UBL and U-BOOT flash issue through UART
hi all.
i am using DM365 on my custum board, i am trying to flash UBL and U-BOOT through UART using TI' S serial flash programmer, some days before its working fine, but now a days its giving problem like as below
this is what i understood from the flash process,
1. Nand Erase is working fine
2. Board is accepting UBL but when its trying to boot that UBL through UART its failing and going into infinite loop(means UBL is accepting but U-boot its not going to accept)
if something is wrong in my understanding about board boot procedure, pls correct it,
Actual Debug prints are as follows,
root@inttel-ubuntu# ./sfh_DM36x.exe -nanderase -p /dev/ttyS0
   TI Serial Flasher Host Program for DM36x
   (C) 2009, Texas Instruments, Inc.
   Ver. 1.50
Globally erasing NAND flash.
Attempting to connect to device /dev/ttyS0...
Press any key to end this program at any time.
Waiting for the DM36x...
BOOTME commmand received. Returning ACK and header...
ACK command sent. Waiting for BEGIN command...
    Target:      BEGIN
BEGIN commmand received. Sending CRC table...
 100% [                                                              ]
                           CRC table sent....
Waiting for DONE...
DONE received.  Sending the UBL...
 100% [                                                              ]
                              UBL sent....
DONE received.  UBL was accepted.
UBL transmitted successfully.
Waiting for SFT on the DM36x...
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
    Target:     BOOTME
root@intel-ubuntu# ./sfh_DM36x.exe -nandflash -p /dev/ttyS0 ubl_DM36x_nand.bin u-boot.bin
   Ver. 1.50
Flashing NAND with ubl_DM36x_nand.bin and u-boot.bin.
    Target:      BEGIN
 100% [                                                              ]
                           CRC table sent....
Waiting for DONE...
 100% [                                                              ]
                              UBL sent....
    Target:    Starting UART Boot...
    Target:    BOOTUBL
BOOTUBL commmand received. Returning CMD and command...
CMD value sent.  Waiting for DONE...
    Target:       DONE
DONE received. Command was accepted.
Sending the UBL image
Waiting for SENDIMG sequence...
    Target:    BOOTUBL
    Target:       DONE
    Target:    BOOTUBL
    Target:       DONE
    Target:    BOOTUBL
    Target:       DONE
    Target:    BOOTUBL
    Target:       DONE
