Part Number: TDA4VMXEVM
Other Parts Discussed in Thread: TDA2
I'm evaluating On Semi AR0323 sensor in TDA4EVM + custom AR0323 sensor board with PSDKRA v0.91.
The camera app is app_single_cam, and iss_sensor_ar0233.c is modified for AR0323 (configuration and serdes)
power_on, reset, i2c, streaming on are ok, sensor mipi signal is ok.
But only 1st raw capture is ok by save_debug_images() in app_single_cam.
There're no further operations and display output.
Please refer to the following log. tivx_set_debug_zone(VX_ZONE_API/ VX_ZONE_INFO) was added to get tiovx log
Kim HJ
root@j7-evm:~/nfs/opt/vision_apps# ./vx_app_single_cam.out
APP: Init ... !!!
APP_LOG: Mapping 0xb8000000 ...
APP_LOG: Mapped 0xb8000000 -> 0xffff9d780000 of size 262144 bytes
MEM: Init ... !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
APP_LOG: Mapping 0xb8040000 ...
APP_LOG: Mapped 0xb8040000 -> 0xffff777c0000 of size 33292288 bytes
APP_LOG: Mapping 0x30e00000 ...
APP_LOG: Mapped 0x30e00000 -> 0xffff9dc90000 of size 3072 bytes
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
APP: Init ... Done !!!
0.000144 s: VX_ZONE_INIT:Enabled
0.000153 s: VX_ZONE_ERROR:Enabled
0.000157 s: VX_ZONE_WARNING:Enabled
0.000161 s: VX_ZONE_API:Enabled
0.000165 s: VX_ZONE_INFO:Enabled
0.000206 s: VX_ZONE_INFO:### kimhj source_platform_psdk_j7_common_tivx_init.c
0.000485 s: VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
0.000669 s: VX_ZONE_INIT:[tivxHostInit:35] Initialization Done for HOST !!!
0.001239 s: ISS: Enumerating sensors ... !!!
0.004304 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
0.004327 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
0.004332 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
[MCU2_1] 1331.204468 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_CREATE
[MCU2_1] 1331.204549 s: Sensor at index 0 = IMX390-UB953_D3
[MCU2_1] 1331.204584 s: Sensor at index 1 = AR0233-UB953_MARS
[MCU2_1] 1331.204611 s: Sensor at index 2 = AR0820-UB953_LI
3 sensor(s) found
Supported sensor list:
a : IMX390-UB953_D3
b : AR0233-UB953_MARS
c : AR0820-UB953_LI
Select a sensor
b
Sensor selected : AR0233-UB953_MARS
LDC Selection Yes(1)/No(0)
0
Querying AR0233-UB953_MARS
28.155107 s: ISS: Querying sensor [AR0233-UB953_MARS] ... !!!
28.155393 s: ISS: Querying sensor [AR0233-UB953_MARS] ... Done !!!
28.155399 s: ISS: Initializing sensor [AR0233-UB953_MARS], doing IM_SENSOR_CMD_PWRON ... !!!
[MCU2_1] 1359.357684 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_QUERY
[MCU2_1] 1359.357737 s: Received Query for AR0233-UB953_MARS
[MCU2_1] 1359.357790 s: Sensor name is IMX390-UB953_D3
[MCU2_1] 1359.357836 s: Sensor name is AR0233-UB953_MARS
[MCU2_1] 1359.357951 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_PWRON
28.170422 s: ISS: Initializing sensor [AR0233-UB953_MARS], doing IM_SENSOR_CMD_CONFIG ... !!!
[MCU2_1] 1359.372979 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_CONFIG
[MCU2_1] 1359.373033 s: Application requested features = 0x158
[MCU2_1]
[MCU2_1] 1359.373069 s: UB960 config start
[MCU2_1] 1359.612927 s: End of UB960 config
[MCU2_1] 1359.612969 s: Configuring camera # 0
[MCU2_1] 1359.712922 s: Configuring AR0233 imager .. Please wait till it finishes
[MCU2_1] 1360.780909 s: AR0233 config done
[MCU2_1] 1360.781294 s: AR0323_Probe SUCCESS : Read expected value 0xd56 at chip ID register 0x3000
[MCU2_1] 1360.781338 s: IM_SENSOR_CMD_CONFIG returning status = 0
29.578991 s: ISS: Initializing sensor [AR0233-UB953_MARS] ... Done !!!
Enabling LDC
32.595305 s: VX_ZONE_INFO:[ownGraphNodeKernelInit:547] kernel init for node 0, kernel com.ti.capture ...
32.836263 s: VX_ZONE_INFO:[ownGraphNodeKernelInit:559] kernel init for node 0, kernel com.ti.capture ... done !!!
32.836270 s: VX_ZONE_INFO:[ownGraphNodeKernelInit:547] kernel init for node 1, kernel com.ti.hwa.vpac_viss ...
33.065911 s: VX_ZONE_INFO:[ownGraphNodeKernelInit:559] kernel init for node 1, kernel com.ti.hwa.vpac_viss ... done !!!
33.065918 s: VX_ZONE_INFO:[ownGraphNodeKernelInit:547] kernel init for node 2, kernel com.ti.imaging.aewb ...
33.067915 s: VX_ZONE_INFO:[ownGraphNodeKernelInit:559] kernel init for node 2, kernel com.ti.imaging.aewb ... done !!!
33.067921 s: VX_ZONE_INFO:[ownGraphNodeKernelInit:547] kernel init for node 3, kernel com.ti.hwa.vpac_ldc ...
[MCU2_1] 1364.268670 s: VX_ZONE_INFO:[tivxAewbCreate:594] tivxAewbCreate : DCC ID = 233
[MCU2_1] 1364.268726 s: VX_ZONE_INFO:[tivxAewbCreate:595] tivxAewbCreate : Image Format = 0
[MCU2_1] 1364.268765 s: VX_ZONE_INFO:[tivxAewbCreate:596] tivxAewbCreate : Phase = 3
[MCU2_1] 1364.268800 s: VX_ZONE_INFO:[tivxAewbCreate:597] tivxAewbCreate : awb_mode = 0
[MCU2_1] 1364.268834 s: VX_ZONE_INFO:[tivxAewbCreate:598] tivxAewbCreate : awb_mode = 0
[MCU2_1] 1364.268870 s: VX_ZONE_INFO:[tivxAewbCreate:599] tivxAewbCreate : awb_num_skip_frames = 0
[MCU2_1] 1364.268938 s: VX_ZONE_INFO:[tivxAewbCreate:600] tivxAewbCreate : ae_num_skip_frames = 0
[MCU2_1] 1364.268981 s: VX_ZONE_INFO:[tivxAewbCreate:607] tivxAewbCreate : DCC Numbytes = 26307
[MCU2_1] 1364.269043 s: VX_ZONE_INFO:[tivxAewbCreate:618] Before dcc_update : awb_calb_data.radius = 0xf8f8fcf8
[MCU2_1] 1364.269369 s: VX_ZONE_INFO:[tivxAewbCreate:623] After dcc_update : awb_calb_data.radius = 0x32
33.169627 s: VX_ZONE_INFO:[ownGraphNodeKernelInit:559] kernel init for node 3, kernel com.ti.hwa.vpac_ldc ... done !!!
33.169634 s: VX_ZONE_INFO:[ownGraphNodeKernelInit:547] kernel init for node 4, kernel com.ti.hwa.display ...
33.170265 s: VX_ZONE_INFO:[ownGraphNodeKernelInit:559] kernel init for node 4, kernel com.ti.hwa.display ... done !!!
33.238250 s: VX_ZONE_INFO:[tivxDataRefQueueEnqueueReadyRef:88] Q (queue=67, ref=2)
33.238263 s: VX_ZONE_INFO:[tivxDataRefQueueEnqueueReadyRef:88] Q (queue=75, ref=18)
33.238270 s: VX_ZONE_INFO:[tivxDataRefQueueEnqueueReadyRef:88] Q (queue=83, ref=19)
33.238277 s: VX_ZONE_INFO:[tivxDataRefQueueEnqueueReadyRef:88] Q (queue=67, ref=4)
33.238283 s: VX_ZONE_INFO:[tivxDataRefQueueEnqueueReadyRef:88] Q (queue=75, ref=19)
33.238289 s: VX_ZONE_INFO:[tivxDataRefQueueEnqueueReadyRef:88] Q (queue=83, ref=20)
33.238294 s: ISS: Starting sensor [AR0233-UB953_MARS] ... !!!
[MCU2_1] 1364.440750 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_STREAM_ON
[MCU2_1] 1364.440825 s: IM_SENSOR_CMD_STREAM_ON: channel_mask = 0x1
[MCU2_1] 1364.440857 s: Starting camera # 0
[MCU2_1] 1364.440919 s: Entering IssSensor_Start
33.248648 s: ISS: Starting sensor [AR0233-UB953_MARS] ... !!!
33.248657 s: VX_ZONE_INFO:[tivxDataRefQueueEnqueueReadyRef:88] Q (queue=67, ref=6)
33.248667 s: VX_ZONE_INFO:[ownGraphScheduleGraph:680] Scheduling Graph (graph=102, pipe=0)
33.248673 s: VX_ZONE_INFO:[ownNodeKernelSchedule:544] Scheduling Node (node=9, pipe=0)
33.248685 s: VX_ZONE_INFO:[tivxDataRefQueueEnqueueReadyRef:88] Q (queue=75, ref=20)
33.248692 s: VX_ZONE_INFO:[tivxDataRefQueueEnqueueReadyRef:88] Q (queue=83, ref=18)
33.248699 s: VX_ZONE_INFO:[tivxDataRefQueueDequeueDoneRef:161] DQ (queue=68) .. NO BUFFER
[MCU2_1] 1364.450899 s: UB960 config start
[MCU2_1] 1364.450979 s: End of UB960 config
[MCU2_1] 1364.451179 s: VX_ZONE_INFO:[tivxTargetNodeDescNodeExecute:584] Node (node=9, pipe=0) acquiring parameters on target 00000068
[MCU2_1] 1364.451266 s: VX_ZONE_INFO:[tivxTargetNodeDescAcquireParameterForPipeup:249] Parameter acquired for pipe up (node=9, pipe=0, data_ref_q=61, queue=67, ref=2)
[MCU2_1] 1364.451421 s: VX_ZONE_INFO:[tivxTargetNodeDescAcquireParameterForPipeup:249] Parameter acquired for pipe up (node=9, pipe=0, data_ref_q=61, queue=67, ref=4)
[MCU2_1] 1364.451546 s: VX_ZONE_INFO:[tivxTargetNodeDescAcquireParameter:177] Parameter acquired (node=9, pipe=0, data_ref_q=61, queue=67, ref=6)
[MCU2_1] 1364.451618 s: VX_ZONE_INFO:[tivxTargetNodeDescNodeExecute:642] Node (node=9, pipe=0) executing on target 00000068
[MCU2_1] 1364.496012 s: VX_ZONE_INFO:[tivxTargetNodeDescNodeExecute:665] Node (node=9, pipe=0) executing on target 00000068 ... DONE !!!
[MCU2_1] 1364.496096 s: VX_ZONE_INFO:[tivxTargetNodeDescReleaseParameter:442] Parameter NOT released (node=9, pipe=0, data_ref_q=61, ref=2, users=1)
[MCU2_1] 1364.496212 s: VX_ZONE_INFO:[tivxTargetNodeDescNodeExecute:584] Node (node=21, pipe=0) acquiring parameters on target 00000067
[MCU2_1] 1364.496291 s: VX_ZONE_INFO:[tivxTargetNodeDescAcquireParameter:177] Parameter acquired (node=21, pipe=0, data_ref_q=69, queue=75, ref=18)
[MCU2_1] 1364.496362 s: VX_ZONE_INFO:[tivxTargetNodeDescAcquireParameter:187] Parameter ALREADY acquired (node=21, pipe=0, data_ref_q=61, ref=2)
[MCU2_1] 1364.496432 s: VX_ZONE_INFO:[tivxTargetNodeDescAcquireParameter:177] Parameter acquired (node=21, pipe=0, data_ref_q=85, queue=88, ref=10)
[MCU2_1] 1364.496499 s: VX_ZONE_INFO:[tivxTargetNodeDescAcquireParameter:177] Parameter acquired (node=21, pipe=0, data_ref_q=89, queue=92, ref=16)
[MCU2_1] 1364.496559 s: VX_ZONE_INFO:[tivxTargetNodeDescNodeExecute:642] Node (node=21, pipe=0) executing on target 00000067
Demo : Single Camera w/ 2A
p: Print performance statistics
s: Save Sensor RAW, VISS Output and H3A output images to File System
x: Exit
Enter Choice: s
Test data path is NULL. Defaulting to current folder
RAW file name capture/./img_0000_1920x1080.g12l
YUV file name capture/./img_0000.yuv
out width = 1920
out height = 1080
out format = 842094158
H3A file name capture/./h3a_0000.bin
