Part Number: DRA76P
Tool/software: Linux
We are trying to implement Ethernet-AVB on J6+ board.
Which AVB stack will support Jacinto 6 plus. Please provide supporting documents available to implement AVB on jacinto board.
Thank you,
Deepthi
Part Number: DRA76P
Thank you,
Deepthi
Deepthi
We do not support ethernet AVB stack as part of the Linux SDK offering.
For typical Use cases, the ethernet AVB stack is supported by our 3P ecosystem (including running the stack from RTOS environment from M4 or A15 cores)
Hi Sriram,
Will you please provide the driver if available.
Thank you,
Deepthi
I need to integrate TI CPTS driver with the existing OpenAVNU stack.
Is there any existing AvNU stack available with CPTS integrated?
If not, what changes do we need to make in the stack for integrating with CPTS?
Deepthi
Hi
From Linux we have not integrated with AVB stack before and there are no plans to do so.
Hence dont have much insight into the OpenAVNU stack integration.
Hi Sriram,
CPSW driver -> Is there a design doc/ user manual on this? Basically I want to understand how to use.
Is it a RAW ethernet driver?
I don't need the switch functionality. What should the dts look like?
Any user page / examples on using it for DRA7x?
From the AVB point of view, just wanted to confirm if the support for the following is available in the cspw/ cpts driver and the switch IP on DRA7x.
Hi Sriram,
Thanks. I understand that.
802.1AS is supported on Linux.
But on the cpsw hardware (DRA76P), are the 802.1Qat, 802.1Qav supported?
-Ramesh
Hi
from SW support perspective, the linux driver supports the time sync feature alone.
from CPSW Ip standpoint, the capabilities are called out in the TRM , please refer section on "Audio Video Bridging" under the "Gigabit ethernet Switch" Chapter of the TRM
