My customer would like to know for what the JESD_PHASE_MODE bits of the JESD Lane Enable Register.
Please elaborate.
And in case of the Wideband-DUC mode with LMFSHd = 82380, what should those bits be set?
K.Hirano
Please elaborate.
K.Hirano
Hi K.Hirano
In order to minimize clock spurs the lane clock used in the JESD RX clock will be made up of multiple phases. Depending on the mode, you would need to change the JESD_PHASE_MODE bits to have 1, 2, 4 or 8 clock phases available.
In table 41 of the datasheet, the column titled “CLOCK PHASES (1-0)” shows the value for each of the different modes based on the interpolation value. So, for the 82380 LMFS mode you would set the JESD_PHASE_MODE bits to 00 if you are using an interpolation value of 1 or 2.
Camilo
