On FDC2214 datasheet figure 14, the sensor signal is drawn as a full sinusoidal waveform. This would be ideal for our application, as its spectral power should mostly be limited to the sensor frequency and its harmonics.
I developed a custom board with the FDC2214, using the same L and C values as the FDC2214 eval board. On my board, the waveform at IN0A with referenced to ground looks like this:
The waveform only has the positive phase of the sinusoid. The blue trace shows the FFT in range 0-5MHz.
Other users who posted the signal seem to show similar half-waves:
Is it possible to configure the LC Tank circuit to output a full sinusoidal waveform as shown in FDC2214 datasheet figure 14?
-Josh
