SDK_VISION RVC on HDMI TDA76P
HI Rishabh,
I have the same issues here we are using vsdk to implement rvc application usecase for   our custom board based on tda76p, i did all the changes and patches that TI provided us , but untill now , the hdmi display don t shows any think at boot up , i saw in this post that we should add custom board and reconfigure the I2C instance please can you provide us how to do that ? . also i give you the  traces on ipu2 and dsp1 below :
cat /d/remoteproc/remoteproc1/trace0
[0][ 0.000] 18 Resource entries at 0x99000000
[0][ 0.000] 0.427591 s: SYSTEM: System Common Init in progress !!!
[1][ 0.001] [t=0x000a6f09] ti.ipc.family.vayu.VirtQueue: vring: 0 0x60000000 (0x3000)
[1][ 0.001]
[1][ 0.001] [t=0x000aab3c] ti.ipc.family.vayu.VirtQueue: vring: 1 0x60004000 (0x3000)
[1][ 0.001]
[1][ 0.002] [t=0x000ac52e] ti.ipc.family.vayu.VirtQueue: VirtQueue_startup: VDEV status: 0x0
[1][ 0.002]
[1][ 0.002] [t=0x000ad8a5] ti.ipc.family.vayu.VirtQueue: VirtQueue_startup: Polling VDEV status...
[1][ 0.002]
[0][ 0.010] 0.437015 s: SYSTEM: IPC init in progress !!!
[0][ 0.010] 0.437290 s: SYSTEM: Attaching to [DSP1] ...
[0][ 0.013] 0.439882 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[0][ 0.013] 0.440218 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[0][ 0.013] 0.440553 s: SYSTEM: Notify init done !!!
[0][ 0.015] 0.442475 s: SYSTEM: MsgQ init done !!!
[0][ 0.015] 0.442719 s: SYSTEM: IPC init DONE !!!
[0][ 0.024] 0.450863 s: SYSTEM: System Common Init Done !!!
[0][ 0.024] 0.451198 s: SYSTEM: System Init in progress !!!
[0][ 0.024] 0.451412 s: SYSTEM: BSP Common Init in progress !!!
[0][ 0.024] 0.451625 s: SYSTEM: BSP Common Init Done !!!
[0][ 0.025] 0.451839 s: SYSTEM: BSP Platform Init in progress !!!
[0][ 0.025] 0.452144 s: SYSTEM: BSP Platform Init Done !!!
[0][ 0.025] 0.452357 s: SYSTEM: FVID2 Init in progress !!!
[0][ 0.025] 0.452662 s: SYSTEM: FVID2 Init Done !!!
[0][ 0.026] 0.452876 s: SYSTEM: VPS Init in progress !!!
[0][ 0.026] 0.453120 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000]
[0][ 0.029] 0.456414 s: *** VPDMA Firmware Loading... ***
[0][ 0.029] 0.456688 s: VPDMA Firmware Address = 0xa035aec0
[0][ 0.030] 0.456993 s: VPDMA Load Address = 0x4897d004
[0][ 0.030] 0.457237 s: VPDMA Firmware Version = 0x4d0001b8
[0][ 0.030] 0.457481 s: VPDMA List Busy Status = 0x00000000
[0][ 0.030] 0.457695 s: *** VPDMA Firmware Load Success ***
[0][ 0.030]
[0][ 0.031] 0.458244 s: *** VPDMA Firmware Loading... ***
[0][ 0.031] 0.458488 s: VPDMA Firmware Address = 0xa035aec0
[0][ 0.031] 0.458732 s: VPDMA Load Address = 0x4899d004
[0][ 0.032] 0.459006 s: VPDMA Firmware Version = 0x4d0001b8
[0][ 0.032] 0.459250 s: VPDMA List Busy Status = 0x00000000
[0][ 0.032] 0.459464 s: *** VPDMA Firmware Load Success ***
[0][ 0.032]
[0][ 0.033] 0.460013 s: *** VPDMA Firmware Loading... ***
[0][ 0.033] 0.460257 s: VPDMA Firmware Address = 0xa035aec0
[0][ 0.033] 0.460470 s: VPDMA Load Address = 0x489dd004
[0][ 0.033] 0.460714 s: VPDMA Firmware Version = 0x4d0001b8
[0][ 0.034] 0.460989 s: VPDMA List Busy Status = 0x00000000
[0][ 0.034] 0.461233 s: *** VPDMA Firmware Load Success ***
[0][ 0.034]
[0][ 0.103] 0.529890 s: SYSTEM: VPS Init Done !!!
[0][ 0.104] 0.531842 s: UTILS: DMA: HWI Create for INT25 !!!
[0][ 0.105] 0.532330 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[0][ 0.106] 0.532666 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 259784 B (253 KB)
[0][ 0.106] 0.533184 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[0][ 0.107] 0.533611 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 346030080 B (330 MB), Free size = 346030080 B (330 MB)
[0][ 0.107] 0.534191 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1047040 B (0 MB), Free size = 1038592 B (0 MB)
[0][ 0.107] 0.534679 s: SYSTEM: Initializing Links !!!
[0][ 0.293] 0.720124 s: SYSTEM: Initializing Links ... DONE !!!
[0][ 0.296] 0.723723 s: BOARD: Board Init in progress !!!
[0][ 0.297] 0.724333 s: BOARD: Board Init Done !!!
[0][ 0.308] 0.735496 s:
[0][ 0.317] 0.744128 s: dispcore/src/vpscore_dctrl.c @ Line 1934: 0.744342 s: vpscore_dctrlHdmiPowerOn(&hdmiConf)ahmed printVPS_DCTRL_DSS_VENC_HDMI= 8
[0][ 0.385] 0.811779 s: DISPLAY: Create in progress !!!
[0][ 0.386] 0.812816 s: DISPLAY: Create Done !!!
[0][ 0.386] 0.813212 s: GRPXSRC: Create in progress !!!
[0][ 0.418] 0.844811 s: GRPXSRC: Create Done !!!
[0][ 0.418] 0.845269 s: DISPLAY: Create in progress !!!
[0][ 0.419] 0.846153 s: DISPLAY: Create Done !!!
[0][ 0.420] 0.847190 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[0][ 0.420] 0.847526 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 256904 B (250 KB)
[0][ 0.421] 0.848044 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[0][ 0.421] 0.848502 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 346030080 B (330 MB), Free size = 342091776 B (326 MB)
[0][ 0.422] 0.849051 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1047040 B (0 MB), Free size = 1038592 B (0 MB)
[0][ 0.422] 0.849600 s: CHAINS: Sensor create in progress
[0][ 0.423] 0.849844 s: VIDEO_DECODER: ********** CREATE **********
[0][ 0.423] 0.850149 s: src/bsp_boardTda2xx.c @ Line 865: 0.850332 s: ahmed BSP_BOARD_CUSTOM device !!
[0][ 0.424] 0.850576 s: src/bsp_boardTda2xx.c @ Line 877: 0.850759 s: ahmed BSP_BOARD_CUSTOM boardData->numDev== 0 !!
[0][ 0.424] 0.851094 s: src/bsp_boardTda2xx.c @ Line 865: 0.851277 s: ahmed BSP_BOARD_CUSTOM device !!
[0][ 0.424] 0.851521 s: src/bsp_boardTda2xx.c @ Line 877: 0.851704 s: ahmed BSP_BOARD_CUSTOM boardData->numDev== 0 !!
[0][ 0.425] 0.852010 s: src/bsp_board.c @ Line 482: 0.852162 s: ahmed Invalid device driver ID!!
[0][ 0.425] 0.852437 s: src/bsp_boardTda2xx.c @ Line 865: 0.852589 s: ahmed BSP_BOARD_CUSTOM device !!
[0][ 0.426] 0.852833 s: src/bsp_boardTda2xx.c @ Line 877: 0.853047 s: ahmed BSP_BOARD_CUSTOM boardData->numDev== 0 !!
[0][ 0.426] 0.853352 s: src/bsp_board.c @ Line 515: 0.853504 s: Invalid device driver ID!!
[0][ 0.427] 0.853779 s: src/bsp_boardTda2xx.c @ Line 865: 0.853962 s: ahmed BSP_BOARD_CUSTOM device !!
[0][ 0.427] 0.854236 s: src/bsp_boardTda2xx.c @ Line 877: 0.854419 s: ahmed BSP_BOARD_CUSTOM boardData->numDev== 0 !!
[0][ 0.428] 0.854724 s: src/bsp_boardTda2xx.c @ Line 865: 0.854877 s: ahmed BSP_BOARD_CUSTOM device !!
[0][ 0.428] 0.855182 s: src/bsp_boardTda2xx.c @ Line 877: 0.855334 s: ahmed BSP_BOARD_CUSTOM boardData->numDev== 0 !!
[0][ 0.429] 0.855670 s: src/bsp_boardTda2xx.c @ Line 865: 0.855822 s: ahmed BSP_BOARD_CUSTOM device !!
[0][ 0.429] 0.856097 s: src/bsp_boardTda2xx.c @ Line 877: 0.856280 s: ahmed BSP_BOARD_CUSTOM boardData->numDev== 0 !!
[0][ 0.429] 0.856615 s: CHAINS: Sensor create ... DONE !!!
[0][ 0.430] 0.856859 s: DISPLAY: Start in progress !!!
[0][ 0.430] 0.857134 s: DISPLAY: Start Done !!!
[0][ 0.431] 0.857805 s: DISPLAY: Start in progress !!!
[0][ 0.431] 0.858079 s: DISPLAY: Start Done !!!
[0][ 0.432] 0.858903 s: CALLING Board_deInit
[1][ 11.555] [t=0x0dd0ad39] ti.ipc.family.vayu.VirtQueue: VirtQueue_startup: VDEV status: 0x7
cat /d/remoteproc/remoteproc2/trace0
[ 0.000] 25 Resource entries at 0xa1000000
[ 0.000] 0.421704 s: SYSTEM: System Common Init in progress !!!
[ 0.000] 0.421948 s: SYSTEM: IPC init in progress !!!
[ 0.000] 0.422039 s: SYSTEM: Attaching to [IPU2] ...
[ 0.018] 0.439882 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[ 0.018] 0.440004 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[ 0.018] 0.440126 s: SYSTEM: Notify init done !!!
[ 0.018] 0.440340 s: SYSTEM: MsgQ init done !!!
[ 0.018] 0.440431 s: SYSTEM: IPC init DONE !!!
[ 0.019] 0.441590 s: SYSTEM: System Common Init Done !!!
[ 0.020] 0.441682 s: SYSTEM: System DSP Init in progress !!!
[ 0.020] 0.442627 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[ 0.021] 0.442780 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[ 0.021] 0.442932 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 522304 B (510 KB)
[ 0.021] 0.443085 s: SYSTEM: Initializing Links !!!
[ 0.038] 0.460501 s: SYSTEM: Initializing Links ... DONE !!!
[ 0.038] 0.460592 s: SYSTEM: System DSP Init Done !!!
[ 0.302] 0.723723 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
[ 0.302] 0.723845 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
[ 0.424] 0.846580 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[ 0.425] 0.846702 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[ 0.425] 0.846855 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 522144 B (509 KB)
Best Regards
AHMED
