Part Number: TMS320C6678
I am working on a new design and need to select the DDR3 devices. I’ve been planning on a 32-bit configuration using 2Gb / (16M × 16 × 8) × 2 SDRAMs at a 1333MT/s rate. I see the requirement to use JEDEC JESD79-3C compliant devices and I have read SPRABI1C (DDR3 Design Requirements). I would very much like to use Zentel A3T2GF40CBF-HPOA devices since we have those designed into other boards. The Zentel datasheet states JEDEC compliance but cites different versions of the standard such as JESD79-3F and JESD79-3-1A.01.
Are these versions of the JEDEC standard backward-compatible such that they comply with JESD79-3C?
Is there a list of DDR3 recommended devices for the TMS320C6678?
The Zentel datasheet can be found at: http://www.zentel.com/Products_List_en.html > Select the DDR3 Page > 7th one down from the top.
