TMDSIDK572: TMDSIDK572 GPMC interface issue
Part Number: TMDSIDK572
Hi team,
            We are using TMDSIDK572 – AM572x Industrial Development Kit (IDK). In this IDK there is no default GPMC interface. but we are made hardware setup and pinmux configuration for GPMC interface. We are using "fpga read write - sync mode" bare metal as-is. but when we write into gpmc memory space we are not get any clock singnal in oscilloscope. here i attached my baremetal file. and also i couldn't see any value in memory window which i write through GPMC bus.
            I am using this SDK "ti-processor-sdk-rtos-am57xx-evm-06.03.00.106-Windows-x86-Install" for windows. there is no default driver available for GPMC bus. So, we are using CSL example GPMC code
            this is my previous question for GPMC issue. AM5729: GPMC issue - Processors forum - Processors - TI E2E support forums.
 *  Copyright (C) 2013-2019 Texas Instruments Incorporated - http://www.ti.com/
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *   \file    main.c
 *   \brief   GPMC test application optimized for FPGA read and write using CPU and DMA.
              Use the macros to select between synchronous/non-synchronous,
              burst/non-burst, and CPU/DMA modes. The application will perform
              reads and writes and output the benchmarks to UART terminal. The
              test will pass/fail depending on whether the benchmark numbers fall
              within the predefined bounds.
              The timing values configured in GPMC_init() can be tuned to further
              optimize your application.
              One of the following configurations can be tested at a time by defining/undefining the macros below.
              1. Synchronous Burst DMA Mode
              2. Synchronous Non-burst DMA Mode
              3. Asynchronous Burst DMA Mode
              4. Asynchronous Non-burst DMA Mode
              5. Synchronous Burst CPU Mode
              6. Synchronous Non-burst CPU Mode
              7. Asynchronous Burst CPU Mode
              8. Asynchronous Non-burst CPU Mode
/*                             Include Files                                  */
//NEW ADDED BY GPIO BAREMETAL
#include <ti/board/board.h>
#include <ti/csl/example/utils/uart_console/inc/uartConfig.h>
#include <ti/csl/csl_gpmc.h>
#include <ti/csl/soc.h>
#include <ti/csl/hw_types.h>
#include <ti/csl/csl_edma.h>
#include <ti/csl/example/edma/edma_test/sample.h>
/*                                 Macros                                     */
/*                             Include Files                                  */
//#define BURST_MODE
#define SYNC_MODE
//#define DMA_ENABLE
/*                            Global Variables                                */
signed char __attribute__((section(".my_sect_ddr"))) _srcBuff1[MAX_BUFFER_SIZE];
signed char __attribute__((section(".my_sect_ddr"))) _dstBuff1[MAX_BUFFER_SIZE];
uint32_t edma_ch_num = 1;
uint32_t edma_tcc_num = 1;
uint32_t edma_evtq_num = 0;
uint32_t region = EDMA3_CC_REGION;
signed char *srcBuff1;
signed char *dstBuff1;
extern uint32_t base_address;
/*To use UARTConfigPuts function for prints*/
uint32_t uartBaseAddr = SOC_UART3_BASE;
/* To use for benchmarking */
#define TIMER14_TCLR (*((volatile uint32_t *)0x4882A038))
#define TIMER14_TLDR (*((volatile uint32_t *)0x4882A040))
#define TIMER14_TCRR (*((volatile uint32_t *)0x4882A03C))
#define TIMER14_TMAR (*((volatile uint32_t *)0x4882A04C))
#define TIMER14_TSICR (*((volatile uint32_t *)0x4882A054))
/*                          Function Definitions                              */
void GPMC_init(void);
void padConfig_prcmEnable(void);
int main(void)
    uint32_t i, t_start, t_stop, t_overhead;
#ifdef DMA_ENABLE
    uint32_t t_delta_dma_writes, t_delta_dma_reads;
#else
    uint32_t t_delta_cpu_writes, t_delta_cpu_reads;
    uint32_t var0 = 0xFFFFFFFF;
    volatile uint32_t * GPMC0 = (volatile uint32_t*) 0x08000000;
    volatile uint32_t * GPMC1 = (volatile uint32_t*) 0x08000004;
    volatile uint32_t * GPMC2 = (volatile uint32_t*) 0x08000008;
    volatile uint32_t * GPMC3 = (volatile uint32_t*) 0x0800000C;
    volatile uint32_t * GPMC4 = (volatile uint32_t*) 0x08000010;
    volatile uint32_t * GPMC5 = (volatile uint32_t*) 0x08000014;
    volatile uint32_t * GPMC6 = (volatile uint32_t*) 0x08000018;
    volatile uint32_t * GPMC7 = (volatile uint32_t*) 0x0800001C;*/
#endif
    /*MMC1 PAD Configuration*/
    padConfig_prcmEnable();
    /* Configure the UART Parameters */
    UARTConfigInit(uartBaseAddr, BAUD_RATE_115200, UART_WORD_LENGTH_8,
    UART_STOP_BIT_1,
                   UART_NO_PARITY, UART_16x_MODE);
#ifdef DMA_ENABLE
    EDMAsetRegion(region);
    /* Do EDMA init once in the beginning of application */
    EDMA3Init(base_address, 0);
#endif
    /* Configure GPMC registers with timing values optimized for an FPGA */
    GPMC_init();
    UARTConfigPuts(uartBaseAddr, "\nGPMC FPGA Example\n\n", -1);
#ifdef SYNC_MODE
    UARTConfigPuts(uartBaseAddr, "Synchronous,", -1);
#else
    UARTConfigPuts(uartBaseAddr, "Asynchronous,", -1);
#endif
#ifdef BURST_MODE
    UARTConfigPuts(uartBaseAddr, " Burst,", -1);
#else
    UARTConfigPuts(uartBaseAddr, " Non-burst,", -1);
#endif
#ifdef DMA_ENABLE
    UARTConfigPuts(uartBaseAddr, " DMA Mode\n", -1);
#else
    UARTConfigPuts(uartBaseAddr, " CPU Mode\n", -1);
#endif
    /* Initialize timer14 for benchmarking */
    TIMER14_TCLR = 0;
    TIMER14_TLDR = 0;
    TIMER14_TCRR = 0;
    TIMER14_TMAR = 0;
    TIMER14_TSICR = 0;
    TIMER14_TCLR = 0x1;
    /* Calculate timer overhead */
    t_start = TIMER14_TCRR;
    t_stop = TIMER14_TCRR;
    t_overhead = t_stop - t_start;
#ifdef DMA_ENABLE  //DMA
    srcBuff1 = (signed char *) (_srcBuff1);
    dstBuff1 = (signed char *) 0x08000000;
     * Initialize the source address with a pattern
    for (i = 0U; i < (MAX_ACOUNT * MAX_BCOUNT * MAX_CCOUNT); i += 4)
        srcBuff1[i] = (int) 0xFF;
        srcBuff1[i + 1] = (int) 0xFF;
        srcBuff1[i + 2] = (int) 0x00;
        srcBuff1[i + 3] = (int) 0x00;
    UARTConfigPuts(uartBaseAddr, "\nStarting DMA Writes", -1);
    /* Start DMA writes */
    t_delta_dma_writes = dma_polled(edma_ch_num, edma_tcc_num, edma_evtq_num,
    MAX_ACOUNT,
                                    MAX_BCOUNT,
                                    MAX_CCOUNT);
    t_delta_dma_writes -= t_overhead;
    srcBuff1 = (signed char *) 0x08000000;
    dstBuff1 = (signed char *) (_dstBuff1);
    UARTConfigPuts(uartBaseAddr, "\nCompleted DMA Writes\n", -1);
    UARTConfigPuts(uartBaseAddr, "\nStarting DMA Reads", -1);
    /* Start DMA reads */
    t_delta_dma_reads = dma_polled(edma_ch_num, edma_tcc_num, edma_evtq_num,
    MAX_ACOUNT,
                                   MAX_BCOUNT,
                                   MAX_CCOUNT);
    t_delta_dma_reads -= t_overhead;
    UARTConfigPuts(uartBaseAddr, "\nCompleted DMA Reads\n", -1);
#else //CPU
    UARTConfigPuts(uartBaseAddr, "\nStarting CPU Writes", -1);
    while(1)
            for(i=0;i<4;i++)
             UARTConfigPuts(uartBaseAddr, "\nCompleted CPU Writes starts\n", -1);
            *GPMC0 = 0xFF;
            //*GPMC0 = 0xAAAA;
            // *GPMC1 = 0x00000000;
            // *GPMC2 = 0xAAAAAAAA;
            //*GPMC3 = 0x55555555;
            //*GPMC4 = 0xFFFFFFFF;
            //*GPMC5 = 0x00000000;
            //*GPMC6 = 0xFFFFFFFF;
            //*GPMC7 = 0xAAAAAAAA;
        t_delta_cpu_writes = t_stop - t_start - t_overhead;
        UARTConfigPuts(uartBaseAddr, "\nCompleted CPU Writes\n", -1);
    UARTConfigPuts(uartBaseAddr, "\nStarting CPU Reads", -1);
    for(i=0;i<4;i++)
        var0 = *GPMC0;
        //var0 = *GPMC1;
        //var0 = *GPMC2;
        //var0 = *GPMC3;
        //var0 = *GPMC4;
        //var0 = *GPMC5;
        //var0 = *GPMC6;
        //var0 = *GPMC7;
    t_delta_cpu_reads = t_stop - t_start - t_overhead;
    UARTConfigPuts(uartBaseAddr, "\nCompleted CPU Reads\n", -1);
#endif
    UARTConfigPuts(uartBaseAddr, "\nBenchmarks:\n", -1);
#ifdef DMA_ENABLE
    UARTConfigPuts(uartBaseAddr, "\nDMA Write: ", -1);
    UARTConfigPutNum(uartBaseAddr, t_delta_dma_writes);
    UARTConfigPuts(uartBaseAddr, " Cycles", -1);
    UARTConfigPuts(uartBaseAddr, "\nDMA Read: ", -1);
    UARTConfigPutNum(uartBaseAddr, t_delta_dma_reads);
#else
    UARTConfigPuts(uartBaseAddr, "\nCPU Write: ", -1);
    UARTConfigPutNum(uartBaseAddr, t_delta_cpu_writes);
    UARTConfigPuts(uartBaseAddr, "\nCPU Read: ", -1);
    UARTConfigPutNum(uartBaseAddr, t_delta_cpu_reads);
#endif
#ifdef DMA_ENABLE
#ifdef SYNC_MODE
#ifdef BURST_MODE
    if ((0 <= t_delta_dma_writes && t_delta_dma_writes < 35)
            && (0 <= t_delta_dma_reads && t_delta_dma_reads < 35))
                       "\n\nSynchronous, Burst, DMA GPMC Test Has Passed.", -1);
    else
                       "\n\nSynchronous, Burst, DMA GPMC Test Has Failed.", -1);
#else
    if((0 <= t_delta_dma_writes && t_delta_dma_writes < 50) && (0 <= t_delta_dma_reads && t_delta_dma_reads < 45))
        UARTConfigPuts(uartBaseAddr, "\n\nSynchronous, Non-burst DMA GPMC Test Has Passed.", -1);
        else
            UARTConfigPuts(uartBaseAddr, "\n\nSynchronous, Non-burst, DMA GPMC Test Has Failed.", -1);
#endif
#else
#ifdef BURST_MODE
    if((0 <= t_delta_dma_writes && t_delta_dma_writes < 50) && (0 <= t_delta_dma_reads && t_delta_dma_reads < 35))
        UARTConfigPuts(uartBaseAddr, "\n\nAsynchronous, Burst, DMA GPMC Test Has Passed.", -1);
    else
        UARTConfigPuts(uartBaseAddr, "\n\nAsynchronous, Burst, DMA GPMC Test Has Failed.", -1);
#else
    if((0 <= t_delta_dma_writes && t_delta_dma_writes < 55) && (0 <= t_delta_dma_reads && t_delta_dma_reads < 40))
        UARTConfigPuts(uartBaseAddr, "\n\nAsynchronous, Non-burst, DMA GPMC Test Has Passed.", -1);
    else
        UARTConfigPuts(uartBaseAddr, "\n\nAsynchronous, Non-burst, DMA GPMC Test Has Failed.", -1);
#endif
#endif
#else
#ifdef SYNC_MODE
#ifdef BURST_MODE
    if((0 <= t_delta_cpu_writes && t_delta_cpu_writes < 10) && (0 <= t_delta_cpu_reads && t_delta_cpu_reads < 310))
        UARTConfigPuts(uartBaseAddr, "\n\nSynchronous, Burst, CPU GPMC Test Has Passed.", -1);
    else
        UARTConfigPuts(uartBaseAddr, "\n\nSynchronous, Burst, CPU GPMC Test Has Failed.", -1);
#else
    if((0 <= t_delta_cpu_writes && t_delta_cpu_writes < 25) && (0 <= t_delta_cpu_reads && t_delta_cpu_reads < 700))
        UARTConfigPuts(uartBaseAddr, "\n\nSynchronous, Non-burst, CPU GPMC Test Has Passed.", -1);
    else
        UARTConfigPuts(uartBaseAddr, "\n\nSynchronous, Non-burst, CPU GPMC Test Has Failed.", -1);
#endif
#else
#ifdef BURST_MODE
    if((0 <= t_delta_cpu_writes && t_delta_cpu_writes < 25) && (0 <= t_delta_cpu_reads && t_delta_cpu_reads < 300))
        UARTConfigPuts(uartBaseAddr, "\n\nAsynchronous, Burst, CPU GPMC Test Has Passed.", -1);
    else
        UARTConfigPuts(uartBaseAddr, "\n\nAsynchronous, Burst, CPU GPMC Test Has Failed.", -1);
#else
    if((0 <= t_delta_cpu_writes && t_delta_cpu_writes < 20) && (0 <= t_delta_cpu_reads && t_delta_cpu_reads < 700))
        UARTConfigPuts(uartBaseAddr, "\n\nAsynchronous, Non-burst, CPU GPMC Test Has Passed.", -1);
    else
        UARTConfigPuts(uartBaseAddr, "\n\nAsynchronous, Non-burst, CPU GPMC Test Has Failed.", -1);
#endif
#endif
#endif
    UARTConfigPuts(uartBaseAddr, "\n\nExiting the GPMC Example\n", -1);
    while (1); //hang here
    return 0;
/* Configures GPMC registers with timing values optimized for an FPGA */
    uint32_t baseAddr = CSL_MPU_GPMC_CONF_REGS_REGS;
    uint32_t config;
    //GPMC reset
    //GPMCModuleSoftReset(baseAddr);
    //while(!GPMCModuleResetStatusGet(baseAddr));
    /* Enable the chip select */
    GPMCCSConfig(baseAddr, GPMC_CHIP_SELECT_0, GPMC_CS_ENABLE);
    /* Select the chip-select base address, chip addr needs to be given */
    GPMCBaseAddrSet(baseAddr, GPMC_CHIP_SELECT_0, 0x00000008);
    /* Select the chip-select mask address */
    GPMCMaskAddrSet(baseAddr, GPMC_CHIP_SELECT_0, GPMC_CS_SIZE_64MB);
    /* Set the device size attached */
    GPMCDevSizeSelect(baseAddr, GPMC_CHIP_SELECT_0, GPMC_DEVICESIZE_16BITS);
    /* Set the read mode operation and write mode operation */
#ifdef SYNC_MODE
    GPMCReadTypeSelect(baseAddr, GPMC_CHIP_SELECT_0, GPMC_READTYPE_SYNC);
    GPMCWriteTypeSelect(baseAddr, GPMC_CHIP_SELECT_0, GPMC_WRITETYPE_SYNC);
#else
    GPMCReadTypeSelect(baseAddr,GPMC_CHIP_SELECT_0, GPMC_READTYPE_ASYNC);
    GPMCWriteTypeSelect(baseAddr,GPMC_CHIP_SELECT_0, GPMC_WRITETYPE_ASYNC);
#endif
    /* Select single access or multiple access reads and writes*/
#ifdef BURST_MODE
    GPMCAccessTypeSelect(baseAddr, GPMC_CHIP_SELECT_0, GPMC_MODE_READ,
    GPMC_ACCESSTYPE_MULTIPLE);
    GPMCAccessTypeSelect(baseAddr, GPMC_CHIP_SELECT_0, GPMC_MODE_WRITE,
#else
    GPMCAccessTypeSelect(baseAddr, GPMC_CHIP_SELECT_0, GPMC_MODE_READ, GPMC_ACCESSTYPE_SINGLE);
    GPMCAccessTypeSelect(baseAddr, GPMC_CHIP_SELECT_0, GPMC_MODE_WRITE, GPMC_ACCESSTYPE_SINGLE);
#endif
    /* Set the signals timing latencies scalar factor */
    GPMCTimeParaGranularitySelect(baseAddr, GPMC_CHIP_SELECT_0,
    GPMC_TIMEPARAGRANULARITY_X1);
    /* Set the address and data multiplexed protocol */
    GPMCAddrDataMuxProtocolSelect(baseAddr, GPMC_CHIP_SELECT_0,
    GPMC_MUXADDDATA_NOMUX);
    /* Set the timing parameters for the chip select signal */
    //CSWROFFTIME, CSRDOFFTIME, CSEXTRADELAY, CSONTIME
    config = GPMC_CS_TIMING_CONFIG(10, 7, GPMC_CS_EXTRA_NODELAY, 0);
    GPMCCSTimingConfig(baseAddr, GPMC_CHIP_SELECT_0, config);
    /* Set the timing parameters for the ADV# signal */
    /* ADVAADMUXWROFFTIME, ADVAADMUXRDOFFTIME, ADVWROFFTIME, ADVRDOFFTIME, ADVEXTRADELAY, ADVAADMUXONTIME, ADVONTIME */
    config = GPMC_ADV_TIMING_CONFIG(0, 0, 4, 4, GPMC_ADV_EXTRA_NODELAY, 0, 0);
    GPMCADVTimingConfig(baseAddr, GPMC_CHIP_SELECT_0, config);
    /* Set the timing parameters for the WE# and OE# signals */
    /* WEOFFTIME, WEEXTRADELAY, WEONTIME, OEAADMUX_OFFTIME, OEOFFTIME, OEEXTRADELAY, OEAADMUX_ONTIME, OEONTIME */
    config = GPMC_WE_OE_TIMING_CONFIG(7, 0, 4, 0, 7, GPMC_OE_EXTRA_NODELAY, 0,
                                      4);
    GPMCWEAndOETimingConfig(baseAddr, GPMC_CHIP_SELECT_0, config);
    /* Set the RdAccessTime and CycleTime timing parameters */
    /* RDCYCLETIME, WRCYCLETIME, RDACCESSTIME, PAGEBURSTACCESSTIME */
    config = GPMC_RDACCESS_CYCLETIME_TIMING_CONFIG(9, 9, 6, 3);
    GPMCRdAccessAndCycleTimeTimingConfig(baseAddr, GPMC_CHIP_SELECT_0, config);
    /* Configure the Cycle2Cycle and BusTurnAround timing parameters */
    /* CYCLE2CYCLEDELAY, CYCLE2CYCLEDELAYSAMECSCFG, CYCLE2CYCLEDELAYDIFFCSCFG, BUSTATIME */
    config = GPMC_CYCLE2CYCLE_BUSTURNAROUND_TIMING_CONFIG(
            2, GPMC_CYCLE2CYCLESAMECSEN_C2CDELAY,
            GPMC_CYCLE2CYCLEDIFFCSEN_NOC2CDELAY, 0);
    GPMCycle2CycleAndTurnArndTimeTimingConfig(baseAddr, GPMC_CHIP_SELECT_0,
                                              config);
    /* Configure the WrAccessTime, Cycle2Cycle andBusTurnAround timing parameters.*/
    /* WRACCESSTIME, WRDATAONADMUXBUS */
    GPMCWrAccessAndWrDataOnADMUXBusTimingConfig(baseAddr, GPMC_CHIP_SELECT_0, 6,
                                                4);
    /* Set the FCLK divide down value */
    GPMCFclkDividerSelect(baseAddr, GPMC_CHIP_SELECT_0, GPMC_FCLK_DIV_BY_3);
    /* Set the attached device page (burst) length */
    GPMCDevPageLenSet(baseAddr, GPMC_CHIP_SELECT_0,
    GPMC_DEV_PAGELENGTH_SIXTEEN);
    //GPMC reset
    Board_initCfg boardCfg;
     boardCfg = BOARD_INIT_UNLOCK_MMR | BOARD_INIT_UART_STDIO |
                BOARD_INIT_MODULE_CLOCK | BOARD_INIT_PINMUX_CONFIG;
     Board_init(boardCfg);
     /*Pad configurations */
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_UART3_RXD,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_UART3_TXD,
            0x00000000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_UART2_CTSN,
            0x00060002);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_UART2_RTSN,
            0x00060001);
    /*Pad configurations*/
    /*GPMC Data lines AD0-AD15*/
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD0,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD1,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD2,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD3,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD4,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD5,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD6,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD7,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD8,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD9,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD10,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD11,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD12,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD13,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD14,
            0x00050000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_AD15,
            0x00050000);
    /*GPMC Add lines A0-A27*/
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A0,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A1,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A2,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A3,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A4,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A5,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A6,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A7,
            0x00040000);
#if 0
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A8,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A9,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A10,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A11,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A12,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A13,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A14,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A15,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A16,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A17,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A18,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A19,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A20,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A21,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A22,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A23,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A24,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A25,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A26,
            0x00040000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_A27,
            0x00040000);
#endif
    /*GPMC chip select*/
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_CS3,
            0x00060000);
    /*GPMC control lines*/
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_ADVN_ALE,
            0x00060000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_OEN_REN,
            0x00070000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_WEN,
            0x00070000);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_BEN0,
            0x00070000);
    HW_WR_REG32(
               CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_BEN1,
               0x00070000);
    HW_WR_REG32(CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_WAIT0, 0x0000000F);
    HW_WR_REG32(
            CSL_MPU_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_GPMC_CLK,
            0x00060000);
/***************************** End Of File ***********************************/
