hi,
I wanna know if I install ccsv5 before QT 4.7, ccs could import QT projects or not ? if not, how I could do to import QT projects after I install QT, reinstall CCSV5?
pan
Power,
Are you working with one our the Sitara SDKs for an AMx device? If so, we use Qt 4.6.2. We have not yet moved to Qt 4.7 but plan to. If using an SDK then the CCSv5 User's Guide has a section that describes how import Qt projects. They are different than standard C projects and you will need CCSv5 version provided with the SDK that contains the Qt Integration plugin.
http://processors.wiki.ti.com/index.php/How_to_Import_Matrix_GUI_into_CCSv5
If you want to use Qt 4.7 then once you install it you will need to point the Qt Preferences within CCSv5 (with the Qt inegration plugin) to the proper Bin Path and Include Path so that CCSv5 can build 4.7. Again details in the article above.
Kevin,
thanks for replying, I read the documents already, but my ccsv5 does not have the QT import selection, don't know why, so I come up with this topic.
the software start guide does not tell me how to install QT, nor telling which one should be installed first, QT or CCSV5, so if you have, please let me know, thanks a lot.
regards,
Pan
