RTOS/DRA745: run rtos error: Jumping to MPU CPU0 App
Part Number: DRA745
Tool/software: TI-RTOS
TDA2xx SBL Boot
DPLL Configuration Completed
Clock Domain Configuration Completed
Module Enable Configuration Completed
TI EVM PAD Config Completed
DDR Config Completed
App Image Download Begins
SD Boot - file open completed successfully
MPU CPU0 Image Load Completed
IPU1 CPU1 Image Load Completed
IPU2 CPU0 and CPU1 Image Load Completed
DSP1 Image Load Completed
DSP2 Image Load Completed
EVE1 Image Load Completed
EVE2 Image Load Completed
EVE3 Image Load Completed
EVE4 Image Load Completed
App Image Download Completed
Putting MPU CPU1 in Off mode
EVE MMU configuration completed
PMCCNTR counts once every 64 clock cycles, multiple by 64 to get actual CPU cycles
SBL Initial Config Cycles - 144553 (12.33 ms)
SOC Init Cycles - 164782 (14.6 ms)
DDR Config Clock Cycles - 43438 (3.70 ms)
App Image Load Cycles - 231177367 (19727.13 ms)
Slave Core Bootup Cycles - 208367 (17.78 ms)
SBL Boot-up Cycles - 231739570 (19775.10 ms)
Time at which SBL started IPU1_0 - 7072608 (603.52 ms)
It stop here. could you give some comments ? thanks.
    There could be various causes of this issue.
    What are the changes have you made?
    First try to find out which core is causing this.
    Try first by enabling only IPU1_0 and check and keep on adding 1 core at a time and check.
    You need to connect CCS and check where exactly it is stuck.?
    Anuj
    Its been long since any update on this thread.
    I hope you are able to resolve your issue.
    If not then please reply below or create a new thread for some different query.
    Anuj
