Part Number: LMK00306
Other Parts Discussed in Thread: LMK62A2-200M,
I have a general question regarding ac coupling your clock chips and clock buffer ICs. Using this part number for example (LMK62A2-200M to drive this part).
1. When should you ac couple clock signals other than when you need to change the DC offset to interface to different signal standards?
2. I noticed your EVM for this part has all cap coupled inputs and outputs. Is there a performance benefit or signal integrity benefit to to this?
3. How do you calculate the correct series capacitance for these cap coupled inputs and outputs?
4. The data sheet for the LMK00306 shows both DC and AC coupled LVDS outputs...If you are driving LVDS inputs (so the signal chain is LVDS and there is no level shift) what are the pros and cons of dc vs ac coupling?
