Part Number: TDA4VM
Can you provide an example of how to add Pinmux for a peripheral using sysconfig / Pinmux tool from dev.ti.com?
Let us try to understand the process of adding the PinMux for a peripheral using an example.
Modification to PinMux in board library
1. Go to https://dev.ti.com/ and launch PinMux tool.
2. Load the mcu_adc.syscfg, this gives an example on how to Pinmux MCU domain's ADC.
3. To get the full picture, load the SDK.syscfg in the tool.
Important note, in case there are multiple options for SoC PADs for a particular signal, check your HW schematics on what actually is pinned out.
How to load a sysconfig project
To load the *.syscfg files open the pinmux tool from dev.ti.com and then File -> Open -> Upload (this is a small cloud sign) -> browse your PC and select the *.syscfg file.
/cfs-file/__key/communityserver-discussions-components-files/791/pinmux_5F00_tool_5F00_projects.zip
Rebuilding the board library
Once you make your updates run the below:
cd pdk/packages/ti/build
/* Clean the board library, this cleans the ti.board.aer5f at pdk/packages/ti/board/lib/j721e/r5f/release/ti.board.aer5f */
make board_clean -sj
/* rebuild the board library, this will rebuild the ti.board.aer5f, you can verify by checking the time stamp of this */
make board -sj
If you are using the SDK then you don't need anything else. But if you are using this library outside of the SDK where you need to explicitly link this, then link the new ti.board.aer5f.
Karan
For PinMuxing in device tree for Linux, please refer - https://e2e.ti.com/support/processors/f/791/t/927526
Karan
