Hi all,
I have TDA2PX EVM with 1GB memory configuration and I am trying to run the default available usecase of VSDK setup mentioned below,
NullSource (A15) -> Decode -> VPE -> Display
To run this usecase I have taken video with resolution 1920x1080 (attaching .h264 and .hdr file here), when i play h264 file on media player of PC it is playing smoothly but when I run the above usecase I see the jerks or glitches happening while displaying. I am using HDMI display with resolution 1920x1080 also I have set displaytype in usecase as CHAINS_DISPLAY_TYPE_HDMI_1080P still issue persist. Can you please help me out to resolve this issue. Attaching a statistics log and the distorted video I am getting for reference.
Gayatri
cd /opt/vision_sdk/ root@dra7xx-evm:/opt/vision_sdk# ./vision_sdk_load.sh [ 33.136674] DMA: Module install successful, device major num = 241 [ 33.143141] DRV: Module install successful insmod: ERROR: could not load module ./bin/cmemk.ko: No such file or directory Error: I2C Read failed Error: I2C Read failed Error: I2C Read failed ./disableDssInterruptsOnA15.sh: line 11: COMMANDS: command not found ./disableDssInterruptsOnA15.sh: line 12: COMMANDS: command not found ./disableDssInterruptsOnA15.sh: line 13: COMMANDS: command not found ./disableDssInterruptsOnA15.sh: line 14: COMMANDS: command not found ./disableDssInterruptsOnA15.sh: line 15: COMMANDS: command not found ./disableDssInterruptsOnA15.sh: line 16: COMMANDS: command not found ./disableDssInterruptsOnA15.sh: line 17: COMMANDS: command not found ./disableDssInterruptsOnA15.sh: line 18: COMMANDS: command not found ./disableDssInterruptsOnA15.sh: line 19: COMMANDS: command not found updated value is COMMANDS ### WARNING ###: use the following [read | write | set bit | clear bit | dump] commands at your own risk! No address check done, may generate: - bus error (invalid or not accessible <physical address>, - platform crash/hang (bad <value>). Read any OMAP memory address (register), given its <physical address> or <name> as listed in TRM. Write <value> at any OMAP memory address (register), given its <physical address> or <name> as listed in TRM. Set bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM. Clear bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM. Dump a range of OMAP memory addresses, from <start address> to <end address>. Note all addresses within given range must be valid and accessible. ### WARNING ###: use the following I2C [read | write] commands at your own risk! No address check done, may generate: - I2C bus error (invalid or not accessible <physical address>, - platform crash/hang (bad <value>). Read I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>. Write <value> in I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>. root@dra7xx-evm:/opt/vision_sdk# ./apps.out [HOST] OSA: MEM: 0: Mapped 0xa0100000 to 0xb65ed000 of size 0x00100000 [HOST] OSA: MEM: 1: Mapped 0x84203000 to 0xa39ed000 of size 0x12c00000 [HOST] OSA: MEM: 2: Mapped 0xa0200000 to 0xa392d000 of size 0x00040000 [HOST] OSA: MEM: 3: Mapped 0xa02c0000 to 0xa396d000 of size 0x00080000 [HOST] OSA: MEM: 4: Mapped 0x00000000 to 0x00000000 of size 0x00000000 [HOST] OSA: IPU1-0 Remote Log Shared Memory @ 0xa0200000 [HOST] OSA: HOST Remote Log Shared Memory @ 0xa024f140 42.106217] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable) [ 42.145841] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable) [ HOST] [IPU1-0] 16.977429 s: ***** IPU1_0 Firmware build tie 10:32:58 Apr 30 2021 [HOST] [IPU1-0] 16.977612 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz> [HOST] [IPU1-0] 16.980479 s: SYSTEM: System Common Init in progress !!! [HOST] [IPU1-0] 16.989782 s: UTILS: CIO: Init Done !!! [HOST] [IPU1-0] 16.989904 s: SYSTEM: IPC init in progress !!! [HOST] [IPU1-0] 16.989995 s: SYSTEM: Notify init done !!! [HOST] [IPU1-0] 16.991703 s: SYSTEM: MsgQ init done !!! [HOST] [IPU1-0] 16.992618 s: RpmsgInit in progress... [HOST] [IPU1-0] 16.992710 s: Connection established with HLOS, calling rpmsgInit [HOST] [IPU1-0] 16.993411 s: SYSTEM: IPC init DONE !!! [HOST] [IPU1-0] 17.000061 s: SYSTEM: System Common Init Done !!! [HOST] [IPU1-0] 17.000183 s: SYSTEM: System Init in progress !!! [HOST] [IPU1-0] 17.000244 s: SYSTEM: BSP Common Init in progress !!! [HOST] [IPU1-0] 17.000305 s: SYSTEM: BSP Common Init Done !!! [HOST] [IPU1-0] 17.000366 s: SYSTEM: BSP Platform Init in progress !!! [HOST] [IPU1-0] 17.000488 s: SYSTEM: BSP Platform Init Done !!! [HOST] [IPU1-0] 17.000549 s: SYSTEM: FVID2 Init in progress !!! [HOST] [IPU1-0] 17.000701 s: SYSTEM: FVID2 Init Done !!! [HOST] [IPU1-0] 17.000762 s: SYSTEM: VPS Init in progress !!! [HOST] [IPU1-0] 17.000854 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000] [HOST] [IPU1-0] 17.003599 s: *** VPDMA Firmware Loading... *** [HOST] [IPU1-0] 17.003721 s: VPDMA Firmware Address = 0xa035b5c0 [HOST] [IPU1-0] 17.003873 s: VPDMA Load Address = 0x4897d004 [HOST] [IPU1-0] 17.003965 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU1-0] 17.004056 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU1-0] 17.004148 s: *** VPDMA Firmware Load Success *** [HOST] [IPU1-0] 17.004453 s: *** VPDMA Firmware Loading... *** [HOST] [IPU1-0] 17.004544 s: VPDMA Firmware Address = 0xa035b5c0 [HOST] [IPU1-0] 17.004636 s: VPDMA Load Address = 0x4899d004 [HOST] [IPU1-0] 17.004758 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU1-0] 17.004849 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU1-0] 17.004941 s: *** VPDMA Firmware Load Success *** [HOST] [IPU1-0] 17.005246 s: *** VPDMA Firmware Loading... *** [HOST] [IPU1-0] 17.005368 s: VPDMA Firmware Address = 0xa035b5c0 [HOST] [IPU1-0] 17.005429 s: VPDMA Load Address = 0x489dd004 [HOST] [IPU1-0] 17.005551 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU1-0] 17.005642 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU1-0] 17.005703 s: *** VPDMA Firmware Load Success *** [HOST] [IPU1-0] 17.073964 s: SYSTEM: VPS Init Done !!! [HOST] [IPU1-0] 17.074788 s: UTILS: DMA: HWI Create for INT34 !!! [HOST] [IPU1-0] 17.075093 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [IPU1-0] 17.075215 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 260696 B (254 KB) [HOST] [IPU1-0] 17.075367 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [HOST] [IPU1-0] 17.075520 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 314572800 B (300 MB), Free size = 314572800 B (300 MB) [HOST] [IPU1-0] 17.075733 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1047168 B (0 MB), Free size = 1047168 B (0 MB) [HOST] [IPU1-0] 17.075886 s: SYSTEM: Initializing Links !!! [HOST] [IPU1-0] 17.380009 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [IPU1-0] 17.380894 s: CHAINS: Application Started !!! [HOST] [IPU1-0] 17.395229 s: BOARD: Board Init in progress !!! [HOST] [IPU1-0] 17.395717 s: BOARD: Board Init Done !!! [HOST] [IPU1-0] 17.406240 s: [HOST] [HOST ] 49.326236 s: SYSTEM: System A15 Init in progress !!! [HOST] [HOST ] 49.326358 s: SYSTEM: IPC: Init in progress !!! [HOST] [HOST ] 49.326358 s: SYSTEM: IPC: Notify init in progress !!! [HOST] [HOST ] 49.327548 s: SYSTEM: IPC: [IPU1-0] socket bind success !!! (dst vproc = 0, endpt = 81) [HOST] [HOST ] 49.327578 s: SYSTEM: IPC: [IPU1-0] socket info (family = 41, dst proc id = -1, endpt = 81) !!! [HOST] [HOST ] 49.327609 s: SYSTEM: IPC: [IPU1-0] socket connect success !!! (dst vproc = 0, endpt = 80) [HOST] [HOST ] 49.327609 s: SYSTEM: IPC: [IPU1-0] socket info (family = 41, dst proc id = -1, endpt = 1024) !!! [HOST] [HOST ] 49.327761 s: SYSTEM: IPC: Notify init DONE !!! [HOST] [HOST ] 49.327761 s: SYSTEM: MSGQ: MsgQ init in progress !!! [HOST] [HOST ] 49.327883 s: SYSTEM: MSGQ: MsgQ init DONE !!! [HOST] [HOST ] 49.327883 s: SYSTEM: IPC: Init DONE !!! [HOST] [HOST ] 49.327883 s: SYSTEM: Initializing A15 Links !!! [HOST] [HOST ] 49.328005 s: IPC_OUT_0 : Init done - linkid-0x2000000 [HOST] [HOST ] 49.328127 s: IPC_OUT_1 : Init done - linkid-0x2000001 [HOST] [HOST ] 49.328219 s: IPC_OUT_2 : Init done - linkid-0x2000002 [HOST] [HOST ] 49.328310 s: IPC_OUT_3 : Init done - linkid-0x2000003 [HOST] [HOST ] 49.328432 s: IPC_OUT_4 : Init done - linkid-0x2000004 [HOST] [HOST ] 49.328554 s: IPC_IN_0 : Init done - linkid-0x200000a [HOST] [HOST ] 49.328676 s: IPC_IN_1 : Init done - linkid-0x200000b [HOST] [HOST ] 49.328798 s: IPC_IN_2 : Init done - linkid-0x200000c [HOST] [HOST ] 49.328920 s: IPC_IN_3 : Init done - linkid-0x200000d [HOST] [HOST ] 49.329073 s: IPC_IN_4 : Init done - linkid-0x200000e [HOST] [HOST ] 49.329195 s: IPC_IN_5 : Init done - linkid-0x200000f [HOST] [HOST ] 49.329347 s: IPC_IN_6 : Init done - linkid-0x2000010 [HOST] [HOST ] 49.329439 s: NULL_0 : Init done - linkid-0x2000014 [HOST] [HOST ] 49.329561 s: NULL_1 : Init done - linkid-0x2000015 [HOST] [HOST ] 49.329744 s: NULL_SRC_0 : Init done - linkid-0x2000039 [HOST] [HOST ] 49.329896 s: DISP_DIST_SRC_0 : Init done - linkid-0x2000062 [HOST] [HOST ] 49.329988 s: DISP_DIST_SRC_1 : Init done - linkid-0x2000063 [HOST] [HOST ] 49.330079 s: DISP_DIST_SRC_2 : Init done - linkid-0x2000064 [HOST] [HOST ] 49.330201 s: DISP_DIST_SRC_3 : Init done - linkid-0x2000065 [HOST] [HOST ] 49.330323 s: ALGORITHM_0 : Init done - linkid-0x2000031 [HOST] [HOST ] 49.330445 s: ALGORITHM_1 : Init done - linkid-0x2000032 [HOST] [HOST ] 49.330567 s: ALGORITHM_2 : Init done - linkid-0x2000033 [HOST] [HOST ] 49.330659 s: ALGORITHM_3 : Init done - linkid-0x2000034 [HOST] [HOST ] 49.330781 s: ALGORITHM_4 : Init done - linkid-0x2000035 [HOST] [HOST ] 49.330903 s: ALGORITHM_5 : Init done - linkid-0x2000036 [HOST] [HOST ] 49.331025 s: ALGORITHM_6 : Init done - linkid-0x2000037 [HOST] [HOST ] 49.331147 s: ALGORITHM_7 : Init done - linkid-0x2000038 [HOST] [HOST ] 49.331147 s: Inside AlgorithmLink_registerPlugin [HOST] [HOST ] 49.331147 s: Create Function Address = 30cd9 [HOST] [HOST ] 49.331330 s: DUP0 : Init done - linkid-0x0 [HOST] [HOST ] 49.331513 s: DUP1 : Init done - linkid-0x0 [HOST] [HOST ] 49.331726 s: DUP2 : Init done - linkid-0x0 [HOST] [HOST ] 49.331970 s: DUP3 : Init done - linkid-0x0 [HOST] [HOST ] 49.332153 s: DUP4 : Init done - linkid-0x0 [HOST] [HOST ] 49.332306 s: SYNC_0 : Init done - linkid-0x0 [HOST] [HOST ] 49.332428 s: SYNC_1 : Init done - linkid-0x0 [HOST] [HOST ] 49.332580 s: SYNC_2 : Init done - linkid-0x0 [HOST] [HOST ] 49.332733 s: SYNC_3 : Init done - linkid-0x0 [HOST] [HOST ] 49.332916 s: MERGE_0 : Init done - linkid-0x0 [HOST] [HOST ] 49.333099 s: MERGE_1 : Init done - linkid-0x0 [HOST] [HOST ] 49.333282 s: MERGE_2 : Init done - linkid-0x0 [HOST] [HOST ] 49.333435 s: MERGE_3 : Init done - linkid-0x0 [HOST] [HOST ] 49.333587 s: MERGE_4 : Init done - linkid-0x0 [HOST] [HOST ] 49.333740 s: SELECT_0 : Init done - linkid-0x0 [HOST] [HOST ] 49.333953 s: SELECT_1 : Init done - linkid-0x0 [HOST] [HOST ] 49.334075 s: GATE_0 : Init done - linkid-0x0 [HOST] [HOST ] 49.334197 s: GATE_1 : Init done - linkid-0x0 [HOST] [HOST ] 49.334350 s: GATE_2 : Init done - linkid-0x0 [HOST] [HOST ] 49.334563 s: GATE_3 : Init done - linkid-0x0 [HOST] [HOST ] 49.334716 s: SGXFRMCPY_0 : Init done - linkid-0x200004a [HOST] [HOST ] 49.334716 s: SYSTEM: Initializing A15 Links ... DONE !!! [HOST] [HOST ] 49.335143 s: OSA: Adjusting global time, timeH by 0 units!!! [HOST] [HOST ] 49.335143 s: SYSTEM: System A15 Init Done !!! [HOST] [HOST ] 49.335326 s: NETWORK_CTRL: Starting Server (port=5000) !!! [HOST] [HOST ] 49.335387 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!! [HOST] [HOST ] 49.886872 s: [HOST] [HOST ] [HOST] [HOST ] ==================== [HOST] [HOST ] Vision SDK Usecases [HOST] [HOST ] ==================== [HOST] [HOST ] 1: Single Camera Usecases [HOST] [HOST ] 2: Multi-Camera LVDS Usecases [HOST] [HOST ] 3: Open-Compute Usecases [HOST] [HOST ] 5: ISS Usecases, (TDA2Px ONLY) [HOST] [HOST ] 6: Radar Usecases [HOST] [HOST ] [HOST] [HOST ] 7: PCIe SSD card Write Test [HOST] [HOST ] p: CPU Status [HOST] [HOST ] i: Show IP Addr (IPU + NDK + AVB) [HOST] [HOST ] [HOST] [HOST ] s: System Settings [HOST] [HOST ] [HOST] [HOST ] x: Exit [HOST] [HOST ] z: Exit - AND SHUTDOWN Remote CPUs [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] 1 [HOST] [HOST ] 51.204386 s: [HOST] [HOST ] [HOST] [HOST ] Single Camera Usecases [HOST] [HOST ] ------------------------ [HOST] [HOST ] 5: NullSrc + Decode + Display (Only 1920x1080 H264/MJPEG Video Input Bit-Stream Supported) [HOST] [HOST ] [HOST] [HOST ] x: Exit [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] [HOST] [HOST ] 51.204416 s: [HOST] [HOST ] 51.204416 s: Unsupported option ' [HOST] [HOST ] '. Please try again [HOST] [HOST ] 51.204416 s: [HOST] [HOST ] [HOST] [HOST ] Single Camera Usecases [HOST] [HOST ] ------------------------ [HOST] [HOST ] 5: NullSrc + Decode + Display (Only 1920x1080 H264/MJPEG Video Input Bit-Stream Supported) [HOST] [HOST ] [HOST] [HOST ] x: Exit [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] 5 [HOST] [HOST ] 53.412188 s: [HOST] [HOST ] 53.412188 s: Display Type = 4 [HOST] [HOST ] 53.412188 s: [HOST] [HOST ] [HOST] [HOST ] ========================================= [HOST] [HOST ] Chains Run-time Codec Type Selection Menu [HOST] [HOST ] ========================================= [HOST] [HOST ] [HOST] [HOST ] Enter '0' for MJPEG [HOST] [HOST ] [HOST] [HOST ] Enter '1' for H.264 [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] 1 [HOST] [HOST ] 55.012444 s: In set App Display Type = 4 [HOST] [HOST ] 55.012444 s: Display Width = 1920 [HOST] [HOST ] 55.012474 s: Display Height = 1080 [HOST] [IPU1-0] 55.031873 s: IPC_IN_0 : Create in progress !!! [HOST] [IPU1-0] 55.033123 s: IPC_IN_0 : Create Done !!! [HOST] [IPU1-0] 55.033550 s: DECODE: Create in progress ... !!! [HOST] [HOST ] 55.031598 s: IPC_OUT_0 : Create in progress !!! [HOST] [HOST ] 55.031690 s: IPC_OUT_0 : Create Done !!! [HOST] [IPU1-0] 55.448545 s: DECODE: Creating CH0 of 1920 x 1080 [1] [0],target bitrate = 10000 Kbps ... [HOST] [IPU1-0] 55.449490 s: DECODE: All CH Create ... DONE !!! [HOST] [IPU1-0] 55.451656 s: DECODE: Create ... DONE !!! [HOST] [IPU1-0] 55.452174 s: VPE: Create in progress !!! [HOST] [IPU1-0] 55.676813 s: VPE: Loading Down-scaling Co-effs [HOST] [IPU1-0] 55.677118 s: VPE: Co-effs Loading ... DONE !!! [HOST] [IPU1-0] 55.677331 s: VPE: Create Done !!! [HOST] [IPU1-0] 55.677728 s: DISPLAY: Create in progress !!! [HOST] [IPU1-0] 55.678368 s: DISPLAY: Create Done !!! [HOST] [IPU1-0] 55.779326 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [IPU1-0] 55.779479 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254328 B (248 KB) [HOST] [IPU1-0] 55.779631 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [HOST] [IPU1-0] 55.779784 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 314572800 B (300 MB), Free size = 258926592 B (246 MB) [HOST] [IPU1-0] 55.779997 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1047168 B (0 MB), Free size = 1047168 B (0 MB) [HOST] [IPU1-0] 55.780485 s: DISPLAY: Start in progress !!! [HOST] [IPU1-0] 55.780577 s: DISPLAY: Start Done !!! [HOST] [HOST ] 55.782132 s: [HOST] [HOST ] [HOST] [HOST ] ==================== [HOST] [HOST ] Chains Run-time Menu [HOST] [HOST ] ==================== [HOST] [HOST ] [HOST] [HOST ] 0: Stop Chain [HOST] [HOST ] [HOST] [HOST ] p: Print Performance Statistics [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] p [HOST] [IPU1-0] 155.660586 s: [HOST] [IPU1-0] 155.660678 s: CPU [IPU1-0 ] Statistics, [HOST] [IPU1-0] 155.660739 s: ************************* [HOST] [IPU1-0] 155.660800 s: [HOST] [IPU1-0] 155.660861 s: LOAD: CPU: 10.8% HWI: 1.4%, SWI:0.8%, Low Power: 1.4% [HOST] [IPU1-0] 155.661013 s: [HOST] [IPU1-0] 155.661074 s: LOAD: TSK: IPC_IN_0 : 0.4% [HOST] [IPU1-0] 155.661227 s: LOAD: TSK: DISPLAY0 : 0.6% [HOST] [IPU1-0] 155.661349 s: LOAD: TSK: DEC0 : 1.1% [HOST] [IPU1-0] 155.661440 s: LOAD: TSK: VPE0 : 1.2% [HOST] [IPU1-0] 155.661593 s: LOAD: TSK: STAT_COLL : 3.2% [HOST] [IPU1-0] 155.661684 s: LOAD: TSK: DEC_PROCESS_TSK_0 : 1.7% [HOST] [IPU1-0] 155.661806 s: LOAD: TSK: MISC : 0.4% [HOST] [IPU1-0] 155.661898 s: [HOST] [IPU1-0] 155.661928 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [IPU1-0] 155.662020 s: [HOST] [IPU1-0] 155.662050 s: SYSTEM: Sempahores Objects, 59 of 1050 free [HOST] [IPU1-0] 155.662172 s: SYSTEM: Task Objects , 6 of 100 free [HOST] [IPU1-0] 155.662264 s: SYSTEM: Clock Objects , 97 of 100 free [HOST] [IPU1-0] 155.662355 s: SYSTEM: Hwi Objects , 91 of 100 free [HOST] [IPU1-0] 155.662447 s: [HOST] [IPU1-0] 155.662477 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB) [HOST] [IPU1-0] 155.662660 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [HOST] [IPU1-0] 155.662813 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 314572800 B (300 MB), Free size = 258926592 B (246 MB) [HOST] [IPU1-0] 155.662996 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1047168 B (0 MB), Free size = 1047168 B (0 MB) [HOST] [IPU1-0] 155.663179 s: [HOST] [IPU1-0] 155.663575 s: [HOST] [IPU1-0] 155.663667 s: Statistics Collector, [HOST] [IPU1-0] 155.663728 s: [HOST] [IPU1-0] 155.663758 s: STATISTIC Avg Data Peak Data [HOST] [IPU1-0] 155.663850 s: COLLECTOR MB/s MB/s [HOST] [IPU1-0] 155.663941 s: -------------------------------------------------- [HOST] [IPU1-0] 155.664033 s: SCI_EMIF1 RD+WR | 600.573660 1454.075236 [HOST] [IPU1-0] 155.664155 s: SCI_EMIF2 RD+WR | 570.871700 1378.586845 [HOST] [IPU1-0] 155.664277 s: SCI_EMIF1 RD ONLY | 420.373349 1082.510283 [HOST] [IPU1-0] 155.664399 s: SCI_EMIF1 WR ONLY | 180.377408 704.479022 [HOST] [IPU1-0] 155.664521 s: SCI_EMIF2 RD ONLY | 397.273397 1032.610873 [HOST] [IPU1-0] 155.664826 s: SCI_EMIF2 WR ONLY | 173.845031 704.928716 [HOST] [IPU1-0] 155.665192 s: SCI_MA_MPU_P1 | 0.467852 139.773523 [HOST] [IPU1-0] 155.665314 s: SCI_MA_MPU_P2 | 0.395614 139.568228 [HOST] [IPU1-0] 155.665436 s: SCI_DSS | 186.602668 195.613843 [HOST] [IPU1-0] 155.665588 s: SCI_IPU1 | 7.435976 24.218312 [HOST] [IPU1-0] 155.665710 s: SCI_VIP1_P1 | 0.000000 0.000000 [HOST] [IPU1-0] 155.665832 s: SCI_VIP1_P2 | 0.000000 0.000000 [HOST] [IPU1-0] 155.665954 s: SCI_VPE_P1 | 77.396415 314.812219 [HOST] [IPU1-0] 155.666076 s: SCI_VPE_P2 | 77.412359 314.838289 [HOST] [IPU1-0] 155.666198 s: SCI_DSP1_MDMA | 0.000000 0.000000 [HOST] [IPU1-0] 155.666290 s: SCI_DSP1_EDMA | 0.000000 0.000000 [HOST] [IPU1-0] 155.666412 s: SCI_DSP2_MDMA | 0.000000 0.000000 [HOST] [IPU1-0] 155.666534 s: SCI_DSP2_EDMA | 0.000000 0.000000 [HOST] [IPU1-0] 155.666656 s: SCI_EVE1_TC0 | 0.000000 0.000000 [HOST] [IPU1-0] 155.666778 s: SCI_EVE1_TC1 | 0.000000 0.000000 [HOST] [IPU1-0] 155.666870 s: SCI_EVE2_TC0 | 0.000000 0.000000 [HOST] [IPU1-0] 155.666992 s: SCI_EVE2_TC1 | 0.000000 0.000000 [HOST] [IPU1-0] 155.667114 s: SCI_EDMA_TC0_RD | 0.000000 0.000000 [HOST] [IPU1-0] 155.667236 s: SCI_EDMA_TC0_WR | 0.000000 0.000000 [HOST] [IPU1-0] 155.667327 s: SCI_EDMA_TC1_RD | 0.000000 0.000000 [HOST] [IPU1-0] 155.667449 s: SCI_EDMA_TC1_WR | 0.000000 0.000000 [HOST] [IPU1-0] 155.667571 s: SCI_VIP2_P1 | 0.000000 0.000000 [HOST] [IPU1-0] 155.667693 s: SCI_VIP2_P2 | 0.000000 0.000000 [HOST] [IPU1-0] 155.667815 s: SCI_IVA | 788.178444 2633.653738 [HOST] [IPU1-0] 155.667937 s: SCI_GPU_P1 | 0.034854 0.037698 [HOST] [IPU1-0] 155.668059 s: SCI_GPU_P2 | 0.078431 0.085833 [HOST] [IPU1-0] 155.668181 s: SCI_GMAC_SW | 0.000000 0.000000 [HOST] [IPU1-0] 155.668273 s: SCI_OCMC_RAM1 | 0.000000 0.000000 [HOST] [IPU1-0] 155.668395 s: SCI_OCMC_RAM2 | 0.000000 0.000000 [HOST] [IPU1-0] 155.668517 s: SCI_OCMC_RAM3 | 0.000000 0.000000 [HOST] [IPU1-0] 155.668639 s: SCI_ISS_RT | 0.000000 0.000000 [HOST] [IPU1-0] 155.668761 s: SCI_ISS_NRT1 | 0.000000 0.000000 [HOST] [IPU1-0] 155.669920 s: SCI_ISS_NRT2 | 0.000000 0.000000 [HOST] [IPU1-0] 155.670042 s: SCI_CAL | 0.000000 0.000000 [HOST] [IPU1-0] 155.770786 s: [HOST] [IPU1-0] 155.770847 s: [HOST] [IPU1-0] 155.772219 s: [HOST] [IPU1-0] 155.772280 s: [ IPC_IN_0 ] Link Statistics, [HOST] [IPU1-0] 155.772341 s: ****************************** [HOST] [IPU1-0] 155.772402 s: [HOST] [IPU1-0] 155.772463 s: Elapsed time = 99950 msec [HOST] [IPU1-0] 155.772524 s: [HOST] [IPU1-0] 155.772585 s: Get Full Buf Cb = 31.25 fps [HOST] [IPU1-0] 155.772677 s: Put Empty Buf Cb = 31.25 fps [HOST] [IPU1-0] 155.772768 s: Driver/Notify Cb = 64.57 fps [HOST] [IPU1-0] 155.772829 s: [HOST] [IPU1-0] 155.772860 s: Input Statistics, [HOST] [IPU1-0] 155.772921 s: [HOST] [IPU1-0] 155.772982 s: CH | In Recv | In Drop | In User Drop | In Process [HOST] [IPU1-0] 155.773043 s: | FPS | FPS | FPS | FPS [HOST] [IPU1-0] 155.773134 s: -------------------------------------------------- [HOST] [IPU1-0] 155.773226 s: 0 | 31.25 0. 0 0. 0 31.25 [HOST] [IPU1-0] 155.773348 s: [HOST] [IPU1-0] 155.773378 s: Output Statistics, [HOST] [IPU1-0] 155.773439 s: [HOST] [IPU1-0] 155.773500 s: CH | Out | Out | Out Drop | Out User Drop [HOST] [IPU1-0] 155.773592 s: | ID | FPS | FPS | FPS [HOST] [IPU1-0] 155.773683 s: --------------------------------------------- [HOST] [IPU1-0] 155.773805 s: 0 | 0 31.25 0. 0 0. 0 [HOST] [IPU1-0] 155.773958 s: [HOST] [IPU1-0] 155.773988 s: [ IPC_IN_0 ] LATENCY, [HOST] [IPU1-0] 155.774049 s: ******************** [HOST] [IPU1-0] 155.774110 s: Local Link Latency : Avg = 17 us, Min = 0 us, Max = 31 us, [HOST] [IPU1-0] 155.774232 s: Source to Link Latency : Avg = 236 us, Min = 213 us, Max = 519 us, [HOST] [IPU1-0] 155.774354 s: [HOST] [IPU1-0] 155.774385 s: [ IPC_IN_0 ] Detailed IPC Latency Statistics [ HOST -> IPU1-0 ] , [HOST] [IPU1-0] 155.774476 s: *************************************************************** [HOST] [IPU1-0] 155.774598 s: IPC One-way Buffer Passing Latency (usecs) : Avg = 217, Min = 153, Max = 488 [HOST] [IPU1-0] 155.774720 s: IPC One-way Notify Interrupt Latency (usecs) : Avg = 163, Min = 122, Max = 457 [HOST] [IPU1-0] 155.775391 s: [HOST] [IPU1-0] 155.775483 s: [ DECODE ] Link Statistics, [HOST] [IPU1-0] 155.775544 s: ****************************** [HOST] [IPU1-0] 155.775635 s: [HOST] [IPU1-0] 155.775696 s: Elapsed time = 99953 msec [HOST] [IPU1-0] 155.775757 s: [HOST] [IPU1-0] 155.775818 s: New data Recv = 31.25 fps [HOST] [IPU1-0] 155.775879 s: Release data Recv = 31.25 fps [HOST] [IPU1-0] 155.775971 s: Get Full Buf Cb = 62.50 fps [HOST] [IPU1-0] 155.776032 s: Put Empty Buf Cb = 31.25 fps [HOST] [IPU1-0] 155.776123 s: [HOST] [IPU1-0] 155.776154 s: Input Statistics, [HOST] [IPU1-0] 155.776215 s: [HOST] [IPU1-0] 155.776245 s: CH | In Recv | In Drop | In User Drop | In Process [HOST] [IPU1-0] 155.776337 s: | FPS | FPS | FPS | FPS [HOST] [IPU1-0] 155.776428 s: -------------------------------------------------- [HOST] [IPU1-0] 155.776489 s: 0 | 31.25 0. 0 0. 0 31.25 [HOST] [IPU1-0] 155.776642 s: [HOST] [IPU1-0] 155.776703 s: Output Statistics, [HOST] [IPU1-0] 155.776764 s: [HOST] [IPU1-0] 155.776794 s: CH | Out | Out | Out Drop | Out User Drop [HOST] [IPU1-0] 155.776855 s: | ID | FPS | FPS | FPS [HOST] [IPU1-0] 155.776947 s: --------------------------------------------- [HOST] [IPU1-0] 155.777008 s: 0 | 0 31.25 0. 0 0. 0 [HOST] [IPU1-0] 155.777160 s: Num frames inside the codec for chId: 0 = 4 [HOST] [IPU1-0] 155.777252 s: Num process reqest count for chId: 0 = 3124 [HOST] [IPU1-0] 155.777343 s: Num process complete count for chId: 0 = 3124 [HOST] [IPU1-0] 155.777435 s: [HOST] [IPU1-0] 155.777465 s: [ DECODE ] LATENCY, [HOST] [IPU1-0] 155.777526 s: ******************** [HOST] [IPU1-0] 155.777618 s: Local Link Latency : Avg = 11825 us, Min = 10888 us, Max = 22845 us, [HOST] [IPU1-0] 155.777709 s: Source to Link Latency : Avg = 12230 us, Min = 11315 us, Max = 23730 us, [HOST] [IPU1-0] 155.777832 s: [HOST] [IPU1-0] 155.777893 s: HDVICP-ID: 0 [HOST] [IPU1-0] 155.777954 s: All percentage figures are based of totalElapsedTime [HOST] [IPU1-0] 155.778015 s: [HOST] [IPU1-0] totalAcquire2Wait :0 % [HOST] [IPU1-0] totalWait2Isr :34 % [HOST] [IPU1-0] totalIsr2Done :0 % [HOST] [IPU1-0] totalWait2Done :34 % [HOST] [IPU1-0] totalDone2Release :0 % [HOST] [IPU1-0] totalAcquire2Release :35 % [HOST] [IPU1-0] totalRelease2AcquireDelay :64 % [HOST] [IPU1-0] totalElapsedTime in msec : 99942 [HOST] [IPU1-0] numAccessCnt: 3124 [HOST] [IPU1-0] 155.778320 s: IVA-FPS : 31 [HOST] [IPU1-0] 155.778381 s: Average time spent per frame in microsec: 10876 [HOST] [IPU1-0] 155.778472 s: [HOST] [IPU1-0] 155.778869 s: [HOST] [IPU1-0] 155.778930 s: [ VPE ] Link Statistics, [HOST] [IPU1-0] 155.778991 s: ****************************** [HOST] [IPU1-0] 155.779082 s: [HOST] [IPU1-0] 155.779113 s: Elapsed time = 99943 msec [HOST] [IPU1-0] 155.779174 s: [HOST] [IPU1-0] 155.779235 s: New data Recv = 31.25 fps [HOST] [IPU1-0] 155.779296 s: Get Full Buf Cb = 31.25 fps [HOST] [IPU1-0] 155.779387 s: Put Empty Buf Cb = 31.23 fps [HOST] [IPU1-0] 155.779448 s: Driver/Notify Cb = 31.25 fps [HOST] [IPU1-0] 155.779540 s: [HOST] [IPU1-0] 155.779601 s: Input Statistics, [HOST] [IPU1-0] 155.779662 s: [HOST] [IPU1-0] 155.779692 s: CH | In Recv | In Drop | In User Drop | In Process [HOST] [IPU1-0] 155.779784 s: | FPS | FPS | FPS | FPS [HOST] [IPU1-0] 155.779875 s: -------------------------------------------------- [HOST] [IPU1-0] 155.779936 s: 0 | 31.25 0. 0 0. 0 31.25 [HOST] [IPU1-0] 155.780089 s: [HOST] [IPU1-0] 155.780119 s: Output Statistics, [HOST] [IPU1-0] 155.780180 s: [HOST] [IPU1-0] 155.780211 s: CH | Out | Out | Out Drop | Out User Drop [HOST] [IPU1-0] 155.780302 s: | ID | FPS | FPS | FPS [HOST] [IPU1-0] 155.780363 s: --------------------------------------------- [HOST] [IPU1-0] 155.780455 s: 0 | 0 31.25 0. 0 0. 0 [HOST] [IPU1-0] 155.780607 s: [HOST] [IPU1-0] 155.780638 s: [ VPE ] LATENCY, [HOST] [IPU1-0] 155.780699 s: ******************** [HOST] [IPU1-0] 155.780760 s: Local Link Latency : Avg = 8421 us, Min = 8387 us, Max = 9608 us, [HOST] [IPU1-0] 155.780882 s: Source to Link Latency : Avg = 20892 us, Min = 19948 us, Max = 32392 us, [HOST] [IPU1-0] 155.781004 s: [HOST] [IPU1-0] 155.781339 s: [HOST] [IPU1-0] 155.781400 s: [ DISPLAY ] Link Statistics, [HOST] [IPU1-0] 155.781461 s: ****************************** [HOST] [IPU1-0] 155.781522 s: [HOST] [IPU1-0] 155.781675 s: Elapsed time = 99938 msec [HOST] [IPU1-0] 155.781766 s: [HOST] [IPU1-0] 155.781797 s: New data Recv = 31.24 fps [HOST] [IPU1-0] 155.781888 s: Driver/Notify Cb = 60.3 fps [HOST] [IPU1-0] 155.781949 s: [HOST] [IPU1-0] 155.782010 s: Input Statistics, [HOST] [IPU1-0] 155.782041 s: [HOST] [IPU1-0] 155.782102 s: CH | In Recv | In Drop | In User Drop | In Process [HOST] [IPU1-0] 155.782163 s: | FPS | FPS | FPS | FPS [HOST] [IPU1-0] 155.782254 s: -------------------------------------------------- [HOST] [IPU1-0] 155.782346 s: 0 | 31.25 0. 0 0. 0 31.25 [HOST] [IPU1-0] 155.782498 s: [HOST] [IPU1-0] 155.782529 s: [ DISPLAY ] LATENCY, [HOST] [IPU1-0] 155.782590 s: ******************** [HOST] [IPU1-0] 155.782651 s: Local Link Latency : Avg = 42 us, Min = 30 us, Max = 153 us, [HOST] [IPU1-0] 155.782773 s: Source to Link Latency : Avg = 21063 us, Min = 20130 us, Max = 32575 us, [HOST] [IPU1-0] 155.782895 s: [HOST] [IPU1-0] 155.782956 s: [HOST] [IPU1-0] 155.783017 s: [ DISPLAY VID1 ] Additional Statistics, [HOST] [IPU1-0] 155.783078 s: ************************************ [HOST] [IPU1-0] 155.783139 s: Driver Queued = 3124 frames [HOST] [IPU1-0] 155.783230 s: Driver De-Queued = 3122 frames [HOST] [IPU1-0] 155.783291 s: Driver Displayed = 5999 frames [HOST] [IPU1-0] 155.783352 s: Driver Repeated = 2877 frames [HOST] [IPU1-0] 155.783444 s: [HOST] [IPU1-0] 155.783474 s: ##### DSS DISPC Underflow Count = 0 ##### [HOST] [IPU1-0] 155.783566 s: [HOST] [HOST ] 155.771091 s: [HOST] [HOST ] 155.771091 s: [ NULL_SRC ] Link Statistics, [HOST] [HOST ] 155.771091 s: ****************************** [HOST] [HOST ] 155.771121 s: [HOST] [HOST ] 155.771121 s: Elapsed time = 99957 msec [HOST] [HOST ] 155.771121 s: [HOST] [HOST ] 155.771121 s: New data Recv = 31.25 fps [HOST] [HOST ] 155.771121 s: Get Full Buf Cb = 31.25 fps [HOST] [HOST ] 155.771121 s: Put Empty Buf Cb = 31.25 fps [HOST] [HOST ] 155.771152 s: Driver/Notify Cb = 31.24 fps [HOST] [HOST ] 155.771152 s: [HOST] [HOST ] 155.771152 s: Input Statistics, [HOST] [HOST ] 155.771152 s: [HOST] [HOST ] 155.771152 s: CH | In Recv | In Drop | In User Drop | In Process [HOST] [HOST ] 155.771152 s: | FPS | FPS | FPS | FPS [HOST] [HOST ] 155.771152 s: -------------------------------------------------- [HOST] [HOST ] 155.771182 s: 0 | 31.25 0. 0 0. 0 31.25 [HOST] [HOST ] 155.771182 s: [HOST] [HOST ] 155.771182 s: Output Statistics, [HOST] [HOST ] 155.771182 s: [HOST] [HOST ] 155.771182 s: CH | Out | Out | Out Drop | Out User Drop [HOST] [HOST ] 155.771182 s: | ID | FPS | FPS | FPS [HOST] [HOST ] 155.771213 s: --------------------------------------------- [HOST] [HOST ] 155.771213 s: 0 | 0 31.25 0. 0 0. 0 [HOST] [HOST ] 155.771243 s: [HOST] [HOST ] 155.771243 s: [ IPC_OUT_0 ] Link Statistics, [HOST] [HOST ] 155.771274 s: ****************************** [HOST] [HOST ] 155.771274 s: [HOST] [HOST ] 155.771274 s: Elapsed time = 99949 msec [HOST] [HOST ] 155.771274 s: [HOST] [HOST ] 155.771274 s: New data Recv = 31.25 fps [HOST] [HOST ] 155.771274 s: Release data Recv = 31.25 fps [HOST] [HOST ] 155.771274 s: Driver/Notify Cb = 31.25 fps [HOST] [HOST ] 155.771304 s: [HOST] [HOST ] 155.771304 s: Input Statistics, [HOST] [HOST ] 155.771304 s: [HOST] [HOST ] 155.771304 s: CH | In Recv | In Drop | In User Drop | In Process [HOST] [HOST ] 155.771304 s: | FPS | FPS | FPS | FPS [HOST] [HOST ] 155.771304 s: -------------------------------------------------- [HOST] [HOST ] 155.771304 s: 0 | 31.25 0. 0 0. 0 31.25 [HOST] [HOST ] 155.771335 s: [HOST] [HOST ] 155.771335 s: Output Statistics, [HOST] [HOST ] 155.771335 s: [HOST] [HOST ] 155.771335 s: CH | Out | Out | Out Drop | Out User Drop [HOST] [HOST ] 155.771335 s: | ID | FPS | FPS | FPS [HOST] [HOST ] 155.771335 s: --------------------------------------------- [HOST] [HOST ] 155.771365 s: 0 | 0 31.25 0. 0 0. 0 [HOST] [HOST ] 155.771365 s: [HOST] [HOST ] 155.771365 s: [ IPC_OUT_0 ] LATENCY, [HOST] [HOST ] 155.771365 s: ******************** [HOST] [HOST ] 155.771365 s: Local Link Latency : Avg = 1 us, Min = 0 us, Max = 31 us, [HOST] [HOST ] 155.771396 s: Source to Link Latency : Avg = 31 us, Min = 0 us, Max = 62 us, [HOST] [HOST ] 155.771396 s: [HOST] [HOST ] 155.784359 s: [HOST] [HOST ] [HOST] [HOST ] ==================== [HOST] [HOST ] Chains Run-time Menu [HOST] [HOST ] ==================== [HOST] [HOST ] [HOST] [HOST ] 0: Stop Chain [HOST] [HOST ] [HOST] [HOST ] p: Print Performance Statistics [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] 0 [HOST] [IPU1-0] 159.413621 s: DISPLAY: Stop in progress !!! [HOST] [IPU1-0] 159.413774 s: DISPLAY: Stop Done !!! [HOST] [IPU1-0] 159.422741 s: VPE: Stop in progress !!! [HOST] [IPU1-0] 159.422832 s: VPE: Stop Done !!! [HOST] [IPU1-0] 159.423229 s: DECODE: Stop in progress !!! [HOST] [IPU1-0] 159.423381 s: DECODE: Stop Done !!! [HOST] [IPU1-0] 159.423778 s: IPC_IN_0 : Stop Done !!! [HOST] [IPU1-0] 159.424235 s: DISPLAY: Delete in progress !!! [HOST] [IPU1-0] 159.424388 s: DISPLAY: Delete Done !!! [HOST] [IPU1-0] 159.424784 s: VPE: Delete in progress !!! [HOST] [IPU1-0] 159.426889 s: VPE: Delete Done !!! [HOST] [IPU1-0] 159.427316 s: DECODE: Stop in progress !!! [HOST] [IPU1-0] 159.427499 s: DECODE: Stop Done !!! [HOST] [IPU1-0] 159.427560 s: DECODE: Delete in progress !!! [HOST] [IPU1-0] 159.431342 s: DECODE: Delete Done !!! [HOST] [HOST ] 159.424022 s: IPC_OUT_0 : Stop Done !!! [HOST] [IPU1-0] 159.431830 s: IPC_IN_0 : Delete in progress !!! [HOST] [IPU1-0] 159.432288 s: IPC_IN_0 : Delete Done !!! [HOST] [IPU1-0] 159.434545 s: [HOST] [IPU1-0] 159.434697 s: #### EVE CLK = 20.0 Mhz [HOST] [IPU1-0] 159.434850 s: #### DSP CLK = 850.0 Mhz [HOST] [IPU1-0] 159.434972 s: #### IPU CLK = 212.800000 Mhz [HOST] [IPU1-0] 159.435094 s: #### A15 CLK = 1000.0 Mhz [HOST] [IPU1-0] 159.435185 s: [HOST] [IPU1-0] 159.435216 s: [HOST] [IPU1-0] 159.435246 s: LOAD: CPU: 10.9% HWI: 1.4%, SWI:0.8% [HOST] [IPU1-0] 159.435368 s: [HOST] [IPU1-0] 159.435429 s: LOAD: TSK: IPC_IN_0 : 0.4% [HOST] [IPU1-0] 159.435551 s: LOAD: TSK: DISPLAY0 : 0.6% [HOST] [IPU1-0] 159.435643 s: LOAD: TSK: DEC0 : 1.1% [HOST] [IPU1-0] 159.435765 s: LOAD: TSK: VPE0 : 1.2% [HOST] [IPU1-0] 159.435887 s: LOAD: TSK: STAT_COLL : 3.2% [HOST] [IPU1-0] 159.435978 s: LOAD: TSK: MISC : 2.2% [HOST] [IPU1-0] 159.436039 s: [HOST] [HOST ] 159.432623 s: IPC_OUT_0 : Delete in progress !!! [HOST] [HOST ] 159.432623 s: IPC_OUT_0 : Delete Done !!! [HOST] [HOST ] 159.536661 s: [HOST] [HOST ] [HOST] [HOST ] Single Camera Usecases [HOST] [HOST ] ------------------------ [HOST] [HOST ] 5: NullSrc + Decode + Display (Only 1920x1080 H264/MJPEG Video Input Bit-Stream Supported) [HOST] [HOST ] [HOST] [HOST ] x: Exit [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] 0^H [HOST] [HOST ] 163.125510 s: [HOST] [HOST ] 163.125541 s: Unsupported option ' [HOST] [HOST ] '. Please try again [HOST] [HOST ] 163.125541 s: [HOST] [HOST ] [HOST] [HOST ] Single Camera Usecases [HOST] [HOST ] ------------------------ [HOST] [HOST ] 5: NullSrc + Decode + Display (Only 1920x1080 H264/MJPEG Video Input Bit-Stream Supported) [HOST] [HOST ] [HOST] [HOST ] x: Exit [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] x [HOST] [HOST ] 163.765479 s: [HOST] [HOST ] 163.765479 s: [HOST] [HOST ] [HOST] [HOST ] ==================== [HOST] [HOST ] Vision SDK Usecases [HOST] [HOST ] ==================== [HOST] [HOST ] 1: Single Camera Usecases [HOST] [HOST ] 2: Multi-Camera LVDS Usecases [HOST] [HOST ] 3: Open-Compute Usecases [HOST] [HOST ] 5: ISS Usecases, (TDA2Px ONLY) [HOST] [HOST ] 6: Radar Usecases [HOST] [HOST ] [HOST] [HOST ] 7: PCIe SSD card Write Test [HOST] [HOST ] p: CPU Status [HOST] [HOST ] i: Show IP Addr (IPU + NDK + AVB) [HOST] [HOST ] [HOST] [HOST ] s: System Settings [HOST] [HOST ] [HOST] [HOST ] x: Exit [HOST] [HOST ] z: Exit - AND SHUTDOWN Remote CPUs [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] x [HOST] [HOST ] 164.917434 s: SYSTEM: System A15 De-Init in progress !!! [HOST] [HOST ] 164.917434 s: SYSTEM: De-Initializing A15 Links !!! [HOST] [HOST ] 164.917525 s: IPC_OUT_0 : DeInit done - linkid-0x2000000 [HOST] [HOST ] 164.917647 s: IPC_OUT_1 : DeInit done - linkid-0x2000001 [HOST] [HOST ] 164.917800 s: IPC_OUT_2 : DeInit done - linkid-0x2000002 [HOST] [HOST ] 164.917922 s: IPC_OUT_3 : DeInit done - linkid-0x2000003 [HOST] [HOST ] 164.918044 s: IPC_OUT_4 : DeInit done - linkid-0x2000004 [HOST] [HOST ] 164.918166 s: IPC_IN_0 : DeInit done - linkid-0x200000a [HOST] [HOST ] 164.918288 s: IPC_IN_1 : DeInit done - linkid-0x200000b [HOST] [HOST ] 164.918410 s: IPC_IN_2 : DeInit done - linkid-0x200000c [HOST] [HOST ] 164.918532 s: IPC_IN_3 : DeInit done - linkid-0x200000d [HOST] [HOST ] 164.918654 s: IPC_IN_4 : DeInit done - linkid-0x200000e [HOST] [HOST ] 164.918776 s: IPC_IN_5 : DeInit done - linkid-0x200000f [HOST] [HOST ] 164.918898 s: IPC_IN_6 : DeInit done - linkid-0x2000010 [HOST] [HOST ] 164.919020 s: NULL_0 : DeInit done - linkid-0x2000014 [HOST] [HOST ] 164.919142 s: NULL_1 : DeInit done - linkid-0x2000015 [HOST] [HOST ] 164.919264 s: NULL_SRC_0 : DeInit done - linkid-0x2000039 [HOST] [HOST ] 164.919386 s: DISP_DIST_SRC_0 : DeInit done - linkid-0x2000062 [HOST] [HOST ] 164.919508 s: DISP_DIST_SRC_1 : DeInit done - linkid-0x2000063 [HOST] [HOST ] 164.919630 s: DISP_DIST_SRC_2 : DeInit done - linkid-0x2000064 [HOST] [HOST ] 164.919752 s: DISP_DIST_SRC_3 : DeInit done - linkid-0x2000065 [HOST] [HOST ] 164.919874 s: ALGORITHM_0 : DeInit done - linkid-0x2000031 [HOST] [HOST ] 164.919965 s: ALGORITHM_1 : DeInit done - linkid-0x2000032 [HOST] [HOST ] 164.920057 s: ALGORITHM_2 : DeInit done - linkid-0x2000033 [HOST] [HOST ] 164.920148 s: ALGORITHM_3 : DeInit done - linkid-0x2000034 [HOST] [HOST ] 164.920209 s: ALGORITHM_4 : DeInit done - linkid-0x2000035 [HOST] [HOST ] 164.920301 s: ALGORITHM_5 : DeInit done - linkid-0x2000036 [HOST] [HOST ] 164.920392 s: ALGORITHM_6 : DeInit done - linkid-0x2000037 [HOST] [HOST ] 164.920453 s: ALGORITHM_7 : DeInit done - linkid-0x2000038 [HOST] [HOST ] 164.920575 s: DUP0 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.920697 s: DUP1 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.920819 s: DUP2 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.920941 s: DUP3 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.921185 s: DUP4 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.921307 s: SYNC_0 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.921429 s: SYNC_1 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.921551 s: SYNC_2 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.921673 s: SYNC_3 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.921795 s: MERGE_0 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.921917 s: MERGE_1 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.922009 s: MERGE_2 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.922131 s: MERGE_3 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.922253 s: MERGE_4 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.922344 s: SELECT_0 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.922466 s: SELECT_1 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.922588 s: GATE_0 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.922680 s: GATE_1 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.922802 s: GATE_2 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.922924 s: GATE_3 : DeInit done - linkid-0x0 [HOST] [HOST ] 164.923046 s: SGXFRMCPY_0 : DeInit done - linkid-0x200004a [HOST] [HOST ] 164.923046 s: SYSTEM: De-Initializing A15 Links ... DONE !!! [HOST] [HOST ] 164.923046 s: SYSTEM: IPC: De-init in progress !!! [HOST] [HOST ] 164.923046 s: SYSTEM: MSGQ: MsgQ de-init in progress !!! [HOST] [HOST ] 164.923076 s: After OSA_quePut !!! [HOST] [HOST ] 164.923168 s: After OSA_thrDelete !!! [HOST] [HOST ] 164.923168 s: Address of gSystem_ipcMsgQObj = 4dc50 [HOST] [HOST ] 164.923168 s: Address of msgQAck = 4dc68 [HOST] [HOST ] 164.923168 s: After OSA_semDelete !!! [HOST] [HOST ] 164.923168 s: After OSA_queDelete !!! [HOST] [HOST ] 164.923198 s: After OSA_mutexDelete !!! [HOST] [HOST ] 164.923198 s: SYSTEM: MSGQ: MsgQ de-init DONE !!! [HOST] [HOST ] 164.923198 s: SYSTEM: IPC: Notify de-init in progress !!! [HOST] [HOST ] 164.923198 s: Inside System_ipcNotifyUnblock !!! [HOST] [HOST ] 164.923198 s: Address of gSystem_ipcNotifyObj = 4dd50 [HOST] [HOST ] 164.923198 s: Address of gSystem_ipcNotifyObj.unblockFd = 4dda0 [HOST] [HOST ] 164.923229 s: File Descriptor = 8 [HOST] [HOST ] 164.923290 s: After System_ipcNotifyUnblock !!! [HOST] [HOST ] 164.923320 s: After OSA_thrDelete !!! [HOST] [HOST ] 164.923351 s: Inside while !!! [HOST] [HOST ] 164.923351 s: ProceId = 0 [HOST] [HOST ] 164.924601 s: Inside while !!! [HOST] [HOST ] 164.924601 s: ProceId = 2 [HOST] [HOST ] 164.924601 s: Outside while !!! [HOST] [HOST ] 164.924632 s: SYSTEM: IPC: Notify de-init DONE !!! [HOST] [HOST ] 164.924632 s: SYSTEM: IPC: De-init DONE !!! [HOST] [HOST ] 164.924662 s: SYSTEM: System A15 De-Init Done !!! [ 158.211220] omap_hwmod: mmu0_dsp2: _wait_target_disable failed [ 158.217120] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0 [ 158.223117] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0 [ 158.238625] omap_hwmod: mmu0_dsp1: _wait_target_disable failed [ 158.244516] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0 [ 158.250506] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0 root@dra7xx-evm:/opt/vision_sdk#
