AWR2243BOOST: No CSI output after going through configuration outlined in the nonos example successfully
Part Number: AWR2243BOOST
Other Parts Discussed in Thread: AWR2243
I have the nonos example going on our microcontroller i.e. replacing the DCA1000 to the AWR2243BOOST board using SPI interface. I am able to communicate with the radar device and go through all configuration successfully. I have set the mmw_config.c as follows
void MMWL_getGlobalConfigStatus(rlDevGlobalCfg_t *rlDevGlobalCfgArgs)
//LinkAdvanceFrameTest
rlDevGlobalCfgArgs->LinkAdvanceFrameTest = 0;
//LinkContModeTest
rlDevGlobalCfgArgs->LinkContModeTest = 1;
//LinkDynChirpTest
rlDevGlobalCfgArgs->LinkDynChirpTest = 1;
//LinkDynProfileTest
rlDevGlobalCfgArgs->LinkDynProfileTest = 0;
//LinkAdvChirpTest
rlDevGlobalCfgArgs->LinkAdvChirpTest = 0;
//EnableFwDownload
rlDevGlobalCfgArgs->EnableFwDownload = 0; //Originally 1
//EnableMmwlLogging
rlDevGlobalCfgArgs->EnableMmwlLogging = 0;
//CalibEnable
rlDevGlobalCfgArgs->CalibEnable = 0;
//CalibStoreRestore
rlDevGlobalCfgArgs->CalibStoreRestore = 1;
//TransferMode
rlDevGlobalCfgArgs->TransferMode = 0;
//IsFlashConnected
rlDevGlobalCfgArgs->IsFlashConnected = 1;
As I don't intend to download firmware if anything exists already.
The idea for me here is to get the AWR2243 in a continuous frame output on MIPI/CSI-2. I have commented out the MMWL_gpadcMeasConfig(deviceMap);, MMWL_powerOff(deviceMap); and MMWL_closeConfigFile(); in the mmw_example_nonos.c file. The example outputs
Continuous streaming start/stop successful
Continuous mode disable successful for deviceMap 1
=========== mmWaveLink Example Application execution Successful ===========
=========== mmWaveLink Example Application: Exit ===========
However, I am unable to get any activity on the CSI lanes, all CSI lanes are at about 1.8V. Even a single frame.
I have disabled the LDO. enabled LDO bypass.
Kindly advise.
  • Changing to Enable firmware download and makes no difference
  • I am using configuration below
    #For detailed view of mmWave Radar configuration structure
    #please refer
    #ti\control\mmwavelink\docs\doxygen\html\index.html
    #Global configuration
    #Advanced frame test enable/disable; 1 - Advanced frame; 0 - Legacy frame
    #Continuous mode test enable/disable; 1 - Enable; 0 - Disable
    #Dynamic chirp test enable/disable; 1 - Enable; 0 - Disable; This should not be enabled if Advanced chirp test is enabled
    #Dynamic profile test enable/disable; 1 - Enable; 0 - Disable
    #Advanced chirp test enable/disable; 1 - Enable; 0 - Disable; The legacy chirp API is not required if this is enabled
    #Firmware download enable/disable; 1 - Enable; 0 - Disable
    #mmWaveLink logging enable/disable; 1 - Enable; 0 - Disable
    #Calibration enable/disable; To perform calibration store/restore; 1 - Enable; 0 - Disable
    #Calibration Store/Restore; If CalibEnable = 1, then whether to store/restore; 1 - Store; 0 - Restore
    #Transport mode; 1 - I2C; 0 - SPI
    #Flash connected enable/disable; 1 - Enable; 0 - Disable
    LinkAdvanceFrameTest=0;
    LinkContModeTest=0;
    LinkDynChirpTest=1;
    LinkDynProfileTest=0;
    LinkAdvChirpTest=0;
    EnableFwDownload=1;
    EnableMmwlLogging=0;
    CalibEnable=0;
    CalibStoreRestore=1;
    TransferMode=0;
    IsFlashConnected=1;
    #END
    #power on master arguments, please modify if needed.
    #rlClientCbs_t: crcType 0:16Bit/1:32Bit/2:64Bit, ackTimeout
    crcType=1;
    ackTimeout=1000;
    #END
    #channel config parameters, please modify if needed.
    #rlChanCfg_t
    channelTx=3;
    channelRx=15;
    cascading=0;
    #END
    #ADC out config parameters, please modify if needed.
    #rlAdcOutCfg_t
    adcBits=2;
    adcFormat=2;
    #END
    #DATA format config parameters, please modify if needed.
    #rlDevDataFmtCfg_t
    rxChanEn=15;
    adcBitsD=2;
    adcFmt=1;
    iqSwapSel=0;
    chInterleave=0;
    #END
    #Low power config Paramters, please modify if needed.
    #rlLowPowerModeCfg_t
    anaCfg=0;
    lpAdcMode=0;
    #END
    #Data Path config parameters, please modify if needed
    #rlDevDataPathCfg_t
    intfSel=1;
    transferFmtPkt0=1;
    transferFmtPkt1=0;
    cqConfig=2;
    cq0TransSize=64;
    cq1TransSize=64;
    cq2TransSize=64;
    #END
    #LVDS clock config parameters, please modify if needed
    #rlDevDataPathClkCfg_t
    laneClk=1;
    dataRate=1;
    #END
    #SET HSI clock parameters, please modify if needed.
    #rlDevHsiClk_t
    hsiClk=9
    #END
    #LANE config parameters, please modify if needed.
    #rlDevLaneEnable_t
    laneEn=15;
    #END
    #LVDS Lane Config parameters, please modify if needed.
    #rlDevLvdsLaneCfg_t
    laneFmtMap=0;
    laneParamCfg=1;
    #END
    #Programmable Filter config parameters, please modify if needed.
    #rlRfProgFiltConf_t
    profileId=0;
    coeffStartIdx=0;
    progFiltLen=14;
    progFiltFreqShift=100;
    #END
    #Profile config parameters, please modify if needed.
    #rlProfileCfg_t
    profileId=0;
    pfVcoSelect=2;
    startFreqConst=1439117143;
    idleTimeConst=1000;
    adcStartTimeConst=600;
    rampEndTime=6000;
    txOutPowerBackoffCode=0;
    txPhaseShifter=0;
    freqSlopeConst=621;
    txStartTime=0;
    numAdcSamples=256;
    digOutSampleRate=10000;
    hpfCornerFreq1=0;
    hpfCornerFreq2=0;
    rxGain=30;
    #END
    #rlProfileCfg_t
    profileId=1;
    pfVcoSelect=2;
    idleTimeConst=1000;
    adcStartTimeConst=700;
    rampEndTime=6000;
    txPhaseShifter=0;
    freqSlopeConst=621;
    txStartTime=0;
    numAdcSamples=256;
    hpfCornerFreq1=0;
    hpfCornerFreq2=0;
    rxGain=30;
    #END
    #rlProfileCfg_t
    profileId=2;
    pfVcoSelect=2;
    idleTimeConst=1000;
    adcStartTimeConst=800;
    rampEndTime=6000;
    txPhaseShifter=0;
    freqSlopeConst=621;
    txStartTime=0;
    numAdcSamples=256;
    hpfCornerFreq1=0;
    hpfCornerFreq2=0;
    rxGain=30;
    #END
    #rlProfileCfg_t
    profileId=3;
    pfVcoSelect=2;
    idleTimeConst=1000;
    adcStartTimeConst=900;
    rampEndTime=6000;
    txPhaseShifter=0;
    freqSlopeConst=621;
    txStartTime=0;
    numAdcSamples=256;
    hpfCornerFreq1=0;
    hpfCornerFreq2=0;
    rxGain=30;
    #END
    #Chirp Configuration parameters, please modify if needed.
    #rlChirpCfg_t
    chirpStartIdx=0;
    chirpEndIdx=63;
    profileIdCPCFG=0;
    startFreqVar=0;
    freqSlopeVar=0;
    idleTimeVar=0;
    adcStartTimeVar=0;
    txEnable=1;
    #END
    #rlChirpCfg_t
    chirpStartIdx=64;
    chirpEndIdx=127;
    profileIdCPCFG=0;
    startFreqVar=0;
    freqSlopeVar=0;
    idleTimeVar=0;
    adcStartTimeVar=0;
    txEnable=2;
    #END
    #Frame configuration parameters, please modify if needed.
    #rlFrameCfg_t
    chirpStartIdxFCF=0;
    chirpEndIdxFCF=127;
    frameCount=50;
    loopCount=1;
    periodicity=20000000;
    triggerDelay=0;
    numAdcSamples=512;
    triggerSelect=1;
    #END
    #Advance Frame configuration parameters, please modify if needed.
    numOfSubFrames=4;
    forceProfile=0;
    numFrames=100;
    loopBackCfg=0;
    triggerSelect=1;
    frameTrigDelay=0;
    #end
    #4th sub Frame configuration parameters, please modify if needed.
    forceProfileIdx=0;
    chirpStartIdxAF=0;
    numOfChirps=1;
    numLoops=8;
    burstPeriodicity=5000000;
    chirpStartIdxOffset=0;
    numOfBurst=1;
    numOfBurstLoops=1;
    subFramePeriodicity=5000000;
    numAdcSamplesAF=256
    numChirpsInDataPacket=1
    #end
    #3rd sub Frame configuration parameters, please modify if needed.
    forceProfileIdx=0;
    chirpStartIdxAF=0;
    numOfChirps=1;
    numLoops=8;
    numOfBurst=1;
    numOfBurstLoops=1;
    numAdcSamplesAF=256
    #end
    #2nd sub Frame configuration parameters, please modify if needed.
    forceProfileIdx=0;
    chirpStartIdxAF=0;
    numOfChirps=1;
    numLoops=8;
    numOfBurst=1;
    numOfBurstLoops=1;
    numAdcSamplesAF=256
    #end
    #1st sub Frame configuration parameters, please modify if needed.
    forceProfileIdx=0;
    chirpStartIdxAF=0;
    numOfChirps=1;
    numLoops=8;
    numOfBurst=1;
    numOfBurstLoops=1;
    numAdcSamplesAF=256
    #end
    #Continuous mode config parameters
    #startFreqConst=1435384036;
    #txOutPowerBackoffCode=0;
    #txPhaseShifter=0;
    #digOutSampleRate=10000;
    #hpfCornerFreq1=0;
    #hpfCornerFreq2=0;
    contModeRxGain=30;
    vcoSelect=3388;
    #end
    #Advanced chirp config parameters
    AdvChirp_chirpParamIdx=0;
    AdvChirp_resetMode=0;
    AdvChirp_deltaResetPeriod=0;
    AdvChirp_deltaParamUpdatePeriod=0;
    AdvChirp_sf0ChirpParamDelta=0;
    AdvChirp_sf1ChirpParamDelta=0;
    AdvChirp_sf2ChirpParamDelta=0;
    AdvChirp_sf3ChirpParamDelta=0;
    AdvChirp_lutResetPeriod=4;
    AdvChirp_lutParamUpdatePeriod=1;
    AdvChirp_lutPatternAddressOffset=0;
    AdvChirp_numPatterns=4;
    AdvChirp_lutBurstIndexOffset=0;
    AdvChirp_lutSfIndexOffset=0;
    AdvChirp_lutChirpParamSize=0;
    AdvChirp_lutChirpParamScale=0;
    AdvChirp_maxTxPhShifIntDither=0;
    #end
    #Advanced chirp Profile config LUT parameters
    #Each data parameter is 4 bits
    AdvChirpLUT_ProfileConfig_LUTAddrOff=0;
    AdvChirpLUT_ProfileConfig_Data1=0;
    AdvChirpLUT_ProfileConfig_Data2=1;
    AdvChirpLUT_ProfileConfig_Data3=2;
    AdvChirpLUT_ProfileConfig_Data4=3;
    #end
    #Advanced chirp Start Freq config LUT parameters
    #The Start Freq data is in GHz
    #Each data parameter is 1 or 2 or 4 bytes depending on ParamSize
    # ParamSize Size in bytes
    # 0 4
    # 1 2
    # 2 1
    AdvChirpLUT_StartFreqConfig_LUTAddrOff=4;
    AdvChirpLUT_StartFreqConfig_ParamSize=1;
    AdvChirpLUT_StartFreqConfig_ParamScale=0;
    AdvChirpLUT_StartFreqConfig_Data1=-0.000001;
    AdvChirpLUT_StartFreqConfig_Data2=0.000000;
    AdvChirpLUT_StartFreqConfig_Data3=0.000001;
    AdvChirpLUT_StartFreqConfig_Data4=-0.000001;
    #end
    #Advanced chirp Freq Slope config LUT parameters
    #The Freq Slope data is in MHz/us
    #Each data parameter is 1 byte
    AdvChirpLUT_FreqSlopeConfig_LUTAddrOff=12;
    AdvChirpLUT_FreqSlopeConfig_Data1=-0.050;
    AdvChirpLUT_FreqSlopeConfig_Data2=0.000;
    AdvChirpLUT_FreqSlopeConfig_Data3=-0.050;
    AdvChirpLUT_FreqSlopeConfig_Data4=0.050;
    #end
    #Advanced chirp Idle time config LUT parameters
    #The Idle time data is in us
    #Each data parameter is 1 or 2 bytes depending on ParamSize
    # 0 2
    # 1 1
    AdvChirpLUT_IdleTimeConfig_LUTAddrOff=16;
    AdvChirpLUT_IdleTimeConfig_ParamSize=0;
    AdvChirpLUT_IdleTimeConfig_ParamScale=0;
    AdvChirpLUT_IdleTimeConfig_Data1=0.01;
    AdvChirpLUT_IdleTimeConfig_Data2=0.02;
    AdvChirpLUT_IdleTimeConfig_Data3=0.00;
    AdvChirpLUT_IdleTimeConfig_Data4=0.01;
    #end
    #Advanced chirp ADC time config LUT parameters
    #The ADC start time data is in us
    # 0 2
    # 1 1
    AdvChirpLUT_ADCTimeConfig_LUTAddrOff=24;
    AdvChirpLUT_ADCTimeConfig_ParamSize=0;
    AdvChirpLUT_ADCTimeConfig_ParamScale=0;
    AdvChirpLUT_ADCTimeConfig_Data1=0.02;
    AdvChirpLUT_ADCTimeConfig_Data2=0.01;
    AdvChirpLUT_ADCTimeConfig_Data3=0.00;
    AdvChirpLUT_ADCTimeConfig_Data4=0.01;
    #end
    #Advanced chirp Tx Enable config LUT parameters
    #b0:TX0 ; b1:TX1; b2:TX2
    AdvChirpLUT_TxEnConfig_LUTAddrOff=32;
    AdvChirpLUT_TxEnConfig_Data1=7;
    AdvChirpLUT_TxEnConfig_Data2=3;
    AdvChirpLUT_TxEnConfig_Data3=1;
    AdvChirpLUT_TxEnConfig_Data4=2;
    #end
    #Advanced chirp BPM Enable config LUT parameters
    AdvChirpLUT_BpmEnConfig_LUTAddrOff=36;
    AdvChirpLUT_BpmEnConfig_Data1=7;
    AdvChirpLUT_BpmEnConfig_Data2=3;
    AdvChirpLUT_BpmEnConfig_Data3=1;
    AdvChirpLUT_BpmEnConfig_Data4=2;
    #end
    #Advanced chirp Tx0 Phase Shifter config LUT parameters
    #The phase shifter data is in degrees
    AdvChirpLUT_Tx0PhShiftConfig_LUTAddrOff=40;
    AdvChirpLUT_Tx0PhShiftConfig_Data1=5.625;
    AdvChirpLUT_Tx0PhShiftConfig_Data2=11.250;
    AdvChirpLUT_Tx0PhShiftConfig_Data3=16.875;
    AdvChirpLUT_Tx0PhShiftConfig_Data4=16.875;
    #end
    #Advanced chirp Tx1 Phase Shifter config LUT parameters
    AdvChirpLUT_Tx1PhShiftConfig_LUTAddrOff=44;
    AdvChirpLUT_Tx1PhShiftConfig_Data1=0.000;
    AdvChirpLUT_Tx1PhShiftConfig_Data2=5.625;
    AdvChirpLUT_Tx1PhShiftConfig_Data3=0.000;
    AdvChirpLUT_Tx1PhShiftConfig_Data4=5.625;
    #end
    #Advanced chirp Tx2 Phase Shifter config LUT parameters
    AdvChirpLUT_Tx2PhShiftConfig_LUTAddrOff=48;
    AdvChirpLUT_Tx2PhShiftConfig_Data1=5.625;
    AdvChirpLUT_Tx2PhShiftConfig_Data2=0.000;
    AdvChirpLUT_Tx2PhShiftConfig_Data3=5.625;
    AdvChirpLUT_Tx2PhShiftConfig_Data4=0.000;
    #end
    In the continuous mode, device will generate one constant tone for a given frequency. It won't be any chirping sequence.
    If you are looking for a long set of chirps continuously then you need to use frame mode to get your modulation scheme, which is default config in this example.
    Now to get the data over CSI2, you need to call required mmwavelink APIs to AWR device.
    C:\ti\mmwave_dfp_02_02_03_01\ti\example\mmWaveLink_Cascade_Example   example configures device for CSI2, even though it is for cascade but you can refer this to implement it for single chip device for CSI2 streaming.
    Jitendra
  • Thanks Jiten,
    I am using the default config in the example and so expect continuous chirps however, don't seem to see any activity on the power sense. I am expecting surges in power for every chirp. How do I debug this? what should I look for?
    Also, before proceeding to CSI2, given the AWR2243 is specifically meant to output on either LVDS or CSI2, I would see some activity even if it configured for either.
    kindly advise,
    Shyam
  • Changing framecount to 0 works as expected
