TDA4VM: The version of objcopy which support binary files in TI format
Part Number: TDA4VM
Hi
■What I want to do
I want to generate binary files in raw data format that will be extracted into memory for the boot loader.
■What I've confirmed.
Since the compiler manual says the above, I decided to use "objcopy" as Hex utility.
I chose "objcopy", which is included in MinGW's binutils.
The download page is as follows.
https://osdn.net/projects/mingw/releases/70619
The format supported by this objcpy is as follows.
supported targets: pe-i386 pei-i386 elf32-i386 elf32-iamcu elf32-little elf32-big plugin srec symbolsrec verilog tekhex binary ihex
When I select the *.out file generated after building a C7x project, I get the following message and cannot convert it
DspMain.out: file format not recognized
■Questions.
Does this revision of objcopy support binary files in TI format?
If not, please let me know which version you have experience with.
If possible, please provide a command line example for objcopy.
