TDA4VM: TDA4VM
Part Number: TDA4VM
Other Parts Discussed in Thread: DS90UB960-Q1
Hello ,
I may have a big problem and need your helps ,very thanks
I am ready to use hyperlynx 2.4 version to do a MIPI simulation about DS90UB960-Q1 with SOC TDA4,I get the IBIS module from CDDS (https://cdds.ext.ti.com/ematrix/common/TIemxNavigator.jsp?objectId=28670.42872.31126.27228&ticket=ST-44520-tfMNfzgcw5XklELNkgVU-cas)
J721E SerDes IBIS-AMI Models
but when I do the simulation ,always show following information:
E: AMI initialization failed:
C:\Users\huangs15\Desktop\High SDE Work\TDA4 part\TDA4\layout\MIPI simulation\SERDES Module\DPHY_RX\dphy_tx_rx_t16ffc\Ref\D\AMI\t16ffc_ami\dphy\IBIS\dphy_rx_rev1_win64.dll
Failure reported by 'AMI_Init' routine
in Tx [ IC42600.24 (at pin)/IC42600.25 (at pin) ] IBIS-AMI model:
I want to know that is this AMI  correct ? and if this AMI just can use by cadence . If you can tell me how to do it right, it's good .thanks
