TDA4VM: ifconfig can't done and get assert from slog2info
Part Number: TDA4VM
The following cmd which I used to set the ip , then I can find assert  below .
/media/ubuntu/9337fff7-8d53-4ef8-b28d-b4c26c6ca1a8/src/baidu/acu/sixi_sdk/ti/ti-processor-sdk-rtos-j721e-evm-07_02_00_06/psdkqa/../ethfw/ethremotecfg/client/src/cpsw_proxy.c: msg->res.retVal == ENET_SOK : failed !!!
cmd "tisci-mgr tiipc-mgr tiudma-mgr" was called.
could you give me a hand about it?
cmd:
J7EVM@QNX:/# history
1       ls
2       slogger2
3       ls /var/log/slogger2/
4       io-pkt-v6-hc -d cpsw9g verbose=0xff
5       ls /var/log/slogger2/
6       slog2info /var/log/io_pkt_v6_hc.102416
7       slog2info /var/log/iopkt.102416
8       if_up -p an0
9       slog2info /var/log/slogger2/io_pkt_v6_hc.102416
10      slog2info /var/log/slogger2/iopkt.102416
11      ifconfig an0 192.168.2.66
12      ps
13      ll
14      slog2info /var/log/slogger2/iopkt.102416
15      slog2info /var/log/slogger2/tiudma_mgr.28685
J7EVM@QNX:/#
log:
[2021-04-02 17:27:34]  U-Boot SPL 2020.01 (Feb 08 2021 - 05:33:50 -0500)
[2021-04-02 17:27:34]  SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla')
[2021-04-02 17:27:34]  Reading on-board EEPROM at 0x50 failed -19
[2021-04-02 17:27:34]  AVS init failed: -19
[2021-04-02 17:27:34]  Trying to boot from MMC2
[2021-04-02 17:27:34]  Loading Environment from MMC... *** Warning - No MMC card found, using default environment
[2021-04-02 17:27:34]  Starting ATF on ARM64 core...
[2021-04-02 17:27:34]  NOTICE:  BL31: v2.3():07.01.00.006-dirty
[2021-04-02 17:27:34]  NOTICE:  BL31: Built : 03:49:38, Jan 25 2021
[2021-04-02 17:27:35]  U-Boot SPL 2020.01 (Feb 08 2021 - 05:33:31 -0500)
[2021-04-02 17:27:35]  SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla')
[2021-04-02 17:27:35]  Reading on-board EEPROM at 0x50 failed -19
[2021-04-02 17:27:35]  Trying to boot from MMC2
[2021-04-02 17:27:35]  U-Boot 2020.01 (Feb 08 2021 - 05:33:31 -0500)
[2021-04-02 17:27:35]  SoC:   J721E SR1.0
[2021-04-02 17:27:35]  Model: Texas Instruments K3 J721E SoC
[2021-04-02 17:27:35]  Board: J721EX-PM1-SOM rev E2
[2021-04-02 17:27:35]  DRAM:  4 GiB
[2021-04-02 17:27:35]  Flash: 0 Bytes
[2021-04-02 17:27:35]  MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
[2021-04-02 17:27:35]  Loading Environment from MMC... MMC: block number 0x3500 exceeds max(0x2000)
[2021-04-02 17:27:35]  MMC: block number 0x3600 exceeds max(0x2000)
[2021-04-02 17:27:35]  *** Error - No Valid Environment Area found
[2021-04-02 17:27:35]  *** Warning - bad env area, using default environment
[2021-04-02 17:27:35]  In:    serial@2800000
[2021-04-02 17:27:35]  Out:   serial@2800000
[2021-04-02 17:27:35]  Err:   serial@2800000
[2021-04-02 17:27:35]  Reading on-board EEPROM at 0x50 failed 1
[2021-04-02 17:27:35]  Net:   Could not get PHY for ethernet@46000000: addr 3
[2021-04-02 17:27:35]  phy_connect() failed
[2021-04-02 17:27:35]  No ethernet found.
[2021-04-02 17:27:35]  Hit any key to stop autoboot:  2  1  0
[2021-04-02 17:27:37]  switch to partitions #0, OK
[2021-04-02 17:27:37]  mmc1 is current device
[2021-04-02 17:27:37]  SD/MMC found on device 1
[2021-04-02 17:27:38]  602 bytes read in 3 ms (195.3 KiB/s)
[2021-04-02 17:27:38]  Loaded env from uEnv.txt
[2021-04-02 17:27:38]  Importing environment from mmc1 ...
[2021-04-02 17:27:38]  Running uenvcmd ...
[2021-04-02 17:27:38]  21958740 bytes read in 1801 ms (11.6 MiB/s)
[2021-04-02 17:27:39]  Load Remote Processor 2 with data@addr=0x82000000 21958740 bytes: Success!
[2021-04-02 17:27:39]  13189628 bytes read in 1102 ms (11.4 MiB/s)
[2021-04-02 17:27:40]  Load Remote Processor 3 with data@addr=0x82000000 13189628 bytes: Success!
[2021-04-02 17:27:41]  5361744 bytes read in 452 ms (11.3 MiB/s)
[2021-04-02 17:27:41]  Load Remote Processor 4 with data@addr=0x82000000 5361744 bytes: Success!
[2021-04-02 17:27:41]  Load Remote Processor 5 with data@addr=0x82000000 5361744 bytes: Success!
[2021-04-02 17:27:41]  11537520 bytes read in 960 ms (11.5 MiB/s)
[2021-04-02 17:27:42]  Load Remote Processor 6 with data@addr=0x82000000 11537520 bytes: Success!
[2021-04-02 17:27:42]  11537568 bytes read in 960 ms (11.5 MiB/s)
[2021-04-02 17:27:43]  Load Remote Processor 7 with data@addr=0x82000000 11537568 bytes: Success!
[2021-04-02 17:27:43]  17570992 bytes read in 957 ms (17.5 MiB/s)
[2021-04-02 17:27:44]  Load Remote Processor 8 with data@addr=0x82000000 17570992 bytes: Success!
[2021-04-02 17:27:44]  8175976 bytes read in 683 ms (11.4 MiB/s)
[2021-04-02 17:27:45]  ## Starting application at 0x80080000 ...
[2021-04-02 17:27:45]  MMU: 16-bit ASID 44-bit PA TCR_EL1=b5183519
[2021-04-02 17:27:45]  cpu0: MPIDR=80000000
[2021-04-02 17:27:45]  cpu0: MIDR=411fd080 Cortex-A72 r1p0
[2021-04-02 17:27:45]  cpu0: CWG=4 ERG=4 Dminline=4 Iminline=4 PIPT
[2021-04-02 17:27:45]  cpu0: CLIDR=a200023 LoUU=1 LoC=2 LoUIS=1
[2021-04-02 17:27:45]  cpu0: L1 Icache 48K linesz=64 set/way=256/3
[2021-04-02 17:27:45]  cpu0: L1 Dcache 32K linesz=64 set/way=256/2
[2021-04-02 17:27:45]  cpu0: L2 Unified 1024K linesz=64 set/way=1024/16
[2021-04-02 17:27:45]  Display set to R5
[2021-04-02 17:27:45]  Loading IFS...decompressing...done
[2021-04-02 17:27:45]  cpu1: MPIDR=80000001
[2021-04-02 17:27:45]  cpu1: MIDR=411fd080 Cortex-A72 r1p0
[2021-04-02 17:27:45]  cpu1: CWG=4 ERG=4 Dminline=4 Iminline=4 PIPT
[2021-04-02 17:27:45]  cpu1: CLIDR=a200023 LoUU=1 LoC=2 LoUIS=1
[2021-04-02 17:27:45]  cpu1: L1 Icache 48K linesz=64 set/way=256/3
[2021-04-02 17:27:45]  cpu1: L1 Dcache 32K linesz=64 set/way=256/2
[2021-04-02 17:27:45]  cpu1: L2 Unified 1024K linesz=64 set/way=1024/16
[2021-04-02 17:27:45]  System page at phys:0000000080011000 user:ffffff8040254000 kern:ffffff8040251000
[2021-04-02 17:27:45]  Starting next program at vffffff8060086e10
[2021-04-02 17:27:45]  All ClockCycles offsets within tolerance
[2021-04-02 17:27:45]  Welcome to QNX Neutrino 7.1.0 on the TI J721E EVM Board!!
[2021-04-02 17:27:45]  Starting random service ...
[2021-04-02 17:27:45]  start serial driver
[2021-04-02 17:27:45]  Starting MMC/SD memory card driver... eMMC
[2021-04-02 17:27:45]  Starting MMC/SD memory card driver... SD
[2021-04-02 17:27:45]  Setting environment variables...
[2021-04-02 17:27:45]  done..
[2021-04-02 17:27:45]  Looking for user script to run: /ti_fs/scripts/user.sh
[2021-04-02 17:27:45]  Path=0 - am65x
[2021-04-02 17:27:45]   target=0 lun=0     Direct-Access(0) - SDMMC: MMC32G Rev: 5.0
[2021-04-02 17:27:46]  Running user script...
[2021-04-02 17:27:46]  user.sh called...
[2021-04-02 17:27:46]  Setting additional environment variables...
[2021-04-02 17:27:46]  Starting tisci-mgr..
[2021-04-02 17:27:46]  Starting shmemallocator..
[2021-04-02 17:27:46]  Starting tiipc-mgr..
[2021-04-02 17:27:46]  Mailbox_plugInterrupt: interrupt Number 489, arg 0xE6B11EA0
[2021-04-02 17:27:46]  Mailbox_plugInterrupt: interrupt Number 490, arg 0xE6B12040
[2021-04-02 17:27:46]  Mailbox_plugInterrupt: interrupt Number 491, arg 0xE6B121E0
[2021-04-02 17:27:46]  Mailbox_plugInterrupt: interrupt Number 492, arg 0xE6B12380
[2021-04-02 17:27:46]  Mailbox_plugInterrupt: interrupt Number 493, arg 0xE6B12520
[2021-04-02 17:27:46]  Starting TI IPC Resmgr
[2021-04-02 17:27:46]  Starting tiudma-mgr..
[2021-04-02 17:27:46]  Start screen..
[2021-04-02 17:27:46]  libkhronos: dlopen() err Library cannot be found, path: '/ti_fs/usr/lib/graphics/jacinto7/libWFDdummy.so'
[2021-04-02 17:27:46]  libkhronos: dlopen() err Library cannot be found, path: 'libWFDdummy.so'
[2021-04-02 17:27:46]  libkhronos: Ensure directory containing graphics libraries is appended to LD_LIBRARY_PATH envar.
[2021-04-02 17:27:46]  screen started with dss_on_r5 configuration..
[2021-04-02 17:27:46]  done...
[2021-04-02 17:27:46]  J7EVM@QNX:/#
[2021-04-02 17:28:08]  J7EVM@QNX:/#
[2021-04-02 17:28:08]  J7EVM@QNX:/# ls
[2021-04-02 17:28:09]  bin      etc      sbin     tmp      var
[2021-04-02 17:28:09]  dev      proc     ti_fs    usr
[2021-04-02 17:28:09]  J7EVM@QNX:/# cd t    c sl
[2021-04-02 17:28:16]  slay       sleep      slog2info  slogger2
J7EVM@QNX:/# sl
J7EVM@QNX:/# sl og
[2021-04-02 17:28:17]  slog2info  slogger2
J7EVM@QNX:/# slog g     slogger2
[2021-04-02 17:28:19]  slogger2 appears to have been restarted, performing cleanup...
[2021-04-02 17:28:19]  J7EVM@QNX:/#
[2021-04-02 17:28:20]  J7EVM@QNX:/#
[2021-04-02 17:28:20]  J7EVM@QNX:/# ls /va   /var/
[2021-04-02 17:28:22]  lock/  log/   run/
J7EVM@QNX:/# ls /var/ sl  lo
[2021-04-02 17:28:25]  lock/  log/
J7EVM@QNX:/# ls /var/lo
J7EVM@QNX:/# ls /var/lo / g/         /var/log/slogger2/
[2021-04-02 17:28:27]  console.73743
[2021-04-02 17:28:27]  J7EVM@QNX:/#
J7EVM@QNX:/# ls /var/log/slogger2/
J7EVM@QNX:/# slogger2
J7EVM@QNX:/# ls          mv  info    io-pkt-v6-hc -d cpsw9g verbose=0xff
[2021-04-02 17:28:46]  J7EVM@QNX:/#
J7EVM@QNX:/# io-pkt-v6-hc -d cpsw9g verbose=0xff
[2021-04-02 17:28:49]  console.73743             iopkt.102416
[2021-04-02 17:28:49]  io_pkt_v6_hc.102416
[2021-04-02 17:28:49]  J7EVM@QNX:/# sl
[2021-04-02 17:28:53]  slay       sleep      slog2info  slogger2
J7EVM@QNX:/# sl g og2     slog2info /med   tm   /tmp/     /tmp/slogger2/             var    /var/
[2021-04-02 17:29:03]  lock/  log/   run/
J7EVM@QNX:/# slog2info /var/ log        /var/log//          /var/log//slogger2/
[2021-04-02 17:29:04]  console.73743             io_pkt_v6_hc.102416       iopkt.102416
J7EVM@QNX:/# slog2info /var/log//slogger2/           io_pkt_v6_hc.102416
[2021-04-02 17:29:10]  Jan 01 00:01:00.866                   iopkt.102416          main_buffer*     0  tcpip starting
[2021-04-02 17:29:10]  Jan 01 00:01:00.867                   iopkt.102416          main_buffer      0  smmu support is disabled
[2021-04-02 17:29:10]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0  initializing IPsec...
[2021-04-02 17:29:10]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0   done
[2021-04-02 17:29:10]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0  IPsec: Initialized Security Association Processing.
[2021-04-02 17:29:10]  Jan 01 00:01:00.950                   iopkt.102416          main_buffer      0  devnp-cpsw9g.so verbose=0xff
[2021-04-02 17:29:10]  Jan 01 00:01:00.950                   iopkt.102416          main_buffer      0  an0
[2021-04-02 17:29:10]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog*     0  cpsw_entry:433 Entry -->
[2021-04-02 17:29:10]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  cpsw_attach:586 Entry -->
[2021-04-02 17:29:10]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  cpsw_parse_options:175 Verbose -->255
[2021-04-02 17:29:10]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  CPSW9G Client (core : mpu1_0) .....
[2021-04-02 17:29:10]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  Remote device (core : mpu1_0) .....
[2021-04-02 17:29:10]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  CpswProxy_start .....
[2021-04-02 17:29:10]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  Remote Device Framework Endpoint located. Remote Core Id:3, Remote End Point:26
[2021-04-02 17:29:10]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Registered a device name = mpu_1_0_ethswitch-device-0, id = 0, type = 3
[2021-04-02 17:29:10]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Version: 0. 1. 1
[2021-04-02 17:29:10]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Build Date (YYYY/MMM/DD):2021/Feb/ 1
[2021-04-02 17:29:10]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Commit SHA:a9b626ae
[2021-04-02 17:29:10]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW PermissionFlag:0x7ffffff, UART Connected:true,UART Id:2
[2021-04-02 17:29:10]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,Handle:a219853c,CoreKey:38acb7e6, RxMtu:1522, TxMtu:2024:2024:2024:2024:2024:2024:2024:2024, TxCsumEnabled:1
[2021-04-02 17:29:10]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,mac_address:70:ff:76:1d:92:c1
[2021-04-02 17:29:10]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  MAC Address: 70:ff:76:1d:92:c1
[2021-04-02 17:29:10]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  cpsw9g
[2021-04-02 17:29:10]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Vendor .............. 0x0
[2021-04-02 17:29:10]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Device .............. 0x0
[2021-04-02 17:29:10]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Revision ............ 0x0
[2021-04-02 17:29:10]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  I/O port base ....... 0xc000000
[2021-04-02 17:29:10]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  MAC address ......... 70ff76 1d92c1
[2021-04-02 17:29:10]  J7EVM@QNX:/#
[2021-04-02 17:29:13]  J7EVM@QNX:/#
J7EVM@QNX:/# slog2info /var/log/io_pkt_v6_hc.102416                      iopkt.102416
[2021-04-02 17:29:22]  Jan 01 00:01:00.866                   iopkt.102416          main_buffer*     0  tcpip starting
[2021-04-02 17:29:23]  Jan 01 00:01:00.867                   iopkt.102416          main_buffer      0  smmu support is disabled
[2021-04-02 17:29:23]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0  initializing IPsec...
[2021-04-02 17:29:23]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0   done
[2021-04-02 17:29:23]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0  IPsec: Initialized Security Association Processing.
[2021-04-02 17:29:23]  Jan 01 00:01:00.950                   iopkt.102416          main_buffer      0  devnp-cpsw9g.so verbose=0xff
[2021-04-02 17:29:23]  Jan 01 00:01:00.950                   iopkt.102416          main_buffer      0  an0
[2021-04-02 17:29:23]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog*     0  cpsw_entry:433 Entry -->
[2021-04-02 17:29:23]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  cpsw_attach:586 Entry -->
[2021-04-02 17:29:23]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  cpsw_parse_options:175 Verbose -->255
[2021-04-02 17:29:23]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  CPSW9G Client (core : mpu1_0) .....
[2021-04-02 17:29:23]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  Remote device (core : mpu1_0) .....
[2021-04-02 17:29:23]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  CpswProxy_start .....
[2021-04-02 17:29:23]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  Remote Device Framework Endpoint located. Remote Core Id:3, Remote End Point:26
[2021-04-02 17:29:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Registered a device name = mpu_1_0_ethswitch-device-0, id = 0, type = 3
[2021-04-02 17:29:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Version: 0. 1. 1
[2021-04-02 17:29:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Build Date (YYYY/MMM/DD):2021/Feb/ 1
[2021-04-02 17:29:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Commit SHA:a9b626ae
[2021-04-02 17:29:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW PermissionFlag:0x7ffffff, UART Connected:true,UART Id:2
[2021-04-02 17:29:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,Handle:a219853c,CoreKey:38acb7e6, RxMtu:1522, TxMtu:2024:2024:2024:2024:2024:2024:2024:2024, TxCsumEnabled:1
[2021-04-02 17:29:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,mac_address:70:ff:76:1d:92:c1
[2021-04-02 17:29:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  MAC Address: 70:ff:76:1d:92:c1
[2021-04-02 17:29:23]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  cpsw9g
[2021-04-02 17:29:23]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Vendor .............. 0x0
[2021-04-02 17:29:23]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Device .............. 0x0
[2021-04-02 17:29:23]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Revision ............ 0x0
[2021-04-02 17:29:23]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  I/O port base ....... 0xc000000
[2021-04-02 17:29:23]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  MAC address ......... 70ff76 1d92c1
[2021-04-02 17:29:23]  J7EVM@QNX:/# if_u    if_up -p an0
[2021-04-02 17:29:41]  J7EVM@QNX:/#
J7EVM@QNX:/# if_up -p an0
J7EVM@QNX:/# slog2info /var/log/iopkt.102416                      /var/log/slogger2/
[2021-04-02 17:29:46]  console.73743             io_pkt_v6_hc.102416       iopkt.102416
[2021-04-02 17:29:47]
J7EVM@QNX:/# slog2info /var/log/slogger2/ io
[2021-04-02 17:29:52]  io_pkt_v6_hc.102416       iopkt.102416
J7EVM@QNX:/# slog2info /var/log/slogger2/io _p                      /var/log/slogger2/io_pkt_v6_hc.102416
[2021-04-02 17:29:55]  Jan 01 00:01:00.866                   iopkt.102416          main_buffer*     0  tcpip starting
[2021-04-02 17:29:55]  Jan 01 00:01:00.867                   iopkt.102416          main_buffer      0  smmu support is disabled
[2021-04-02 17:29:55]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0  initializing IPsec...
[2021-04-02 17:29:55]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0   done
[2021-04-02 17:29:55]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0  IPsec: Initialized Security Association Processing.
[2021-04-02 17:29:55]  Jan 01 00:01:00.950                   iopkt.102416          main_buffer      0  devnp-cpsw9g.so verbose=0xff
[2021-04-02 17:29:55]  Jan 01 00:01:00.950                   iopkt.102416          main_buffer      0  an0
[2021-04-02 17:29:55]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog*     0  cpsw_entry:433 Entry -->
[2021-04-02 17:29:55]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  cpsw_attach:586 Entry -->
[2021-04-02 17:29:56]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  cpsw_parse_options:175 Verbose -->255
[2021-04-02 17:29:56]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  CPSW9G Client (core : mpu1_0) .....
[2021-04-02 17:29:56]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  Remote device (core : mpu1_0) .....
[2021-04-02 17:29:56]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  CpswProxy_start .....
[2021-04-02 17:29:56]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  Remote Device Framework Endpoint located. Remote Core Id:3, Remote End Point:26
[2021-04-02 17:29:56]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Registered a device name = mpu_1_0_ethswitch-device-0, id = 0, type = 3
[2021-04-02 17:29:56]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Version: 0. 1. 1
[2021-04-02 17:29:56]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Build Date (YYYY/MMM/DD):2021/Feb/ 1
[2021-04-02 17:29:56]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Commit SHA:a9b626ae
[2021-04-02 17:29:56]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW PermissionFlag:0x7ffffff, UART Connected:true,UART Id:2
[2021-04-02 17:29:56]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,Handle:a219853c,CoreKey:38acb7e6, RxMtu:1522, TxMtu:2024:2024:2024:2024:2024:2024:2024:2024, TxCsumEnabled:1
[2021-04-02 17:29:56]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,mac_address:70:ff:76:1d:92:c1
[2021-04-02 17:29:56]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  MAC Address: 70:ff:76:1d:92:c1
[2021-04-02 17:29:56]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  cpsw9g
[2021-04-02 17:29:56]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Vendor .............. 0x0
[2021-04-02 17:29:56]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Device .............. 0x0
[2021-04-02 17:29:56]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Revision ............ 0x0
[2021-04-02 17:29:56]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  I/O port base ....... 0xc000000
[2021-04-02 17:29:56]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  MAC address ......... 70ff76 1d92c1
[2021-04-02 17:29:56]  J7EVM@QNX:/#
[2021-04-02 17:30:05]  J7EVM@QNX:/#
J7EVM@QNX:/# slog2info /var/log/slogger2/io_pkt_v6_hc.102416                                        /var/log/slogger2/io_pkt_v6_hc.102416
[2021-04-02 17:30:09]  bin/    dev/    etc/    proc/   sbin/   ti_fs/  tmp/    usr/    var/
[2021-04-02 17:30:11]  console.73743             io_pkt_v6_hc.102416       iopkt.102416
[2021-04-02 17:30:12]  console.73743             io_pkt_v6_hc.102416       iopkt.102416
J7EVM@QNX:/# slog2info /var/log/slogger2/ ip op                     /var/log/slogger2/iopkt.102416
[2021-04-02 17:30:15]  Jan 01 00:01:00.866                   iopkt.102416          main_buffer*     0  tcpip starting
[2021-04-02 17:30:15]  Jan 01 00:01:00.867                   iopkt.102416          main_buffer      0  smmu support is disabled
[2021-04-02 17:30:15]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0  initializing IPsec...
[2021-04-02 17:30:15]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0   done
[2021-04-02 17:30:15]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0  IPsec: Initialized Security Association Processing.
[2021-04-02 17:30:15]  Jan 01 00:01:00.950                   iopkt.102416          main_buffer      0  devnp-cpsw9g.so verbose=0xff
[2021-04-02 17:30:15]  Jan 01 00:01:00.950                   iopkt.102416          main_buffer      0  an0
[2021-04-02 17:30:15]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog*     0  cpsw_entry:433 Entry -->
[2021-04-02 17:30:15]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  cpsw_attach:586 Entry -->
[2021-04-02 17:30:15]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  cpsw_parse_options:175 Verbose -->255
[2021-04-02 17:30:15]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  CPSW9G Client (core : mpu1_0) .....
[2021-04-02 17:30:15]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  Remote device (core : mpu1_0) .....
[2021-04-02 17:30:15]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  CpswProxy_start .....
[2021-04-02 17:30:15]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  Remote Device Framework Endpoint located. Remote Core Id:3, Remote End Point:26
[2021-04-02 17:30:15]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Registered a device name = mpu_1_0_ethswitch-device-0, id = 0, type = 3
[2021-04-02 17:30:15]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Version: 0. 1. 1
[2021-04-02 17:30:15]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Build Date (YYYY/MMM/DD):2021/Feb/ 1
[2021-04-02 17:30:15]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Commit SHA:a9b626ae
[2021-04-02 17:30:15]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW PermissionFlag:0x7ffffff, UART Connected:true,UART Id:2
[2021-04-02 17:30:15]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,Handle:a219853c,CoreKey:38acb7e6, RxMtu:1522, TxMtu:2024:2024:2024:2024:2024:2024:2024:2024, TxCsumEnabled:1
[2021-04-02 17:30:15]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,mac_address:70:ff:76:1d:92:c1
[2021-04-02 17:30:15]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  MAC Address: 70:ff:76:1d:92:c1
[2021-04-02 17:30:15]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  cpsw9g
[2021-04-02 17:30:15]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Vendor .............. 0x0
[2021-04-02 17:30:15]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Device .............. 0x0
[2021-04-02 17:30:15]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Revision ............ 0x0
[2021-04-02 17:30:15]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  I/O port base ....... 0xc000000
[2021-04-02 17:30:15]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  MAC address ......... 70ff76 1d92c1
[2021-04-02 17:30:15]  J7EVM@QNX:/# ifconfig eth   an0 192.168.2.66
[2021-04-02 17:30:46]  [1] + Stopped              ifconfig an0 192.168.2.66
[2021-04-02 17:30:55]  J7EVM@QNX:/# ps
[2021-04-02 17:30:57]         PID TTY          TIME CMD
[2021-04-02 17:30:57]           9 ?        00:00:00 ksh
[2021-04-02 17:30:57]       40974 ?        00:00:00 ksh
[2021-04-02 17:30:57]      204817 ?        00:00:00 ifconfig
[2021-04-02 17:30:57]      213010 ?        00:00:00 ps
[2021-04-02 17:30:57]  J7EVM@QNX:/# kill      ll
[2021-04-02 17:31:04]  ksh: ll: cannot execute - No such file or directory
[2021-04-02 17:31:04]  J7EVM@QNX:/# cat
J7EVM@QNX:/# ll
J7EVM@QNX:/# ps
J7EVM@QNX:/# ifconfig an0 192.168.2.66
J7EVM@QNX:/# slog2info /var/log/slogger2/iopkt.102416
[2021-04-02 17:31:11]  console.73743             iopkt.102416
[2021-04-02 17:31:11]  io_pkt_v6_hc.102416       tiudma_mgr.28685
J7EVM@QNX:/# slog2info /var/log/slogger2/ tiu                     /var/log/slogger2/tiudma_mgr.28685                  io
[2021-04-02 17:31:21]  io_pkt_v6_hc.102416       iopkt.102416
J7EVM@QNX:/# slog2info /var/log/slogger2/io p                     /var/log/slogger2/iopkt.102416
[2021-04-02 17:31:22]  Jan 01 00:01:00.866                   iopkt.102416          main_buffer*     0  tcpip starting
[2021-04-02 17:31:23]  Jan 01 00:01:00.867                   iopkt.102416          main_buffer      0  smmu support is disabled
[2021-04-02 17:31:23]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0  initializing IPsec...
[2021-04-02 17:31:23]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0   done
[2021-04-02 17:31:23]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0  IPsec: Initialized Security Association Processing.
[2021-04-02 17:31:23]  Jan 01 00:01:00.950                   iopkt.102416          main_buffer      0  devnp-cpsw9g.so verbose=0xff
[2021-04-02 17:31:23]  Jan 01 00:01:00.950                   iopkt.102416          main_buffer      0  an0
[2021-04-02 17:31:23]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog*     0  cpsw_entry:433 Entry -->
[2021-04-02 17:31:23]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  cpsw_attach:586 Entry -->
[2021-04-02 17:31:23]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  cpsw_parse_options:175 Verbose -->255
[2021-04-02 17:31:23]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  CPSW9G Client (core : mpu1_0) .....
[2021-04-02 17:31:23]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  Remote device (core : mpu1_0) .....
[2021-04-02 17:31:23]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  CpswProxy_start .....
[2021-04-02 17:31:23]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  Remote Device Framework Endpoint located. Remote Core Id:3, Remote End Point:26
[2021-04-02 17:31:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Registered a device name = mpu_1_0_ethswitch-device-0, id = 0, type = 3
[2021-04-02 17:31:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Version: 0. 1. 1
[2021-04-02 17:31:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Build Date (YYYY/MMM/DD):2021/Feb/ 1
[2021-04-02 17:31:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Commit SHA:a9b626ae
[2021-04-02 17:31:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW PermissionFlag:0x7ffffff, UART Connected:true,UART Id:2
[2021-04-02 17:31:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,Handle:a219853c,CoreKey:38acb7e6, RxMtu:1522, TxMtu:2024:2024:2024:2024:2024:2024:2024:2024, TxCsumEnabled:1
[2021-04-02 17:31:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,mac_address:70:ff:76:1d:92:c1
[2021-04-02 17:31:23]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  MAC Address: 70:ff:76:1d:92:c1
[2021-04-02 17:31:23]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  cpsw9g
[2021-04-02 17:31:23]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Vendor .............. 0x0
[2021-04-02 17:31:23]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Device .............. 0x0
[2021-04-02 17:31:23]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Revision ............ 0x0
[2021-04-02 17:31:23]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  I/O port base ....... 0xc000000
[2021-04-02 17:31:23]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  MAC address ......... 70ff76 1d92c1
[2021-04-02 17:31:23]  Jan 01 00:03:00.961            io_pkt_v6_hc.102416                 slog      0  ENET_CPSW_9G on MAIN NAVSS
[2021-04-02 17:31:23]  Jan 01 00:03:00.971               tiudma_mgr.28685                 slog*    55  udma_io_devctl:398 UDMA---> vintr.vintrNum=39
[2021-04-02 17:31:23]  Jan 01 00:03:00.971               tiudma_mgr.28685                 slog     55  udma_io_devctl:411 UDMA---> rintr.preferredIrIntrNum=-65535 irintr.irIntrNum=11
[2021-04-02 17:31:23]  Jan 01 00:03:00.979            io_pkt_v6_hc.102416                 slog      0  EnetIf_registerIntr: InterruptAttachEvent succeed irq/75 coid/1073741848 event/a
[2021-04-02 17:31:23]  Jan 01 00:03:00.979            io_pkt_v6_hc.102416                 slog      0  cpsw_alloc:291: Alloc successfull; Virt: 0x25c8e86000, Phys: 0x8fc990000
[2021-04-02 17:31:23]  Jan 01 00:03:00.979            io_pkt_v6_hc.102416                 slog      0  EnetUdma_memMgrInit: addr=0x25c8e86000 is  aligned
[2021-04-02 17:31:23]  Jan 01 00:03:00.980            io_pkt_v6_hc.102416                 slog      0  cpsw_alloc:291: Alloc successfull; Virt: 0x25c8e97000, Phys: 0x8fc9a1000
[2021-04-02 17:31:23]  Jan 01 00:03:00.980            io_pkt_v6_hc.102416                 slog      0  EnetIfMem_init: addr=0x25c8e97000 is  aligned
[2021-04-02 17:31:23]  Jan 01 00:03:00.980            io_pkt_v6_hc.102416                 slog      0  EnetIfMem_init: addr=0x25c8e97000, size=0x221000, gMem=0x25c8e97000, gMemBufPhys=0x8fc9a1000
[2021-04-02 17:31:23]  Jan 01 00:03:00.980            io_pkt_v6_hc.102416                 slog      0  EnetIfMem_init: gDmaDescMemArray=0x25c8e97000, size=0x200000
[2021-04-02 17:31:23]  Jan 01 00:03:00.980            io_pkt_v6_hc.102416                 slog      0  EnetIfMem_init: gRingMemArray=0x25c9097000, size=0x21000
[2021-04-02 17:31:23]  Jan 01 00:03:00.981            io_pkt_v6_hc.102416                 slog      0  EnetIfMem_init: gDmaDescMemArrayBasePhys=0x8fc9a1000, gDmaDescMemArrayBase=0x25c8e97000
[2021-04-02 17:31:23]  Jan 01 00:03:00.983            io_pkt_v6_hc.102416                 slog      0  initQs() freePktInfoQ initialized with 256 pkts
[2021-04-02 17:31:23]  Jan 01 00:03:00.984            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,Txid:51712
[2021-04-02 17:31:23]  Jan 01 00:03:00.984               tiudma_mgr.28685                 slog     55  udma_io_devctl:268 UDMA---> tx.preferredChNum=50, tx.ChNum=50
[2021-04-02 17:31:23]  Jan 01 00:03:00.984               tiudma_mgr.28685                 slog     55  udma_io_devctl:372 UDMA---> freering.ringNum=440
[2021-04-02 17:31:23]  Jan 01 00:03:00.986               tiudma_mgr.28685                 slog     55  udma_io_devctl:372 UDMA---> freering.ringNum=441
[2021-04-02 17:31:23]  Jan 01 00:03:00.988            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,RxAllocId:172
[2021-04-02 17:31:23]  Jan 01 00:03:00.989               tiudma_mgr.28685                 slog     55  udma_io_devctl:372 UDMA---> freering.ringNum=442
[2021-04-02 17:31:23]  Jan 01 00:03:00.990               tiudma_mgr.28685                 slog     55  udma_io_devctl:372 UDMA---> freering.ringNum=443
[2021-04-02 17:31:23]  Jan 01 00:03:00.990               tiudma_mgr.28685                 slog     55  udma_io_devctl:372 UDMA---> freering.ringNum=444
[2021-04-02 17:31:23]  Jan 01 00:03:00.993               tiudma_mgr.28685                 slog     55  udma_io_devctl:424 UDMA---> event.globalEvent=38
[2021-04-02 17:31:23]  Jan 01 00:03:00.993               tiudma_mgr.28685                 slog     55  udma_io_devctl:398 UDMA---> vintr.vintrNum=40
[2021-04-02 17:31:23]  Jan 01 00:03:00.993               tiudma_mgr.28685                 slog     55  udma_io_devctl:437 UDMA---> vintrbit.vintrBitNum=0
[2021-04-02 17:31:23]  Jan 01 00:03:00.993               tiudma_mgr.28685                 slog     55  udma_io_devctl:411 UDMA---> rintr.preferredIrIntrNum=-65535 irintr.irIntrNum=12
[2021-04-02 17:31:23]  Jan 01 00:03:01.009            io_pkt_v6_hc.102416                 slog      0  EnetIf_registerIntr: InterruptAttachEvent succeed irq/76 coid/1073741850 event/b
[2021-04-02 17:31:23]  Jan 01 00:03:01.011            io_pkt_v6_hc.102416                 slog      0  Host MAC address:
[2021-04-02 17:31:23]  Jan 01 00:03:01.011            io_pkt_v6_hc.102416                 slog      0  70:ff:76:1d:92:c1
[2021-04-02 17:31:23]  Jan 01 00:03:01.011            io_pkt_v6_hc.102416                 slog      0  cpsw_init:853 Phy is linked
[2021-04-02 17:31:23]  Jan 01 00:03:01.011            io_pkt_v6_hc.102416                 slog      0  cpsw_start:1060 packet length 42, protocol is 255 txFreeCnt 128
[2021-04-02 17:31:23]  Jan 01 00:03:01.011            io_pkt_v6_hc.102416                 slog      0  IPv4 address: 192:168:2:66
[2021-04-02 17:31:23]  Jan 01 00:03:01.012            io_pkt_v6_hc.102416                 slog      0  Assertion @ Line: 1155 in /media/ubuntu/9337fff7-8d53-4ef8-b28d-b4c26c6ca1a8/src/baidu/acu/sixi_sdk/ti/ti-processor-sdk-rtos-j721e-evm-07_02_00_06/psdkqa/../ethfw/ethremotecfg/client/src/cpsw_proxy.c: msg->res.retVal == ENET_SOK : failed !!!
[2021-04-02 17:31:23]  J7EVM@QNX:/#
J7EVM@QNX:/# ll
J7EVM@QNX:/# ps
J7EVM@QNX:/# ll
[2021-04-02 17:31:48]  console.73743             iopkt.102416
[2021-04-02 17:31:48]  io_pkt_v6_hc.102416       tiudma_mgr.28685
[2021-04-02 17:31:50]  Jan 01 00:01:00.866                   iopkt.102416          main_buffer*     0  tcpip starting
[2021-04-02 17:31:51]  Jan 01 00:01:00.867                   iopkt.102416          main_buffer      0  smmu support is disabled
[2021-04-02 17:31:51]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0  initializing IPsec...
[2021-04-02 17:31:51]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0   done
[2021-04-02 17:31:51]  Jan 01 00:01:00.868                   iopkt.102416          main_buffer      0  IPsec: Initialized Security Association Processing.
[2021-04-02 17:31:51]  Jan 01 00:01:00.950                   iopkt.102416          main_buffer      0  devnp-cpsw9g.so verbose=0xff
[2021-04-02 17:31:51]  Jan 01 00:01:00.950                   iopkt.102416          main_buffer      0  an0
[2021-04-02 17:31:51]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog*     0  cpsw_entry:433 Entry -->
[2021-04-02 17:31:51]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  cpsw_attach:586 Entry -->
[2021-04-02 17:31:51]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  cpsw_parse_options:175 Verbose -->255
[2021-04-02 17:31:51]  Jan 01 00:01:00.950            io_pkt_v6_hc.102416                 slog      0  CPSW9G Client (core : mpu1_0) .....
[2021-04-02 17:31:51]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  Remote device (core : mpu1_0) .....
[2021-04-02 17:31:51]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  CpswProxy_start .....
[2021-04-02 17:31:51]  Jan 01 00:01:00.952            io_pkt_v6_hc.102416                 slog      0  Remote Device Framework Endpoint located. Remote Core Id:3, Remote End Point:26
[2021-04-02 17:31:51]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Registered a device name = mpu_1_0_ethswitch-device-0, id = 0, type = 3
[2021-04-02 17:31:51]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Version: 0. 1. 1
[2021-04-02 17:31:51]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Build Date (YYYY/MMM/DD):2021/Feb/ 1
[2021-04-02 17:31:51]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW Commit SHA:a9b626ae
[2021-04-02 17:31:51]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  ETHFW PermissionFlag:0x7ffffff, UART Connected:true,UART Id:2
[2021-04-02 17:31:51]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,Handle:a219853c,CoreKey:38acb7e6, RxMtu:1522, TxMtu:2024:2024:2024:2024:2024:2024:2024:2024, TxCsumEnabled:1
[2021-04-02 17:31:51]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,mac_address:70:ff:76:1d:92:c1
[2021-04-02 17:31:51]  Jan 01 00:01:00.963            io_pkt_v6_hc.102416                 slog      0  MAC Address: 70:ff:76:1d:92:c1
[2021-04-02 17:31:51]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  cpsw9g
[2021-04-02 17:31:51]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Vendor .............. 0x0
[2021-04-02 17:31:51]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Device .............. 0x0
[2021-04-02 17:31:51]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  Revision ............ 0x0
[2021-04-02 17:31:51]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  I/O port base ....... 0xc000000
[2021-04-02 17:31:51]  Jan 01 00:01:00.964            io_pkt_v6_hc.102416                 slog      0  MAC address ......... 70ff76 1d92c1
[2021-04-02 17:31:51]  Jan 01 00:03:00.961            io_pkt_v6_hc.102416                 slog      0  ENET_CPSW_9G on MAIN NAVSS
[2021-04-02 17:31:51]  Jan 01 00:03:00.971               tiudma_mgr.28685                 slog*    55  udma_io_devctl:398 UDMA---> vintr.vintrNum=39
[2021-04-02 17:31:51]  Jan 01 00:03:00.971               tiudma_mgr.28685                 slog     55  udma_io_devctl:411 UDMA---> rintr.preferredIrIntrNum=-65535 irintr.irIntrNum=11
[2021-04-02 17:31:51]  Jan 01 00:03:00.979            io_pkt_v6_hc.102416                 slog      0  EnetIf_registerIntr: InterruptAttachEvent succeed irq/75 coid/1073741848 event/a
[2021-04-02 17:31:51]  Jan 01 00:03:00.979            io_pkt_v6_hc.102416                 slog      0  cpsw_alloc:291: Alloc successfull; Virt: 0x25c8e86000, Phys: 0x8fc990000
[2021-04-02 17:31:51]  Jan 01 00:03:00.979            io_pkt_v6_hc.102416                 slog      0  EnetUdma_memMgrInit: addr=0x25c8e86000 is  aligned
[2021-04-02 17:31:51]  Jan 01 00:03:00.980            io_pkt_v6_hc.102416                 slog      0  cpsw_alloc:291: Alloc successfull; Virt: 0x25c8e97000, Phys: 0x8fc9a1000
[2021-04-02 17:31:51]  Jan 01 00:03:00.980            io_pkt_v6_hc.102416                 slog      0  EnetIfMem_init: addr=0x25c8e97000 is  aligned
[2021-04-02 17:31:51]  Jan 01 00:03:00.980            io_pkt_v6_hc.102416                 slog      0  EnetIfMem_init: addr=0x25c8e97000, size=0x221000, gMem=0x25c8e97000, gMemBufPhys=0x8fc9a1000
[2021-04-02 17:31:51]  Jan 01 00:03:00.980            io_pkt_v6_hc.102416                 slog      0  EnetIfMem_init: gDmaDescMemArray=0x25c8e97000, size=0x200000
[2021-04-02 17:31:51]  Jan 01 00:03:00.980            io_pkt_v6_hc.102416                 slog      0  EnetIfMem_init: gRingMemArray=0x25c9097000, size=0x21000
[2021-04-02 17:31:51]  Jan 01 00:03:00.981            io_pkt_v6_hc.102416                 slog      0  EnetIfMem_init: gDmaDescMemArrayBasePhys=0x8fc9a1000, gDmaDescMemArrayBase=0x25c8e97000
[2021-04-02 17:31:51]  Jan 01 00:03:00.983            io_pkt_v6_hc.102416                 slog      0  initQs() freePktInfoQ initialized with 256 pkts
[2021-04-02 17:31:51]  Jan 01 00:03:00.984            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,Txid:51712
[2021-04-02 17:31:51]  Jan 01 00:03:00.984               tiudma_mgr.28685                 slog     55  udma_io_devctl:268 UDMA---> tx.preferredChNum=50, tx.ChNum=50
[2021-04-02 17:31:51]  Jan 01 00:03:00.984               tiudma_mgr.28685                 slog     55  udma_io_devctl:372 UDMA---> freering.ringNum=440
[2021-04-02 17:31:51]  Jan 01 00:03:00.986               tiudma_mgr.28685                 slog     55  udma_io_devctl:372 UDMA---> freering.ringNum=441
[2021-04-02 17:31:51]  Jan 01 00:03:00.988            io_pkt_v6_hc.102416                 slog      0  Function:CpswProxy_cmdHandler,RxAllocId:172
[2021-04-02 17:31:51]  Jan 01 00:03:00.989               tiudma_mgr.28685                 slog     55  udma_io_devctl:372 UDMA---> freering.ringNum=442
[2021-04-02 17:31:51]  Jan 01 00:03:00.990               tiudma_mgr.28685                 slog     55  udma_io_devctl:372 UDMA---> freering.ringNum=443
[2021-04-02 17:31:51]  Jan 01 00:03:00.990               tiudma_mgr.28685                 slog     55  udma_io_devctl:372 UDMA---> freering.ringNum=444
[2021-04-02 17:31:51]  Jan 01 00:03:00.993               tiudma_mgr.28685                 slog     55  udma_io_devctl:424 UDMA---> event.globalEvent=38
[2021-04-02 17:31:51]  Jan 01 00:03:00.993               tiudma_mgr.28685                 slog     55  udma_io_devctl:398 UDMA---> vintr.vintrNum=40
[2021-04-02 17:31:51]  Jan 01 00:03:00.993               tiudma_mgr.28685                 slog     55  udma_io_devctl:437 UDMA---> vintrbit.vintrBitNum=0
[2021-04-02 17:31:51]  Jan 01 00:03:00.993               tiudma_mgr.28685                 slog     55  udma_io_devctl:411 UDMA---> rintr.preferredIrIntrNum=-65535 irintr.irIntrNum=12
[2021-04-02 17:31:51]  Jan 01 00:03:01.009            io_pkt_v6_hc.102416                 slog      0  EnetIf_registerIntr: InterruptAttachEvent succeed irq/76 coid/1073741850 event/b
[2021-04-02 17:31:51]  Jan 01 00:03:01.011            io_pkt_v6_hc.102416                 slog      0  Host MAC address:
[2021-04-02 17:31:51]  Jan 01 00:03:01.011            io_pkt_v6_hc.102416                 slog      0  70:ff:76:1d:92:c1
[2021-04-02 17:31:51]  Jan 01 00:03:01.011            io_pkt_v6_hc.102416                 slog      0  cpsw_init:853 Phy is linked
[2021-04-02 17:31:51]  Jan 01 00:03:01.011            io_pkt_v6_hc.102416                 slog      0  cpsw_start:1060 packet length 42, protocol is 255 txFreeCnt 128
[2021-04-02 17:31:51]  Jan 01 00:03:01.011            io_pkt_v6_hc.102416                 slog      0  IPv4 address: 192:168:2:66
[2021-04-02 17:31:51]  Jan 01 00:03:01.012            io_pkt_v6_hc.102416                 slog      0  Assertion @ Line: 1155 in /media/ubuntu/9337fff7-8d53-4ef8-b28d-b4c26c6ca1a8/src/baidu/acu/sixi_sdk/ti/ti-processor-sdk-rtos-j721e-evm-07_02_00_06/psdkqa/../ethfw/ethremotecfg/client/src/cpsw_proxy.c: msg->res.retVal == ENET_SOK : failed !!!
[2021-04-02 17:31:51]  J7EVM@QNX:/# q
