What MMU and other settings must be used to get cache coherence between a72 and c7x. I am using bare metal code.
What was changed to fix the issue on this tread? https://e2e.ti.com/support/processors/f/processors-forum/891317/tda4vm-c7x-ipc-issue/3310381#3310381
Does the SMMU need to be set like mentioned in this thread? https://e2e.ti.com/support/processors/f/processors-forum/877988/am6548-cache-coherence-questions/3587440?tisearch=e2e-sitesearch&keymatch=coherence#3587440
What is L2CFG.M3CACHE used for?
Can c7x access a DDR 64bit address(like 0x8_8000_0000) before the mmu is enabled? I haven't been able to but works fine once cache is enabled. I see all the lauterbach scripts do MAP.DENYACCESS 0x100000000--0xffffffffffffffff but it isn't clear why.
