AWR2243: Setup the BPM configuration
Part Number: AWR2243
Hi Team,
Our customer is using AWR2243 with DCA100 and wants to learn how to set up the BPM configuration in the mmwaveconfig.txt file
In mmwave studio, the json file output looks like this
in mmwaveconfig.txt it looks like this, but I don't get the same results
#For detailed view of mmWave Radar configuration structure
#please refer
#ti\control\mmwavelink\docs\doxygen\html\index.html
#please refer
#Global configuration
#Advanced frame test enable/disable; 1 - Advanced frame; 0 - Legacy frame
#Continuous mode test enable/disable; 1 - Enable; 0 - Disable
#Dynamic chirp test enable/disable; 1 - Enable; 0 - Disable; This should not be enabled if Advanced chirp test is enabled
#Dynamic profile test enable/disable; 1 - Enable; 0 - Disable
#Advanced chirp test enable/disable; 1 - Enable; 0 - Disable; The legacy chirp API is not required if this is enabled
#Firmware download enable/disable; 1 - Enable; 0 - Disable
#mmWaveLink logging enable/disable; 1 - Enable; 0 - Disable
#Calibration enable/disable; To perform calibration store/restore; 1 - Enable; 0 - Disable
#Calibration Store/Restore; If CalibEnable = 1, then whether to store/restore; 1 - Store; 0 - Restore
#Transport mode; 1 - I2C; 0 - SPI
#Flash connected enable/disable; 1 - Enable; 0 - Disable
LinkAdvanceFrameTest=0;
LinkContModeTest=0;
LinkDynChirpTest=1;
LinkDynProfileTest=0;
LinkAdvChirpTest=0;
EnableFwDownload=1;
EnableMmwlLogging=0;
CalibEnable=0;
CalibStoreRestore=1;
TransferMode=0;
IsFlashConnected=1;
#END
#power on master arguments, please modify if needed.
#rlClientCbs_t: crcType 0:16Bit/1:32Bit/2:64Bit, ackTimeout
crcType=1;
ackTimeout=50000;
#END
## Custom for TDM
#waveformType = "legacyFrameChirp";
#MIMOScheme = "TDM";
#END
#channel config parameters, please modify if needed.
#rlChanCfg_t
channelTx=7;
channelRx=15;
cascading=0;
#END
#ADC out config parameters, please modify if needed.
#rlAdcOutCfg_t
adcBits=2;
adcFormat=1;
#END
#DATA format config parameters, please modify if needed.
#rlDevDataFmtCfg_t
rxChanEn=15;
adcBitsD=2;
adcFmt=1;
iqSwapSel=0;
chInterleave=0;
#END
#Low power config Paramters, please modify if needed.
#rlLowPowerModeCfg_t
anaCfg=0;
lpAdcMode=0;
#END
#Data Path config parameters, please modify if needed
#rlDevDataPathCfg_t
intfSel=1;
transferFmtPkt0=1;
transferFmtPkt1=0;
cqConfig=0;
cq0TransSize=0;
cq1TransSize=0;
cq2TransSize=0;
#END
#LVDS clock config parameters, please modify if needed
#rlDevDataPathClkCfg_t
laneClk=1;
dataRate=1;
#END
#SET HSI clock parameters, please modify if needed.
#rlDevHsiClk_t
hsiClk=9
#END
#LANE config parameters, please modify if needed.
#rlDevLaneEnable_t
laneEn=15;
#laneEn=3;
#END
#LVDS Lane Config parameters, please modify if needed.
#rlDevLvdsLaneCfg_t
laneFmtMap=0;
laneParamCfg=1;
#END
#Profile config parameters, please modify if needed.
#rlProfileCfg_t
profileId=0;
pfVcoSelect=0;
startFreqConst=1435384035;
idleTimeConst=10000;
adcStartTimeConst=500;
rampEndTime=5000;
txOutPowerBackoffCode=0;
txPhaseShifter=0;
freqSlopeConst=1655.03515;
txStartTime=0;
numAdcSamples=256;
digOutSampleRate=5688;
hpfCornerFreq1=0;
hpfCornerFreq2=0;
rxGain=48;
rfGainTarget=1,
#END
#Chirp #1 Configuration parameters, please modify if needed.
#rlChirpCfg_t
# txEnable = {b0 (ant0), b1 (ant1), b2 (ant2)}
# numOfChirpsToConfig = the number of defined chirp configs.
numOfChirpsToConfig=3;
chirpStartIdx=2;
chirpEndIdx=2;
profileIdCPCFG=0;
startFreqVar=0;
freqSlopeVar=0;
idleTimeVar=0;
adcStartTimeVar=0;
txEnable=2;
chirpStartIdx=0;
chirpEndIdx=0;
profileIdCPCFG=0;
startFreqVar=0;
freqSlopeVar=0;
idleTimeVar=0;
adcStartTimeVar=0;
txEnable=1;
chirpStartIdx=1;
chirpEndIdx=1;
profileIdCPCFG=0;
startFreqVar=0;
freqSlopeVar=0;
idleTimeVar=0;
adcStartTimeVar=0;
txEnable=4;
#END
#Frame configuration parameters, please modify if needed.
#rlFrameCfg_t
chirpStartIdxFCF=0;
chirpEndIdxFCF=2;
frameCount=0;
loopCount=88;
periodicity=8000000;
triggerDelay=0;
triggerSelect=1;
#END
# rlBpmChirpCfg_t
chirpStartIdx = 1
chirpEndIdx = 1
constBpmVal = 48 # "0x30" in hex
#END
I shared the E2E thread below but he can't make the bpm work. Can you please help us with this inquiry?
e2e.ti.com/.../4064717
Danilo
