...
    [    9.412834] cryptodev: loading out-of-tree module taints kernel.
    [    9.424201] systemd[1]: Starting Remount Root and Kernel File Systems...
             [    9.438911] cryptodev: driver 1.10 loaded.
    [    9.459959] systemd[1]: Starting udev Coldplug all Devices...
    [    9.488059] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    9.489509] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    9.511800] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
    [    9.735600] systemd-journald[169]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API.
    [  OK  ] Listening on dropbear.socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting rc.pvr.service...
             Starting Login Service...
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framew[   10.649011] rti-wdt 2200000.watchdog: heartbeat 60 sec
    ork.
    [  OK  ] Reached target Network (Pre).
             Starting Network Service...
    [   10.817208] PVR_K:  244: Read BVNC 22.104.208.318 from HW device registers
    [   10.826472] PVR_K:  244: RGX Device initialised with BVNC 22.104.208.318
    [   10.840706] [drm] Initialized pvr 1.10.5371573 20170530 for 4e20000000.gpu on minor 0
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Started Login Service.
    [   10.917265] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [   11.321230] rti-wdt 2210000.watchdog: heartbeat 60 sec
    [   11.510435] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [   11.801634] remoteproc remoteproc0: 4d80800000.dsp is available
    [   11.871986] random: crng init done
    [   11.875387] random: 7 urandom warning(s) missed due to ratelimiting
    [   11.903841] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    [  OK  ] Started Load/Save Random Seed.
    [   11.967418] remoteproc remoteproc0: powering up 4d80800000.dsp
    [   11.973289] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 1579152
    [   11.986527] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [   11.993330]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
    [   12.007114] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   12.012685]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [   12.023350] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
    [   12.031759] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [   12.086191] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [   12.150573] CAN device driver interface
    [   12.215219] m_can_platform 40528000.can: m_can device registered (irq=15, version=32)
    [  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
    [   12.430711] remoteproc remoteproc1: 4d81800000.dsp is available
    [   12.477861] m_can_platform 40568000.can: m_can device registered (irq=17, version=32)
    [   12.586814] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [   12.619320] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [   12.631248] remoteproc remoteproc1: powering up 4d81800000.dsp
    [   12.637108] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 1579152
    [   12.650599] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [   12.658088]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
    [   12.671356] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   12.681194]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [   12.690464] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
    [   12.695379] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [   12.978648] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [   13.015917] platform 41000000.r5f: configured R5F for IPC-only mode
    [   13.150656] remoteproc remoteproc2: 64800000.dsp is available
    NOTICE: This file system contains the following GPLv3 packages[   13.182762] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	glmark2
    	gstreamer1.0-libav
    	gzip
    	less
    	libasm1
    	libbfd
    	libdw1
    	libelf1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp10
    	libidn2-0
    	libmpc3
    	libmpfr6
    	libreadline-dev
    	libreadline8
    	libunistring2
    	m4-dev
    	m4
    	make
    	nettle
    	parted
    	tar
    	which
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [   13.367520] remoteproc remoteproc2: powering up 64800000.dsp
    [   13.373239] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 9969648
    [   13.386720] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [   13.393398]  remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
    [   13.411230] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   13.416785]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [   13.426480] remoteproc remoteproc2: remote processor 64800000.dsp is now up
    [   13.438796] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [   13.467976] remoteproc remoteproc3: 41000000.r5f is available
    [   13.492551] remoteproc remoteproc3: powering up 41000000.r5f
    [   13.498490] remoteproc remoteproc3: Booting fw image j7-mcu-r5f0_0-fw, size 195880
    [   13.510676] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [   13.522477]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [   13.535685] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   13.545258]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [   13.553711] remoteproc remoteproc3: remote processor 41000000.r5f is now up
    [   13.584927] platform 5c00000.r5f: configured R5F for IPC-only mode
    [   13.591206] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [   13.602663] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [   13.718590] platform 5c00000.r5f: assigned reserved memory node vision_apps-r5f-dma-memory@a1000000
    [   13.748894] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    [   13.768973] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [   13.908432] remoteproc remoteproc4: 5c00000.r5f is available
    [   14.003732] platform 5d00000.r5f: configured R5F for IPC-only mode
    [   14.082320] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   14.113443] remoteproc remoteproc4: powering up 5c00000.r5f
    [   14.119061] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 5216600
    [   14.132844] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [   14.142489]  remoteproc4#vdev0buffer: assigned reserved memory node vision_apps-r5f-dma-memory@a1000000
    [   14.157640] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   14.163216]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [   14.174459] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
    [   14.184917] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [   14.230665] remoteproc remoteproc5: 5d00000.r5f is available
    [   14.388130] remoteproc remoteproc5: powering up 5d00000.r5f
    [   14.393800] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 1964032
    [   14.406596] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [   14.416584]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
    [   14.430986] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   14.436503]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [   14.446393] platform 5e00000.r5f: configured R5F for remoteproc mode
    [   14.452823] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
    [   14.459977] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [   14.467148] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [   14.478610] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [   14.485879] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [   14.498585] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [   14.505863] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [   14.518616] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [   14.528120] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [   14.535746] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [   14.550688] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
    [   14.558739] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
    [   14.588966] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: Device info: permissions: 07FFFFFF uart_id: 2
    [   14.601026] platform 5e00000.r5f: assigned reserved memory node vision_apps-r5f-dma-memory@a5000000
    [   14.610176] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: FW ver 0.1 (rev 1)  3/Feb/2021 SHA:
    [   14.620290] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [   14.636000] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
    [   14.643939] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:00000003 rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00
    [   14.659178] remoteproc remoteproc6: 5e00000.r5f is available
    [   14.662450] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
    [   14.713291] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   14.789510] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [   14.815717] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
    [   14.824126] platform 5f00000.r5f: configured R5F for remoteproc mode
    [   14.832784] remoteproc remoteproc6: powering up 5e00000.r5f
    [   14.841389] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   14.842149] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
    [   14.866712] remoteproc remoteproc6: request_firmware failed: -2
    [   14.883594] platform 5f00000.r5f: assigned reserved memory node vision_apps-r5f-dma-memory@a5800000
    [   15.054614] remoteproc remoteproc7: 5f00000.r5f is available
    [   15.169487] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
    [   15.182471] remoteproc remoteproc7: powering up 5f00000.r5f
    [   15.188087] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
    [   15.206460] remoteproc remoteproc7: request_firmware failed: -2
    [   15.213789] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   15.224443] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [  OK  ] Created slice system-weston.slice.
    [  OK  ] Started Weston Wayland Compositor.
    [   15.882043] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   15.891580] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   15.913933] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   15.922471] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   15.932117] remoteproc remoteproc8: b034000.pru is available
    [   15.948970] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   15.958495] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   15.971658] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [  OK  ] Created slice User Slice of UID 0[[   15.990507] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    0m.
             Starting User Runtime Directory /run/user/0[0[   16.018517] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    m...
    [  OK  ] [   16.046888] pru-rproc b034000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@34000 probed successfully
    Started User Runtime Directory /run/user/0.
             Starting User Manager for UID 0...
    [   16.189703] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   16.202455] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   16.246124] remoteproc remoteproc9: b004000.rtu is available
    [   16.252175] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   16.259714] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   16.303862] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   16.314594] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   16.314721] pru-rproc b004000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@4000 probed successfully
    [   16.327577] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   16.342488] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   16.379010] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   16.392734] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   16.407002] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   16.422556] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   16.534044] cdns-usb3 6000000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
    [   16.569648] pru-rproc b00a000.txpru: IRQ vring not found
    [   16.575443] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   16.584254] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   16.659622] pru-rproc b00a000.txpru: IRQ kick not found
    [   16.687488] cdns-usb3 6400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
    [   16.695266] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   16.702922] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   16.711098] remoteproc remoteproc10: b00a000.txpru is available
    [   16.735765] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   16.743262] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   16.747226] pru-rproc b00a000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@a000 probed successfully
    [   16.848698] remoteproc remoteproc11: b038000.pru is available
    [   16.854901] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   16.862647] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   16.907962] pru-rproc b038000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@38000 probed successfully
    [   17.009794] remoteproc remoteproc12: b006000.rtu is available
    [   17.016265] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   17.027654] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   17.042549] pru-rproc b006000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@6000 probed successfully
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7-evm ttyS2
    Arago 2020.09 j7-evm ttyS2
    j7-evm login: [   17.172908] pru-rproc b00c000.txpru: IRQ vring not found
    [   17.179492] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   17.189168] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   17.241992] pru-rproc b00c000.txpru: IRQ kick not found
    [   17.325038] remoteproc remoteproc13: b00c000.txpru is available
    [   17.344964] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
    [   17.370016] pru-rproc b00c000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@c000 probed successfully
    [   17.371956] usbcore: registered new interface driver usbfs
    [   17.392435] remoteproc remoteproc14: b134000.pru is available
    [   17.398618] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   17.406108] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   17.407275] usbcore: registered new interface driver hub
    [   17.418492] pru-rproc b134000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@34000 probed successfully
    [   17.428836] usbcore: registered new device driver usb
    [   17.434291] remoteproc remoteproc15: b104000.rtu is available
    [   17.440422] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   17.447917] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   17.463146] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   17.466591] pru-rproc b104000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@4000 probed successfully
    [   17.478856] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   17.486731] pru-rproc b10a000.txpru: IRQ vring not found
    [   17.492372] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   17.499193] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
    [   17.499867] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   17.522449] pru-rproc b10a000.txpru: IRQ kick not found
    [   17.526755] xhci-hcd xhci-hcd.2.auto: irq 599, io mem 0x06410000
    [   17.528398] remoteproc remoteproc16: b10a000.txpru is available
    [   17.539069] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    [   17.554476] pru-rproc b10a000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@a000 probed successfully
    [   17.562789] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   17.571872] remoteproc remoteproc17: b138000.pru is available
    [   17.577974] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   17.585384] usb usb1: Product: xHCI Host Controller
    [   17.585484] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   17.594444] usb usb1: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
    [   17.606526] pru-rproc b138000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@38000 probed successfully
    [   17.614439] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   17.621522] hub 1-0:1.0: USB hub found
    [   17.626806] remoteproc remoteproc18: b106000.rtu is available
    [   17.630654] hub 1-0:1.0: 1 port detected
    [   17.632909] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   17.642887] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   17.643950] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   17.654489] pru-rproc b106000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@6000 probed successfully
    [   17.666056] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   17.670464] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   17.673547] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   17.690457] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   17.697671] pru-rproc b10c000.txpru: IRQ vring not found
    [   17.703312] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   17.714452] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   17.721575] pru-rproc b10c000.txpru: IRQ kick not found
    [   17.730509] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   17.742520] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
    [   17.742679] remoteproc remoteproc19: b10c000.txpru is available
    [   17.758449] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   17.774441] usb usb2: Product: xHCI Host Controller
    [   17.774473] pru-rproc b10c000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@c000 probed successfully
    [   17.779311] usb usb2: Manufacturer: Linux 5.4.74-g9574bba32a xhci-hcd
    [   17.779313] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   17.786859] hub 2-0:1.0: USB hub found
    [   17.803636] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   17.813073] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   17.875397] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [   17.883944] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   17.950465] hub 2-0:1.0: 1 port detected
    [   17.982483] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [   18.004380] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   18.011883] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    [   18.142769] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
    [   18.154442] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
    [   18.161570] usb 1-1: SerialNumber: A1070051A7A1
    [   18.174652] hub 1-1:1.0: USB hub found
    [   18.178421] hub 1-1:1.0: 4 ports detected
    [   18.187599] j721e-audio sound@0: ASoC: failed to init link CPB pcm3168a DAC: -517
    [   18.198456] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
    j7-evm login:
    root@j7-evm:/opt/vision_apps# source ./vision_apps_init.sh [  131.379777] Initializing XFRM netlink socket
    [  133.537702] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [  133.553111] Bridge firewalling registered
    root@j7-evm:/opt/vision_apps# [MCU2_0]      4.299794 s: CIO: Init ... Done !!!
    [MCU2_0]      4.299868 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz>
    [MCU2_0]      4.299911 s: APP: Init ... !!!
    [MCU2_0]      4.299934 s: SCICLIENT: Init ... !!!
    [MCU2_0]      4.301074 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla]
    [MCU2_0]      4.301121 s: SCICLIENT: DMSC FW revision 0x14
    [MCU2_0]      4.301150 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_0]      4.301178 s: SCICLIENT: Init ... Done !!!
    [MCU2_0]      4.301201 s: UDMA: Init ... !!!
    [MCU2_0]      4.310822 s: UDMA: Init ... Done !!!
    [MCU2_0]      4.310888 s: MEM: Init ... !!!
    [MCU2_0]      4.310929 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d2400000 of size 8388608 bytes !!!
    [MCU2_0]      4.310984 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 131072 bytes !!!
    [MCU2_0]      4.311031 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ ce000000 of size 65536 bytes !!!
    [MCU2_0]      4.311076 s: MEM: Init ... Done !!!
    [MCU2_0]      4.311096 s: IPC: Init ... !!!
    [MCU2_0]      4.311127 s: IPC: 6 CPUs participating in IPC !!!
    [MCU2_0]      4.311166 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_0]     20.254692 s: IPC: HLOS is ready !!!
    [MCU2_0]     20.265711 s: IPC: Init ... Done !!!
    [MCU2_0]     20.265774 s: APP: Syncing with 5 CPUs ... !!!
    [MCU2_0]     20.702006 s: APP: Syncing with 5 CPUs ... Done !!!
    [MCU2_0]     20.702059 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_0]     20.704059 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_0]     20.704128 s: ETHFW: Init ... !!!
    [MCU2_0]     20.739332 s: CPSW_9G Test on MAIN NAVSS
    [MCU2_0]     20.763522 s: ETHFW: Version   : 0.01.01
    [MCU2_0]     20.763596 s: ETHFW: Build Date: Feb  3, 2021
    [MCU2_0]     20.763634 s: ETHFW: Build Time: 20:05:36
    [MCU2_0]     20.763659 s: ETHFW: Commit SHA:
    [MCU2_0]     20.763681 s: ETHFW: Init ... DONE !!!
    [MCU2_0]     20.763707 s: ETHFW: Remove server Init ... !!!
    [MCU2_0]     20.764965 s: Remote demo device (core : mcu2_0) .....
    [MCU2_0]     20.765029 s: ETHFW: Remove server Init ... DONE !!!
    [MCU2_0]     20.792298 s: Host MAC address: 70:ff:76:1d:92:c2
    [MCU2_0]     20.821210 s: FVID2: Init ... !!!
    [MCU2_0]     20.821352 s: FVID2: Init ... Done !!!
    [MCU2_0]     20.821403 s: DSS: Init ... !!!
    [MCU2_0]     20.821437 s: DSS: Display type is eDP !!!
    [MCU2_0]     20.821462 s: DSS: SoC init ... !!!
    [MCU2_0]     20.821486 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2
    [MCU2_0]     20.823226 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     20.823261 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2
    [MCU2_0]     20.825226 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     20.825257 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2
    [MCU2_0]     20.826446 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     20.826477 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11
    [MCU2_0]     20.826902 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
    [MCU2_0]     20.826930 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18
    [MCU2_0]     20.827400 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
    [MCU2_0]     20.827430 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2
    [MCU2_0]     20.827834 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
    [MCU2_0]     20.827862 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000
    [MCU2_0]     20.848638 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
    [MCU2_0]     20.848685 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0
    [MCU2_0]     20.849747 s: SCICLIENT: Sciclient_pmModuleClkRequest success
    [MCU2_0]     20.849782 s: DSS: SoC init ... Done !!!
    [MCU2_0]     20.849806 s: DSS: Board init ... !!!
    [MCU2_0]     20.849827 s: DSS: Turning on DP_PWR pin for eDP adapters ... !!!
    [MCU2_0]     20.895219 s: DSS: Turning on DP_PWR pin for eDP adapters ... Done!!!
    [MCU2_0]     20.895290 s: DSS: Board init ... Done !!!
    [MCU2_0]     20.904532 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6
    [MCU2_0]     20.916572 s: DSS: Init ... Done !!!
    [MCU2_0]     20.916634 s: VHWA: VPAC Init ... !!!
    [MCU2_0]     20.916660 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2
    [MCU2_0]     20.917480 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     20.917522 s: VHWA: LDC Init ... !!!
    [MCU2_0]     20.931432 s: VHWA: LDC Init ... Done !!!
    [MCU2_0]     20.931488 s: VHWA: MSC Init ... !!!
    [MCU2_0]     20.972669 s: VHWA: MSC Init ... Done !!!
    [MCU2_0]     20.972731 s: VHWA: NF Init ... !!!
    [MCU2_0]     20.980280 s: VHWA: NF Init ... Done !!!
    [MCU2_0]     20.980332 s: VHWA: VISS Init ... !!!
    [MCU2_0]     21.009300 s: VHWA: VISS Init ... Done !!!
    [MCU2_0]     21.009356 s: VHWA: VPAC Init ... Done !!!
    [MCU2_0]     21.009397 s:  VX_ZONE_INIT:Enabled
    [MCU2_0]     21.009422 s:  VX_ZONE_ERROR:Enabled
    [MCU2_0]     21.009442 s:  VX_ZONE_WARNING:Enabled
    [MCU2_0]     21.010636 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target IPU1-0
    [MCU2_0]     21.010918 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_NF
    [MCU2_0]     21.011173 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_LDC1
    [MCU2_0]     21.011482 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_MSC1
    [MCU2_0]     21.011749 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_MSC2
    [MCU2_0]     21.012033 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_VISS1
    [MCU2_0]     21.012370 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE1
    [MCU2_0]     21.012677 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE2
    [MCU2_0]     21.012964 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DISPLAY1
    [MCU2_0]     21.013308 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DISPLAY2
    [MCU2_0]     21.013611 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CSITX
    [MCU2_0]     21.013918 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE3
    [MCU2_0]     21.014272 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE4
    [MCU2_0]     21.014571 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE5
    [MCU2_0]     21.014854 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE6
    [MCU2_0]     21.015140 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE7
    [MCU2_0]     21.015486 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE8
    [MCU2_0]     21.015542 s:  VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
    [MCU2_0]     21.015570 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_0]     21.028614 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_0]     21.028666 s: CSI2RX: Init ... !!!
    [MCU2_0]     21.028689 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
    [MCU2_0]     21.029260 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     21.029295 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2
    [MCU2_0]     21.030132 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     21.030158 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2
    [MCU2_0]     21.030931 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     21.030960 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2
    [MCU2_0]     21.031437 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     21.031464 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2
    [MCU2_0]     21.031924 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     21.035250 s: CSI2RX: Init ... Done !!!
    [MCU2_0]     21.035304 s: CSI2TX: Init ... !!!
    [MCU2_0]     21.035333 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
    [MCU2_0]     21.035769 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     21.035806 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2
    [MCU2_0]     21.036800 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     21.036835 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2
    [MCU2_0]     21.037640 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     21.040681 s: CSI2TX: Init ... Done !!!
    [MCU2_0]     21.040731 s: ISS: Init ... !!!
    [MCU2_0]     21.040799 s: Found sensor IMX390-UB953_D3 at location 0
    [MCU2_0]     21.040857 s: Found sensor AR0233-UB953_MARS at location 1
    [MCU2_0]     21.040905 s: Found sensor AR0820-UB953_LI at location 2
    [MCU2_0]     21.040954 s: Found sensor UB9xxx_RAW12_TESTPATTERN at location 3
    [MCU2_0]     21.041003 s: Found sensor UB96x_UYVY_TESTPATTERN at location 4
    [MCU2_0]     21.041050 s: Found sensor GW_AR0233_UYVY at location 5
    [MCU2_0]     21.041080 s: IssSensor_Init ... Done !!!
    [MCU2_0]     21.041149 s: vissRemoteServer_Init ... Done !!!
    [MCU2_0]     21.041234 s: IttRemoteServer_Init ... Done !!!
    [MCU2_0]     21.041268 s: UDMA Copy: Init ... !!!
    [MCU2_0]     21.048430 s: UDMA Copy: Init ... Done !!!
    [MCU2_0]     21.048501 s: APP: Init ... Done !!!
    [MCU2_0]     21.048533 s: APP: Run ... !!!
    [MCU2_0]     21.048554 s: IPC: Starting echo test ...
    [MCU2_0]     21.051328 s: APP: Run ... Done !!!
    [MCU2_0]     21.053013 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.]
    [MCU2_0]     21.053183 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[P] C7X_1[.]
    [MCU2_0]     21.053369 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.]
    [MCU2_0]     21.053494 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P]
    [MCU2_0]     23.579146 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a21d09fc,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:172, FlowIdxOffset:0
    [MCU2_0]     23.582209 s: Cpsw_ioctlInternal: CPSW: Registered MAC address.ALE entry:11, Policer Entry:0
    [MCU2_0]    188.868316 s: DHCP client timed out. Retrying.....
    [MCU2_1]      4.365116 s: CIO: Init ... Done !!!
    [MCU2_1]      4.365193 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz>
    [MCU2_1]      4.365240 s: APP: Init ... !!!
    [MCU2_1]      4.365260 s: SCICLIENT: Init ... !!!
    [MCU2_1]      4.366377 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla]
    [MCU2_1]      4.366424 s: SCICLIENT: DMSC FW revision 0x14
    [MCU2_1]      4.366452 s: SCICLIENT: DMSC FW ABI revision 3.1
    [MCU2_1]      4.366479 s: SCICLIENT: Init ... Done !!!
    [MCU2_1]      4.366502 s: UDMA: Init ... !!!
    [MCU2_1]      4.377792 s: UDMA: Init ... Done !!!
    [MCU2_1]      4.377845 s: MEM: Init ... !!!
    [MCU2_1]      4.377882 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d2c00000 of size 16777216 bytes !!!
    [MCU2_1]      4.377938 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3620000 of size 131072 bytes !!!
    [MCU2_1]      4.377990 s: MEM: Created heap (DDR_NON_CACHE_ME, id=5, flags=0x00000000) @ ce010000 of size 67043328 bytes !!!
    [MCU2_1]      4.378039 s: MEM: Init ... Done !!!
    [MCU2_1]      4.378059 s: IPC: Init ... !!!
    [MCU2_1]      4.378090 s: IPC: 6 CPUs participating in IPC !!!
    [MCU2_1]      4.378124 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_1]     20.690470 s: IPC: HLOS is ready !!!
    [MCU2_1]     20.701893 s: IPC: Init ... Done !!!
    [MCU2_1]     20.701960 s: APP: Syncing with 5 CPUs ... !!!
    [MCU2_1]     20.702003 s: APP: Syncing with 5 CPUs ... Done !!!
    [MCU2_1]     20.702034 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_1]     20.703909 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_1]     20.703977 s: FVID2: Init ... !!!
    [MCU2_1]     20.704060 s: FVID2: Init ... Done !!!
    [MCU2_1]     20.704093 s: VHWA: DMPAC: Init ... !!!
    [MCU2_1]     20.704119 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2
    [MCU2_1]     20.705359 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]     20.705396 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2
    [MCU2_1]     20.707891 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]     20.707927 s: VHWA: DOF Init ... !!!
    [MCU2_1]     20.763171 s: VHWA: DOF Init ... Done !!!
    [MCU2_1]     20.763255 s: VHWA: SDE Init ... !!!
    [MCU2_1]     20.779219 s: VHWA: SDE Init ... Done !!!
    [MCU2_1]     20.779278 s: VHWA: DMPAC: Init ... Done !!!
    [MCU2_1]     20.779309 s: VHWA: Codec: Init ... !!!
    [MCU2_1]     20.779333 s: VHWA: VDEC Init ... !!!
    [MCU2_1]     20.795072 s: VHWA: VDEC Init ... Done !!!
    [MCU2_1]     20.795126 s: VHWA: VENC Init ... !!!
    [MCU2_1]     20.795878 s: MM_ENC_Init: No OCM RAM pool available, fallback to DDR mode for above mp params
    [MCU2_1]     20.839773 s: VHWA: VENC Init ... Done !!!
    [MCU2_1]     20.839843 s: VHWA: Init ... Done !!!
    [MCU2_1]     20.839900 s:  VX_ZONE_INIT:Enabled
    [MCU2_1]     20.839929 s:  VX_ZONE_ERROR:Enabled
    [MCU2_1]     20.839953 s:  VX_ZONE_WARNING:Enabled
    [MCU2_1]     20.841040 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DMPAC_SDE
    [MCU2_1]     20.841344 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DMPAC_DOF
    [MCU2_1]     20.841603 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VDEC1
    [MCU2_1]     20.841868 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VDEC2
    [MCU2_1]     20.842112 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VENC1
    [MCU2_1]     20.842405 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VENC2
    [MCU2_1]     20.842461 s:  VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
    [MCU2_1]     20.842494 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_1]     20.842868 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_1]     20.842914 s: UDMA Copy: Init ... !!!
    [MCU2_1]     20.855862 s: UDMA Copy: Init ... Done !!!
    [MCU2_1]     20.855918 s: APP: Init ... Done !!!
    [MCU2_1]     20.855948 s: APP: Run ... !!!
    [MCU2_1]     20.855973 s: IPC: Starting echo test ...
    [MCU2_1]     20.858221 s: APP: Run ... Done !!!
    [MCU2_1]     20.859417 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.]
    [MCU2_1]     20.859519 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.]
    [MCU2_1]     20.859609 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
    [MCU2_1]     21.052822 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
    [C6x_1 ]      4.447469 s: CIO: Init ... Done !!!
    [C6x_1 ]      4.447504 s: ### CPU Frequency <ORG = 1350000000 Hz>, <NEW = 1350000000 Hz>
    [C6x_1 ]      4.447518 s: APP: Init ... !!!
    [C6x_1 ]      4.447525 s: SCICLIENT: Init ... !!!
    [C6x_1 ]      4.448644 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla]
    [C6x_1 ]      4.448657 s: SCICLIENT: DMSC FW revision 0x14
    [C6x_1 ]      4.448666 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C6x_1 ]      4.448676 s: SCICLIENT: Init ... Done !!!
    [C6x_1 ]      4.448686 s: UDMA: Init ... !!!
    [C6x_1 ]      4.462581 s: UDMA: Init ... Done !!!
    [C6x_1 ]      4.462604 s: MEM: Init ... !!!
    [C6x_1 ]      4.462616 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d4000000 of size 16777216 bytes !!!
    [C6x_1 ]      4.462634 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
    [C6x_1 ]      4.462650 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ d5000000 of size 50331648 bytes !!!
    [C6x_1 ]      4.462667 s: MEM: Init ... Done !!!
    [C6x_1 ]      4.462675 s: IPC: Init ... !!!
    [C6x_1 ]      4.462689 s: IPC: 6 CPUs participating in IPC !!!
    [C6x_1 ]      4.462704 s: IPC: Waiting for HLOS to be ready ... !!!
    [C6x_1 ]     18.218806 s: IPC: HLOS is ready !!!
    [C6x_1 ]     18.242765 s: IPC: Init ... Done !!!
    [C6x_1 ]     18.242803 s: APP: Syncing with 5 CPUs ... !!!
    [C6x_1 ]     20.702003 s: APP: Syncing with 5 CPUs ... Done !!!
    [C6x_1 ]     20.702020 s: REMOTE_SERVICE: Init ... !!!
    [C6x_1 ]     20.702857 s: REMOTE_SERVICE: Init ... Done !!!
    [C6x_1 ]     20.702934 s:  VX_ZONE_INIT:Enabled
    [C6x_1 ]     20.702950 s:  VX_ZONE_ERROR:Enabled
    [C6x_1 ]     20.702961 s:  VX_ZONE_WARNING:Enabled
    [C6x_1 ]     20.704008 s:  VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
    [C6x_1 ]     20.704024 s: APP: OpenVX Target kernel init ... !!!
    [C6x_1 ]     20.704321 s: APP: OpenVX Target kernel init ... Done !!!
    [C6x_1 ]     20.704342 s: UDMA Copy: Init ... !!!
    [C6x_1 ]     20.726507 s: UDMA Copy: Init ... Done !!!
    [C6x_1 ]     20.726532 s: APP: Init ... Done !!!
    [C6x_1 ]     20.735255 s: APP: Run ... !!!
    [C6x_1 ]     20.735269 s: IPC: Starting echo test ...
    [C6x_1 ]     20.736448 s: APP: Run ... Done !!!
    [C6x_1 ]     20.736806 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P]
    [C6x_1 ]     20.737858 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P]
    [C6x_1 ]     20.859181 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
    [C6x_1 ]     21.052670 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
    [C6x_2 ]      4.503530 s: CIO: Init ... Done !!!
    [C6x_2 ]      4.503566 s: ### CPU Frequency <ORG = 1350000000 Hz>, <NEW = 1350000000 Hz>
    [C6x_2 ]      4.503580 s: APP: Init ... !!!
    [C6x_2 ]      4.503589 s: SCICLIENT: Init ... !!!
    [C6x_2 ]      4.504724 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla]
    [C6x_2 ]      4.504737 s: SCICLIENT: DMSC FW revision 0x14
    [C6x_2 ]      4.504747 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C6x_2 ]      4.504758 s: SCICLIENT: Init ... Done !!!
    [C6x_2 ]      4.504767 s: UDMA: Init ... !!!
    [C6x_2 ]      4.519263 s: UDMA: Init ... Done !!!
    [C6x_2 ]      4.519286 s: MEM: Init ... !!!
    [C6x_2 ]      4.519299 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ d8000000 of size 16777216 bytes !!!
    [C6x_2 ]      4.519318 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
    [C6x_2 ]      4.519334 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ d9000000 of size 50331648 bytes !!!
    [C6x_2 ]      4.519351 s: MEM: Init ... Done !!!
    [C6x_2 ]      4.519360 s: IPC: Init ... !!!
    [C6x_2 ]      4.519374 s: IPC: 6 CPUs participating in IPC !!!
    [C6x_2 ]      4.519389 s: IPC: Waiting for HLOS to be ready ... !!!
    [C6x_2 ]     18.994996 s: IPC: HLOS is ready !!!
    [C6x_2 ]     19.017976 s: IPC: Init ... Done !!!
    [C6x_2 ]     19.018018 s: APP: Syncing with 5 CPUs ... !!!
    [C6x_2 ]     20.702004 s: APP: Syncing with 5 CPUs ... Done !!!
    [C6x_2 ]     20.702020 s: REMOTE_SERVICE: Init ... !!!
    [C6x_2 ]     20.702869 s: REMOTE_SERVICE: Init ... Done !!!
    [C6x_2 ]     20.702947 s:  VX_ZONE_INIT:Enabled
    [C6x_2 ]     20.702961 s:  VX_ZONE_ERROR:Enabled
    [C6x_2 ]     20.702971 s:  VX_ZONE_WARNING:Enabled
    [C6x_2 ]     20.704009 s:  VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
    [C6x_2 ]     20.704029 s: APP: OpenVX Target kernel init ... !!!
    [C6x_2 ]     20.704336 s: APP: OpenVX Target kernel init ... Done !!!
    [C6x_2 ]     20.704359 s: UDMA Copy: Init ... !!!
    [C6x_2 ]     20.727534 s: UDMA Copy: Init ... Done !!!
    [C6x_2 ]     20.727553 s: APP: Init ... Done !!!
    [C6x_2 ]     20.736105 s: APP: Run ... !!!
    [C6x_2 ]     20.736114 s: IPC: Starting echo test ...
    [C6x_2 ]     20.737467 s: APP: Run ... Done !!!
    [C6x_2 ]     20.737867 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.]
    [C6x_2 ]     20.737903 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P]
    [C6x_2 ]     20.859203 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
    [C6x_2 ]     21.052727 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
    [C7x_1 ]      4.616021 s: CIO: Init ... Done !!!
    [C7x_1 ]      4.616044 s: ### CPU Frequency <ORG = 1000000000 Hz>, <NEW = 1000000000 Hz>
    [C7x_1 ]      4.616060 s: APP: Init ... !!!
    [C7x_1 ]      4.616067 s: SCICLIENT: Init ... !!!
    [C7x_1 ]      4.617225 s: SCICLIENT: DMSC FW version [20.8.5--v2020.08b (Terrific Lla]
    [C7x_1 ]      4.617240 s: SCICLIENT: DMSC FW revision 0x14
    [C7x_1 ]      4.617249 s: SCICLIENT: DMSC FW ABI revision 3.1
    [C7x_1 ]      4.617260 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]      4.617268 s: UDMA: Init ... !!!
    [C7x_1 ]      4.626491 s: UDMA: Init ... Done !!!
    [C7x_1 ]      4.626503 s: MEM: Init ... !!!
    [C7x_1 ]      4.626514 s: MEM: Created heap (DDR_SHARED_MEM, id=0, flags=0x00000004) @ dc000000 of size 268435456 bytes !!!
    [C7x_1 ]      4.626535 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!!
    [C7x_1 ]      4.626553 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 491520 bytes !!!
    [C7x_1 ]      4.626570 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
    [C7x_1 ]      4.626587 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ ec000000 of size 234881024 bytes !!!
    [C7x_1 ]      4.626605 s: MEM: Init ... Done !!!
    [C7x_1 ]      4.626613 s: IPC: Init ... !!!
    [C7x_1 ]      4.626623 s: IPC: 6 CPUs participating in IPC !!!
    [C7x_1 ]      4.626635 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]     19.570603 s: IPC: HLOS is ready !!!
    [C7x_1 ]     19.580768 s: IPC: Init ... Done !!!
    [C7x_1 ]     19.580782 s: APP: Syncing with 5 CPUs ... !!!
    [C7x_1 ]     20.702004 s: APP: Syncing with 5 CPUs ... Done !!!
    [C7x_1 ]     20.702021 s: REMOTE_SERVICE: Init ... !!!
    [C7x_1 ]     20.702294 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_1 ]     20.702317 s:  VX_ZONE_INIT:Enabled
    [C7x_1 ]     20.702327 s:  VX_ZONE_ERROR:Enabled
    [C7x_1 ]     20.702337 s:  VX_ZONE_WARNING:Enabled
    [C7x_1 ]     20.702656 s:  VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
    [C7x_1 ]     20.702670 s: APP: OpenVX Target kernel init ... !!!
    [C7x_1 ]     20.702750 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_1 ]     20.702764 s: APP: Init ... Done !!!
    [C7x_1 ]     20.702773 s: APP: Run ... !!!
    [C7x_1 ]     20.702781 s: IPC: Starting echo test ...
    [C7x_1 ]     20.703302 s: APP: Run ... Done !!!
    [C7x_1 ]     20.736816 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s]
    [C7x_1 ]     20.737858 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s]
    [C7x_1 ]     20.859244 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
    [C7x_1 ]     21.052753 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
    root@j7-evm:/opt/vision_apps# ./run_app_single_cam.sh
    APP: Init ... !!!
    MEM: Init ... !!!
    MEM: Initialized DMA HEAP (fd=4) !!!
    IPC: Init ... !!!
       286.799410 s:  VX_ZONE_INIT:Enabled
       286.799435 s:  VX_ZONE_ERROR:Enabled
       286.799439 s:  VX_ZONE_WARNING:Enabled
       286.800031 s:  VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
       286.800226 s:  VX_ZONE_INIT:[tivxHostInit:48] Initialization Done for HOST !!!
    sensor_selection = [0]
    ldc_enable = [0]
    num_frames_to_run = [1000000000]
    is_interactive = [1]
    IttCtrl_registerHandler: command echo registered at location 0
    IttCtrl_registerHandler: command iss_read_2a_params registered at location 1
    IttCtrl_registerHandler: command iss_write_2a_params registered at location 2
    IttCtrl_registerHandler: command iss_raw_save registered at location 3
    IttCtrl_registerHandler: command iss_yuv_save registered at location 4
    IttCtrl_registerHandler: command iss_read_sensor_reg registered at location 5
    IttCtrl_registerHandler: command iss_write_sensor_reg registered at location 6
    IttCtrl_registerHandler: command dev_ctrl registered at location 7
    IttCtrl_registerHandler: command iss_send_dcc_file registered at location 8
     NETWORK: Opened at IP Addr = 0.0.0.0, socket port=5000!!!
       286.802572 s: ISS: Enumerating sensors ... !!!
       286.803047 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
       286.803062 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
       286.803067 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
       286.803072 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
       286.803077 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
       286.803081 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
    6 sensor(s) found
    Supported sensor list:
    a : IMX390-UB953_D3
    b : AR0233-UB953_MARS
    c : AR0820-UB953_LI
    d : UB9xxx_RAW12_TESTPATTERN
    e : UB96x_UYVY_TESTPATTERN
    f : GW_AR0233_UYVY
    Select a sensor
    [MCU2_0]    286.802698 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_CREATE
    [MCU2_0]    286.802787 s: Sensor at index 0 = IMX390-UB953_D3
    [MCU2_0]    286.802822 s: Sensor at index 1 = AR0233-UB953_MARS
    [MCU2_0]    286.802849 s: Sensor at index 2 = AR0820-UB953_LI
    [MCU2_0]    286.802876 s: Sensor at index 3 = UB9xxx_RAW12_TESTPATTERN
    [MCU2_0]    286.802903 s: Sensor at index 4 = UB96x_UYVY_TESTPATTERN
    [MCU2_0]    286.802929 s: Sensor at index 5 = GW_AR0233_UYVY
    a
    LDC Selection Yes(1)/No(0)
    0
    Sensor selected : IMX390-UB953_D3
    Querying IMX390-UB953_D3
       289.658710 s: ISS: Querying sensor [IMX390-UB953_D3] ... !!!
       289.658980 s: ISS: Querying sensor [IMX390-UB953_D3] ... Done !!!
       289.658988 s: ISS: Initializing sensor [IMX390-UB953_D3], doing IM_SENSOR_CMD_PWRON ... !!!
    [MCU2_0]    289.658818 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_QUERY
    [MCU2_0]    289.658888 s: Received Query for IMX390-UB953_D3
    [MCU2_0]    289.659062 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_PWRON
    [MCU2_0]    289.659144 s: IM_SENSOR_CMD_PWRON : channel_mask = 0x1
    [MCU2_0]    289.659305 s: IMX390_PowerOn : chMask = 0x1
    [MCU2_0]    289.659358 s: ub960_cfgScript : ub960I2cAddr = 0x3d
    [MCU2_0]    289.659388 s: UB960 config start
       289.859587 s: ISS: Initializing sensor [IMX390-UB953_D3], doing IM_SENSOR_CMD_CONFIG ... !!!
    [MCU2_0]    289.859472 s:  End of UB960 config
    [MCU2_0]    289.859666 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_CONFIG
    [MCU2_0]    289.859717 s: Application requested features = 0x358
    [MCU2_0]
    [MCU2_0]    289.859787 s: ub960_cfgScript : ub960I2cAddr = 0x3d
    [MCU2_0]    289.859822 s: UB960 config start
    [MCU2_0]    290.115298 s:  End of UB960 config
    [MCU2_0]    290.115398 s: ub960_cfgScript : ub960I2cAddr = 0x36
    [MCU2_0]    290.115435 s: UB960 config start
    [MCU2_0]    290.371298 s:  End of UB960 config
    [MCU2_0]    290.371358 s: Configuring camera # 0
    [MCU2_0]    290.371391 s: ub953 config start : slaveAddr = 0x74
    [MCU2_0]    290.561300 s:  End of UB953 config
    [MCU2_0]    290.561394 s:  Configuring IMX390 imager 0x40.. Please wait till it finishes
       292.696430 s: ISS: Initializing sensor [IMX390-UB953_D3] ... Done !!!
    reading test RAW image /opt/vision_apps/test_data/img_test.raw
    read_test_image_raw : Unable to open file /opt/vision_apps/test_data/img_test.raw
    [MCU2_0]    292.696232 s:  IMX390 config done
    [MCU2_0]    292.696295 s: IM_SENSOR_CMD_CONFIG returning status = 0
    Separate related question. When does ./vision_apps_init.sh need to be used? On my working alpha board it doesn't matter if I run it or not the cameras come up fine. I had never sourced it either, just ran it, based on some instructions I got from a vendor.
    Thanks for the help
  • Hi Andrew,
    The vision_apps_init script enables logging from the remote cores as well as setting some environment variables when you source the file.  I wanted to see if any of the remote cores are throwing any errors to indicate the issue, but it does not look like it.
    Could you also send me the output when pressing "p" on the console?  Could you also provide your Linux and RTOS SDK versions?
    Also, I have contacted our imaging expert to see if he is aware of what may be the issue.
    Lucas
  • The app doesn't make it far enough to process keyboard input so pressing "p" does nothing.
    I am building this on Ubuntu 18.04.5 LTS. I downloaded ti-processor-sdk-rtos-j721e-evm-07_02_00_06.
    I can build and run fine on the alpha board I have with this Ubuntu and SDK setup. I have multiple SD cards I set up and run ok on the alpha system with IMX390 cameras.
  • Hello Andrew,
    Can you please confirm the revision number of your Fusion board (on the non working setup)?
    Can you please also try app_multi_cam? Please select number of cameras = 1 when prompted.
    Mayank
  • Have tried both single and multi, neither work. Both work fine on the alpha board. The fusion board seems to be the same on both the working and non-working system.
     Fusion board PWB 518521 Rev C, LOGIC 518522 Rev C. Other boards say PCB# PROC079E3D OPN#J721EXSOMG01EVM.
  • OK. Let's first check if your Fusion board is functional. Can you please try the test patterns?
  • So I ran these on both single and multi cam apps and it ends with
    IM_SENSOR_COMMAND CFG returning status = 0
    Then just hangs there. No output on DP.
    The board boots and i get the TI splash screen if i use the included SD card so i know the DP port, cable and monitor work ok.
  • Do you reach the runtime menu where you can press 'p' can get profile stats?
  • No it just hangs after the config status returns as 0. The console spits out ethernet messages occasionally but nothing else from the camera app. No menu, no image.
  • Does anybody know what the config SW switches should be set to for the Fusion board? My working alpha unit had them set differently than the default setting on the beta board. A couple of the switches seem to belong to the expansion card but they say refer to the expansion card manual which doesn't specify anything. SW3.7-8 in particular.
  • Default switch settings should work fine. There are instructions in the box Fusion board comes in. Please follow them and make sure that it is securely mounted to the EVM using the provided standoffs.
  • The instructions only cover mechanical mounting and power cable polarity, nothing else. 3.7 sets a voltage for CSI2 expansion interface, i assume that is what the Fusion board is plugged into? I don't know what voltage levels are used on the Fusion board, it is not documented. The default on the beta board was 3.3V and my working alpha board is set at 1.8V? Maybe it doesn't matter, the only real physical difference i could find between the systems.
    SW3.7 ON CSI_VIO_SEL Sets I/O voltage for CSI2 Expansion Interface (LVCMOS signals) ‘0’ (OFF) = 1.8V I/O Voltage ‘1’ (ON) = 3.3V I/O Voltage
    SW3.8 ON INFO_CAM_VIO_SEL Switch is to be used on Expansion board. See specific expansion board User’s Guide for definition.
  • The default settings for the Fusion board are listed in the schematic.  I've provided below.
  • S3 on the EVM not the Fusion board.
    This page shows some SW3 settings on the EVM (at least the first switch) for different boot modes but nothing else https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/07_02_00_06/exports/docs/psdk_rtos/docs/user_guide/evm_setup_j721e.html#fusion-daughter-card
    I was looking at S4 and S5 on the schematic and It calls for ON,OFF,OFF,ON for CSI-COAX yet my working board , default setting, design guide and images online show those set to OFF,ON,OFF,ON for CSI Coax?
    Taken from TIDUDJ8A–April 2018–Revised May 2019.
    Set the Mode setting for the DS90UB960 devices 1. Set switch S4 and S5 to 1-OFF, 2-ON, 3-OFF, and 4-ON (Sets up both devices in CSI-2 and Coax Mode for compatibility to the DS90UB953.)
  • So I may know the issue, not sure how to solve it. I have a SR2.0 J721E SoM. My old one is SR1.0 and there is a patch available for SR1.1 but nothing for SR2.0. The SR1.1 patch doesnt work on either 7.1 or 7.2. I find no mention of SR2.0 anywhere.
  • Can you clarify what J721E SOM you have?  There should be a PROC078Ex part label on the board.  This will help identify which silicon revision you have.
  • I got this sorted. It is a SR1.1. The patch had an extra directory level in it so it didn't work correctly when you put in the root of the rtos directory it didn't overwrite the files it needed to. After i figured that out i manually moved the files down a level and rebuilt then it worked.
  • Thanks for the confirmation Andrew. Closing this thread.
    If you have a related topic, continue posting here on this thread.
    If you have a different question, please create a new thread.
