Hi Xiang,
What exactly do you mean by dsp cannot run? Can you elaborate?
BR,
Animesh Anand
when i did warm reset in app,and it reset and start from bootloader,and it will be in Endless loop 。Beause the
DSP_PD_STATUS is still be 0x00000030 (Hex). It was accidental .
Hi Xiang,
You said you were performing warm reset then why are sharing a snapshot of power on reset function (POR)?
BR,
Animesh Anand
Becuse when I do warm reset in app,and it will restart from bootloader。So Whether it's POR or wram reset, SOC_rcmDspPowerOnReset(void) is necessary!
Hi Xiang,
Did you made any modification in bootloader, or you are using the default bootloader?
BR,
Animesh Anand
yes,i made some modification in my own bootloader.It was accidental that dsp is in halt
Hi Xiang,
The picture that you shared with me is not quite visible. Can you re send it?
BR,
Animesh Anand
Hi Xiang,
Can you use the original SBL provided by TI and Can check if it is failing or not?
BR,
Animesh Anand
