Other Parts Discussed in Thread: TMS320C6457
Doesn't work DDR2 (2 chips MT47H128M16HG-3IT:A) c c6457.
Подлючено under the scheme sprugk5c.pdf page 30 (Figure 16).
Program code:
/////////////////////////////File ddr2.h
#ifndef DDR2_DEFH
#define DDR2_DEFH
#define MIDRDDR2 ((volatile unsigned int *)0x78000000)
#define DMCSTAT ((volatile unsigned int *)0x78000004)
#define SDCFG ((volatile unsigned int *)0x78000008)
#define SDRFC ((volatile unsigned int *)0x7800000C)
#define SDTIM1 ((volatile unsigned int *)0x78000010)
#define SDTIM2 ((volatile unsigned int *)0x78000014)
#define BPRIO ((volatile unsigned int *)0x78000020)
#define DMCCTL ((volatile unsigned int *)0x780000E4)
typedef struct // SIZE = 4 byte
unsigned int PAGESIZE : 3;
unsigned int RES1 : 1;
unsigned int IBANK : 3;
unsigned int RES2 : 2;
unsigned int CL : 3;
unsigned int RES3 : 2;
unsigned int NM : 1;
unsigned int TIMUNLOCK : 1;
unsigned int SDRAM_ENABLE : 1;
unsigned int DDR_ENABLE : 1;
unsigned int SDRAM_DRIVE0 : 1;
unsigned int DDR_DISABLE_DLL : 1;
unsigned int DDR2_ENABLE : 1;
unsigned int DDR2_TERM0 : 1;
unsigned int DDR2_DDQS : 1;
unsigned int BOOT_UNLOCK : 1;
unsigned int RES4 : 3;
unsigned int DDR2_TERM1 : 1;
unsigned int RES5 : 4;
} SDCFG_struct;
unsigned int REFRESH_RATE : 16;
unsigned int RES1 : 15;
unsigned int SR : 1;
} SDRFC_struct;
unsigned int T_WTR : 2;
unsigned int T_RRD : 3;
unsigned int T_RC : 5;
unsigned int T_RAS : 5;
unsigned int T_WR : 3;
unsigned int T_RCD : 3;
unsigned int T_RP : 3;
unsigned int T_RFC : 7;
} SDTIM1_struct;
unsigned int T_CKE : 5;
unsigned int T_RTP : 3;
unsigned int T_XSRD : 8;
unsigned int T_XSNR : 7;
unsigned int T_ODT : 2;
unsigned int RES1 : 7;
} SDTIM2_struct;
unsigned int RL : 3;
unsigned int DDRPVTCNTL : 2;
unsigned int RES2 : 3;
unsigned int DDRSLRATE : 1;
unsigned int RES3 : 22;
} DMCCTL_struct;
#endif
/////////////////////////program
SDCFG_struct ddr2cfg;
SDRFC_struct ddr2rfc;
SDTIM1_struct ddr2tim1;
SDTIM2_struct ddr2tim2;
DMCCTL_struct ddr2ctl;
#define DDR2CLKOUT 250.0 //208.333
#define REFRESHRATE 3.9 // usec
#define TWTR 7.5 // ns
#define TRRD 7.5 // ns
#define TRC 55.0 // ns
#define TRAS 40.0 // ns
#define TWR 15.0 // ns
#define TRCD 15.0 // ns
#define TRP 15.0 // ns
#define TRFC 195.0 // ns
#define TCKE 3.0
#define TRTP 7.5 // ns
#define TXSRD 200.0
#define TXSNR 210.0 // ns
#define TODT 2
*((int*)(&ddr2cfg)) = *SDCFG;
*((int*)(&ddr2rfc)) = *SDRFC;
*((int*)(&ddr2tim1)) = *SDTIM1;
*((int*)(&ddr2tim2)) = *SDTIM2;
*((int*)(&ddr2ctl)) = *DMCCTL;
ddr2cfg.TIMUNLOCK = 1;
ddr2cfg.BOOT_UNLOCK = 1;
*SDCFG = *((int*)(&ddr2cfg));
ddr2cfg.PAGESIZE = 2; // 1024 word
ddr2cfg.IBANK = 3; // 8 banks
ddr2cfg.CL = 5; // CL
ddr2cfg.NM = 0; // 32 bit
ddr2cfg.TIMUNLOCK = 1; // UnLock
ddr2cfg.SDRAM_ENABLE = 1; // Enable SDRAM
ddr2cfg.DDR_ENABLE = 1; // Enable DDR
ddr2cfg.SDRAM_DRIVE0 = 0; // Normal
ddr2cfg.DDR_DISABLE_DLL = 0; // Enable DDR DLL
ddr2cfg.DDR2_ENABLE = 1; // DDR2 Enable
ddr2cfg.DDR2_TERM0 = 1; // 50 Om
ddr2cfg.DDR2_DDQS = 1; //
ddr2cfg.BOOT_UNLOCK = 1; // UnLock
ddr2cfg.DDR2_TERM1 = 1; // 50 Om
ddr2tim1.T_WTR = ceil(TWTR * DDR2CLKOUT/1000.0 - 1);
ddr2tim1.T_RRD = ceil(TRRD * DDR2CLKOUT/1000.0 - 0.5);
ddr2tim1.T_RC = ceil(TRC * DDR2CLKOUT/1000.0 - 1);
ddr2tim1.T_RAS = ceil(TRAS * DDR2CLKOUT/1000.0 - 1);
ddr2tim1.T_WR = ceil(TWR * DDR2CLKOUT/1000.0 - 1);
ddr2tim1.T_RCD = ceil(TRCD * DDR2CLKOUT/1000.0 - 1);
ddr2tim1.T_RP = ceil(TRP * DDR2CLKOUT/1000.0 - 1);
ddr2tim1.T_RFC = ceil(TRFC * DDR2CLKOUT/1000.0 - 1);
*SDTIM1 = *((int*)(&ddr2tim1));
ddr2tim2.T_CKE = TCKE - 1;
ddr2tim2.T_RTP = ceil(TRTP * DDR2CLKOUT/1000.0 - 1);;
ddr2tim2.T_XSRD = TXSRD - 1;
ddr2tim2.T_XSNR = ceil(TXSNR * DDR2CLKOUT/1000.0 - 1);
ddr2tim2.T_ODT = TODT;
*SDTIM2 = *((int*)(&ddr2tim2));
ddr2ctl.RL = ddr2cfg.CL + 1;
ddr2ctl.DDRPVTCNTL = 1;
ddr2ctl.DDRSLRATE = 1;
*DMCCTL = *((int*)(&ddr2ctl));
ddr2rfc.REFRESH_RATE = ceil(DDR2CLKOUT*REFRESHRATE);
ddr2rfc.SR = 0;
*SDRFC = *((int*)(&ddr2rfc));
ddr2cfg.BOOT_UNLOCK = 0; // LOCK
ddr2cfg.TIMUNLOCK = 0; // LOCK
*((int*)(0xE0000000)) = 0x01234567;
p = *((int*)(0xE0000000)); // Result pp = 0xffffffff
With correctly I configure?
