Part Number: AM5748
We are using 2GB DDR3 in our board and we are trying to enable ECC in EMIF 1 for DDR3 from the excel sheet configs we are programming as below w
.emif_ecc_ctrl_reg = 0xC0000001,
.emif_ecc_address_range_1 = 0xFFFF0000,
.emif_ecc_address_range_2 = 0x00000000,
The board was not comming up, then we reduced the address range to 0x3FFF0000 then the board started crashing and we are not able to use. The crash log is attached.
Then we found the post in e2e
DRA762-GP ES1.0 ABZ package
Trying to boot from SPI
NG-WCP U-Boot Version 1 .0.0 (Apr 07 2021 - 17:33:06 +0530)
CPU : DRA762-GP ES1.0 ABZ package
Model: TI AM5748 IDK
Board: NG-WCP CBB Revision 1
DRAM: 2 GiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1, OMAP SD/MMC: 2
Net: eth0: ethernet@48484000
Hit any key to stop autoboot: 0
Trying to boot Linux from eMMC Partition 1 ...
switch to partitions #0, OK
mmc2(part 0) is current device
SD/MMC found on device 2
3310080 bytes read in 220 ms (14.3 MiB/s)
99524 bytes read in 12 ms (7.9 MiB/s)
Loading Device Tree to 8ffe4000, end 8ffff4c3 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.40-g4796173fc5 (deepak@Deepak-PC) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #3 SMP PREEMPT Mon Feb 8 14:53:19 IST 2021
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM5748 IDK
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000fd400000
[ 0.000000] OMAP4: Map 0x00000000fed00000 to fe600000 for dram barrier
[ 0.000000] DRA762 ES1.0
[ 0.000000] percpu: Embedded 15 pages/cpu @eed58000 s31308 r8192 d21940 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 468544
[ 0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=d76c4e6d-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1661580K/1881088K available (8192K kernel code, 237K rwdata, 1692K rodata, 2048K init, 277K bss, 31092K reserved, 188416K cma-reserved, 1266688K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB)
[ 0.000000] .init : 0xc0c00000 - 0xc0e00000 (2048 kB)
[ 0.000000] .data : 0xc0e00000 - 0xc0e3b7f0 ( 238 kB)
[ 0.000000] .bss : 0xc0e3d000 - 0xc0e82634 ( 278 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000007] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000025] Switching to timer-based delay loop, resolution 162ns
[ 0.000513] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000526] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.001211] Console: colour dummy device 80x30
[ 0.001234] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[ 0.001245] This ensures that you still see kernel messages. Please
[ 0.001255] update your kernel commandline.
[ 0.001284] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.001306] pid_max: default: 32768 minimum: 301
[ 0.001470] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001489] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002283] CPU: Testing write buffer coherency: ok
[ 0.002599] CPU0: update cpu_capacity 1024
[ 0.002616] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.039797] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.059809] Hierarchical SRCU implementation.
[ 0.080086] EFI services will not be available.
[ 0.099894] smp: Bringing up secondary CPUs ...
[ 0.170312] CPU1: update cpu_capacity 1024
[ 0.170321] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.170454] smp: Brought up 1 node, 2 CPUs
[ 0.170478] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.170489] CPU: All CPU(s) started in HYP mode.
[ 0.170499] CPU: Virtualization extensions available.
[ 0.171236] devtmpfs: initialized
[ 0.198156] random: get_random_u32 called from bucket_table_alloc+0x108/0x230 with crng_init=0
[ 0.198470] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.198758] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.198781] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.204410] xor: measuring software checksum speed
[ 0.300257] arm4regs : 1349.200 MB/sec
[ 0.400374] 8regs : 1025.600 MB/sec
[ 0.500490] 32regs : 1025.200 MB/sec
[ 0.600611] neon : 1979.600 MB/sec
[ 0.600624] xor: using function: neon (1979.600 MB/sec)
[ 0.600643] pinctrl core: initialized pinctrl subsystem
[ 0.601299] DMI not present or invalid.
[ 0.601649] NET: Registered protocol family 16
[ 0.603127] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.604256] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.838771] cpuidle: using governor ladder
[ 0.838819] cpuidle: using governor menu
[ 0.840854] ------------[ cut here ]------------
[ 0.840881] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[ 0.840896] 44000000.ocp:L3 Custom Error: MASTER TC1_EDMA TARGET DMM_P1 (Idle): Data Access in User mode during Functional access
[ 0.840907] Modules linked in:
[ 0.840930] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.14.40-g4796173fc5 #3
[ 0.840942] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.840952] Backtrace:
[ 0.840978] [<c020b5ac>] (dump_backtrace) from [<c020b890>] (show_stack+0x18/0x1c)
[ 0.840994] r7:00000009 r6:60000193 r5:00000000 r4:c0e38f68
[ 0.841014] [<c020b878>] (show_stack) from [<c07f4c28>] (dump_stack+0x90/0xa4)
[ 0.841037] [<c07f4b98>] (dump_stack) from [<c022aaa0>] (__warn+0xec/0x104)
[ 0.841052] r7:00000009 r6:c0b49040 r5:00000000 r4:ee87f980
[ 0.841073] [<c022a9b4>] (__warn) from [<c022aaf8>] (warn_slowpath_fmt+0x40/0x48)
[ 0.841089] r9:00000001 r8:ee9d0a50 r7:c0b493f0 r6:00000000 r5:c0b48f6c r4:c0b49010
[ 0.841109] [<c022aabc>] (warn_slowpath_fmt) from [<c05991f4>] (l3_interrupt_handler+0x254/0x370)
[ 0.841122] r3:ee9d08c0 r2:c0b49010
[ 0.841133] r4:80080003
[ 0.841152] [<c0598fa0>] (l3_interrupt_handler) from [<c027e870>] (__handle_irq_event_percpu+0x6c/0x134)
[ 0.841168] r10:c0e3a051 r9:ee9d2200 r8:00000017 r7:ee87faa4 r6:00000000 r5:ee9d2200
[ 0.841179] r4:ee9d0dc0
[ 0.841196] [<c027e804>] (__handle_irq_event_percpu) from [<c027e95c>] (handle_irq_event_percpu+0x24/0x60)
[ 0.841213] r10:60000013 r9:ee87e000 r8:ee808000 r7:00000000 r6:c0e094ac r5:ee9d2200
[ 0.841223] r4:ee9d2200
[ 0.841240] [<c027e938>] (handle_irq_event_percpu) from [<c027e9d8>] (handle_irq_event+0x40/0x64)
[ 0.841252] r5:ee9d2264 r4:ee9d2200
[ 0.841270] [<c027e998>] (handle_irq_event) from [<c02822ac>] (handle_fasteoi_irq+0xac/0x160)
[ 0.841284] r7:00000000 r6:c0e094ac r5:ee9d2264 r4:ee9d2200
[ 0.841302] [<c0282200>] (handle_fasteoi_irq) from [<c027dac0>] (generic_handle_irq+0x2c/0x3c)
[ 0.841316] r7:00000000 r6:00000000 r5:00000017 r4:c0c56afc
[ 0.841332] [<c027da94>] (generic_handle_irq) from [<c027e048>] (__handle_domain_irq+0x64/0xbc)
[ 0.841348] [<c027dfe4>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[ 0.841364] r9:ee87e000 r8:fa213000 r7:fa212000 r6:ee87fb60 r5:fa21200c r4:c0e03ffc
[ 0.841380] [<c0201430>] (gic_handle_irq) from [<c020c478>] (__irq_svc+0x58/0x8c)
[ 0.841392] Exception stack(0xee87fb60 to 0xee87fba8)
[ 0.841408] fb60: ee9d2264 60000013 00000004 00000005 ee9d2200 ee9d0dc0 00000017 00000000
[ 0.841423] fb80: ee9d22cc ee9d2264 60000013 ee87fbbc ee87fbc0 ee87fbb0 c02809b4 c080d8c4
[ 0.841435] fba0: 60000013 ffffffff
[ 0.841449] r9:ee87e000 r8:ee9d22cc r7:ee87fb94 r6:ffffffff r5:60000013 r4:c080d8c4
[ 0.841468] [<c080d89c>] (_raw_spin_unlock_irqrestore) from [<c02809b4>] (__setup_irq+0x44c/0x70c)
[ 0.841487] [<c0280568>] (__setup_irq) from [<c0280de4>] (request_threaded_irq+0xe0/0x154)
[ 0.841503] r10:ee9d2214 r9:00000000 r8:00000017 r7:00000000 r6:ee9d2200 r5:00000000
[ 0.841513] r4:ee9d0dc0
[ 0.841532] [<c0280d04>] (request_threaded_irq) from [<c0283460>] (devm_request_threaded_irq+0x70/0xc4)
[ 0.841548] r10:00000000 r9:eea1ea10 r8:c0598fa0 r7:00000017 r6:ee9d0a50 r5:ee9d0d90
[ 0.841559] r4:c0b48ddc r3:00000000
[ 0.841578] [<c02833f0>] (devm_request_threaded_irq) from [<c05994ec>] (omap_l3_probe+0x1dc/0x278)
[ 0.841593] r10:00000002 r9:ee9d0a50 r8:eea1ea10 r7:c0e759ec r6:00000008 r5:ee9d0a50
[ 0.841603] r4:00000000
[ 0.841623] [<c0599310>] (omap_l3_probe) from [<c0618418>] (platform_drv_probe+0x58/0xb4)
[ 0.841638] r10:00000000 r9:00000000 r8:c0e232d4 r7:fffffdfb r6:c0e232d4 r5:ffffffed
[ 0.841649] r4:eea1ea10
[ 0.841667] [<c06183c0>] (platform_drv_probe) from [<c061695c>] (driver_probe_device+0x240/0x2f0)
[ 0.841681] r7:00000000 r6:c0e7998c r5:c0e79988 r4:eea1ea10
[ 0.841698] [<c061671c>] (driver_probe_device) from [<c0616b5c>] (__device_attach_driver+0xa0/0xd4)
[ 0.841713] r10:00000000 r9:00000000 r8:c0e79964 r7:00000001 r6:ee87fd40 r5:eea1ea10
[ 0.841725] r4:c0e232d4 r3:00000000
[ 0.841741] [<c0616abc>] (__device_attach_driver) from [<c0614d54>] (bus_for_each_drv+0x4c/0x9c)
[ 0.841755] r7:00000001 r6:c0616abc r5:ee87fd40 r4:00000000
[ 0.841771] [<c0614d08>] (bus_for_each_drv) from [<c06165f8>] (__device_attach+0xb8/0x11c)
[ 0.841784] r6:eea1ea10 r5:eea1ea44 r4:eea1ea10
[ 0.841801] [<c0616540>] (__device_attach) from [<c0616bdc>] (device_initial_probe+0x14/0x18)
[ 0.841814] r7:00000000 r6:eea1ea10 r5:c0e2bf20 r4:eea1ea18
[ 0.841830] [<c0616bc8>] (device_initial_probe) from [<c0615b54>] (bus_probe_device+0x8c/0x94)
[ 0.841847] [<c0615ac8>] (bus_probe_device) from [<c0613d58>] (device_add+0x39c/0x59c)
[ 0.841860] r7:00000000 r6:eea1ea10 r5:c0e2bd90 r4:eea1ea18
[ 0.841878] [<c06139bc>] (device_add) from [<c06c9020>] (of_device_add+0x38/0x40)
[ 0.841893] r10:00000001 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:eed7a360
[ 0.841903] r4:eea1ea00
[ 0.841921] [<c06c8fe8>] (of_device_add) from [<c06c9548>] (of_platform_device_create_pdata+0x7c/0xb4)
[ 0.841939] [<c06c94cc>] (of_platform_device_create_pdata) from [<c06c9744>] (of_platform_bus_create+0x168/0x1ec)
[ 0.841954] r9:00000000 r8:c0c44520 r7:00000000 r6:c0c44520 r5:00000000 r4:eed7a310
[ 0.841973] [<c06c95dc>] (of_platform_bus_create) from [<c06c9908>] (of_platform_populate+0x64/0xb4)
[ 0.841988] r10:c0e3d000 r9:00000001 r8:00000000 r7:c0c44520 r6:c0c46f8c r5:eed785b8
[ 0.841999] r4:eed7a310
[ 0.842018] [<c06c98a4>] (of_platform_populate) from [<c0c0eab0>] (pdata_quirks_init+0x74/0x88)
[ 0.842034] r9:00000082 r8:c0c40828 r7:c0e3d000 r6:c0c03834 r5:00000000 r4:c0c46f8c
[ 0.842051] [<c0c0ea3c>] (pdata_quirks_init) from [<c0c0ea30>] (omap_generic_init+0x18/0x24)
[ 0.842063] r5:00000000 r4:ffffe000
[ 0.842081] [<c0c0ea18>] (omap_generic_init) from [<c0c0385c>] (customize_machine+0x28/0x30)
[ 0.842098] [<c0c03834>] (customize_machine) from [<c02019fc>] (do_one_initcall+0x4c/0x170)
[ 0.842115] [<c02019b0>] (do_one_initcall) from [<c0c00f80>] (kernel_init_freeable+0x1d8/0x274)
[ 0.842130] r8:c0c40828 r7:c0e3d000 r6:00000004 r5:c0c4f888 r4:c0ba6378
[ 0.842149] [<c0c00da8>] (kernel_init_freeable) from [<c0807ca0>] (kernel_init+0x10/0x110)
[ 0.842164] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0807c90
[ 0.842174] r4:00000000
[ 0.842194] [<c0807c90>] (kernel_init) from [<c0207d58>] (ret_from_fork+0x14/0x3c)
[ 0.842206] r5:c0807c90 r4:00000000
[ 0.842222] ---[ end trace bb73aa8d472dbd3c ]---
[ 0.851464] OMAP GPIO hardware version 0.1
[ 0.880156] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 0.880638] gpmc cs3 before gpmc_cs_program_settings:
[ 0.880653] cs3 GPMC_CS_CONFIG1: 0x00001000
[ 0.880666] cs3 GPMC_CS_CONFIG2: 0x00101001
[ 0.880678] cs3 GPMC_CS_CONFIG3: 0x22060514
[ 0.880690] cs3 GPMC_CS_CONFIG4: 0x10057016
[ 0.880701] cs3 GPMC_CS_CONFIG5: 0x010f1111
[ 0.880712] cs3 GPMC_CS_CONFIG6: 0x8f070000
[ 0.880722] gpmc cs3 access configuration:
[ 0.880733] gpmc,mux-add-data = <0>;
[ 0.880744] gpmc,device-width = <2>;
[ 0.880755] gpmc,wait-pin = <0>;
[ 0.880766] gpmc,burst-length = <4>;
[ 0.880779] gpmc cs3 timings configuration:
[ 0.880794] gpmc,cs-on-ns = <3>; /* 1 ns - 3 ns; 1 ticks */
[ 0.880807] gpmc,cs-rd-off-ns = <60>; /* 57 ns - 60 ns; 16 ticks */
[ 0.880820] gpmc,cs-wr-off-ns = <60>; /* 57 ns - 60 ns; 16 ticks */
[ 0.880834] gpmc,adv-on-ns = <15>; /* 12 ns - 15 ns; 4 ticks */
[ 0.880847] gpmc,adv-rd-off-ns = <18>; /* 16 ns - 18 ns; 5 ticks */
[ 0.880860] gpmc,adv-wr-off-ns = <22>; /* 19 ns - 22 ns; 6 ticks */
[ 0.880873] gpmc,adv-aad-mux-on-ns = <3>; /* 1 ns - 3 ns; 1 ticks */
[ 0.880886] gpmc,adv-aad-mux-rd-off-ns = <7>; /* 4 ns - 7 ns; 2 ticks */
[ 0.880900] gpmc,adv-aad-mux-wr-off-ns = <7>; /* 4 ns - 7 ns; 2 ticks */
[ 0.880912] gpmc,oe-on-ns = <22>; /* 19 ns - 22 ns; 6 ticks */
[ 0.880925] gpmc,oe-off-ns = <60>; /* 57 ns - 60 ns; 16 ticks */
[ 0.880937] gpmc,oe-aad-mux-on-ns = <3>; /* 1 ns - 3 ns; 1 ticks */
[ 0.880949] gpmc,oe-aad-mux-off-ns = <11>; /* 8 ns - 11 ns; 3 ticks */
[ 0.880963] gpmc,we-on-ns = <18>; /* 16 ns - 18 ns; 5 ticks */
[ 0.880977] gpmc,we-off-ns = <60>; /* 57 ns - 60 ns; 16 ticks */
[ 0.880989] gpmc,rd-cycle-ns = <63>; /* 61 ns - 63 ns; 17 ticks */
[ 0.881002] gpmc,wr-cycle-ns = <63>; /* 61 ns - 63 ns; 17 ticks */
[ 0.881015] gpmc,access-ns = <56>; /* 53 ns - 56 ns; 15 ticks */
[ 0.881028] gpmc,page-burst-access-ns = <3>; /* 1 ns - 3 ns; 1 ticks */
[ 0.881041] gpmc,bus-turnaround-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881053] gpmc,cycle2cycle-delay-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881065] gpmc,wait-monitoring-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881077] gpmc,clk-activation-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881090] gpmc,wr-data-mux-bus-ns = <26>; /* 23 ns - 26 ns; 7 ticks */
[ 0.881103] gpmc,wr-access-ns = <56>; /* 53 ns - 56 ns; 15 ticks */
[ 0.881119] GPMC CS3: cs_on : 0 ticks, 0 ns (was 1 ticks) 0 ns
[ 0.881135] GPMC CS3: cs_rd_off : 19 ticks, 71 ns (was 16 ticks) 70 ns
[ 0.881149] GPMC CS3: cs_wr_off : 20 ticks, 75 ns (was 16 ticks) 75 ns
[ 0.881163] GPMC CS3: adv_on : 0 ticks, 0 ns (was 4 ticks) 0 ns
[ 0.881176] GPMC CS3: adv_rd_off : 10 ticks, 37 ns (was 5 ticks) 35 ns
[ 0.881189] GPMC CS3: adv_wr_off : 10 ticks, 37 ns (was 6 ticks) 35 ns
[ 0.881201] GPMC CS3: adv_aad_mux_on : 0 ticks, 0 ns (was 1 ticks) 0 ns
[ 0.881215] GPMC CS3: adv_aad_mux_rd_off: 0 ticks, 0 ns (was 2 ticks) 0 ns
[ 0.881227] GPMC CS3: adv_aad_mux_wr_off: 0 ticks, 0 ns (was 2 ticks) 0 ns
[ 0.881239] GPMC CS3: oe_on : 0 ticks, 0 ns (was 6 ticks) 0 ns
[ 0.881252] GPMC CS3: oe_off : 19 ticks, 71 ns (was 16 ticks) 70 ns
[ 0.881264] GPMC CS3: oe_aad_mux_on : 0 ticks, 0 ns (was 1 ticks) 0 ns
[ 0.881276] GPMC CS3: oe_aad_mux_off : 0 ticks, 0 ns (was 3 ticks) 0 ns
[ 0.881288] GPMC CS3: we_on : 0 ticks, 0 ns (was 5 ticks) 0 ns
[ 0.881300] GPMC CS3: we_off : 20 ticks, 75 ns (was 16 ticks) 75 ns
[ 0.881313] GPMC CS3: rd_cycle : 19 ticks, 71 ns (was 17 ticks) 70 ns
[ 0.881326] GPMC CS3: wr_cycle : 20 ticks, 75 ns (was 17 ticks) 75 ns
[ 0.881338] GPMC CS3: access : 19 ticks, 71 ns (was 15 ticks) 70 ns
[ 0.881351] GPMC CS3: page_burst_access: 6 ticks, 22 ns (was 1 ticks) 20 ns
[ 0.881363] GPMC CS3: bus_turnaround : 0 ticks, 0 ns (was 0 ticks) 0 ns
[ 0.881374] GPMC CS3: cycle2cycle_delay: 0 ticks, 0 ns (was 0 ticks) 0 ns
[ 0.881387] GPMC CS3: wr_data_mux_bus : 0 ticks, 0 ns (was 7 ticks) 0 ns
[ 0.881399] GPMC CS3: wr_access : 0 ticks, 0 ns (was 15 ticks) 0 ns
[ 0.881412] GPMC CS3: wait_monitoring : 0 ticks, 0 ns (was 0 ticks) 0 ns
[ 0.881423] GPMC CS3: clk_activation : 0 ticks, 0 ns (was 0 ticks) 0 ns
[ 0.881434] GPMC CS3 CLK period is 3 ns (div 1)
[ 0.881446] gpmc cs3 after gpmc_cs_set_timings:
[ 0.881458] cs3 GPMC_CS_CONFIG1: 0x00000002
[ 0.881469] cs3 GPMC_CS_CONFIG2: 0x00141300
[ 0.881479] cs3 GPMC_CS_CONFIG3: 0x000a0a00
[ 0.881489] cs3 GPMC_CS_CONFIG4: 0x14001300
[ 0.881499] cs3 GPMC_CS_CONFIG5: 0x06131413
[ 0.881510] cs3 GPMC_CS_CONFIG6: 0x80000000
[ 0.881519] gpmc cs3 access configuration:
[ 0.881530] gpmc,mux-add-data = <0>;
[ 0.881540] gpmc,device-width = <1>;
[ 0.881550] gpmc,wait-pin = <0>;
[ 0.881561] gpmc,burst-length = <4>;
[ 0.881574] gpmc cs3 timings configuration:
[ 0.881586] gpmc,cs-on-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881600] gpmc,cs-rd-off-ns = <71>; /* 68 ns - 71 ns; 19 ticks */
[ 0.881612] gpmc,cs-wr-off-ns = <75>; /* 72 ns - 75 ns; 20 ticks */
[ 0.881625] gpmc,adv-on-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881639] gpmc,adv-rd-off-ns = <37>; /* 34 ns - 37 ns; 10 ticks */
[ 0.881651] gpmc,adv-wr-off-ns = <37>; /* 34 ns - 37 ns; 10 ticks */
[ 0.881663] gpmc,adv-aad-mux-on-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881675] gpmc,adv-aad-mux-rd-off-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881687] gpmc,adv-aad-mux-wr-off-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881699] gpmc,oe-on-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881712] gpmc,oe-off-ns = <71>; /* 68 ns - 71 ns; 19 ticks */
[ 0.881724] gpmc,oe-aad-mux-on-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881736] gpmc,oe-aad-mux-off-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881748] gpmc,we-on-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881761] gpmc,we-off-ns = <75>; /* 72 ns - 75 ns; 20 ticks */
[ 0.881774] gpmc,rd-cycle-ns = <71>; /* 68 ns - 71 ns; 19 ticks */
[ 0.881786] gpmc,wr-cycle-ns = <75>; /* 72 ns - 75 ns; 20 ticks */
[ 0.881799] gpmc,access-ns = <71>; /* 68 ns - 71 ns; 19 ticks */
[ 0.881811] gpmc,page-burst-access-ns = <22>; /* 19 ns - 22 ns; 6 ticks */
[ 0.881823] gpmc,bus-turnaround-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881835] gpmc,cycle2cycle-delay-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881847] gpmc,wait-monitoring-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881859] gpmc,clk-activation-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881871] gpmc,wr-data-mux-bus-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.881883] gpmc,wr-access-ns = <0>; /* 0 ns - 0 ns; 0 ticks */
[ 0.893605] No ATAGs?
[ 0.893704] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.893725] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.894256] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.894272] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.894995] OMAP DMA hardware revision 0.0
[ 1.063084] raid6: int32x1 gen() 150 MB/s
[ 1.233140] raid6: int32x1 xor() 173 MB/s
[ 1.403401] raid6: int32x2 gen() 221 MB/s
[ 1.573448] raid6: int32x2 xor() 220 MB/s
[ 1.743604] raid6: int32x4 gen() 283 MB/s
[ 1.913720] raid6: int32x4 xor() 231 MB/s
[ 2.083960] raid6: int32x8 gen() 307 MB/s
[ 2.254141] raid6: int32x8 xor() 215 MB/s
[ 2.424318] raid6: neonx1 gen() 625 MB/s
[ 2.594429] raid6: neonx1 xor() 666 MB/s
[ 2.764607] raid6: neonx2 gen() 884 MB/s
[ 2.934758] raid6: neonx2 xor() 1122 MB/s
[ 3.104930] raid6: neonx4 gen() 1279 MB/s
[ 3.275111] raid6: neonx4 xor() 1184 MB/s
[ 3.445303] raid6: neonx8 gen() 1140 MB/s
[ 3.615453] raid6: neonx8 xor() 982 MB/s
[ 3.615464] raid6: using algorithm neonx4 gen() 1279 MB/s
[ 3.615476] raid6: .... xor() 1184 MB/s, rmw enabled
[ 3.615487] raid6: using neon recovery algorithm
[ 3.619723] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 3.620018] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 3.620378] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 3.620721] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 3.621233] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 3.621543] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 3.621883] iommu: Adding device 58820000.ipu to group 1
[ 3.621997] iommu: Adding device 55020000.ipu to group 2
[ 3.622202] iommu: Adding device 40800000.dsp to group 0
[ 3.622553] iommu: Adding device 41000000.dsp to group 3
[ 3.623903] palmas 0-0058: Irq flag is 0x00000004
[ 3.655038] palmas 0-0058: Muxing GPIO 2b, PWM 0, LED 0
[ 3.656988] SMPS12: supplied by regulator-dummy
[ 3.658971] SMPS3: supplied by VMAIN
[ 3.660761] SMPS45: supplied by regulator-dummy
[ 3.662850] SMPS6: supplied by VMAIN
[ 3.664841] SMPS7: supplied by VMAIN
[ 3.666929] SMPS8: supplied by VMAIN
[ 3.668427] SMPS9: supplied by VMAIN
[ 3.669593] LDO1: supplied by VMAIN
[ 3.684094] LDO2: supplied by VMAIN
[ 3.684516] random: fast init done
[ 3.693936] LDO3: supplied by VMAIN
[ 3.703957] LDO4: supplied by VMAIN
[ 3.713959] LDO5: supplied by regulator-dummy
[ 3.714805] LDO6: supplied by regulator-dummy
[ 3.715665] LDO7: supplied by regulator-dummy
[ 3.716514] LDO8: supplied by regulator-dummy
[ 3.717382] LDO9: supplied by VMAIN
[ 3.734339] LDOLN: supplied by VMAIN
[ 3.744034] LDOUSB: supplied by VMAIN
[ 3.757164] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 3.757855] omap_i2c 48072000.i2c: bus 1 rev0.12 at 25 kHz
[ 3.758231] dmi: Firmware registration failed.
[ 3.758762] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 3.759160] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 3.760274] clocksource: Switched to clocksource arch_sys_counter
[ 3.770943] NET: Registered protocol family 2
[ 3.771630] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 3.771725] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.771914] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.772012] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.772060] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.772237] NET: Registered protocol family 1
[ 3.773269] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 3.773585] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 3.775032] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 3.783220] bounce: pool size: 64 pages
[ 3.783282] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 3.783430] io scheduler noop registered
[ 3.783445] io scheduler deadline registered
[ 3.783684] io scheduler cfq registered (default)
[ 3.783700] io scheduler mq-deadline registered
[ 3.783713] io scheduler kyber registered
[ 3.784672] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 3.788461] V3_3D: supplied by smps9
[ 3.788773] vtt_fixed: supplied by V3_3D
[ 3.850178] HDLC line discipline maxframe=4096
[ 3.850194] N_HDLC line discipline registered.
[ 3.850209] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 3.853760] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 45, base_baud = 3000000) is a 8250
[ 3.854822] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 46, base_baud = 3000000) is a 8250
[ 6.059394] console [ttyS2] enabled
[ 6.064025] 4806e000.serial: ttyS3 at MMIO 0x4806e000 (irq = 47, base_baud = 3000000) is a 8250
[ 6.073888] 48420000.serial: ttyS6 at MMIO 0x48420000 (irq = 48, base_baud = 3000000) is a 8250
[ 6.094756] brd: module loaded
[ 6.105952] loop: module loaded
[ 6.110301] spi spi1.0: not using DMA for McSPI (-19)
[ 6.115767] m25p80 spi1.0: unrecognized JEDEC id bytes: 00, 00, 00
[ 6.123096] ti-qspi 4b300000.qspi: No Rx DMA available, trying mmap mode
[ 6.131138] m25p80 spi0.0: s25fl256s1 (32768 Kbytes)
[ 6.136182] 4 ofpart partitions found on MTD device spi0.0
[ 6.141732] Creating 4 MTD partitions on "spi0.0":
[ 6.146555] 0x000000000000-0x000000040000 : "QSPI.MLO"
[ 6.153000] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[ 6.159571] 0x000000140000-0x000000150000 : "QSPI.u-boot-env"
[ 6.166506] 0x0000001d0000-0x0000001e0000 : "QSPI.Private-Space"
[ 6.174856] libphy: Fixed MDIO Bus: probed
[ 6.179370] tun: Universal TUN/TAP device driver, 1.6
[ 6.240321] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 6.248021] davinci_mdio 48485000.mdio: detected phy mask fffffffc
[ 6.279390] libphy: 48485000.mdio: probed
[ 6.283459] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver Micrel KSZ9031 Gigabit PHY
[ 6.293191] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[ 6.303708] cpsw 48484000.ethernet: Detected MACID = 90:9a:77:65:11:0c
[ 6.310370] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 6.316760] cpsw 48484000.ethernet: ALE Table size 1024
[ 6.322113] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 6.330348] cpsw 48484000.ethernet: cpsw: Detected MACID = 90:9a:77:65:11:0d
[ 6.338703] Driver for 1-wire Dallas network protocol.
[ 6.385272] w1_master_driver w1_bus_master1: Attaching one wire slave 10.000803a23473 crc 9d
[ 6.394803] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 6.402536] cpu cpu0: dev_pm_opp_set_regulators: no regulator (vdd) found: -19
[ 6.410398] sdhci: Secure Digital Host Controller Interface driver
[ 6.416610] sdhci: Copyright(c) Pierre Ossman
[ 6.421736] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.428865] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 6.434920] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[ 6.441608] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[ 6.500594] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[ 6.570329] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[ 6.580485] sdhci-omap 480ad000.mmc: no pinctrl state for ddr_1_8v mode
[ 6.587236] sdhci-omap 480ad000.mmc: no pinctrl state for hs mode
[ 6.593481] sdhci-omap 480ad000.mmc: no pinctrl state for hs mode
[ 6.599699] sdhci-omap 480ad000.mmc: no pinctrl state for hs200_1_8v mode
[ 6.612267] mmc0: host does not support reading read-only switch, assuming write-enable
[ 6.627015] mmc0: new high speed SDHC card at address aaaa
[ 6.633421] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[ 6.643133] mmcblk0: p1 p2
[ 6.660325] mmc2: SDHCI controller on 480ad000.mmc [480ad000.mmc] using PIO
[ 6.670890] NET: Registered protocol family 10
[ 6.688233] Segment Routing with IPv6
[ 6.692074] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 6.698669] NET: Registered protocol family 17
[ 6.703319] omap_voltage_late_init: Voltage driver support not added
[ 6.709706] Power Management for TI OMAP4+ devices.
[ 6.715342] Registering SWP/SWPB emulation handler
[ 6.721982] Btrfs loaded, crc32c=crc32c-generic
[ 6.737984] mmc2: new MMC card at address 0001
[ 6.743481] mmcblk2: mmc2:0001 IS004G 3.64 GiB
[ 6.746072] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 6.750354] hctosys: unable to open rtc device (rtc0)
[ 6.761216] mmcblk2boot0: mmc2:0001 IS004G partition 1 2.00 MiB
[ 6.767656] mmcblk2boot1: mmc2:0001 IS004G partition 2 2.00 MiB
[ 6.774136] mmcblk2rpmb: mmc2:0001 IS004G partition 3 512 KiB
[ 6.781623] mmcblk2: p1 p2 p3
[ 6.806433] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.814968] VFS: Mounted root (ext4 filesystem) on device 179:18.
[ 6.824776] devtmpfs: mounted
[ 6.836365] Freeing unused kernel memory: 2048K
[ 7.275477] systemd[1]: System time before build time, advancing clock.
[ 7.323325] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 7.344745] systemd[1]: Detected architecture arm.
Welcome to Arago 2018.04!
[ 7.381205] systemd[1]: Set hostname to <AirlinkWCP>.
[ 7.750057] systemd[1]: Configuration file /lib/systemd/system/sshpipe.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.764652] systemd[1]: Configuration file /lib/systemd/system/sshpipe.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.798585] systemd[1]: Configuration file /lib/systemd/system/docker.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.874754] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.881692] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 7.948764] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.955702] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 7.990428] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.997380] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 8.040724] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Listening on Syslog Socket.
[ OK ] Listening on Process Core Dump Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Remote File Systems.
[ OK ] Listening on Journal Socket.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Created slice System Slice.
Starting Journal Service...
Mounting Kernel Debug File System...
[ OK ] Created slice system-getty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting Load Kernel Modules...
[ OK ] Reached target Slices.
Starting Create list of required st��…ce nodes for the current kernel...
[ OK ] Reached target Swap.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Paths.
Mounting POSIX Message Queue File System...
Starting Remount Root and Kernel File Systems...
[ 8.706908] EXT4-fs (mmcblk2p2): re-mounted. Opts: (null)
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Started Journal Service.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Create list of required sta��…vice nodes for the current kernel.
[ OK ] Started Remount Root and Kernel File Systems.
Starting udev Coldplug all Devices...
Starting Load/Save Random Seed...
Starting Create Static Device Nodes in /dev...
Starting Apply Kernel Variables...
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Apply Kernel Variables.
[ 9.237056] systemd-journald[79]: Received request to flush runtime journal from PID 1
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /tmp...
[ OK ] Mounted /tmp.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ 10.015358] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
[ OK ] Started udev Coldplug all Devices.
[ 10.034411] remoteproc remoteproc0: 58820000.ipu is available
[ OK ] Reached target System Initialization.
[ 10.108165] remoteproc remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[ 10.136892] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
[ 10.137024] remoteproc remoteproc1: 55020000.ipu is available
[ 10.137423] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[ 10.137527] remoteproc remoteproc2: 40800000.dsp is available
[ 10.138134] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
[ 10.138244] remoteproc remoteproc3: 41000000.dsp is available
[ 10.413523] remoteproc remoteproc0: powering up 58820000.ipu
Starting Network Service...
[ OK ] Listening on D-Bus System Message Bus Socket.[ 10.425778] remoteproc remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[ 10.490515] ds1307 type ds3231
[ 10.521454] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 10.521464] omap-des 480a5000.des: Unable to request in DMA channel
[ 10.533683] omap-des 480a5000.des: will run requests pump with realtime priority
[ 10.552944] rtc-ds1307 1-0068: registered as rtc0
[ 10.567495] m25p80_fpga spi1.0: unrecognized JEDEC id bytes: 00, 00, 00
[ OK ] Started Daily rotation of log files.
[ 10.633025] remoteproc remoteproc0: request_firmware failed: -2
[ 10.644284] remoteproc remoteproc1: Direct firmware load for dra7-ipu2-fw.xem4 failed with error -2
[ OK ] Started Daily Cleanup of Temporary Directorie[ 10.706318] remoteproc remoteproc1: powering up 55020000.ipu
s.
[ OK ] Reached target Timers.
[ 10.732912] remoteproc remoteproc1: Direct firmware load for dra7-ipu2-fw.xem4 failed with error -2
[ OK ] Listening on RPCbind Server Activation Socket[ 10.869106] remoteproc remoteproc1: request_firmware failed: -2
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ 11.080047] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ OK ] Started SSH pipe to execute commands on serial terminal.
[ 11.185312] random: crng init done
[ 11.190853] random: 7 urandom warning(s) missed due to ratelimiting
Starting tiipclad-daemon.service...
[ 11.207763] remoteproc remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
[ 11.220989] remoteproc remoteproc3: powering up 41000000.dsp
[ 11.229693] remoteproc remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
[ 11.476018] remoteproc remoteproc3: request_firmware failed: -2
[ 11.487608] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 11.487617] omap-aes 4b500000.aes: Unable to request in DMA channel
[ 11.537162] omap-aes 4b500000.aes: will run requests pump with realtime priority
[ 11.545360] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 11.545369] omap-aes 4b700000.aes: Unable to request in DMA channel
[ 11.545782] omap-aes 4b700000.aes: will run requests pump with realtime priority
[ 11.605753] remoteproc remoteproc2: powering up 40800000.dsp
[ 11.605773] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 5226672
[ 11.613716] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 11.613774] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 11.613892] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 11.635335] remoteproc remoteproc2: unsupported resource -1728053248
[ 11.635346] remoteproc remoteproc2: unsupported resource -1728036864
[ OK ] Reached target Containers.
Starting telnetd.service...
[ OK ] Started Kernel Logging Service.
[ OK ] Started D-Bus System Message Bus.
[ 12.062933] remoteproc remoteproc2: unsupported resource -1728053248
[ 12.186880] remoteproc remoteproc2: unsupported resource -1728036864
[ 12.336402] ------------[ cut here ]------------
[ 12.341080] WARNING: CPU: 0 PID: 372 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[ 12.350439] 44000000.ocp:L3 Custom Error: MASTER DSP1_MDMA TARGET DMM_P1 (Idle): Data Access in User mode during Functional access
[ 12.362237] Modules linked in: omap_aes_driver omap_sham pruss_soc_bus m25p80_fpga omap_des des_generic rtc_ds1307 crypto_engine omap_crypto omap_remoteproc virtio_rpmsg_bus rpmsg_core remoteproc sch_fl
[ 12.380965] CPU: 0 PID: 372 Comm: mount.sh Tainted: G W 4.14.40-g4796173fc5 #3
[ 12.389362] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 12.395489] Backtrace:
[ 12.397975] [<c020b5ac>] (dump_backtrace) from [<c020b890>] (show_stack+0x18/0x1c)
[ 12.405592] r7:00000009 r6:600b0193 r5:00000000 r4:c0e38f68
[ 12.411302] [<c020b878>] (show_stack) from [<c07f4c28>] (dump_stack+0x90/0xa4)
[ 12.418580] [<c07f4b98>] (dump_stack) from [<c022aaa0>] (__warn+0xec/0x104)
[ 12.425580] r7:00000009 r6:c0b49040 r5:00000000 r4:ed003b18
[ 12.431289] [<c022a9b4>] (__warn) from [<c022aaf8>] (warn_slowpath_fmt+0x40/0x48)
[ 12.438824] r9:00000001 r8:ee9d0a50 r7:c0b49334 r6:00000000 r5:c0b48f6c r4:c0b49010
[ 12.446623] [<c022aabc>] (warn_slowpath_fmt) from [<c05991f4>] (l3_interrupt_handler+0x254/0x370)
[ 12.455544] r3:ee9d08c0 r2:c0b49010
[ 12.459148] r4:80080003
[ 12.461715] [<c0598fa0>] (l3_interrupt_handler) from [<c027e870>] (__handle_irq_event_percpu+0x6c/0x134)
[ 12.471260] r10:c0e3a051 r9:ee9d2200 r8:00000017 r7:ed003c3c r6:00000000 r5:ee9d2200
[ 12.479136] r4:ee9d0dc0
[ 12.481703] [<c027e804>] (__handle_irq_event_percpu) from [<c027e95c>] (handle_irq_event_percpu+0x24/0x60)
[ 12.491411] r10:00000000 r9:ed002000 r8:ee808000 r7:00000000 r6:c0e094ac r5:ee9d2200
[ 12.499280] r4:ee9d2200
[ 12.501838] [<c027e938>] (handle_irq_event_percpu) from [<c027e9d8>] (handle_irq_event+0x40/0x64)
[ 12.510759] r5:ee9d2264 r4:ee9d2200
[ 12.514374] [<c027e998>] (handle_irq_event) from [<c02822ac>] (handle_fasteoi_irq+0xac/0x160)
[ 12.522947] r7:00000000 r6:c0e094ac r5:ee9d2264 r4:ee9d2200
[ 12.528644] [<c0282200>] (handle_fasteoi_irq) from [<c027dac0>] (generic_handle_irq+0x2c/0x3c)
[ 12.537300] r7:00000000 r6:00000000 r5:00000017 r4:c0c56afc
[ 12.543000] [<c027da94>] (generic_handle_irq) from [<c027e048>] (__handle_domain_irq+0x64/0xbc)
[ 12.551754] [<c027dfe4>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[ 12.560153] r9:ed002000 r8:fa213000 r7:fa212000 r6:ed003cf8 r5:fa21200c r4:c0e03ffc
[ 12.567941] [<c0201430>] (gic_handle_irq) from [<c020c478>] (__irq_svc+0x58/0x8c)
[ 12.575461] Exception stack(0xed003cf8 to 0xed003d40)
[ 12.580539] 3ce0: c0e39ec0 600b0113
[ 12.588775] 3d00: 00003a59 000016a8 00000004 eff181e0 eed5dc00 eed5dbec 600b0113 c02edc3c
[ 12.597000] 3d20: 00000000 ed003d54 ed003d58 ed003d48 c02ee1c4 c080d8c4 a00b0113 ffffffff
[ 12.605226] r9:ed002000 r8:600b0113 r7:ed003d2c r6:ffffffff r5:a00b0113 r4:c080d8c4
[ 12.613028] [<c080d89c>] (_raw_spin_unlock_irqrestore) from [<c02ee1c4>] (pagevec_lru_move_fn+0xb8/0xe0)
[ 12.622571] [<c02ee10c>] (pagevec_lru_move_fn) from [<c02ef4ec>] (lru_add_drain_cpu+0xf0/0x108)
[ 12.631317] r10:00000009 r9:edd6c540 r8:ed8f204c r7:edacc8c0 r6:ed06be00 r5:00000000
[ 12.639187] r4:c0e03e4c r3:2e108000
[ 12.642794] [<c02ef3fc>] (lru_add_drain_cpu) from [<c02ef7b8>] (lru_add_drain+0x30/0x60)
[ 12.650929] r7:edacc8c0 r6:ed06be00 r5:edd6c540 r4:ffffe000
[ 12.656629] [<c02ef788>] (lru_add_drain) from [<c031427c>] (exit_mmap+0x78/0x150)
[ 12.664158] r5:edd6c540 r4:ed28c618
[ 12.667774] [<c0314204>] (exit_mmap) from [<c0228060>] (mmput+0x48/0xe8)
[ 12.674513] r5:00000000 r4:edd6c540
[ 12.678122] [<c0228018>] (mmput) from [<c0342f40>] (flush_old_exec+0x4b4/0x6f0)
[ 12.685474] r5:edd6c540 r4:ed8f1b00
[ 12.689084] [<c0342a8c>] (flush_old_exec) from [<c038d428>] (load_elf_binary+0x2b4/0x11fc)
[ 12.697398] r10:00000009 r9:00000000 r8:ed977e00 r7:ed003e80 r6:00000034 r5:ed06be00
[ 12.705273] r4:ed929c00
[ 12.707837] [<c038d174>] (load_elf_binary) from [<c03431e8>] (search_binary_handler.part.3+0x6c/0x234)
[ 12.717196] r10:edacc8c0 r9:00000000 r8:fffffff8 r7:c0e6d5f4 r6:c0e1d538 r5:ed06be00
[ 12.725067] r4:c0e1da10
[ 12.727626] [<c034317c>] (search_binary_handler.part.3) from [<c0343bf8>] (do_execveat_common+0x594/0x67c)
[ 12.737332] r9:00000000 r8:ed06be00 r7:00000174 r6:ffffe000 r5:ed8f1b00 r4:edd7f000
[ 12.745121] [<c0343664>] (do_execveat_common) from [<c0343f34>] (SyS_execve+0x38/0x40)
[ 12.753084] r10:00000000 r9:ed002000 r8:c0207e64 r7:0000000b r6:001029b8 r5:001015e0
[ 12.760956] r4:00102b88
[ 12.763521] [<c0343efc>] (SyS_execve) from [<c0207c80>] (ret_fast_syscall+0x0/0x4c)
[ 12.771221] r5:000f4084 r4:00102898
[ 12.774817] ---[ end trace bb73aa8d472dbd3e ]---
[ 12.818398] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 12.865745] remoteproc remoteproc2: registered virtio0 (type 7)
[ OK ] Started Periodic Command Scheduler.
[ 13.015491] remoteproc remoteproc2: remote processor 40800000.dsp is now up
[ OK ] Started System Logging Service.
[ 13.122929] EXT4-fs (mmcblk2p3): mounted filesystem with ordered data mode. Opts: (null)
Starting RPC Bind Service...
Starting Print notice about GPLv3 packages...
[ OK ] Started Job spooling tools.
[ 13.297099] pruss 4b200000.pruss: creating PRU cores and other child platform devices
Starting Login Service...
[ 13.428491] pruss 4b280000.pruss: creating PRU cores and other child platform devices
[ 13.461767] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ OK ] Started Network Service.
[ OK ] Started tiipclad-daemon.service.
[ OK ] Started telnetd.service.
[ OK ] Started [ 13.681051] davinci_mdio 4b2b2400.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 13.689423] libphy: 4b2b2400.mdio: probed
RPC Bind Service.
[ OK ] Found device /dev/ttyS2.
[ 14.295150] davinci_mdio 4b2b2400.mdio: phy[2]: device 4b2b2400.mdio:02, driver unknown
[ 14.334471] davinci_mdio 4b2b2400.mdio: phy[3]: device 4b2b2400.mdio:03, driver unknown
[ 14.438982] remoteproc remoteproc4: 4b234000.pru is available
[ 14.512238] pru-rproc 4b234000.pru: PRU rproc node /ocp/pruss_soc_bus@4b226004/pruss@0/pru@34000 probed successfully
[ 14.646013] remoteproc remoteproc5: 4b238000.pru is available
[ 14.712589] pru-rproc 4b238000.pru: PRU rproc node /ocp/pruss_soc_bus@4b226004/pruss@0/pru@38000 probed successfully
[ 14.805299] remoteproc remoteproc6: 4b2b4000.pru is available
[ 14.839733] pru-rproc 4b2b4000.pru: PRU rproc node /ocp/pruss_soc_bus@4b2a6004/pruss@0/pru@34000 probed successfully
[ 14.940977] remoteproc remoteproc7: 4b2b8000.pru is available
[ 14.983208] pru-rproc 4b2b8000.pru: PRU rproc node /ocp/pruss_soc_bus@4b2a6004/pruss@0/pru@38000 probed successfully
[ 15.193515] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 15.327649] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 17.204147] EXT4-fs (mmcblk2p1): mounted filesystem with ordered data mode. Opts: (null)
Starting LSB: OpenBSD Secure Shell server...
Starting LSB: Misc Things...
Starting thttpd.service...
[ OK ] Reached target Network.
Starting Permit User Sessions...
Starting Network Name Resolution...
[ OK ] Started LSB: Misc Things.
[FAILED] Failed to start LSB: Misc Things.
See 'systemctl status systemreq.service' for details.
[ OK ] Started Login Service.
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ OK ] Started Synchronize System and HW clocks.
[ OK ] Started thttpd.service.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
NOTICE: This file system contains the following GPLv3 packages:
bash
binutils
cifs-utils
cpio
dosfstools
elfutils
gawk
gzip
libdw1
libelf1
libreadline7
m4
which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ OK ] Started LSB: OpenBSD Secure Shell server.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
[ OK ] Reached target Multi-User System.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
Starting internet superserver: xinetd.
[ 21.214481] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 21.233954] Bridge firewalling registered
[ 21.298098] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 21.324820] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 22.094950] Initializing XFRM netlink socket
LCD driver loaded
[ 22.738526] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
sh: Mounting: command not found
Setting eth2 IP to 1.1.1.2
ifconfig: SIOCSIFADDR: No such device
ifconfig: SIOCGIFFLAGS: No such device
starting Application ...........
[ 26.714119] net eth1: initializing cpsw version 1.15 (0)
[ 26.841131] Micrel KSZ9031 Gigabit PHY 48485000.mdio:01: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:01, irq=POLL)
[ 26.863371] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
## Error: "autostart" not defined
Last login: Wed Apr 7 12:06:39 UTC 2021 on ttyS2
root@AirlinkWCP:~#
root@AirlinkWCP:~#
root@AirlinkWCP:~#
root@AirlinkWCP:~# free
total used free shared buff/cache available
Mem: 1852044 51680 1670616 17868 129748 1759224
Swap: 0 0 0
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7 | VT102 | Offline | ttyUSB0
