Part Number: AM3359
Tool/software: Linux
Hello all,
I'm working on AM3359 ice v2 evk with sdk version 4.0.As of now no hardware is connected to gpmc.I'm trying to enable gpmc clk,cs0,cs2 and then probe the all signal through IO expansion header(except gpmc_clk).The added gpmc pinmuxing and configurations in am335x-icev2.dts file.But when i boot i get the following errors
[ 0.304272] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/gpmc_pins, deferring probe
[ 1.325367] pinctrl-single 44e10800.pinmux: pin PIN28 already requested by 481a8000.serial; cannot claim for 50000000.gpmc
[ 1.336648] pinctrl-single 44e10800.pinmux: pin-28 (50000000.gpmc) status -22
[ 1.343872] pinctrl-single 44e10800.pinmux: could not request pin 28 (PIN28) from group gpmc_pins on device pinctrl-single
[ 1.355094] omap-gpmc 50000000.gpmc: Error applying setting, reverse things back
[ 1.362566] omap-gpmc: probe of 50000000.gpmc failed with error -22
My dts file:
* Copyright (C) 2016 Texas Instruments Incorporated - http://www.ti.com/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
* AM335x ICE V2 board
* http://www.ti.com/tool/tmdsice3359
/dts-v1/;
#include "am33xx.dtsi"
model = "TI AM3359 ICE-V2";
compatible = "ti,am3359-icev2", "ti,am33xx";
memory@80000000 {
device_type = "memory";
reg = <0x80000000 0x10000000>; /* 256 MB */
chosen {
stdout-path = &uart3;
vbat: fixedregulator0 {
compatible = "regulator-fixed";
regulator-name = "vbat";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
vtt_fixed: fixedregulator1 {
regulator-name = "vtt";
regulator-min-microvolt = <1500000>;
regulator-max-microvolt = <1500000>;
gpio = <&gpio0 18 GPIO_ACTIVE_HIGH>;
regulator-always-on;
regulator-boot-on;
enable-active-high;
leds-iio {
status = "disabled";
compatible = "gpio-leds";
led-out0 {
label = "out0";
gpios = <&tpic2810 0 GPIO_ACTIVE_HIGH>;
default-state = "off";
led-out1 {
label = "out1";
gpios = <&tpic2810 1 GPIO_ACTIVE_HIGH>;
led-out2 {
label = "out2";
gpios = <&tpic2810 2 GPIO_ACTIVE_HIGH>;
led-out3 {
label = "out3";
gpios = <&tpic2810 3 GPIO_ACTIVE_HIGH>;
led-out4 {
label = "out4";
gpios = <&tpic2810 4 GPIO_ACTIVE_HIGH>;
led-out5 {
label = "out5";
gpios = <&tpic2810 5 GPIO_ACTIVE_HIGH>;
led-out6 {
label = "out6";
gpios = <&tpic2810 6 GPIO_ACTIVE_HIGH>;
led-out7 {
label = "out7";
gpios = <&tpic2810 7 GPIO_ACTIVE_HIGH>;
/* Tricolor status LEDs */
leds1 {
pinctrl-names = "default";
pinctrl-0 = <&user_leds>;
led0 {
label = "status0:red:cpu0";
gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "cpu0";
led1 {
label = "status0:green:usr";
gpios = <&gpio0 16 GPIO_ACTIVE_HIGH>;
led2 {
label = "status0:yellow:usr";
gpios = <&gpio3 9 GPIO_ACTIVE_HIGH>;
led3 {
label = "status1:red:mmc0";
gpios = <&gpio1 30 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "mmc0";
led4 {
label = "status1:green:usr";
gpios = <&gpio0 20 GPIO_ACTIVE_HIGH>;
led5 {
label = "status1:yellow:usr";
gpios = <&gpio0 19 GPIO_ACTIVE_HIGH>;
gpio-decoder {
compatible = "gpio-decoder";
gpios = <&pca9536 3 GPIO_ACTIVE_HIGH>,
<&pca9536 2 GPIO_ACTIVE_HIGH>,
<&pca9536 1 GPIO_ACTIVE_HIGH>,
<&pca9536 0 GPIO_ACTIVE_HIGH>;
linux,axis = <0>; /* ABS_X */
decoder-max-value = <9>;
/* Dual mac ethernet application node on icss */
pruss_eth {
compatible = "ti,am3359-prueth";
pruss = <&pruss>;
sram = <&ocmcram>;
interrupt-parent = <&pruss_intc>;
pinctrl-0 = <&pruss_eth_default>;
pruss_emac0: ethernet-mii0 {
phy-handle = <&pruss_eth0_phy>;
phy-mode = "mii";
interrupts = <20>, <22>;
interrupt-names = "rx", "tx";
/* Filled in by bootloader */
local-mac-address = [00 00 00 00 00 00];
pruss_emac1: ethernet-mii1 {
phy-handle = <&pruss_eth1_phy>;
phy-mode = "mii";
interrupts = <21>, <23>;
&am33xx_pinmux {
user_leds: user_leds {
pinctrl-single,pins = <
AM33XX_IOPAD(0x91c, PIN_OUTPUT | MUX_MODE7) /* (J18) gmii1_txd3.gpio0[16] */
AM33XX_IOPAD(0x920, PIN_OUTPUT | MUX_MODE7) /* (K15) gmii1_txd2.gpio0[17] */
AM33XX_IOPAD(0x9b0, PIN_OUTPUT | MUX_MODE7) /* (A15) xdma_event_intr0.gpio0[19] */
AM33XX_IOPAD(0x9b4, PIN_OUTPUT | MUX_MODE7) /* (D14) xdma_event_intr1.gpio0[20] */
AM33XX_IOPAD(0x880, PIN_OUTPUT | MUX_MODE7) /* (U9) gpmc_csn1.gpio1[30] */
AM33XX_IOPAD(0x92c, PIN_OUTPUT | MUX_MODE7) /* (K18) gmii1_txclk.gpio3[9] */
mmc0_pins_default: mmc0_pins_default {
AM33XX_IOPAD(0x8f0, PIN_INPUT_PULLUP | MUX_MODE0) /* (F17) mmc0_dat3.mmc0_dat3 */
AM33XX_IOPAD(0x8f4, PIN_INPUT_PULLUP | MUX_MODE0) /* (F18) mmc0_dat2.mmc0_dat2 */
AM33XX_IOPAD(0x8f8, PIN_INPUT_PULLUP | MUX_MODE0) /* (G15) mmc0_dat1.mmc0_dat1 */
AM33XX_IOPAD(0x8fc, PIN_INPUT_PULLUP | MUX_MODE0) /* (G16) mmc0_dat0.mmc0_dat0 */
AM33XX_IOPAD(0x900, PIN_INPUT_PULLUP | MUX_MODE0) /* (G17) mmc0_clk.mmc0_clk */
AM33XX_IOPAD(0x904, PIN_INPUT_PULLUP | MUX_MODE0) /* (G18) mmc0_cmd.mmc0_cmd */
i2c0_pins_default: i2c0_pins_default {
AM33XX_IOPAD(0x988, PIN_INPUT | MUX_MODE0) /* (C17) I2C0_SDA.I2C0_SDA */
AM33XX_IOPAD(0x98c, PIN_INPUT | MUX_MODE0) /* (C16) I2C0_SCL.I2C0_SCL */
spi0_pins_default: spi0_pins_default {
AM33XX_IOPAD(0x950, PIN_INPUT_PULLUP | MUX_MODE0) /* (A17) spi0_sclk.spi0_sclk */
AM33XX_IOPAD(0x954, PIN_INPUT_PULLUP | MUX_MODE0) /* (B17) spi0_d0.spi0_d0 */
AM33XX_IOPAD(0x958, PIN_INPUT_PULLUP | MUX_MODE0) /* (B16) spi0_d1.spi0_d1 */
AM33XX_IOPAD(0x95c, PIN_INPUT_PULLUP | MUX_MODE0) /* (A16) spi0_cs0.spi0_cs0 */
AM33XX_IOPAD(0x960, PIN_INPUT_PULLUP | MUX_MODE0) /* (C15) spi0_cs1.spi0_cs1 */
AM33XX_IOPAD(0x9a0, PIN_INPUT_PULLUP | MUX_MODE7) /* (B12) mcasp0_aclkr.gpio3[18] */
uart3_pins_default: uart3_pins_default {
AM33XX_IOPAD(0x934, PIN_INPUT_PULLUP | MUX_MODE1) /* (L17) gmii1_rxd3.uart3_rxd */
AM33XX_IOPAD(0x938, PIN_OUTPUT_PULLUP | MUX_MODE1) /* (L16) gmii1_rxd2.uart3_txd */
uart4_pins_default: uart4_pins_default {
AM33XX_IOPAD(0x870, PIN_INPUT_PULLUP | MUX_MODE6) /* (T17) gpmc_wait0.uart4_rxd */
AM33XX_IOPAD(0x874, PIN_OUTPUT_PULLUP | MUX_MODE6) /* (U17) gpmc_wpn.uart4_txd */
cpsw_default: cpsw_default {
/* Slave 1, RMII mode */
AM33XX_IOPAD(0x90c, (PIN_INPUT_PULLUP | MUX_MODE1)) /* mii1_crs.rmii1_crs_dv */
AM33XX_IOPAD(0x944, (PIN_INPUT_PULLUP | MUX_MODE0)) /* rmii1_refclk.rmii1_refclk */
AM33XX_IOPAD(0x940, (PIN_INPUT_PULLUP | MUX_MODE1)) /* mii1_rxd0.rmii1_rxd0 */
AM33XX_IOPAD(0x93c, (PIN_INPUT_PULLUP | MUX_MODE1)) /* mii1_rxd1.rmii1_rxd1 */
AM33XX_IOPAD(0x910, (PIN_INPUT_PULLUP | MUX_MODE1)) /* mii1_rxerr.rmii1_rxerr */
AM33XX_IOPAD(0x928, (PIN_OUTPUT_PULLDOWN | MUX_MODE1)) /* mii1_txd0.rmii1_txd0 */
AM33XX_IOPAD(0x924, (PIN_OUTPUT_PULLDOWN | MUX_MODE1)) /* mii1_txd1.rmii1_txd1 */
AM33XX_IOPAD(0x914, (PIN_OUTPUT_PULLDOWN | MUX_MODE1)) /* mii1_txen.rmii1_txen */
/* Slave 2, RMII mode */
AM33XX_IOPAD(0x870, (PIN_INPUT_PULLUP | MUX_MODE3)) /* gpmc_wait0.rmii2_crs_dv */
AM33XX_IOPAD(0x908, (PIN_INPUT_PULLUP | MUX_MODE1)) /* mii1_col.rmii2_refclk */
AM33XX_IOPAD(0x86c, (PIN_INPUT_PULLUP | MUX_MODE3)) /* gpmc_a11.rmii2_rxd0 */
AM33XX_IOPAD(0x868, (PIN_INPUT_PULLUP | MUX_MODE3)) /* gpmc_a10.rmii2_rxd1 */
AM33XX_IOPAD(0x874, (PIN_INPUT_PULLUP | MUX_MODE3)) /* gpmc_wpn.rmii2_rxerr */
AM33XX_IOPAD(0x854, (PIN_OUTPUT_PULLDOWN | MUX_MODE3)) /* gpmc_a5.rmii2_txd0 */
AM33XX_IOPAD(0x850, (PIN_OUTPUT_PULLDOWN | MUX_MODE3)) /* gpmc_a4.rmii2_txd1 */
AM33XX_IOPAD(0x840, (PIN_OUTPUT_PULLDOWN | MUX_MODE3)) /* gpmc_a0.rmii2_txen */
cpsw_sleep: cpsw_sleep {
/* Slave 1 reset value */
AM33XX_IOPAD(0x90c, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x944, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x940, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x93c, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x910, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x928, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x924, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x914, (PIN_INPUT_PULLDOWN | MUX_MODE7))
/* Slave 2 reset value */
AM33XX_IOPAD(0x870, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x908, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x86c, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x868, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x874, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x854, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x850, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x840, (PIN_INPUT_PULLDOWN | MUX_MODE7))
davinci_mdio_default: davinci_mdio_default {
/* MDIO */
AM33XX_IOPAD(0x948, (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0)) /* mdio_data.mdio_data */
AM33XX_IOPAD(0x94c, (PIN_OUTPUT_PULLUP | MUX_MODE0)) /* mdio_clk.mdio_clk */
davinci_mdio_sleep: davinci_mdio_sleep {
/* MDIO reset value */
AM33XX_IOPAD(0x948, (PIN_INPUT_PULLDOWN | MUX_MODE7))
AM33XX_IOPAD(0x94c, (PIN_INPUT_PULLDOWN | MUX_MODE7))
pruss_mdio_default: pruss_mdio_default {
AM33XX_IOPAD(0x88c, (PIN_OUTPUT | MUX_MODE5)) /* gpmc_clk.pr1_mdio_mdclk */
AM33XX_IOPAD(0x888, (PIN_INPUT | MUX_MODE5)) /* gpmc_csn3.pr1_mdio_data */
AM33XX_IOPAD(0x89c, (PIN_INPUT_PULLUP | MUX_MODE7)) /* gpmc_ben0_cle.gpio2_5 */
/* disable CPSW MDIO */
AM33XX_IOPAD(0x948, (PIN_INPUT_PULLUP | MUX_MODE7)) /* mdio_data.gpio0_0 */
AM33XX_IOPAD(0x94c, (PIN_INPUT_PULLUP | MUX_MODE7)) /* mdio_clk.gpio0_1 */
pruss_eth_default: pruss_eth_default {
AM33XX_IOPAD(0x8a0, (PIN_INPUT | MUX_MODE2)) /* dss_data0.pr1_mii_mt0_clk */
AM33XX_IOPAD(0x8b4, (PIN_OUTPUT | MUX_MODE2)) /* dss_data5.pr1_mii0_txd0 */
AM33XX_IOPAD(0x8b0, (PIN_OUTPUT | MUX_MODE2)) /* dss_data4.pr1_mii0_txd1 */
AM33XX_IOPAD(0x8ac, (PIN_OUTPUT | MUX_MODE2)) /* dss_data3.pr1_mii0_txd2 */
AM33XX_IOPAD(0x8a8, (PIN_OUTPUT | MUX_MODE2)) /* dss_data2.pr1_mii0_txd3 */
AM33XX_IOPAD(0x8cc, (PIN_INPUT | MUX_MODE5)) /* dss_data11.pr1_mii0_rxd0 */
AM33XX_IOPAD(0x8c8, (PIN_INPUT | MUX_MODE5)) /* dss_data10.pr1_mii0_rxd1 */
AM33XX_IOPAD(0x8c4, (PIN_INPUT | MUX_MODE5)) /* dss_data9.pr1_mii0_rxd2 */
AM33XX_IOPAD(0x8c0, (PIN_INPUT | MUX_MODE5)) /* dss_data8.pr1_mii0_rxd3 */
AM33XX_IOPAD(0x8a4, (PIN_OUTPUT | MUX_MODE2)) /* dss_data1.pr1_mii0_txen */
AM33XX_IOPAD(0x8d8, (PIN_INPUT | MUX_MODE5)) /* dss_data14.pr1_mii_mr0_clk */
AM33XX_IOPAD(0x8dc, (PIN_INPUT | MUX_MODE5)) /* dss_data15.pr1_mii0_rxdv */
AM33XX_IOPAD(0x8d4, (PIN_INPUT | MUX_MODE5)) /* dss_data13.pr1_mii0_rxer */
AM33XX_IOPAD(0x8d0, (PIN_INPUT | MUX_MODE5)) /* dss_data12.pr1_mii0_rxlink */
AM33XX_IOPAD(0x8e8, (PIN_INPUT | MUX_MODE2)) /* dss_pclk.pr1_mii0_crs */
AM33XX_IOPAD(0x840, (PIN_INPUT | MUX_MODE5)) /* gpmc_a0.pr1_mii_mt1_clk */
AM33XX_IOPAD(0x850, (PIN_OUTPUT | MUX_MODE5)) /* gpmc_a4.pr1_mii1_txd0 */
AM33XX_IOPAD(0x84c, (PIN_OUTPUT | MUX_MODE5)) /* gpmc_a3.pr1_mii1_txd1 */
AM33XX_IOPAD(0x848, (PIN_OUTPUT | MUX_MODE5)) /* gpmc_a2.pr1_mii1_txd2 */
AM33XX_IOPAD(0x844, (PIN_OUTPUT | MUX_MODE5)) /* gpmc_a1.pr1_mii1_txd3 */
AM33XX_IOPAD(0x860, (PIN_INPUT | MUX_MODE5)) /* gpmc_a8.pr1_mii1_rxd0 */
AM33XX_IOPAD(0x85c, (PIN_INPUT | MUX_MODE5)) /* gpmc_a7.pr1_mii1_rxd1 */
AM33XX_IOPAD(0x858, (PIN_INPUT | MUX_MODE5)) /* gpmc_a6.pr1_mii1_rxd2 */
AM33XX_IOPAD(0x854, (PIN_INPUT | MUX_MODE5)) /* gpmc_a5.pr1_mii1_rxd3 */
AM33XX_IOPAD(0x874, (PIN_OUTPUT | MUX_MODE5)) /* gpmc_wpn.pr1_mii1_txen */
AM33XX_IOPAD(0x864, (PIN_INPUT | MUX_MODE5)) /* gpmc_a9.pr1_mii_mr1_clk */
AM33XX_IOPAD(0x868, (PIN_INPUT | MUX_MODE5)) /* gpmc_a10.pr1_mii1_rxdv */
AM33XX_IOPAD(0x86c, (PIN_INPUT | MUX_MODE5)) /* gpmc_a11.pr1_mii1_rxer */
AM33XX_IOPAD(0x878, (PIN_INPUT | MUX_MODE5)) /* gpmc_ben1.pr1_mii1_rxlink */
AM33XX_IOPAD(0x8ec, (PIN_INPUT | MUX_MODE2)) /* lcd_ac_bias_en.pr1_mii1_crs */
AM33XX_IOPAD(0x870, (PIN_INPUT | MUX_MODE5)) /* gpmc_wait0.pr1_mii1_col */
gpmc_pins: gpmc_pins {
pinctrl-single,pins=<
AM33XX_IOPAD(0x800,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad0.gpmc.ad0*/
AM33XX_IOPAD(0x804,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad1.gpmc.ad1*/
AM33XX_IOPAD(0x808,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad2.gpmc.ad2*/
AM33XX_IOPAD(0x80C,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad3.gpmc.ad3*/
AM33XX_IOPAD(0x810,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad4.gpmc.ad4*/
AM33XX_IOPAD(0x814,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad5.gpmc.ad5*/
AM33XX_IOPAD(0x818,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad6.gpmc.ad6*/
AM33XX_IOPAD(0x81C,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad7.gpmc.ad7*/
AM33XX_IOPAD(0x820,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad8.gpmc.ad8*/
AM33XX_IOPAD(0x824,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad9.gpmc.ad9*/
AM33XX_IOPAD(0x828,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad10.gpmc.ad10*/
AM33XX_IOPAD(0x82C,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad11.gpmc.ad11*/
AM33XX_IOPAD(0x830,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad12.gpmc.ad12*/
AM33XX_IOPAD(0x834,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad13.gpmc.ad13*/
AM33XX_IOPAD(0x838,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad14.gpmc.ad14*/
AM33XX_IOPAD(0x83C,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_ad15.gpmc.ad15*/
AM33XX_IOPAD(0x870,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_wait0*/
AM33XX_IOPAD(0x874,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_wpn*/
AM33XX_IOPAD(0x878,PIN_OUTPUT|MUX_MODE0)/*gpmc_ben1*/
AM33XX_IOPAD(0x87C,PIN_OUTPUT|MUX_MODE0)/*gpmc_csn0*/
AM33XX_IOPAD(0x884,PIN_OUTPUT|MUX_MODE0)/*gpmc_csn2*/
AM33XX_IOPAD(0x88C,PIN_INPUT_PULLUP|MUX_MODE0)/*gpmc_clk*/
AM33XX_IOPAD(0x890,PIN_OUTPUT|MUX_MODE0)/*gpmc_advn_ale*/
AM33XX_IOPAD(0x894,PIN_OUTPUT_PULLUP|MUX_MODE0)/*gpmc_oen_ren*/
AM33XX_IOPAD(0x898,PIN_OUTPUT_PULLUP|MUX_MODE0)/*gpmc_wen*/
AM33XX_IOPAD(0x89C,PIN_OUTPUT_PULLUP|MUX_MODE0)/*gpmc_ben0_cle*/
&i2c0 {
pinctrl-0 = <&i2c0_pins_default>;
status = "okay";
clock-frequency = <400000>;
tps: power-controller@2d {
reg = <0x2d>;
tpic2810: gpio@60 {
compatible = "ti,tpic2810";
reg = <0x60>;
gpio-controller;
#gpio-cells = <2>;
pca9536: gpio@41 {
compatible = "ti,pca9536";
reg = <0x41>;
gpio-controller;
#gpio-cells = <2>;
&spi0 {
status = "okay";
pinctrl-0 = <&spi0_pins_default>;
sn65hvs882@1 {
compatible = "pisosr-gpio";
gpio-controller;
#gpio-cells = <2>;
load-gpios = <&gpio3 18 GPIO_ACTIVE_LOW>;
reg = <1>;
spi-max-frequency = <1000000>;
spi-cpol;
spi_nor: flash@0 {
#address-cells = <1>;
#size-cells = <1>;
compatible = "winbond,w25q64", "jedec,spi-nor";
spi-max-frequency = <80000000>;
m25p,fast-read;
reg = <0>;
partition@0 {
label = "u-boot-spl";
reg = <0x0 0x80000>;
read-only;
partition@1 {
label = "u-boot";
reg = <0x80000 0x100000>;
read-only;
partition@2 {
label = "u-boot-env";
reg = <0x180000 0x20000>;
read-only;
partition@3 {
label = "misc";
reg = <0x1A0000 0x660000>;
&tscadc {
status = "okay";
adc {
ti,adc-channels = <1 2 3 4 5 6 7>;
#include "tps65910.dtsi"
&tps {
vcc1-supply = <&vbat>;
vcc2-supply = <&vbat>;
vcc3-supply = <&vbat>;
vcc4-supply = <&vbat>;
vcc5-supply = <&vbat>;
vcc6-supply = <&vbat>;
vcc7-supply = <&vbat>;
vccio-supply = <&vbat>;
regulators {
vrtc_reg: regulator@0 {
vio_reg: regulator@1 {
vdd1_reg: regulator@2 {
regulator-name = "vdd_mpu";
regulator-min-microvolt = <912500>;
regulator-max-microvolt = <1326000>;
regulator-boot-on;
vdd2_reg: regulator@3 {
regulator-name = "vdd_core";
regulator-max-microvolt = <1144000>;
regulator-boot-on;
vdd3_reg: regulator@4 {
vdig1_reg: regulator@5 {
vdig2_reg: regulator@6 {
vpll_reg: regulator@7 {
vdac_reg: regulator@8 {
vaux1_reg: regulator@9 {
vaux2_reg: regulator@10 {
vaux33_reg: regulator@11 {
vmmc_reg: regulator@12 {
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <3300000>;
&mmc1 {
status = "okay";
vmmc-supply = <&vmmc_reg>;
bus-width = <4>;
pinctrl-0 = <&mmc0_pins_default>;
&gpio0 {
/* Do not idle the GPIO used for holding the VTT regulator */
ti,no-reset-on-init;
ti,no-idle-on-init;
p7 {
gpio-hog;
gpios = <7 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "FET_SWITCH_CTRL";
&uart3 {
pinctrl-0 = <&uart3_pins_default>;
status = "okay";
&uart4 {
pinctrl-0 = <&uart4_pins_default>;
status = "okay";
&gpio3 {
p4 {
gpio-hog;
gpios = <4 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "PR1_MII_CTRL";
p10 {
gpio-hog;
gpios = <10 GPIO_ACTIVE_HIGH>;
/* ETH1 mux: Low for MII-PRU, high for RMII-CPSW */
output-high;
line-name = "MUX_MII_CTL1";
&cpsw_emac0 {
phy_id = <&davinci_mdio>, <1>;
phy-mode = "rmii";
dual_emac_res_vlan = <1>;
&cpsw_emac1 {
phy_id = <&davinci_mdio>, <3>;
phy-mode = "rmii";
dual_emac_res_vlan = <2>;
&mac {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&cpsw_default>;
pinctrl-1 = <&cpsw_sleep>;
status = "okay";
dual_emac;
&phy_sel {
rmii-clock-ext;
&davinci_mdio {
pinctrl-0 = <&davinci_mdio_default>;
pinctrl-1 = <&davinci_mdio_sleep>;
status = "okay";
reset-gpios = <&gpio2 5 GPIO_ACTIVE_LOW>;
reset-delay-us = <2>; /* PHY datasheet states 1uS min */
&pruss_soc_bus {
status = "okay";
pruss: pruss@4a300000 {
status = "okay";
pru0: pru@4a334000 {
status = "okay";
pru1: pru@4a338000 {
status = "okay";
&pruss_mdio {
pinctrl-0 = <&pruss_mdio_default>;
pruss_eth0_phy: ethernet-phy@1 {
reg = <1>;
pruss_eth1_phy: ethernet-phy@3 {
reg = <3>;
/*&i2c1{
compatible = "ti,omap4-i2c";
#size-cells = <0>;
ti,hwmods = "i2c2";
reg = <0x4802a000 0x1000>;
interrupts = <71>;
status = "okay";
ad7414@48 {
compatible = "analog,ad7414";
reg = <0x48>;
status = "okay";
&gpmc {
status = "okay";
pinctrl-0 = <&gpmc_pins>;
/*ranges = <0 0 0x08000000 0x10000000>; *//* CS0: NAND */
ranges = <0 0 0x08000000 0x10000000>, /*CSn0 for NAND*/
<2 0 0x18000000 0x08000000>; /*CSn2 for FPGA*/
nand@0,0 {
compatible = "ti,omap2-nand";
reg = <0 0 4>; /* CS0, offset 0 */
ti,nand-ecc-opt = "bch8";
ti,elm-id = <&elm>;
nand-bus-width = <16>;
ti,nand-xfer-type = "polled";
rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 */
gpmc,device-width = <1>;
gpmc,sync-clk-ps = <0>;
gpmc,cs-on-ns = <0>;
gpmc,cs-rd-off-ns = <44>;
gpmc,cs-wr-off-ns = <44>;
gpmc,adv-on-ns = <6>;
gpmc,adv-rd-off-ns = <34>;
gpmc,adv-wr-off-ns = <44>;
gpmc,we-on-ns = <0>;
gpmc,we-off-ns = <40>;
gpmc,oe-on-ns = <0>;
gpmc,oe-off-ns = <54>;
gpmc,access-ns = <64>;
gpmc,rd-cycle-ns = <82>;
gpmc,wr-cycle-ns = <82>;
gpmc,wait-on-read = "true";
gpmc,wait-on-write = "true";
gpmc,bus-turnaround-ns = <0>;
gpmc,cycle2cycle-delay-ns = <0>;
gpmc,clk-activation-ns = <0>;
gpmc,wait-monitoring-ns = <0>;
gpmc,wr-access-ns = <40>;
gpmc,wr-data-mux-bus-ns = <0>;
/* MTD partition table */
/* All SPL-* partitions are sized to minimal length
* which can be independently programmable. For
* NAND flash this is equal to size of erase-block */
#size-cells = <1>;
partition@0 {
label = "NAND.SPL";
reg = <0x00000000 0x000020000>;
partition@1 {
label = "NAND.SPL.backup1";
reg = <0x00020000 0x00020000>;
partition@2 {
label = "NAND.SPL.backup2";
reg = <0x00040000 0x00020000>;
partition@3 {
label = "NAND.SPL.backup3";
reg = <0x00060000 0x00020000>;
partition@4 {
label = "NAND.u-boot-spl-os";
reg = <0x00080000 0x00040000>;
partition@5 {
label = "NAND.u-boot";
reg = <0x000C0000 0x00100000>;
partition@6 {
label = "NAND.u-boot-env";
reg = <0x001C0000 0x00020000>;
partition@7 {
label = "NAND.u-boot-env.backup1";
reg = <0x001E0000 0x00020000>;
partition@8 {
label = "NAND.kernel";
reg = <0x00200000 0x00800000>;
partition@9 {
label = "NAND.file-system";
reg = <0x00A00000 0x0F600000>;
fpga{
reg = <2 0 0x10000000>; /*CSn2*/
compatible = "xillybus,xillybus-1.00.a";
#size-cells = <0>;
bank-width = <2>; /* GPMC_CONFIG1_DEVICESIZE(1) *//*16 bit wide*/
/*gpmc,burst-write;*/
/*gpmc,burst-read;*/
/*gpmc,burst-wrap;*/
gpmc,sync-read; /* GPMC_CONFIG1_READTYPE_ASYNC */
gpmc,sync-write; /* GPMC_CONFIG1_WRITETYPE_ASYNC */
gpmc,clk-activation-ns = <0>; /* GPMC_CONFIG1_CLKACTIVATIONTIME(2) */
gpmc,burst-length = <16>; /* GPMC_CONFIG1_PAGE_LEN(2) */
gpmc,mux-add-data = <2>; /* GPMC_CONFIG1_MUXTYPE(2) */
gpmc,sync-clk-ps = <20000>; /* CONFIG2 */
gpmc,cs-rd-off-ns = <100>;
gpmc,cs-wr-off-ns = <40>;
gpmc,adv-on-ns = <0>; /* CONFIG3 */
gpmc,adv-rd-off-ns = <20>;
gpmc,adv-wr-off-ns = <20>;
gpmc,we-on-ns = <20>; /* CONFIG4 */
gpmc,oe-on-ns = <20>;
gpmc,oe-off-ns = <100>;
gpmc,page-burst-access-ns = <20>; /* CONFIG 5 */
gpmc,access-ns = <80>;
gpmc,rd-cycle-ns = <120>;
gpmc,wr-cycle-ns = <60>;
gpmc,wr-access-ns = <40>; /* CONFIG 6 */
gpmc,wr-data-mux-bus-ns = <20>;
/*gpmc,bus-turnaround-ns = <40>;*/ /* CONFIG6:3:0 = 4 */
gpmc,cycle2cycle-samecsen; /* CONFIG6:7 = 1 */
gpmc,cycle2cycle-delay-ns = <20>; /* CONFIG6:11:8 = 4 */
/* not using dma engine yet, but we can get the channel number here */
dmas = <&edma 1>;
dma-names = "cscdma";
Murugan S
