TDA4VM: RTOS SDK migration for customized board (Version: 07.02.00.06)
Part Number: TDA4VM
Hello all,
We are doing SDK (Version: 07.02.00.06) migration for TDA4-Customized board. We have memory issues as per the log.
Can you please support in finding the root cause of this issue ?
7_2_csi_error.txt
Thanks & regards,
Gokul
  • Thanks Gokul,
    Can you please provide a description of the H/W setup under test.  What sensor, what serializer / deserializer are under test for the failure.
    In regards to the customized S/W it would be helpful to know the scope of the changes that were done.  Was the porting effort fairly clean, or were issues encountered, if so any areas that were problematic, that may be related to the error being seen.
    Are you able to provide the "successful" boot/test log from the working setup in the Process SDK Linux 7.0 setup, that have the similar code changes.
    Kip
  • Hello Kip,
    After updating bootloader specific changes to latest SDK, We don't have memory issues.
    Thanks & regards,
    Gokul
