Part Number: OMAPL138B-EP
Other Parts Discussed in Thread: OMAPL138
I am using OMAPL138 SoC on my hardware board and after running for few days I get an error every 24 hours as per the message file in the /var/log/message (attached)
Any idea what is this error message means?
The partition it's writing data to is an Micro-SD card and its partition is EXT4. SDK (ti-sdk-linux-04-00-00-04) was used for Linux configuration.
Thanks.
Oct 23 11:13:12 omapl138-lcdk syslog.info syslogd started: BusyBox v1.24.1 Jun 28 20:26:04 omapl138-lcdk daemon.info systemd-modules-load[58]: Inserted module 'cryptodev' Jun 28 20:26:04 omapl138-lcdk daemon.info systemd-sysctl[74]: Couldn't write 'fq_codel' to 'net/core/default_qdisc', ignoring: No such file or directory Jun 28 20:26:04 omapl138-lcdk daemon.info systemd-sysctl[74]: Couldn't write '16' to 'kernel/sysrq', ignoring: No such file or directory Jun 28 20:26:04 omapl138-lcdk daemon.info systemd[1]: Starting Flush Journal to Persistent Storage... Jun 28 20:26:05 omapl138-lcdk daemon.info systemd[1]: Started Create Static Device Nodes in /dev. Jun 28 20:26:05 omapl138-lcdk daemon.info systemd[1]: Started Flush Journal to Persistent Storage. Jun 28 20:26:05 omapl138-lcdk daemon.info systemd[1]: Starting udev Kernel Device Manager... Jun 28 20:26:05 omapl138-lcdk daemon.info systemd[1]: Reached target Local File Systems (Pre). Jun 28 20:26:05 omapl138-lcdk daemon.info systemd[1]: Mounting /media/ram... Jun 28 20:26:05 omapl138-lcdk daemon.info systemd[1]: Mounting /var/volatile... Jun 28 20:26:05 omapl138-lcdk daemon.info systemd[1]: Mounting /home/codauser/data... Jun 28 20:26:06 omapl138-lcdk daemon.info systemd[1]: Mounted /var/volatile. Jun 28 20:26:06 omapl138-lcdk daemon.info systemd[1]: Mounted /media/ram. Jun 28 20:26:06 omapl138-lcdk daemon.info systemd[1]: Mounted /home/codauser/data. Jun 28 20:26:06 omapl138-lcdk daemon.info systemd[1]: Starting Load/Save Random Seed... Jun 28 20:26:06 omapl138-lcdk daemon.info systemd[1]: Reached target Local File Systems. Jun 28 20:26:06 omapl138-lcdk daemon.info systemd[1]: Starting Create Volatile Files and Directories... Jun 28 20:26:06 omapl138-lcdk daemon.info systemd[1]: Started udev Kernel Device Manager. Jun 28 20:26:06 omapl138-lcdk daemon.info systemd[1]: Started Load/Save Random Seed. Jun 28 20:26:06 omapl138-lcdk daemon.warn systemd-tmpfiles[90]: "/var/tmp" already exists and is not a directory. Jun 28 20:26:07 omapl138-lcdk daemon.warn systemd-tmpfiles[90]: "/var/log" already exists and is not a directory. Jun 28 20:26:07 omapl138-lcdk daemon.info systemd[1]: Started Create Volatile Files and Directories. Jun 28 20:26:07 omapl138-lcdk daemon.info systemd[1]: Starting Network Time Synchronization... Jun 28 20:26:07 omapl138-lcdk daemon.info systemd[1]: Starting Update UTMP about System Boot/Shutdown... Jun 28 20:26:08 omapl138-lcdk daemon.info systemd[1]: Started Update UTMP about System Boot/Shutdown. Jun 28 20:26:08 omapl138-lcdk cron.info systemd-timesyncd[101]: System clock time unset or jumped backwards, restoring from recorded timestamp: Fri 2020-10-23 11:13:07 UTC Oct 23 11:13:07 omapl138-lcdk daemon.info systemd[1]: Time has been changed Oct 23 11:13:07 omapl138-lcdk daemon.info systemd[1]: Started Network Time Synchronization. Oct 23 11:13:07 omapl138-lcdk daemon.info systemd[1]: Reached target System Time Synchronized. Oct 23 11:13:07 omapl138-lcdk daemon.info systemd[1]: Starting Synchronize System and HW clocks... Oct 23 11:13:07 omapl138-lcdk daemon.info hwclock[105]: hwclock: can't open '/dev/misc/rtc': No such file or directory Oct 23 11:13:07 omapl138-lcdk daemon.notice systemd[1]: sync-clocks.service: Main process exited, code=exited, status=1/FAILURE Oct 23 11:13:07 omapl138-lcdk daemon.err systemd[1]: Failed to start Synchronize System and HW clocks. Oct 23 11:13:07 omapl138-lcdk daemon.notice systemd[1]: sync-clocks.service: Unit entered failed state. Oct 23 11:13:07 omapl138-lcdk daemon.warn systemd[1]: sync-clocks.service: Failed with result 'exit-code'. Oct 23 11:13:09 omapl138-lcdk daemon.warn systemd-udevd[108]: Process '/sbin/modprobe platform:Fixed MDIO bus' failed with exit code 1. Oct 23 11:13:09 omapl138-lcdk daemon.warn systemd-udevd[109]: Process '/sbin/modprobe platform:alarmtimer' failed with exit code 1. Oct 23 11:13:09 omapl138-lcdk daemon.warn systemd-udevd[110]: Process '/sbin/modprobe of:Nmemory-controllerT<NULL>Cti,da850-ddr-controller' failed with exit code 1. Oct 23 11:13:09 omapl138-lcdk daemon.warn systemd-udevd[114]: Process '/sbin/modprobe platform:reg-dummy' failed with exit code 1. Oct 23 11:13:09 omapl138-lcdk daemon.warn systemd-udevd[115]: Process '/sbin/modprobe platform:serial8250' failed with exit code 1. Oct 23 11:13:09 omapl138-lcdk daemon.warn systemd-udevd[108]: Process '/sbin/modprobe of:NsocT<NULL>Csimple-bus' failed with exit code 1. Oct 23 11:13:10 omapl138-lcdk daemon.warn systemd-udevd[109]: Process '/sbin/modprobe of:NedmaT<NULL>Cti,edma3-tpcc' failed with exit code 1. Oct 23 11:13:10 omapl138-lcdk daemon.warn systemd-udevd[122]: Process '/sbin/modprobe of:NtptcT<NULL>Cti,edma3-tptc' failed with exit code 1. Oct 23 11:13:10 omapl138-lcdk daemon.warn systemd-udevd[124]: Process '/sbin/modprobe of:NtptcT<NULL>Cti,edma3-tptc' failed with exit code 1. Oct 23 11:13:10 omapl138-lcdk daemon.warn systemd-udevd[108]: Process '/sbin/modprobe of:NpinmuxT<NULL>Cpinctrl-single' failed with exit code 1. Oct 23 11:13:10 omapl138-lcdk daemon.warn systemd-udevd[125]: Process '/sbin/modprobe of:Npriority-controllerT<NULL>Cti,da850-mstpri' failed with exit code 1. Oct 23 11:13:10 omapl138-lcdk daemon.warn systemd-udevd[109]: Process '/sbin/modprobe of:Nchip-controllerT<NULL>Cti,da830-cfgchipCsysconCsimple-mfd' failed with exit code 1. Oct 23 11:13:10 omapl138-lcdk daemon.warn systemd-udevd[111]: Process '/sbin/modprobe of:NedmaT<NULL>Cti,edma3-tpcc' failed with exit code 1. Oct 23 11:13:10 omapl138-lcdk daemon.warn systemd-udevd[114]: Process '/sbin/modprobe of:NgpioT<NULL>Cti,dm6441-gpio' failed with exit code 1. Oct 23 11:13:11 omapl138-lcdk daemon.info systemd[1]: Started udev Coldplug all Devices. Oct 23 11:13:11 omapl138-lcdk daemon.info systemd[1]: Reached target System Initialization. Oct 23 11:13:11 omapl138-lcdk daemon.info systemd[1]: Started Daily Cleanup of Temporary Directories. Oct 23 11:13:11 omapl138-lcdk daemon.info systemd[1]: Reached target Timers. Oct 23 11:13:11 omapl138-lcdk daemon.warn systemd-udevd[125]: Process '/sbin/modprobe of:NtptcT<NULL>Cti,edma3-tptc' failed with exit code 1. Oct 23 11:13:11 omapl138-lcdk daemon.info systemd[1]: Listening on D-Bus System Message Bus Socket. Oct 23 11:13:11 omapl138-lcdk daemon.warn systemd-udevd[122]: Process '/sbin/modprobe of:NmmcT<NULL>Cti,da830-mmc' failed with exit code 1. Oct 23 11:13:11 omapl138-lcdk daemon.warn systemd-udevd[108]: Process '/sbin/modprobe of:NethernetT<NULL>Cti,davinci-dm6467-emac' failed with exit code 1. Oct 23 11:13:11 omapl138-lcdk daemon.warn systemd-udevd[111]: Process '/sbin/modprobe platform:vpif_capture' failed with exit code 1. Oct 23 11:13:11 omapl138-lcdk daemon.warn systemd-udevd[109]: Process '/sbin/modprobe of:NmdioT<NULL>Cti,davinci_mdio' failed with exit code 1. Oct 23 11:13:11 omapl138-lcdk daemon.info systemd[1]: Listening on dropbear.socket. Oct 23 11:13:11 omapl138-lcdk daemon.info systemd[1]: Listening on RPCbind Server Activation Socket. Oct 23 11:13:11 omapl138-lcdk daemon.info systemd[1]: Reached target Sockets. Oct 23 11:13:11 omapl138-lcdk daemon.info systemd[1]: Reached target Basic System. Oct 23 11:13:12 omapl138-lcdk daemon.warn systemd-udevd[122]: Process '/sbin/modprobe mmc:block' failed with exit code 1. Oct 23 11:13:12 omapl138-lcdk daemon.warn systemd-udevd[125]: Process '/sbin/modprobe of:NserialT<NULL>Cti,da830-uartCns16550a' failed with exit code 1. Oct 23 11:13:12 omapl138-lcdk daemon.info systemd[1]: Started System Logging Service. Oct 23 11:13:12 omapl138-lcdk daemon.info systemd[1]: Starting Ethernet Bridge Filtering Tables... Oct 23 11:13:12 omapl138-lcdk daemon.info systemd[1]: Starting tiipclad-daemon.service... Oct 23 11:13:13 omapl138-lcdk daemon.info systemd[1]: Starting Login Service... Oct 23 11:13:13 omapl138-lcdk daemon.info systemd[1]: Started www-coda Run init Service. Oct 23 11:13:13 omapl138-lcdk daemon.info systemd[1]: Started Kernel Logging Service. Oct 23 11:13:13 omapl138-lcdk user.notice kernel: klogd started: BusyBox v1.24.1 (2017-06-28 17:27:01 EDT) Oct 23 11:13:13 omapl138-lcdk user.info kernel: Booting Linux on physical CPU 0x0 Oct 23 11:13:13 omapl138-lcdk user.notice kernel: Linux version 4.9.28-geed43d1050 (root@ubuntu) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 PREEMPT Thu Jun 11 16:36:43 BST 2020 Oct 23 11:13:13 omapl138-lcdk user.info kernel: CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f Oct 23 11:13:13 omapl138-lcdk daemon.info systemd[1]: Starting Print notice about GPLv3 packages... Oct 23 11:13:13 omapl138-lcdk user.info kernel: CPU: VIVT data cache, VIVT instruction cache Oct 23 11:13:13 omapl138-lcdk daemon.err systemd[172]: gplv3-notice.service: Failed at step STDOUT spawning /etc/init.d/gplv3-notice: No such device Oct 23 11:13:13 omapl138-lcdk user.info kernel: OF: fdt:Machine model: DA850/AM1808/OMAP-L138 LCDK Oct 23 11:13:14 omapl138-lcdk daemon.info systemd[1]: Starting telnetd.service... Oct 23 11:13:13 omapl138-lcdk user.info kernel: Reserved memory: created CMA memory pool at 0xc3000000, size 32 MiB Oct 23 11:13:14 omapl138-lcdk daemon.info systemd[1]: Started D-Bus System Message Bus. Oct 23 11:13:13 omapl138-lcdk user.info kernel: OF: reserved mem: initialized node dsp_cma@c3000000, compatible id shared-dma-pool Oct 23 11:13:13 omapl138-lcdk user.info kernel: cma: Reserved 16 MiB at 0xc6c00000 Oct 23 11:13:13 omapl138-lcdk user.info kernel: Memory policy: Data cache writethrough Oct 23 11:13:13 omapl138-lcdk user.info kernel: DaVinci da850/omap-l138/am18x variant 0x1 Oct 23 11:13:13 omapl138-lcdk user.debug kernel: On node 0 totalpages: 32768 Oct 23 11:13:14 omapl138-lcdk daemon.info tiipclad-daemon.sh[150]: Starting tiipclad daemon Oct 23 11:13:14 omapl138-lcdk daemon.info tiipclad-daemon.sh[150]: GateMP is not supported for this device Oct 23 11:13:15 omapl138-lcdk daemon.info tiipclad-daemon.sh[150]: Opened log file: lad.txt Oct 23 11:13:15 omapl138-lcdk daemon.info tiipclad-daemon.sh[150]: numProcessors = 2 id = 0 baseId = 0 Oct 23 11:13:15 omapl138-lcdk daemon.info tiipclad-daemon.sh[150]: Spawned daemon: /usr/bin/lad_omapl138 Oct 23 11:13:13 omapl138-lcdk user.debug kernel: free_area_init_node: node 0, pgdat c066bcf0, node_mem_map c7ec1000 Oct 23 11:13:15 omapl138-lcdk daemon.info tiipclad-daemon.sh[150]: . Oct 23 11:13:15 omapl138-lcdk daemon.info telnetd[178]: Starting telnet daemon. Oct 23 11:13:13 omapl138-lcdk user.debug kernel: DMA zone: 288 pages used for memmap Oct 23 11:13:13 omapl138-lcdk user.debug kernel: DMA zone: 0 pages reserved Oct 23 11:13:13 omapl138-lcdk user.debug kernel: DMA zone: 32768 pages, LIFO batch:7 Oct 23 11:13:13 omapl138-lcdk user.debug kernel: pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 Oct 23 11:13:13 omapl138-lcdk user.debug kernel: pcpu-alloc: [0] 0 Oct 23 11:13:13 omapl138-lcdk user.info kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32480 Oct 23 11:13:13 omapl138-lcdk user.notice kernel: Kernel command line: console=ttyS2,115200n8 root=PARTUUID=a8d05222-02 rw rootfstype=ext4 rootwait Oct 23 11:13:13 omapl138-lcdk user.info kernel: PID hash table entries: 512 (order: -1, 2048 bytes) Oct 23 11:13:13 omapl138-lcdk user.info kernel: Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Oct 23 11:13:13 omapl138-lcdk user.info kernel: Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Oct 23 11:13:13 omapl138-lcdk user.info kernel: Memory: 73740K/131072K available (4553K kernel code, 309K rwdata, 1452K rodata, 228K init, 162K bss, 8180K reserved, 49152K cma-reserved) Oct 23 11:13:13 omapl138-lcdk user.notice kernel: Virtual kernel memory layout: Oct 23 11:13:13 omapl138-lcdk user.notice kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB) Oct 23 11:13:13 omapl138-lcdk user.notice kernel: fixmap : 0xffc00000 - 0xfff00000 (3072 kB) Oct 23 11:13:13 omapl138-lcdk user.notice kernel: vmalloc : 0xc8800000 - 0xff800000 ( 880 MB) Oct 23 11:13:13 omapl138-lcdk user.notice kernel: lowmem : 0xc0000000 - 0xc8000000 ( 128 MB) Oct 23 11:13:13 omapl138-lcdk user.notice kernel: modules : 0xbf000000 - 0xc0000000 ( 16 MB) Oct 23 11:13:13 omapl138-lcdk user.notice kernel: .text : 0xc0008000 - 0xc047a960 (4555 kB) Oct 23 11:13:13 omapl138-lcdk user.notice kernel: .init : 0xc05e7000 - 0xc0620000 ( 228 kB) Oct 23 11:13:13 omapl138-lcdk user.notice kernel: .data : 0xc0620000 - 0xc066d628 ( 310 kB) Oct 23 11:13:13 omapl138-lcdk user.notice kernel: .bss : 0xc066d628 - 0xc0696170 ( 163 kB) Oct 23 11:13:13 omapl138-lcdk user.info kernel: SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Oct 23 11:13:13 omapl138-lcdk user.info kernel: Preemptible hierarchical RCU implementation. Oct 23 11:13:13 omapl138-lcdk user.info kernel: Build-time adjustment of leaf fanout to 32. Oct 23 11:13:13 omapl138-lcdk user.info kernel: NR_IRQS:245 Oct 23 11:13:13 omapl138-lcdk user.info kernel: clocksource: timer0_1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns Oct 23 11:13:13 omapl138-lcdk user.info kernel: sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns Oct 23 11:13:13 omapl138-lcdk user.info kernel: Console: colour dummy device 80x30 Oct 23 11:13:13 omapl138-lcdk user.info kernel: Calibrating delay loop... 227.32 BogoMIPS (lpj=1136640) Oct 23 11:13:13 omapl138-lcdk user.info kernel: pid_max: default: 32768 minimum: 301 Oct 23 11:13:13 omapl138-lcdk user.info kernel: Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) Oct 23 11:13:13 omapl138-lcdk user.info kernel: Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) Oct 23 11:13:16 omapl138-lcdk daemon.info systemd[1]: Starting Network Service... Oct 23 11:13:13 omapl138-lcdk user.info kernel: CPU: Testing write buffer coherency: ok Oct 23 11:13:13 omapl138-lcdk user.info kernel: Setting up static identity map for 0xc0008400 - 0xc0008458 Oct 23 11:13:17 omapl138-lcdk daemon.info systemd[1]: Started System Logger Daemon. Oct 23 11:13:13 omapl138-lcdk user.info kernel: devtmpfs: initialized Oct 23 11:13:13 omapl138-lcdk user.info kernel: VFP support v0.3: not present Oct 23 11:13:13 omapl138-lcdk user.info kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns Oct 23 11:13:13 omapl138-lcdk user.info kernel: futex hash table entries: 256 (order: -1, 3072 bytes) Oct 23 11:13:13 omapl138-lcdk user.info kernel: pinctrl core: initialized pinctrl subsystem Oct 23 11:13:17 omapl138-lcdk daemon.info systemd[1]: Started Ethernet Bridge Filtering Tables. Oct 23 11:13:13 omapl138-lcdk user.info kernel: NET: Registered protocol family 16 Oct 23 11:13:17 omapl138-lcdk daemon.info systemd[1]: Started tiipclad-daemon.service. Oct 23 11:13:13 omapl138-lcdk user.info kernel: DMA: preallocated 256 KiB pool for atomic coherent allocations Oct 23 11:13:17 omapl138-lcdk daemon.notice systemd[1]: gplv3-notice.service: Main process exited, code=exited, status=209/STDOUT Oct 23 11:13:13 omapl138-lcdk user.info kernel: cpuidle: using governor ladder Oct 23 11:13:18 omapl138-lcdk daemon.err systemd[1]: Failed to start Print notice about GPLv3 packages. Oct 23 11:13:13 omapl138-lcdk user.info kernel: cpuidle: using governor menu Oct 23 11:13:18 omapl138-lcdk daemon.notice systemd[1]: gplv3-notice.service: Unit entered failed state. Oct 23 11:13:13 omapl138-lcdk user.debug kernel: gpio gpiochip0: (Davinci): added GPIO chardev (254:0) Oct 23 11:13:18 omapl138-lcdk daemon.warn systemd[1]: gplv3-notice.service: Failed with result 'exit-code'. Oct 23 11:13:13 omapl138-lcdk user.debug kernel: gpiochip_setup_dev: registered GPIOs 0 to 143 on device: gpiochip0 (Davinci) Oct 23 11:13:18 omapl138-lcdk daemon.info systemd[1]: Started telnetd.service. Oct 23 11:13:18 omapl138-lcdk daemon.info syslog-ng[199]: [2020-10-23T11:13:18.614202] WARNING: Configuration file format is too old, syslog-ng is running in compatibility mode Please update it to use the syslog-ng 3.6 format at your time of convinience, compatibility mode can Oct 23 11:13:13 omapl138-lcdk user.warn kernel: mux: initialized RTC_ALARM Oct 23 11:13:13 omapl138-lcdk user.warn kernel: mux: Setting register RTC_ALARM Oct 23 11:13:13 omapl138-lcdk user.warn kernel: mux: PINMUX0 (0x00000000) = 0x44080000 -> 0x24080000 Oct 23 11:13:13 omapl138-lcdk user.info kernel: No ATAGs? Oct 23 11:13:13 omapl138-lcdk user.info kernel: edma 1c00000.edma: memcpy is disabled Oct 23 11:13:13 omapl138-lcdk user.info kernel: edma 1c00000.edma: TI EDMA DMA engine driver Oct 23 11:13:19 omapl138-lcdk daemon.warn systemd-networkd[196]: [/etc/systemd/network/10-eth.network:11] Unknown lvalue 'Submask' in section 'Network' Oct 23 11:13:13 omapl138-lcdk user.info kernel: edma 1e30000.edma: memcpy is disabled Oct 23 11:13:19 omapl138-lcdk daemon.warn systemd-networkd[196]: [/etc/systemd/network/10-eth.network:16] Unknown lvalue 'Submask' in section 'Network' Oct 23 11:13:13 omapl138-lcdk user.info kernel: edma 1e30000.edma: TI EDMA DMA engine driver Oct 23 11:13:19 omapl138-lcdk daemon.info systemd-networkd[196]: Enumeration completed Oct 23 11:13:13 omapl138-lcdk user.info kernel: pps_core: LinuxPPS API ver. 1 registered Oct 23 11:13:19 omapl138-lcdk daemon.info systemd[1]: Started Network Service. Oct 23 11:13:13 omapl138-lcdk user.info kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> Oct 23 11:13:19 omapl138-lcdk daemon.info systemd-networkd[196]: eth0: IPv6 disabled for interface: Success Oct 23 11:13:13 omapl138-lcdk user.info kernel: PTP clock support registered Oct 23 11:13:19 omapl138-lcdk auth.info systemd-logind[157]: New seat seat0. Oct 23 11:13:13 omapl138-lcdk user.info kernel: clocksource: Switched to clocksource timer0_1 Oct 23 11:13:19 omapl138-lcdk daemon.info systemd[1]: Started Login Service. Oct 23 11:13:13 omapl138-lcdk user.info kernel: NET: Registered protocol family 2 Oct 23 11:13:19 omapl138-lcdk daemon.info systemd[1]: Reached target Network. Oct 23 11:13:13 omapl138-lcdk user.info kernel: TCP established hash table entries: 1024 (order: 0, 4096 bytes) Oct 23 11:13:20 omapl138-lcdk daemon.info systemd[1]: Starting Lightning Fast Webserver With Light System Requirements... Oct 23 11:13:21 omapl138-lcdk daemon.info lighttpd[231]: Syntax OK Oct 23 11:13:13 omapl138-lcdk user.info kernel: TCP bind hash table entries: 1024 (order: 0, 4096 bytes) Oct 23 11:13:20 omapl138-lcdk daemon.info systemd[1]: Starting Run Coda Octopus startup scripts... Oct 23 11:13:13 omapl138-lcdk user.info kernel: TCP: Hash tables configured (established 1024 bind 1024) Oct 23 11:13:20 omapl138-lcdk daemon.info systemd[1]: Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf. Oct 23 11:13:13 omapl138-lcdk user.info kernel: UDP hash table entries: 256 (order: 0, 4096 bytes) Oct 23 11:13:21 omapl138-lcdk daemon.info systemd[1]: Started Vsftpd ftp daemon. Oct 23 11:13:13 omapl138-lcdk user.info kernel: UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) Oct 23 11:13:21 omapl138-lcdk daemon.info systemd[1]: Starting Permit User Sessions... Oct 23 11:13:13 omapl138-lcdk user.info kernel: NET: Registered protocol family 1 Oct 23 11:13:21 omapl138-lcdk daemon.info systemd[1]: Starting Network Name Resolution... Oct 23 11:13:13 omapl138-lcdk user.info kernel: RPC: Registered named UNIX socket transport module. Oct 23 11:13:21 omapl138-lcdk daemon.info systemd-networkd[196]: eth0: Gained carrier Oct 23 11:13:13 omapl138-lcdk user.info kernel: RPC: Registered udp transport module. Oct 23 11:13:21 omapl138-lcdk cron.info systemd-timesyncd[101]: Network configuration changed, trying to establish connection. Oct 23 11:13:13 omapl138-lcdk user.info kernel: RPC: Registered tcp transport module. Oct 23 11:13:22 omapl138-lcdk daemon.info systemd[1]: Starting Simple Network Management Protocol (SNMP) Daemon.... Oct 23 11:13:13 omapl138-lcdk user.info kernel: RPC: Registered tcp NFSv4.1 backchannel transport module. Oct 23 11:13:22 omapl138-lcdk daemon.info systemd[1]: Starting rng-tools.service... Oct 23 11:13:13 omapl138-lcdk user.info kernel: workingset: timestamp_bits=14 max_order=15 bucket_order=1 Oct 23 11:13:24 omapl138-lcdk daemon.info snmpd[253]: pcilib: Cannot open /proc/bus/pci Oct 23 11:13:13 omapl138-lcdk user.info kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) Oct 23 11:13:13 omapl138-lcdk user.info kernel: io scheduler noop registered (default) Oct 23 11:13:24 omapl138-lcdk daemon.info systemd-resolved[247]: Positive Trust Anchors: Oct 23 11:13:13 omapl138-lcdk user.warn kernel: pinctrl-single 1c14120.pinmux: please update dts to use #pinctrl-cells = <2> Oct 23 11:13:24 omapl138-lcdk daemon.info systemd-resolved[247]: . IN DS 19036 8 2 49aac11d7b6f6446702e54a1607371607a1a41855200fd2ce1cdde32f24e8fb5 Oct 23 11:13:13 omapl138-lcdk user.info kernel: pinctrl-single 1c14120.pinmux: 160 pins at pa fec14120 size 80 Oct 23 11:13:24 omapl138-lcdk daemon.info systemd-resolved[247]: Negative trust anchors: 10.in-addr.arpa 16.172.in-addr.arpa 17.172.in-addr.arpa 18.172.in-addr.arpa 19.172.in-addr.arpa 20.172.in-addr.arpa 21.172.in-addr.arpa 22.172.in-addr.arpa 23.172.in-addr.arpa 24.172.in-ad Oct 23 11:13:13 omapl138-lcdk user.info kernel: Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled Oct 23 11:13:24 omapl138-lcdk daemon.info systemd-resolved[247]: Using system hostname 'omapl138-lcdk'. Oct 23 11:13:13 omapl138-lcdk user.info kernel: serial8250.1: ttyS1 at MMIO 0x1d0c000 (irq = 53, base_baud = 14250000) is a TI DA8xx/66AK2x Oct 23 11:13:26 omapl138-lcdk daemon.info rng-tools[257]: Starting random number generator daemon. Oct 23 11:13:25 omapl138-lcdk daemon.info systemd[1]: Started Network Name Resolution. Oct 23 11:13:13 omapl138-lcdk user.info kernel: brd: module loaded Oct 23 11:13:26 omapl138-lcdk daemon.info bash[234]: No 'Factory Calibration' file - using DEFAULT Oct 23 11:13:26 omapl138-lcdk daemon.info systemd[1]: Started Lightning Fast Webserver With Light System Requirements. Oct 23 11:13:13 omapl138-lcdk user.info kernel: libphy: Fixed MDIO Bus: probed Oct 23 11:13:26 omapl138-lcdk daemon.info ipsec[238]: Starting strongSwan 5.5.0 IPsec [starter]... Oct 23 11:13:26 omapl138-lcdk daemon.info systemd[1]: Started Run Coda Octopus startup scripts. Oct 23 11:13:26 omapl138-lcdk daemon.info bash[234]: No 'Kalman Filter Calibration Data' file - using DEFAULT Oct 23 11:13:13 omapl138-lcdk user.info kernel: davinci_mdio davinci_mdio.0: davinci mdio revision 1.5 Oct 23 11:13:26 omapl138-lcdk daemon.info systemd[1]: Started Permit User Sessions. Oct 23 11:13:13 omapl138-lcdk user.info kernel: davinci_mdio davinci_mdio.0: detected phy mask fffffffd Oct 23 11:13:26 omapl138-lcdk daemon.info systemd[1]: Started rng-tools.service. Oct 23 11:13:13 omapl138-lcdk user.info kernel: libphy: davinci_mdio.0: probed Oct 23 11:13:13 omapl138-lcdk user.info kernel: davinci_mdio davinci_mdio.0: phy[1]: device davinci_mdio.0:01, driver NatSemi DP83640 Oct 23 11:13:27 omapl138-lcdk daemon.info ipsec[238]: no netkey IPsec stack detected Oct 23 11:13:13 omapl138-lcdk user.info kernel: i2c /dev entries driver Oct 23 11:13:13 omapl138-lcdk user.debug kernel: davinci_mmc da830-mmc.0: GPIO lookup for consumer cd Oct 23 11:13:13 omapl138-lcdk user.debug kernel: davinci_mmc da830-mmc.0: using device tree for GPIO lookup Oct 23 11:13:13 omapl138-lcdk user.debug kernel: of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/soc@1c00000/mmc@40000[0]' - status (0) Oct 23 11:13:13 omapl138-lcdk user.info kernel: davinci_mmc da830-mmc.0: Got CD GPIO Oct 23 11:13:13 omapl138-lcdk user.debug kernel: davinci_mmc da830-mmc.0: GPIO lookup for consumer wp Oct 23 11:13:13 omapl138-lcdk user.debug kernel: davinci_mmc da830-mmc.0: using device tree for GPIO lookup Oct 23 11:13:13 omapl138-lcdk user.debug kernel: of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/soc@1c00000/mmc@40000[0]' Oct 23 11:13:13 omapl138-lcdk user.debug kernel: of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/soc@1c00000/mmc@40000[0]' Oct 23 11:13:28 omapl138-lcdk daemon.info ipsec[238]: no KLIPS IPsec stack detected Oct 23 11:13:28 omapl138-lcdk daemon.info ipsec[238]: no known IPsec stack detected, ignoring! Oct 23 11:13:13 omapl138-lcdk user.debug kernel: davinci_mmc da830-mmc.0: using lookup tables for GPIO lookup Oct 23 11:13:13 omapl138-lcdk user.debug kernel: davinci_mmc da830-mmc.0: lookup for GPIO wp failed Oct 23 11:13:13 omapl138-lcdk user.info kernel: davinci_mmc da830-mmc.0: Using DMA, 4-bit mode Oct 23 11:13:13 omapl138-lcdk user.info kernel: NET: Registered protocol family 10 Oct 23 11:13:13 omapl138-lcdk user.info kernel: sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver Oct 23 11:13:13 omapl138-lcdk user.info kernel: NET: Registered protocol family 17 Oct 23 11:13:13 omapl138-lcdk user.info kernel: console [netcon0] enabled Oct 23 11:13:13 omapl138-lcdk user.info kernel: netconsole: network logging started Oct 23 11:13:13 omapl138-lcdk user.err kernel: davinci_emac davinci_emac.1: incompatible machine/device type for reading mac address Oct 23 11:13:13 omapl138-lcdk user.info kernel: hctosys: unable to open rtc device (rtc0) Oct 23 11:13:13 omapl138-lcdk user.err kernel: Warning: unable to open an initial console. Oct 23 11:13:13 omapl138-lcdk user.info kernel: Waiting for root device PARTUUID=a8d05222-02... Oct 23 11:13:13 omapl138-lcdk user.warn kernel: mmc0: host does not support reading read-only switch, assuming write-enable Oct 23 11:13:13 omapl138-lcdk user.info kernel: mmc0: new high speed SDHC card at address 0007 Oct 23 11:13:13 omapl138-lcdk user.info kernel: mmcblk0: mmc0:0007 SD32G 29.0 GiB Oct 23 11:13:13 omapl138-lcdk user.info kernel: mmcblk0: p1 p2 p3 Oct 23 11:13:13 omapl138-lcdk user.notice kernel: random: fast init done Oct 23 11:13:13 omapl138-lcdk user.info kernel: EXT4-fs (mmcblk0p2): recovery complete Oct 23 11:13:13 omapl138-lcdk user.info kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) Oct 23 11:13:13 omapl138-lcdk user.info kernel: VFS: Mounted root (ext4 filesystem) on device 179:2. Oct 23 11:13:13 omapl138-lcdk user.info kernel: devtmpfs: mounted Oct 23 11:13:13 omapl138-lcdk user.info kernel: Freeing unused kernel memory: 228K (c05e7000 - c0620000) Oct 23 11:13:13 omapl138-lcdk user.warn kernel: This architecture does not have kernel memory protection. Oct 23 11:13:13 omapl138-lcdk daemon.info kernel: systemd[1]: System time before build time, advancing clock. Oct 23 11:13:13 omapl138-lcdk daemon.info kernel: systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN) Oct 23 11:13:13 omapl138-lcdk daemon.info kernel: systemd[1]: Detected architecture arm. Oct 23 11:13:13 omapl138-lcdk daemon.info kernel: systemd[1]: Set hostname to <omapl138-lcdk>. Oct 23 11:13:13 omapl138-lcdk daemon.warn kernel: systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked executable. Please remove executable permission bits. Proceeding anyway. Oct 23 11:13:13 omapl138-lcdk daemon.warn kernel: systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway. Oct 23 11:13:13 omapl138-lcdk daemon.warn kernel: systemd[1]: Configuration file /etc/systemd/system/sync-clocks.service is marked executable. Please remove executable permission bits. Proceeding anyway. Oct 23 11:13:13 omapl138-lcdk daemon.warn kernel: systemd[1]: Configuration file /etc/systemd/system/sync-clocks.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway. Oct 23 11:13:31 omapl138-lcdk daemon.info syslog-ng[199]: [2020-10-23T11:13:31.204192] Using /dev/log Unix socket with systemd is not possible. Changing to systemd-syslog source, which supports socket activation.; Oct 23 11:13:13 omapl138-lcdk daemon.warn kernel: systemd[1]: Configuration file /etc/systemd/system/systemd-hostnamed.service is marked executable. Please remove executable permission bits. Proceeding anyway. Oct 23 11:13:13 omapl138-lcdk daemon.warn kernel: systemd[1]: Configuration file /etc/systemd/system/systemd-hostnamed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway. Oct 23 11:13:13 omapl138-lcdk daemon.err kernel: systemd[1]: serial-getty@ttyS2.service: Service lacks both ExecStart= and ExecStop= setting. Refusing. Oct 23 11:13:13 omapl138-lcdk user.warn kernel: cryptodev: loading out-of-tree module taints kernel. Oct 23 11:13:13 omapl138-lcdk user.info kernel: cryptodev: driver 1.8 loaded. Oct 23 11:13:13 omapl138-lcdk user.info kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Oct 23 11:13:13 omapl138-lcdk syslog.info kernel: systemd-journald[67]: Received request to flush runtime journal from PID 1 Oct 23 11:13:13 omapl138-lcdk user.info kernel: davinci-rproc davinci-rproc.0: assigned reserved memory node dsp_cma@c3000000 Oct 23 11:13:13 omapl138-lcdk user.info kernel: remoteproc remoteproc0: dsp is available Oct 23 11:13:13 omapl138-lcdk user.info kernel: remoteproc remoteproc0: powering up dsp Oct 23 11:13:13 omapl138-lcdk user.info kernel: remoteproc remoteproc0: Booting fw image rproc-dsp-fw, size 6056580 Oct 23 11:13:13 omapl138-lcdk user.info kernel: davinci-wdt davinci-wdt: heartbeat 60 sec Oct 23 11:13:13 omapl138-lcdk user.info kernel: remoteproc remoteproc0: registered virtio0 (type 7) Oct 23 11:13:13 omapl138-lcdk user.info kernel: remoteproc remoteproc0: remote processor dsp is now up Oct 23 11:13:14 omapl138-lcdk user.notice root: udev/mount.sh [/dev/ram0] is blacklisted, ignoring Oct 23 11:13:16 omapl138-lcdk daemon.notice dbus[179]: [system] Successfully activated service 'org.freedesktop.systemd1' Oct 23 11:13:19 omapl138-lcdk user.warn kernel: davinci_mdio davinci_mdio.0: resetting idled controller Oct 23 11:13:19 omapl138-lcdk user.info kernel: NatSemi DP83640 davinci_mdio.0:01: attached PHY driver [NatSemi DP83640] (mii_bus:phy_addr=davinci_mdio.0:01, irq=-1) Oct 23 11:13:21 omapl138-lcdk user.info kernel: EXT4-fs (mmcblk0p3): mounting ext3 file system using the ext4 subsystem Oct 23 11:13:21 omapl138-lcdk user.info kernel: davinci_emac davinci_emac.1 eth0: Link is Up - 100Mbps/Full - flow control rx/tx Oct 23 11:13:23 omapl138-lcdk user.warn kernel: FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. Oct 23 11:13:23 omapl138-lcdk user.notice root: mount.sh/automount Auto-mount of [/run/media/mmcblk0p1] successful Oct 23 11:13:24 omapl138-lcdk local0.err snmpd[253]: pcilib: Cannot find any working access method. Oct 23 11:13:24 omapl138-lcdk local0.err snmpd[253]: pcilib: pci_init failed Oct 23 11:13:33 omapl138-lcdk syslog.info syslogd exiting Oct 23 11:13:33 omapl138-lcdk syslog-ng[199]: syslog-ng starting up; version='3.5.4.1' Oct 23 11:13:25 omapl138-lcdk kernel: virtio_rpmsg_bus virtio0: rpmsg host is online Oct 23 11:13:25 omapl138-lcdk kernel: virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d Oct 23 11:13:25 omapl138-lcdk kernel: virtio_rpmsg_bus virtio0: msg received with no recipient Oct 23 11:13:25 omapl138-lcdk kernel: NET: Registered protocol family 43 Oct 23 11:13:25 omapl138-lcdk kernel: random: crng init done Oct 23 11:13:30 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): warning: mounting fs with errors, running e2fsck is recommended Oct 23 11:13:30 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): recovery complete Oct 23 11:13:30 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null) Oct 23 11:13:30 omapl138-lcdk root: mount.sh/automount Auto-mount of [/run/media/mmcblk0p3] successful Oct 23 11:13:35 omapl138-lcdk snmpd[253]: NET-SNMP version 5.7.3 Oct 23 11:13:38 omapl138-lcdk kernel: davinci_nand: probe of 60000000.nand failed with error -2 Oct 23 11:13:38 omapl138-lcdk kernel: nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xcc Oct 23 11:13:38 omapl138-lcdk kernel: nand: Micron MT29F4G16ABADAH4 Oct 23 11:13:38 omapl138-lcdk kernel: nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64 Oct 23 11:13:38 omapl138-lcdk kernel: Bad block table not found for chip 0 Oct 23 11:13:38 omapl138-lcdk kernel: Bad block table not found for chip 0 Oct 23 11:13:38 omapl138-lcdk kernel: Scanning device for bad blocks Oct 23 11:13:42 omapl138-lcdk kernel: Bad block table written to 0x00001ffe0000, version 0x01 Oct 23 11:13:42 omapl138-lcdk kernel: Bad block table written to 0x00001ffc0000, version 0x01 Oct 23 11:13:42 omapl138-lcdk kernel: 5 ofpart partitions found on MTD device davinci-nand.0 Oct 23 11:13:42 omapl138-lcdk kernel: Creating 5 MTD partitions on "davinci-nand.0": Oct 23 11:13:42 omapl138-lcdk kernel: 0x000000000000-0x000000020000 : "u-boot env" Oct 23 11:13:42 omapl138-lcdk kernel: 0x000000020000-0x0000000a0000 : "u-boot" Oct 23 11:13:42 omapl138-lcdk kernel: 0x0000000a0000-0x0000000c0000 : "FPGA FW Settings" Oct 23 11:13:42 omapl138-lcdk kernel: 0x0000000c0000-0x0000002c0000 : "FPGA FW" Oct 23 11:13:42 omapl138-lcdk kernel: 0x0000002c0000-0x000020000000 : "free space" Oct 23 11:13:42 omapl138-lcdk kernel: davinci_nand davinci-nand.0: controller rev. 2.5 Oct 23 11:13:54 omapl138-lcdk kdump: Kdump isn't supported on the running kernel,please check boot option!!! Apr 1 14:27:24 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): error count since last fsck: 6 Apr 1 14:27:24 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): initial error at time 1616143513: ext4_free_branches:1005: inode 1315 Apr 1 14:27:24 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): last error at time 1616272532: ext4_clear_blocks:841: inode 1392 Apr 1 15:33:10 omapl138-lcdk kernel: TCP: request_sock_TCP: Possible SYN flooding on port 9001. Sending cookies. Check SNMP counters. Apr 2 14:28:36 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): error count since last fsck: 6 Apr 2 14:28:36 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): initial error at time 1616143513: ext4_free_branches:1005: inode 1315 Apr 2 14:28:36 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): last error at time 1616272532: ext4_clear_blocks:841: inode 1392 Apr 3 14:30:24 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): error count since last fsck: 6 Apr 3 14:30:24 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): initial error at time 1616143513: ext4_free_branches:1005: inode 1315 Apr 3 14:30:24 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): last error at time 1616272532: ext4_clear_blocks:841: inode 1392 Apr 4 14:32:11 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): error count since last fsck: 6 Apr 4 14:32:11 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): initial error at time 1616143513: ext4_free_branches:1005: inode 1315 Apr 4 14:32:11 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): last error at time 1616272532: ext4_clear_blocks:841: inode 1392 Apr 5 14:33:59 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): error count since last fsck: 6 Apr 5 14:33:59 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): initial error at time 1616143513: ext4_free_branches:1005: inode 1315 Apr 5 14:33:59 omapl138-lcdk kernel: EXT4-fs (mmcblk0p3): last error at time 1616272532: ext4_clear_blocks:841: inode 1392
